Thanks @jock for keep legacy kernel still avaliable... This is the way I build it cd /opt git clone -b history-rk322x-family https://github.com/paolosabatino/armbian-build.git build cd build ./compile.sh docker-shell ./compile.sh EXPERT="yes"
Hello @primoitt , yes it has been deprecated. It wasn't developer anymore, now has been fully removed. You can find the latest iteration with the legacy kernel for rk322x family on this branch. After that, rk322x and rockchip familes have been merged and legacy kernels removed because old and unmaintained. The main reason to keep legacy was raw NAND support, but we at last we decided it does not worth the effort to keep it.
seems like a nice sbc i'm running all my local stuff on an old rk3328 tv box, it's been holding up all these years but i want to do a more advanced home setup with BMS as in building management system and rk3588 seems like the perfect candidate, that way the old sbc can just handle media center and shared storage
Odroid N2 with Armbian Bookworm; emmc boot fail
HansD replied to hjheins's topic in Odroid N2/N2+/HC4
The Armbian project will solve the problem in time, someday. Untill then I will use something else, no problem in my particular case. I'm not a technician who can talk firmware, install/partition- and bootprocesses. I cannot contribute, the analysis I give is the max I can contribute. I'm sorry, I just use stuff like Homeassistant. -
Hi all, I'm having issues with 32GB version of Orange Pi 5 Plus as well (kernel panic). It can be easily reproduced by running sudo memtester 30G After a few seconds it crashes. At the same time it works well on 16GB version of Orange Pi 5 Plus. I tried also installing Ubuntu 24.04 LTS and it works well.
Hi guys! Is the legacy kernel no more? git clone https://github.com/armbian/build cd build ./compile.sh docker-shell ./compile.sh BOARD=rk322x-box BRANCH=legacy RELEASE=focal BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_CONFIGURE=yes INSTALL_HEADERS=yes KERNEL_KEEP_CONFIG=yes [๐ฅ] error! [ Invalid BRANCH='legacy' for BOARD='rk322x-box'; please select a valid branch for this board, eg one of 'current,edge' ] [๐ฅ] Exiting with error 43 [ at /opt/build/lib/functions/logging/traps.sh:1
You are running out of stack space during rsync.
received this kernel panic today. 24.5.0 with the 6.6.30 kernel using the 75mV dtb reverting the dtb, to see if that makes it more stable. cpu settings are ENABLE=true MIN_SPEED=408000 MAX_SPEED=1800000 GOVERNOR=ondemand [73481.995035] Insufficient stack space to handle exception! [73481.995044] ESR: 0x000000009a000000 -- SP Alignment [73481.995050] FAR: 0x000000000000012b [73481.995052] Task stack: [0xffff80008abe0000..0xffff80008abe4000] [73481.995054] IRQ stack: [0xffff800081d40000..0xffff800081d44000] [73481.995056] Overflow stack: [0xffff0000f778a310..0xffff0000f778b310] [73481.995061] CPU: 5 PID: 40075 Comm: rsync Tainted: P C O 6.6.30-current-rockchip64 #1 [73481.995067] Hardware name: Helios64 (DT) [73481.995070] pstate: 800003c5 (Nzcv DAIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [73481.995075] pc : el1h_64_sync+0x0/0x68 [73481.995084] lr : dequeue_task_fair+0xa8/0x3e8 [73481.995095] sp : 000000000000012b [73481.995097] x29: ffff80008abe3650 x28: 0000000000000000 x27: 0000000000000009 [73481.995104] x26: ffff0000f779e540 x25: ffff00000078e980 x24: ffff0000f779e4c0 [73481.995109] x23: 0000000000000001 x22: ffff00000078e900 x21: 0000000000000001 [73481.995114] x20: ffff0000f779e540 x19: 0000000000000000 x18: 0000000000000000 [73481.995119] x17: 0000000000000000 x16: 0000000000000000 x15: 0000110e637753ac [73481.995123] x14: 0020f1c8fb93347c x13: 0000000000000001 x12: 0000000000000001 [73481.995127] x11: 0000000000000001 x10: 0000000000000137 x9 : 00000000000001e4 [73481.995132] x8 : ffff0000f779e5c0 x7 : 0000000000000005 x6 : 000000000000006b [73481.995137] x5 : ffff800076092000 x4 : ffff800081a4dc98 x3 : 00000000f779e4c0 [73481.995141] x2 : ffff0000f779e578 x1 : ffff8000817094c0 x0 : 000000000000006b [73481.995148] Kernel panic - not syncing: kernel stack overflow [73481.995151] CPU: 5 PID: 40075 Comm: rsync Tainted: P C O 6.6.30-current-rockchip64 #1 [73481.995155] Hardware name: Helios64 (DT) [73481.995156] Call trace: [73481.995159] dump_backtrace+0x94/0x114 [73481.995164] show_stack+0x18/0x24 [73481.995167] dump_stack_lvl+0x48/0x60 [73481.995175] dump_stack+0x18/0x24 [73481.995179] panic+0x324/0x38c [73481.995183] nmi_panic+0x8c/0x90 [73481.995186] panic_bad_stack+0x104/0x124 [73481.995189] handle_bad_stack+0x34/0xb8 [73481.995196] __bad_stack+0x78/0x7c [73481.995199] el1h_64_sync+0x0/0x68 [73481.995202] __schedule+0x518/0xb60 [73481.995205] schedule+0x5c/0xc4 [73481.995207] schedule_hrtimeout_range_clock+0xc8/0x1f8 [73481.995212] schedule_hrtimeout_range+0x14/0x20 [73481.995216] do_select+0x598/0x640 [73481.995223] core_sys_select+0x1e0/0x4b8 [73481.995226] __arm64_sys_pselect6+0x150/0x21c [73481.995231] invoke_syscall+0x48/0x118 [73481.995236] el0_svc_common.constprop.0+0x40/0xe8 [73481.995241] do_el0_svc+0x20/0x2c [73481.995246] el0_svc+0x40/0xf4 [73481.995250] el0t_64_sync_handler+0x13c/0x158 [73481.995255] el0t_64_sync+0x190/0x194 [73481.995259] SMP: stopping secondary CPUs [73481.995385] Kernel Offset: disabled [73481.995386] CPU features: 0x0,80000208,24020000,1000421b [73481.995389] Memory Limit: none [73482.017954] ---[ end Kernel panic - not syncing: kernel stack overflow ]---
I gonna use Banana Pi instead of Orange Pi in my phandomate. It's social project to improve our environment through recycling. Lets see video in telegram channel https://t.me/avto_yar . It can work without electronics, but people wanna have statistics, cash back, monitoring and other. I added microcomputer. I improve it. It's so cheap device.
First of all, thanks for this post! It helped me. Sorry to revive an old post but I followed the steps and read in the replies that a boot partition was not needed but I did not see a solution to NOT using the boot partition. The armbian installer does not copy the boot partition from the SD card so I manually copied the folder data and it am now booting off my NVME. instead of step 4: sudo mount /dev/nvme0n1p1 /mnt // Now copy the sd card boot contents to the nvme. (The boot partition on the SD needs to be mounted) sudo cp -R /boot /mnt Then continue to step 5
At present, when I check the status of the phy controller, it is unlocked. But I am very curious about the relationship between wdev 0x100000001 in wlan1 and wdev 0x1 in wlan0. Does this mean that wlan1 is simulated from wlan0? pi@orangepipcplus:~$ iw dev phy#1 Interface wlan1 ifindex 4 wdev 0x100000001 addr 12:81:64:17:13:3d type managed txpower 12.00 dBm phy#0 Interface wlan0 ifindex 3 wdev 0x1 addr 12:81:64:17:11:3d ssid R15-3437 type managed txpower 12.00 dBm pi@orangepipcplus:~$ rfkill ID TYPE DEVICE SOFT HARD 0 wlan phy0 unblocked unblocked 1 wlan phy1 unblocked unblocked pi@orangepipcplus:~$
Hi, I am not sure but in HARDWARE armbian-config when we set [*] w1-gpio (on for example OZPI v1 with ArmBian v23) is only set automatic loading modules during start up system? modprobe wire modprobe w1-gpio modprobe w1-therm I do this manually and I see exist path in system /sys/bus/w1/devices/ but we need know how to set number GPIO to use 1-Wire hardware, on Armbian v23 (Debian v11) it was added in /boot/armbianEnv.txt param_w1_pin=PA14 param_w1_pin_int_pullup=1 but how do this in Armbian v25 (based on Debian v12) so if I would like to connect my thermal sensor to GPIO 74 (PC10) I should be set in armbianEnv.txt ? param_w1_pin=PC10 param_w1_pin_int_pullup=1
usual user replied to hjheins's topic in Odroid N2/N2+/HC4
I guess with such an attitude you certainly can't motivate anyone to find an immediate solution to your problem. Maybe you'll be lucky and it will work with a future release, but until then all you can do is keep trying and waiting. You got what you paid for. The currency here is to contribute to the project (Armbian) and help with problem analysis. The project is community driven and you are a member of the community. -
@voapilro, I'd think for 1.5GB, we'd make do with that 1.5GB custom bootloader, I'd likely adopt your codes so that most who use that can benefit from it. As for pushing it to mainline, I'd think it is pre-mature, as that code applies to *all* H616/H618 devices and not simply Orange Pi Zero 3.
I'm not into bootmenu editing nor firmaware building. So I cannot and have not checked those suggestions. I just need a reliable host for Homeassistant. By the way: the card is OK: It does work allright with Ubuntu Bookworm It does work with Armbian when using the TF-card slot with the TF-emmc-adapter (but much slower). -
Helios64 - Armbian 23.08 Bookworm issues (solved)
magostinelli replied to ebin-dev's topic in Rockchip
In my case the new kernel runs fine! Now I'm trying your last suggestion, i wrote here the command, so any users can try: echo "ENABLE=true MIN_SPEED=600000 MAX_SPEED=1800000 GOVERNOR=ondemand" > /etc/default/cpufrequtils systemctl disable --now armbian-hardware-optimize.service vi /etc/rc.local and insert before exit 0: for i in $(awk -F":" "/xhci/ {print \$1}" < /proc/interrupts | sed 's/\ //g'); do echo 20 > /proc/irq/$i/smp_affinity done for i in $(awk -F":" "/ahci/ {print \$1}" < /proc/interrupts | sed 's/\ //g'); do echo 30 > /proc/irq/$i/smp_affinity done -
Does it make a difference if you drop in this firmware? -
Yes, I'have the same problem with my OdroidN2+ and 128GB emmc card. Bookworm variants don't boot at the second en consecutive restarts. Nothing found at mmc1, mmc2 not found and peculiar failed voltage test (-110?!). Ubuntu Bookworm minimal (and other variants) does boot at restarts, so I switched for the time being. -
Since nobody mentioned it. I don't know what desktop env that is, but I think using those prefixes is not connected to the packages you get for installing for example cifs-utils. I more think this has to do with fuse or something similar. If you provide a bit more info of your system, more help might be provided by users. I have never used any graphical env on any of my armbian installs so I simply have no idea what is on them. ๐ฎ It looks like gnome, so I think you can google using Ubuntu in your searches, and that might give you the solution of what you have to install. Never the less, you can always mount the share using `mount` in cli and they will become accessible that way.
So VY 73 and Grazie, de LZ4TU taaa ti ti taaa *Excuse me for the offtopic but could not resist, for those not knowing Morse code and are not HAMs each CW QSO finish with TU, on morse: _ .._ meaning Thank You! Good team here: @jock, @ilmich, @fabiobassa and so much great contributors, ofcourse the leading @Igor , Thanks again, wish you all good luck!
i perfectly understand, I also hate when an available piece of hardware cannot be used, but really lost a lot of time in wifi drivers and, especially realtek drivers, need constant care because they are overbloated software written by simians. When complied, any realtek driver is few megabytes large, while the average wifi driver is well below the 100kbytes. The device id you see in rk322x-config 024c:8723 is clearly declares that your chip is rtl8723as (for some other references: https://forum.libreelec.tv/thread/27091-no-wifi-at-mxq-pro-4k-5g/)
@suser your avatar is a smith cart about impedence, I suppose.. Italian HAM here This make me think that you have the right approach to problem : WHY IS NOT WORKING !!! And not the simple " ok it will work in othe manner" but " what hell is going now" This is the spirit that animated @jock @ilmich and myself when we approached to rk322x world Unfortunately lack of documentation = trial and errors and understand code and compilation !! And again unsuccess and again trial and errors. Even actually the evil nand driver is ONLY proprietary, even if jock and ilmich actively searching for months a workaround Welcome in the club ๐
