Anna Vahtera Posted March 25, 2020 Posted March 25, 2020 (edited) I hope I can ask here (I'm new so it won't let me post a question on the main H6 page). What's the difference between the images for Orange Pi 3 and Orange Pi Lite 2? I have both boards, downloaded both images. The Lite 2 image (Armbian_20.02.1_Orangepilite2_buster_current_5.4.20.img) works on both boards, flawlessly (well as flawlessy as Armbian and Orange Pi ever do). Both boards boot just fine with that image. However the OPi3 does not display anything with the 3 image (Armbian_20.02.1_Orangepi3_buster_current_5.4.20.img). I can connect to the board via serial console and I can see it booting fine and I can interact with it, but it does not display anything at all. So there's some difference between those images that prevents the OPi3 from displaying anything. I haven't yet tried to boot the Lite2 with the OPi3 image, will get to that later. Edited March 25, 2020 by Anna Vahtera wrong filename
martinayotte Posted March 25, 2020 Posted March 25, 2020 10 minutes ago, Anna Vahtera said: What's the difference between the images for Orange Pi 3 and Orange Pi Lite 2? OPi3 has eMMC while OPiLite2 doesn't . 11 minutes ago, Anna Vahtera said: So there's some difference between those images that prevents the OPi3 from displaying anything. HDMI is working fine on my OPi3 using 5.6.0-rc3, although I don´t have "desktop" and stay at "headless". So, maybe try another HDMI monitor ...
Anna Vahtera Posted March 25, 2020 Posted March 25, 2020 1 minute ago, martinayotte said: OPi3 has eMMC while OPiLite2 doesn't . HDMI is working fine on my OPi3 using 5.6.0-rc3, although I don´t have "desktop" and stay at "headless". So, maybe try another HDMI monitor ... Well, the OPi3 has the option of having an eMMC, it doesn't necessarily have it - mine doesn't. I don't even have a slot for it, just solder markers on the board. So maybe that's the problem? If the OPi3 image assumes the board has eMMC when it doesn't, and then that doesn't work? It would be too weird if it was the monitor, as both the boards work well with the same monitor when booting the Lite2 image. It works on the OPi3 when booting either OPi3 Android 7 or OPi1+ Android 9. It works with RPi and Rasbian, RetroPie. I highly doubt it would be the monitor if the Lite2 image works with both boards just fine. It's just the OPi3 image that doesn't work. ps. The Lite2 does not boot with the OPi3 image either, just tested.
Localhost Posted March 25, 2020 Posted March 25, 2020 Quote The Lite2 does not boot with the OPi3 image either, just tested You need to change the dtb file I did the same with LibreElec image, and had success only after I changed dtb file Btw. Has anyone had success with HDMI audio using 5.6 kernel?
martinayotte Posted March 25, 2020 Posted March 25, 2020 1 hour ago, Anna Vahtera said: If the OPi3 image assumes the board has eMMC when it doesn't, and then that doesn't work? No, since all Allwinner's SoC has boot priority on SD. 1 hour ago, Anna Vahtera said: It would be too weird if it was the monitor I know it is a bit weird, but in my case, HDMI is working ...
Anna Vahtera Posted March 25, 2020 Posted March 25, 2020 (edited) 6 hours ago, martinayotte said: No, since all Allwinner's SoC has boot priority on SD. I know it is a bit weird, but in my case, HDMI is working ... Mine too, HDMI *is* working, perfectly. With Android 7/9 AND the same Armbian version with the Lite2 image - that's why I said I highly doubt it's the monitor. HDMI *is* working, it's just the OPi3 image that won't display anything. It displays everything just perfectly if I boot it with the Lite2 image (since the hardware is pretty much identical, the OPi3 just has the option for eMMC and it has more ports, that's pretty much it) EDIT: Here's too captures (via serial) of the board booting: OPi3 booting Lite2 image: https://pastebin.com/tRgtehHA (HDMI Out IS working with this image) OPi3 booting OPi3 image: https://pastebin.com/4yig6Pd9 (HDMI Out is NOT working with this image) The Lite2 has UART3 enabled, otherwise it is the same. I noted that there is a bunch of voltage info at the top which is missing from the OPi3 image. I don't know if this is relevant. I also don't know what to make of this, but just noting that both of the boards boot well with the Lite2 image and neither of the boards boot with the OPi3 image. There's GOTTA be a difference there, it's not hardware. EDIT2: Here's 'dmesg' from the two images booted on the OPi3:: Image "Lite2", Working HDMI: https://pastebin.com/gNrFBj1G Image "OPi3", No HDMI: https://pastebin.com/MBiueDe0 Edited March 25, 2020 by Anna Vahtera Added links to pastebin for booting captures | EDIT2: Added dmesg info
maxpyeha Posted April 19, 2020 Posted April 19, 2020 Good afternoon, tell me what to do! Armbian ceased to be sad and constantly reboots (an example in the attached file). It does not boot from a flash drive, I made it with Etcher. I don't understand much about Linux, but I can follow the step-by-step instructions. Thank you in advance.
Igor Posted April 19, 2020 Posted April 19, 2020 14 hours ago, maxpyeha said: but I can follow the step-by-step instructions Its always the same: https://docs.armbian.com/User-Guide_Getting-Started/ 14 hours ago, maxpyeha said: tell me what to do! Armbian ceased to be sad and constantly reboots Tell us exactly what you did. Tell us everything, perhaps make a photo of a board, SD card, cablings. Did you try different SD cards, which images, ... The picture you added, only tells something is wrong with a file system - it / SD card can't be found.
andydj Posted April 24, 2020 Posted April 24, 2020 (edited) Hi , i have a Orange Pi One plus and i have some problem : 1)video resolution stuck on 1024x768 and less colore bit instead of 1920x1080 in my TV 2)Hardware acceleration in h264 encoding , i don't know how i have to use it 3) when i try ti update kernel i got an error "test install failed" Edited April 24, 2020 by andydj Correction
Werner Posted April 24, 2020 Posted April 24, 2020 15 minutes ago, andydj said: Hi , i have a Orange Pi One plus and i have some problem : 1)video resolution stuck on 1024x768 and less colore bit instead of 1920x1080 of May TV 2)Hardware acceleration on h264 codec , i don't know how i have to use it For 1) try For 2) modprobe cedrus. Everything above is beyond Armbian's part. For 3) armbianmonitor -u And complete console log from installation
Localhost Posted April 24, 2020 Posted April 24, 2020 2 minutes ago, andydj said: Hi , i have a Orange Pi One plus and i have some problem : 1)video resolution stuck on 1024x768 and less colore bit instead of 1920x1080 of May TV 2)Hardware acceleration on h264 codec , i don't know how i have to use it You can use xrandr to fix the resolution See : https://askubuntu.com/questions/377937/how-to-set-a-custom-resolution
fsb4000 Posted April 24, 2020 Posted April 24, 2020 (edited) 1 hour ago, andydj said: Hi , i have a Orange Pi One plus and i have some problem : 1)video resolution stuck on 1024x768 and less colore bit instead of 1920x1080 in my TV For the problem, my solution is: 1. Boot the board. 2. cd /boot 3. sudo nano armbianEnv.txt 4. Add extraargs=video=HDMI-A-1:1920x1080@60 5. Save file. 6. sudo mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr 7. reboot It is worked for me with Orangepi lite2. Edited April 24, 2020 by fsb4000
Igor Posted April 24, 2020 Posted April 24, 2020 1 hour ago, fsb4000 said: 6. sudo mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr This is not needed.
andydj Posted April 24, 2020 Posted April 24, 2020 16 hours ago, Werner said: For 1) try For 2) modprobe cedrus. Everything above is beyond Armbian's part. For 3) armbianmonitor -u And complete console log from installation Many thanks to all 1)Resolution fixed to 1920x1080 , less video artifact but i have no audio and slow on youtube 2) modprobe: FATAL: Module cedrus not found in directory /lib/modules/5.4.28-sunxi64 3) http://ix.io/2jpr
Werner Posted April 25, 2020 Posted April 25, 2020 6 hours ago, andydj said: Many thanks to all 1)Resolution fixed to 1920x1080 , less video artifact but i have no audio and slow on youtube 2) modprobe: FATAL: Module cedrus not found in directory /lib/modules/5.4.28-sunxi64 3) http://ix.io/2jpr [ 4.909501] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 4.912325] cedrus 1c0e000.video-codec: Device registered as /dev/video0 Maybe due to missing hardware acceleration. But that is another story. Maybe retry later with kernel 5.6. Cedrus is loaded at boot it seems and therefore available. Cannot find a cause why the kernel update should fail. try again and copy the full console output including the update command.
Localhost Posted April 25, 2020 Posted April 25, 2020 Has anyone had success with hdmi audio and kernel 5.6? I didn't manage to get it to work Also I tried the "HDMI audio tutorial" post, and it didn't have any effect, because the patches it listed were already in armbian
andydj Posted April 25, 2020 Posted April 25, 2020 14 hours ago, Werner said: [ 4.909501] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 4.912325] cedrus 1c0e000.video-codec: Device registered as /dev/video0 Maybe due to missing hardware acceleration. But that is another story. Maybe retry later with kernel 5.6. Cedrus is loaded at boot it seems and therefore available. 14 hours ago, Werner said: Cannot find a cause why the kernel update should fail. try again and copy the full console output including the update command. For encoding i think i use wrong command ; i use in ffmpeg the option -c:v h264_vaapi and pix-fmt nv12 but i get error This is the output of ffmpeg -ecoders ffmpeg version 3.2.14-1~deb9u1 Copyright (c) 2000-2019 the FFmpeg developers built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516 configuration: --prefix=/usr --extra-version='1~deb9u1' --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared libavutil 55. 34.101 / 55. 34.101 libavcodec 57. 64.101 / 57. 64.101 libavformat 57. 56.101 / 57. 56.101 libavdevice 57. 1.100 / 57. 1.100 libavfilter 6. 65.100 / 6. 65.100 libavresample 3. 1. 0 / 3. 1. 0 libswscale 4. 2.100 / 4. 2.100 libswresample 2. 3.100 / 2. 3.100 libpostproc 54. 1.100 / 54. 1.100 Encoders: V..... = Video A..... = Audio S..... = Subtitle .F.... = Frame-level multithreading ..S... = Slice-level multithreading ...X.. = Codec is experimental ....B. = Supports draw_horiz_band .....D = Supports direct rendering method 1 ------ V..... a64multi Multicolor charset for Commodore 64 (codec a64_multi) V..... a64multi5 Multicolor charset for Commodore 64, extended with 5th color (colram) (codec a64_multi5) V..... alias_pix Alias/Wavefront PIX image V..... amv AMV Video V..... apng APNG (Animated Portable Network Graphics) image V..... asv1 ASUS V1 V..... asv2 ASUS V2 V..... avrp Avid 1:1 10-bit RGB Packer V..X.. avui Avid Meridien Uncompressed V..... ayuv Uncompressed packed MS 4:4:4:4 V..... bmp BMP (Windows and OS/2 bitmap) V..... cinepak Cinepak / CVID V..... cljr Cirrus Logic AccuPak V.S... vc2 SMPTE VC-2 (codec dirac) V.S... dnxhd VC3/DNxHD V..... dpx DPX (Digital Picture Exchange) image VFS... dvvideo DV (Digital Video) V.S... ffv1 FFmpeg video codec #1 VF.... ffvhuff Huffyuv FFmpeg variant V..... flashsv Flash Screen Video V..... flashsv2 Flash Screen Video Version 2 V..... flv FLV / Sorenson Spark / Sorenson H.263 (Flash Video) (codec flv1) V..... gif GIF (Graphics Interchange Format) V..... h261 H.261 V..... h263 H.263 / H.263-1996 V.S... h263p H.263+ / H.263-1998 / H.263 version 2 V..... libx264 libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (codec h264) V..... libx264rgb libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 RGB (codec h264) V..... h264_omx OpenMAX IL H.264 video encoder (codec h264) V..... h264_vaapi H.264/AVC (VAAPI) (codec h264) V..... hap Vidvox Hap encoder V..... libx265 libx265 H.265 / HEVC (codec hevc) V..... hevc_vaapi H.265/HEVC (VAAPI) (codec hevc) VF.... huffyuv Huffyuv / HuffYUV V..... jpeg2000 JPEG 2000 VF.... libopenjpeg OpenJPEG JPEG 2000 (codec jpeg2000) VF.... jpegls JPEG-LS VF.... ljpeg Lossless JPEG VFS... mjpeg MJPEG (Motion JPEG) V..... mjpeg_vaapi MJPEG (VAAPI) (codec mjpeg) V.S... mpeg1video MPEG-1 video V.S... mpeg2video MPEG-2 video V.S... mpeg4 MPEG-4 part 2 V..... libxvid libxvidcore MPEG-4 part 2 (codec mpeg4) V..... msmpeg4v2 MPEG-4 part 2 Microsoft variant version 2 V..... msmpeg4 MPEG-4 part 2 Microsoft variant version 3 (codec msmpeg4v3) V..... msvideo1 Microsoft Video-1 V..... pam PAM (Portable AnyMap) image V..... pbm PBM (Portable BitMap) image V..... pcx PC Paintbrush PCX image V..... pgm PGM (Portable GrayMap) image V..... pgmyuv PGMYUV (Portable GrayMap YUV) image VF.... png PNG (Portable Network Graphics) image V..... ppm PPM (Portable PixelMap) image VF.... prores Apple ProRes VF.... prores_aw Apple ProRes (codec prores) V.S... prores_ks Apple ProRes (iCodec Pro) (codec prores) V..... qtrle QuickTime Animation (RLE) video V..... r10k AJA Kona 10-bit RGB Codec V..... r210 Uncompressed RGB 10-bit V..... rawvideo raw video V..... roqvideo id RoQ video (codec roq) V..... rv10 RealVideo 1.0 V..... rv20 RealVideo 2.0 V..... sgi SGI image V..... snow Snow V..... sunrast Sun Rasterfile image V..... svq1 Sorenson Vector Quantizer 1 / Sorenson Video 1 / SVQ1 V..... targa Truevision Targa image V..... libtheora libtheora Theora (codec theora) VF.... tiff TIFF image VF.... utvideo Ut Video V..... v210 Uncompressed 4:2:2 10-bit V..... v308 Uncompressed packed 4:4:4 V..... v408 Uncompressed packed QT 4:4:4:4 V..... v410 Uncompressed 4:4:4 10-bit V..... libvpx libvpx VP8 (codec vp8) V..... libvpx-vp9 libvpx VP9 (codec vp9) V..... libwebp_anim libwebp WebP image (codec webp) V..... libwebp libwebp WebP image (codec webp) V..... wmv1 Windows Media Video 7 V..... wmv2 Windows Media Video 8 V..... wrapped_avframe AVFrame to AVPacket passthrough V..... xbm XBM (X BitMap) image V..... xface X-face image V..... xwd XWD (X Window Dump) image V..... y41p Uncompressed YUV 4:1:1 12-bit V..... yuv4 Uncompressed packed 4:2:0 VF.... zlib LCL (LossLess Codec Library) ZLIB V..... zmbv Zip Motion Blocks Video A..... aac AAC (Advanced Audio Coding) A..... ac3 ATSC A/52A (AC-3) A..... ac3_fixed ATSC A/52A (AC-3) (codec ac3) A..... adpcm_adx SEGA CRI ADX ADPCM A..... g722 G.722 ADPCM (codec adpcm_g722) A..... g726 G.726 ADPCM (codec adpcm_g726) A..... adpcm_ima_qt ADPCM IMA QuickTime A..... adpcm_ima_wav ADPCM IMA WAV A..... adpcm_ms ADPCM Microsoft A..... adpcm_swf ADPCM Shockwave Flash A..... adpcm_yamaha ADPCM Yamaha A..... alac ALAC (Apple Lossless Audio Codec) A..... comfortnoise RFC 3389 comfort noise generator A..X.. dca DCA (DTS Coherent Acoustics) (codec dts) A..... eac3 ATSC A/52 E-AC-3 A..... flac FLAC (Free Lossless Audio Codec) A..... g723_1 G.723.1 A..... libgsm libgsm GSM (codec gsm) A..... libgsm_ms libgsm GSM Microsoft variant (codec gsm_ms) A..X.. mlp MLP (Meridian Lossless Packing) A..... mp2 MP2 (MPEG audio layer 2) A..... mp2fixed MP2 fixed point (MPEG audio layer 2) (codec mp2) A..... libtwolame libtwolame MP2 (MPEG audio layer 2) (codec mp2) A..... libmp3lame libmp3lame MP3 (MPEG audio layer 3) (codec mp3) A..... libshine libshine MP3 (MPEG audio layer 3) (codec mp3) A..... nellymoser Nellymoser Asao A..... libopus libopus Opus (codec opus) A..... pcm_alaw PCM A-law / G.711 A-law A..... pcm_f32be PCM 32-bit floating point big-endian A..... pcm_f32le PCM 32-bit floating point little-endian A..... pcm_f64be PCM 64-bit floating point big-endian A..... pcm_f64le PCM 64-bit floating point little-endian A..... pcm_mulaw PCM mu-law / G.711 mu-law A..... pcm_s16be PCM signed 16-bit big-endian A..... pcm_s16be_planar PCM signed 16-bit big-endian planar A..... pcm_s16le PCM signed 16-bit little-endian A..... pcm_s16le_planar PCM signed 16-bit little-endian planar A..... pcm_s24be PCM signed 24-bit big-endian A..... pcm_s24daud PCM D-Cinema audio signed 24-bit A..... pcm_s24le PCM signed 24-bit little-endian A..... pcm_s24le_planar PCM signed 24-bit little-endian planar A..... pcm_s32be PCM signed 32-bit big-endian A..... pcm_s32le PCM signed 32-bit little-endian A..... pcm_s32le_planar PCM signed 32-bit little-endian planar A..... pcm_s64be PCM signed 64-bit big-endian A..... pcm_s64le PCM signed 64-bit little-endian A..... pcm_s8 PCM signed 8-bit A..... pcm_s8_planar PCM signed 8-bit planar A..... pcm_u16be PCM unsigned 16-bit big-endian A..... pcm_u16le PCM unsigned 16-bit little-endian A..... pcm_u24be PCM unsigned 24-bit big-endian A..... pcm_u24le PCM unsigned 24-bit little-endian A..... pcm_u32be PCM unsigned 32-bit big-endian A..... pcm_u32le PCM unsigned 32-bit little-endian A..... pcm_u8 PCM unsigned 8-bit A..... real_144 RealAudio 1.0 (14.4K) (codec ra_144) A..... roq_dpcm id RoQ DPCM A..X.. s302m SMPTE 302M A..X.. sonic Sonic A..X.. sonicls Sonic lossless A..... libspeex libspeex Speex (codec speex) A..X.. truehd TrueHD A..... tta TTA (True Audio) A..X.. vorbis Vorbis A..... libvorbis libvorbis (codec vorbis) A..... wavpack WavPack A..... libwavpack (codec wavpack) A..... wmav1 Windows Media Audio 1 A..... wmav2 Windows Media Audio 2 S..... ssa ASS (Advanced SubStation Alpha) subtitle (codec ass) S..... ass ASS (Advanced SubStation Alpha) subtitle S..... dvbsub DVB subtitles (codec dvb_subtitle) S..... dvdsub DVD subtitles (codec dvd_subtitle) S..... mov_text 3GPP Timed Text subtitle S..... srt SubRip subtitle (codec subrip) S..... subrip SubRip subtitle S..... text Raw text subtitle S..... webvtt WebVTT subtitle S..... xsub DivX subtitles (XSUB) What can i do to captere the console output ? I'm trying to update kernel from armbian-config from my user with sudo or directly from user root
Werner Posted April 26, 2020 Posted April 26, 2020 8 hours ago, andydj said: What can i do to captere the console output ? I'm trying to update kernel from armbian-config from my user with sudo or directly from user root Good question, I do not use this tool much You could try to execute it this way: bash -x armbian-config This will get a bit spammy but might help to track it down. For the output you could use a service like https://paste.debian.net/
andydj Posted April 27, 2020 Posted April 27, 2020 On 4/26/2020 at 6:33 AM, Werner said: Good question, I do not use this tool much You could try to execute it this way: bash -x armbian-config This will get a bit spammy but might help to track it down. For the output you could use a service like https://paste.debian.net/ https://paste.debian.net/1143444 , captured whit tee https://paste.debian.net/1143445/ , log file
Werner Posted April 28, 2020 Posted April 28, 2020 5 hours ago, andydj said: https://paste.debian.net/1143444 , captured whit tee https://paste.debian.net/1143445/ , log file Hm nothing spectacular...I guess the 2nd paste is this mentioned log file? "Test install failed. Can't change firmware[12;18HCheck /tmp/switch_kernel.log"
andydj Posted April 28, 2020 Posted April 28, 2020 3 hours ago, Werner said: Hm nothing spectacular...I guess the 2nd paste is this mentioned log file? "Test install failed. Can't change firmware[12;18HCheck /tmp/switch_kernel.log" Switched to nightly and kernel update , now remain hdmiaudio and h264 encoding
JORGETECH Posted April 28, 2020 Posted April 28, 2020 Do you need special VAAPI or VDPAU packages for decoding/encoding or has that been upstreamed? Sunxi-linux wiki mentions libvdpau-cedrus but that package is not available on Armbian. I have yet to try video decoding but as far as I'm aware LibreELEC has cedrus fully working, does that use VDPAU?
dziobak Posted May 1, 2020 Posted May 1, 2020 Ubuntu Bionic, kernel 5.6.5 #trunk.120 not detect of UAS JMicron (USB ID 152d:0561). I use two controllers for NAS and both dissapearing. After reverting to kernel #trunk.111 all is working. Tested two times, there is something weird, JMicron is not detected on second (and next) boot on kernel #trunk.120. Also, when changed kernel to #trunk.111 JMicron is correctly detected on second boot also.
dziobak Posted May 1, 2020 Posted May 1, 2020 More to above. Problem is after every reboot, JMicron is not detected. But when Bionic is cold booted JMicron's detecting is OK. Tested on kernel 5.6.8 #trunk.120 and #trunk.122. After reverting to "good" 5.6.5 #trunk.111 must be also cold booted to detect JMicron, then UAS is properly detected after each reboot.
Werner Posted May 2, 2020 Posted May 2, 2020 The trunk.111 must have been built around April 22th. Though besides upstream patches I do not think there were any relevant changes at the sunxi-dev branch. Did you try to put usbstorage quirks on your Jmicron? UAS is known for issues...
dziobak Posted May 2, 2020 Posted May 2, 2020 Werner, thank you for suggestion. I checked usb-storage but no luck, same result like uas. I'm starting to think if this is something with voltage control on USB lines? Or stuck USB state when reboot and not reset properly? Both JMicron's controllers have own power supply, so normal reboot not cut them off. When cold booted, I turn off entire power strip with connected powers to OPi3, both JMicron's and external fan.
dziobak Posted May 5, 2020 Posted May 5, 2020 I made more checking of latest kernels. Last non-problematic compiled kernel was 5.6.5 trunk.117. First problematic was 5.6.5 trunk.118. DTB files are same for both. So there must be something new in 118 or something with kernel's config. Is there a changelog for kernel trunks?
Werner Posted May 5, 2020 Posted May 5, 2020 Not really. These are simply nighty builts. 117 has been built 26-Apr-2020. Check what happened after at https://github.com/armbian/build/commits/master
Igor Posted May 5, 2020 Posted May 5, 2020 14 hours ago, dziobak said: So there must be something new in 118 or something with kernel's config. Is there a changelog for kernel trunks? Each kernel has its config packed inside deb file. Its location is /boot /config-* ... if you will do comparisons. Nightly kernels and images are regularly purged. We don't keep a lot of historical versions. Not at this moment.
