Just plugged a M.2 M key to E key adapter with an Intel AX200 iwlwifi (installed the firmware) booted up and Wifi 6 is going without using a USB port. My project is one step closer!!! Just have to get that last USB-C port working.
Bluetooth doesn't appear after boot very often in Orange Pi 2W
sminder replied to sminder's topic in Orange Pi Zero 2
user@orangepizero2w:~$ systemctl status bt-gpio.service × bt-gpio.service - Enable GPIO for Bluetooth chip Loaded: loaded (/etc/systemd/system/bt-gpio.service; enabled; preset: enabled) Active: failed (Result: exit-code) since Tue 2025-06-10 23:18:23 +03; 11h ago Process: 489 ExecStart=/bin/sh -c echo 225 > /sys/class/gpio/export || true; echo out > /sys/class/gpio/gpio225/direction; echo 1 > /sys/class/gpio/gpio225/value (code=exited, status=2) Main PID: 489 (code=exited, status=2) CPU: 5ms jun 10 23:18:23 orangepizero2w systemd[1]: Starting bt-gpio.service - Enable GPIO for Bluetooth chip... jun 10 23:18:23 orangepizero2w sh[489]: /bin/sh: 1: echo: echo: I/O error jun 10 23:18:23 orangepizero2w sh[489]: /bin/sh: 1: cannot create /sys/class/gpio/gpio225/direction: Directory nonexistent jun 10 23:18:23 orangepizero2w sh[489]: /bin/sh: 1: cannot create /sys/class/gpio/gpio225/value: Directory nonexistent jun 10 23:18:23 orangepizero2w systemd[1]: bt-gpio.service: Main process exited, code=exited, status=2/INVALIDARGUMENT jun 10 23:18:23 orangepizero2w systemd[1]: bt-gpio.service: Failed with result 'exit-code'. jun 10 23:18:23 orangepizero2w systemd[1]: Failed to start bt-gpio.service - Enable GPIO for Bluetooth chip. Also I attached boot log which is connected to that "systemctl status bt-gpio.service" command. bt_fail_boot_log_3.txt When the board was boot correctly (BT is working fine) the output looks the same: user@orangepizero2w:~$ systemctl status bt-gpio.service × bt-gpio.service - Enable GPIO for Bluetooth chip Loaded: loaded (/etc/systemd/system/bt-gpio.service; enabled; preset: enabled) Active: failed (Result: exit-code) since Wed 2025-06-11 11:04:21 +03; 1min 30s ago Process: 492 ExecStart=/bin/sh -c echo 225 > /sys/class/gpio/export || true; echo out > /sys/class/gpio/gpio225/direction; echo 1 > /sys/class/gpio/gpio225/value (code=exited, status=2) Main PID: 492 (code=exited, status=2) CPU: 5ms jun 11 11:04:21 orangepizero2w systemd[1]: Starting bt-gpio.service - Enable GPIO for Bluetooth chip... jun 11 11:04:21 orangepizero2w sh[492]: /bin/sh: 1: echo: echo: I/O error jun 11 11:04:21 orangepizero2w sh[492]: /bin/sh: 1: cannot create /sys/class/gpio/gpio225/direction: Directory nonexistent jun 11 11:04:21 orangepizero2w sh[492]: /bin/sh: 1: cannot create /sys/class/gpio/gpio225/value: Directory nonexistent jun 11 11:04:21 orangepizero2w systemd[1]: bt-gpio.service: Main process exited, code=exited, status=2/INVALIDARGUMENT jun 11 11:04:21 orangepizero2w systemd[1]: bt-gpio.service: Failed with result 'exit-code'. jun 11 11:04:21 orangepizero2w systemd[1]: Failed to start bt-gpio.service - Enable GPIO for Bluetooth chip. -
Sounds good, thank you Werner! If anyone wants to share their favorite boards then please go ahead too 🙂
No
That is worrying, I wonder if there could potentially be issues with the RAM, which could either be faulty or clocked higher than a level it is stable at. Reffering back to the fex you provide earlier it suggest a dram value of 384, so you may have to the def_config file to include the line CONFIG_DRAM_CLK=384. Is the card just class 10 rated or is it an A1 SD card? https://docs.armbian.com/User-Guide_Getting-Started/ Strange it should auto login on first boot. What it should be request is to set a new root password then confirming that password. Could you please provide a screen shot of the login screen you are greeted with. Alternatively it may be possible to set the root password external to get around this issue. Please see: https://docs.armbian.com/User-Guide_Autoconfig/ Strange never encoutered that before, have you tried pulling the latest version of armbian build to see if it fixes it? Unfortunately I have not had a lot of luck in trying to get WSL2 to work so I have stuck with virtual box. Worth a shot with the pre-built images, but I dont believe the Cubieboard is in a much better state. best of luck Ryzer -
Description Fix the peripheral aliases to ensure consistent allocation when enabled, so that kernel assignment matches the numbering convention of the SOC. This targets the Allwinner A10 and A20 and ensures, that for example if enabling UART2 exposes it correctly in userspace as ttyS2 rather than dynamically assigning it to the first avaliable ttySx slot. Secondly spidev overlays creates an instance of spidevX.Y based on the bus specified with armbianEnv.txt however it does not correctly configure the corresponding pins into spi mode. To resolve this the individual spi bus overlays have been include in the makefile. The desired bus must be enabled alongside spidev or seperately if using another spi device driver in order to be functional. I have also corrected the A10 spi overlays where they incorrectly target the A20. How Has This Been Tested? Built and tested on Pcduino 2 running 6.12.23-current-sunxi Built and tested on Pcduino 3 running 6.14.5-edge sunxi Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] My changes generate no new warnings View the full article
5B+ on vendor (6.1.115) has all I/O related stuff fixed (since 6.1.84) as far as my testing (the one reported in the https://www.armbian.com/rock-5b-plus/ description). Looking into the broken gnome image though and will update here!
hi , can i use these image to boot armbian to my s805X Amlogic soc.
Helios-64 Fails to boot since upgrading to Bookworm
djurny replied to Carlos Hartmann's topic in Rockchip
Hi, If you are having trouble sourcing a proper serial dongle, you could also try to set (or cap) the serial console's baudrate yourself in armbianEnv.txt. Use/replace the following: console=comfort extraargs=console=ttyS2,115200 earlyprintk=ttyS2,115200 This should prevent your bootscript from setting the kernel's serial baudrate to 1M5 and at least give you some kernel logging during booting. Not sure if the login prompt will follow the same baudrate, as `getty` (or one of it's variants) might use different default settings. Groetjes, -
the manufacturer hates us, that's it There is no method, they are all hobbyist experiments -
@maka into this file: https://github.com/hqnicolas/ubuntu-rockchip-joshua/blob/main/config/suites/noble.sh it makes refference to the kernel repo: https://github.com/hqnicolas/linux-rockchip that contains the dts file: https://github.com/hqnicolas/linux-rockchip/blob/arm64--dts--rockchip--add-rk3566-h96max-v56/arch/arm64/boot/dts/rockchip/rk3566-h96max-v56.dts That have the USB setup: &usb2phy0 { status = "okay"; }; &usb2phy1 { status = "disabled"; }; &usb_host0_ehci { status = "disabled"; }; &usb_host0_ohci { status = "disabled"; }; &usb_host1_ehci { status = "disabled"; }; &usb_host1_ohci { status = "disabled"; }; &usbdrd_dwc3 { dr_mode = "host"; extcon = <&usb2phy0>; status = "okay"; }; &usbdrd30 { status = "okay"; }; &usbhost_dwc3 { status = "okay"; }; &usbhost30 { status = "okay"; }; &pinctrl { usb { vcc5v0_otg_en: vcc5v0-otg-en { rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; }; }; There Are 3 Branches: -
Does anyone know if this will be solved in new releases or should we use an old kernel 6.6.75 as alternative? Then the next question : can we avoid an update of the kernel when using the apt command upgrade? Already found the solution: Use armbian-config and disable upgrade of firmware
klipper@transpeed-8k618-t:~/8821au-20210708$ sudo modprobe 8812au modprobe: ERROR: could not insert '8812au': Unknown symbol in module, or unknown parameter (see dmesg) klipper@transpeed-8k618-t:~/8821au-20210708$ sudo dmesg | grep 8812 [ 7.950162] module 8812au: .gnu.linkonce.this_module section size must match the kernel's built struct module size at run time klipper@transpeed-8k618-t:~/8821au-20210708$ dkms status rtl8812au/5.13.6-23, 6.12.11-edge-sunxi64, aarch64: installed rtl8821au/5.12.5.2, 6.12.11-edge-sunxi64, aarch64: installed I've compile a new image with MT7601U, it works. What should I do for rtl8812 to work? -
Ok Tks, very hard work with nand. But, ok work for me with sd card. Could you tell me if the Wifi would work?
Can someone share a ready .dtb file with this patch. I am trying to run SPDIF in Tv-Box Vontar X3 with Amlogic S905x3 processor but I can't compile with this patch.
Update maintainers and board status synced status from the database rename to .csc where we don't have anyone If you want to become a board maintainer, adjust data here. Ref: Board Maintainers Procedures and Guidelines Contribute View the full article
Description Attempt to work towards one U-Boot bootscript for (at least) mvebu, sunxi and rockchip64. This adds: (Aligned) load address calculations This will remove the need to update any kernel_load_addr_r or ramdisk_addr_r in case kernel image increases. Calculation is based on either Flat kernel image image_size + text_offset as specified in the vmlinux(/Image) header info Compressed kernel image filesize (vmlinuz/zImage) Clear warnings to user in case files are not found, not able to load or application failed. Merge of armbianEnv.txt kernel options was attempted for sunxi, mvebu and rockchip64. DT folder determination based on sunxi approach. DT file determination based on sunxi approach. Compat with /boot/dtb/fdtfile.dtb and /boot/dtb/vendor/fdtfile.dtb. Simplified some constructs by assuming U-Boot has successfully sourced us with a set of pre-set variables, like ${prefix} ${devtype} etc. Actively set the ${kernel_comp_*} parameters based on calculations of load addresses. Ability to select different kernel/initrd by setting kver in armbianEnv.txt Also: Any warning or error includes a 10 second delay to make sure the user is able to see and read them. Any "informative" message added by the bootscript can be silenced by setting verbosity to 0 Attempted to make the bootscript 'reentrant' in away: all variables required for proper (re)execution are set, which should allow for the entire bootscript to be re-run on a next boot_target. All variables used in for-loops are actively cleared from the environment to ensure for loops work as expected. Any pre-set variable that might be used in next boot_target will be reset whenever necessary. Documentation summary for feature / change [ ] short description (copy / paste of PR title) [x] summary (description relevant for end users) Load address calculation can be disabled by adding load_addr_calc=off to armbianEnv.txt Load address calculation OBOE avoidance can be disabled by adding align_overlap_oboe_avoidance=off to armbianEnv.txt User can set custom fdtdir and fdtfile in armbianEnv.txt, but make sure to only specify DT filename in fdtfile. fdtdir will be used to both load DT, DT overlays and fixup scripts [ ] example of usage (how to see this in function) How Has This Been Tested? [x] Orangepi Zero (first gen):[12:39:52] U-Boot SPL 2024.01-armbian-2024.01-S866c-P6b16-Ha5c2-V367a-Bb703-R448a (Apr 29 2025 - 02:50:09 +0000) [12:39:52] DRAM: 512 MiB [12:39:52] Trying to boot from MMC1 [12:39:53] ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 [12:39:53] U-Boot 2024.01-armbian-2024.01-S866c-P6b16-Ha5c2-V367a-Bb703-R448a (Apr 29 2025 - 02:50:09 +0000) Allwinner Technology [12:39:53] CPU: Allwinner H3 (SUN8I 1680) [12:39:53] Model: Xunlong Orange Pi Zero [12:39:53] DRAM: 512 MiB [12:39:53] Core: 70 devices, 19 uclasses, devicetree: separate [12:39:53] WDT: Not starting watchdog@1c20ca0 [12:39:53] MMC: mmc@1c0f000: 0, mmc@1c10000: 1 [12:39:53] Loading Environment from FAT... Unable to use mmc 0:1... [12:39:53] In: serial,usbkbd [12:39:53] Out: serial [12:39:53] Err: serial [12:39:53] Starting SCP... [12:39:53] Net: SCP/INF: Crust v0.6.10000 [12:39:53] eth0: ethernet@1c30000 [12:39:53] starting USB... [12:39:53] Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus [12:39:53] USB EHCI 1.00 [12:39:53] Bus usb@1c1a400: USB OHCI 1.0 [12:39:53] Bus usb@1c1b000: USB EHCI 1.00 [12:39:53] Bus usb@1c1b400: USB OHCI 1.0 [12:39:53] Bus usb@1c1c000: USB EHCI 1.00 [12:39:53] Bus usb@1c1c400: USB OHCI 1.0 [12:39:53] scanning bus usb@1c1a000 for devices... 1 USB Device(s) found [12:39:54] scanning bus usb@1c1a400 for devices... 1 USB Device(s) found [12:39:55] scanning bus usb@1c1b000 for devices... 1 USB Device(s) found [12:39:56] scanning bus usb@1c1b400 for devices... 1 USB Device(s) found [12:39:57] scanning bus usb@1c1c000 for devices... 1 USB Device(s) found [12:39:59] scanning bus usb@1c1c400 for devices... 1 USB Device(s) found [12:40:00] scanning usb for storage devices... 0 Storage Device(s) found [12:40:00] Autoboot in 1 seconds, press <Space> to stop [12:40:01] switch to partitions #0, OK [12:40:01] mmc0 is current device [12:40:01] Scanning mmc 0:1... [12:40:01] Found U-Boot script /boot/boot.scr [12:40:01] 18117 bytes read in 4 ms (4.3 MiB/s) [12:40:01] ## Executing script at 43100000 [12:40:01] Boot script loaded from mmc 0:1. [12:40:01] 687 bytes read in 3 ms (223.6 KiB/s) [12:40:01] Loaded/imported environment /boot/armbianEnv.txt to/from 0x45000000. [12:40:01] Found mainline kernel configuration. [12:40:01] 35473 bytes read in 11 ms (3.1 MiB/s) [12:40:01] Loaded DT /boot/dtb/sun8i-h2-plus-orangepi-zero.dtb to 0x43000000. [12:40:01] Working FDT set to 43000000 [12:40:01] Loading kernel provided DT overlay(s) from /boot/dtb/overlay to 0x45000000 .. [12:40:01] 504 bytes read in 10 ms (48.8 KiB/s) [12:40:01] Applied DT overlay usbhost2 (/boot/dtb/overlay/sun8i-h3-usbhost2.dtbo). [12:40:01] 504 bytes read in 10 ms (48.8 KiB/s) [12:40:01] Applied DT overlay usbhost3 (/boot/dtb/overlay/sun8i-h3-usbhost3.dtbo). [12:40:01] 617 bytes read in 10 ms (59.6 KiB/s) [12:40:01] Applied DT overlay tve (/boot/dtb/overlay/sun8i-h3-tve.dtbo). [12:40:01] 374 bytes read in 9 ms (40 KiB/s) [12:40:01] Applied DT overlay i2c0 (/boot/dtb/overlay/sun8i-h3-i2c0.dtbo). [12:40:01] Loading user provided DT overlay(s) from /boot/overlay-user to 0x45000000 .. [12:40:01] 835 bytes read in 3 ms (271.5 KiB/s) [12:40:01] Applied user DT overlay rtc0-i2c-ds3231-rtc1-soc (/boot/overlay-user/rtc0-i2c-ds3231-rtc1-soc.dtbo). [12:40:01] 4185 bytes read in 10 ms (408.2 KiB/s) [12:40:01] ## Executing script at 45000000 [12:40:01] Loaded/sourced fixup script /boot/dtb/overlay/sun8i-h3-fixup.scr to/at 0x45000000. [12:40:02] 10554192 bytes read in 441 ms (22.8 MiB/s) [12:40:02] Loaded compressed kernel image /boot/zImage to 4300a000. [12:40:02] Using compressed kernel image filesize 0xa10b50 bytes to calculate initial ramdisk load address. [12:40:02] 11621101 bytes read in 484 ms (22.9 MiB/s) [12:40:02] Loaded initial ramdisk /boot/uInitrd to 43a1b000. [12:40:02] Unknown command 'kaslrseed' - try 'help' [12:40:02] Not able to prepare for KASLR. [12:40:02] Kernel commandline arguments: [12:40:02] root=/dev/nfs [12:40:02] rootfstype=nfs [12:40:02] rootwait [12:40:02] splash=verbose [12:40:02] earlycon [12:40:02] console=ttyS0,115200 [12:40:02] consoleblank=0 [12:40:02] loglevel=8 [12:40:02] ubootpart=81f6566a-01 [12:40:02] usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u,0x174c:0x55aa:u [12:40:02] dwc_otg.fiq_enable=0 [12:40:02] net.ifnames=0 [12:40:02] ipv6.disable=1 [12:40:02] rw [12:40:02] nfsroot=192.168.2.34:/export/rootfs/blippi [12:40:02] ip=dhcp [12:40:02] nfsrootdebug [12:40:02] nfs.enable_ino64=0 [12:40:02] cgroup_enable=cpuset [12:40:02] cgroup_memory=1 [12:40:02] cgroup_enable=memory [12:40:02] Kernel image @ 0x4300a000 [ 0x000000 - 0xa10b50 ] [12:40:02] ## Loading init Ramdisk from Legacy Image at 43a1b000 ... [12:40:02] Image Name: uInitrd [12:40:02] Image Type: ARM Linux RAMDisk Image (gzip compressed) [12:40:02] Data Size: 11621037 Bytes = 11.1 MiB [12:40:02] Load Address: 00000000 [12:40:02] Entry Point: 00000000 [12:40:02] Verifying Checksum ... OK [12:40:02] ## Flattened Device Tree blob at 43000000 [12:40:02] Booting using the fdt blob at 0x43000000 [12:40:02] Working FDT set to 43000000 [12:40:02] Loading Ramdisk to 494ea000, end 49fff2ad ... OK [12:40:02] Loading Device Tree to 494de000, end 494e9fff ... OK [12:40:02] Working FDT set to 494de000 [12:40:02] Starting kernel ... [12:40:03] [ 0.000000] Booting Linux on physical CPU 0x0 [x] Orangepi zero (first gen): OKU-Boot SPL 2024.01-armbian (Feb 23 2024 - 10:47:39 +0000) DRAM: 256 MiB Trying to boot from MMC1 ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.01-armbian (Feb 23 2024 - 10:47:39 +0000) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 256 MiB Core: 70 devices, 19 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial,usbkbd Out: serial Err: serial Starting SCP... Net: SCP/INF: Crust v0.6.10000 eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus USB EHCI 1.00 Bus usb@1c1a400: USB OHCI 1.0 Bus usb@1c1b000: USB EHCI 1.00 Bus usb@1c1b400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c1a000 for devices... 1 USB Device(s) found scanning bus usb@1c1a400 for devices... 1 USB Device(s) found scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning bus usb@1c1b400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 18202 bytes read in 5 ms (3.5 MiB/s) ## Executing script at 43100000 Boot script loaded from mmc 0:1. 265 bytes read in 4 ms (64.5 KiB/s) Loaded/imported environment /boot/armbianEnv.txt to/from 0x45000000. Found mainline kernel configuration. 35473 bytes read in 9 ms (3.8 MiB/s) Loaded DT /boot/dtb/sun8i-h2-plus-orangepi-zero.dtb to 0x43000000. Working FDT set to 43000000 Loading kernel provided DT overlay(s) from /boot/dtb/overlay to 0x45000000 .. 504 bytes read in 11 ms (43.9 KiB/s) Applied DT overlay usbhost2 (/boot/dtb/overlay/sun8i-h3-usbhost2.dtbo). 504 bytes read in 12 ms (41 KiB/s) Applied DT overlay usbhost3 (/boot/dtb/overlay/sun8i-h3-usbhost3.dtbo). 4185 bytes read in 11 ms (371.1 KiB/s) ## Executing script at 45000000 Loaded/sourced fixup script /boot/dtb/overlay/sun8i-h3-fixup.scr to/at 0x45000000. 10554192 bytes read in 442 ms (22.8 MiB/s) Loaded compressed kernel image /boot/zImage to 4300a000. Using compressed kernel image filesize 0xa10b50 bytes to calculate initial ramdisk load address. 11867098 bytes read in 497 ms (22.8 MiB/s) Loaded initial ramdisk /boot/uInitrd to 43a1b000. Unknown command 'kaslrseed' - try 'help' Not able to prepare for KASLR. Kernel commandline arguments: root=PARTUUID=1c01f668-02 rootfstype=f2fs rootwait splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=8 ubootpart=1c01f668-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u,0x174c:0x55aa:u net.ifnames=0 ipv6.disable=1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory Kernel image @ 0x4300a000 [ 0x000000 - 0xa10b50 ] ## Loading init Ramdisk from Legacy Image at 43a1b000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11867034 Bytes = 11.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Working FDT set to 43000000 Loading Ramdisk to 494ae000, end 49fff39a ... OK Loading Device Tree to 494a2000, end 494adfff ... OK Working FDT set to 494a2000 Starting kernel ... Checklist: [ ] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [ ] My changes generate no new warnings New warnings introduced: Environment load failed Environment import failed DT load/application failed DT (user) overlay load/application failed Initial ramdisk load failed Kernel image load failed Boot failed [x] Any dependent changes have been merged and published in downstream modules Prequisite U-Boot setexpr command already merged via https://github.com/armbian/build/pull/8260. View the full article
In this final article of a three-part series, I look at locking with C++ and Matt Godbolt's notion of CADR. View the full article
OrangePi 3 lts / i2C / overlay / armbian-config ?
Lars Christian Nygård replied to kris777's topic in Allwinner sunxi
Having trouble with my klipper accelerometer every time the dtb is upgraded during a update/upgrade. I made this patch to fix the spi@5011000 { ...} section: 831c831 < status = "disabled"; --- > status = "okay"; 834a835,840 > spidev@0 { > compatible = "armbian,spi-dev"; > reg = <0x00>; > spi-max-frequency = <0xf4240>; > }; > And then dtc -I dtb -O dts -o sun50i-h6-orangepi-3-lts.dts /boot/dtb/allwinner/sun50i-h6-orangepi-3-lts.dtb patch -b sun50i-h6-orangepi-3-lts.dtso opi3lts-dtb.patch dtc -I dts -O dtb -o /boot/dtb/allwinner/sun50i-h6-orangepi-3-lts.dtb sun50i-h6-orangepi-3-lts.dts Not sure if this is a sane and safe way to do it, but it works for me at least. Hope it can find it's way in a sane form into a future release. Maybe it's better to do it in an overlay, rather than directly? opi3lts-dtb.patch -
Helios64 - SATA issues with Armbian 25.5.1/Kernel 6.12.32
djurny replied to Alexander Eiblinger's topic in Rockchip
Hi, Not an expert here, but some educated guesses would be related to either timing, blocksizes towards the devices. Anything that might change or increase the amount of ATA commands towards the disks would be my bet to look at. You could experiment with enabling/disabling NCQ, reducing read-ahead, increasing chunksizes in case you use [software] RAID, increasing caching by tweaking vm options. Perhaps even the IO schedulers, there might have been some new IO schedulers introduced on the new kernel that show different behavior compared to the older kernel, etc. Groetjes, -
Offeacy61 replied to Pita Bread's topic in TV Boxes running Armbian
Thanks for the detailed description! Very useful post, especially for those who are just starting to tinker with Armbian on TV boxes. I had a similar situation with another S905X3 box - neither Wi-Fi nor Bluetooth worked, and there was trouble with HDMI audio. Special thanks for the advice on disabling unattended-upgrades and systemd-networkd-wait-online, I just encountered problems with long loading, now I understand where the legs are growing from. Regarding USB audio - an excellent solution, I didn't even know that it was so easy to bypass the lack of built-in sound. I will try with a similar adapter. If you have a chance, tell me later whether you managed to set up Wi-Fi via a USB adapter or in another way. And I wonder if you tried other window environments besides XFCE? LXQt, for example? In any case - a great guide, thanks for your work! -
Description Currently, PocketBeagle 2 edge images cannot build (without patch 1) and fails to boot (without patch 3). The patch one just defines the missing variable for OPTEE. Patch 3 specifies root using path instead of UUID. For some reason, UUID does not work with PocketBeagle 2 U-boot. How Has This Been Tested? Tested on PocketBeagle 2 rev A0 Checklist: Please delete options that are not relevant. [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
Description The idea is to introduce the possibility to cache downloads from GH runners to lower downstream bandwidth used and increase overall speed. Especially on machines with lots of runner this could save quite some bandwidth while sacrificing disk space. http caching has been tested and seem to work nicely. https caching is a lot more tricky and may be introduced later. This PR has two parts: set apt repository to http instead of https where possible. Packages are signed anyways. Pass various proxy environment variables to docker so it respects those. Doesn't make sense not to pass them since when using PREFER_DOCKER=no and any of these variables are set beforehand they just work. So this more or less just harmonizes overall behavior. There is still an issue on line 4838 caused by https://github.com/armbian/build/blob/c0da65087aad628ba0714f23d8d29800f152d97c/lib/functions/rootfs/apt-install.sh#L67 due to absence of apt proxy setting there. Not sure why this is not added here? How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] build random image: https://paste.armbian.de/xopitiguyo , look for 10.100.0.87 to see where it is used [x] built the same random image but having all proxy env variables unset beforehand: builds just fine as well: https://paste.armbian.de/ozidivugor Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
