@buzz89In oranges zero2 dts it has a 3.3v regulator defined as reg_dcdce. There’s only 5v defined in the vontar dts. You can add this to your dts reg_dcdce: dcdce { regulator-always-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc-eth-mmc"; };
@ARx8X98h has a similar AIC8800D wifi chip. You could probably use the wifi section from x98h dts. I have never had problems with my sdcard. Maybe it’s a bad solder joint?
@justanothernoob the images with "current" instead of "vendor" in the name have very limited hardware support (no HDMI, no sound, etc). You should peek the "vendor" images. Mind I noted to use the images dated 16th of August or post as otherwise your pcie sata connected drives won't work most of the time. So you should try bookworm_vendor or noble_vendor with xfce,cinnamon,gnome,kde-neon if you want a graphical interface and minimal for serial console/ssh only. You will only get black screen from HDMI with "current" images, that is expected (the HDMI support is not in the linux kernel, only in linux-rockchip kernel, ie vendor as of yet). ie the image you told using https://fi.mirror.armbian.de/incoming/prahal/rock-5-itx/archive/Armbian_25.8.1_Rock-5-itx_bookworm_current_6.12.41_minimal.img.xz is such a linux kernel without HDMI support for rock-5-itx. https://fi.mirror.armbian.de/incoming/prahal/rock-5-itx/archive/Armbian_25.8.1_Rock-5-itx_bookworm_vendor_6.1.115_xfce_desktop.img.xz has HDMI support. you should be able to install form serial console with both vendor and current images. Mind I still need to read about installing RoobiOS on my emmc as sadly my board was shipped with an empty EMMC. So I cannot yet guide you through RoobiOS boot selection.
https://forum.armbian.com/topic/30074-helios64-armbian-2308-bookworm-issues-solved/page/11/#findComment-224260 wow, that's a bummer... how can I check if this happens also to my configuration?
@Piotr s im using the same warpme patches so it’s odd that it doesn’t boot. To show more information on your console screen change your loglevel to 7 in armbianEnv.txt. The file is located at the root directory of your sdcard.
Updates should now be ok, aren't they?
@darcyg @ Hqnicolas 使用了你的rk3576-h96-m9s。dts rk3576-h96-m9s-linux.dtsiarmsom-sige5-rk3576_defconfig 预算Armbian-unofficial_25.11.0-trunk_H96-m9_bookworm_vendor_6.1.115-backported-mesa.img gup可以工作,kodi 4K硬件加速。 1、关机不断电,电源灯亮 2、3.5音频无设备 无输出 3、无wifi蓝牙 4、kodi https://github.com/armsurvivors/kodi-rockchip-deb 硬件共享 https://drive.google.com/drive/folders/1lzLwm9NhxZ_0_mghKG4A0XQ6NNsU9sn-?usp=drive_link -
Hi, To my side, below work in root but not with systemd service: # Helios64 PWM Fan Control Configuration # Temp source : /dev/thermal-cpu #INTERVAL=10 INTERVAL=30 FCTEMPS=/dev/fan-p6/pwm1=/dev/thermal-cpu/temp1_input /dev/fan-p7/pwm1=/dev/thermal-cpu/temp1_input MINTEMP=/dev/fan-p6/pwm1=40 /dev/fan-p7/pwm1=40 MAXTEMP=/dev/fan-p6/pwm1=50 /dev/fan-p7/pwm1=50 MINSTART=/dev/fan-p6/pwm1=20 /dev/fan-p7/pwm1=20 MINSTOP=/dev/fan-p6/pwm1=20 /dev/fan-p7/pwm1=20 MINPWM=20 To my side, below work in root and with systemd service: # Helios64 PWM Fan Control Configuration # Temp source : /dev/thermal-cpu INTERVAL=10 FCTEMPS=/sys/devices/platform/p6-fan/hwmon/hwmon6/pwm1=/sys/devices/virtual/thermal/thermal_zone0/hwmon0/temp1_input /sys/devices/platform/p7-fan/hwmon/hwmon5/pwm1=/sys/devices/virtual/thermal/thermal_zone0/hwmon0/temp1_input MINTEMP=/sys/devices/platform/p6-fan/hwmon/hwmon6/pwm1=40 /sys/devices/platform/p7-fan/hwmon/hwmon5/pwm1=40 MAXTEMP=/sys/devices/platform/p6-fan/hwmon/hwmon6/pwm1=50 /sys/devices/platform/p7-fan/hwmon/hwmon5/pwm1=50 MINSTART=/sys/devices/platform/p6-fan/hwmon/hwmon6/pwm1=20 /sys/devices/platform/p7-fan/hwmon/hwmon5/pwm1=20 MINSTOP=/sys/devices/platform/p6-fan/hwmon/hwmon6/pwm1=20 /sys/devices/platform/p7-fan/hwmon/hwmon5/pwm1=20
Armbian doesnt seem to see sata harddrives.
Werner replied to DontMindMe's topic in Radxa Rock 5 ITX
At some point we will bump edge to 6.17. These bumps always take time since our patchset on top always needs adjustments. There are 3rd party ppa's for newer mesa. I suggest to use kisak since those are briefly tested. Otherwise go for oibaf which are automated untested, therefore latest mesa packages. In terms of Debian, no clue if there is a similar apt repo for such. -
My apologies. I started working on this board again and just spent 3 wasted hours getting angry at the previous wipe eMMC instructions only to realize *I* had the wrong version of RKDevTool. Protip - do not do any hardware development angry, hungry, in a rage, or pressed for time. Wow. Here is the issues with your "erase eMMC" instructions (apparently partly taken from the guide to getting Linux on the T95 Plus): -Config file was loaded, loader, parameters and uboot were written. Board usually does not restart when this is done, restarted once out of my many attempts. -There are no instructions about "wipe_part", what partitions to destroy, or how to do this. Using your version of RKDevTool, no partitions are loaded which then appear in the Download Image window (as I assume they are supposed to). -Flashing the other Miniloader file is met with a Waiting for Device Success prompt, which never completes. These instructions obviously worked the first time I did this several months ago. I don't know what at all could have changed, and I'm pretty frustrated as I'm trying to recover from another OMV system crashing and trying to recover data, so the use was/is pretty urgent, and given this forum, it could be a few days before a replay so my system is now sitting hostage to these instructions.
Does anybody know how to resume suspend from keyboard press?
snow replied to snow's topic in Orange Pi 5
I'm a bit embarassed to say they are confusing to me. I am going to ask Grok and see if it can help me, thank you - Yesterday
fighting with netplan/networkd/networkmanager
tabrisnet replied to tabrisnet's topic in Software, Applications, Userspace
https://forum.banana-pi.org/t/bpi-r4-eeprom/17836/13 suggests we should figure out how to give the info to uboot? or it already does generate it for us in one case? I can say I find eth0's local-mac-address in the running device tree, but the other two mac@ entries lack it. root@ratatosk:/boot# dtc /proc/device-tree 2>/dev/null |grep -PA 10 'mac@[0-9] ' mac@2 { phy-mode = "usxgmii"; compatible = "mediatek,eth-mac"; status = "okay"; pcs-handle = <0x3a 0x3b>; managed = "in-band-status"; phys = <0x3c>; reg = <0x02>; openwrt,netdev-name = "sfp-wan"; sfp = <0x3d>; }; -- mac@0 { phy-mode = "internal"; local-mac-address = [22 16 68 60 40 c2]; mac-address = [22 16 68 60 40 c2]; compatible = "mediatek,eth-mac"; status = "okay"; reg = <0x00>; phandle = <0x2c>; fixed-link { full-duplex; -- mac@1 { phy-mode = "usxgmii"; compatible = "mediatek,eth-mac"; status = "okay"; pcs-handle = <0x36 0x37>; managed = "in-band-status"; phys = <0x38>; reg = <0x01>; openwrt,netdev-name = "sfp-lan"; sfp = <0x39>; }; -
Adguard Home not running after reboot.
Nathan Warawa replied to Nathan Warawa's topic in Software, Applications, Userspace
I don't think it's an SD card issue. Performance wise it's about twice the requirement. And if it was a bad block, I doubt the issue would be the same across two different images. As for logs... where? I tried running "sudo dmesg -T --color=always --level=err,warn | more" and nothing about AdGuard came up. I checked the AdGuardHome.yaml file and confirmed bind_host was set to 0.0.0.0 (I also tried setting it to 192.168.0.6... no improvement). The command "sudo netstat -tulnp | grep 3000" said command not found, and "journalctl -u AdGuardHome" came back with no entries. -
Thx for your reply. Yes i tried both together. And just one. No difference. # Enable DRM VC4 V3D driver dtoverlay=vc4-kms-v3d # Enable the Touch Display 2 DSI panel dtoverlay=vc4-kms-dsi-ili9881-7inch
Which kernel mod needs to be loaded to get battrey support on cubietruck?
Igor replied to pet's topic in Allwinner sunxi
OS is stable, errors you are experiencing are likely related to faulty HW component as @eselarm already exposed. And we would most likely notice such anomaly before it gets to you. There are thousands of users and this is the only report of this kind ... Boards are going to the market at high rate, while users support remains more or less the same in past 10 years https://docs.armbian.com/User-Guide_Board-Support-Rules/ Community builds and their upgrades are untested as size of Armbian can only cope with a small selection of boards we call as "standard support", where we have volunteers behind. Community builds are on Debian / Arch images level, but packed with more features. https://github.com/armbian/community?tab=readme-ov-file#purpose-of-this-repository For those - Armbian provides build and hosting infrastructure, place to meet - this forum - while everything else is anyone's problem. -
... straightforward and smooth.
2
Try to upload the old and new driver to an AI with you overlay included. Here it gives some suggestions for what you can try. The power sequence seems to be changed with the new driver and it might be too fast for your display. It suggests to put some parameters in the overlay to delay some parts, with higher chance with the first 3: Under "dsi0_panel: panel@0 {" prepare-delay-ms = <120>; reset-delay-ms = <50>; init-delay-ms = <150>; enable-delay-ms = <50>; disable-delay-ms = <50>; unprepare-delay-ms = <120>;
BPI-R4 fails to build, missing bl2 firmware
tabrisnet replied to tabrisnet's topic in Other families
https://github.com/armbian/build/pull/8517 appears to fix my SFP problems. -
Ryzer replied to schunckt's topic in Allwinner sunxi
@schunckt Yes, I should have clarified that drm-copy is an argument is for MPV, which according to the guide mentioned above should allow the frame-buffer to be accessed directly. It is worth noting that mpv makes use of ffmpeg under the hood. Tried with ffplay once but did not have much luck with it. last I checked VLC is not supported other than the legacy vaapi. Please see: https://linux-sunxi.org/Sunxi-Cedrus You can use the sample media from linaro: https://samplemedia.linaro.org/ Just to check are you using the ffmpeg-v4l2-request? -
multiple system error messages after latest kernel update
bhouseski replied to bhouseski's topic in Radxa Rock 5B
v25.8.1 for Rock 5B Plus running Armbian Linux 6.1.115-vendor-rk35xx -
That's exactly what I did. I wrote a replacement for the .not_logged_in_yet file in my customize-image.sh with pre-set parameters, just like I create /root/provisioning.sh. I was just wondering if there were any other ways to do this.
