AFBC support has been merged to PanVK and will be available in the Mesa 25.3 release! This new enablement reduces memory bandwidth and boosts performance. View the full article
perhaps someone who's more knowledgeable could update the script to work on newer versions than buster, like bookworm or trixie?
How to install armbian to Amlogic S805 android box
Vittorio Saldo replied to remolaan's topic in Amlogic CPU Boxes
@remolaan "...Hey i have a SDMC DV8040 stb ,SoC-Amlogic S805X,CPU-Quad-core 1.2 GHz,GPU-ARM Mali-450,RAM-1GB,Storage-8GB it currently runs custom made android 9..." Please @remolaan, could you send me a working download link for the custom Android 9 system you made? -
Armbian 25.8.1 Noble XFCE (mainline Kernel: 6.16.6-edge-rockchip64) + PanVk - mesa 23.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.7 (https://ryanfortner.github.io/box64-debs/) + wine-10.15-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.15) + DXVK-stripped v2.7.1 ~60fps@720p Hades -
Hello @Ian Coelho, have you ever got any solution? I got the same issue
As long as you keep the discussion about this at their place... ophub is (ab)using the name Armbian without permission and they do not contribute to the core development process. Rather they trick users into thinking they get support here and therefore (ab)using our resources.
zero2w != zero2 moved
Yeah, I wasn't asking for diagnostics, I realise that this issue could be for a myriad of reasons, just I was sure (before) that it was hardware related, now I'm not so sure. FWIW, it has just happened again less than an hour after boot, so I'm going to pull the card and chroot in to analyse. (I'm a software developer, so am well aware of the 'it don't go, what's wrong?' approach to tech support 😉) Interestingly, I was still logged in on an ssh shell, and I realised there was an issue when it was telling me that `cat` was an unknown command (clearly not!). I logged out, and now got the dreaded "Connection reset by 192.168.1.44 port 22". I also ran a full badblocks pass (4 real passes) on the SD card prior to imaging just to 100% make sure the card is fine. My main concern is that it will not have flushed logs to disk after the issue, so I suspect I will find nothing. ____ Edit: It looks like Armbian has rsync on a schedule to hold logs in RAM and perhaps periodically copy back to HDD. so unfortunately I have no useful info here. Going to look into the Armbian docs and see if I can get it to log directly to disk whilst I test. ______________ Another edit: I managed to disable ramlog, but unfortunately nothing of note has been written to the log files. I have tried connecting a monitor via HDMI, but am getting no output. I am sure this is fixable, but not sure how much I'm prepared to fiddle around with a box that just wants to lock up after some undetermined amount of time. I'm going to install the official Ubuntu 18.04 image (urrrgh) and leave it running for a long while. If that displays the same symptoms, then I can safely say this board is e-waste. If it does not, then I will come back to it and try to get myself an output.
@Rodrigo Campos @kazekami_him I think @nitrolack and @afiftyp had the same Transpeed M98-8k board. It booted fine with my transpeed image. (other than wifi) They didn't have a board that had secure boot. Check if your board is the same. Maybe you could try my older images. It could be the newer u-boot and patches broke the ram detection? Maybe your board is using a different ram?
Hi and Thank @jock That's what I thought. I used ledconf-3 because that's the configuration you made specifically for my MX10 box. I ran a memtest, which went smoothly. The system is working, and I was able to compile rockchip mpp without any problems. The system is running Bookworm. Would it be better to update to Trixie or revert to a previous version? What do you think? I think the problem comes either from rk3318-box.dtb or from the overlays. Thanks again. 🤜🤛
@jock well thanks but I already figured that part out 😊 my problem right now is that i can't find a single distro that works with my box . almost every one (even multitool) goes to a black screen and freezes excatly after 60 seconds . the best thing i could find was a android rom that have the same problem but in excatly 30 minute after booting up ! i did this stupid thing that did not backed up my original rom before writing to internal emcp flash 🤦♂️ if i can find any version that doesn't have this problem , i know how to merge armbian rootfs with it ! thank you again !
Have you tried your python script with your Linux PC? If it happens again, you can tell that the problem is within the ESP32 program. I generally prefer having the most complex system (Armbian) poll the simplest device (ESP32), instead of the ESP32 interrupting the Armbian system. I found it more stable that way. Stay with wifi, and use the ESP32 serial port just for debugging. Program the ESP32 print an acknowledgement of data requests, and an alarm if it gets stuck in an unexpected state. I have also found ESP32 circuit or micro python very stable for serial port communications.
Vincenzoernst1 replied to Hqnicolas's topic in Rockchip CPU Boxes
@Hqnicolas would it be possible to have the driver @guenter pointed out in the base image? -
I think the core problem is that headers were compiled with Ubuntu compiler / userspace and you try to use it on Debian. I used this on Ubuntu, which is the reason why it worked. We are aware of this problem - headers should be distro specific. Which adds complexity on our side ...
Feel free to pr any missing overlay here: https://github.com/armbian/linux-rockchip
moved to csc https://docs.armbian.com/User-Guide_FAQ/#why-no-universal-image tl;dr: You are using the wrong image. Get/build one for your board
I don't see it as the very latest bleeding edge kernel version. I see it as a newish Linux, which already has the armbian patches updated for. Some CPUs end up with newer or older Linux versions, due to varying levels of development success. For example, sunxi's armbian edge is 6.15.4 today, but the linux trunk is up to 6.17-rc6 ... (not available in Armbian)
I tried it on 6.16.7, and the log started working: [ 4.838111] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device Error again after initialization: [ 5.118148] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 5.637839] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
Has anyone ever gotten the Radxa Zero 3w working in gadget mode? I bought a Zero 3w about a week ago and have been beating this horse most of the time. I can't get the device to connect via USB. A or C. When I try to connect (radxa.local) it will always go through wifi. If I have wlan0 disabled or even my internet off it just will NOT connect. It clearly is using wifi to connect even if I use the hostname. Maybe this is something simple but I and another engineer I work with have been scratching our heads about it. The obligatory AI search was an endless loop of everything we had already tried. Anybody have any advice?
Hello, I am selling a working unit of Kobol Helios64 with the fix done, without drives. Based in Czech Republic, able to send within EU. Please DM me if interested.
Visit us at the STMicroelectronics booth, where Collabora will highlight how the STM32MP2 chip empowers edge AI solutions for industrial applications. View the full article
current isn't ideal for any rk3588 hw anyway due to lack of hw features mainlined for now. edge or vendor working best.
Let's say the world has been extra certain to bring me IRL problems 😄, as far as a bootloader being present, the Libre Computer Tritium boards are as barebones as can be possible, so any issues should be shared across any/all other H5 boards and really not board specific.
