Whats your favorite little heat sink for the Allwinner SoCs... LibreComputer's doesn't count.
On 3/10/2020 at 1:16 PM, Werner said:
What do you think?
I think they are a bit 'overkill' and quite expensive. See the answer below.  Means, unless you want to run at maximum all the time, a cheap heat sink should do the job.
On 3/10/2020 at 11:38 PM, manuti said:
(I think @tkaiser shared this model here
I guess this is correct and IIRC with the idea in mind helping to spread the heat (increase the surface of the SoC) for short high load. With the idea to have sane settings to throttle the SoC and keep the temperature on a healthy level software wise.
I like 'Go big or go home' stuff :lol:
Who mentioned overkill? :P
I usually use those, and usually oriented properly:
Mine also arrived last week. They are around 40% bigger than stock for Tinkerboard.
