martinayotte Posted March 24, 2019 Posted March 24, 2019 1 hour ago, mraiser said: was able to get wifi working using kexec's trick. It wasn't kexec's trick, but mine ... BTW, I'm still digging eMMC issue, but I got it working using the DTB from 4.20.12 under the kernel 5.0.4, so it must be a small issue in DT.
mraiser Posted March 24, 2019 Posted March 24, 2019 30 minutes ago, NicoD said: For 1080p do this. xrandr --newmode "1920x1080_60.00" 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync && xrandr --addmode HDMI-1 1920x1080_60.00 && xrandr --output HDMI-1 --mode 1920x1080_60.00 Look up to see how to do it with other resolutions.@mraiser @TuricaT Can you guys test ethernet please? SBC-bench result of the OPi3 with Armbian Bionic dev 5.0.2 fan at 3.3V : http://ix.io/1Ep9 Thank you, 1920x1080 works with that. I can confirm ethernet works fine as well.
mraiser Posted March 24, 2019 Posted March 24, 2019 7 minutes ago, martinayotte said: It wasn't kexec's trick, but mine ... Well, thank you! It works great.
Murdag Posted March 24, 2019 Posted March 24, 2019 20 minutes ago, mraiser said: I can confirm ethernet works fine as well. Thats good to know, did you do anything special? I just put the image on the SD, even used the fancy formatting tool recommended by armbian and plugged the thing in, red lights blinking but its not coming onto the network. I did not do any manual config of the image. Maybe its because my board does not have eMMC but this would be a bit of a surprise if this would make some difference. If someone has a clue I'll try it although I don't have much debugging tooling at hand right now, otherwise wait and see, thanks guys.
NicoD Posted March 24, 2019 Posted March 24, 2019 There was a small fault in SBC-Bench. I fixed it. Now I know it doesn't underclock above 60C when on performance. @tkaiser line 180 V0.6.6 CpuFreq=$(awk '{printf ("%0.0f",$1/1000); }' </sys/devices/system/cpu/cpufreq/policy0/cpufreq/${CpuFreqToQuery} 2>/dev/null) --> CpuFreq=$(awk '{printf ("%0.0f",$1/1000); }' </sys/devices/system/cpu/cpufreq/policy0/${CpuFreqToQuery} 2>/dev/null) (I don't know if this is different on the OPi3 compared to other sbc's) SBC-Bench result with 5V fan @ 5V http://ix.io/1EpH I think I like this board. Amazing work done @martinayotte. I worked on the Rock64 the whole week, this is already better than the rock64 for me.
Frank Kettenbeil Posted March 24, 2019 Posted March 24, 2019 Actually there seems to be a problem in the build process - at least for me at dev kernel. Any idea, what the reason could be?
martinayotte Posted March 24, 2019 Posted March 24, 2019 2 minutes ago, Frank Kettenbeil said: Any idea, what the reason could be? Please, look at output/debug/compilation.log and search the actual errors there...
Frank Kettenbeil Posted March 24, 2019 Posted March 24, 2019 Thank you very much for pointing me there. Seems we have a redefinition of some drivers here. I remember clicking the "include unused drivers" option - but I'm not sure if this could be the reason. trying on
martinayotte Posted March 24, 2019 Posted March 24, 2019 5 minutes ago, Frank Kettenbeil said: Seems we have a redefinition of some drivers here. Right ! I've seen that today ... It seems that this patch/kernel/sunxi-dev/0081-arm64-arch_timer-Workaround-for-Allwinner-A64-timer-.patch as been commit directly into 5.0.2 branch, so this patch is become useless. Since it become useless, I've just deleted it from Armbian patches. Please, retry to build again ...
NicoD Posted March 24, 2019 Posted March 24, 2019 There does seem to be something very strange with the temperature sensor. When doing exactly the same test, one time I see 52°C. Like that without the fan it underclocks above 60°C. (I believe this to be the real temperature) I reboot, and do the same test, and I get 75°C and no underclock. Another time I reach 68°C with the same test. I'm using the same heatsink and fan at 3.3V. This worked great earlier on. Now it shows a lot higher temps, but it's not underclocking anymore. Still on ondemand. The heatsink isn't hot at all. This is the same as what I've seen earlier. For some kind of reason the temperature sensor seems to give wrong values. I'm using " cat /sys/class/thermal/thermal_zone0/temp " in a taskbar app.
martinayotte Posted March 25, 2019 Posted March 25, 2019 4 hours ago, martinayotte said: BTW, I'm still digging eMMC issue, but I got it working using the DTB from 4.20.12 under the kernel 5.0.4, so it must be a small issue in DT. I must be blind today, I still have not found this DT glitch ...
martinayotte Posted March 25, 2019 Posted March 25, 2019 20 hours ago, martinayotte said: I must be blind today, I still have not found this DT glitch ... Yes ! I was blind, because I've only search in my stuff, the glitch was elsewhere : @megous , Megous 5.0.y branch has USB0-IDDET wrongly on PC6, one of the eMMC data pin, I've fixed it by assigning it to the good PC15 pin. 5
Frank Kettenbeil Posted March 27, 2019 Posted March 27, 2019 (edited) On 3/25/2019 at 10:53 PM, martinayotte said: Yes ! I was blind, because I've only search in my stuff, the glitch was elsewhere : @megous , Megous 5.0.y branch has USB0-IDDET wrongly on PC6, one of the eMMC data pin, I've fixed it by assigning it to the good PC15 pin. Thank you for your investigation and fix! - for those who could not do the build themselves yet - here you can find my updated image (Armbian_5.77_Orangepi3_Ubuntu_bionic_dev_5.0.4_desktop.img) with this patch included - please report, if the emmc works with this image, as I did not have the opportunity to replace my own one, yet. - Thank you! Edited 2019-03-30: private built file no longer available. You will be better off with the nightly builds from armbian from now on: https://dl.armbian.com/orangepi3/ Thanks to @martinayotte ! Edited March 30, 2019 by Frank Kettenbeil deprecated file link no longer available 1
moneyrain Posted March 27, 2019 Posted March 27, 2019 I have build and flash this version, it work good with wifi ( with trick) and emmc. With emmc, the os a lot more response. One thing i found break is bluetooth, i enabled it via armbian-config but it fail at next boot.
YXY Posted March 27, 2019 Posted March 27, 2019 4 hours ago, Frank Kettenbeil said: Thank you for your investigation and fix! - for those who could not do the build themselves yet - here you can find my updated image (Armbian_5.77_Orangepi3_Ubuntu_bionic_dev_5.0.4_desktop.img) with this patch included - please report, if the emmc works with this image, as I did not have the opportunity to replace my own one, yet. - Thank you! Hi,the download page is not accessible. I am in SIngapore
martinayotte Posted March 27, 2019 Posted March 27, 2019 5 hours ago, moneyrain said: One thing i found break is bluetooth, Many boards have WiFi module with Bluetooth hardware capabilites, but nothing has been done in software and DT to enable it.
choephix Posted March 27, 2019 Posted March 27, 2019 10 hours ago, Frank Kettenbeil said: Thank you for your investigation and fix! - for those who could not do the build themselves yet - here you can find my updated image (Armbian_5.77_Orangepi3_Ubuntu_bionic_dev_5.0.4_desktop.img) with this patch included - please report, if the emmc works with this image, as I did not have the opportunity to replace my own one, yet. - Thank you! Thank you!
Frank Kettenbeil Posted March 27, 2019 Posted March 27, 2019 6 hours ago, YXY said: Hi,the download page is not accessible. I am in SIngapore Sorry to hear that, but for me the server seems to work and I can see a bunch of downloads (at least) have been started.
choephix Posted March 27, 2019 Posted March 27, 2019 The link returns 404 for me too. It did not an hour ago, I should have downloaded the image while at work, damn -- 😂
kexec Posted March 27, 2019 Posted March 27, 2019 there is quite easy and good manual how to build an image by yourself. in that way you are sure that it is clean and latest/greatest version I personally use vagrant setup as it looks like easiest way to do this on windows. https://docs.armbian.com/Developer-Guide_Build-Preparation/ torrent images for orange pi 3 Armbian_5.77_Orangepi3_Ubuntu_bionic_dev_5.0.4_desktop.img.torrent Armbian_5.77_Orangepi3_Debian_stretch_dev_5.0.4_desktop.img.torrent 3
choephix Posted March 27, 2019 Posted March 27, 2019 Thank you, I don't have much experience with VMs, but I'll give it a shot
Frank Kettenbeil Posted March 27, 2019 Posted March 27, 2019 just restarted my nextcloud - could be a temporary problem with the hard disk (too much power consumption for the OPi3?)
lamp216 Posted March 27, 2019 Posted March 27, 2019 On 3/25/2019 at 10:53 PM, martinayotte said: Yes ! I was blind, because I've only search in my stuff, the glitch was elsewhere : @megous , Megous 5.0.y branch has USB0-IDDET wrongly on PC6, one of the eMMC data pin, I've fixed it by assigning it to the good PC15 pin. emmc installation fixed! thank u so much
mraiser Posted March 28, 2019 Posted March 28, 2019 On 3/25/2019 at 5:53 PM, martinayotte said: Yes ! I was blind, because I've only search in my stuff, the glitch was elsewhere : @megous , Megous 5.0.y branch has USB0-IDDET wrongly on PC6, one of the eMMC data pin, I've fixed it by assigning it to the good PC15 pin. I just built a fresh image using VirtualBox and I can confirm eMMC issue is fixed as well. Thank you!!!
YXY Posted March 28, 2019 Posted March 28, 2019 9 hours ago, Frank Kettenbeil said: just restarted my nextcloud - could be a temporary problem with the hard disk (too much power consumption for the OPi3?) Thanks! The link is working now!
Zhou Posted March 28, 2019 Posted March 28, 2019 Find a issue about ethernet,when I use "ethtool eth0",system report speed is 1000Mbps. But I use iperf3 test link speed,eth0 link speed is only 100Mbps。Did anyone have same issue ? My image is builded by myself. The version is 5.0.4
renedis Posted March 28, 2019 Posted March 28, 2019 (edited) I'm planning on buying the OPI3 because of the rich feature set. I would love to put Armbian on it. Building an image is no problem for me but I'm lost tracing the current issues and would like to know what those are at the moment. I've found out: - HDMI resolution output issues. Fixed - CPU speed throttling issues. Fixed - WiFi issues. Fixed - eMMC issues: Fixed - NIC issues: ??? No issues for some? - Bluetooth issues: ??? - Sound issues: ??? - Reboot issues: ??? Can someone tell me if I'm correct about the above? Or i'm I wrong or missing something? Edited March 28, 2019 by renedis added sound issue
reciu Posted March 28, 2019 Posted March 28, 2019 On 3/27/2019 at 6:12 AM, Frank Kettenbeil said: Thank you for your investigation and fix! - for those who could not do the build themselves yet - here you can find my updated image (Armbian_5.77_Orangepi3_Ubuntu_bionic_dev_5.0.4_desktop.img) with this patch included - please report, if the emmc works with this image, as I did not have the opportunity to replace my own one, yet. - Thank you! this build works on SD?
martinayotte Posted March 28, 2019 Posted March 28, 2019 10 minutes ago, reciu said: this build works on SD? Every Armbian images work on SD ! After having it booted, it can then be transferred on eMMC using "nand-sata-install" ....
