balbes150 Posted June 22, 2018 Author Posted June 22, 2018 Try to record a clean image and before the first start of the system, immediately switch the entire system to 720. That would first start the system and KODI was with 720 parameters.
Reddwarf Posted June 22, 2018 Posted June 22, 2018 @balbes150 I'm running Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_mate_20180515, sound, wifi, ethernet and BT (with external adapter) works fine so I'm pretty happy with this image but the search function in Synaptic Packet Manager is extremly slow, any idea why?
martinayotte Posted June 22, 2018 Posted June 22, 2018 13 minutes ago, Reddwarf said: Synaptic Packet Manager is extremly slow, any idea why? Maybe related :
Reddwarf Posted June 23, 2018 Posted June 23, 2018 I want to try to build my own image for MiniM8S/MiniMX-III, is there a HowTo somewhere to guide me?
MOHAMMAD HADI Posted June 23, 2018 Posted June 23, 2018 Hi, Have anyone tried to get the IR remote working on these boxes in Linux? How to configure lirc to use the meson_ir module? Also, do we need to modify the dtbs for this to work? Thanks
shippy Posted June 23, 2018 Posted June 23, 2018 Sorry if below have been answered: 1. Is it true that Mali HW acceleration is not supported in Linux as it is under Android? If yes then those GPUs have no function with Armbian desktop builds, e.g., for Kodi? 2. I read that 720p or less resolution doesn't need HW acceleration, and is actually SW decoded by the (quadcore) CPU. So only 1080p and more resolution would require HW acceleration? How many CPU cores would be required to stream 2-4 concurrent 720p channels? 3. What is the function of the VPU unit on S905/W?
Reddwarf Posted June 24, 2018 Posted June 24, 2018 9 hours ago, shippy said: Sorry if below have been answered: 1. Is it true that Mali HW acceleration is not supported in Linux as it is under Android? If yes then those GPUs have no function with Armbian desktop builds, e.g., for Kodi? 2. I read that 720p or less resolution doesn't need HW acceleration, and is actually SW decoded by the (quadcore) CPU. So only 1080p and more resolution would require HW acceleration? How many CPU cores would be required to stream 2-4 concurrent 720p channels? 3. What is the function of the VPU unit on S905/W? I don't know the answer to 1&2 but for 3, the VPU is the video processing unit. Unlike PC-graphics cards the Amlogic does not have the GPU and VPU integrated but as two separate processors. This implies that the GPU can be used for other tasks without interfering with the video output.
shippy Posted June 24, 2018 Posted June 24, 2018 8 hours ago, Reddwarf said: I don't know the answer to 1&2 but for 3, the VPU is the video processing unit. Unlike PC-graphics cards the Amlogic does not have the GPU and VPU integrated but as two separate processors. This implies that the GPU can be used for other tasks without interfering with the video output. Thanks. Now does the VPU do video decoding or GUI rendering or can/does both? How about for GPUs? I am assuming that balbes150 desktop distro supports S905/X quadcore processing, as AndroidOS does.
MOHAMMAD HADI Posted June 24, 2018 Posted June 24, 2018 @balbes150 regarding the wifi drivers of the ampak am6335 and the dvb drivers I've asked you about before, it turns out that for the wifi you don't need an out-of-tree driver, the wifi is already supported by the dhd module provided with amlogic's kernel, the problem is that for some reason the module is failing to detect the right path of the firmware to load so I'm getting this after modprobe dhd: [ 82.045326] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/brcm/.bin [ 82.045330] _dhdsdio_download_firmware: dongle image file download failed [ 82.045348] dhd_bus_devreset Failed to download binary to the dongle Anyways I solved it by passing the path manually to the module like so: modprobe dhd firmware_path=/lib/firmware/brcm/fw_bcm4335b0_ag note that I only tested this on the Debian stretch image running 3.14.29 kernel As for the dvb drivers they are out of tree and I had to compile the whole kernel to be able to load them without crashing the kernel, I hope that you can include them In your future releases. One last question: do you know how to configure lirc in linux for these boxes (ir remote)?Do I need to modify the dtb for it to work ? Thanks
hanguofu Posted June 25, 2018 Posted June 25, 2018 Sorry for my question if it had been asked : is there any Ubuntu img available for MXQ PRO+ 4K ( s905x , 2G/16G ) with cvbs compatibility ? I donot have a hdmi monitor and I would like to try Ubuntu on my tv box. I tried multi-boot with Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_server_20180515.img at my sd card , but there is no av ( cvbs ) output at all. I am not sure if the dtb.img is suitable for my tv box ( I tried several dtb files ) or the armbian Ubuntu img does not support cvsb output at all ?
Saurabh Posted June 25, 2018 Posted June 25, 2018 14 minutes ago, hanguofu said: Sorry for my question if it had been asked : is there any Ubuntu img available for MXQ PRO+ 4K ( s905x , 2G/16G ) with cvbs compatibility ? I donot have a hdmi monitor and I would like to try Ubuntu on my tv box. I tried multi-boot with Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_server_20180515.img at my sd card , but there is no av ( cvbs ) output at all. I am not sure if the dtb.img is suitable for my tv box ( I tried several dtb files ) or the armbian Ubuntu img does not support cvsb output at all ? I'm using Armbian 5.41 image which you can find in mali 7 folder. It's working fine for me without any dtb. Since you don't have a hdmi monitor you can choosing 720p option in the hdmi.sh file (comment the 1080p one ) and it will work on normal monitors too.
Saurabh Posted June 25, 2018 Posted June 25, 2018 Hi , one question , does anyone know how to enable sound during remote sessions on pulse audio?
Reddwarf Posted June 25, 2018 Posted June 25, 2018 20 hours ago, shippy said: Thanks. Now does the VPU do video decoding or GUI rendering or can/does both? How about for GPUs? I am assuming that balbes150 desktop distro supports S905/X quadcore processing, as AndroidOS does. I'm no guru at this but as far as I know the VPU does only video processing and the rendering is either done i SW or in the GPU if supported. I don't know about Balbes images but I remember him mentioning that the no-mali images have support for quadcore in Kodi. 1
Reddwarf Posted June 25, 2018 Posted June 25, 2018 7 hours ago, Saurabh said: I'm using Armbian 5.41 image which you can find in mali 7 folder. It's working fine for me without any dtb. Since you don't have a hdmi monitor you can choosing 720p option in the hdmi.sh file (comment the 1080p one ) and it will work on normal monitors too. I think what he ment is that he does not have a monitor with hdmi-connection....
Reddwarf Posted June 25, 2018 Posted June 25, 2018 7 hours ago, hanguofu said: Sorry for my question if it had been asked : is there any Ubuntu img available for MXQ PRO+ 4K ( s905x , 2G/16G ) with cvbs compatibility ? I donot have a hdmi monitor and I would like to try Ubuntu on my tv box. I tried multi-boot with Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_server_20180515.img at my sd card , but there is no av ( cvbs ) output at all. I am not sure if the dtb.img is suitable for my tv box ( I tried several dtb files ) or the armbian Ubuntu img does not support cvsb output at all ? Do I understand correctly that your monitor does not have hdmi-input? If you have DVI or VGA you can get an adapter hdmi->DVI or hdmi->VGA.
hanguofu Posted June 25, 2018 Posted June 25, 2018 1 minute ago, Reddwarf said: Do I understand correctly that your monitor does not have hdmi-input? If you have DVI or VGA you can get an adapter hdmi->DVI or hdmi->VGA. Yes . You got it . I only have a traditional tv set with cvbs ( composite or AV ) input and a computer monitor with VGA input.
Reddwarf Posted June 25, 2018 Posted June 25, 2018 Just now, hanguofu said: Yes . You got it . I only have a traditional tv set with cvbs ( composite or AV ) input and a computer monitor with VGA input. In that case a hdmi to VGA adapter would do the trick, you can get one from Aliexpress.com or Banggood. I think that is your best bet
andry_82 Posted June 25, 2018 Posted June 25, 2018 There is a monitor with a resolution of 1440x900 (16:10) connected via the hdmi-> vga adapter. In the adjustment there is a current resolution of 1280X1024. How do I add the permission that I need.
Reddwarf Posted June 26, 2018 Posted June 26, 2018 11 hours ago, andry_82 said: There is a monitor with a resolution of 1440x900 (16:10) connected via the hdmi-> vga adapter. In the adjustment there is a current resolution of 1280X1024. How do I add the permission that I need. I don't understand the question, which permission? To edit /boot/hdmi.sh? You can just edit hdmi.sh on some other computer, if it is windows you don't need special permission, if on linux you can start the editor with the sudo command.
balbes150 Posted June 26, 2018 Author Posted June 26, 2018 On 6/22/2018 at 4:23 PM, Reddwarf said: I'm running Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_mate_20180515, sound, wifi, ethernet and BT (with external adapter) works fine so I'm pretty happy with this image but the search function in Synaptic Packet Manager is extremly slow, any idea why? Yes, I found this problem around the beginning of the year (maybe when I switched to version 5.4 x, but it's not accurate). I don't have time to figure out the reason right now. I use "apt-cache search". On 6/22/2018 at 4:37 PM, martinayotte said: Maybe related : We should try this option. On 6/23/2018 at 3:16 PM, MOHAMMAD HADI said: Have anyone tried to get the IR remote working on these boxes in Linux? How to configure lirc to use the meson_ir module? Also, do we need to modify the dtbs for this to work? https://github.com/150balbes/build/blob/amlogic/config/kernel/linux-amlogics905x-default.config#L2724 On 6/24/2018 at 12:05 AM, shippy said: Sorry if below have been answered: 1. Is it true that Mali HW acceleration is not supported in Linux as it is under Android? If yes then those GPUs have no function with Armbian desktop builds, e.g., for Kodi? 2. I read that 720p or less resolution doesn't need HW acceleration, and is actually SW decoded by the (quadcore) CPU. So only 1080p and more resolution would require HW acceleration? How many CPU cores would be required to stream 2-4 concurrent 720p channels? 3. What is the function of the VPU unit on S905/W? 1. Incorrectly. HW is in Linux. 2. For full-screen video playback >= 1080p on s905 need hardware support for VPU (not to be confused with GPU\libMali). 3. The VPU decodes the video stream. 15 hours ago, Reddwarf said: I don't know about Balbes images but I remember him mentioning that the no-mali images have support for quadcore in Kodi. If there is no GPU support (which adds up to several elements, the kernel + system + program itself must have this support), then the CPU is used (all available cores from 1 to 8 and more, if any). 15 hours ago, hanguofu said: Yes . You got it . I only have a traditional tv set with cvbs ( composite or AV ) input and a computer monitor with VGA input. For some tests I use a FullHD VGA monitor, via HDMI->VGA adapter. Everything works fine. 14 hours ago, andry_82 said: There is a monitor with a resolution of 1440x900 (16:10) connected via the hdmi-> vga adapter. In the adjustment there is a current resolution of 1280X1024. How do I add the permission that I need. For such screen resolution options you need to use either the system with the kernel "4.1x", or build your kernel 3.14\4.9 with the addition of the necessary patches.
andry_82 Posted June 26, 2018 Posted June 26, 2018 I,m using Armbian5_44_s9xx_debian_stretch_4.16.1_icewm. But the list of permissions has 1280x1024 and the next 1920x1080. How to add 1440x900. If i add through Xrandr then the application of this mode flickers the screen and gets an error.
andry_82 Posted June 26, 2018 Posted June 26, 2018 On the 4.16.1 kernel, when the device is turned off, the device re How ro fix?
MOHAMMAD HADI Posted June 26, 2018 Posted June 26, 2018 2 hours ago, balbes150 said: https://github.com/150balbes/build/blob/amlogic/config/kernel/linux-amlogics905x-default.config#L2724 Yes, I've already built and loaded the remote modules, I also had to edit the meson-remote and meson-ir sections of the dtb(now I have an rc device under /sys/class/rc/rc0 ) the problem is with lirc, I can't set it up with the amlogic drivers, maybe amlogic is using a special protocol, every time I train lirc for the remote and then when I test the config It fails to recognize the buttons. Thanks
shippy Posted June 26, 2018 Posted June 26, 2018 8 hours ago, balbes150 said: 1. Incorrectly. HW is in Linux. 2. For full-screen video playback >= 1080p on s905 need hardware support for VPU (not to be confused with GPU\libMali). 3. The VPU decodes the video stream. If there is no GPU support (which adds up to several elements, the kernel + system + program itself must have this support), then the CPU is ..... @balbes150 Great to hear from you ?? 1. So GPUs are essentially for screen rendering /UI, and multi GPU could be helpful with a Linux Multi-seat (if Multi-seat could be set up)? 2. Can your Armbian distro be used as here, with proot ( or chroot Linux Deploy): https://www.xda-developers.com/guide-installing-and-running-a-gnulinux-environment-on-any-android-device/ Above was tested on Google Pixel C with Snapdragon ARM.
Reddwarf Posted June 27, 2018 Posted June 27, 2018 @balbes150 Can you elaborate a bit about making an image for MiniM8S/MiniMXIII, I found this on the net: http://www.librecalc.com/en/blog/realiser-une-distribution-debian-personalisee-pour-arm9/ Does it apply to "our" tv-boxes? Or is there a better HowTo somewhere?
balbes150 Posted June 27, 2018 Author Posted June 27, 2018 On 6/26/2018 at 11:01 AM, andry_82 said: I,m using Armbian5_44_s9xx_debian_stretch_4.16.1_icewm. But the list of permissions has 1280x1024 and the next 1920x1080. How to add 1440x900. If i add through Xrandr then the application of this mode flickers the screen and gets an error. Build your kernel version with the addition of a patch or wait for the developers to add this mode. On 6/26/2018 at 11:03 AM, andry_82 said: On the 4.16.1 kernel, when the device is turned off, the device re How ro fix? It is unclear what we are talking about. On 6/26/2018 at 12:20 PM, MOHAMMAD HADI said: I can't set it up with the amlogic drivers, What kind of driver are you writing ? 23 hours ago, shippy said: 1. So GPUs are essentially for screen rendering /UI, and multi GPU could be helpful with a Linux Multi-seat (if Multi-seat could be set up)? 2. Can your Armbian distro be used as here, with proot ( or chroot Linux Deploy): https://www.xda-developers.com/guide-installing-and-running-a-gnulinux-environment-on-any-android-device/ Above was tested on Google Pixel C with Snapdragon ARM. 1. That's possible. 2. I do not know. Probably not. Why try to be so perverted ? Armbian is a complete standalone system that does not need to cram in a chroot from Android. 4 hours ago, Reddwarf said: Can you elaborate a bit about making an image for MiniM8S/MiniMXIII, I found this on the net: http://www.librecalc.com/en/blog/realiser-une-distribution-debian-personalisee-pour-arm9/ Does it apply to "our" tv-boxes? Or is there a better HowTo somewhere? What do you want to collect ? What system ?
Reddwarf Posted June 27, 2018 Posted June 27, 2018 1 hour ago, balbes150 said: What do you want to collect ? What system ? Sorry I should have been clearer. If I can download the Armbian source and do my own modifications I want to build and Armbian image for my MiniM8S and MiniMXIII (the HW in thos boxes seems to be pretty similar, only different wifi chip IFAIS). So what I'm asking for is a HowTo to compile and build a complete bootable image.
shippy Posted June 27, 2018 Posted June 27, 2018 9 hours ago, balbes150 said: 1. That's possible. 2. I do not know. Probably not. Why try to be so perverted ? Armbian is a complete standalone system that does not need to cram in a chroot from Android. 1. Ok, so you are saying Multi-seat with S905/X/W Android Box, e.g., two concurrent live streams from two Kodi instances on same box, say one 720p via HDMI and another SD+ via AV port to one TV set each, is possible? (Of course we should be able to stream local HD content on the LAN via UPnP (just recorded video, without Kodi GUI) from the same KODI instance using USB port or WiFi streaming.) 2. Armbian desktop distro for Kodi is beautiful, with HW acceleration and multicore support. But then one perverse idea is to use the power of a Linux distro with the myriad of popular Android apps !
MOHAMMAD HADI Posted June 27, 2018 Posted June 27, 2018 8 hours ago, balbes150 said: What kind of driver are you writing ? 1 I'm talking about the meson-ir module, doesn't seem to be using a standard ir protocol.
balbes150 Posted June 28, 2018 Author Posted June 28, 2018 16 hours ago, Reddwarf said: Sorry I should have been clearer. If I can download the Armbian source and do my own modifications I want to build and Armbian image for my MiniM8S and MiniMXIII (the HW in thos boxes seems to be pretty similar, only different wifi chip IFAIS). So what I'm asking for is a HowTo to compile and build a complete bootable image. https://github.com/150balbes/build The build process is described in the General Armbian documentation, but take into account the features of the build version for TV boxes. 11 hours ago, shippy said: 1. Ok, so you are saying Multi-seat with S905/X/W Android Box, e.g., two concurrent live streams from two Kodi instances on same box, say one 720p via HDMI and another SD+ via AV port to one TV set each, is possible? (Of course we should be able to stream local HD content on the LAN via UPnP (just recorded video, without Kodi GUI) from the same KODI instance using USB port or WiFi streaming.) 2. Armbian desktop distro for Kodi is beautiful, with HW acceleration and multicore support. But then one perverse idea is to use the power of a Linux distro with the myriad of popular Android apps ! 1. I wrote that it's possible if you do it yourself. 2. I strongly doubt that it will work normally. 11 hours ago, MOHAMMAD HADI said: I'm talking about the meson-ir module, doesn't seem to be using a standard ir protocol. Compare how it is implemented in Libreelec.
