Orange Pi One Plus
54 minutes ago, lvmc said:
Is H6 significantly faster than H5?
According to their docs, it can run at 1.8Ghz and since it's a 28nm chip, it should use less power than the H5. This doesn't mean that the OrangePi boards will run at 1.8Ghz, but at least it's a possibility. It also supports USB 3.0 and DDR4 RAM. Again, these are capabilities of the chip and not necessarily exposed on the SBCs sold by Orange Pi.
7 hours ago, Larry Bank said:
Is it available yet? Any other H6 boards have pricing availability?
Pine H64 claims to follow the same price with Rock64 with the same DRAM capacity. (Note: the 4GiB version of Pine H64 can only address 3GiB DRAM due to restriction of Allwinner chips).
Hopefully - if the H6 draws less power than the H5 its getting cooler.
As its my feeling - the H5 already run much cooler with the actual mainline kernel against the more hot running legacy kernel.
(here on NanoPi Neo2 and the Orange Pi Zero Plus).
I wouldnt expect more than 1.5Ghz on 28nm
I see Orange have released a H6 board. Android only for the moment, but might be interesting once Linux is available.
https://www.aliexpress.com/store/product/Orange-Pi-One-Plus-H6-1GB-Quad-core-64bit-development-board-Support-android7-0-mini-PC/1553371_32848891030.html
Not a board to cause huge amounts of excitement (limited IO, only 1G ram) but it's a low cost way of testing out the H6.
Edit: Ah, thanks tkaiser. I obviously haven't been keeping up recently.
  • chwe locked this topic
Got my hands on one today. Gonna run some tests. The company already provides Android and Ubuntu Server distributions to it, however im more interested on it for multimedia ends. Lets see how it performs.
Is there plans for Armbian distro to it?
Thanks for noticing that. I've got mine sitting on my desk as a paperweight waiting for someone to release a working Linux distro for it. I'll report back my power consumption and speed measurements later today.
Ugh - now I remember why I appreciate Armbian so much. The Linux distro provided by OrangePi is 1.5GB, yet somehow is missing everything I need. This may take a while...
Update: The board doesn't really seem to have any advantage over H5 boards. The max CPU frequency in the kernel shows as being 1.8Ghz, with the min set to 480Mhz. When pushed by my gcc_perf test, the results didn't fare much better than an RPI3. The power usage is what's really disappointing. The other H2+/H3/H5 boards I've tested usually max out at about 580mA when all 4 cores are cranking. The H6 is supposed to be a 28nm process and I thought that would mean lower power usage. The Orange Pi One Plus maxes out at 830mA when all 4 cores are stressed by gcc. Can anyone else do some testing to see if it matches my results?
Quote
My observations are:
- Android distribution: sucks! Very premature. One can not do anything. I was intended to test video playing, but could not get Kodi to run, neither any other app since Google play is not installed. So, even the apps that show up in the menu do not work. So I rapidly gave up on it.
Current when idle seemed stable at around 380mA
- Ubuntu server: distro does not boot if you have HDMI plugged in....
Idle current is 410mA
Ethernet seems to be really Gigabit... Results for iperf below.
in this case the current rises to 550mA.
[ ID] Interval       Transfer     Bandwidth
[  3]  0.0-60.0 sec  6.34 GBytes   907 Mbits/sec
when using bidirectional simultaneous transfers with the following command:
root@OrangePi:~# iperf -c 192.168.1.100 -t 60 -d
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
Client connecting to 192.168.1.100, TCP port 5001
TCP window size:  113 KByte (default)
[  5] local 192.168.1.143 port 37423 connected with 192.168.1.100 port 5001
[  4] local 192.168.1.143 port 5001 connected with 192.168.1.100 port 51684
[  5]  0.0-60.0 sec  4.56 GBytes   653 Mbits/sec
[  4]  0.0-60.0 sec  4.92 GBytes   705 Mbits/sec
Then I run the gcc_perf @Larry Bank from here: https://github.com/bitbank2/gcc_perf
Average current was around 560mA, with peak 640mA.
My conclusion is: This board makes sense as a remote video player, connected to some TV with Kodi, probably, so that you can stream from your main server. That because it has great ethernet, with great 4K video decoding capabilities....
One USB3 would make it a good choice for servers... But no...
probably not as long as things do not improve:
  • Xunlong provides an outdated 3.10.65 kernel (3.10.108 is the newest and reached EOL in Nov 2017),
  • Mainline is... http://linux-sunxi.org/Mainlining_Effort#Status_Matrix on the way. (Edit: but for sure not ready yet, keep going @Icenowy ;))
  • There are no schematics released for the OPi One Plus (there are schematics in the 'user manual collection' but they are for the OPi Lite and it locks like copy paste...  (Design name: H6-PROTO, DC-In 12V/1A --> 5V/2A)
spottend so far (xunlongs Ubuntu):
  • Thermal zones are there :)
  • powering over microUSB 'works' (don't do it, but I've to wait for my second 5V barrel plug..)
  • cpu freq seems to stay at 1800 MHz idle TZ0 48°C (1488MHz stress -c 4 ~10min TZ0: 83°C, TZ1: 69°C)
  • minerd (~5min Total: 4.61 khash/s at 1488MHZ TZ087-89°C,  trip_point_1 would be at 90°C)
keep in mind,  those numbers do not benchmark the SoC (it might benchmark the current available combination of OS and SoC). Cause SD-card is near to SoC, I stopped minerd to avoid a SD-Card BBQ...
Hmm.. after minerd, the SoC idles sometimes at 480MHz...  Next topic might be the investigation of the  PMIC (AXP805).
A 4.9 kernel is released by Allwinner yesterday (as UTC+8).
P.S. AXP805 has only power key (for power down functionality) and DCDC+LDO, like RK805 from RK(used with RK3328, also OTT):-)
Hoped to find something like voltage monitoring (on input) but as far as I understand the manual of the AXP805, there is no such possibility.  :( Would it make a goods beginners board (as soon as kernel is 'in a good shape') cause it would avoid 'powering gone wrong'...  :P - anyway, every barrel plug powered board is a bit more beginners friendly..
I don't follow sunxi mailing list fully (mostly cause I wouldn't understand most of the things discussed there.. :P ), but as I saw for the A64s PMIC was a bit problematic (handled by AR100, whereas complier for it is not GPL). As I understand, this issue was solved with those commits. Is the H6 also affected by such problems? (Allwinner had PMIC since a long time on the AR100 but it was possible to avoid using it).
More experienced users have to decide if it's worth to use this kernel... But nice to see that allwinner publishes this stuff faster than in the past. :) btw. for those interested in it: https://github.com/Allwinner-Homlet?tab=repositories there you go. :)
Hello!
I am starting on this space and I would ask help for this!
I installed an android on the orange pi one plus based on the description, but so much happened that appeared on the display the H6 allwiner logo and that's all.
I use a 5v/3A adapter, I install the android with the PhoenixCard to a 16GB micro SD
I am an absolute beginner, and I cannot realise the problem!
Any idea?
Any idea?
This board at this stage is probably not the best for absolute beginners. You will only find yourself frustrated. Start your explorations with previous versions (preferable H3 Orangepi PC+), which are decently supported with Linux, Openelec, Android, Retrogaming, ...
And here we are mainly - if not strictly - focused on (Debian like) Linux experience. Android or proprietary Phoenix tools are mainly out of this interest zone.
But anyway, welcome for trying things and not being an absolute beginner anymore :)
Did someone try to build u-boot or kernel with their sources?
Seems that the whole thing is somehow messed up.  From their buildscript I expect that it should build 'u-boot-2014.07' but it seems that it messes up somewhere in 'u-boot-2011.09'. Not that I would expect that I wouldn't fail (completely new on this field of stuff and starting with a 'not so well' documented script might be an overkill :rolleyes:),  but I'm interested if someone had a look into it. :)
btw. up since 7days without load (hadn't time/interest to play with it).. :P
orangepi@OrangePi:~$ uptime
 15:23:47 up 7 days, 16:22,  1 user,  load average: 3.00, 3.01, 3.05
checked dmesg the first time:
Spoiler
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.65 (xunlong@xunlong) (gcc version 4.9.3 201501                                    13 (prerelease) (Linaro GCC 4.9-2015.01-3) ) #35 SMP PREEMPT Tue Jan 23 18:13:02                                     CST 2018
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: sun50iw6
[    0.000000] bootconsole [earlycon0] enabled
[    0.000000] cma: CMA: reserved 16 MiB at 7f000000
[    0.000000] On node 0 totalpages: 262144
[    0.000000]   DMA zone: 3584 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc03ef86000 s20224 r8192 d207                                    36 u49152
[    0.000000] pcpu-alloc: s20224 r8192 d20736 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag                                    es: 258560
[    0.000000] Kernel command line: console=tty0 console=ttyS0,115200n8 no_conso                                    le_suspend earlyprintk=sunxi-uart,0x05000000 mac_addr=72:D6:05:4F:B9:3B root=/de                                    v/mmcblk0p2 ro rootwait
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Memory: 1024MB = 1024MB total
[    0.000000] Memory: 983456k/983456k available, 65120k reserved
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 M                                    B)
                   vmemmap : 0xffffffbc00e00000 - 0xffffffbc01c00000   (    14 M                                    B)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 M                                    B)
                   memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 M                                    B)
                     .init : 0xffffffc000b7c000 - 0xffffffc000c0af00   (   572 k                                    B)
                     .text : 0xffffffc000080000 - 0xffffffc000b7b924   ( 11247 k                                    B)
                     .data : 0xffffffc000c0b000 - 0xffffffc000dbc0b8   (  1733 k                                    B)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] allocated 4194304 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memor                                    y cgroups
[    0.030000] Calibrating delay loop (skipped), value calculated using timer fr                                    equency.. 48.00 BogoMIPS (lpj=240000)
[    0.030008] pid_max: default: 32768 minimum: 301
[    0.034597] Security Framework initialized
[    0.038535] SELinux:  Initializing.
[    0.040054] SELinux:  Starting in permissive mode
[    0.040156] Mount-cache hash table entries: 256
[    0.044949] Initializing cgroup subsys debug
[    0.048616] Initializing cgroup subsys memory
[    0.050024] Initializing cgroup subsys freezer
[    0.054367] ftrace: allocating 30235 entries in 119 pages
[    0.080595] CPU0: update cpu_power 1024
[    0.080652] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counter                                    s available
[    0.081514] virtual base = 0xffffff800000a000.
[    0.081566] gicd_base = 0xffffff800000c000.
[    0.081607] gicc_base = 0xffffff800000e000.
[    0.083434] CPU1: Booted secondary processor
[    0.083434] CPU1: update cpu_power 1024
[    0.083475] CPU2: Booted secondary processor
[    0.083475] CPU2: update cpu_power 1024
[    0.083475] CPU3: Booted secondary processor
[    0.083475] CPU3: update cpu_power 1024
[    0.083475] Brought up 4 CPUs
[    0.090009] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.096480] devtmpfs: initialized
[    0.102548] atomic64 test passed
[    0.102548] pinctrl core: initialized pinctrl subsystem
[    0.105248] NET: Registered protocol family 16
[    0.110083] dump_class_init,844, success
[    0.112883] vdso: 2 pages (1 code, 1 data) at base ffffffc000c11000
[    0.115810] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.120968] software IO TLB [mem 0x7cc00000-0x7d000000] (4MB) mapped at [ffff                                    ffc03cc00000-ffffffc03cffffff]
[    0.130436] DMA: preallocated 256 KiB pool for atomic allocations
[    0.140185] pll_periph0-set_default_rate=600000000 success!
[    0.150024] pll_periph1-set_default_rate=600000000 success!
[    0.155484] pll_video1-set_default_rate=594000000 success!
[    0.160029] pll_de-set_default_rate=696000000 success!
[    0.165308] de-set_default_source=pll_de success!
[    0.169635] de-set_default_rate=696000000 success!
[    0.170626] clk sata not found in of_sunxi_periph_clk_setup
[    0.175464] clk sata_24m not found in of_sunxi_periph_clk_setup
[    0.180620] pciemaxi-set_default_rate=200000000 success!
[    0.185217] pcieaux-set_default_rate=1000000 success!
[    0.190053] hdmi-set_default_source=pll_video1 success!
[    0.195278] tcon_tv-set_default_source=pll_video1 success!
[    0.200146] hdmi_hdcp-set_default_source=pll_periph1 success!
[    0.210765] sun50iw6p1-r-pinctrl r_pio: initialized sunXi PIO driver
[    0.221837] sun50iw6p1-pinctrl pio: initialized sunXi PIO driver
[    0.225788] sunxi hwspinlock vbase:0xffffff800005e000
[    0.240194] [ARISC] :sunxi-arisc driver v1.60
[    0.240787] [ARISC] :sunxi-arisc driver v1.60 startup succeeded
[    0.260128] bio: create slab <bio-0> at 0
[    0.260223] pwm module init!
[    0.270185] SCSI subsystem initialized
[    0.270185] usbcore: registered new interface driver usbfs
[    0.270185] usbcore: registered new interface driver hub
[    0.270185] usbcore: registered new device driver usb
[    0.270645] media: Linux media interface: v0.10
[    0.272899] Linux video capture interface: v2.00
[    0.281193] [axp806] chip id detect 0x60 !
[    0.332130] drm config service not available: FFFFFFFF
[    0.332130]  irq = 89
[    0.332130] Attached to iommu domain
[    0.332130] Advanced Linux Sound Architecture Driver Initialized.
[    0.340124] Bluetooth: Core ver 2.16
[    0.343109] NET: Registered protocol family 31
[    0.344283] Bluetooth: HCI device and connection manager initialized
[    0.350015] Bluetooth: HCI socket layer initialized
[    0.354772] Bluetooth: L2CAP socket layer initialized
[    0.359729] Bluetooth: SCO socket layer initialized
[    0.360160] cfg80211: Calling CRDA to update world regulatory domain
[    0.366131] [DISP]disp_module_init
[    0.370504] [DISP] disp_boot_para_parse,line:685:of_property_read disp.init_d                                    isp fail
[    0.377375] [DISP] init_disp:0x0
[    0.380013] [DISP] boot_disp:0x0
[    0.384726] [DISP] fb_base:0x0
[    0.394934] [DISP] Fb_copy_boot_fb,line:1065:no boot_fb0
[    0.395074] [DISP]disp_module_init finish
[    0.395074] acx00_detect, l:382, twi_id:3, adapter->nr:1
[    0.400019] acx00_detect, l:382, twi_id:3, adapter->nr:3
[    0.405263] acx00_i2c_probe,l:264
[    0.405263] acx00_init_work,l:127
[    0.410509] __sid_efuse_key_is_readable()609 - The key oem write protect bit                                     not burned!
[    0.420250] sunxi budget cooling probe start !
[    0.421666] CPU freq cooling register Success
[    0.425921] CPU hotplug cooling register Success
[    0.430074] CPU budget cooling register Success
[    0.434447] __sid_efuse_key_is_readable()609 - The key thermal_sensor write p                                    rotect bit not burned!
[    0.440427] Switching to clocksource arch_sys_counter
[    0.454598] FS-Cache: Loaded
[    0.455022] CacheFiles: Loaded
[    0.465038] get det_vbus is fail, 84
[    0.466188] [ddrfreq] disabled, but continue to get freq!
[    0.466464] devfreq dramfreq: Couldn't update frequency transition informatio                                    n.
[    0.466556] sunxi_dramfreq_irq_mask_control: the key master doesn't exit
[    0.468746] NET: Registered protocol family 2
[    0.473608] TCP established hash table entries: 8192 (order: 5, 131072 bytes)
[    0.480313] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[    0.486698] TCP: Hash tables configured (established 8192 bind 8192)
[    0.493077] TCP: reno registered
[    0.496171] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.502145] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.508545] NET: Registered protocol family 1
[    0.512964] RPC: Registered named UNIX socket transport module.
[    0.518574] RPC: Registered udp transport module.
[    0.523356] RPC: Registered tcp transport module.
[    0.527952] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.534592] Unpacking initramfs...
[    0.550713] acx00_init_work,l:134
[    0.574194] Freeing initrd memory: 1064K (ffffffc036b71000 - ffffffc036c7b000                                    )
[    0.574706] hw perfevents: Failed to parse /pmu/interrupt-affinity[0]
[    0.575945] lock super standby defaultly!
[    0.575993] lookup_scene_lock_name: new scene lock super_standby
[    0.576048] scene_lock_init name=super_standby
[    0.580033] scene_lock: super_standby, type 5, count 1
[    0.585718] audit: initializing netlink socket (disabled)
[    0.590537] type=2000 audit(0.590:1): initialized
[    0.603557] FS-Cache: Netfs 'nfs' registered for caching
[    0.604278] FS-Cache: Netfs 'cifs' registered for caching
[    0.606083] NTFS driver 2.1.30 [Flags: R/W].
[    0.610331] fuse init (API version 7.22)
[    0.614689] msgmni has been set to 1954
[    0.617771] SELinux:  Registering netfilter hooks
[    0.618845] io scheduler noop registered
[    0.621721] io scheduler deadline registered
[    0.626117] io scheduler cfq registered (default)
[    0.631144] [pm]aw_pm_init!
[    0.633463] np name = /soc@03000000/rtc@07000000.
[    0.638052] base = ffffff800248a100, len = 8.
[    0.642505] pmu name: pmic0 .
[    0.645470] Warning: can not find np for pmic0.
[    0.650044] pmu name: pmic1 .
[    0.652952] Warning: can not find np for pmic1.
[    0.660680] add_sys_pwr_dm: get ldo name  for id: vdd-cpus failed
[    0.663600] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[    0.670827] add_sys_pwr_dm: axp80_cldo1 ldo already alwayson.
[    0.675444] add_sys_pwr_dm: get ldo name  for id: vcc-ldoin failed
[    0.682682] add_sys_pwr_dm: get ldo name  for id: vcc-pc failed
[    0.687469] after inited: sys_mask config = 0x4a15.
[    0.692537] Warning: can not find np for dynamic_standby_para.
[    0.698444] [pm]valid
[    0.700652] [pm]valid
[    0.702863] Notice: sun9i & sun8iw5 & sun50i not need support normal standby,        change to super standby.
[    0.712932] sunxi_bootup_extend_probe: bootup extend state 1
[    0.718072] bootup extend probe ok
[    0.721879] failed to get standby led pin assign
[    0.726085] gpio_pin_1(359) gpio_is_valid
[    0.730271] gpio_pin_2(356) gpio_is_valid
[    0.734214] gpio_pin_3(102) gpio_is_valid
[    0.738255] gpio name is PL7, ret = 0
[    0.741872] gpio name is PL4, ret = 0
[    0.745490] gpio name is PD6, ret = 0
[    0.749181] gpio_init finish with uesd
[    0.753170] Console: switching to colour frame buffer device 240x67
[    0.776521] sw_uart_probe()1448 - uart0 error to get bt property
[    0.776703] uart0: ttyS0 at MMIO 0x5000000 (irq = 32) is a SUNXI
[    0.776864] sw_console_setup()1271 - console setup baud 115200 parity n bits                                     8, flow n
[    0.779712] console [ttyS0] enabled, bootconsole disabled
[    0.808491] uart1: ttyS1 at MMIO 0x5000400 (irq = 33) is a SUNXI
[    0.820485] sw_uart_probe()1448 - uart3 error to get bt property
[    0.827219] uart3: ttyS3 at MMIO 0x5000c00 (irq = 35) is a SUNXI
[    0.835179] misc dump reg init
[    0.842056] loop: module loaded
[    0.845604] Get boot type cmd line fail
[    0.851653] spi spi0: master is unqueued, this is deprecated
[    0.864180] __sid_efuse_key_is_readable()609 - The key oem write protect bit                                     not burned!
[    0.874592] tun: Universal TUN/TAP device driver, 1.6
[    0.880323] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.888195] gmac-power2: NULL
[    0.892180] PPP generic driver version 2.4.2
[    0.897258] PPP BSD Compression module registered
[    0.902595] PPP Deflate Compression module registered
[    0.908230] PPP MPPE Compression module registered
[    0.913776] NET: Registered protocol family 24
[    0.918746] PPTP driver version 0.8.5
[    0.923165] hso: drivers/net/usb/hso.c: Option Wireless
[    0.929212] usbcore: registered new interface driver hso
[    0.935328] usbcore: registered new interface driver asix
[    0.941534] usbcore: registered new interface driver ax88179_178a
[    0.948537] usbcore: registered new interface driver cdc_ether
[    0.955237] usbcore: registered new interface driver net1080
[    0.961759] usbcore: registered new interface driver cdc_subset
[    0.968532] usbcore: registered new interface driver zaurus
[    0.974956] usbcore: registered new interface driver cdc_ncm
[    0.981367] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.988882] get ehci0-controller, regulator_io is no nocare
[    0.995377] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi                                    _ehci: 0xffffffc000eb7c70, 0x:ffffff8002532000, irq_no:38
[    1.009167] sunxi-ehci 5101000.ehci0-controller: SW USB2.0 'Enhanced' Host Co                                    ntroller (EHCI) Driver
[    1.019493] sunxi-ehci 5101000.ehci0-controller: new USB bus registered, assi                                    gned bus number 1
[    1.029610] sunxi-ehci 5101000.ehci0-controller: irq 56, io mem 0xffffffc0008                                    b2d80
[    1.050023] sunxi-ehci 5101000.ehci0-controller: USB 0.0 started, EHCI 1.00
[    1.057864] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.065684] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=                                    1
[    1.073889] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Dr                                    iver
[    1.082363] usb usb1: Manufacturer: Linux 3.10.65 ehci_hcd
[    1.088475] usb usb1: SerialNumber: sunxi-ehci
[    1.120159] hub 1-0:1.0: USB hub found
[    1.128837] hub 1-0:1.0: 1 port detected
[    1.138221] get ehci3-controller, regulator_io is no nocare
[    1.149105] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi                                    _ehci: 0xffffffc000eb8648, 0x:ffffff800253a000, irq_no:3c
[    1.167491] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Co                                    ntroller (EHCI) Driver
[    1.182500] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assi                                    gned bus number 2
[    1.197275] sunxi-ehci 5311000.ehci3-controller: irq 60, io mem 0xffffffc0008                                    b2d80
[    1.230036] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
[    1.242830] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.255334] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=                                    1
[    1.268344] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Dr                                    iver
[    1.281699] usb usb2: Manufacturer: Linux 3.10.65 ehci_hcd
[    1.292795] usb usb2: SerialNumber: sunxi-ehci
[    1.330159] hub 2-0:1.0: USB hub found
[    1.339086] hub 2-0:1.0: 1 port detected
[    1.348861] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.360887] get ohci0-controller, regulator_io is no nocare
[    1.372050] hci: request ohci0-controller gpio:357
[    1.382397] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi                                    _ohci: 0xffffffc000eb6f50
[    1.397969] sunxi-ohci 5101000.ohci0-controller: SW USB2.0 'Open' Host Contro                                    ller (OHCI) Driver
[    1.412927] sunxi-ohci 5101000.ohci0-controller: new USB bus registered, assi                                    gned bus number 3
[    1.427889] sunxi-ohci 5101000.ohci0-controller: irq 57, io mem 0xffffffc000e                                    b6f50
[    1.503997] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.517072] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=                                    1
[    1.530503] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.543867] usb usb3: Manufacturer: Linux 3.10.65 ohci_hcd
[    1.555338] usb usb3: SerialNumber: sunxi-ohci
[    1.590162] hub 3-0:1.0: USB hub found
[    1.599423] hub 3-0:1.0: 1 port detected
[    1.609439] get ohci3-controller, regulator_io is no nocare
[    1.620963] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi                                    _ohci: 0xffffffc000eb7928
[    1.636699] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Contro                                    ller (OHCI) Driver
[    1.651799] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assi                                    gned bus number 4
[    1.666826] sunxi-ohci 5311000.ohci3-controller: irq 61, io mem 0xffffffc000e                                    b7928
[    1.743996] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.757080] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=                                    1
[    1.770509] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.783857] usb usb4: Manufacturer: Linux 3.10.65 ohci_hcd
[    1.795299] usb usb4: SerialNumber: sunxi-ohci
[    1.830161] hub 4-0:1.0: USB hub found
[    1.839476] hub 4-0:1.0: 1 port detected
[    1.850081] get xhci-controller, regulator_io is no nocare
[    1.861610] hci: request xhci-controller gpio:357
[    1.872413] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.883879] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu                                    mber 5
[    1.898419] xhci-hcd xhci-hcd.0.auto: irq 58, io mem 0x05200000
[    1.910447] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    1.923436] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=                                    1
[    1.936941] usb usb5: Product: xHCI Host Controller
[    1.947847] usb usb5: Manufacturer: Linux 3.10.65 xhci-hcd
[    1.959510] usb usb5: SerialNumber: xhci-hcd.0.auto
[    1.970829] xHCI xhci_add_endpoint called for root hub
[    1.970835] xHCI xhci_check_bandwidth called for root hub
[    2.000170] hub 5-0:1.0: USB hub found
[    2.009777] hub 5-0:1.0: 1 port detected
[    2.020030] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.031824] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus nu                                    mber 6
[    2.046070] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    2.059317] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=                                    1
[    2.072962] usb usb6: Product: xHCI Host Controller
[    2.083832] usb usb6: Manufacturer: Linux 3.10.65 xhci-hcd
[    2.095405] usb usb6: SerialNumber: xhci-hcd.0.auto
[    2.106500] xHCI xhci_add_endpoint called for root hub
[    2.106505] xHCI xhci_check_bandwidth called for root hub
[    2.130152] hub 6-0:1.0: USB hub found
[    2.139585] hub 6-0:1.0: 1 port detected
[    2.150015] usbcore: registered new interface driver usb-storage
[    2.162234] usbcore: registered new interface driver ums-alauda
[    2.174239] usbcore: registered new interface driver ums-cypress
[    2.186278] usbcore: registered new interface driver ums-datafab
[    2.198270] usbcore: registered new interface driver ums_eneub6250
[    2.210434] usbcore: registered new interface driver ums-freecom
[    2.222377] usbcore: registered new interface driver ums-isd200
[    2.234201] usbcore: registered new interface driver ums-jumpshot
[    2.246088] usbcore: registered new interface driver ums-karma
[    2.257480] usbcore: registered new interface driver ums-onetouch
[    2.269147] usbcore: registered new interface driver ums-realtek
[    2.280634] usbcore: registered new interface driver ums-sddr09
[    2.292017] usbcore: registered new interface driver ums-sddr55
[    2.303290] usbcore: registered new interface driver ums-usbat
[    2.314532] usbcore: registered new interface driver usbserial
[    2.325588] usbcore: registered new interface driver option
[    2.336306] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.349297] mousedev: PS/2 mouse device common for all mice
[    2.360291] usbcore: registered new interface driver xpad
[    2.370935] usbcore: registered new interface driver usb_acecad
[    2.382130] usbcore: registered new interface driver aiptek
[    2.392832] usbcore: registered new interface driver gtco
[    2.403349] usbcore: registered new interface driver hanwang
[    2.413995] usbcore: registered new interface driver kbtab
[    2.424373] usbcore: registered new interface driver wacom
[    2.435571] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
[    2.446552] sunxi-rtc rtc: RTC enabled
[    2.455166] i2c /dev entries driver
[    2.463508] IR NEC protocol handler initialized
[    2.472540] IR RC5(x) protocol handler initialized
[    2.481794] IR RC6 protocol handler initialized
[    2.490778] IR JVC protocol handler initialized
[    2.499553] IR Sony protocol handler initialized
[    2.508778] IR RC5 (streamzap) protocol handler initialized
[    2.518913] IR SANYO protocol handler initialized
[    2.528008] IR MCE Keyboard/mouse protocol handler initialized
[    2.538314] sunxi cedar version 0.1
[    2.546154] VE: install start!!!
[    2.558838] cedar_ve: cedar-ve the get irq is 121
[    2.568087] VE: install end!!!
[    2.580506] google_vp9: sunxi google vp9 version 0.1
[    2.589580] google_vp9: [google vp9]: install start!!!
[    2.599115] google_vp9: google vp9: the get irq is 122
[    2.608761] google_vp9: [cedar]: install end!!!
[    2.618172] input: axp80-powerkey as /devices/soc/pmu0/axp80-powerkey/input/i                                    nput0
[    2.647319] sunxi gpu cooling probe start !
[    2.655734] CPU gpu cooling register Success
[    2.664568] device-mapper: uevent: version 1.0.3
[    2.673711] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-d                                    evel@redhat.com
[    2.686920] Bluetooth: HCI UART driver ver 2.2
[    2.695591] Bluetooth: HCI H4 protocol initialized
[    2.704596] Bluetooth: HCI Realtek H5 protocol initialized
[    2.714655] rtk_btcoex: rtk_uart_coex_init, version: 1.1
[    2.724248] rtk_btcoex: create workqueue
[    2.733713] [cpufreq] use dvfs_table_0
[    2.747757] cpuidle: using governor ladder
[    2.755118] cpuidle: using governor menu
[    2.763283] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v0.83 2017-08-                                    17 16:22) Compiled in Jan 23 2018 at 18:12:21
[    2.778442] sunxi-mmc sdc0: ***ctl-spec-caps*** 80
[    2.786521] sunxi-mmc sdc0: regulator prop vmmc,str vcc-sdcv
[    2.795562] sunxi-mmc sdc0: regulator prop vqmmc,str vcc-sdcvq33
[    2.804968] sunxi-mmc sdc0: regulator prop vdmmc,str vcc-sdcvd
[    2.815528] sunxi-mmc sdc0: no earse
[    2.822201] sunxi-mmc sdc0: Got CD GPIO #166.
[    2.829875] sunxi-mmc sdc0: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 t                                    iming LEGACY(SDR12) dt B
[    2.860014] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 widt                                    h 1 timing LEGACY(SDR12) dt B
[    2.890118] sunxi-mmc sdc0: base:0xffffff800257e000 irq:67
[    2.891758] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 widt                                    h 1 timing LEGACY(SDR12) dt B
[    2.894155] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 widt                                    h 1 timing LEGACY(SDR12) dt B
[    2.899397] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 15 widt                                    h 1 timing LEGACY(SDR12) dt B
[    2.899436] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 15 widt                                    h 1 timing LEGACY(SDR12) dt B
[    2.901827] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 15 widt                                    h 1 timing LEGACY(SDR12) dt B
[    2.942052] mmc0: host does not support reading read-only switch. assuming wr                                    ite-enable.
[    2.943895] sunxi-mmc sdc0: sdc set ios: clk 400000Hz bm PP pm ON vdd 15 widt                                    h 1 timing SD-HS(SDR25) dt B
[    2.943934] sunxi-mmc sdc0: sdc set ios: clk 50000000Hz bm PP pm ON vdd 15 wi                                    dth 1 timing SD-HS(SDR25) dt B
[    2.943993] sunxi-mmc sdc0: sdc set ios: clk 50000000Hz bm PP pm ON vdd 15 wi                                    dth 4 timing SD-HS(SDR25) dt B
[    2.944015] mmc0: new high speed SDHC card at address 59b4
[    3.030320] mmcblk0: mmc0:59b4 EB2MW 29.8 GiB
[    3.030438] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v0.83 2017-08-                                    17 16:22) Compiled in Jan 23 2018 at 18:12:21
[    3.030457] sunxi-mmc sdc1: Can't get vmmc regulator string
[    3.030460] sunxi-mmc sdc1: Can't get vqmmc regulator string
[    3.030463] sunxi-mmc sdc1: Can't get vdmmc regulator string
[    3.030465] get() with no identifier
[    3.030466] get() with no identifier
[    3.030467] get() with no identifier
[    3.030469] sunxi-mmc sdc1: No vmmc regulator found
[    3.030471] sunxi-mmc sdc1: No vqmmc regulator found
[    3.030473] sunxi-mmc sdc1: No vdmmc regulator found
[    3.130723] sunxi-mmc sdc1: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 t                                    iming LEGACY(SDR12) dt B
[    3.144429] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[    3.145250]  mmcblk0: p1 p2
[    3.180020] sunxi-mmc sdc1: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 widt                                    h 1 timing LEGACY(SDR12) dt B
[    3.210031] sunxi-mmc sdc1: base:0xffffff800267a000 irq:68
[    3.210323] sunxi-mmc sdc1: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 widt                                    h 1 timing LEGACY(SDR12) dt B
[    3.212992] sunxi-mmc sdc1: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 widt                                    h 1 timing LEGACY(SDR12) dt B
[    3.214365] mmc1: host doesn't support card's voltages
[    3.214368] mmc1: error -22 whilst initialising SDIO card
[    3.214912] sunxi-mmc sdc1: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 widt                                    h 1 timing LEGACY(SDR12) dt B
[    3.215502] sunxi-mmc sdc1: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 t                                    iming LEGACY(SDR12) dt B
[    3.295602] [EMCE]:Unsupport Current Storage!
[    3.304052] sunxi_emce_probe()474emce hw init failed!
[    3.313267] emce: probe of emce failed with error -22
[    3.322752] hidraw: raw HID events driver (C) Jiri Kosina
[    3.336369] PT71600 Driver - version 2.0.0-Half-IMA!
[    3.345912] usbcore: registered new interface driver usbhid
[    3.355820] usbhid: USB HID core driver
[    3.364132] zram: Created 1 device(s) ...
[    3.372691] ashmem: initialized
[    3.379976] logger: created 256K log 'log_main'
[    3.388821] logger: created 256K log 'log_events'
[    3.398319] logger: created 256K log 'log_radio'
[    3.407177] logger: created 256K log 'log_system'
[    3.416729] usbcore: registered new interface driver snd-usb-audio
[    3.428978] Creating PCM netlink successfully
[    3.431046] sndahub sound.3:  sunxi-ahub-aif1 <-> 5097000.cpudai0-controller                                     mapping ok
[    3.444759] sndahub sound.3:  sunxi-ahub-aif2 <-> 5097000.cpudai1-controller                                     mapping ok
[    3.458176] sndahub sound.3:  sunxi-ahub-aif3 <-> 5097000.cpudai2-controller                                     mapping ok
[    3.472296] sndhdmi sndhdmi:  sndhdmi <-> 5097000.ahub_daudio1 mapping ok
[    3.484168] u32 classifier
[    3.490705]     Actions configured
[    3.497838] Netfilter messages via NETLINK v0.30.
[    3.506726] nf_conntrack version 0.5.0 (7819 buckets, 31276 max)
[    3.517204] ctnetlink v0.93: registering with nfnetlink.
[    3.526716] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.538110] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.548487] xt_time: kernel timezone is -0000
[    3.556891] ipip: IPv4 over IPv4 tunneling driver
[    3.565973] gre: GRE over IPv4 demultiplexor driver
[    3.574929] ip_gre: GRE over IPv4 tunneling driver
[    3.584603] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.594244] arp_tables: (C) 2002 David S. Miller
[    3.603015] TCP: bic registered
[    3.610045] TCP: cubic registered
[    3.617099] TCP: westwood registered
[    3.624630] TCP: htcp registered
[    3.631606] Initializing XFRM netlink socket
[    3.640309] NET: Registered protocol family 10
[    3.649245] mip6: Mobile IPv6
[    3.656231] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.666012] sit: IPv6 over IPv4 tunneling driver
[    3.675171] NET: Registered protocol family 17
[    3.683600] NET: Registered protocol family 15
[    3.692045] Bluetooth: RFCOMM TTY layer initialized
[    3.700970] Bluetooth: RFCOMM socket layer initialized
[    3.710071] Bluetooth: RFCOMM ver 1.11
[    3.717452] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.726773] Bluetooth: BNEP filters: protocol multicast
[    3.735819] Bluetooth: BNEP socket layer initialized
[    3.744588] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.754470] Bluetooth: HIDP socket layer initialized
[    3.763598] Registering SWP/SWPB emulation handler
[    3.773230] HDMI 2.0 driver init start!
[    3.781243] [DISP] boot_disp:0x0
[    3.788036] boot_hdmi=false
[    3.794595] hdmi reg base:0xffffffc042f00000 esm_hpi_base:0xffffffc042f08000
[    3.807637] HDMI2.0 module init end
[    3.815375] [DISP] boot_disp:0x0
[    4.410025] [HDMI receive params]: tv mode: 0xa format:0x1 data bits:0x0 eotf                                    :0x4 cs:0x101 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
[    5.420217] [HDMI2.0]CEA VIC=16:
[    5.423701] 1920x1080p
[    5.429648] @60 Hz
[    5.430506] 16:9,
[    5.436005] 8-bpp
[    5.436590] YCbCr-444
[    5.446000] BT709
[    5.451368] eotf:SDR_LUMINANCE_RANGE
[    5.570604] [DISP] disp_device_attached_and_enable,line:192:attched ok, mgr0<                                    -->dev0
[    5.582647] [DISP] disp_device_attached_and_enable,line:205:type:4,mode:10,fm                                    t:yuv444,bits:8bits,eotf:4,cs:257 dvi_hdmi:2, range:2 scan:0 ratio:8
[    5.601055] __sid_efuse_key_is_readable()609 - The key oem write protect bit                                     not burned!
[    5.632111] usb_serial_number:20080411
[    5.639962] file system registered
[    5.648061] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    5.659162] android_usb gadget: Number of LUNs=3
[    5.667667]  lun0: LUN: removable file: (no medium)
[    5.676459]  lun1: LUN: removable file: (no medium)
[    5.685239]  lun2: LUN: removable file: (no medium)
[    5.694337] android_usb gadget: android_usb ready
[    5.702955] sunxi-rtc rtc: setting system clock to 2018-01-01 00:00:08 UTC (1                                    514764808)
[    5.718866] snddaudio snddaudio2: codec: snd-soc-dummy, codec_dai: snd-soc-du                                    mmy-dai.
[    5.731394] snddaudio snddaudio2:  snd-soc-dummy-dai <-> 5097000.ahub_daudio2                                     mapping ok
[    5.744595] snddaudio snddaudio3: codec: acx00-codec, codec_dai: acx00-dai.
[    5.811190] snddaudio snddaudio3:  acx00-dai <-> 5097000.ahub_daudio3 mapping                                     ok
[    5.823855] ALSA device list:
[    5.830645]   #0: sndahub
[    5.836930]   #1: sndhdmi
[    5.843404]   #2: snddaudio2
[    5.850014]   #3: sndacx00-codec
[    5.857141] Freeing unused kernel memory: 568K (ffffffc000b7c000 - ffffffc000                                    c0a000)
[    5.921359] EXT2-fs (mmcblk0p2): error: couldn't mount because of unsupported                                     optional features (240)
[    5.936331] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incomp                                    atibilities
[    5.988345] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O                                    pts: (null)
[    6.355082] systemd[1]: Failed to insert module 'autofs4': No such file or di                                    rectory
[    6.394429] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SEL                                    INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +                                    XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    6.418741] systemd[1]: Detected architecture arm64.
[    6.440939] systemd[1]: Set hostname to <OrangePi>.
[    6.867106] systemd[1]: Reached target Swap.
[    6.890104] systemd[1]: Reached target Encrypted Volumes.
[    6.920191] systemd[1]: Started Dispatch Password Requests to Console Directo                                    ry Watch.
[    6.950203] systemd[1]: Listening on Syslog Socket.
[    6.980212] systemd[1]: Created slice System Slice.
[    7.010204] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.040170] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    7.070149] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.100147] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    7.130193] systemd[1]: Listening on Journal Socket.
[    7.161127] systemd[1]: Mounting Debug File System...
[    7.191311] systemd[1]: Starting Nameserver information manager...
[    7.232004] systemd[1]: Starting Load Kernel Modules...
[    7.261191] systemd[1]: Starting Set console keymap...
[    7.290521] systemd[1]: Started Forward Password Requests to Wall Directory W                                    atch.
[    7.320365] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.351227] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.380286] systemd[1]: Created slice User and Session Slice.
[    7.410091] systemd[1]: Reached target Slices.
[    7.440211] systemd[1]: Listening on udev Kernel Socket.
[    7.470086] systemd[1]: Reached target Remote File Systems (Pre).
[    7.500061] systemd[1]: Reached target Remote File Systems.
[    7.531273] systemd[1]: Starting Journal Service...
[    7.560293] systemd[1]: Listening on udev Control Socket.
[   10.001080] systemd[1]: Starting Create list of required static device nodes                                     for the current kernel...
[   10.032259] systemd[1]: Mounted Debug File System.
[   10.062500] systemd[1]: Started Load Kernel Modules.
[   10.090926] systemd[1]: Started Set console keymap.
[   10.144331] systemd[1]: Mounting Configuration File System...
[   10.171218] systemd[1]: Starting Apply Kernel Variables...
[   10.201353] systemd[1]: Mounting FUSE Control File System...
[   10.231715] systemd[1]: Mounted Configuration File System.
[   10.260181] systemd[1]: Mounted FUSE Control File System.
[   15.252345] systemd[1]: Started Nameserver information manager.
[   15.280823] systemd[1]: Started Create list of required static device nodes f                                    or the current kernel.
[   15.324844] systemd[1]: Starting Create Static Device Nodes in /dev...
[   15.360228] systemd[1]: Reached target Network (Pre).
[   20.433396] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   20.445044] systemd[1]: Started Remount Root and Kernel File Systems.
[   25.677240] systemd[1]: Starting udev Coldplug all Devices...
[   25.701203] systemd[1]: Starting Load/Save Random Seed...
[   28.293821] systemd[1]: Started Apply Kernel Variables.
[   30.925542] systemd[1]: Started Load/Save Random Seed.
[   30.968431] systemd[1]: Started Journal Service.
[   31.073962] systemd-journald[1255]: Received request to flush runtime journal                                     from PID 1
[   31.309048] sunxi_keyboard_startup: keyboard has no clk.
[   31.309608] input: sunxi-keyboard as /devices/virtual/input/input1
[   34.575128] libphy: gmac0: probed
[   34.610269] sunxi-gmac gmac0 eth0: eth0: Type(6) PHY ID 001cc915 at 7 IRQ pol                                    l (gmac0-0:07)
[   34.621496] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   43.610276] libphy: gmac0-0:07 - Link is Up - 100/Full
[   43.610303] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   60.949889] nf_conntrack: automatic helper assignment is deprecated and it wi                                    ll be removed soon. Use the iptables CT target to attach helpers instead.
[ 7901.025095] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x3)
[ 7901.025373] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x4)
[ 7901.025637] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x5)
[ 7901.025907] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x6)
[ 7901.026165] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x7)
[ 7901.026566] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x8)
[ 7901.026886] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x9)
[ 7901.027192] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0xa)
[ 7901.027493] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0xb)
[ 7901.027736] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0xc)
[ 7901.027976] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0xd)
[ 7901.028219] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0xe)
[ 7901.028462] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0xf)
[ 7901.028832] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x10)
[ 7901.029074] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x11)
[ 7901.029315] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x12)
[ 7901.029556] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x13)
[ 7901.029796] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x14)
[ 7901.030185] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x15)
[ 7901.030622] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x16)
[ 7901.030908] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x17)
[ 7901.031155] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x18)
[ 7901.031396] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x19)
[ 7901.031689] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x1a)
[ 7901.031930] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x1b)
[ 7901.032171] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x1c)
[ 7901.032412] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x1d)
[ 7901.032654] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x1e)
[ 7901.032905] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x1f)
[ 7901.033289] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x20)
[ 7901.033531] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x21)
[ 7901.033773] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x22)
[ 7901.034032] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x23)
[ 7901.034275] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x24)
[ 7901.034515] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x25)
[ 7901.034755] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x26)
[ 7901.034995] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x27)
[ 7901.035277] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x28)
[ 7901.035519] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x29)
[ 7901.035759] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x2a)
[ 7901.035999] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x2b)
[ 7901.036241] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x2c)
[ 7901.036481] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x2d)
[ 7901.036726] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x2e)
[ 7901.036968] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x2f)
[ 7901.037326] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x30)
[ 7901.037568] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x31)
[ 7901.037810] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x32)
[ 7901.038052] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x33)
[ 7901.038293] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x34)
[ 7901.038533] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x35)
[ 7901.038774] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x36)
[ 7901.039015] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x37)
[ 7901.039226] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x38)
[ 7901.039437] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x39)
[ 7901.039649] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x3a)
[ 7901.039890] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x3b)
[ 7901.040131] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x3c)
[ 7901.040403] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x3d)
[ 7901.040673] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x3e)
[ 7901.041008] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x3f)
[ 7901.041383] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x40)
[ 7901.041625] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x41)
[ 7901.041908] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x42)
[ 7901.042151] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x43)
[ 7901.042392] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x44)
[ 7901.042632] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x45)
[ 7901.042874] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x46)
[ 7901.043113] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x47)
[ 7901.043354] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x48)
[ 7901.043594] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x49)
[ 7901.043834] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x4a)
[ 7901.044057] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x4b)
[ 7901.044278] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x4c)
[ 7901.044499] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x4d)
[ 7901.044719] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x4e)
[ 7901.044939] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x4f)
[ 7901.045236] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x50)
[ 7901.045457] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x51)
[ 7901.045677] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x52)
[ 7901.045897] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x53)
[ 7901.046118] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x54)
[ 7901.046350] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x55)
[ 7901.046588] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x56)
[ 7901.046830] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x57)
[ 7901.047071] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x58)
[ 7901.047319] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x59)
[ 7901.047560] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x5a)
[ 7901.047802] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x5b)
[ 7901.048043] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x5c)
[ 7901.048285] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x5d)
[ 7901.048526] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x5e)
[ 7901.048784] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x48, de                                    v addr: 0x5f)
[ 7901.049143] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x60)
[ 7901.049398] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x61)
[ 7901.049642] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x62)
[ 7901.049883] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x63)
[ 7901.050128] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x64)
[ 7901.050402] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x65)
[ 7901.050757] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x66)
[ 7901.051022] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x67)
[ 7901.051267] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x68)
[ 7901.051509] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x69)
[ 7901.051752] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x6a)
[ 7901.051994] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x6b)
[ 7901.052235] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x6c)
[ 7901.052476] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x6d)
[ 7901.052717] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x6e)
[ 7901.053000] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x6f)
[ 7901.053374] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x70)
[ 7901.053614] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x71)
[ 7901.053875] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x72)
[ 7901.054118] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x73)
[ 7901.054359] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x74)
[ 7901.054600] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x75)
[ 7901.054843] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x76)
[ 7901.055084] sunxi_i2c_do_xfer()923 - [i2c1] incomplete xfer (status: 0x20, de                                    v addr: 0x77)
[ 7911.928417] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3)
[ 7911.928621] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4)
[ 7911.928872] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x5)
[ 7911.929114] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6)
[ 7911.929355] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x7)
[ 7911.929598] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x8)
[ 7911.929843] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x9)
[ 7911.930109] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xa)
[ 7911.930418] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xb)
[ 7911.930685] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xc)
[ 7911.930929] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xd)
[ 7911.931199] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xe)
[ 7911.931440] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xf)
[ 7911.931853] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x11)
[ 7911.932146] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x12)
[ 7911.932387] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x13)
[ 7911.932628] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x14)
[ 7911.932869] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x15)
[ 7911.933111] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x16)
[ 7911.933352] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x17)
[ 7911.933594] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x18)
[ 7911.933857] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x19)
[ 7911.934097] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1a)
[ 7911.934338] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1b)
[ 7911.934579] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1c)
[ 7911.934820] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1d)
[ 7911.935074] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1e)
[ 7911.935316] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1f)
[ 7911.935673] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x20)
[ 7911.935934] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x21)
[ 7911.936176] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x22)
[ 7911.936416] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x23)
[ 7911.936656] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x24)
[ 7911.936915] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x25)
[ 7911.937157] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x26)
[ 7911.937412] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x27)
[ 7911.937654] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x28)
[ 7911.937894] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x29)
[ 7911.938135] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2a)
[ 7911.938376] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2b)
[ 7911.938618] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2c)
[ 7911.938857] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2d)
[ 7911.939099] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2e)
[ 7911.939378] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2f)
[ 7911.939735] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x30)
[ 7911.939993] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x31)
[ 7911.940301] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x32)
[ 7911.940615] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x33)
[ 7911.940889] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x34)
[ 7911.941141] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x35)
[ 7911.941400] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x36)
[ 7911.941646] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x37)
[ 7911.941887] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x38)
[ 7911.942147] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x39)
[ 7911.942410] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3a)
[ 7911.942651] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3b)
[ 7911.942892] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3c)
[ 7911.943134] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3d)
[ 7911.943413] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3e)
[ 7911.943658] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3f)
[ 7911.944153] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x40)
[ 7911.944398] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x41)
[ 7911.944640] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x42)
[ 7911.944881] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x43)
[ 7911.945123] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x44)
[ 7911.945364] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x45)
[ 7911.945606] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x46)
[ 7911.945847] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x47)
[ 7911.946088] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x48)
[ 7911.946329] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x49)
[ 7911.946572] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4a)
[ 7911.946812] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4b)
[ 7911.947053] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4c)
[ 7911.947310] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4d)
[ 7911.947572] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4e)
[ 7911.947815] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4f)
[ 7911.948173] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x50)
[ 7911.948414] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x51)
[ 7911.948655] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x52)
[ 7911.948896] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x53)
[ 7911.949138] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x54)
[ 7911.949378] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x55)
[ 7911.949618] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x56)
[ 7911.949860] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x57)
[ 7911.950128] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x58)
[ 7911.950401] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x59)
[ 7911.950707] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5a)
[ 7911.951011] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5b)
[ 7911.951254] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5c)
[ 7911.951520] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5d)
[ 7911.951763] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5e)
[ 7911.952004] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5f)
[ 7911.952383] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x60)
[ 7911.952624] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x61)
[ 7911.952865] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x62)
[ 7911.953106] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x63)
[ 7911.953368] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x64)
[ 7911.953609] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x65)
[ 7911.953850] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x66)
[ 7911.954091] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x67)
[ 7911.954375] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x68)
[ 7911.954637] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x69)
[ 7911.954877] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6a)
[ 7911.955118] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6b)
[ 7911.955358] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6c)
[ 7911.955597] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6d)
[ 7911.955855] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6e)
[ 7911.956098] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6f)
[ 7911.956455] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x70)
[ 7911.956696] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x71)
[ 7911.956957] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x72)
[ 7911.957197] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x73)
[ 7911.957437] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x74)
[ 7911.957733] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x75)
[ 7911.957974] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x76)
[ 7911.958214] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x77)
[ 7916.288406] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3)
[ 7916.288610] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4)
[ 7916.288861] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x5)
[ 7916.289103] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6)
[ 7916.289346] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x7)
[ 7916.289588] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x8)
[ 7916.289830] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x9)
[ 7916.290161] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xa)
[ 7916.290438] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xb)
[ 7916.290732] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xc)
[ 7916.290980] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xd)
[ 7916.291221] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xe)
[ 7916.291462] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0xf)
[ 7916.291926] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x11)
[ 7916.292149] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x12)
[ 7916.292369] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x13)
[ 7916.292615] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x14)
[ 7916.292858] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x15)
[ 7916.293100] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x16)
[ 7916.293340] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x17)
[ 7916.293601] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x18)
[ 7916.293879] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x19)
[ 7916.294121] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1a)
[ 7916.294367] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1b)
[ 7916.294607] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1c)
[ 7916.294847] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1d)
[ 7916.295087] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1e)
[ 7916.295327] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x1f)
[ 7916.295763] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x20)
[ 7916.296005] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x21)
[ 7916.296244] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x22)
[ 7916.296504] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x23)
[ 7916.296747] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x24)
[ 7916.296987] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x25)
[ 7916.297246] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x26)
[ 7916.297486] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x27)
[ 7916.297747] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x28)
[ 7916.297988] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x29)
[ 7916.298229] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2a)
[ 7916.298470] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2b)
[ 7916.298710] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2c)
[ 7916.298951] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2d)
[ 7916.299192] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2e)
[ 7916.299432] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x2f)
[ 7916.299794] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x30)
[ 7916.300195] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x31)
[ 7916.300809] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x32)
[ 7916.301082] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x33)
[ 7916.301326] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x34)
[ 7916.301569] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x35)
[ 7916.301812] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x36)
[ 7916.302053] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x37)
[ 7916.302294] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x38)
[ 7916.302534] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x39)
[ 7916.302774] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3a)
[ 7916.303082] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3b)
[ 7916.303326] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3c)
[ 7916.303568] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3d)
[ 7916.303809] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3e)
[ 7916.304066] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x3f)
[ 7916.304428] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x40)
[ 7916.304669] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x41)
[ 7916.304912] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x42)
[ 7916.305153] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x43)
[ 7916.305395] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x44)
[ 7916.305636] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x45)
[ 7916.305876] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x46)
[ 7916.306116] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x47)
[ 7916.306357] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x48)
[ 7916.306600] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x49)
[ 7916.306842] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4a)
[ 7916.307103] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4b)
[ 7916.307344] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4c)
[ 7916.307583] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4d)
[ 7916.307825] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4e)
[ 7916.308067] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x4f)
[ 7916.308424] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x50)
[ 7916.308724] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x51)
[ 7916.308964] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x52)
[ 7916.309207] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x53)
[ 7916.309448] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x54)
[ 7916.309689] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x55)
[ 7916.309928] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x56)
[ 7916.310279] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x57)
[ 7916.310607] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x58)
[ 7916.310958] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x59)
[ 7916.311221] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5a)
[ 7916.311463] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5b)
[ 7916.311705] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5c)
[ 7916.311946] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5d)
[ 7916.312188] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5e)
[ 7916.312430] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x48, de                                    v addr: 0x5f)
[ 7916.312792] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x60)
[ 7916.313033] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x61)
[ 7916.313273] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x62)
[ 7916.313514] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x63)
[ 7916.313754] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x64)
[ 7916.313994] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x65)
[ 7916.314235] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x66)
[ 7916.314516] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x67)
[ 7916.314758] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x68)
[ 7916.315002] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x69)
[ 7916.315244] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6a)
[ 7916.315497] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6b)
[ 7916.315738] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6c)
[ 7916.315979] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6d)
[ 7916.316242] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6e)
[ 7916.316504] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x6f)
[ 7916.316861] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x70)
[ 7916.317101] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x71)
[ 7916.317342] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x72)
[ 7916.317621] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x73)
[ 7916.317863] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x74)
[ 7916.318102] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x75)
[ 7916.318343] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x76)
[ 7916.318584] sunxi_i2c_do_xfer()923 - [i2c3] incomplete xfer (status: 0x20, de                                    v addr: 0x77)
[ 9898.440043] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[ 9898.440100] CPU Budget hotplug: cluster0 min:0 max:4
[ 9899.440046] CPU Budget hotplug: cluster0 min:0 max:4
[ 9900.440032] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[ 9900.440080] CPU Budget hotplug: cluster0 min:0 max:4
[ 9901.440035] CPU Budget hotplug: cluster0 min:0 max:4
[ 9902.440040] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[ 9902.440089] CPU Budget hotplug: cluster0 min:0 max:4
[ 9903.440038] CPU Budget hotplug: cluster0 min:0 max:4
[ 9904.440036] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[ 9904.440087] CPU Budget hotplug: cluster0 min:0 max:4
[ 9905.440037] CPU Budget hotplug: cluster0 min:0 max:4
[ 9906.440030] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[ 9906.440079] CPU Budget hotplug: cluster0 min:0 max:4
[ 9907.440058] CPU Budget hotplug: cluster0 min:0 max:4
[ 9954.440038] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[ 9954.440094] CPU Budget hotplug: cluster0 min:0 max:4
[ 9955.440058] CPU Budget hotplug: cluster0 min:0 max:4
[ 9956.440056] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[ 9956.440120] CPU Budget hotplug: cluster0 min:0 max:4
[ 9957.440045] CPU Budget hotplug: cluster0 min:0 max:4
[ 9958.440059] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[ 9958.440122] CPU Budget hotplug: cluster0 min:0 max:4
[ 9959.440068] CPU Budget hotplug: cluster0 min:0 max:4
[ 9960.440058] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[ 9960.440122] CPU Budget hotplug: cluster0 min:0 max:4
[ 9961.440046] CPU Budget hotplug: cluster0 min:0 max:4
[ 9962.440032] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[ 9962.440080] CPU Budget hotplug: cluster0 min:0 max:4
[10820.440078] CPU Budget hotplug: cluster0 min:0 max:4
[12622.440117] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[12622.440188] CPU Budget hotplug: cluster0 min:0 max:4
[12623.440121] CPU Budget hotplug: cluster0 min:0 max:4
[12624.440115] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[12624.440185] CPU Budget hotplug: cluster0 min:0 max:4
[13047.440113] CPU Budget:update CPU 0 cpufreq max to 1320000 min to 480000
[13047.440187] CPU Budget hotplug: cluster0 min:0 max:3
[13047.440195] CPU Budget:Try to down cpu 3, cluster0 online 4, max 3
[13047.450617] [sched_delayed] process 7463 (minerd) no longer affine to cpu3
[13047.450958] CPU3: shutdown
[13047.450979] psci: CPU3 killed.
[13048.450093] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[13048.450121] CPU Budget hotplug: cluster0 min:0 max:4
[13048.450129] CPU Budget:Try to up cpu 3, cluster0 online 3, max 4
[13048.450237] CPU3: Booted secondary processor
[13048.450237] CPU3: update cpu_power 1024
[13065.450114] CPU Budget:update CPU 0 cpufreq max to 1320000 min to 480000
[13065.450187] CPU Budget hotplug: cluster0 min:0 max:3
[13065.450195] CPU Budget:Try to down cpu 3, cluster0 online 4, max 3
[13065.451068] CPU3: shutdown
[13065.451082] psci: CPU3 killed.
[13066.450094] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[13066.450119] CPU Budget hotplug: cluster0 min:0 max:4
[13066.450126] CPU Budget:Try to up cpu 3, cluster0 online 3, max 4
[13066.450234] CPU3: Booted secondary processor
[13066.450234] CPU3: update cpu_power 1024
[13078.450109] CPU Budget:update CPU 0 cpufreq max to 1320000 min to 480000
[13078.450182] CPU Budget hotplug: cluster0 min:0 max:3
[13078.450191] CPU Budget:Try to down cpu 3, cluster0 online 4, max 3
[13078.451062] CPU3: shutdown
[13078.451075] psci: CPU3 killed.
[13079.450103] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[13079.450128] CPU Budget hotplug: cluster0 min:0 max:4
[13079.450135] CPU Budget:Try to up cpu 3, cluster0 online 3, max 4
[13079.450245] CPU3: Booted secondary processor
[13079.450245] CPU3: update cpu_power 1024
[13092.450108] CPU Budget:update CPU 0 cpufreq max to 1320000 min to 480000
[13092.450181] CPU Budget hotplug: cluster0 min:0 max:3
[13092.450189] CPU Budget:Try to down cpu 3, cluster0 online 4, max 3
[13092.451064] CPU3: shutdown
[13092.451077] psci: CPU3 killed.
[13093.450108] CPU Budget:update CPU 0 cpufreq max to 1488000 min to 480000
[13093.450134] CPU Budget hotplug: cluster0 min:0 max:4
[13093.450142] CPU Budget:Try to up cpu 3, cluster0 online 3, max 4
[13093.450248] CPU3: Booted secondary processor
[13093.450248] CPU3: update cpu_power 1024
[13145.450148] CPU Budget hotplug: cluster0 min:0 max:4
[15146.679853] addr ffffff800248a100, value = 0.
[15146.679876] notice: para err, index = 0.
[15146.679888] addr ffffff800248a104, value = 0.
[15146.679904] ERR_FIRST_BOOT_FLAG_DONE.
[15146.679916] addr ffffff800248a108, value = 0.
[15146.679926] notice: para err, index = 2.
[15146.679938] addr ffffff800248a10c, value = b00f.
[15146.679950] addr ffffff800248a110, value = 0.
[15146.680205] notice: para err, index = 4.
[15146.680220] addr ffffff800248a114, value = 0.
[15146.680231] notice: para err, index = 5.
[15146.680243] addr ffffff800248a118, value = 0.
[15146.680253] notice: para err, index = 6.
[15146.680265] addr ffffff800248a11c, value = 0.
[15146.680275] notice: para err, index = 7.
[15163.572590] addr ffffff800248a100, value = 0.
[15163.572613] notice: para err, index = 0.
[15163.572626] addr ffffff800248a104, value = 0.
[15163.572640] ERR_FIRST_BOOT_FLAG_DONE.
[15163.572652] addr ffffff800248a108, value = 0.
[15163.572663] notice: para err, index = 2.
[15163.572674] addr ffffff800248a10c, value = b00f.
[15163.572686] addr ffffff800248a110, value = 0.
[15163.572696] notice: para err, index = 4.
[15163.572708] addr ffffff800248a114, value = 0.
[15163.572718] notice: para err, index = 5.
[15163.572729] addr ffffff800248a118, value = 0.
[15163.572739] notice: para err, index = 6.
[15163.572750] addr ffffff800248a11c, value = 0.
[15163.572760] notice: para err, index = 7.
[15172.523306] addr ffffff800248a100, value = 0.
[15172.523323] notice: para err, index = 0.
[15172.523331] addr ffffff800248a104, value = 0.
[15172.523341] ERR_FIRST_BOOT_FLAG_DONE.
[15172.523349] addr ffffff800248a108, value = 0.
[15172.523356] notice: para err, index = 2.
[15172.523364] addr ffffff800248a10c, value = b00f.
[15172.523372] addr ffffff800248a110, value = 0.
[15172.523379] notice: para err, index = 4.
[15172.523387] addr ffffff800248a114, value = 0.
[15172.523394] notice: para err, index = 5.
[15172.523401] addr ffffff800248a118, value = 0.
[15172.523408] notice: para err, index = 6.
[15172.523416] addr ffffff800248a11c, value = 0.
[15172.523422] notice: para err, index = 7.
seems that it killed or try to kill the CPU during the 'stress/minerd-orgy'. And there are some errors during boot up.
On 2/7/2018 at 3:43 PM, chwe said:
Did someone try to build u-boot or kernel with their sources?
https://github.com/Allwinner-Homlet?tab=repositories
Seems that the whole thing is somehow messed up.  From their buildscript I expect that it should build 'u-boot-2014.07' but it seems that it messes up somewhere in 'u-boot-2011.09'. Not that I would expect that I wouldn't fail (completely new on this field of stuff and starting with a 'not so well' documented script might be an overkill :rolleyes:),  but I'm interested if someone had a look into it. :)
I just had a go.. fairly new to this myself, so I'm not even sure what I'm actually doing, but there's something wrong with the SDK itself, apparently.
Anyway, to select uboot 2014.07 you need to specify the board with -p:
./build.sh -p sun50iw6p1
First complains about a Makefile error (an endline that shouldn't be thre at line 1214. After fixing that, the compilation *almost* goes on nicely, but it returns an error for a couple targets:
make[1]: *** No rule to make target 'arch/arm/cpu/armv7/lowlevel_init.o', needed by 'arch/arm/cpu/armv7/built-in.o'. Stop.
make[1]: *** No rule to make target 'arch/arm/lib/vectors.o', needed by 'arch/arm/lib/built-in.o'. Stop.
btw. up since 7days without load (hadn't time/interest to play with it).. :P
orangepi@OrangePi:~$ uptime
 15:23:47 up 7 days, 16:22,  1 user,  load average: 3.00, 3.01, 3.05
I guess you did use the orangepi server image for that, right?
I tried to build that u-boot 2014 release from the BSP too... after fixing the error in the Makefile like you mentioned, I also got stuck on the u-boot build unless I use the specific linaro toolchain contained within that BSP drop, but the scripts are totally broken because they split up the BSP into several repos...
Yeah, that was first Xunlongs Ubuntu. I didn't spend that much time with it cause the board is of minor interest to me (a wired out USB3 would make it much more interesting.. :P). As soon as mainline is somehow usable this might change cause I can use it at least as a lightweight webserver (don't ask when armbian 'is ready' cause I simply don't know it).
Cause @Xalius and others reported that the BSP kernels are the same mess than older Allwinner kernels this might be a mainline only SoC too.
Yup, same for me... that's why I got the other H6 board (Orange Pi Lite2, no GbE but USB3). I know this topic is about the pi one plus , but they share quite a lot in term of kernel compatibility and boot process (the same orange pi image boots on my board).
