2 captains on the same ship is my first note. Then there is fake-hwclock and maybe an RTC onchip/silicon and/or your own or PCB vendor added RTC module like DS3231. And the battery can be almost empty. Early Debian Trixie had a bug with fake hwclock script, I already removed it years ago on SBCs where I added DS3231, but if you haven't there is the sort of 3rd captain. RPi/Raspbian users had that issue.
keep pushing, this device is not brickable, you can make your trip worry-free - Today
I think it still makes sense. And in the off chance that you DO find you have some time leftover, it's also nice to tinker and hobby about with. Mine is still running Buster and has not missed a beat since I got the thing - besides some issues with the SATA connector on the top drive and the inability to upgrade RAM. Groetjes,
Can anyone tell me if it's possible to install renegade firmware on a Rasperry Pi build for example? Libre used to host a script for a tool that achieved this but it hasn't been updated since Buster TIA
Hello, I am using an X96 Air (S905X3) with Armbian (6.1.127-ophub) and I can see the hardware decoder working: v4l2-ctl --list-devices Amlogic Video Decoder (platform:meson-vdec): /dev/video0 However, the hardware encoder (VENC) does not appear: ls /dev/video* /dev/video0 ls /dev/amvenc* ls: cannot access '/dev/amvenc*': No such file or directory I want to use ffmpeg with hardware encoding (h264_v4l2m2m) for real-time RTMP streaming, but without the encoder device, it is not possible. Could you please explain: Does this kernel support VENC on S905X3 at all? If not, what changes are required to enable hardware encoder in the kernel? Is there any instructions or topics ? Any guidance or examples would be very helpful. Thank you!
What you need to understand is that whatever money you paid, you paid for the hardware not for software support. So, the hardware vendor does not give you software support. And we are just a bunch of enthusiasts trying to keep our own boards alive. I am sure that you can understand that your understandable nonetheless misguided rant does not necessarily help in making us more enthusiastic. Armbian provides you with some help to maintain your own board yourself. Whenever somebody does so and provides their work back to the community you are in luck and can freeload off of their work. Still doesn't give you the right to make demands and rant. In your case, you are in luck as there is a person donating their expertise and time. Let's see if @NicoD has anything to say about the issue with your board. Buy him a coffee on Paypal or Patreon for the time he already donated to keep YOUR board alive while getting 0 cents from you so far?
try and tell us
Because they sell you the hardware only. Their software support is very poorly made since for the price they cannot afford proper software support and - even more important - maintenance. They leave this burden to - mostly unpaid - random developers across the world like us. At least I'd go for a device with Standard Support which the Ultra and Max hasn't: https://www.armbian.com/download/?device_support=Standard support For the raspberry you would need additional hardware (an AI kit I guess). No clue though about how they both perform in comparsion. For RK3588 you have two choices for now: The rockchip bsp implementation and https://github.com/rockchip-linux/rknn-toolkit2. Or using 6.18 kernel using the reverse engineered Rocket driver and latest bleeding edge mesa to get npu access. I personally did not play with either of these options and have no intention to do so for the moment.
I'm working on a project that utilises AI, GPS, Bluetooth... and i can't decide whether i should choose OPi or RPi. I've been researching for the past couple of days and I'm amazed at what the OPi can do, it's crazy for it's price. But my concern is how little support and community there is out there, idk if it's worth the risk. So if any one worked with it can you please tell me what kind of difficulties have you faced and how similar is it to working with the raspberry?
@Nick A this is updated patch for x98h that enables wifi after warm reboot. 2001-arm64-dts-allwinner-h618-add-x98h.patch
Armbian 25.8.1 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + wine-10.15-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.15) + DXVK-stripped v2.7.1 ~20fps@720p (low settings) Skyrim SE -
I have a working img that boots fine from sd card. However the dtb is not perfectly working. Below are dts from android and linux (partial working). I hope that someone can help me with rewriting device tree source for it. Thank you! rk3399-emb3531.dts.txtrk3399-emb3531-android.dts.txt
Armbian current: It seems that the N2+ is [i]immune[/i] to Chrony and systemd-timesyncd. The only way I can set the date/time is manually through date -s. # systemctl status systemd-timesyncd ● systemd-timesyncd.service - Network Time Synchronization Loaded: loaded (/usr/lib/systemd/system/systemd-timesyncd.service; enabled; preset: enabled) Active: active (running) since Mon 2025-11-24 13:06:59 PST; 31min ago Invocation: 50da85c1116348dbbd83cca270da6ff8 Docs: man:systemd-timesyncd.service(8) Main PID: 1185 (systemd-timesyn) Status: "Idle." Tasks: 2 (limit: 4227) Memory: 1.6M (peak: 2.3M) CPU: 79ms CGroup: /system.slice/systemd-timesyncd.service └─1185 /usr/lib/systemd/systemd-timesyncd Nov 24 13:06:59 lab systemd-timesyncd[1185]: System clock time advanced to recorded timestamp: Mon 2025-11-24 13:06:59 PST Nov 24 13:06:57 lab systemd-timesyncd[1185]: Network configuration changed, trying to establish connection. Nov 24 13:06:57 lab systemd-timesyncd[1185]: Network configuration changed, trying to establish connection. Nov 24 13:06:57 lab systemd-timesyncd[1185]: Network configuration changed, trying to establish connection. Nov 24 13:07:01 lab systemd-timesyncd[1185]: Network configuration changed, trying to establish connection. Nov 24 13:07:11 lab systemd-timesyncd[1185]: Timed out waiting for reply from 10.2.1.10:123 (10.2.1.10). No, the network configuration has na-ha-hot, changed, Spastic. I see via tcpdump, the request going out 123/udp and the response, coming back. The information arrives at the destination. But it hits a hard rock head and disintegrates. Of course if it can't set the system clock, there's no sense trying to make it set the RTC. How is this possible in the 21st Century? Does time, no longer matter to Gen Z? Is this the precursor to the Apocalypse? Should I convert to religion and start praying?
If you are using the radxa-pkg github "which is the most up-to-date" know that its hardcoded to point to specific firmware. To get around this you need to create a file: This example is for an SDIO variant using the radxa dkms package cat > /etc/modprobe.d/aic8800-wireless.conf <<- EOT options aic8800_fdrv_sdio aicwf_dbg_level=0 custregd=0 ps_on=0 options aic8800_bsp_sdio aic_fw_path=/lib/firmware/aic8800_fw/SDIO/aic8800 EOT Also note that the AIC8800 firmware located in armbian-firmware is kind of old and probs not compat with the radxa builds.
Scroll back and read all my posts from April 11 onwards (page 17). On Radxa's github there are Wifi/BT drivers for AIC8800. They are at version 4 now : https://github.com/radxa-pkg/aic8800/releases/tag/4.0%2Bgit20250410.b99ca8b6-3 Also to fix BT : sudo crontab -e then add the line : @reboot sudo hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep then reboot the H96. -
We are slowly releasing v25.11 images and here I did some mess-up, fixed now. We don't offer Bookworm anymore, so Trixie it is. If you need to Bookworm for some reason, you can build on your own or use the one from archive: http://archive.armbian.com/ Attached torrent will download super fast. Armbian_25.11.1_Helios64_trixie_current_6.12.58_minimal.img.xz.torrent
Trying to download new images off the Helios64 page but every link seems to lead nowhere: This armbian.lv.auroradev.org page can’t be found No webpage was found for the web address: https://armbian.lv.auroradev.org/dl/helios64/archive/Armbian_25.5.1_Helios64_bookworm_current_6.12.28_minimal.img.xz HTTP ERROR 404 Is there another place to get these?
alex001gg1 replied to fensoft's topic in Rockchip CPU Boxes
Will it work on the H96 max RK3528 4gb ram 64gb rom? -
Im trying to flash armbian into the eMMC but its not detected, only the SD card. What should i do? Useful info: CPU/Chip/Idk: sun8iw7p1 PCB Model(?): H3 Q44 V4.0 Uname -a: Linux orangepipcplus 6.12.58-current-sunxi #1 SMP Thu Nov 13 20:34:41 UTC 2025 armv7l GNU/Linux dmesg | grep -i mmc [ 0.000000] Kernel command line: root=UUID=cf60c629-17b3-4fb8-91bb-24bd021f8c6b rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=def8ba6d-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory [ 0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=def8ba6d-01 ubootsource=mmc sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory", will be passed to user space. [ 4.995824] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 5.019105] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB [ 5.031030] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB [ 5.048053] mmc2: Failed to initialize a non-removable card [ 5.063249] mmc0: host does not support reading read-only switch, assuming write-enable [ 5.067129] mmc0: new high speed SDXC card at address aaaa [ 5.071189] mmcblk0: mmc0:aaaa SC64G 59.5 GiB [ 5.080563] mmcblk0: p1 [ 5.316321] ubootsource=mmc [ 7.603641] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq [ 7.635175] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB [ 7.687081] mmc1: new high speed SDIO card at address 0001 [ 8.364751] EXT4-fs (mmcblk0p1): mounted filesystem cf60c629-17b3-4fb8-91bb-24bd021f8c6b ro with writeback data mode. Quota mode: none. [ 14.091111] EXT4-fs (mmcblk0p1): re-mounted cf60c629-17b3-4fb8-91bb-24bd021f8c6b r/w. dmesg | grep -i mmc2 [ 5.048053] mmc2: Failed to initialize a non-removable card I also extracted a DTB file and DTS file from the android of the TV box, if that is useful (I used AI for that, and dont really know if they are useful) Thanks. dts.txt
I found this thread https://forum.armbian.com/topic/47929-banana-pi-bpi-m2-ultra-with-armbian-stops-load-after-scanning-for-btrfs-filesystems/
The Wi-Fi isn't working. I've been trying to get it working for a week now. My hardware is a board from a TV set-top box based on the Amlogic S905X. I have six of them. Armbian OS v26.2, kernel 6.12.59-current-meson64 There are 6 adapters: noname aic8800 ax900 bt5.4 usb (Two types. Some are detected slightly differently by the system, but I want to figure out the first type first (on the left in the photo)) Photo of adapters: https://disk.yandex.ru/i/x37stQnEgEW52gра As far as I can tell, the manufacturer's website: https://www.fenvi.com/index.php/drive.html?id=1&page=2 What I've tried: https://resource.tp-link.com.cn/pc/docCenter/showDocproductId=3343&type=DRIVER&id=1744265707665927 https://www.tendacn.com/ru/material/show/105769 https://www.lulian.cn/download/135.html https://github.com/Wolfdv1/aic8800/ https://github.com/radxapkg/aic8800 https://github.com/geniuskidkanyi/aic8800 https://github.com/nbfalcon/aic8800 https://github.com/shenmintao/aic8800d80 In the related thread https://www.linux.org.ru/forum/linux-hardware/18109581?cid=18151734 , they suggested installing: https://github.com/shenmintao/aic8800d80 , but that didn't help me. What helped: 1) I tried following the instructions from https://linux.brostrend.com/ After that, the adapter worked once, but after a reboot, it didn't work again. I couldn't try again on a clean system. 2) On a clean system, the description from the first post helped once: https://forums.linuxmint.com/viewtopic.php?t=437357 ``` sudo dkms remove aic8800/1.0.8 –all sudo dpkg –remove –force-all aic8800-dkms sudo dpkg –remove –force-all aic8800-dkms sudo rm -rf /var/lib/dkms/aic8800 ``` then installed the deb packages from https://github.com/radxa-pkg/aic8800/releases/tag/4.0%2Bgit20250410.b99ca8b6-3 ``` sudo dpkg -i aic8800-firmware_4.0+git20250410.b99ca8b6-3_all.deb sudo dpkg -i aic8800-usb-dkms_4.0+git20250410.b99ca8b6-3_all.deb ``` But after two reboots, for some reason, it crashed and I can't retry. I also disable the storage on the Wi-Fi adapter: according to the instructions at https://linux.brostrend.com/advanced/usb_modeswitch/, that is, ``` sudo apt install usb-modeswitch lsusb | grep -E '(0bda|368b|a69c):(8812|b812|c811|b832|c832|1a2b|88df|8d80|8d83|5721|5723)' sudo /usr/sbin/usb_modeswitch -KQ -v a69c -p 5721 ``` When running the lsusb command, the output is: ``` Bus 001 Device 004: ID 368b:8d81 AICSemi AIC 8800D80 ``` I also tried this one because the description says it supports my adapter. They promise support for 368b:* https://github.com/xProbe/aic8800d80-wifi-driver But there are a lot of mistakes there: '''/home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:259:5: warning: no previous prototype for ‘aic_crc32’ [-Wmissing-prototypes] 259 | u32 aic_crc32(u8 p, u32 len, u32 crc) | ^~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c: In function ‘rwnx_plat_flash_bin_upload_android’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:760:15: warning: conversion from ‘long unsigned int’ to ‘u32’ {aka ‘unsigned int’} changes value from ‘18446744073709551615’ to ‘4294967295’ [-Woverflow] 760 | u32 crc = ~0UL; | ^ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c: At top level: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:900:6: warning: no previous prototype for ‘get_fw_path’ [-Wmissing-prototypes] 900 | void get_fw_path(char fw_path){ | ^~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:908:6: warning: no previous prototype for ‘set_testmode’ [-Wmissing-prototypes] 908 | void set_testmode(int val){ | ^~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:912:5: warning: no previous prototype for ‘get_testmode’ [-Wmissing-prototypes] 912 | int get_testmode(void){ | ^~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:916:5: warning: no previous prototype for ‘get_hardware_info’ [-Wmissing-prototypes] 916 | int get_hardware_info(void){ | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:921:5: warning: no previous prototype for ‘get_adap_test’ [-Wmissing-prototypes] 921 | int get_adap_test(void){ | ^~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:925:5: warning: no previous prototype for ‘get_flash_bin_size’ [-Wmissing-prototypes] 925 | int get_flash_bin_size(void) | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:930:5: warning: no previous prototype for ‘get_flash_bin_crc’ [-Wmissing-prototypes] 930 | u32 get_flash_bin_crc(void) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:949:6: warning: no previous prototype for ‘get_userconfig_xtal_cap’ [-Wmissing-prototypes] 949 | void get_userconfig_xtal_cap(xtal_cap_conf_t *xtal_cap) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:962:6: warning: no previous prototype for ‘get_userconfig_txpwr_idx’ [-Wmissing-prototypes] 962 | void get_userconfig_txpwr_idx(txpwr_idx_conf_t *txpwr_idx){ | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:989:6: warning: no previous prototype for ‘get_userconfig_txpwr_ofst’ [-Wmissing-prototypes] 989 | void get_userconfig_txpwr_ofst(txpwr_ofst_conf_t *txpwr_ofst){ | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:1012:6: warning: no previous prototype for ‘rwnx_plat_userconfig_set_value’ [-Wmissing-prototypes] 1012 | void rwnx_plat_userconfig_set_value(char *command, char *value){ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth.c:1060:6: warning: no previous prototype for ‘rwnx_plat_userconfig_parsing’ [-Wmissing-prototypes] 1060 | void rwnx_plat_userconfig_parsing(char *buffer, int size){ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_usb.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:174:18: warning: no previous prototype for ‘rwnx_cmd_malloc’ [-Wmissing-prototypes] 174 | struct rwnx_cmd *rwnx_cmd_malloc(void){ | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:203:6: warning: no previous prototype for ‘rwnx_cmd_free’ [-Wmissing-prototypes] 203 | void rwnx_cmd_free(struct rwnx_cmd *cmd){ | ^~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:213:5: warning: no previous prototype for ‘rwnx_init_cmd_array’ [-Wmissing-prototypes] 213 | int rwnx_init_cmd_array(void){ | ^~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.c:228:6: warning: no previous prototype for ‘rwnx_free_cmd_array’ [-Wmissing-prototypes] 228 | void rwnx_free_cmd_array(void){ | ^~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_rx.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_txrxif.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_usb.c:1375:5: warning: no previous prototype for ‘aicfw_download_fw_8800’ [-Wmissing-prototypes] 1375 | int aicfw_download_fw_8800(struct aic_usb_dev *usb_dev){ | ^~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_usb.c:1650:5: warning: no previous prototype for ‘aicfw_download_fw’ [-Wmissing-prototypes] 1650 | int aicfw_download_fw(struct aic_usb_dev *usb_dev) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_rx.c:1655:6: warning: no previous prototype for ‘rwnx_rx_handle_msg’ [-Wmissing-prototypes] 1655 | void rwnx_rx_handle_msg(struct rwnx_hw *rwnx_hw, struct ipc_e2a_msg *msg) | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_rx.c:1667:6: warning: no previous prototype for ‘rwnx_rx_handle_print’ [-Wmissing-prototypes] 1667 | void rwnx_rx_handle_print(struct rwnx_hw *rwnx_hw, u8 *msg, u32 len) | ^~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_utils.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicbluetooth_cmds.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_cmds.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_irqs.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_utils.c:23:5: warning: no previous prototype for ‘rwnx_init_aic’ [-Wmissing-prototypes] 23 | int rwnx_init_aic(struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_cfgfile.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_cmds.c:339:6: warning: no previous prototype for ‘cmd_mgr_task_process’ [-Wmissing-prototypes] 339 | void cmd_mgr_task_process(struct work_struct *work) | ^~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.c: In function ‘aicfw_download_fw_8800d80’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.c:375:31: warning: unused variable ‘patch_info’ [-Wunused-variable] 375 | struct aicbt_patch_info_t patch_info = { | ^~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.c:374:31: warning: unused variable ‘head’ [-Wunused-variable] 374 | struct aicbt_patch_table *head = NULL; | ^~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.c: At top level: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80.c:340:12: warning: ‘aicbt_ext_patch_data_load’ defined but not used [-Wunused-function] 340 | static int aicbt_ext_patch_data_load(struct aic_usb_dev *usb_dev, struct aicbt_patch_info_t *patch_info) | ^~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_compat_8800d80x2.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_strs.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_irqs.c:21:13: warning: no previous prototype for ‘rwnx_irq_hdlr’ [-Wmissing-prototypes] 21 | irqreturn_t rwnx_irq_hdlr(int irq, void *dev_id) | ^~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_irqs.c:34:6: warning: no previous prototype for ‘rwnx_task’ [-Wmissing-prototypes] 34 | void rwnx_task(unsigned long data) | ^~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_tx.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/md5.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_txq.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_rx_prealloc.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:344:6: warning: no previous prototype for ‘rwnx_rx_data_skb_resend’ [-Wmissing-prototypes] 344 | void rwnx_rx_data_skb_resend(struct rwnx_hw *rwnx_hw, struct rwnx_vif *rwnx_vif, struct sk_buff *skb) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1533:5: warning: no previous prototype for ‘reord_flush_tid’ [-Wmissing-prototypes] 1533 | int reord_flush_tid(struct aicwf_rx_priv *rx_priv, struct sk_buff *skb, u8 tid) | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1793:6: warning: no previous prototype for ‘reord_rxframes_process’ [-Wmissing-prototypes] 1793 | bool reord_rxframes_process(struct aicwf_rx_priv *rx_priv, struct reord_ctrl *preorder_ctrl, int bforced) | ^~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1829:6: warning: no previous prototype for ‘reord_rxframes_ind’ [-Wmissing-prototypes] 1829 | void reord_rxframes_ind(struct aicwf_rx_priv *rx_priv, | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1915:5: warning: no previous prototype for ‘reord_process_unit’ [-Wmissing-prototypes] 1915 | int reord_process_unit(struct recv_msdu *pframe, struct aicwf_rx_priv *rx_priv, struct sk_buff *skb, u16 seq_num, u8 tid, u8 forward, u8 is_amsdu) | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:2115:6: warning: no previous prototype for ‘remove_sec_hdr_mgmt_frame’ [-Wmissing-prototypes] 2115 | void remove_sec_hdr_mgmt_frame(struct hw_rxhdr *hw_rxhdr,struct sk_buff *skb) | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:2196:6: warning: no previous prototype for ‘defrag_timeout_cb’ [-Wmissing-prototypes] 2196 | void defrag_timeout_cb(struct timer_list *t) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_tx.c:1244:5: warning: no previous prototype for ‘intf_tx’ [-Wmissing-prototypes] 1244 | int intf_tx(struct rwnx_hw *priv,struct msg_buf *msg) | ^~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.o In file included from ./include/linux/string.h:390, from ./include/linux/dma-mapping.h:7, from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:10: In function ‘fortify_memcpy_chk’, inlined from ‘rwnx_rx_add_rtap_hdr’ at /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1365:9, inlined from ‘rwnx_rx_monitor’ at /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:1405:5, inlined from ‘rwnx_rxdataind_aicwf’ at /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_rx.c:2335:13: ./include/linux/fortify-string.h:571:25: warning: call to ‘__write_overflow_field’ declared with attribute warning: detected write beyond size of field (1st parameter); maybe use struct_group()? [-Wattribute-warning] 571 | write_overflow_field(p_size_field, size); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_txq_prealloc.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_txq.c:154:6: warning: no previous prototype for ‘rwnx_txq_flush’ [-Wmissing-prototypes] 154 | void rwnx_txq_flush(struct rwnx_hw *rwnx_hw, struct rwnx_txq *txq) | ^~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_txq_prealloc.c:13:7: warning: no previous prototype for ‘aicwf_prealloc_txq_alloc’ [-Wmissing-prototypes] 13 | void aicwf_prealloc_txq_alloc(size_t size) | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aicwf_txq_prealloc.c:50:6: warning: no previous prototype for ‘aicwf_prealloc_txq_free’ [-Wmissing-prototypes] 50 | void aicwf_prealloc_txq_free(void) | ^~~~~~~~~~~~~~~~~~~~~~~ LD [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic_load_fw/aic_load_fw.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_mod_params.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_mesh.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:552:6: warning: no previous prototype for ‘rwnx_skb_align_8bytes’ [-Wmissing-prototypes] 552 | void rwnx_skb_align_8bytes(struct sk_buff skb){ | ^~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:619:6: warning: no previous prototype for ‘rwnx_frame_parser’ [-Wmissing-prototypes] 619 | void rwnx_frame_parser(char tag, char data, unsigned long len){ | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:1157:6: warning: no previous prototype for ‘rwnx_update_mesh_power_mode’ [-Wmissing-prototypes] 1157 | void rwnx_update_mesh_power_mode(struct rwnx_vif *vif) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~ In file included from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_defs.h:32, from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:25: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_compat.h:395:5: warning: no previous prototype for ‘rwnx_select_queue’ [-Wmissing-prototypes] 395 | rwnx_select_queue(dev, skb, sb_dev) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:1736:5: note: in expansion of macro ‘rwnx_select_queue’ 1736 | u16 rwnx_select_queue(struct net_device *dev, struct sk_buff *skb, | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:2029:6: warning: no previous prototype for ‘aicwf_p2p_alive_timeout’ [-Wmissing-prototypes] 2029 | void aicwf_p2p_alive_timeout(struct timer_list *t) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:2708:5: warning: no previous prototype for ‘rwnx_send_check_p2p’ [-Wmissing-prototypes] 2708 | int rwnx_send_check_p2p(struct cfg80211_scan_request *param){ | ^~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:3564:6: warning: no previous prototype for ‘apm_staloss_work_process’ [-Wmissing-prototypes] 3564 | void apm_staloss_work_process(struct work_struct *work) | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:3678:6: warning: no previous prototype for ‘apm_probe_sta_work_process’ [-Wmissing-prototypes] 3678 | void apm_probe_sta_work_process(struct work_struct *work) | ^~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:4216:5: warning: no previous prototype for ‘rwnx_cfg80211_set_monitor_channel’ [-Wmissing-prototypes] 4216 | int rwnx_cfg80211_set_monitor_channel(struct wiphy *wiphy, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:4228:5: warning: no previous prototype for ‘rwnx_cfg80211_probe_client’ [-Wmissing-prototypes] 4228 | int rwnx_cfg80211_probe_client(struct wiphy *wiphy, struct net_device *dev, | ^~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:4265:6: warning: no previous prototype for ‘rwnx_cfg80211_mgmt_frame_register’ [-Wmissing-prototypes] 4265 | void rwnx_cfg80211_mgmt_frame_register(struct wiphy *wiphy, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:4969:5: warning: no previous prototype for ‘rwnx_cfg80211_channel_switch’ [-Wmissing-prototypes] 4969 | int rwnx_cfg80211_channel_switch(struct wiphy *wiphy, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:5311:5: warning: no previous prototype for ‘rwnx_cfg80211_change_bss’ [-Wmissing-prototypes] 5311 | int rwnx_cfg80211_change_bss(struct wiphy *wiphy, struct net_device *dev, | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:8438:5: warning: no previous prototype for ‘rwnx_ic_system_init’ [-Wmissing-prototypes] 8438 | int rwnx_ic_system_init(struct rwnx_hw *rwnx_hw){ | ^~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:8477:5: warning: no previous prototype for ‘rwnx_ic_rf_init’ [-Wmissing-prototypes] 8477 | int rwnx_ic_rf_init(struct rwnx_hw *rwnx_hw){ | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_main.c:8516:6: warning: no previous prototype for ‘aic_ipc_setting’ [-Wmissing-prototypes] 8516 | void aic_ipc_setting(struct rwnx_vif rwnx_vif){ | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_mod_params.c:270:6: warning: no previous prototype for ‘rwnx_get_countrycode_channels’ [-Wmissing-prototypes] 270 | void rwnx_get_countrycode_channels(struct wiphy wiphy, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_pci.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:762:5: warning: no previous prototype for ‘rwnx_request_firmware_common’ [-Wmissing-prototypes] 762 | int rwnx_request_firmware_common(struct rwnx_hw rwnx_hw, u32 buffer, const char filename) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:773:6: warning: no previous prototype for ‘rwnx_release_firmware_common’ [-Wmissing-prototypes] 773 | void rwnx_release_firmware_common(u32 buffer) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:790:5: warning: no previous prototype for ‘rwnx_plat_bin_fw_upload_2’ [-Wmissing-prototypes] 790 | int rwnx_plat_bin_fw_upload_2(struct rwnx_hw *rwnx_hw, u32 fw_addr, | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:1959:5: warning: no previous prototype for ‘rwnx_atoi2’ [-Wmissing-prototypes] 1959 | int rwnx_atoi2(char *value, int c_len) | ^~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:1986:5: warning: no previous prototype for ‘rwnx_atoi’ [-Wmissing-prototypes] 1986 | int rwnx_atoi(char *value) | ^~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:2334:6: warning: no previous prototype for ‘get_userconfig_xtal_cap’ [-Wmissing-prototypes] 2334 | void get_userconfig_xtal_cap(xtal_cap_conf_t *xtal_cap) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:2343:6: warning: no previous prototype for ‘rwnx_plat_nvram_set_value’ [-Wmissing-prototypes] 2343 | void rwnx_plat_nvram_set_value(char *command, char *value) | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:2649:6: warning: no previous prototype for ‘rwnx_plat_nvram_set_value_8800d80x2’ [-Wmissing-prototypes] 2649 | void rwnx_plat_nvram_set_value_8800d80x2(char *command, char *value) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:2872:6: warning: no previous prototype for ‘rwnx_plat_userconfig_parsing_8800d80x2’ [-Wmissing-prototypes] 2872 | void rwnx_plat_userconfig_parsing_8800d80x2(char *buffer, int size) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_dini.o In function ‘rwnx_plat_patch_load’, inlined from ‘rwnx_platform_on’ at /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:3563:11: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:1589:9: warning: ‘sprintf’ argument 3 overlaps destination object ‘aic_fw_path’ [-Wrestrict] 1589 | sprintf(aic_fw_path, «%s/%s», aic_fw_path, «aic8800DC»); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c: In function ‘rwnx_platform_on’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_platform.c:51:13: note: destination object referenced by ‘restrict’-qualified argument 1 was declared here 51 | extern char aic_fw_path[FW_PATH_MAX_LEN]; | ^~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_pci.c:85:5: warning: no previous prototype for ‘rwnx_pci_register_drv’ [-Wmissing-prototypes] 85 | int rwnx_pci_register_drv(void) | ^~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_pci.c:90:6: warning: no previous prototype for ‘rwnx_pci_unregister_drv’ [-Wmissing-prototypes] 90 | void rwnx_pci_unregister_drv(void) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_dini.c:105:5: warning: no previous prototype for ‘rwnx_cfpga_irq_enable’ [-Wmissing-prototypes] 105 | int rwnx_cfpga_irq_enable(struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_dini.c:129:5: warning: no previous prototype for ‘rwnx_cfpga_irq_disable’ [-Wmissing-prototypes] 129 | int rwnx_cfpga_irq_disable(struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_v7.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/ipc_host.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_tdls.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/regdb.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/md5.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_vendor.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_priv_cmd.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800dc.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_vendor.c:41:5: warning: no previous prototype for ‘aic_dev_start_mkeep_alive’ [-Wmissing-prototypes] 41 | int aic_dev_start_mkeep_alive(struct rwnx_hw *rwnx_hw, struct rwnx_vif *rwnx_vif, | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_vendor.c:69:5: warning: no previous prototype for ‘aic_dev_stop_mkeep_alive’ [-Wmissing-prototypes] 69 | int aic_dev_stop_mkeep_alive(struct rwnx_hw *rwnx_hw, struct rwnx_vif *rwnx_vif, u8 mkeep_alive_id) | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_vendor.c:1064:5: warning: no previous prototype for ‘aicwf_vendor_init’ [-Wmissing-prototypes] 1064 | int aicwf_vendor_init(struct wiphy *wiphy) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_priv_cmd.c:235:14: warning: no previous prototype for ‘command_strtoul’ [-Wmissing-prototypes] 235 | unsigned int command_strtoul(const char *cp, char **endp, unsigned int base) | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_priv_cmd.c:268:5: warning: no previous prototype for ‘str_starts’ [-Wmissing-prototypes] 268 | int str_starts(const char *str, const char *start) | ^~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_priv_cmd.c:1614:5: warning: no previous prototype for ‘handle_private_cmd’ [-Wmissing-prototypes] 1614 | int handle_private_cmd(struct net_device *net, char *command, u32 cmd_len) | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aic_priv_cmd.c:1730:6: warning: no previous prototype for ‘set_mon_chan’ [-Wmissing-prototypes] 1730 | void set_mon_chan(struct rwnx_vif *vif, char *parameter) | ^~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800dc.c:2637:5: warning: no previous prototype for ‘aicwf_patch_var_config_8800dc’ [-Wmissing-prototypes] 2637 | int aicwf_patch_var_config_8800dc(struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800dc.c:3585:5: warning: no previous prototype for ‘set_bbpll_config’ [-Wmissing-prototypes] 3585 | int set_bbpll_config(struct rwnx_hw *rwnx_hw){ | ^~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.c:19:5: warning: no previous prototype for ‘aicwf_set_rf_config_8800d80’ [-Wmissing-prototypes] 19 | int aicwf_set_rf_config_8800d80(struct rwnx_hw *rwnx_hw, struct mm_set_rf_calib_cfm *cfm) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.c:39:9: warning: no previous prototype for ‘rwnx_plat_userconfig_load_8800d80’ [-Wmissing-prototypes] 39 | int rwnx_plat_userconfig_load_8800d80(struct rwnx_hw *rwnx_hw){ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.c: In function ‘rwnx_plat_userconfig_load_8800d80’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.c:57:13: warning: ‘sprintf’ argument 3 overlaps destination object ‘aic_fw_path’ [-Wrestrict] 57 | sprintf(aic_fw_path, «%s/%s», aic_fw_path, «aic8800D80»); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80.c:11:13: note: destination object referenced by ‘restrict’-qualified argument 1 was declared here 11 | extern char aic_fw_path[200]; | ^~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_radar.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/usb_host.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.c:17:5: warning: no previous prototype for ‘aicwf_set_rf_config_8800d80x2’ [-Wmissing-prototypes] 17 | int aicwf_set_rf_config_8800d80x2(struct rwnx_hw *rwnx_hw, struct mm_set_rf_calib_cfm *cfm) | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.c:37:9: warning: no previous prototype for ‘rwnx_plat_userconfig_load_8800d80x2’ [-Wmissing-prototypes] 37 | int rwnx_plat_userconfig_load_8800d80x2(struct rwnx_hw *rwnx_hw){ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.c: In function ‘rwnx_plat_userconfig_load_8800d80x2’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.c:43:5: warning: ‘sprintf’ argument 3 overlaps destination object ‘aic_fw_path’ [-Wrestrict] 43 | sprintf(aic_fw_path, «%s/%s», aic_fw_path, «aic8800D80X2»); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_compat_8800d80x2.c:8:13: note: destination object referenced by ‘restrict’-qualified argument 1 was declared here 8 | extern char aic_fw_path[200]; | ^~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_txrxif.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_radar.c:904:22: warning: no previous prototype for ‘pri_detector_init’ [-Wmissing-prototypes] 904 | struct pri_detector *pri_detector_init(struct dfs_pattern_detector *dpd, | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_radar.c:1073:6: warning: no previous prototype for ‘print_radar_detect_info’ [-Wmissing-prototypes] 1073 | void print_radar_detect_info(struct pri_detector *pde, struct pri_sequence *ps) | ^~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:17:6: warning: no previous prototype for ‘intf_tcp_drop_msg’ [-Wmissing-prototypes] 17 | void intf_tcp_drop_msg(struct rwnx_hw *priv, | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:30:6: warning: no previous prototype for ‘tcp_ack_timeout’ [-Wmissing-prototypes] 30 | void tcp_ack_timeout(struct timer_list *t) | ^~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:123:5: warning: no previous prototype for ‘tcp_check_quick_ack’ [-Wmissing-prototypes] 123 | int tcp_check_quick_ack(unsigned char *buf, | ^~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:216:5: warning: no previous prototype for ‘tcp_check_ack’ [-Wmissing-prototypes] 216 | int tcp_check_ack(unsigned char *buf, | ^~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:260:5: warning: no previous prototype for ‘tcp_ack_match’ [-Wmissing-prototypes] 260 | int tcp_ack_match(struct tcp_ack_manage *ack_m, | ^~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:288:6: warning: no previous prototype for ‘tcp_ack_update’ [-Wmissing-prototypes] 288 | void tcp_ack_update(struct tcp_ack_manage *ack_m) | ^~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:313:5: warning: no previous prototype for ‘tcp_ack_alloc_index’ [-Wmissing-prototypes] 313 | int tcp_ack_alloc_index(struct tcp_ack_manage *ack_m) | ^~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:352:5: warning: no previous prototype for ‘tcp_ack_handle’ [-Wmissing-prototypes] 352 | int tcp_ack_handle(struct msg_buf *new_msgbuf, | ^~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_tcp_ack.c:447:5: warning: no previous prototype for ‘tcp_ack_handle_new’ [-Wmissing-prototypes] 447 | int tcp_ack_handle_new(struct msg_buf *new_msgbuf, | ^~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/usb_host.c:35:30: warning: no previous prototype for ‘aicwf_usb_host_txdesc_get’ [-Wmissing-prototypes] 35 | volatile struct txdesc_host *aicwf_usb_host_txdesc_get(struct usb_host_env_tag *env, const int queue_idx) | ^~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_usb.o CC [M] /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.o /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_txrxif.c:1300:17: warning: no previous prototype for ‘rxbuff_queue_penq’ [-Wmissing-prototypes] 1300 | struct rx_buff *rxbuff_queue_penq(struct rx_frame_queue *pq, struct rx_buff *p) | ^~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_usb.c:158:6: warning: no previous prototype for ‘rwnx_stop_sta_all_queues’ [-Wmissing-prototypes] 158 | void rwnx_stop_sta_all_queues(struct rwnx_sta *sta, struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_usb.c:168:6: warning: no previous prototype for ‘rwnx_wake_sta_all_queues’ [-Wmissing-prototypes] 168 | void rwnx_wake_sta_all_queues(struct rwnx_sta *sta, struct rwnx_hw *rwnx_hw) | ^~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c: In function ‘aicwf_get_iwe_stream_mac_addr’: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c:403:25: warning: the comparison will always evaluate as ‘true’ for the address of ‘bssid’ will never be NULL [-Waddress] 403 | if(scan_re->bss && &scan_re->bss->bssid[0]){ | ^~ In file included from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_defs.h:20, from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/rwnx_msg_tx.h:16, from /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c:10: ./include/net/cfg80211.h:2980:12: note: ‘bssid’ declared here 2980 | u8 bssid[ETH_ALEN]; | ^~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c: At top level: /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c:717:5: warning: no previous prototype for ‘aic_get_sec_ie’ [-Wmissing-prototypes] 717 | int aic_get_sec_ie(u8 *in_ie, uint in_len, u8 *rsn_ie, u16 *rsn_len, u8 *wpa_ie, u16 *wpa_len) | ^~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_usb.c:1964:6: warning: no previous prototype for ‘aicwf_usb_cancel_all_urbs’ [-Wmissing-prototypes] 1964 | void aicwf_usb_cancel_all_urbs(struct aic_usb_dev *usb_dev){ | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/igor/aic8800d80-wifi-driver/drivers/aic8800/aic8800_fdrv/aicwf_wext_linux.c:830:4: warning: no previous prototype for ‘aicwf_get_is_wps_ie’ [-Wmissing-prototypes] 830 | u8 aicwf_get_is_wps_ie(u8 *ie_ptr, uint *wps_ielen) | ^~~~~~~~~~~~~~~~~~~ '''
