Device: Opi5-Plus. Have the same issue on Debian-Trixie kernel-6.16.8-edge-rockchip64 mpv (0.40.0_ deos not support vpu hardware acceleration. mpv --hwdec=v4l2request-copy is too slow to decode 4K/60 video, very high dropped frames. mpv --hwdec=v4l2request '/media/jfl/writable/home/jfl/Videos/Two Steps From Hell - Unleashed-15ZqpVOjZEc.mp4' ● Video --vid=1 (h264 1920x1080 60 fps) [default] ● Audio --aid=1 --alang=eng (aac 2ch 44100 Hz 128 kbps) [default] AO: [pipewire] 44100Hz stereo 2ch floatp VO: [gpu] 1920x1080 yuv420p AV: 00:00:04 / 00:05:41 (1%) A-V: 0.000 Exiting... (Quit) The is a mpv-full-git version @junari had build for arch linux which support v4l2request. The PKGBUILD https://github.com/iuncuim/manjaro-h616/blob/main/mpv-v4l2request/PKGBUILD Don't have experience to compile or build packages for Linux. Experience Armbian users and developers might be able to build the mpv-full-git for Debian Trixie.
Failed to boot after trying to manually upgrade kernel
The Tall Man replied to lovenemesis's topic in Raspberry Pi
Well I'm glad you found a way to get what you really needed and now have something that works : ) - Yesterday
Ok, figured it out My first mistake was not copying the proper u-boot file to the /boot folder cause the folder didn't exist when I flashed it with Balena Second, this box has a weird set of hardware that had issues with CoreELEC and even the Official Android upgrade, hence bricking into the Android dead robot and allowing me to force an upgrade with the official Android that fixed the partitions so I could run Armbian Third, the correct DTB for this box was meson-gxm-q200.dtb that makes everything works (attached a hw info file for future references) As of the moment, the Armbian is working perfectly. SSH works and it's displaying everything correctly. Not going to mess with Wi-Fi cause I don't really care about it. Again, thank you so much SteeMan for the help, the instructions and everything. I'll upload the hw_info and the URL for both "official" Android 7.1.1 upgrades (PC and SD flash images) for anyone to find cause it took me around a week to find those. Official MeCool BB2 Pro Android: https://www.geekbuying.com/geekgiz/2018/06/mecool-bb2-pro-s912-3gb16gb-tv-box-firmware-update-20180202/?admitad_uid=b4ee2a23c13552c70bd97fdfc0371b76&utm_source=4pda.ru&utm_medium=referral&utm_campaign=ilia hw_info.log
@JaydenWithaWhy ok ,the source is right. The multitool should leave a dmesg log in the MULTITOOL partition of the sdcard; that log could be handy to understand what's wrong. Also you can access via SSH and run the multitool from there, so you may get some clearer output and some more details about the error. A last note, I never tested it with a 128gb sdcard; it should work but bugs are around the corner...
Sorry if I have come to the wrong place. A friend has given me an Orange Pi 5 Plus, fitted with a 1GB SSD, and I have been trying to get it started up. According to its previous owner, the SSD had been completely erased (I don't know why). It had no SD card with it when I got it. I downloaded the online instruction manuals, and set about trying to start it up, using a suitable 32GB SD card. I first tried with (OrangePi) Ubuntu, but ran into problems using Balena Etcher. It apparently transfers the Ubuntu Image to the SD card, but just as it appears to complete the process of verification, it produces a helpful error message ('There was an Error'....). I also tried with other OSes, with the same result, so it seems to be either me or the OPi which is having problems. After a bit of research, I found a description of using the Linux command 'dd' to transfer an image, so I did this, under a machine with Linux Mint - this appeared to go OK. I then plugged in the SD card, and powered up the OPi. After a delay, I get what looks like a Ubuntu 'splash' page on screen, and it appears to go through an installation process (? not sure if thats whats happening). However, after several minutes, there is a message saying there is an error, and a desktop session will be started to allow debugging - but I can't get anything else to happen. I have asked the previous owner, but he says probably the bootloader is missing. (I suspect he never got it running). Here I come unstuck - I can't find any info on bootloaders - like what it is, where to get it, what to do with it, etc, so I am hoping someone here can point me in the right direction. I have gone through the instruction manual, but it seems to be slightly out of date, and I had no success using its instructions. Ideally, I would like to boot the OPi from the SSD, if that is possible, but have no idea how to go about this - and there seems to be a great deal of conflicting (wrong?) info online. I did try the Orange Pi 'official' forums, but got lost in the chinese messages which came up.
No one has ever submitted this for inclusion in Armbian. This is a community supported board. If anyone were to submit this as a PR it would almost certainly be included as the approval process for community supported boards is a low bar, basically that it doesn't break the build.
I am using :- [ Ubuntu 24.04 (Noble)](https://dl.armbian.com/rock-5b-plus/Noble_vendor_server) from :- [Radxa Rock 5B Plus - Armbian](https://www.armbian.com/rock-5b-plus/) Trying to turn fan on on Radxa Rock 5B+ selecting the device using armbian-config actually makes it disappear I am getting `line 3: echo: write error:Device or resource busy`
https://apt.armbian.com/ Expired Certificate
Werner replied to ER Samson's topic in Advanced users - Development
We're aware -
duplicate
I have tried A lot of ROMs and they do not work. The device is not working now. Please help. Thank you.
Could you please be more explicit or point me to some tutorial? In the readme the only info I can see are how to build U-Boot for s905x in the version I already have, or newer but for different chips s905x2 and s905x3. Thanks again for your help -
If you're still able to boot from microsd (which should be prefered over emmc if Armbian uboot is used) you can chroot into the system on eMMC and downgrade packages, either manually (apt/dpkg) or with armbian-config.
No clue, sorry. Maybe the driver might be optimized to work best with wayland. Maybe there is a fix pending or already merged into newer Linux version.
Addendum: An Easy Way To Bypass Grub's Self-Centric Orientation & Eliminate The Need For OS-Prober 1. Assuming you already have your EFI partition set up, for any OS that's mounting the EFI partition, stop that. In the /etc/fstab file, comment out (with a #) the line where it's mounted (i.e. as /boot/efi/). 2. Install grub on each OS. You can keep the /boot/grub/ directory on the same partition as root. Each installed OS will just update its own grub.cfg whenever it's needed. # If the your OS doesn't have a /boot/efi/ directory, create one. mkdir /boot/efi # Install grub. This will force it to install even though it won't detect a genuine EFI. grub-install --efi-directory /boot/efi --force Remember if you need to disable os-prober (recommended), just comment-out its line in /etc/default/grub. 3. Optional: Eliminate the pesky EFI Firmware menu entry in each OS this way: cd /etc/grub.d mkdir skip.d mv 30_uefi-firmware skip.d/ 4. Update Grub with your current kernels update-grub 5. Create a small partition for grub. 64 MB will suffice. 6. Choose an OS's grub, and copy all files from /boot/grub/ to that small grub partition. 7. On that grub partition, create a new grub.cfg. Here is a sample: set timeout=10 # Load Modules insmod all_video insmod part_gpt insmod ext2 insmod png # Setup Background loadfont unicode terminal_output gfxterm background_image /grub-16x9.png set color_normal=white/black set color_highlight=black/white # Menu Entries menuentry 'Orange PI Bookworm' { search.fs_uuid df078711-12a0-4637-9264-bac72ee25e4c root set prefix=($root)'/boot/grub' configfile $prefix/grub.cfg } menuentry 'Debian Trixie' { search.fs_uuid 1b6add1b-05ac-4568-bf54-1f920a6f8e3e root set prefix=($root)'/boot/grub' configfile $prefix/grub.cfg } menuentry 'Armbian 25.8.1 Bookworm' { search.fs_uuid ecb0ae86-8f5c-477e-bcd0-bc77ee5ebee9 root set prefix=($root)'/boot/grub' configfile $prefix/grub.cfg } menuentry 'Armbian 25.8.1 Trixie' { search.fs_uuid 6f2d1972-8868-4fb2-bde4-e14325ea4d31 root set prefix=($root)'/boot/grub' configfile $prefix/grub.cfg } menuentry 'Armbian 25.8.1 Noble (Ubuntu 24.04)' { search.fs_uuid d974e989-b201-48c6-b74b-f9ab5dfdfdae root set prefix=($root)'/boot/grub' configfile $prefix/grub.cfg } Of course, change the menu entry titles and UUIDs to your own. 8. Copy the background image you'd like to use to your grub partition. On Debian, background images for grub are typically stored some place like this: /usr/share/desktop-base/emerald-theme/grub Note in the sample grub.cfg file, grub-16x9.png is the background image named. If you want to use a .jpg instead of a .png, change the insmod png to insmod jpeg. 9. In your EFI partition, modify the grub.cfg to be as follows: search.fs_uuid 3D53-E216 root set prefix=($root)'/' configfile $prefix/grub.cfg ...changing the UUID to that of your grub partition. Usage Select the OS you want. That will take you to the OS's own grub menu, which will likely show you two options, the main boot option and "Advanced" boot options. If you select an operating system and wish to change your mind, the ESCAPE key will return you to your previous menu. Problems I did this and everything worked well except the Armbian Noble (Ubuntu) entry. I coped Debian Bookworm's grub to my grub partition, and either Ubuntu's grub is buggy or apparently Ubuntu's grub used language in its grub.cfg that Debian's grub didn't like. It boots into Ubuntu automatically, but it doesn't show any boot menu. I set its timeout for 10 seconds, so it sits with a blank screen for 10 seconds before it boots. Update: I replaced the grub files on my grub partition with those from Debian Trixie. Same results with Armbian Noble (Ubuntu).
Getting error installing Octoprint via armbian-config on Orange Pi Zero
djurny replied to seamoce's topic in Allwinner sunxi
Hi there, I ran octoprint and klipper on a orangepi zero (not at the same time). Octoprint from docker and klipper I cannot remember. Octoprint ran fine but it did have some issues when the CPU got overloaded with loading a new gcode file while printing for example. If you do things one by one it should be OKish. Btw i ran octoprint in a 512MB version, not on the 256MB one. Groetjes, -
Install openVFD for LCD display on recent (6.12) kernels - Tutorial
torz77 replied to torz77's topic in Reviews / Tutorials
So I looked into this, and unfortunately, no dice. I am happy to investigate further, if you so wish, but I'm happy enough with the way it works currently (auto patching the dtb after a kernel update) so am unlikely to go exploring further on my own. To let you know what I did: copied the dtbo to /boot/dtb/amlogic/overlay/meson-gxl-s905w-tx3-mini-openvfd.dtbo Added to /boot/extlinux/extlinux.conf: fdtoverlays /dtb/amlogic/overlay/meson-gxl-s905w-tx3-mini-openvfd.dtbo (I also tried with /boot prepended to the path as well, but same issue) note: I assume FDTOVERLAYS is a typo from the armbianEnv.txt days, so I went with the lowercase as that is standard for extlinux The device would not come up on the network. I plugged in an HDMI monitor and found that it would hang at: ethernet end0: renamed from eth0 Which is.... odd. I suspect one of 2 things: My entry in extlinux.conf is incorrect (entirely plausible, I'm struggling to find documentation, I've just gone on what you've said, and also changed the capitalisation!) U-Boot overlays are applied differently than fdtoverlay in Linux. It’s possible U-Boot leaves something unaligned or adds an unexpected property, and the kernel hits a corner case. I realise that the above is noway near enough information, however, connecting directly to serial is not realistic at this stage, but I can attach a netconsole if needs be, as we are reaching the kernel, and provide further output. Like I say though, I will only do this if you think there is value in it. Whilst my method might not be the preferred way, it does work, at least. -
@DiplDi I was doing some experiments on Armbian 25.8.1 Trixie, and I decided to do a quick try of installing the XFCE desktop (along with some others): sudo apt-get -o APT::Install-Recommends="true" install task-xfce-desktop It works under X, but not under Wayland. I found out that its Wayland support is experimental, and that if you install the labwc package, that will get it running (very very badly) under Wayland. But it does work well under X. It's possible a different wayland compositor (than labwc) will work better? I also tried with the Vendor kernel (with the Panthor GPU overlay), and the edge kernel. Edge GPU performs seemingly not at all under X, but vendor with Panthor overlay performs well in X. I initially logged in via the SDDM display manager, but I switched to LightDM, and that worked as well, although with a hiccup.
Composite TV OUT WORKING in Orange Pi One H3, 6.12 current
robertoj replied to Error1429's topic in Orange Pi One
That change is already merged into Armbian for the orange pi zero LTS. It was such a long time ago, I don't remember how to use it right now. https://github.com/armbian/build/blob/9ef5b99b220c5e77b55514136e025008c16ccbfd/patch/kernel/archive/sunxi-6.12/patches.armbian/enable-TV-Output-on-OrangePi-Zero-LTE.patch#L8 https://github.com/armbian/build/commit/41260ac309b487d241fec97ffbdeced730bc2d04 Partial progress log https://forum.armbian.com/topic/22226-orange-pi-zero-lts-tv-out-in-2022/#findComment-162035 -
Is it the 128x160 1.8" red screen? Combine the knowledge of https://forums.raspberrypi.com/viewtopic.php?t=380704&hilit=ST7735S#p2275556 and https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/ To use the panel-mipi-dbi-spi driver, which is more universal for SPI screens Warning: you will not get the spidev, and the linux OS will handle all the rendering. Also, X11 may have a problem with Linux 6.14, unless someone fixes a bug
Abandoned vendor-provided BSP roadblocks can be overcome when mainline Open Source projects like the Linux kernel are integrated directly. Get your upstreamed BSPs from day one. View the full article
I tested the upstream Debian and I only got 4GB as well, I don't know if that was stable or not. Actually some upstream Debian images I tried didn't work at all at first. Then I upgraded the firmwares on my board, following these instructions: https://forum.rvspace.org/t/visionfive-2-debian-image-released/994/75 Bu I was more precise than that, first I used the sdcard image and fimware files from 2.6.0 (said to work in that page): https://github.com/starfive-tech/VisionFive2/releases/tag/VF2_v2.6.0 Note: I had no display, I ran the firmware update commands over SSH. Then I rebooted, using the sdcard image from 2.11.5 (arbitrary chosen): https://github.com/starfive-tech/VisionFive2/releases/tag/VF2_v2.11.5 But I used the latest (5.11.3) firmware files to update the firmware: https://github.com/starfive-tech/VisionFive2/releases/tag/JH7110_VF2_515_v5.11.3 After that, I flased the latest image (202409), for sdcard: starfive-jh7110-202409-SD-minimal-desktop-wayland.img The whole 8GB is displayed and everything looks stable, the board is running since 9 hours without problem. But one problem is that this Debian image is based on an now-old Debian Trixie/Sid snapshot, which is painful to deal whit. I'll try again the Armbian image later to see if the firmware update fixed the memory size problem and the stability.
Is it possible to use /dev/ttyS0 to connect a zigbee coordinator?
Yurannich replied to Yurannich's topic in Amlogic CPU Boxes
S905W2 I didn't find a solution to my problem on the forum. -
Armbian 25.8.1 Noble XFCE (mainline Kernel: 6.16.6-edge-rockchip64) + PanVk - mesa 23.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.7 (https://ryanfortner.github.io/box64-debs/) + wine-10.15-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.15) + DXVK-stripped v2.7.1 ~30fps@720p Dark Souls 2 - SotFS
