Sevillano Posted Friday at 07:02 AM Posted Friday at 07:02 AM Hi to everyone. I've installed community build Armbian on a Nanopi R1S-H5 and all ok but i see two differents Wlan (Wlan0 and Wlan1). If the board has only one wifi nic, how is this possible? Is there an error in any configuration file or in other place? Thanks in advance. 0 Quote
Werner Posted Friday at 12:30 PM Posted Friday at 12:30 PM Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Sevillano Posted Friday at 04:17 PM Author Posted Friday at 04:17 PM Hi. The logs are https://paste.armbian.com/febewikocu. Regards. 0 Quote
IBV Posted Sunday at 07:07 AM Posted Sunday at 07:07 AM Link has an . at the end, the correct one: https://paste.armbian.com/febewikocu 0 Quote
Solution Igor Posted Sunday at 08:05 AM Solution Posted Sunday at 08:05 AM On 4/4/2025 at 9:02 AM, Sevillano said: how is this possible? Most likely P2P wireless, not necessarily functional. This is automatically present by a (wireless) kernel driver. Use the device that works and ignore the other. If bogus device gets to your nerves, dig into the code, find a way how to disable it and sent a patch. 1 Quote
Sevillano Posted Sunday at 09:39 AM Author Posted Sunday at 09:39 AM Thanks Igor, i will do so. Regards. 0 Quote
