35 minutes ago, Igor said:
You mean also to remove Buster desktop from building?
No, I mean for the future. When focal is released, still leave Bionic for rockchip legacy desktop as an available download in the main page. Only for legacy desktop, not current
1 hour ago, jeanrhum said:
- buster image for pineh64-b (wlan0 visible, but not able to connect to my wifi network): http://ix.io/2bN0
thanks for testing.. did wifi working on the H64-b on previous kernels?
About 1 year ago, I reported that wifi works on kernel 5.0.5, but I didn't use this board recently:
On 4/3/2019 at 12:11 PM, jeanrhum said:
Compiled yesterday evening a dev (kernel 5.0.5) image for pineh64 and run it on my B model (writting this post with it). It works quite well (hdmi, wifi, eth, desktop).
I think I have made a test with a kernel 5.3, but I don't remember if wifi was working.
Can you try if this helps:
https://github.com/armbian/build/pull/1780/files
Creating a file /etc/NetworkManager/conf.d/10-override-wifi-random-mac-disable.conf with this content following by reboot or NM restart:
[connection]
wifi.mac-address-randomization=1
[device]
wifi.scan-rand-mac-address=no
Hi Igor,
The proposed fix doesn't work for me, but after googling I found a way to connect with wifi (https://bbs.archlinux.org/viewtopic.php?id=237619)
After removing the module and adding it with an additional parameter I was able to connect using nmtui and run apt update successfully.
The two commands I used was:
modprobe -rfv r8723bs
modprobe -v r8723bs ant_sel=1
After a reboot, I have to write again these commands to be able to connect again. During boot NetworkManager service failed to start and after log in, if the network seems associated, there is no ip for wlan0. Adding the ant_sel option to /etc/modprobe.d/r8723bs.conf does not change anything after a reboot. Only unloading and loading of the module is able to make wlan0 connect even if it is not always able to detect the wifi signal strength.
I'm installing DE to be able to easily post the dmesg output and test the stability of wifi during download (~10min).
Strange. I have no other ideas and no resources to dig in.
Half or non functional WiFi on not supported board is not a release showstopper. Will need to wait for the future.
Of course, I understand and agree. Here is the dmesg in the case it is useful to somebody:
[   50.222117] RTL8723BS: auth success, start assoc
[   51.352618] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[   52.200012] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   52.572034] RTL8723BS: start auth
[   52.576635] RTL8723BS: auth success, start assoc
[   52.582349] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   52.582366] RTL8723BS: assoc success
[   52.588943] RTL8723BS: send eapol packet
[   52.594660] RTL8723BS: send eapol packet
[   52.595253] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[   52.596271] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[   54.171329] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   54.415347] RTL8723BS: start auth
[   54.417144] RTL8723BS: auth success, start assoc
[   55.521502] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[   56.388959] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   56.668048] RTL8723BS: start auth
[   56.669787] RTL8723BS: auth success, start assoc
[   56.673377] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   56.673397] RTL8723BS: assoc success
[   56.683097] RTL8723BS: send eapol packet
[   56.690250] RTL8723BS: send eapol packet
[   56.690519] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[   56.691789] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[   58.261072] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   58.511182] RTL8723BS: start auth
[   58.512966] RTL8723BS: auth success, start assoc
[   59.608754] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[   60.488840] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   60.763930] RTL8723BS: start auth
[   60.766094] RTL8723BS: auth success, start assoc
[   60.769759] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   60.769780] RTL8723BS: assoc success
[   60.779774] RTL8723BS: send eapol packet
[   60.785236] RTL8723BS: send eapol packet
[   60.785520] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[   60.786241] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[   62.408820] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   62.607001] RTL8723BS: start auth
[   62.608631] RTL8723BS: auth success, start assoc
[   63.722278] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[   64.579691] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   64.859785] RTL8723BS: start auth
[   64.861870] RTL8723BS: auth success, start assoc
[   64.865626] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   64.865654] RTL8723BS: assoc success
[   66.877000] RTL8723BS: send eapol packet
[   66.882945] RTL8723BS: send eapol packet
[   66.884517] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   66.884842] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[   66.885465] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[   68.454145] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   68.750902] RTL8723BS: start auth
[   68.755746] RTL8723BS: auth success, start assoc
[   69.871314] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[   70.739218] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   71.003682] RTL8723BS: start auth
[   71.005691] RTL8723BS: auth success, start assoc
[   71.009711] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   71.009744] RTL8723BS: assoc success
[   71.020974] RTL8723BS: send eapol packet
[   71.035512] RTL8723BS: send eapol packet
[   71.036428] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   71.176754] RTL8723BS: set_stakey_hdl sta:dc:ef:09:e3:a1:8a not found
[   72.634212] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   73.051580] RTL8723BS: start auth
[   73.053438] RTL8723BS: auth success, start assoc
[   73.057093] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   73.057107] RTL8723BS: assoc success
[   73.065843] RTL8723BS: send eapol packet
[   73.071165] RTL8723BS: send eapol packet
[   73.071416] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[   73.073565] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[   74.644985] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   75.099600] RTL8723BS: start auth
[   75.101455] RTL8723BS: auth success, start assoc
[   76.151150] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[   77.198499] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   77.455524] RTL8723BS: start auth
[   77.762945] RTL8723BS: auth success, start assoc
[   77.766691] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   77.766720] RTL8723BS: assoc success
[   77.779786] RTL8723BS: send eapol packet
[   77.788137] RTL8723BS: send eapol packet
[   77.788488] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[   77.789572] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[   79.362140] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   79.707447] RTL8723BS: start auth
[   79.710253] RTL8723BS: auth success, start assoc
[   80.774481] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[   81.680444] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   82.063584] RTL8723BS: start auth
[   82.068406] RTL8723BS: auth success, start assoc
[   82.072231] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   82.072259] RTL8723BS: assoc success
[   82.080789] RTL8723BS: send eapol packet
[   82.089030] RTL8723BS: send eapol packet
[   82.089473] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[   82.091751] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[   83.661651] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   83.905701] RTL8723BS: start auth
[   83.907338] RTL8723BS: auth success, start assoc
[   84.972949] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[   85.885063] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   86.158484] RTL8723BS: start auth
[   86.160737] RTL8723BS: auth success, start assoc
[   86.166436] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   86.166463] RTL8723BS: assoc success
[   86.174624] RTL8723BS: send eapol packet
[   86.180284] RTL8723BS: send eapol packet
[   86.180733] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[   86.183506] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[   87.753638] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   88.001695] RTL8723BS: start auth
[   88.004201] RTL8723BS: auth success, start assoc
[   89.060752] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[   89.976155] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   90.356885] RTL8723BS: start auth
[   90.358834] RTL8723BS: auth success, start assoc
[   90.364494] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   90.364516] RTL8723BS: assoc success
[   91.177324] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:3, no_gkey_mc_cnt:0
[   92.201420] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
[   92.372000] RTL8723BS: send eapol packet
[   92.377907] RTL8723BS: send eapol packet
[   92.378380] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[   92.379241] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[   92.385772] RTL8723BS: sta recv deauth reason code(6) sta:dc:ef:09:e3:a1:8a, ignore = 0
[   93.952260] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   94.248104] RTL8723BS: start auth
[   94.254071] RTL8723BS: auth success, start assoc
[   94.259813] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[   94.259839] RTL8723BS: assoc success
[   95.273325] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
[   96.269094] RTL8723BS: send eapol packet
[   96.274922] RTL8723BS: send eapol packet
[   96.275267] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[   96.280239] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[   97.849573] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[   98.548783] RTL8723BS: start auth
[   98.559812] RTL8723BS: auth success, start assoc
[   99.660689] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[  100.536047] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  100.801408] RTL8723BS: start auth
[  100.804910] RTL8723BS: auth success, start assoc
[  100.808527] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  100.808548] RTL8723BS: assoc success
[  100.817361] RTL8723BS: send eapol packet
[  100.825365] RTL8723BS: send eapol packet
[  100.825629] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  100.828738] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  102.409686] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  102.644540] RTL8723BS: start auth
[  102.647546] RTL8723BS: auth success, start assoc
[  103.700398] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  104.621977] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  104.897454] RTL8723BS: start auth
[  104.900186] RTL8723BS: auth success, start assoc
[  104.903829] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  104.903854] RTL8723BS: assoc success
[  104.914443] RTL8723BS: send eapol packet
[  104.923209] RTL8723BS: send eapol packet
[  104.923546] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  104.924453] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  106.501044] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  106.740421] RTL8723BS: start auth
[  106.742066] RTL8723BS: auth success, start assoc
[  107.871400] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  108.721186] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  108.993440] RTL8723BS: start auth
[  108.995407] RTL8723BS: auth success, start assoc
[  108.999298] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  108.999330] RTL8723BS: assoc success
[  109.008302] RTL8723BS: send eapol packet
[  109.014006] RTL8723BS: send eapol packet
[  109.014299] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  109.016431] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  110.589719] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  110.836419] RTL8723BS: start auth
[  110.838162] RTL8723BS: auth success, start assoc
[  111.941351] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  112.864647] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  113.191544] RTL8723BS: start auth
[  113.198786] RTL8723BS: auth success, start assoc
[  113.202350] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  113.202362] RTL8723BS: assoc success
[  113.211175] RTL8723BS: send eapol packet
[  113.216566] RTL8723BS: send eapol packet
[  113.216820] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  113.217502] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  113.220539] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  114.787454] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  115.034722] RTL8723BS: start auth
[  115.036455] RTL8723BS: auth success, start assoc
[  116.151384] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  117.004867] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  117.287464] RTL8723BS: start auth
[  117.290199] RTL8723BS: auth success, start assoc
[  117.293763] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  117.293775] RTL8723BS: assoc success
[  117.302539] RTL8723BS: send eapol packet
[  117.307883] RTL8723BS: send eapol packet
[  117.308139] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  117.308750] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  117.310584] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  118.882202] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  119.130649] RTL8723BS: start auth
[  119.132346] RTL8723BS: auth success, start assoc
[  120.220072] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  121.105682] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  121.383449] RTL8723BS: start auth
[  121.387365] RTL8723BS: auth success, start assoc
[  121.392416] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  121.392442] RTL8723BS: assoc success
[  122.922602] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
[  123.403285] RTL8723BS: send eapol packet
[  123.408869] RTL8723BS: send eapol packet
[  123.409137] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  123.409758] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  124.977513] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  125.377006] RTL8723BS: start auth
[  125.383742] RTL8723BS: auth success, start assoc
[  125.387589] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  125.387613] RTL8723BS: assoc success
[  125.397706] RTL8723BS: send eapol packet
[  126.405318] RTL8723BS: send eapol packet
[  126.405608] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  126.406327] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  127.991111] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  128.244126] RTL8723BS: start auth
[  128.246175] RTL8723BS: auth success, start assoc
[  129.300872] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  130.219007] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  130.496876] RTL8723BS: start auth
[  130.498957] RTL8723BS: auth success, start assoc
[  130.502576] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  130.502598] RTL8723BS: assoc success
[  130.513829] RTL8723BS: send eapol packet
[  130.520793] RTL8723BS: send eapol packet
[  130.521931] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  130.522636] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  132.095072] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  132.339994] RTL8723BS: start auth
[  132.342444] RTL8723BS: auth success, start assoc
[  133.400096] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[  134.314892] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  134.695209] RTL8723BS: start auth
[  134.698567] RTL8723BS: auth success, start assoc
[  134.704651] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  134.704680] RTL8723BS: assoc success
[  134.712508] RTL8723BS: send eapol packet
[  134.718297] RTL8723BS: send eapol packet
[  134.720970] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  134.722362] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  136.296075] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  136.538193] RTL8723BS: start auth
[  136.540843] RTL8723BS: auth success, start assoc
[  137.596485] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[  138.516707] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  138.791048] RTL8723BS: start auth
[  138.793542] RTL8723BS: auth success, start assoc
[  138.799202] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  138.799221] RTL8723BS: assoc success
[  138.805899] RTL8723BS: send eapol packet
[  138.811348] RTL8723BS: send eapol packet
[  138.811692] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  138.813056] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  140.383025] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  140.634244] RTL8723BS: start auth
[  140.635939] RTL8723BS: auth success, start assoc
[  141.691541] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  142.608869] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  142.886974] RTL8723BS: start auth
[  142.890561] RTL8723BS: auth success, start assoc
[  142.894265] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  142.894291] RTL8723BS: assoc success
[  142.903483] RTL8723BS: send eapol packet
[  142.909150] RTL8723BS: send eapol packet
[  142.910620] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  142.911331] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  144.483796] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  144.730121] RTL8723BS: start auth
[  144.731727] RTL8723BS: auth success, start assoc
[  145.792754] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  146.706423] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  147.085352] RTL8723BS: start auth
[  147.087096] RTL8723BS: auth success, start assoc
[  147.090772] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  147.090796] RTL8723BS: assoc success
[  148.008041] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
[  149.032007] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
[  149.101415] RTL8723BS: send eapol packet
[  149.106860] RTL8723BS: send eapol packet
[  149.107176] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  149.109185] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  150.682464] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  151.693198] RTL8723BS: start auth
[  151.706540] RTL8723BS: auth success, start assoc
[  152.809656] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  153.680181] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  153.945831] RTL8723BS: start auth
[  153.956284] RTL8723BS: auth success, start assoc
[  153.962089] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  153.962117] RTL8723BS: assoc success
[  153.977808] RTL8723BS: send eapol packet
[  153.985683] RTL8723BS: send eapol packet
[  154.112147] RTL8723BS: set_stakey_hdl sta:dc:ef:09:e3:a1:8a not found
[  155.576563] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  155.789011] RTL8723BS: start auth
[  155.790667] RTL8723BS: auth success, start assoc
[  156.847116] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[  157.764439] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  159.688515] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  159.884953] RTL8723BS: start auth
[  159.887712] RTL8723BS: auth success, start assoc
[  159.891301] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  159.891312] RTL8723BS: assoc success
[  159.901279] RTL8723BS: send eapol packet
[  159.909210] RTL8723BS: send eapol packet
[  159.909417] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  159.909870] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  159.909914] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  159.917405] RTL8723BS: sta recv deauth reason code(6) sta:dc:ef:09:e3:a1:8a, ignore = 0
[  161.480089] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  161.728159] RTL8723BS: start auth
[  161.729814] RTL8723BS: auth success, start assoc
[  161.735964] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  161.735983] RTL8723BS: assoc success
[  161.743239] RTL8723BS: send eapol packet
[  161.749584] RTL8723BS: send eapol packet
[  161.749862] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  161.750619] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  161.750624] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  163.323217] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  163.571462] RTL8723BS: start auth
[  163.573266] RTL8723BS: auth success, start assoc
[  164.679105] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[  165.541901] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  165.824117] RTL8723BS: start auth
[  165.825993] RTL8723BS: auth success, start assoc
[  165.829727] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  165.829756] RTL8723BS: assoc success
[  165.838471] RTL8723BS: send eapol packet
[  165.844313] RTL8723BS: send eapol packet
[  165.847847] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  165.852210] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  165.859967] RTL8723BS: sta recv deauth reason code(6) sta:dc:ef:09:e3:a1:8a, ignore = 0
[  165.862207] RTL8723BS: sta recv deauth reason code(6) sta:dc:ef:09:e3:a1:8a, ignore = 0
[  165.864982] RTL8723BS: sta recv deauth reason code(6) sta:dc:ef:09:e3:a1:8a, ignore = 0
[  167.419101] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  167.667160] RTL8723BS: start auth
[  167.670627] RTL8723BS: auth success, start assoc
[  167.676177] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  167.676188] RTL8723BS: assoc success
[  167.682623] RTL8723BS: send eapol packet
[  167.701355] RTL8723BS: send eapol packet
[  167.837774] RTL8723BS: set_stakey_hdl sta:dc:ef:09:e3:a1:8a not found
[  169.300274] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  169.510370] RTL8723BS: start auth
[  169.512315] RTL8723BS: auth success, start assoc
[  170.570127] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  171.487085] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  171.763070] RTL8723BS: start auth
[  171.764886] RTL8723BS: auth success, start assoc
[  171.768515] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  171.768529] RTL8723BS: assoc success
[  173.607391] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
[  173.778772] RTL8723BS: send eapol packet
[  173.783978] RTL8723BS: send eapol packet
[  173.784193] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  173.784712] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  175.352839] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  175.756780] RTL8723BS: start auth
[  175.763688] RTL8723BS: auth success, start assoc
[  176.828831] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[  177.897640] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  178.316608] RTL8723BS: start auth
[  178.322612] RTL8723BS: auth success, start assoc
[  178.327884] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  178.327907] RTL8723BS: assoc success
[  178.338796] RTL8723BS: send eapol packet
[  178.727454] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
[  179.751420] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
[  180.349606] RTL8723BS: send eapol packet
[  180.349872] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  180.350549] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  182.125644] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  182.412484] RTL8723BS: start auth
[  182.418399] RTL8723BS: auth success, start assoc
[  183.478692] RTL8723BS: sta recv disassoc reason code(5) sta:dc:ef:09:e3:a1:8a
[  184.389286] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  184.665190] RTL8723BS: start auth
[  184.672738] RTL8723BS: auth success, start assoc
[  184.685835] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  184.685851] RTL8723BS: assoc success
[  186.696202] RTL8723BS: send eapol packet
[  186.701458] RTL8723BS: send eapol packet
[  186.701666] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  186.702080] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  188.266418] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  188.556548] RTL8723BS: start auth
[  188.558510] RTL8723BS: auth success, start assoc
[  189.638613] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  190.720942] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  191.116418] RTL8723BS: start auth
[  191.123359] RTL8723BS: auth success, start assoc
[  191.132369] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  191.132397] RTL8723BS: assoc success
[  192.038976] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
[  192.142337] RTL8723BS: send eapol packet
[  193.150410] RTL8723BS: send eapol packet
[  193.150614] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  193.152924] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  194.718463] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  195.212352] RTL8723BS: start auth
[  195.215652] RTL8723BS: auth success, start assoc
[  195.224571] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  195.224601] RTL8723BS: assoc success
[  197.235856] RTL8723BS: send eapol packet
[  197.241460] RTL8723BS: send eapol packet
[  197.241801] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  197.242866] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  198.818466] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  199.205808] RTL8723BS: start auth
[  199.226247] RTL8723BS: auth success, start assoc
[  200.310460] RTL8723BS: sta recv disassoc reason code(6) sta:dc:ef:09:e3:a1:8a
[  201.206338] RTL8723BS: rtw_set_802_11_connect(wlan0)  fw_state = 0x00000008
[  201.458516] RTL8723BS: start auth
[  201.472802] RTL8723BS: auth success, start assoc
[  201.484217] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  201.484242] RTL8723BS: assoc success
[  201.767096] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:1, no_gkey_mc_cnt:0
[  202.793085] RTL8723BS: rtw_aes_decrypt(wlan0) no_gkey_bc_cnt:2, no_gkey_mc_cnt:0
[  203.493390] RTL8723BS: send eapol packet
[  203.499836] RTL8723BS: send eapol packet
[  203.500175] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  203.507667] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
[  204.642911] RTL8723BS: module exit start
[  204.662650] RTL8723BS: rtw_ndev_uninit(wlan0)
[  204.723361] RTL8723BS: rtw_cmd_thread: DriverStopped(1) SurpriseRemoved(0) break at line 432
[  204.723667] RTL8723BS: rtw_dev_unload: driver not in IPS
[  204.731743] RTL8723BS: module exit success
[  251.456617] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[  251.458095] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  251.458295] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[  251.458308] cfg80211: failed to load regulatory.db
[  251.461564] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[  251.483862] r8723bs: unknown parameter 'ant_sel' ignored
[  251.484779] RTL8723BS: module init start
[  251.484796] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[  251.484801] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[  251.486972] pnetdev = 000000008355a52e
[  251.537855] RTL8723BS: rtw_ndev_init(wlan0)
[  251.558875] RTL8723BS: module init ret =0
[  251.637413] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin
[  252.870249] RTL8723BS: set bssid:00:00:00:00:00:00
[  263.421610] RTL8723BS: set bssid:dc:ef:09:e3:a1:8a
[  263.421643] RTL8723BS: set ssid [NETGEAR86] fw_state = 0x00000088
[  263.507486] RTL8723BS: sta recv disassoc reason code(1) sta:dc:ef:09:e3:a1:8a
[  268.845270] RTL8723BS: set bssid:00:00:00:00:00:00
[  279.373779] RTL8723BS: set bssid:dc:ef:09:e3:a1:8a
[  279.373830] RTL8723BS: set ssid [NETGEAR86] fw_state = 0x00000088
[  279.485700] RTL8723BS: start auth
[  279.490537] RTL8723BS: auth success, start assoc
[  279.498197] RTL8723BS: rtw_cfg80211_indicate_connect(wlan0) BSS not found !!
[  279.498220] RTL8723BS: assoc success
[  279.498361] ------------[ cut here ]------------
[  279.498408] WARNING: CPU: 0 PID: 350 at net/wireless/sme.c:756 __cfg80211_connect_result+0x38c/0x3d0 [cfg80211]
[  279.498411] Modules linked in: r8723bs(C) cfg80211 fuse zstd snd_soc_simple_card sun4i_i2s snd_soc_hdmi_codec rfkill snd_soc_simple_card_utils snd_soc_core sunxi_cedrus(C) snd_pcm_dmaengine snd_pcm snd_timer sunxi_cir rc_core snd v4l2_mem2mem soundcore videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc cpufreq_dt zram realtek rtc_pcf8563 dw_hdmi_cec dw_hdmi_i2s_audio i2c_mv64xxx dwmac_sun8i mdio_mux panfrost gpu_sched [last unloaded: cfg80211]
[  279.498492] CPU: 0 PID: 350 Comm: kworker/u8:2 Tainted: G         C        5.4.14-sunxi64 #rc1
[  279.498495] Hardware name: Pine H64 model B (DT)
[  279.498521] Workqueue: cfg80211 cfg80211_event_work [cfg80211]
[  279.498530] pstate: 60000005 (nZCv daif -PAN -UAO)
[  279.498554] pc : __cfg80211_connect_result+0x38c/0x3d0 [cfg80211]
[  279.498577] lr : __cfg80211_connect_result+0x2f8/0x3d0 [cfg80211]
[  279.498580] sp : ffff80001126bca0
[  279.498583] x29: ffff80001126bca0 x28: 0000000000000000
[  279.498590] x27: 0000000000000060 x26: dead000000000100
[  279.498597] x25: dead000000000122 x24: 0000000000000000
[  279.498603] x23: ffff80001126bce8 x22: ffff000097fa2000
[  279.498610] x21: ffff800010ec88c8 x20: ffff0000b257ec18
[  279.498616] x19: ffff000097ed6800 x18: 0000000000000000
[  279.498622] x17: 0000000000000000 x16: 0000000000000000
[  279.498628] x15: 0000000000000000 x14: 090005dd2001002a
[  279.498634] x13: 3700060049100301 x12: 0000000000000028
[  279.498641] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[  279.498647] x9 : fefefefefefefeff x8 : ffff0000aae3b044
[  279.498653] x7 : 0000000000000000 x6 : 0000000000000001
[  279.498659] x5 : ffff0000b1677058 x4 : 00000000e309efdc
[  279.498665] x3 : ffffffff00003150 x2 : ffff0000b34a4f80
[  279.498671] x1 : ffff0000b34a4f80 x0 : 0000000000000000
[  279.498677] Call trace:
[  279.498702]  __cfg80211_connect_result+0x38c/0x3d0 [cfg80211]
[  279.498725]  cfg80211_process_wdev_events+0x1a0/0x208 [cfg80211]
[  279.498748]  cfg80211_process_rdev_events+0x38/0x90 [cfg80211]
[  279.498770]  cfg80211_event_work+0x1c/0x30 [cfg80211]
[  279.498783]  process_one_work+0x1ec/0x370
[  279.498791]  worker_thread+0x4c/0x4f8
[  279.498798]  kthread+0x120/0x128
[  279.498806]  ret_from_fork+0x10/0x18
[  279.498811] ---[ end trace a3cc33cc5f0b2926 ]---
[  280.505956] RTL8723BS: send eapol packet
[  281.517203] RTL8723BS: send eapol packet
[  281.517308] RTL8723BS: set pairwise key camid:4, addr:dc:ef:09:e3:a1:8a, kid:0, type:AES
[  281.517800] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  281.517827] RTL8723BS: set group key camid:5, addr:dc:ef:09:e3:a1:8a, kid:1, type:AES
EDIT: I also tested to unload and load r8723bs module without the ant_sel option and it works. So just reloading the module is enough even if signal strength is not always detected.
2 shorts questions:
-  is it possible  to compile armbian 20.02 rc1 myself using armbian-build-system (and how / which parameters?)
[EDIT] using?
LIB_TAG="v20.02-rc1"
-  whats the real difference between armbian 19.11.9 and 20.02 rc1 and where can I read about it?
8 minutes ago, guidol said:
2 shorts questions:
git fetch
git checkout v20.02-rc1
sudo ./compile.sh FORCE_CHECKOUT=no
Unofficial release notes https://gist.github.com/lanefu/e32eb43aaaa7928c51ca8890af58c841#file-temp_notes-md
4 minutes ago, lanefu said:
git fetch
is this useable as a temporary compile-switch to v20.02-rc1 (so that afterwards I can compile also a a non-rc 19.11.x armbian)?
Or Iam then completly nailed to v20.02?
git checkout master
git pull
sudo ./compile.sh
will take you back to the master branch that you normally use.... FYI master is a rolling release..which may have looked like 19.11.x but its actually newer.. In fact we've updated the version in master release to reflect it as v20.05-trunk
Le Potato seems to be broken.  I did several clean builds and always did the same thing.  Another user in IRC confirmed not working on recent kernels for them as well.
 http://ix.io/2bUZ
... while Odroid C2 works fine.
We can patch meson64 current with a last good know kernel afterwards. Just need to find one ... :P And rebuilt Le Potato image.
LaFrite too! I get stuck to kernel loading step. Here is what I got on serial console:
�GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:1;RCY:0;SPI:0;0.0;CHK:0;
TE: 35041
BL2 Built : 14:59:36, Aug  9 2017.
gxl ge8c6a83 - xiaobo.gu@droid12
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 11
CPU clk: 1200MHz
DDR enable rdbi
DQS-corr enabled
DDR scramble enabled
DDR4 chl: Rank0 16bit @ 1200MHz
Rank0: 1024MB(auto)-2T-18
DataBus test pass!
AddrBus test pass!
Set ddr ssc: ppm1000-
Load fip header from SPI, src: 0x0000c000, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from SPI, src: 0x00010000, des: 0x01100000, size: 0x0000d600
Load bl31 from SPI, src: 0x00020000, des: 0x05100000, size: 0x0002c600
Load bl33 from SPI, src: 0x00050000, des: 0x01000000, size: 0x000dc000
NOTICE:  BL3-1: v1.0(release):801e730
NOTICE:  BL3-1: Built : 22:09:38, Aug 10 2017
[BL31]: GXL CPU setup!
mpu_config_enable:ok
[Image: gxl_v1.1.3221-2cfba6977-dirty 2017-08-01 17:22:28 jianxin.pan@droid09]
OPS=0x34
2 dc 9 e4 df 6d 0 5b 52 b6 b5 8b [0.945590 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2019.04+ (Sep 09 2019 - 16:14:37 +0000) Libre Computer AML-S805X-AC
Model: Libre Computer Board AML-S805X-AC
DRAM:  1 GiB
MMC:   mmc@74000: 0
Loading Environment from SPI Flash... SF: Detected gd25lq128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
In:    serial
Out:   serial
Err:   serial
Boot:  spi
[BL31]: tee size: 0
Net:   eth0 chip_id MAC address: 18:66:c7:b6:b5:8b
Card did not respond to voltage select!
Error: could not access storage.
Net:   eth0: ethernet@c9410000
starting USB...
USB0:   Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1:   scanning bus 0 for devices... usb_new_device: Cannot read configuration, skipping device 046d:c30b
2 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
Press ESC for menu. 0
Device 0: Vendor: Verbatim Rev: 1.00 Prod: STORE N GO
            Type: Removable Hard Disk
            Capacity: 7651.0 MB = 7.4 GB (15669248 x 512)
... is now current device
Scanning usb 0:1...
3056 bytes read in 11 ms (270.5 KiB/s)
## Executing script at 08000000
203 bytes read in 6 ms (32.2 KiB/s)
## Error: Can't overwrite "ethaddr"
himport_r: can't insert "ethaddr=00:50:43:84:fb:2f" into hash table
8690780 bytes read in 361 ms (23 MiB/s)
21475840 bytes read in 867 ms (23.6 MiB/s)
36130 bytes read in 37 ms (953.1 KiB/s)
232 bytes read in 21 ms (10.7 KiB/s)
Applying kernel provided DT fixup script (meson-fixup.scr)
## Executing script at 34000000
## Loading init Ramdisk from Legacy Image at 13000000 ...
   Image Name:   uInitrd
   Created:      2020-02-16  22:55:57 UTC
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    8690716 Bytes = 8.3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 08008000
   Booting using the fdt blob at 0x8008000
Host not halted after 16000 microseconds.
   Loading Ramdisk to 3b6b6000, end 3beffc1c ... OK
   Loading Device Tree to 000000003b644000, end 000000003b6b5fff ... OK
cvbs: disabled
efuse: read-only
Starting kernel ...
domain-0 init dvfs: 4
The log of 19.4 image that boots:
TE: 35039
set vcck to 1120 mv
Board ID = 11
CPU clk: 1200MHz
DDR enable rdbi
DQS-corr enabled
DataBus test pass!
AddrBus test pass!
New fip structure!
OPS=0x34
2 dc 9 e4 df 6d 0 5b 52 b6 b5 8b [0.945415 Inits done]
secure task start!
high task start!
low task start!
DRAM:  1 GiB
MMC:   mmc@74000: 0
In:    serial
Out:   serial
Err:   serial
Boot:  spi
[BL31]: tee size: 0
starting USB...
USB XHCI 1.00
Scanning usb 0:1...
8678683 bytes read in 381 ms (21.7 MiB/s)
21473792 bytes read in 896 ms (22.9 MiB/s)
36572 bytes read in 37 ms (964.8 KiB/s)
232 bytes read in 15 ms (14.6 KiB/s)
   Image Name:   uInitrd
   Created:      2019-12-26   0:24:54 UTC
   Data Size:    8678619 Bytes = 8.3 MiB
   Loading Ramdisk to 3b6b9000, end 3beffcdb ... OK
   Loading Device Tree to 000000003b647000, end 000000003b6b8fff ... OK
cvbs: disabled
efuse: read-only
Starting kernel ...
[BL31]: tee size: 0
Armbian 19.11.4 Buster ttyAML0
lafrite login:
On 1/26/2020 at 6:22 PM, stut said:
RC1 working very nicely on NanoPi NEO2 boards here. Also running cooler than I remember, hovering between 22-27c idle/light load.
as my compile didnt switch to v20.02-rc1 via LIB_TAG="v20.02-rc1" so my armbian-build-system did build 20.05.0-trunk (master-branch).
The 20.05.0-trunk does work with normal temperatures on my Neo2 LTS like in 19.11.9 = 43-48 degree celsius while using lcd4linux and some shell-scripts.
Welcome to Armbian bullseye with Linux 5.5.0-sunxi64
No end-user support: built from trunk & unsupported (bullseye) userspace!
package bsp-kernel[20.05.0-trunk] u-boot[20.05.0-trunk]    dtb[20.05.0-trunk]
firmware          [20.05.0-trunk] config[20.05.0-trunk] branch[dev]
System load:   0.15 0.24 0.19   Up time:       32 min           Local users:   2
Memory usage:  12 % of 989MB    IP:            192.168.6.24
CPU temp:      48°C
Usage of /:    10% of 15G       storage/:      41% of 458G
check out the branch direclty and try what i said here
Le Potato Update:
I built and tested images through several commits, and patch adjustments.
Le Potato has been broken since our switch to mainline kernel from this merge https://github.com/armbian/build/pull/1748
I was able to build a working image from here https://github.com/armbian/build/commit/cc7ab6a6b1d91977bd9e154245307e85f7f76519
Since the scope is only le potato, my thoughts are to update v20.02 branch (lepotato and v20.02 only) to use the older kernel config just for le potato.   Then we can focus on fixing correctly for v20.05.
I'll start working on a PR for that in a bit.  If we find another solution thats fine.
The problem will be updating. We have to fix this kernel (hack DTB for Lepotato) somehow.
Hmmm I wish i understood how the armbian debian packaging worked a little better.      Is there a short answer for why its a problem? :)
Can we not lock kernels to a release?
Edited by lanefu
can we lock kernels to a release?
When a current Le potato will fire apt update and reboot it will get stuck, right? Per board we can control: u-boot, bsp and DTB, kernel is identical to all meson64 family.
Perhaps @Neil Armstrong can give us a hint with the error http://ix.io/2bUZ ?
Is this only on Le Potato ? This should not happen, it fails while registering a clock.
Only on le potato. Not odroid c2.
We have some different uboot steps for s905x but i haven't been able to understand them. @Igor do you think the gxl stuff in the uboot steps is relevant?
There was mention of La Frite as well from what I quickly read.  I don't think this is U-boot related, personally.  But I also haven't spent more than an hour on it.
I don't think so. I didn't catch on the IRC - have you tried to boot without our patches ... and perhaps also with older config? We need some better reference point. Sadly I can't help much with debug this week - crippled workstation and out of office for few days.
I tried removing all patches and that didnt change the behavior.
Ill take a look at kernel config again, but it seemed like it hasnt changed since we switched to mainline
