lanefu Posted February 21, 2020 Posted February 21, 2020 Whats your favorite little heat sink for the Allwinner SoCs... LibreComputer's doesn't count.
guidol Posted February 21, 2020 Posted February 21, 2020 I do use some real simple Aluminium-coolers ( https://www.robotistan.com/aluminyum-mini-sogutucu-seti-heat-sink ) The bigger one on the CPU and the small ones on the RAM chips
Werner Posted February 21, 2020 Posted February 21, 2020 On 2/21/2020 at 7:58 AM, guidol said: I do use some real simple Aluminium-coolers ( https://www.robotistan.com/aluminyum-mini-sogutucu-seti-heat-sink ) The bigger one on the CPU and the small ones on the RAM chips Expand Are those self-adhesive?
guidol Posted February 21, 2020 Posted February 21, 2020 On 2/21/2020 at 9:37 AM, Werner said: Are those self-adhesive? Expand Yes - they have 3M-thermal-Tape on it
Tido Posted February 22, 2020 Posted February 22, 2020 I got a pack of these: https://www.aliexpress.com/item/2031287967.html USD 2.99.- (8 pieces/lot) back in 2017 2
Werner Posted March 10, 2020 Posted March 10, 2020 I saw those on Amazon recently. https://www.amazon.com/-/de/dp/B077VM8FJW/ref=sr_1_1?currency=USD&ie=UTF8&keywords=Alphacool 17427&language=en_US&qid=1583842491&sr=8-1 What do you think?
manuti Posted March 10, 2020 Posted March 10, 2020 On 2/22/2020 at 9:44 AM, Tido said: I got a pack of these: https://www.aliexpress.com/item/2031287967.html USD 2.99.- (8 pieces/lot) back in 2017 Expand Same here (I think @tkaiser shared this model here and everybody copied his idea). 2
Tido Posted March 14, 2020 Posted March 14, 2020 On 3/10/2020 at 12:16 PM, Werner said: What do you think? Expand I think they are a bit 'overkill' and quite expensive. See the answer below. Means, unless you want to run at maximum all the time, a cheap heat sink should do the job. On 3/10/2020 at 10:38 PM, manuti said: (I think @tkaiser shared this model here Expand I guess this is correct and IIRC with the idea in mind helping to spread the heat (increase the surface of the SoC) for short high load. With the idea to have sane settings to throttle the SoC and keep the temperature on a healthy level software wise. 1
Werner Posted March 15, 2020 Posted March 15, 2020 On 3/14/2020 at 8:27 PM, Tido said: I think they are a bit 'overkill' and quite expensive. Expand I like 'Go big or go home' stuff
Igor Posted March 15, 2020 Posted March 15, 2020 Who mentioned overkill? I usually use those, and usually oriented properly: 2
Tido Posted March 19, 2020 Posted March 19, 2020 On 3/15/2020 at 7:17 AM, Werner said: I like 'Go big or go home' stuff Expand #me too ... soon after the power connector died https://forum.armbian.com/topic/6909-pi-factor-power-solution/?tab=comments#comment-52516 But some day I will amend the power-HAT from @TonyMac32 cut out the middle part in KiCAD and see if I can get it manufactured in China. So this great board, with the gorgeous heat sink gets back to live :-D 1
Werner Posted April 20, 2020 Posted April 20, 2020 They are finally here. Still waiting for the thermal adhesive. 1
Igor Posted April 20, 2020 Posted April 20, 2020 Mine also arrived last week. They are around 40% bigger than stock for Tinkerboard. 1
m][sko Posted April 20, 2020 Posted April 20, 2020 I mount this one on Hikey970 I can only recommend! 3
