  2. Good morning. Is there any means of writing an Armbian image to Allwinner H313 emmc? Phoenixsuit does not allow Armbiam images to be written. I have tried to compile (Make) Livesuit, but I gave up due to several incompatibilities (kernel, libraries, etc.). Thanks in advance.
  4. Hello everyone. I’m attempting to mount a Windows network share on Armbian, but something seems off—both smb://10.10.2.101 and sftp://10.10.2.101 show up in red. The same addresses work perfectly on Rocky Linux; any thoughts on what I might be overlooking?
  5. You need to provide more informations. I wasn't able to repreoduce. I works here.
  6. What you’re seeing is open-source maintenance in practice. It’s not centrally orchestrated. We only manage to do this for some key features while DVB support is present in some kernels, but it’s not guaranteed to be consistently enabled across all targets unless someone explicitly maintains this functionality. -> https://github.com/armbian/build/pulls
  7. Yesterday
  8. @Nick A Great! and Good job! I've tested both the server and desktop versions of v0.6.4 on the A7S, and the DP output works perfectly on both. I've attached a screenshot for your reference. I’m using a USB‑C to HDMI docking station to test it. When I repeatedly plug and unplug it, the display works fine. The dock also has a keyboard receiver plugged in, which works normally. However, if I then plug a USB flash drive into the dock, the display output stops working (probably due to power supply issues). If I unplug the USB drive and plug it back in, the display works normally again. Additionally, I tested the Mainline v0.1. It seems to have issues on the A7S: the blue LED flashes after boot, but neither the Ethernet nor WiFi connects, and there is no output on the DP port. It appears the system cannot be login (I haven't tested via UART). However, the A7Z handles dual screens fine over HDMI and DP.
  9. $ grep -i error /var/log/armbian-hardware-monitor.log [ 2.990779] rockchip-pcie f8000000.pcie: probe with driver rockchip-pcie failed with error -110 Looking at this I see the following: https://patchwork.ozlabs.org/project/linux-pci/patch/20210421083115.30213-1-jinsiyu940203@163.com/ "In function rockchip_pcie_host_init_port(), it defines a timeout value of 500ms to wait for pcie training. However, it is not enough for samsung PM953 SSD drive and realtek RTL8111F network adapter, which leads to the following errors: [ 0.879663] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 0.880284] rockchip-pcie f8000000.pcie: deferred probe failed [ 0.880932] rockchip-pcie: probe of f8000000.pcie failed with error -110 The pcie spec only defines the min time of training, not the max one. So set a proper timeout value is important. Change the value to 1000ms will fix this bug." Is it possible for team to add patch such as ../patch/kernel/rockchip64-current/0002-rockchip-pcie-increase-timeout.patch which contains the fix specified in the patchwork.ozlabs.org link above? A humble thank you for any more help and consideration on this!
  10. @well0nez I didn't even think about that. When I made the original post almost two years ago, AI was much less capable than today. You just gave me a few ideas for different projects. As I said, unfortunately I don't have the HY300 anymore, but I do have a Magcubic L018(same chip I think), though it's in use every day as a bedroom TV. I don't think my girlfriend would appreciate if I started to hack it 😉 Especially if core functions like projecting the things coming through the HDMI port to the wall. The L018 has worse software than the HY300, in my opinion, so I've connected it to a certified Android TV 14 Box.
  11. Hello, I updated to Armbian 26.2.1 trixie installaed on emmc. If I poweroff the nas and power on again it does't work, but if I attach an usb cable to the console it works. I think the problem must be related to the u-boot part.
  12. It worked seamlessly! Thanks!
  13. Hi everyone! I tried installing hardware decoding from this link - https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/ , but it didn't work for me. My board version is 5.1. Has anyone been able to fix this?
  14. I tried to enable the I2S / PCM5102 service with AI, but unfortunately, despite numerous attempts, I couldn't. But anyone can use a USB audio card. Maybe someone else will figure out how to enable it 🙂 Best regards
  15. Last week
  16. yes, i've studied the schematic well to see if that gave any clues and I have learned that it ties into the Power Management Unit. It remains that the button doesn't work on mainline kernels but does on the vendor kernel. There must be some init step or configuration that's missing.
  17. Looks like the current-rockchip64 kernel that one receives with apt on PINE64 rockpro64 is 3.18.10 (6.18.10-current-rockchip64), vulnerable to copy-fail. This seems weird because if you go to https://armbian.com/boards/rockpro64 that page says that the "current" kernel for these systems is 6.18.26 and that is what you get when you download the image file. Is there an issue with updating the apt repos?
  18. Things are still very sad with Ethernet. Is this could be related to some low-level timings in device configuration?
  19. First of all, thanks for your reply. Even though you said there are no "vendor-lockin" i felt like so that's why i created a post on this forum as this issue came only after armbian os flash. As i said, after flashing armbian os, i was not able to use MASK button to bypass emmc boot and about a dozen of different os other than armbian failed to boot from SD card. Then i experimented on different methods including the PC connectivity but changing bootloader or os image didn't work as the mask communication is getting lost during flash command run. I deleted boot files from armbian boot partition to check if that fall back to SD card, but there was no luck. However armbian SD card boot still worked. So i confirmed that it is the change in bootloader that armbian made. Then i re installed armbian os inside emmc and used dd command to write the original bootloader images which is taken from the nanopi r6s official eflasher download link. It worked! Now i am able to install other os than armbian. Kindly fix this issue and acknowledge the same, otherwise people like me will think twice before testing latest armbian os next time. Best regards
  20. Ah, this board has n out of tree dt as well which most likely overwrites the patch. Try adjusting this file: ~/build/patch/kernel/archive/rockchip64-6.18/dt/rk3576-nanopi-r76s.dts
  21. I'll give it a go when ready for download 🙂 ljones
  22. I am trying to get the ARM performance assessment setup working (I'm trying to get Mali profiling for OpenCL code) on the Rock 5B+, and I've hit a blocker. The main component to this is some kernel configuration (CONFIG_ARM_SPE_PMU) and a loadable module. Oddly, those work fine in a custom kernel build. What I am hitting appears to be some missing interrupt setup that renders all those components inert. (It has to be a custom build to get CONFIG_ARM_SPE_PMU set. The issue is that even with the kernel configured and the module loaded, the SPE component remains inactive. ARM has its own system report tool which analyzes a setup, and that tool is reporting an issue: And indeed, nothing seems to show in cat /proc/interrupts. The man page for the module suggests this is the issue: It says: KPTI is definitely disabled and the SPE PMU loads (it's in lsmod) but it still doesn’t show in /sys/bus/event_source/devices/. Nothing relevant seemed to show in dmesg either. Frankly, I have no idea where to look for the SPE interrupt, or how to set it up. If anybody has any pointers or suggestions, I'd be extremely grateful.
  23. The TV box is equipped with an AP 6330 WiFi module. The Ethernet RTL module is 8911F.
  24. In case someone finds this useful, I found a way to change the display mode from NTSC (default) to PAL NTSC to PAL: xrandr --output Composite-1 --set "TV mode" PAL xrandr --output Composite-1 --mode 720x576i PAL to NTSC: xrandr --output Composite-1 --set "TV mode" NTSC xrandr --output Composite-1 --mode 720x480i I thought I would have to recompile the whole kernel because the patch isn't working properly but these two commands did the trick. I don't know how to make this permanent but it works in the terminal.
  25. @Ducdanh Nguyen Your board is using a HiSilicon Hi3798MV310. I have no experience with this SoC. The kernel sources for this SoC are too old. You are better off finding another cheap box to run Armbian.
  26. @KV1 I've fixed the build issue above: https://github.com/MarvellEmbeddedProcessors/A3700-utils-marvell/pull/36. I don't think anyone at Marvell pays attention to this old repo anymore so I don't expect it will actually be merged.
  27. Yes it looks like but with reboot on Ornage Pi zero back. After fixing the problem with kernel 6.12.xx https://github.com/armbian/build/issues/8197 now when we use kernel like 6.18.24 we can not reboot OZPI v1. When we run 'reboot' it is rather to power off so it looks like it is a problem with Crust https://github.com/armbian/build/pull/8503 it wille nice to fix this problem with reboot in kernel 6.18.x like was fixed in 6.12.x I know that the Orange Pi Zero platform is on community support, but maybe there will be a volunteer who will fix this problem. but extraargs=reboot=watchdog help solve problem
  28. Thank you for your kind words. For RK3229, I thought it's supported by mainline kernel and you can easily install using method provided by Jock?
