Neil Armstrong Posted January 15, 2019 Posted January 15, 2019 @Igor The Debian stretch image works fine, I looked in the /boot directory of the Ubuntu images and it's empty
Igor Posted January 15, 2019 Posted January 15, 2019 57 minutes ago, Neil Armstrong said: I looked in the /boot directory of the Ubuntu images and it's empty I found and fix a problem. Some images were corrupted - I did upload new one, but corrupted had higher linking priority. Not anymore ... checking if that happened elsewhere too.
JMCC Posted January 16, 2019 Posted January 16, 2019 I fixed some u-boot bug, happening in boards with 1GB of RAM, that could not load u-boot. Here is the console log with the failure: Spoiler resetting ... bl31 reboot reason: 0xd bl31 reboot reason: 0x0 system cmd 1. GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:0;RCY:0;USB:0;SPI:0;CHK:AA;EMMC:400;NAND:81;SD:0;READ:0;0.0;CHK:0; no sdio debug board detected TE: 1726106 BL2 Built : 11:58:42, May 27 2017. gxl gc3c9a84 - xiaobo.gu@droid05 set vcck to 1120 mv set vddee to 1000 mv Board ID = 6 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 912MHz - FAIL DDR3 chl: Rank0 @ 912MHz - PASS Rank0: 1024MB(auto)-2T-13 DataBus test pass! AddrBus test pass! Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from SD, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from SD, src: 0x00020200, des: 0x05100000, size: 0x00018400 Load bl33 from SD, src: 0x0003c200, des: 0x01000000, size: 0x00081200 NOTICE: BL3-1: v1.0(release):3348978 NOTICE: BL3-1: Built : 15:44:01, May 12 2017 [BL31]: GXL CPU setup! mpu_config_enable:ok [Image: gxl_v1.1.3221-2cfba69 2017-05-27 16:03:58 qiufang.dai@droid07] OPS=0x82 4b 3 4b 94 98 ec 53 5f 9 91 ee 70 [2.165399 Inits done] secure task start! high task start! low task start! ERROR: Error initializing runtime service opteed_fast U-Boot 2018.11-armbian (Jan 11 2019 - 19:16:55 +0100) libretech-cc DRAM: 1 GiB MMC: mmc@72000: 0, mmc@74000: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@4c0 Out: serial@4c0 Err: serial@4c0 [BL31]: tee size: 0 [BL31]: tee size: 0 Net: Warning: ethernet@c9410000 (eth0) using random MAC address - 86:e2:d9:ef:ec:60 eth0: ethernet@c9410000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3048 bytes read in 2 ms (1.5 MiB/s) ## Executing script at 1f000000 154 bytes read in 0 ms "Synchronous Abort" handler, esr 0x96000010 elr: 000000000104abe4 lr : 00000000010492dc (reloc) elr: 000000003ffa3be4 lr : 000000003ffa22dc x0 : 000000003df7e2c0 x1 : 0000000044000000 x2 : 000000000000009a x3 : 0000000000000000 x4 : 0000000000000013 x5 : 0000000000000098 x6 : 0000000000000036 x7 : 000000003ffbf1e0 x8 : 0000000000000100 x9 : 0000000000000000 x10: 000000003df7ed70 x11: 000000003df63480 x12: 0000000000000000 x13: 0000000000000200 x14: 0000000000000000 x15: 00000000ffffffff x16: 0000000000000000 x17: 0000000000000020 x18: 000000003df56df8 x19: 0000000000000000 x20: 0000000000000000 x21: 000000003df7e2c0 x22: 0000000000000000 x23: 000000003ffc2188 x24: 0000000000000000 x25: 000000000000000a x26: 0000000000000001 x27: 000000000000009a x28: 0000000000000000 x29: 000000003df4dff0 Resetting CPU ... Reference to the commit: https://github.com/armbian/build/commit/01571c0a4c6c3e7cdb1fec8c99465d8fc00c8c90 1
TonyMac32 Posted January 16, 2019 Author Posted January 16, 2019 @Neil Armstrong It works from what I can tell, also realized I was using the wrong input on my 4K monitor, switched and was able to verify 4k 60 Hz. Awesome! Side note, I saw the patchset land on the mailinglist, will that work on all dw-hdmi 2.0 controllers? [edit] @JMCC this was a fresh build, so your bugfix is verified on my side to work with the 2GB board as well.
Igor Posted January 16, 2019 Posted January 16, 2019 3 hours ago, JMCC said: I fixed some u-boot bug, happening in boards with 1GB of RAM, that could not load u-boot. Here is the console log with the failure: I will rebuild those images ASAP. 1
JMCC Posted January 16, 2019 Posted January 16, 2019 6 hours ago, Igor said: I will rebuild those images ASAP. Good to hear. Also, some comments about wifi. RTL8188CUS (Odroid wifi module 3) has an excellent driver in this kernel. It's much faster and much more stable than in any other kernel I have tried. But support for RTL8188EUS (Comfast WU810N) seems to have been completely dropped, it is not even recognized, while any other Armbian kernel I've used it was recognized although performance wasn't too good. Is this the expected behavior?
Igor Posted January 16, 2019 Posted January 16, 2019 5 hours ago, JMCC said: seems to have been completely dropped, it is not even recognized, while any other Armbian kernel I've used it was recognized although performance wasn't too good. Is this the expected behavior? https://github.com/armbian/documentation/commit/63c02d26ceca64d032696247e7c4657f4656a1cehttps://github.com/armbian/build/commit/730c1f6f4d6a5f45418c39e789f63b8da4fb1411 (not yet included in latest images, but included via apt update) 1m from router. RTL8188CUS Spoiler [ 4] 0.00-1.00 sec 8.32 MBytes 69.7 Mbits/sec 0 345 KBytes [ 4] 1.00-2.00 sec 8.76 MBytes 73.5 Mbits/sec 15 447 KBytes [ 4] 2.00-3.00 sec 7.46 MBytes 62.5 Mbits/sec 0 518 KBytes [ 4] 3.00-4.00 sec 6.34 MBytes 53.2 Mbits/sec 0 566 KBytes [ 4] 4.00-5.00 sec 7.02 MBytes 58.9 Mbits/sec 2 428 KBytes [ 4] 5.00-6.00 sec 7.27 MBytes 61.0 Mbits/sec 0 460 KBytes [ 4] 6.00-7.00 sec 7.27 MBytes 61.0 Mbits/sec 0 478 KBytes [ 4] 7.00-8.00 sec 7.33 MBytes 61.5 Mbits/sec 0 488 KBytes [ 4] 8.00-9.00 sec 7.15 MBytes 59.9 Mbits/sec 0 489 KBytes [ 4] 9.00-10.00 sec 6.96 MBytes 58.4 Mbits/sec 0 489 KBytes RTL8188EUS Spoiler [ 4] 0.00-1.00 sec 3.30 MBytes 27.7 Mbits/sec 0 154 KBytes [ 4] 1.00-2.00 sec 2.73 MBytes 22.9 Mbits/sec 0 264 KBytes [ 4] 2.00-3.00 sec 3.29 MBytes 27.6 Mbits/sec 0 397 KBytes [ 4] 3.00-4.00 sec 3.04 MBytes 25.6 Mbits/sec 11 341 KBytes [ 4] 4.00-5.00 sec 1.93 MBytes 16.2 Mbits/sec 0 395 KBytes [ 4] 5.00-6.00 sec 1.99 MBytes 16.7 Mbits/sec 0 436 KBytes [ 4] 6.00-7.00 sec 2.24 MBytes 18.8 Mbits/sec 0 464 KBytes [ 4] 7.00-8.00 sec 1.86 MBytes 15.6 Mbits/sec 1 332 KBytes [ 4] 8.00-9.00 sec 2.24 MBytes 18.8 Mbits/sec 0 365 KBytes [ 4] 9.00-10.00 sec 2.49 MBytes 20.8 Mbits/sec 0 387 KBytes MT7610 at 5G Spoiler [ 4] 0.00-1.00 sec 4.53 MBytes 38.0 Mbits/sec 0 209 KBytes [ 4] 1.00-2.00 sec 5.03 MBytes 42.2 Mbits/sec 0 411 KBytes [ 4] 2.00-3.00 sec 4.66 MBytes 39.1 Mbits/sec 0 583 KBytes [ 4] 3.00-4.00 sec 7.08 MBytes 59.4 Mbits/sec 61 481 KBytes [ 4] 4.00-5.00 sec 12.4 MBytes 104 Mbits/sec 11 382 KBytes [ 4] 5.00-6.00 sec 12.0 MBytes 101 Mbits/sec 0 414 KBytes [ 4] 6.00-7.00 sec 8.26 MBytes 69.3 Mbits/sec 0 431 KBytes [ 4] 7.00-8.00 sec 2.24 MBytes 18.8 Mbits/sec 0 443 KBytes [ 4] 8.00-9.00 sec 7.39 MBytes 62.0 Mbits/sec 0 447 KBytes [ 4] 9.00-10.00 sec 8.26 MBytes 69.3 Mbits/sec 0 447 KBytes MT7601U Spoiler [ 4] 0.00-1.00 sec 9.73 MBytes 81.6 Mbits/sec 0 407 KBytes [ 4] 1.00-2.00 sec 8.45 MBytes 70.9 Mbits/sec 15 421 KBytes [ 4] 2.00-3.00 sec 8.20 MBytes 68.8 Mbits/sec 0 477 KBytes [ 4] 3.00-4.00 sec 8.45 MBytes 70.9 Mbits/sec 0 515 KBytes [ 4] 4.00-5.00 sec 9.07 MBytes 76.1 Mbits/sec 4 393 KBytes [ 4] 5.00-6.00 sec 9.13 MBytes 76.6 Mbits/sec 0 420 KBytes [ 4] 6.00-7.00 sec 9.13 MBytes 76.6 Mbits/sec 0 433 KBytes [ 4] 7.00-8.00 sec 9.57 MBytes 80.3 Mbits/sec 0 440 KBytes [ 4] 8.00-9.00 sec 9.20 MBytes 77.2 Mbits/sec 0 440 KBytes [ 4] 9.00-10.00 sec 9.20 MBytes 77.1 Mbits/sec 0 452 KBytes 1
JMCC Posted January 16, 2019 Posted January 16, 2019 6 hours ago, Igor said: https://github.com/armbian/documentation/commit/63c02d26ceca64d032696247e7c4657f4656a1cehttps://github.com/armbian/build/commit/730c1f6f4d6a5f45418c39e789f63b8da4fb1411 (not yet included in latest images, but included via apt update) 1m from router. RTL8188CUS Reveal hidden contents [ 4] 0.00-1.00 sec 8.32 MBytes 69.7 Mbits/sec 0 345 KBytes [ 4] 1.00-2.00 sec 8.76 MBytes 73.5 Mbits/sec 15 447 KBytes [ 4] 2.00-3.00 sec 7.46 MBytes 62.5 Mbits/sec 0 518 KBytes [ 4] 3.00-4.00 sec 6.34 MBytes 53.2 Mbits/sec 0 566 KBytes [ 4] 4.00-5.00 sec 7.02 MBytes 58.9 Mbits/sec 2 428 KBytes [ 4] 5.00-6.00 sec 7.27 MBytes 61.0 Mbits/sec 0 460 KBytes [ 4] 6.00-7.00 sec 7.27 MBytes 61.0 Mbits/sec 0 478 KBytes [ 4] 7.00-8.00 sec 7.33 MBytes 61.5 Mbits/sec 0 488 KBytes [ 4] 8.00-9.00 sec 7.15 MBytes 59.9 Mbits/sec 0 489 KBytes [ 4] 9.00-10.00 sec 6.96 MBytes 58.4 Mbits/sec 0 489 KBytes RTL8188EUS Reveal hidden contents [ 4] 0.00-1.00 sec 3.30 MBytes 27.7 Mbits/sec 0 154 KBytes [ 4] 1.00-2.00 sec 2.73 MBytes 22.9 Mbits/sec 0 264 KBytes [ 4] 2.00-3.00 sec 3.29 MBytes 27.6 Mbits/sec 0 397 KBytes [ 4] 3.00-4.00 sec 3.04 MBytes 25.6 Mbits/sec 11 341 KBytes [ 4] 4.00-5.00 sec 1.93 MBytes 16.2 Mbits/sec 0 395 KBytes [ 4] 5.00-6.00 sec 1.99 MBytes 16.7 Mbits/sec 0 436 KBytes [ 4] 6.00-7.00 sec 2.24 MBytes 18.8 Mbits/sec 0 464 KBytes [ 4] 7.00-8.00 sec 1.86 MBytes 15.6 Mbits/sec 1 332 KBytes [ 4] 8.00-9.00 sec 2.24 MBytes 18.8 Mbits/sec 0 365 KBytes [ 4] 9.00-10.00 sec 2.49 MBytes 20.8 Mbits/sec 0 387 KBytes MT7610 at 5G Reveal hidden contents [ 4] 0.00-1.00 sec 4.53 MBytes 38.0 Mbits/sec 0 209 KBytes [ 4] 1.00-2.00 sec 5.03 MBytes 42.2 Mbits/sec 0 411 KBytes [ 4] 2.00-3.00 sec 4.66 MBytes 39.1 Mbits/sec 0 583 KBytes [ 4] 3.00-4.00 sec 7.08 MBytes 59.4 Mbits/sec 61 481 KBytes [ 4] 4.00-5.00 sec 12.4 MBytes 104 Mbits/sec 11 382 KBytes [ 4] 5.00-6.00 sec 12.0 MBytes 101 Mbits/sec 0 414 KBytes [ 4] 6.00-7.00 sec 8.26 MBytes 69.3 Mbits/sec 0 431 KBytes [ 4] 7.00-8.00 sec 2.24 MBytes 18.8 Mbits/sec 0 443 KBytes [ 4] 8.00-9.00 sec 7.39 MBytes 62.0 Mbits/sec 0 447 KBytes [ 4] 9.00-10.00 sec 8.26 MBytes 69.3 Mbits/sec 0 447 KBytes MT7601U Reveal hidden contents [ 4] 0.00-1.00 sec 9.73 MBytes 81.6 Mbits/sec 0 407 KBytes [ 4] 1.00-2.00 sec 8.45 MBytes 70.9 Mbits/sec 15 421 KBytes [ 4] 2.00-3.00 sec 8.20 MBytes 68.8 Mbits/sec 0 477 KBytes [ 4] 3.00-4.00 sec 8.45 MBytes 70.9 Mbits/sec 0 515 KBytes [ 4] 4.00-5.00 sec 9.07 MBytes 76.1 Mbits/sec 4 393 KBytes [ 4] 5.00-6.00 sec 9.13 MBytes 76.6 Mbits/sec 0 420 KBytes [ 4] 6.00-7.00 sec 9.13 MBytes 76.6 Mbits/sec 0 433 KBytes [ 4] 7.00-8.00 sec 9.57 MBytes 80.3 Mbits/sec 0 440 KBytes [ 4] 8.00-9.00 sec 9.20 MBytes 77.2 Mbits/sec 0 440 KBytes [ 4] 9.00-10.00 sec 9.20 MBytes 77.1 Mbits/sec 0 452 KBytes Working for me too on my C2. The performance of RTL8188EUS is an order of magnitude faster than legacy kernel, and it doesn't drop connection after a few minutes as before.
JMCC Posted January 16, 2019 Posted January 16, 2019 On 12/28/2018 at 1:41 PM, rino said: Accelerated 4K full-screen video in vlc on Armbian Bionic 4.19 beta image of Le Potato is working. I followed your steps and didn't work. I did my tests on an Odroid C2, not sure if that would make a difference. It fails when opening vaapi, and keeps doing SW decoding: Spoiler vlc bbb_sunflower_2160p_30fps_normal.mp4 VLC media player 3.0.4 Vetinari (revision 3.0.4-0-gf615db6332) [0000aaaaee170580] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface. QXcbConnection: XCB error: 8 (BadMatch), sequence: 536, resource id: 52428809, major code: 2 (ChangeWindowAttributes), minor code: 0 [0000ffff58009fb0] main filter error: Failed to create video converter libva info: VA-API version 1.1.0 libva info: va_getDriverName() returns -1 libva error: va_getDriverName() failed with unknown libva error,driver_name=(null) [0000ffff540be0d0] vaapi_drm generic error: vaInitialize: unknown libva error [h264 @ 0xffff6cdcf3f0] co located POCs unavailable [h264 @ 0xffff6cdb3ed0] mmco: unref short failure QObject::~QObject: Timers cannot be stopped from another thread I also tried with ffmpeg, and the device is recognized but it does not decode any frame. This is the output: Spoiler ffmpeg -c:v h264_v4l2m2m -i bbb_sunflower_2160p_30fps_normal.mp4 -f rawvideo output_nv12 ffmpeg version 3.4.4-0ubuntu0.18.04.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 7 (Ubuntu/Linaro 7.3.0-16ubuntu3) configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libavresample 3. 7. 0 / 3. 7. 0 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'bbb_sunflower_2160p_30fps_normal.mp4': Metadata: major_brand : isom minor_version : 1 compatible_brands: isomavc1 creation_time : 2013-12-18T14:43:04.000000Z title : Big Buck Bunny, Sunflower version artist : Blender Foundation 2008, Janus Bager Kristensen 2013 comment : Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net genre : Animation composer : Sacha Goedegebure Duration: 00:10:34.53, start: 0.000000, bitrate: 7980 kb/s Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 3840x2160 [SAR 1:1 DAR 16:9], 7498 kb/s, 30 fps, 30 tbr, 30k tbn, 60 tbc (default) Metadata: creation_time : 2013-12-18T14:43:04.000000Z handler_name : GPAC ISO Video Handler Stream #0:1(und): Audio: mp3 (mp4a / 0x6134706D), 48000 Hz, stereo, s16p, 160 kb/s (default) Metadata: creation_time : 2013-12-18T14:43:06.000000Z handler_name : GPAC ISO Audio Handler Stream #0:2(und): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, 5.1(side), fltp, 320 kb/s (default) Metadata: creation_time : 2013-12-18T14:43:06.000000Z handler_name : GPAC ISO Audio Handler Side data: audio service type: main [h264_v4l2m2m @ 0xaaaaff943250] driver 'meson-vdec' on card 'Amlogic Video Decoder' [h264_v4l2m2m @ 0xaaaaff943250] Using device /dev/video0 [h264_v4l2m2m @ 0xaaaaff943250] driver 'meson-vdec' on card 'Amlogic Video Decoder' Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_v4l2m2m) -> rawvideo (native)) Press [q] to stop, [?] for help [h264_v4l2m2m @ 0xaaaaff943250] output POLLERR frame= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbFinishing stream 0:0 without any data written to it. Output #0, rawvideo, to 'output_nv12': Metadata: major_brand : isom minor_version : 1 compatible_brands: isomavc1 composer : Sacha Goedegebure title : Big Buck Bunny, Sunflower version artist : Blender Foundation 2008, Janus Bager Kristensen 2013 comment : Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net genre : Animation encoder : Lavf57.83.100 Stream #0:0(und): Video: rawvideo (I420 / 0x30323449), yuv420p, 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, 2985984 kb/s, 30 fps, 30 tbn, 30 tbc (default) Metadata: creation_time : 2013-12-18T14:43:04.000000Z handler_name : GPAC ISO Video Handler encoder : Lavc57.107.100 rawvideo frame= 0 fps=0.0 q=0.0 Lsize= 0kB time=00:00:00.00 bitrate=N/A speed= 0x video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Output file is empty, nothing was encoded (check -ss / -t / -frames parameters if used) Exiting normally, received signal 2. juan@odroidc2:/media/juan/ESD-USB/Video$ ffmpeg -c:v h264_v4l2m2m -i tears_of_steel_1080p.mov -f rawvideo output_nv12 ffmpeg version 3.4.4-0ubuntu0.18.04.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 7 (Ubuntu/Linaro 7.3.0-16ubuntu3) configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libavresample 3. 7. 0 / 3. 7. 0 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'tears_of_steel_1080p.mov': Metadata: major_brand : qt minor_version : 512 compatible_brands: qt encoder : Lavf53.32.100 Duration: 00:12:14.17, start: 0.000000, bitrate: 6361 kb/s Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1920x800 [SAR 1:1 DAR 12:5], 6162 kb/s, 24 fps, 24 tbr, 24 tbn, 48 tbc (default) Metadata: handler_name : DataHandler encoder : libx264 Stream #0:1(eng): Audio: mp3 (.mp3 / 0x33706D2E), 44100 Hz, stereo, s16p, 191 kb/s (default) Metadata: handler_name : DataHandler File 'output_nv12' already exists. Overwrite ? [y/N] y [h264_v4l2m2m @ 0xaaaaf27dba00] driver 'meson-vdec' on card 'Amlogic Video Decoder' [h264_v4l2m2m @ 0xaaaaf27dba00] Using device /dev/video0 [h264_v4l2m2m @ 0xaaaaf27dba00] driver 'meson-vdec' on card 'Amlogic Video Decoder' Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_v4l2m2m) -> rawvideo (native)) Press [q] to stop, [?] for help [h264_v4l2m2m @ 0xaaaaf27dba00] output POLLERR Finishing stream 0:0 without any data written to it.14:32:22.77 bitrate= -0.0kbits/s speed=N/A Output #0, rawvideo, to 'output_nv12': Metadata: major_brand : qt minor_version : 512 compatible_brands: qt encoder : Lavf57.83.100 Stream #0:0(eng): Video: rawvideo (I420 / 0x30323449), yuv420p, 1920x800 [SAR 1:1 DAR 12:5], q=2-31, 442368 kb/s, 24 fps, 24 tbn, 24 tbc (default) Metadata: handler_name : DataHandler encoder : Lavc57.107.100 rawvideo frame= 0 fps=0.0 q=0.0 Lsize= 0kB time=00:00:00.00 bitrate=N/A speed= 0x video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Output file is empty, nothing was encoded (check -ss / -t / -frames parameters if used) Exiting normally, received signal 2. However, I was successful in getting gles to work on X11, using the module from here: https://github.com/superna9999/meson_gx_mali_450. See attached image. It was just good enough for running glmark2-es2, when I tried to run Chromium with egl, it failed with EGL_BAD_ALLOC. [EDIT]: No, it was just a bad flag! Chromium WebGL is also working! See attached pic @Neil Armstrong @TonyMac32 Is there any chance that we patch this mali module into the kernel, so we can test it without the need to compile it separately?
TonyMac32 Posted January 16, 2019 Author Posted January 16, 2019 @Jmcc I briefly tried it, didn't get anywhere. That would be ideal of course, have it as a patch.Sent from my Pixel using Tapatalk
beautynow Posted January 17, 2019 Posted January 17, 2019 (edited) Spoiler 14 hours ago, JMCC said: I followed your steps and didn't work. I did my tests on an Odroid C2, not sure if that would make a difference. It fails when opening vaapi, and keeps doing SW decoding: Reveal hidden contents vlc bbb_sunflower_2160p_30fps_normal.mp4 VLC media player 3.0.4 Vetinari (revision 3.0.4-0-gf615db6332) [0000aaaaee170580] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface. QXcbConnection: XCB error: 8 (BadMatch), sequence: 536, resource id: 52428809, major code: 2 (ChangeWindowAttributes), minor code: 0 [0000ffff58009fb0] main filter error: Failed to create video converter libva info: VA-API version 1.1.0 libva info: va_getDriverName() returns -1 libva error: va_getDriverName() failed with unknown libva error,driver_name=(null) [0000ffff540be0d0] vaapi_drm generic error: vaInitialize: unknown libva error [h264 @ 0xffff6cdcf3f0] co located POCs unavailable [h264 @ 0xffff6cdb3ed0] mmco: unref short failure QObject::~QObject: Timers cannot be stopped from another thread I also tried with ffmpeg, and the device is recognized but it does not decode any frame. This is the output: Reveal hidden contents ffmpeg -c:v h264_v4l2m2m -i bbb_sunflower_2160p_30fps_normal.mp4 -f rawvideo output_nv12 ffmpeg version 3.4.4-0ubuntu0.18.04.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 7 (Ubuntu/Linaro 7.3.0-16ubuntu3) configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libavresample 3. 7. 0 / 3. 7. 0 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'bbb_sunflower_2160p_30fps_normal.mp4': Metadata: major_brand : isom minor_version : 1 compatible_brands: isomavc1 creation_time : 2013-12-18T14:43:04.000000Z title : Big Buck Bunny, Sunflower version artist : Blender Foundation 2008, Janus Bager Kristensen 2013 comment : Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net genre : Animation composer : Sacha Goedegebure Duration: 00:10:34.53, start: 0.000000, bitrate: 7980 kb/s Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 3840x2160 [SAR 1:1 DAR 16:9], 7498 kb/s, 30 fps, 30 tbr, 30k tbn, 60 tbc (default) Metadata: creation_time : 2013-12-18T14:43:04.000000Z handler_name : GPAC ISO Video Handler Stream #0:1(und): Audio: mp3 (mp4a / 0x6134706D), 48000 Hz, stereo, s16p, 160 kb/s (default) Metadata: creation_time : 2013-12-18T14:43:06.000000Z handler_name : GPAC ISO Audio Handler Stream #0:2(und): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, 5.1(side), fltp, 320 kb/s (default) Metadata: creation_time : 2013-12-18T14:43:06.000000Z handler_name : GPAC ISO Audio Handler Side data: audio service type: main [h264_v4l2m2m @ 0xaaaaff943250] driver 'meson-vdec' on card 'Amlogic Video Decoder' [h264_v4l2m2m @ 0xaaaaff943250] Using device /dev/video0 [h264_v4l2m2m @ 0xaaaaff943250] driver 'meson-vdec' on card 'Amlogic Video Decoder' Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_v4l2m2m) -> rawvideo (native)) Press [q] to stop, [?] for help [h264_v4l2m2m @ 0xaaaaff943250] output POLLERR frame= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbframe= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbFinishing stream 0:0 without any data written to it. Output #0, rawvideo, to 'output_nv12': Metadata: major_brand : isom minor_version : 1 compatible_brands: isomavc1 composer : Sacha Goedegebure title : Big Buck Bunny, Sunflower version artist : Blender Foundation 2008, Janus Bager Kristensen 2013 comment : Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net genre : Animation encoder : Lavf57.83.100 Stream #0:0(und): Video: rawvideo (I420 / 0x30323449), yuv420p, 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, 2985984 kb/s, 30 fps, 30 tbn, 30 tbc (default) Metadata: creation_time : 2013-12-18T14:43:04.000000Z handler_name : GPAC ISO Video Handler encoder : Lavc57.107.100 rawvideo frame= 0 fps=0.0 q=0.0 Lsize= 0kB time=00:00:00.00 bitrate=N/A speed= 0x video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Output file is empty, nothing was encoded (check -ss / -t / -frames parameters if used) Exiting normally, received signal 2. juan@odroidc2:/media/juan/ESD-USB/Video$ ffmpeg -c:v h264_v4l2m2m -i tears_of_steel_1080p.mov -f rawvideo output_nv12 ffmpeg version 3.4.4-0ubuntu0.18.04.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 7 (Ubuntu/Linaro 7.3.0-16ubuntu3) configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libavresample 3. 7. 0 / 3. 7. 0 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'tears_of_steel_1080p.mov': Metadata: major_brand : qt minor_version : 512 compatible_brands: qt encoder : Lavf53.32.100 Duration: 00:12:14.17, start: 0.000000, bitrate: 6361 kb/s Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1920x800 [SAR 1:1 DAR 12:5], 6162 kb/s, 24 fps, 24 tbr, 24 tbn, 48 tbc (default) Metadata: handler_name : DataHandler encoder : libx264 Stream #0:1(eng): Audio: mp3 (.mp3 / 0x33706D2E), 44100 Hz, stereo, s16p, 191 kb/s (default) Metadata: handler_name : DataHandler File 'output_nv12' already exists. Overwrite ? [y/N] y [h264_v4l2m2m @ 0xaaaaf27dba00] driver 'meson-vdec' on card 'Amlogic Video Decoder' [h264_v4l2m2m @ 0xaaaaf27dba00] Using device /dev/video0 [h264_v4l2m2m @ 0xaaaaf27dba00] driver 'meson-vdec' on card 'Amlogic Video Decoder' Stream mapping: Stream #0:0 -> #0:0 (h264 (h264_v4l2m2m) -> rawvideo (native)) Press [q] to stop, [?] for help [h264_v4l2m2m @ 0xaaaaf27dba00] output POLLERR Finishing stream 0:0 without any data written to it.14:32:22.77 bitrate= -0.0kbits/s speed=N/A Output #0, rawvideo, to 'output_nv12': Metadata: major_brand : qt minor_version : 512 compatible_brands: qt encoder : Lavf57.83.100 Stream #0:0(eng): Video: rawvideo (I420 / 0x30323449), yuv420p, 1920x800 [SAR 1:1 DAR 12:5], q=2-31, 442368 kb/s, 24 fps, 24 tbn, 24 tbc (default) Metadata: handler_name : DataHandler encoder : Lavc57.107.100 rawvideo frame= 0 fps=0.0 q=0.0 Lsize= 0kB time=00:00:00.00 bitrate=N/A speed= 0x video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Output file is empty, nothing was encoded (check -ss / -t / -frames parameters if used) Exiting normally, received signal 2. However, I was successful in getting gles to work on X11, using the module from here: https://github.com/superna9999/meson_gx_mali_450. See attached image. It was just good enough for running glmark2-es2, when I tried to run Chromium with egl, it failed with EGL_BAD_ALLOC. [EDIT]: No, it was just a bad flag! Chromium WebGL is also working! See attached pic @Neil Armstrong @TonyMac32 Is there any chance that we patch this mali module into the kernel, so we can test it without the need to compile it separately? Hello @JMCC Could you kindly tell me how to get gles to work on X11? I want to try mainline kernel with gles on my C2. Thanks so much. Edited January 17, 2019 by Tido added spoiler - for better reading, please do that yourself next time. thx
JMCC Posted January 17, 2019 Posted January 17, 2019 11 minutes ago, beautynow said: Hello @JMCC Could you kindly tell me how to get gles to work on X11? I want to try mainline kernel with gles on my C2. Thanks so much. Hello. I'm still testing, I want to post a howto/script when I have some more results. 2
JMCC Posted January 17, 2019 Posted January 17, 2019 Aha, I got it. We were missing the firmware. Here is the output of mpv. Notice the line confirming the use of hardware decoding: Spoiler $ mpv --hwdec=v4l2m2m-copy bbb_sunflower_1080p_60fps_normal.mp4 Playing: bbb_sunflower_1080p_60fps_normal.mp4 (+) Video --vid=1 (*) (h264 1920x1080 60.000fps) (+) Audio --aid=1 (*) (mp3 2ch 48000Hz) Audio --aid=2 (*) (ac3 6ch 48000Hz) File tags: Artist: Blender Foundation 2008, Janus Bager Kristensen 2013 Comment: Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net Composer: Sacha Goedegebure Genre: Animation Title: Big Buck Bunny, Sunflower version libGL error: unable to load driver: meson_dri.so libGL error: driver pointer missing libGL error: failed to load driver: meson [vo/gpu/opengl] Suspected software renderer or indirect context. Using hardware decoding (v4l2m2m-copy). No video PTS! Making something up. Using 60.000000 FPS. VO: [gpu] 1920x1080 nv12 AO: [pulse] 48000Hz stereo 2ch float No video PTS! Making something up. Using 60.000000 FPS. Ignoring further missing PTS warnings. AV: 00:00:04 / 00:10:34 (0%) A-V: 0.000 Dropped: 207 Exiting... (Quit) Here is a ffmpeg output: Spoiler ffmpeg -c:v mpeg2_v4l2m2m -i MPEG2_1080i_sample.mkv -f rawvideo output_nv12 ffmpeg version 3.4.4-0ubuntu0.18.04.1 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 7 (Ubuntu/Linaro 7.3.0-16ubuntu3) configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared WARNING: library configuration mismatch avcodec configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared --enable-version3 --disable-doc --disable-programs --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libtesseract --enable-libvo_amrwbenc avfilter configuration: --prefix=/usr --extra-version=0ubuntu0.18.04.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared --enable-version3 --disable-doc --disable-programs --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libtesseract --enable-libvo_amrwbenc libavutil 55. 78.100 / 55. 78.100 libavcodec 57.107.100 / 57.107.100 libavformat 57. 83.100 / 57. 83.100 libavdevice 57. 10.100 / 57. 10.100 libavfilter 6.107.100 / 6.107.100 libavresample 3. 7. 0 / 3. 7. 0 libswscale 4. 8.100 / 4. 8.100 libswresample 2. 9.100 / 2. 9.100 libpostproc 54. 7.100 / 54. 7.100 [mpeg2_v4l2m2m @ 0xaaaaeb90cba0] driver 'meson-vdec' on card 'Amlogic Video Decoder' [mpeg2_v4l2m2m @ 0xaaaaeb90cba0] Using device /dev/video0 [mpeg2_v4l2m2m @ 0xaaaaeb90cba0] driver 'meson-vdec' on card 'Amlogic Video Decoder' [mpeg2_v4l2m2m @ 0xaaaaeb90cba0] output POLLERR Input #0, matroska,webm, from 'MPEG2_1080i_sample.mkv': Metadata: encoder : libebml v1.3.1 + libmatroska v1.4.2 creation_time : 2015-05-28T12:43:09.000000Z Duration: 00:01:00.14, start: 0.067000, bitrate: 17990 kb/s Stream #0:0: Video: mpeg2video, yuv420p(top first), 1920x1080, SAR 1:1 DAR 16:9, 29.97 fps, 29.97 tbr, 1k tbn, 59.94 tbc (default) Metadata: BPS : 17562211 BPS-eng : 17562211 DURATION : 00:01:00.060000000 DURATION-eng : 00:01:00.060000000 NUMBER_OF_FRAMES: 1800 NUMBER_OF_FRAMES-eng: 1800 NUMBER_OF_BYTES : 131848306 NUMBER_OF_BYTES-eng: 131848306 _STATISTICS_WRITING_APP: mkvmerge v7.9.0 ('Birds') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v7.9.0 ('Birds') 64bit _STATISTICS_WRITING_DATE_UTC: 2015-05-28 12:43:09 _STATISTICS_WRITING_DATE_UTC-eng: 2015-05-28 12:43:09 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default) Metadata: BPS : 448000 BPS-eng : 448000 DURATION : 00:01:00.064000000 DURATION-eng : 00:01:00.064000000 NUMBER_OF_FRAMES: 1877 NUMBER_OF_FRAMES-eng: 1877 NUMBER_OF_BYTES : 3363584 NUMBER_OF_BYTES-eng: 3363584 _STATISTICS_WRITING_APP: mkvmerge v7.9.0 ('Birds') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v7.9.0 ('Birds') 64bit _STATISTICS_WRITING_DATE_UTC: 2015-05-28 12:43:09 _STATISTICS_WRITING_DATE_UTC-eng: 2015-05-28 12:43:09 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES [mpeg2_v4l2m2m @ 0xaaaaeb9637c0] driver 'meson-vdec' on card 'Amlogic Video Decoder' [mpeg2_v4l2m2m @ 0xaaaaeb9637c0] Using device /dev/video0 [mpeg2_v4l2m2m @ 0xaaaaeb9637c0] driver 'meson-vdec' on card 'Amlogic Video Decoder' Stream mapping: Stream #0:0 -> #0:0 (mpeg2video (mpeg2_v4l2m2m) -> rawvideo (native)) Press [q] to stop, [?] for help [mpeg2_v4l2m2m @ 0xaaaaeb9637c0] output POLLERR Output #0, rawvideo, to 'output_nv12': Metadata: encoder : Lavf57.83.100 Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 745750 kb/s, 29.97 fps, 29.97 tbn, 29.97 tbc (default) Metadata: BPS : 17562211 BPS-eng : 17562211 DURATION : 00:01:00.060000000 DURATION-eng : 00:01:00.060000000 NUMBER_OF_FRAMES: 1800 NUMBER_OF_FRAMES-eng: 1800 NUMBER_OF_BYTES : 131848306 NUMBER_OF_BYTES-eng: 131848306 _STATISTICS_WRITING_APP: mkvmerge v7.9.0 ('Birds') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v7.9.0 ('Birds') 64bit _STATISTICS_WRITING_DATE_UTC: 2015-05-28 12:43:09 _STATISTICS_WRITING_DATE_UTC-eng: 2015-05-28 12:43:09 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES encoder : Lavc57.107.100 rawvideo frame= 10 fps=0.0 q=-0.0 size= 30208kB time=00:00:00.33 bitrate=741649.4kbitframe= 21 fps= 20 q=-0.0 size= 63744kB time=00:00:00.70 bitrate=745241.7kbitframe= 32 fps= 20 q=-0.0 size= 97024kB time=00:00:01.06 bitrate=744400.2kbitframe= 42 fps= 20 q=-0.0 size= 127488kB time=00:00:01.40 bitrate=745241.7kbitframe= 44 fps= 19 q=-0.0 Lsize= 133650kB time=00:00:01.46 bitrate=745750.4kbits/s speed=0.63x video:133650kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000% [mpeg2_v4l2m2m @ 0xaaaaeb9637c0] ff_v4l2m2m_codec_end leaving pending buffers Exiting normally, received signal 2. Though, performance is far from being good yet. Let's see if I can find some time to package everything I have so far into a script, for others to test too. I'm attaching the firmware here. @Igor I'm going to add it to the armbian/firmware repo. meson-firmware.tgz 1
Igor Posted January 18, 2019 Posted January 18, 2019 23 hours ago, JMCC said: I'm going to add it to the armbian/firmware repo. ok
Neil Armstrong Posted February 4, 2019 Posted February 4, 2019 @Igorthe firnware are stored here https://github.com/LibreELEC/meson-firmware until we manage to get them into linux-firmware...
JMCC Posted February 4, 2019 Posted February 4, 2019 26 minutes ago, Neil Armstrong said: @Igorthe firnware are stored here https://github.com/LibreELEC/meson-firmware until we manage to get them into linux-firmware... Here are my results so far with the v4l2 decoder: I'm able to decode h.264 at 1080p correctly. MPEG2 at 1080p, and h.264 at 2160p are accepted by the decoder, but I get no output, it just hangs. HEVC is simply not accepted by the decoder, I can only do SW decoding. Does that correspond to the current status of the driver, or we should be getting something better?
JMCC Posted February 8, 2019 Posted February 8, 2019 I made a very rough and basic, alpha (or pre-alpha) script, to test the v4l2 decoder and the mali kernel module. I tried to integrate the mali module into the kernel, but I wasn't able to make it work. No matter what I tried, it was always the same: the module was loaded, you could see it in dmesg and in lsmod, but the "/dev/mali" node was never there. I suppose that is why everywhere on the net, people are compiling the mali module separately from the kernel. Any suggestions to sort this problem out are welcome: Wait until lima is mainlined? There seems to be hope that it can happen soon. Make a DKMS package for the module? In any case, this is the thread for the script:
TonyMac32 Posted February 9, 2019 Author Posted February 9, 2019 16 hours ago, JMCC said: suppose that is why everywhere on the net, people are compiling the mali module separately from the kernel. It's not taking the config you're feeding it, if it's doing what it did to me when I tried it. I know it's not in his 'need to do' list, but perhaps @Neil Armstrong can shed some light? I've stuffed Midgard drivers into the kernel for in-tree compilation without much difficulty, but these sources are messing with me. I also don't claim to be a wizard or a professional.
JMCC Posted February 9, 2019 Posted February 9, 2019 2 hours ago, TonyMac32 said: It's not taking the config you're feeding it If that's the case, then we can just use the tough solution: change the defaults in the module source to the ones we need. Kind of a dirty fix but, as I said, it is probably just a temporary solution until something is figured out in upstream mainline. [Edit:] However, in any case, that was not my problem. When I made config changes, I could confirm that it was making a difference in the way the module was compiled (either as a module or as part of the kernel), the options it enabled, etc.. But, again, nothing worked. I even got to the point of applying a patch from the Odroid forums to enable UMP, and the "/dev/ump" node would appear, but mali still would not.
TonyMac32 Posted February 9, 2019 Author Posted February 9, 2019 12 minutes ago, JMCC said: If that's the case, then we can just use the tough solution: It might also be worth looking into simply scripting the cloning and compiling of such out of tree code as part of the board configs, the amount of work to graft this stuff in can be time consuming. On another note, did you get the firmwares into the package system?
JMCC Posted February 9, 2019 Posted February 9, 2019 18 minutes ago, TonyMac32 said: simply scripting the cloning and compiling of such out of tree code as part of the board configs But that would mean losing the module when the board updates the kernel, if I'm not wrong. We would need to do a DKMS package for the module, and that can be time consuming too. Specially if you consider that I tried to compile the module natively on the board and it wouldn't work, so we would need to figure out that problem too. 21 minutes ago, TonyMac32 said: did you get the firmwares into the package system? I did: https://github.com/armbian/firmware/commit/8bdf0a6b1896a6ce67eb7d10caefeced3cc5e984
TonyMac32 Posted February 9, 2019 Author Posted February 9, 2019 The function might be able to be hooked into the makedeb part of the kernel build script, I haven't spent more than 2-3 minutes considering the option, mostly brainstorming, since this won't be the last such piece of code.
balbes150 Posted February 10, 2019 Posted February 10, 2019 What sources (Neil Armstrong branch) of the Mali driver do you use ?
JMCC Posted February 10, 2019 Posted February 10, 2019 2 hours ago, balbes150 said: What sources (Neil Armstrong branch) of the Mali driver do you use ? DX910-SW-99002-r7p0-00rel1_meson_gx
balbes150 Posted February 10, 2019 Posted February 10, 2019 2 hours ago, JMCC said: DX910-SW-99002-r7p0-00rel1_meson_gx I tried to build a Mali module (two versions 6 and 7), executed a script on the system (to install all the files and settings, but left my kernel with Mali modules for Khadas VIM1). When launching the Mali module, the kernel is automatically accepted and the system has a "/dev/mali" device. When you start MPV, the video plays in a window without brakes (with the resolution that the video file itself has) . If the resolution of the desktop 1080, run video 720, the window runs without brakes, but if you try to expand to full screen, the video starts to slow down. Tried Gstreamer, it starts, but when you try to play something, there is nothing on the screen and no sound. This behavior with both Mali 6 and 7 modules (when I replace the module, I also change the libMali library to the same version from the m450-X directory from GIT ). How can I check the overall operation of the armsoc driver ? Perhaps there are some commands\utilities that can show that the driver is using HW mode ?
JMCC Posted February 10, 2019 Posted February 10, 2019 1 hour ago, balbes150 said:  there are some commands\utilities that can show that the driver is using HW mode Using mpv from the command line console should give you a log, with info about the decoder and display driver it is using. Also with gst-play-1.0 for gstreamer. Also, running glmark2-es2 will tell you whether it is using Mesa SW emulation, or Mali. For last, if you have configured chromium to use acceleration (like my script does), you can check whether it is working by typing in the address bar "chrome://gpu" Edit: And, of course, you can also check /var/log/Xorg.0.log 1
balbes150 Posted February 15, 2019 Posted February 15, 2019 I added Mali sources to the kernel sources to build the module together with the kernel. The module is built and the system can load it, but HW does not work and the size of the module is significantly smaller than the one that is built according to the old scheme from a separate directory. Perhaps you need additional options or settings ? I don't know which ones. May be more experienced comrades will be able to suggest what else need to add to fix it ? During the tests, I found several reasons (which are not immediately noticeable) that affect the launch of HW. The sources of the kernel should be only 4.19 (with the corresponding patches), if you try at 4.20, like everything is, but HW does not work. Just be sure to need a script control Hot-HDMI. I wonder why HW doesn't work without it ?
JMCC Posted February 15, 2019 Posted February 15, 2019 1 hour ago, balbes150 said: I added Mali sources to the kernel sources to build the module together with the kernel. The module is built and the system can load it, but HW does not work and the size of the module is significantly smaller than the one that is built according to the old scheme from a separate directory. Perhaps you need additional options or settings ? I don't know which ones. May be more experienced comrades will be able to suggest what else need to add to fix it ? During the tests, I found several reasons (which are not immediately noticeable) that affect the launch of HW. The sources of the kernel should be only 4.19 (with the corresponding patches), if you try at 4.20, like everything is, but HW does not work. Just be sure to need a script control Hot-HDMI. I wonder why HW doesn't work without it ? Yes, that's the point where everybody gets stuck. @TonyMac32 suggested some posts above that the driver may not be getting the config you feed it, so maybe that can be the cause for the problem. I may give it some other try, but the truth is that I don't think it is worth spending much time on this, until some steps are taken upstream. The v4l2-m2m driver is still immature, and there are also chances that the Lima driver can be mainlined for the next release (see some posts above). It is probably time to wait, and work in some other projects in the meantime (like Rockchip). However, as I said, I may give a try to the possibility of hardcoding the compile options, as a possible temporary solution, as I mentioned some posts above.
balbes150 Posted February 15, 2019 Posted February 15, 2019 if I change the configuration kernel, change the size of the module. And I added options from the build script 'buid.sh" in the makefile itself. If select the option in the UMP kernel configuration, the build fails. I also do not plan to spend a lot of time, but you can try.
lanefu Posted March 18, 2019 Posted March 18, 2019 So I'm on a fresh build of a Le Potato desktop... I'm able to run at 1080p just fine, but no easy config for the higher 2k or 4k resolutions... I tried both latest dev kernel, and next kernel.... Not sure how hard I try to make it work via X config... or go kernel hunting, device tree hacking or what..... maybe the "default" kernel? eww (My Tritium H5 can do it :P... same monitor, same cables etc)
