junnikokuki Posted September 15, 2018 Posted September 15, 2018 Hi, I recently read from github testings of orange pi lite2 testing that wireless is working. But I download from the official website of https://dl.armbian.com/orangepilite2/Debian_stretch_dev_nightly.7z(built 0824) and burn it, it starts, but the wireless is missing. I also read that the firmware added ap6255 wireless driver, so I download https://beta.armbian.com/pool/main/a/armbian-firmware-full/armbian-firmware-full_5.59.180915_all.deb and installed it. After reboot, the wireless is still missing. So the support of wireless is built-in or usb? Should I build armbian myself with the lastest code to support the built-in wireless? Thank you.
martinayotte Posted September 16, 2018 Posted September 16, 2018 19 hours ago, junnikokuki said: Should I build armbian myself with the lastest code to support the built-in wireless? Right, since the commit was done on Sept.7th ...
junnikokuki Posted September 17, 2018 Author Posted September 17, 2018 So when will the automate nightly build run? I think wireless support is a big improvement for orange pi lite2 version. It deserves a new build.
Igor Posted September 17, 2018 Posted September 17, 2018 5 hours ago, junnikokuki said: So when will the automate nightly build run? Never, since it is not enabled for this board. 5 hours ago, junnikokuki said: It deserves a new build. There is no end-user support for boards/kernels that are still under development because it is too expensive. We barely manage to provide free support for stable builds. We make nightly images for developers and development purposes.
junnikokuki Posted September 17, 2018 Author Posted September 17, 2018 33 minutes ago, Igor said: Never, since it is not enabled for this board. There is no end-user support for boards/kernels that are still under development because it is too expensive. We barely manage to provide free support for stable builds. We make nightly images for developers and development purposes. Yeah, I know, it is a wip board. I do not intend to act as an end user, but a tester, only.
Igor Posted September 17, 2018 Posted September 17, 2018 2 minutes ago, junnikokuki said: Yeah, I know, it is a wip board. I do not intend to act as an end user, but a tester, only. https://github.com/armbian/build/blob/master/config/boards/orangepilite2.wip#L13-L14 Sent PR with correct parameters and image will be in the batch.
junnikokuki Posted September 17, 2018 Author Posted September 17, 2018 3 hours ago, Igor said: https://github.com/armbian/build/blob/master/config/boards/orangepilite2.wip#L13-L14 Sent PR with correct parameters and image will be in the batch. So I should set CLI_BETA_TARGET="bionic,stretch:dev" DESKTOP_BETA_TARGET="bionic,stretch:dev" and then request a pull request?
Igor Posted September 17, 2018 Posted September 17, 2018 20 minutes ago, junnikokuki said: So I should set CLI_BETA_TARGET="bionic,stretch:dev" DESKTOP_BETA_TARGET="bionic,stretch:dev" and then request a pull request? Only CLI images. We don't need the desktop for now. CLI_BETA_TARGET="bionic,stretch:dev"
junnikokuki Posted September 26, 2018 Author Posted September 26, 2018 On 9/18/2018 at 1:56 AM, Igor said: Only CLI images. We don't need the desktop for now. CLI_BETA_TARGET="bionic,stretch:dev" Sorry for testing late, just back from vocation. The new nightly build is unable to get to the login step. The Armbian_5.59.180824_Orangepilite2_Debian_stretch_dev_4.18.0-rc7.7z, which is able to login, will show this: and then a black screen with a cursor blinking, then after a long time, the login message showed. The Armbian_5.60.180923_Orangepilite2_Debian_stretch_dev_4.18.9.7z bulid, along with 0918/4.18.8 build, will show: and then the hdmi screen lost signal. Seems that the simplefb node not found. Other debug messages missing, still waiting for my usb2ttl cable.
Werner Posted September 26, 2018 Posted September 26, 2018 Unbootable kernel with OPi One Plus confirmed, runs into panic, reading from UART. There is something wrong with the later 4.18.x kernel. 4.18.0-rc7 from @Icenowy sources working well. But this kind a runs off topic I guess
Igor Posted September 26, 2018 Posted September 26, 2018 34 minutes ago, Werner said: Unbootable kernel with OPi One Plus confirmed, runs into panic, reading from UART. There is something wrong with the later 4.18.x kernel. 4.18.0-rc7 from @Icenowy sources working well. But this kind a runs off topic I guess I'll try to bring it up in 4.19.y ... some basic support is getting mainlined and it will be less troublesome. I hope. 1
Werner Posted September 26, 2018 Posted September 26, 2018 6 minutes ago, Igor said: I'll try to bring it up in 4.19.y ... some basic support is getting mainlined and it will be less troublesome. I hope. I am ready to give it a shot whenever you are ready
chwe Posted September 26, 2018 Posted September 26, 2018 13 hours ago, junnikokuki said: Other debug messages missing, still waiting for my usb2ttl cable. or you use just another SBC... (see: the silly approach)
data Posted September 26, 2018 Posted September 26, 2018 Since nightly builds are now available, what else do I need in order to enable ap6255 wireless?
Igor Posted September 27, 2018 Posted September 27, 2018 6 hours ago, data said: Since nightly builds are now available, what else do I need in order to enable ap6255 wireless? If the image boots, it should work out of the box.
data Posted September 27, 2018 Posted September 27, 2018 The ubuntu images boot, but wifi does not. First I tried the 0923 nighly, then upgraded to 0926 last night but wifi does not show up. I found nothing related to AP6255 nor Broadcom in dmesg. I will try the latest debian later today.
Werner Posted September 27, 2018 Posted September 27, 2018 2 hours ago, data said: The ubuntu images boot, but wifi does not. First I tried the 0923 nighly, then upgraded to 0926 last night but wifi does not show up. I found nothing related to AP6255 nor Broadcom in dmesg. I will try the latest debian later today. The kernel is the same, just the OS on top is different.
martinayotte Posted September 27, 2018 Posted September 27, 2018 5 hours ago, data said: I found nothing related to AP6255 nor Broadcom in dmesg. Which kernel are you using ? what are the timestamps of those kernel files in /boot ? Are they newer than Sept.7th ? Did you do the following "grep" on "dmesg" ? dmesg | grep -i mmc dmesg | grep -i sdio dmesg | grep -i brcm
data Posted September 27, 2018 Posted September 27, 2018 See all details below: ___ ____ _ _ _ _ ____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) | | (_) |_ ___ |___ \ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | | | | __/ _ \ __) | | |_| | | | (_| | | | | (_| | __/ | __/| | | |___| | || __/ / __/ \___/|_| \__,_|_| |_|\__, |\___| |_| |_| |_____|_|\__\___| |_____| |___/ Welcome to ARMBIAN 5.61.180926 nightly Ubuntu 18.04.1 LTS 4.18.10-sunxi64 System load: 0.83 0.32 0.12 Up time: 1 min Memory usage: 7 % of 994MB IP: 10.1.1.162 10.1.1.157 CPU temp: 31°C Usage of /: 4% of 29G [ General system configuration (beta): armbian-config ] Last login: Wed Sep 26 20:51:01 2018 root@orangepilite2:~# dmesg |grep -i mmc [ 0.892184] sunxi-mmc 4020000.mmc: could not find pctldev for node /soc/pinctrl@300b000/mmc0-pins, deferring probe [ 0.892214] sunxi-mmc 4022000.mmc: could not find pctldev for node /soc/pinctrl@300b000/mmc2-pins, deferring probe [ 1.118542] sunxi-mmc 4020000.mmc: Got CD GPIO [ 1.143911] sunxi-mmc 4020000.mmc: base:0x(____ptrval____) irq:11 [ 1.170113] sunxi-mmc 4022000.mmc: base:0x(____ptrval____) irq:12 [ 1.193092] mmc0: host does not support reading read-only switch, assuming write-enable [ 1.197899] mmc0: new high speed SDHC card at address 0007 [ 1.198880] mmcblk0: mmc0:0007 SDCIT 29.2 GiB [ 1.200152] mmcblk0: p1 [ 3.368126] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 5.610572] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro root@orangepilite2:~# dmesg | grep -i sdio root@orangepilite2:~# dmesg | grep -i brcm root@orangepilite2:~# uname -a Linux orangepilite2 4.18.10-sunxi64 #292 SMP Wed Sep 26 16:53:32 CEST 2018 aarch64 aarch64 aarch64 GNU/Linux root@orangepilite2:~# ls -la /boot total 33304 drwxr-xr-x 3 root root 4096 Sep 26 21:31 . drwxr-xr-x 22 root root 4096 Sep 23 23:12 .. -rw-r--r-- 1 root root 165 Sep 26 21:31 armbianEnv.txt -rw-r--r-- 1 root root 165 Sep 26 21:31 armbianEnv.txte -rw-r--r-- 1 root root 1536 Sep 23 23:13 armbian_first_run.txt.template -rw-r--r-- 1 root root 230454 Sep 23 23:13 boot.bmp -rw-r--r-- 1 root root 3018 Sep 23 23:11 boot.cmd -rw-r--r-- 1 root root 4882 Sep 23 23:13 boot-desktop.png -rw-rw-r-- 1 root root 3090 Sep 23 23:14 boot.scr -rw-r--r-- 1 root root 147050 Sep 26 14:53 config-4.18.10-sunxi64 lrwxrwxrwx 1 root root 19 Sep 26 21:00 dtb -> dtb-4.18.10-sunxi64 drwxr-xr-x 3 root root 4096 Sep 26 20:58 dtb-4.18.10-sunxi64 lrwxrwxrwx 1 root root 18 Sep 23 23:12 dtb.old -> dtb-4.18.9-sunxi64 lrwxrwxrwx 1 root root 23 Sep 26 20:59 Image -> vmlinuz-4.18.10-sunxi64 -rw-r--r-- 1 root root 8407047 Sep 26 21:00 initrd.img-4.18.10-sunxi64 -rw-r--r-- 1 root root 0 Sep 26 20:59 .next -rw-r--r-- 1 root root 3011411 Sep 26 14:53 System.map-4.18.10-sunxi64 lrwxrwxrwx 1 root root 23 Sep 26 21:00 uInitrd -> uInitrd-4.18.10-sunxi64 -rw-r--r-- 1 root root 8407111 Sep 26 21:00 uInitrd-4.18.10-sunxi64 -rwxr-xr-x 1 root root 13844488 Sep 26 14:53 vmlinuz-4.18.10-sunxi64 root@orangepilite2:~#
martinayotte Posted September 27, 2018 Posted September 27, 2018 32 minutes ago, data said: See all details below: That is really odd ! @Igor is this nightly has been built differently from the normal WIP DEV build process ? First odd thing is the kernel 4.18.10-sunxi64, while Armbian config/sources/sun50iw6.conf still pointing to Icenowy's h6-integrate-2-ugly branch, which is a 4.18.0-rc7 ... Second odd thing, the "dmesg | grep -i mmc" should have shown "mmc1" probing with finally "mmc1: new high speed SDIO card at address 0001", but it is not there, so I presume that my Sept.7th DTS patch is not in this build ...
Igor Posted September 28, 2018 Posted September 28, 2018 11 hours ago, martinayotte said: is this nightly has been built differently from the normal WIP DEV build process ? Possible. Let me check this during the day.
Igor Posted September 28, 2018 Posted September 28, 2018 We have a few problems here. First is that sunxi64-next branch was reverted back to 4.14.y since 4.18.y just not ready yet ... in 4.14.y there is no support for H6 ... I can only switch to sunx64-dev, where the board boots, but without http://ix.io/1nK7 HDMI, WiFi and USB3 seem also not to function properly. @martinayotte Should I apply this? diff --git a/config/sources/sun50iw6.conf b/config/sources/sun50iw6.conf index 16834529..692bb292 100644 --- a/config/sources/sun50iw6.conf +++ b/config/sources/sun50iw6.conf @@ -31,6 +31,13 @@ case $BRANCH in KERNELDIR=$MAINLINE_KERNEL_DIR KERNEL_USE_GCC='> 7.0' KERNELPATCHDIR='sunxi-dev-h6' + + KERNELSOURCE=$MAINLINE_KERNEL_SOURCE + KERNELBRANCH='branch:linux-4.18.y' + KERNELDIR=$MAINLINE_KERNEL_DIR + KERNEL_USE_GCC='> 7.0' + KERNELPATCHDIR='sunxi-dev' + ;; esac diff --git a/patch/kernel/sunxi-dev/p-board-h6-add-THS.patch b/patch/kernel/sunxi-dev/p-board-h6-add-THS.patch index 8d59cca2..631a40f8 100644 --- a/patch/kernel/sunxi-dev/p-board-h6-add-THS.patch +++ b/patch/kernel/sunxi-dev/p-board-h6-add-THS.patch @@ -1012,7 +1012,7 @@ diff --git a/arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi b/arch/arm64/boot/dts/ index 000a681fb515..bec8c4a46ec7 100644 --- a/arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi +++ b/arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi -@@ -41,6 +41,32 @@ +@@ -41,6 +41,30 @@ opp-microvolt = <880000>; clock-latency-ns = <244144>; /* 8 32k periods */ };
junnikokuki Posted September 28, 2018 Author Posted September 28, 2018 Mmmmmm, I don't know why have to revert, but 4.18.0 rc7 works well except wifi.
data Posted September 28, 2018 Posted September 28, 2018 Same here. I am using an external USB3 - Gigabit Ethernet (ASIX AX88179 USB 3.0 Gigabit Ethernet) with no issues so far.
Igor Posted September 28, 2018 Posted September 28, 2018 20 minutes ago, junnikokuki said: Mmmmmm, I don't know why have to revert, but 4.18.0 rc7 works well except wifi. Because that branch is temporarily development branch with a purpose to develop a few things. We only have two choices here - switch to current 4.18.y, say goodbye to HDMI for a while and fix other things, wifi perhaps ... or wait until HDMI is not mainlined. Other options are too expensive. I have to remind you that this board is under development and regressions are possible. Some are intended, some not. 1
data Posted September 28, 2018 Posted September 28, 2018 In my case, I can forego HDMI and would prefer the latest kernel instead.
junnikokuki Posted September 28, 2018 Author Posted September 28, 2018 10 minutes ago, Igor said: Because that branch is temporarily development branch with a purpose to develop a few things. We only have two choices here - switch to current 4.18.y, say goodbye to HDMI for a while and fix other things, wifi perhaps ... or wait until HDMI is not mainlined. Other options are too expensive. I have to remind you that this board is under development and regressions are possible. Some are intended, some not. Byebye hdmi.
martinayotte Posted September 28, 2018 Posted September 28, 2018 6 hours ago, Igor said: Should I apply this? I don't know since I was using the current config with Icenowy's ugly branch. I will have to check if my previous WiFi patch will still be valid when used with Mainline 4.18.y ...
Igor Posted September 28, 2018 Posted September 28, 2018 51 minutes ago, martinayotte said: I don't know since I was using the current config with Icenowy's ugly branch. I will have to check if my previous WiFi patch will still be valid when used with Mainline 4.18.y ... It should work. https://github.com/armbian/build/commit/9fcb58b8f17b128dc305d76264830140d5a80c62 Someone needs to test this.
