Hello fellow Linux gurus, Seeking for some assistance on this. I have NIC1 on 192.168.100.1/24 network with gateway set as 192.168.100.254 < this cant be changed. with a few PC’s connected to this. And NIC2 on 10.10.10.1/24 with a few devices on this. I want to be able to ping from PC1 connected to NIC1 on 192.168.100.100/24 to devices connected to NIC2 on 10.10.10.100/24 Could someone advise on the route settings I need to configure to make this work please ?
I was able to find a UART module to read out the boot. See the file attached of the full log I was able to capture. It seems to fail on this part: Starting kernel ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. done. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=0a0755af-1936-4167-9d26-9ca9a87a9103 does not exist. Dropping to a shell! U-Boot SPL 2025.10-rc3-armbian-2025.txt
For this board https://www.olimex.com/Products/SOM/NXP-iMX8/iMX8MP-SOM-4GB-IND/open-source-hardware It looks like Olimex have forked Armbian-build and done the board bringup: https://github.com/OLIMEX/imx8mp-build/commit/a3cb5ad2710cd3edf6a4c6c067b049af48b03fa5#diff-1b53368896f4902ddbb5db1fa206835ccbb04445cd8bcaa5fef353655794665a How could I bring that code back into the main https://github.com/armbian/build/tree/main I think I need to rebase the Olimex fork back to the main Armbian Repo? Or should I fork the Armbian repo and then re-apply the Olimex changes to the fork?
Modified based on nanopi-r76s.dts, both wireless and Bluetooth networks are working properly. There is no 3.5 interface fiber optic interface audio in DTS, and the standard infrared remote control cannot be used 4k hardware acceleration mpv kodi is normal Compile-configuration.zip -
Terrific! You're welcome!
@Rodrigo Campos@Nick A This guy seems to have created a u-boot that can get 4gb ram for M98-8K. https://github.com/nitrolack/M98-8K-Linux/blob/main/U-Boot Screen 20-03-2024
For anyone interested in solving this temporarily, doing the following steps worked for me: sudo systemctl edit systemd-networkd ### Editing /etc/systemd/system/systemd-networkd.service.d/override.conf ### Anything between here and the comment below will become the new contents of the file [Service] ExecStartPre=/bin/sleep 5 ### Lines below this comment will be discarded sudo systemctl daemon-reexec sudo reboot
John Taylor replied to fedes_gl's topic in Rockchip CPU Boxes
Guys, please do keep us all updated on the rk3528. I was just about to buy a job lot of boards for a grid computing project when I found it's not supported yet. I found that my old TV rk32xx box was well supported, so am prepared to wait. -
@snow try the transpeed image https://github.com/NickAlilovic/build/releases/tag/20250306
Thanks for the reply. In the end I soved it by following also a few steps from over here. I don't know exactly what did the trick, but actually I assume it was pure coincidence: my ethernet device is actually called en0, not eth0. During my first run through this tutorial I wasn't aware of that. I think I simply forgot to change this bit in my recent try and luckily got it working that way. About the systemd-cryptsetup: I don't know if I understand correctly, but doesn't this do some of the steps automatically which we set up manually? If so, maybe it should be adopted to this tutorial in the future …
You could try to write the bootloader again to the SD-card, it seems like it's mixed up. Old with new. not sure if the names are exactly like this but something like this: cd /usr/lib/linux-u-boot-vendor-orangepi-5 sudo dd if=u-boot-rockchip.bin of=/dev/sdx seek=64 conv=fsync sudo sync Or is ls -l /boot to see if the symlinks are correct. The correct dtb in armbianEnv.txt? The correct dtb for your current kernel version?
There are three ways to do this. The first simplest is to assemble a binary debian package using the Armbiyan assembly system and then convert it to a rpm package directly in a running OpenSuse OS. The second way is more complicated but it is more correct. You can take patches directly from the build system and apply them to OpenSuse kernel sources in the sequence in which the build system does this while running. Next, build the kernel package using rpmbuild. The third way is the same as the second but use OBS. This will allow you to have your own repository of signed packages and install them using zypper. You can find like-minded people anywhere on our planet, including this place. Hope this helps you.
HC4 PWM Fan Control Not Working - Need Guidance to Contribute a Fix
Georges Holland replied to Adrienne's topic in Beginners
Hey, I think I'm impacted by the same issue. I've replaced the original fan of the HC4 with a Noctua NF-A4x10 5V PWM earlier this year. It was working as expected, but since couple weeks the fan is at 100% speed continuously, which is loud. It sounds like it's a software upgrade that broke the PWM control, but no idea which one. I've done part of the same testing you mentioned but didn't managed to find a fix neither. I'm probably even more beginner than you, so I don't think I can help much unfortunately. How can we get more eyes on this issue? Did you post on Odroid Forum? -
OK, so I installed the latest Debian/Trixie + Cinnamon + vendor kernel available and audio is working. The name of the cards and mixers are different though: speaker-test worked both by specifying the mixer (... -D plughw:CARD=rockchiphdmi0,DEV=0) or through PulseAudio's ALSA emulation after setting the default sink to the rockchiphdmi0 card. The list of audio cards is different in the vendor kernel than what's available OOB with the edge kernel, so I'm not sure if the configuration is comparable. But the audio port/cable combo seems to be fine so there's that..
Yes, exactly.
support request: NanoPi-R76S
SuperKali replied to Dantes's topic in Framework and userspace feature requests
@Dantes Board is now supported, i advice you to wait next nightly release for fix some issue on cpufreq driver. If experiencing some issue please report on https://forum.armbian.com/forum/85-rockchip/ -
@Ducdanh Nguyen, can you contact seller of your tv box and ask if they can provide firmware (or "firmware update") for it? - Last week
https://fi.mirror.armbian.de/apt/pool/noble-utils/b/base-files/ They are in. Perhaps need some time for repo to get in sync.
robertoj replied to Stefal's topic in Raspberry Pi
Building a rolling release is more than just showing that in the MOTD. If you do "sudo apt upgrade" in an OS image you just built, you probably will have zero or one packages to upgrade. If you start with an image built a long time ago, or with packages defined a long time ago, then "sudo apt upgrade" would take a long time. -
I have the same debian as you: 5.1.4-xxx-v4l2request, installed over Debian Bookworm, with Linux 6.15 (OS built by myself). When I tried the ffmpeg-7.x.x-v4l2request for Trixie, I could not get hardware acceleration. -
Building Custom Armbian FirmWare for BananaPi M2 Berry
Prana Cale replied to Calvin Ronksley's topic in Beginners
Banana Pi M2 Berry – My Advice This board is a pain. It can’t boot from SSD. An SSD can hit ~200 MB/s, but you’ll need a strong 5 V power supply – especially at startup it often needs 3 A or more. If it refuses to boot (happened to me a lot), the cause was almost always a weak PSU. Other issues: the V40 SoC has almost no proper support and was never optimized. That means no real 3D acceleration – if it works at all, it’s unstable. Sound output often doesn’t work, HDMI audio basically never worked for me. Wi-Fi usually works, but only 2.4 GHz and WPA2 max. If you want more, you’ll need a compatible USB stick – but even then you’re limited to ~15 MB/s because it’s just USB 2.0. If you want >100 MB/s, you’ll need to use the LAN port and write to SSD. Forget doing that on the SD card. To be honest, almost nothing that came out after 2020 runs well as an OS on this thing. The official ISOs are here: 👉 https://wiki.banana-pi.org/Banana_Pi_BPI-M2_Berry You can test them if you like – they all run “meh” at best. As I said, 3D acceleration is rare, and when it exists it’s terrible. Another option to test: 👉 https://docs.banana-pi.org/en/BPI-M2_Berry/BananaPi_BPI-M2_Berry For me, the best (and really the only sensible) choice right now: 👉 https://sd-card-images.johang.se/boards/banana_pi_m2_berry.html But it’s pure/light – console only. You have to install everything else yourself. If you’ve ever managed a root server, you know the path: tmux/screen for multi-window SSH, sudo apt install apache2 -y, MariaDB, mail server, SSL certificates (yes, free ones), dynamic DNS, Pi-hole, cronjobs, and so on. Everything works, but you’ll need patience and some hand-holding (AI copilots can help). If you don’t have time for all that: get something better. Realistically, all you can use this board for today is as a shell server. Nothing else works properly. Honestly, even an old smartphone is a thousand times better. That’s why the M2 Berry was already dirt-cheap when I bought it in 2017 (€18 😂💩). Bottom line: The only sensible use is as a shell server. For anything else it’s useless – the drivers are crap, the V40 has almost no support. An old laptop or smartphone will serve you better (and it will run latest linux and 3d accel..) and by the way SPI or something like that can be also used over special boards/esp2066/esp32 and more ... And Banana Pi M2 Berry as an emulator? Forget about it ... PS: To write proper image files on Windows, I use Rufus or PowerISO (on Windows 11, UAC probably needs to be turned off). -
maka replied to FucusMeDeep's topic in Rockchip CPU Boxes
It is shown on internet how to get maskrom, serIal, and more. Also there is a clue that this box should start with firefly dtb but not stated exactly. Things are different from 1997 now and getting this working without experience is very difficult. With kernel 4.4 you could try with android dtb.
