I consider the btrfs issue 'solved', from past experience I know sometimes explicit balancing is needed for certain blockdevice level or lowlevel operations, like conversion of profiles, for example single into raid1, there must be enough unallocated space so new 1GB chunks can be created, especially on the originating device as it is all fundamentally copy-on-write so at least extra/double space for 1 system, meta, data chunk shall be available and I simply forgot to check/realize that. Further enhancements to Btrfs that this is done automatically somehow means likely that I first need to browse the kernel mailing list and see what people like David Sterba are doing nowadays. The CMA issue I suspect maybe it is related to power supply. Because of testing, I needed to take the NanoPi-R6C to another room where i used a 65W 'white-label branded' USB-C PD PSU that I got delivered with a refurbished laptop. That PSU has once shown under-voltage on an RPi4, so I expect too much ripple (when 5V). Besides the CMA issue, lateron also sudden hard reset of the NanoPi-R6C when I was doing networked backup, was 2x ethernet + HDMI + NVMe + eMMC active and that could mean >3A when only 5V. When I also took my RPI5 27W USB-C PD PSU to that room and used that, no strange issues anymore, so running fine at least with EDK2-UEFI and Armbian kernel 6.15.2-edge-rockchip64 and Bookworm or Tumbleweed userspace (and KDE Wayland). I have never seen PD working on the NanoPi-R6C and the powering circuit looks a lot like ROCK3A w.r.t. staged DC-DC conversion. And I use Armbian mainline based U-Boot or EDK2-UEFI, not the original FriendlyWrt installation with some 2017 based U-Boot. Also for that original one, I doubt that it does USB-C PD to request 9V or higher. I assume not, looking at: https://wiki.friendlyelec.com/wiki/index.php/NanoPi_R6C#PD_Power_Adapters_We_Tested https://wiki.friendlyelec.com/wiki/index.php/Template:PDPowerWeTested There is also nothing about USB-C PD under https://www.friendlyelec.com/Forum/viewforum.php?f=81 so I assume: Great HW but SW/OS support is abandoned and DIY. That also means, same as for ROCK3A and ROCK5B, solder some 12V wire to a male USB-C connector and use that in order to be sure power won't drop too much when e.g. some USB3 HDD/SSD is inserted. Or limit cables to only RPI5 PSU and WAN/1GB ethernet (and still Samsung 970 NVMe, that works OK, even when 800% CPUload). Or check/see if PD handling is available in denx.de/mainline U-Boot.
Context: new Banana Pi M4 zero (rev 2) is using Wifi/BT over SDIO, which requires an sdio overlay. Thanks to Armbian team for providing it. Editing armbianEnv.txt to add "overlays=bananapi-m4-sdio-wifi-bt" did the trick for Wifi but BT is still not available (neither in standard or rolling builds)... @c0rnelius I know you tried to figure out why, I'm missing technical knowledge to help... Digging the Internet I saw similar bluetooth issue for radxa zero 3w with aic8800, resolved using hciattach / hci up, but needing an available /dev/ttyS1 (UART1) we are missing here... Do you know why? Could it be the problem for banana pi m4 zero and if yes could an overlay activate it? Denis
Recreated hdmi patches under kernels 6.12 and kernels 6.15 in pcduino-boards-fixes branch. When attempting to build with current kernel 6.12.30, with drm patches for sun4i_hdmi_enc.c to use drm_hdmi_connector_mode_valid and drm_atomic_helper_connector_hdmi_check fails to compile. when just applying drm_atomic_helper_connector_hdmi_check patch build compilation is successful. Just need to verify this build works. For kernel 6.15, with just the hdmi patches, we get a working HDMI display output:
Yes exactly
Shakai2 replied to Shakai2's topic in Allwinner sunxi
Thank you for the reply ! I see — is there any version of Armbian or another distro that has working HDMI output and graphics drivers ? -
Hi, Then the only other difference would be that your device has a pin tied to usb0-vbus. The topwise dts does not have the display nodes included in the cubieboard. Now as you are currently kernel 6.1, it is possible to enable the display via overlays or compile a version of the topwise dts that includes the display nodes. So the internal display does not work under 6.1? Are there any kind of errors or does it not appear to intialise at all? Cubieboard nodes (*Note - Nodes other than hdmi and usb related have been removed): /dts-v1/; #include "sun4i-a10.dtsi" #include "sunxi-common-regulators.dtsi" #include <dt-bindings/gpio/gpio.h> / { model = "Cubietech Cubieboard"; compatible = "cubietech,a10-cubieboard", "allwinner,sun4i-a10"; hdmi-connector { compatible = "hdmi-connector"; type = "a"; port { hdmi_con_in: endpoint { remote-endpoint = <&hdmi_out_con>; }; }; }; }; &de { status = "okay"; }; &hdmi { status = "okay"; }; &hdmi_out { hdmi_out_con: endpoint { remote-endpoint = <&hdmi_con_in>; }; }; ®_usb1_vbus { status = "okay"; }; ®_usb2_vbus { status = "okay"; }; &usb_otg { dr_mode = "otg"; status = "okay"; }; &usbphy { usb0_id_det-gpios = <&pio 7 4 (GPIO_ACTIVE_HIGH | GPIO_PULL_UP)>; /* PH4 */ usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; }; Topwise a721: /dts-v1/; #include "sun4i-a10.dtsi" #include "sunxi-common-regulators.dtsi" #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/pwm/pwm.h> / { model = "Topwise A721"; compatible = "topwise,a721", "allwinner,sun4i-a10"; panel { compatible = "starry,kr070pe2t"; backlight = <&backlight>; power-supply = <®_lcd_power>; port { panel_input: endpoint { remote-endpoint = <&tcon0_out_panel>; }; }; }; reg_lcd_power: reg-lcd-power { compatible = "regulator-fixed"; regulator-name = "reg-lcd-power"; gpio = <&pio 7 8 GPIO_ACTIVE_HIGH>; /* PH8 */ enable-active-high; }; }; &de { status = "okay"; }; ®_usb0_vbus { status = "okay"; }; ®_usb1_vbus { status = "okay"; }; ®_usb2_vbus { status = "okay"; }; &tcon0_out { tcon0_out_panel: endpoint@0 { reg = <0>; remote-endpoint = <&panel_input>; }; }; &usb_otg { dr_mode = "otg"; status = "okay"; }; &usb_power_supply { status = "okay"; }; &usbphy { usb0_id_det-gpios = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ usb0_vbus_det-gpios = <&pio 7 5 GPIO_ACTIVE_HIGH>; /* PH5 */ usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; }; It is possible to build just uboot using the BUILD_ONLY=uboot option. Again here you could face potential issues as newer uboot might not work well with an old kernel. All the best Ryzer -
KrzyPacu replied to Jean-Francois Lessard's topic in Amlogic meson
hk1-x3.conf I haven't opened my TV box but I saw a picture and it seems to me that the controller is "FD6551" -
You can build an armbian image with these instructions:https://docs.armbian.com/Developer-Guide_Build-Preparation/ You can configure it: https://docs.armbian.com/ When you have a setup you like, use this to backup as an image: https://forum.armbian.com/topic/29427-shrink-backup-a-tool-for-backing-up-sbcs/ I still suggest only armbian... but please share if you can use buildroot for opiz2w -
It is Allwinner H618, Quad-core ARM Cortex™-A53 processor. I meant which Eth chip is used in your case Bananapi-m4-berry: h618 ==> Eth chip rtl8211f ==> connecting socket Bananapi-m4-zero: h618 ==> Eth chip ???? ==> connecting socket As far as I understand, this is some kind of expansion card for the 26 pin connector. Can you post a diagram of this expansion board here. The brand of the Ethernet chip matters.
Notice, translation by ChatGPT. Hi everyone! I have an MX10 F3 TV stick running Android for a specific purpose, but I believe it could be more efficient with Armbian. I'm testing Nick's image Armbian-unofficial_25.05.0-trunk_X96q-lpddr3-v1-3_bookworm_edge_6.12.11_xfce_desktop.img.xz on a microSD. It works well, except for Wi-Fi and Bluetooth — the chip is AIC8800. I don’t know how to install the patch that has been shared. I also haven’t been able to make it work by installing the firmware and SDIO from https://github.com/geniuskidkanyi/aic8800 @Nick Aif you plan to release future versions, do you intend to include native support for the AIC8800 chip?
sorry for the typo, it is Kernel 6.12.30 that still doesn't support usb
Hello everyone, I'm currently working on a custom firmware project for the Allwinner V851S/V851SS SoC (e.g., dash cam or smart camera). I've reached the stage where I need to modify and re-sign the firmware images (TOC0/TOC1) for use with tools like PhoenixCard. Unfortunately, the tools found on GitHub (e.g., dragonsecboot, pack_tools, boot0, etc.) are often incomplete or fail to build due to missing references (e.g., rsa_sign_main, GetFullPath, etc.). 🔍 I'm looking for a complete and working version of the following tools: dragonsecboot pack boot0 sunxi_tools Full config files such as dragon_toc.cfg, sys_config.fex Working pack_tools with all required source files Full Tina SDK for V851S or V851SS 🎯 My goal is to properly sign and rebuild TOC0/TOC1 and PACKAGE images, and build a customized embedded Linux system. 📤 If anyone has the official SDK or a working toolchain, I’d really appreciate it if you could share it via Google Drive, Mega, Transfer.sh, or any other file host. Thank you in advance to anyone who can help 🙏
It sounds like you're in a tough spot with your x88 box, but there are definitely a few things you can try to unbrick it. Check Power Supply: As you mentioned, the power supply might be outputting 13V, which is not ideal. It's crucial to have a stable 5V supply for the device to boot properly. If you can, try using a different power adapter (5V, 2A) and see if that helps stabilize the boot process. Use a Correct Recovery Image: Make sure you're using the correct image for the box. It seems like you were trying to burn the image directly, but if the process was interrupted, it could leave your internal storage in an inconsistent state. Try downloading the official firmware for your box model from the manufacturer's site (if available) or from trusted forums where users with similar devices share their files. Try the USB Burning Tool: Some boxes like this one can be recovered using a tool like the USB Burning Tool (if it's based on Rockchip). You can try flashing the firmware through USB using the tool while the box is in recovery mode. Here’s a general approach: Download and install the USB Burning Tool. Put your box into MaskROM Mode (this usually involves shorting specific pins or pressing a button while plugging the box into your computer via USB). Connect your device to the PC and use the USB Burning Tool to flash the firmware. Serial Console Output: If you're comfortable with it, connecting a serial console to the box can give you a lot of insight into where things are failing. This could help identify whether it's a hardware or software issue. The serial output could give you error messages that could point to a specific issue (e.g., faulty bootloader or file system corruption). SD Card Recovery: If you can't get it to boot from the internal flash, continue using the SD card with a stable Armbian image. If the internal storage is corrupt, you might still be able to boot and recover your box through the SD card by reinstalling the firmware on the internal storage via the system running off the SD card. If you haven't already, you could also try reaching out to the manufacturer or seller for support, as they might be able to help you with the recovery process. But if that’s not an option, digging into the serial console is definitely your best bet. Good luck! Hopefully, you'll be able to get your device back up and running soon.
Good day, respected Balbes150. Please advise an Armbian build for the Roc-rk3588s-pc v1.1, with support for an M.2 NVMe SSD, intended to be used as a "smart home" server. The image will be installed on an SD card. The single-board computer is connected to the home router via Ethernet cable. HDMI is only used temporarily to connect to a TV for initial setup (further configuration will be done via SSH). The board will run Docker containers. Thank you so much in advance!
Truenox replied to Truenox's topic in Radxa Rock Pi S
Hello, Any update of this? -
They will provide you new drivers only if you will pay them to do that for you. End users, including this project, can do nothing about - we have negative budget and can only do best-effort work to keep those drivers at least operational with recent kernels: https://github.com/armbian/build/tree/main/patch/misc while bulk of the patches goes directly to the Git of specific driver. What you are hoping exceeds ability of amateur maintainers, those few people that are actually looking into the code and fix bugs that are made by kernel API changes. HW vendor is usually long gone from there - their development capacity is also limited and they are focused into current products. FYI -
there are a few caveats that may need a bit of attention It is documented somewhere that if you use channel 0, the driver would automatically select an appropriate channel / frequency. However, it seemed that back then initially while I tested it, that didn't seem to work. (i'm not sure if it may have changed) hence to list the channels one needs to run iw list and you would get a list of channels like such * 2412 MHz [1] (20.0 dBm) * 2417 MHz [2] (20.0 dBm) * 2422 MHz [3] (20.0 dBm) * 2427 MHz [4] (20.0 dBm) * 2432 MHz [5] (20.0 dBm) * 2437 MHz [6] (20.0 dBm) * 2442 MHz [7] (20.0 dBm) * 2447 MHz [8] (20.0 dBm) * 2452 MHz [9] (20.0 dBm) * 2457 MHz [10] (20.0 dBm) * 2462 MHz [11] (20.0 dBm) * 2467 MHz [12] (20.0 dBm) * 2472 MHz [13] (20.0 dBm) * 2484 MHz [14] (20.0 dBm) * 5170 MHz [34] (disabled) * 5180 MHz [36] (20.0 dBm) * 5200 MHz [40] (20.0 dBm) * 5220 MHz [44] (20.0 dBm) * 5240 MHz [48] (20.0 dBm) * 5260 MHz [52] (20.0 dBm) (radar detection) * 5280 MHz [56] (20.0 dBm) (radar detection) ... * 5720 MHz [144] (20.0 dBm) (radar detection) * 5745 MHz [149] (20.0 dBm) * 5765 MHz [153] (20.0 dBm) * 5785 MHz [157] (20.0 dBm) * 5805 MHz [161] (20.0 dBm) * 5825 MHz [165] (20.0 dBm) what I normally do is to do a scan and pick an unused / least used channel : iw wlan0 scan pick an appropriate channel and specify it in hostapd.conf. 5ghz channels (hw_mode=a) delivers a max throughput of like 140 Mbps which is fast. https://docs.armbian.com/WifiPerformance/#uwe-5622 accordingly there are some country specific requirements for 5ghz channel selections and one may like review https://en.wikipedia.org/wiki/List_of_WLAN_channels iw reg set etc I did a google search and some of these resources may be useful https://wiki.archlinux.org/title/NetworkManager https://www.baeldung.com/linux/nmcli-wap-sharing-internet in a same way you may need to set the channel if necessary then that this repo is found in a google search which may be useful https://github.com/pi-top/Wi-Fi-Access-Point-and-Station-Mode/tree/master
I'm trying to compile an LED display driver: https://github.com/arthur-liberman/linux_openvfd I follow this description: https://github.com/bk3a12/openvfd_enable_for_tx3_mini However, I can't build anything and the whole process ends with errors: sh ./scripts/modules-check.sh /home/user/INSTALKI/linux_openvfd/driver/modules.order make -f ./scripts/Makefile.modpost make[3]: *** No rules to make an object '/home/user/INSTALKI/linux_openvfd/driver/modules.order', required by '/home/user/INSTALKI/linux_openvfd/driver/Module.symvers'. Stop. make[2]: *** [/usr/src/linux-headers-6.12.33-current-meson64/Makefile:1897: modpost] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving the directory '/usr/src/linux-headers-6.12.33-current-meson64' make: *** [Makefile:5: modules] Error 2
@werner Sorry the delay, I was trying to get the TTL adapter. Here is what I get from the TTL in the first boot after flashing Armbian_community_25.8.0-trunk.228_Orangepi5pro_bookworm_vendor_6.1.115_minimal.img DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 ch0 ttot7 LPDDR5, 2400MHz channel[0] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch1 ttot7 channel[1] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch2 ttot7 channel[2] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB ch3 ttot7 channel[3] BW=16 Col=10 Bk=16 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB Manufacturer ID:0xff DQS rds:l0,l0 CH0 RX Vref:27.1%, TX Vref:20.0%,20.0% DQ rds:h3 h4 h2 h1 h5 h2 h2 h1, h1 h3 h3 h5 h1 h3 h2 h2 DQS rds:l0,h1 CH1 RX Vref:27.9%, TX Vref:21.0%,20.0% DQ rds:l0 h1 h2 h3 h6 h2 h3 h6, h4 h2 h2 h2 h2 h1 h4 l0 DQS rds:l0,l0 CH2 RX Vref:26.7%, TX Vref:19.0%,21.0% DQ rds:h3 l0 l0 l0 h4 h1 h7 h3, h2 l0 h1 l0 h2 h4 h1 h1 DQS rds:l0,h1 CH3 RX Vref:27.9%, TX Vref:20.0%,20.0% DQ rds:h5 h3 h7 h4 h2 h2 h4 h4, h4 h3 h4 h2 h3 h1 h3 h1 stride=0x2, ddr_config=0x6 hash ch_mask0-1 0x20 0x40, bank_mask0-3 0x0 0x2400 0x44800 0x89000, rank_mask0 0 x2000 change to F1: 534MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F2: 1320MHz ch0 ttot8 ch1 ttot8 ch2 ttot8 ch3 ttot8 change to F3: 1968MHz ch0 ttot6 ch1 ttot6 ch2 ttot6 ch3 ttot6 change to F0: 2400MHz ch0 ttot7 ch1 ttot7 ch2 ttot7 ch3 ttot7 out U-Boot SPL board init U-Boot SPL 2017.09 (Jun 13 2025 - 02:18:34) unknown raw ID ff ff ff unrecognized JEDEC id bytes: ff, ff, ff Trying to boot from MMC1 Card did not respond to voltage select! spl: mmc init failed with error: -95 Trying to boot from MMC2 Card did not respond to voltage select! spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### # Reset the board to bootrom # Not sure if it matters, but I have a EMMC installed and flashed the image to it using the rkdevelop tool. ( The same way I do to flash the firmware from orangepi site ) Just in case, here are the commands I use ./rkdeveloptool db MiniLoaderAll.bin ./rkdeveloptool wl 0 Armbian_community_25.8.0-trunk.228_Orangepi5pro_bookworm_vendor_6.1.115_minimal.img ./rkdeveloptool rd
Hi, I also tried to run this sensor, tried different ports but to no avail. maybe you found a way to solve this problem?
Share the image of your assembly, preferably server-side.
I think I solved it! In the upgraded system there was no package pahole! After I installed the pahole and reinstalled the package linux-headers-6.12.33-current-x86, I got the BTF stuff as described above in the .config file and I can compile modules! Pfff, finally! I checked the Raspberry Pi 4 version, I see no pahole package installed there, and I can compile modules and zfs. I don't see any BTF stuff in the .config there also. So, I don't know what is really going on here, I should install pahole on arm64 systems as well? And should pahole not be included when you upgrade your system to 25.5.1 ?
Thanks a lot for your help, Igor. That did not make the trick, as the available packages are still in the old form (docker.io instead of docker-ce for example. Nonetheless, I now have a working (but old) docker binary, which is enough for my use case. Now, I will try to build a more recent docker binary. The next problem to solve will be to get the NVMe to work. I'm sorry your F3 died.
