DrHaos 0 Posted December 25, 2017 Share Posted December 25, 2017 (edited) Same problem. Log with Serial port without hdmi without hdmi Spoiler HELLO! BOOT0 is starting! boot0 version : 2.0.0▒ read dram para. dram driver version: 1.15 dram size =1024MB 0x18042c60 super_standby_flag = 0 Succeed in opening nand flash. block from 2 to 6 deal block 2 Succeed in reading Boot1 file head. The size of Boot1 is 0x00068000. The file stored in 0x00000000 of block 2 is perfect. Check is correct. Ready to disable icache. Succeed in loading Boot1. Jump to Boot1. [ 0.143] boot1 version : 2.0.0 [ 0.150] script installed early ok [ 0.151] pmu type = 3 [ 0.152] bat vol = 0 mv [ 0.170] axi:ahb:apb=4:2:2 [ 0.170] set dcdc2=1425mv, clock=912M successed [ 0.172] key [ 0.185] no key found [ 0.185] flash init start [ 0.185] NB1 : enter NFB_Init [ 0.188] NB1 : enter phy init [ 0.191] [NAND] nand driver(b) version: 0x0x00000002, 0x0x00000012, data: 0x20130325 [ 0.201] get the good blk ratio from hwscan : 944 [ 0.204] NB1 : nand phy init ok [ 3.913] _RepairLogBlkTbl start [ 3.916] Log Block Index 0x00000000, LogicBlockNum: 0x00000074, LogBlockTy pe: 0x00000000 [ 3.919] log0: 0x00000033, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 3.926] datablock: 0x00000788, lastusedpage: 0x00000003 [ 3.935] Log Block Index 0x00000001, LogicBlockNum: 0x0000003e, LogBlockTy pe: 0x00000000 [ 3.940] log0: 0x00000050, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 3.947] datablock: 0x00000790, lastusedpage: 0x00000001 [ 3.956] Log Block Index 0x00000002, LogicBlockNum: 0x00000031, LogBlockTy pe: 0x00000000 [ 3.961] log0: 0x00000052, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 3.967] datablock: 0x0000079c, lastusedpage: 0x00000004 [ 3.977] Log Block Index 0x00000003, LogicBlockNum: 0x00000038, LogBlockTy pe: 0x00000000 [ 3.981] log0: 0x000007a4, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 3.988] datablock: 0x000007b3, lastusedpage: 0x00000003 [ 3.997] Log Block Index 0x00000004, LogicBlockNum: 0x000000b0, LogBlockTy pe: 0x00000000 [ 4.002] log0: 0x0000078c, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.008] datablock: 0x000007bc, lastusedpage: 0x00000045 [ 4.018] Log Block Index 0x00000005, LogicBlockNum: 0x00000048, LogBlockTy pe: 0x00000000 [ 4.023] log0: 0x00000794, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.029] datablock: 0x000007cc, lastusedpage: 0x00000001 [ 4.038] Log Block Index 0x00000006, LogicBlockNum: 0x0000003c, LogBlockTy pe: 0x00000000 [ 4.043] log0: 0x000001f2, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.050] datablock: 0x000007cf, lastusedpage: 0x00000001 [ 4.059] Log Block Index 0x00000007, LogicBlockNum: 0x00000033, LogBlockTy pe: 0x00000000 [ 4.064] log0: 0x000007c4, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.070] datablock: 0x000007d8, lastusedpage: 0x00000018 [ 4.079] Log Block Index 0x00000008, LogicBlockNum: 0x00000037, LogBlockTy pe: 0x00000000 [ 4.084] log0: 0x000007da, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.091] datablock: 0x000007d9, lastusedpage: 0x0000000c [ 4.100] Log Block Index 0x00000009, LogicBlockNum: 0x0000003d, LogBlockTy pe: 0x00000000 [ 4.105] log0: 0x000007de, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.112] datablock: 0x000007cd, lastusedpage: 0x00000006 [ 4.121] Log Block Index 0x0000000a, LogicBlockNum: 0x00000073, LogBlockTy pe: 0x00000000 [ 4.126] log0: 0x000007e0, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.132] datablock: 0x0000007a, lastusedpage: 0x00000004 [ 4.141] Log Block Index 0x0000000b, LogicBlockNum: 0x00000030, LogBlockTy pe: 0x00000000 [ 4.146] log0: 0x000007d4, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.153] datablock: 0x000007e4, lastusedpage: 0x00000036 [ 4.162] Log Block Index 0x0000000c, LogicBlockNum: 0x00000230, LogBlockTy pe: 0x00000000 [ 4.167] log0: 0x000007b5, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.173] datablock: 0x000007ee, lastusedpage: 0x00000003 [ 4.182] Log Block Index 0x0000000d, LogicBlockNum: 0x000001eb, LogBlockTy pe: 0x00000000 [ 4.188] log0: 0x000007f0, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.194] datablock: 0x000001f3, lastusedpage: 0x0000003e [ 4.203] Log Block Index 0x0000000e, LogicBlockNum: 0x00000215, LogBlockTy pe: 0x00000000 [ 4.208] log0: 0x000007f4, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.215] datablock: 0x00000032, lastusedpage: 0x0000000e [ 4.224] Log Block Index 0x0000000f, LogicBlockNum: 0x00000216, LogBlockTy pe: 0x00000000 [ 4.229] log0: 0x000007f8, Log1: 0x0000ffff, WriteIndex: 0x00000000 [ 4.235] datablock: 0x000007e9, lastusedpage: 0x0000000a [ 4.241] _RepairLogBlkTbl end [ 4.319] NB1 : init ok [ 4.319] flash init finish [ 4.343] fs init ok [ 4.344] fattype FAT16 [ 4.344] fs mount ok [ 4.349] nand good_block_ratio=944 [ 4.349] storage_type=0 [ 4.395] 0 [ 4.608] WRN:L232(Common/ui/display_interface/display_interface.c):fetch s cript data boot_disp.output_type fail [ 4.613] WRN:L268(Common/ui/display_interface/display_interface.c):fetch s cript data boot_disp.output_mode fail [ 4.623] WRN:L288(Common/ui/display_interface/display_interface.c):fetch s cript data boot_disp.auto_hpd fail [ 4.633] lcd0_para.lcd_used=1 [ 4.636] 0 [ 4.839] 1 [ 5.040] 2 [ 5.241] 3 [ 5.442] 4 [ 5.643] 5 [ 5.844] tv detect, ret = 0 [ 5.844] no device plug [ 5.844] key value = 0 [ 5.847] recovery key high 40, low 4 [ 5.942] show pic finish [ 5.942] load kernel start [ 5.974] load kernel successed [ 5.975] start address = 0x4a000000 [ 6.996] jump to U-Boot 2011.09-rc1 (Jul 31 2013 - 13:09:28) Allwinner Technology CPU: SUNXI Family Board: cubieboard2 DRAM: 1 GiB NAND: [NAND] set nand_good_block_ratio 944 3776 MiB In: serial Out: serial Err: serial --------fastboot partitions-------- -total partitions:5- -name- -start- -size- bootloader : 8000 10000 env : 18000 8000 boot : 20000 10000 rootfs : 30000 400000 UDISK : 430000 330000 ----------------------------------- no misc partition is found Hit any key to stop autoboot: 0 Starting kernel ... <6>Booting Linux on physical CPU 0 <6>Initializing cgroup subsys cpuset <6>Initializing cgroup subsys cpu <5>Linux version 3.4.43+ (matson@ubt) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1u buntu5) ) #1 SMP PREEMPT Thu Aug 29 16:21:36 CST 2013 CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: sun7i <6>Memory cut off: <6> MALI : 0x5c000000 - 0x5fffffff ( 64 MB) <4>Ignoring unrecognised tag 0x00000000 <6>Memory Reserved: <6> SYS : 0x43000000 - 0x4300ffff ( 64 kB) <6> LCD : 0x5a000000 - 0x5bffffff ( 32 MB) Memory policy: ECC disabled, Data cache writealloc <6>sunxi: Allwinner A20 (AW1651/sun7i) detected. <7>On node 0 totalpages: 245760 <7>free_area_init_node: node 0, pgdat c09e2140, node_mem_map d0000000 <7> DMA zone: 512 pages used for memmap <7> DMA zone: 0 pages reserved <7> DMA zone: 65024 pages, LIFO batch:15 <7> Normal zone: 1008 pages used for memmap <7> Normal zone: 111632 pages, LIFO batch:31 <7> HighMem zone: 528 pages used for memmap <7> HighMem zone: 67056 pages, LIFO batch:15 <6>PERCPU: Embedded 7 pages/cpu @d0808000 s7616 r8192 d12864 u32768 <7>pcpu-alloc: s7616 r8192 d12864 u32768 alloc=8*4096<c> <7>pcpu-alloc: <c>[0] <c>0 <c>[0] <c>1 <c> Built 1 zonelists in Zone order, mobility grouping on. Total pages: 243712 <5>Kernel command line: console=ttyS0,115200 init=/init loglevel=5 <6>PID hash table entries: 4096 (order: 2, 16384 bytes) <6>Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) <6>Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) <6>allocated 2097152 bytes of page_cgroup <6>please try 'cgroup_disable=memory' option if you don't want memory cgroups <6>Memory: 448MB 512MB = 960MB total <5>Memory: 924028k/924028k available, 59012k reserved, 270336K highmem <5>Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) lowmem : 0xc0000000 - 0xef800000 ( 760 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc091b000 (9292 kB) .init : 0xc091b000 - 0xc0954dc0 ( 232 kB) .data : 0xc0956000 - 0xc09eab88 ( 595 kB) .bss : 0xc09eabac - 0xc0bb9278 (1850 kB) <6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 <6>Preemptible hierarchical RCU implementation. <6> RCU dyntick-idle grace-period acceleration is enabled. <6> Additional per-CPU info printed with stalls. <6>NR_IRQS:192 <6>Architected local timer running at 24.00MHz. <6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms <2>start_kernel(): bug: interrupts were enabled early <6>Console: colour dummy device 80x30 <6>Calibrating delay loop... <c>1816.98 BogoMIPS (lpj=9084928) <6>pid_max: default: 32768 minimum: 301 <6>Mount-cache hash table entries: 512 <6>Initializing cgroup subsys cpuacct <6>Initializing cgroup subsys memory <6>Initializing cgroup subsys devices <6>Initializing cgroup subsys freezer <6>Initializing cgroup subsys blkio <6>Initializing cgroup subsys perf_event <6>CPU: Testing write buffer coherency: ok <6>CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 <6>hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available <6>Setting up static identity map for 0x405f9290 - 0x405f92e8 CPU1: Booted secondary processor <6>CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 <6>Brought up 2 CPUs <6>SMP: Total of 2 processors activated (3640.52 BogoMIPS). <6>devtmpfs: initialized <6>dummy: <6>NET: Registered protocol family 16 <6>hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. <6>hw-breakpoint: maximum watchpoint size is 8 bytes. <6>[ccu-inf] aw clock manager init <6>[ccu-inf] aw_ccu_init <6>[ccu-inf] script config pll3 to 297MHz <6>[ccu-inf] script config pll4 to 300MHz <6>[ccu-inf] script config pll6 to 600MHz <6>[ccu-inf] script config pll7 to 297MHz <6>[ccu-inf] script config pll8 to 336MHz <6>Init eGon pin module V2.0 <6>bio: create slab <bio-0> at 0 <5>SCSI subsystem initialized <7>libata version 3.00 loaded. <6>usbcore: registered new interface driver usbfs <6>usbcore: registered new interface driver hub <6>usbcore: registered new device driver usb <6>Linux media interface: v0.10 <6>Linux video capture interface: v2.00 <6>Advanced Linux Sound Architecture Driver Version 1.0.25. <6>cfg80211: Calling CRDA to update world regulatory domain <6>Switching to clocksource arch_sys_counter <5>FS-Cache: Loaded <6>CacheFiles: Loaded <6>sw_hcd_host0 sw_hcd_host0: sw_hcd host driver <6>sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1 <6>hub 1-0:1.0: USB hub found <6>hub 1-0:1.0: 1 port detected <6>NET: Registered protocol family 2 <6>IP route cache hash table entries: 32768 (order: 5, 131072 bytes) <6>TCP established hash table entries: 131072 (order: 8, 1048576 bytes) <6>TCP bind hash table entries: 65536 (order: 7, 786432 bytes) <6>TCP: Hash tables configured (established 131072 bind 65536) <6>TCP: reno registered <6>UDP hash table entries: 512 (order: 2, 16384 bytes) <6>UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) <6>NET: Registered protocol family 1 <6>RPC: Registered named UNIX socket transport module. <6>RPC: Registered udp transport module. <6>RPC: Registered tcp transport module. <6>RPC: Registered tcp NFSv4.1 backchannel transport module. <6>Trying to unpack rootfs image as initramfs... <6>Freeing initrd memory: 3548K <6>audit: initializing netlink socket (disabled) <5>type=2000 audit(0.790:1): initialized highmem bounce pool size: 64 pages <5>VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) <5>NFS: Registering the id_resolver key type <6>NTFS driver 2.1.30 [Flags: R/W]. <6>fuse init (API version 7.18) <6>msgmni has been set to 1283 <6>alg: No test for stdrng (krng) <6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) <6>io scheduler noop registered <6>io scheduler deadline registered <6>io scheduler cfq registered (default) <6>sunxi disp driver loaded (/dev/disp api 1.0) <6>Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled <6>[uart]: used uart info.: 0x01 <6>[uart]: serial probe 0 irq 33 mapbase 0x01c28000 <6>sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A [ 0.000000] Ignoring unrecognised tag 0x00000000 [ 0.000000] start_kernel(): bug: interrupts were enabled early <6>console [ttyS0] enabled <6>brd: module loaded <6>loop: module loaded [NAND] nand driver version: 0x2 0x9 PHY_PageReadSpare : too much ecc err,bank 0 block 0,page 7f PHY_PageReadSpare : too much ecc err,bank 0 block 0,page 0 <4>Dev Sunxi softw311 nand magic does not match for MBR 1: softw411 [ 3.946092] Dev Sunxi softw311 nand magic does not match for MBR 1: softw411 <4>Dev Sunxi softw311 nand magic does not match for MBR 2: [ 3.959181] Dev Sunxi softw311 nand magic does not match for MBR 2: <4>Dev Sunxi softw311 nand magic does not match for MBR 3: [ 3.972230] Dev Sunxi softw311 nand magic does not match for MBR 3: <4>Dev Sunxi softw311 nand magic does not match for MBR 4: [ 3.985277] Dev Sunxi softw311 nand magic does not match for MBR 4: <4>Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not p resent. [ 4.000052] Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrup ted or not present. <4>Dev Sunxi softw411 nand: part 1, start 32768, size 65536 [ 4.018446] Dev Sunxi softw411 nand: part 1, start 32768, size 65536 <4>Dev Sunxi softw411 nand: part 2, start 98304, size 32768 [ 4.030136] Dev Sunxi softw411 nand: part 2, start 98304, size 32768 <4>Dev Sunxi softw411 nand: part 3, start 131072, size 65536 [ 4.041883] Dev Sunxi softw411 nand: part 3, start 131072, size 65536 <4>Dev Sunxi softw411 nand: part 4, start 196608, size 4194304 [ 4.053889] Dev Sunxi softw411 nand: part 4, start 196608, size 4194304 <4>Dev Sunxi softw411 nand: part 5, start 4390912, size 3588096 [ 4.066198] Dev Sunxi softw411 nand: part 5, start 4390912, size 3588096 <6> nand: nanda nandb nandc nandd nande [NAND]nand driver, ok. <6>sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP <4>sw_ahci sw_ahci.0: forcing PORTS_IMPL to 0x1 [ 4.090412] sw_ahci sw_ahci.0: forcing PORTS_IMPL to 0x1 <6>sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform m ode <6>sw_ahci sw_ahci.0: flags: ncq sntf pm led clo only pio slum part ccc <6>scsi0 : sw_ahci_platform <6>ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88 <6>sunxi_emac Using mii phy on PortA <6>sunxi_emac Using MAC from SID: 02:8b:06:81:52:22<6>PPP generic driver version 2.4.2 <6>PPP BSD Compression module registered <6>PPP Deflate Compression module registered <6>PPP MPPE Compression module registered <6>NET: Registered protocol family 24 <6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [sw-ehci1]: open clock [sw-ehci1]: Set USB Power ON <6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver <6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2 <6>sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000 <6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00 <6>hub 2-0:1.0: USB hub found <6>hub 2-0:1.0: 1 port detected [sw-ohci1]: open clock <6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver <6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3 <6>sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400 <6>hub 3-0:1.0: USB hub found <6>hub 3-0:1.0: 1 port detected [sw-ehci2]: open clock [sw-ehci2]: Set USB Power ON <6>sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver <6>sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4 <6>sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000 <6>sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00 <6>hub 4-0:1.0: USB hub found <6>hub 4-0:1.0: 1 port detected [sw-ohci2]: open clock <6>sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver <6>sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5 <6>sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400 <6>ata1: SATA link down (SStatus 0 SControl 300) <6>hub 5-0:1.0: USB hub found <6>hub 5-0:1.0: 1 port detected <6>mousedev: PS/2 mouse device common for all mice <6>input: sunxi-ir as /devices/virtual/input/input0 IR Initial OK ===========================hv_keypad_init===================== ========HV Inital =================== <3>tkey_fetch_sysconfig_para: tkey_unused. [ 4.502032] tkey_fetch_sysconfig_para: tkey_unused. hv_keypad_init: after fetch_sysconfig_para: normal_i2c: 0x0. normal_i2c[1]: 0x0 <3>sunxi-rtc sunxi-rtc: Warning: RTC time is wrong! [ 4.519217] sunxi-rtc sunxi-rtc: Warning: RTC time is wrong! <6>sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0 <6>i2c /dev entries driver config i2c gpio with gpio_config api <6>axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected <4>i2c i2c-0: Invalid probe address 0x00 [ 4.546423] i2c i2c-0: Invalid probe address 0x00 <6>I2C: i2c-0: AW16XX I2C adapter <4>i2c i2c-1: Invalid probe address 0x00 [ 4.558226] i2c i2c-1: Invalid probe address 0x00 <6>I2C: i2c-1: AW16XX I2C adapter <4>i2c i2c-2: Invalid probe address 0x00 [ 4.569955] i2c i2c-2: Invalid probe address 0x00 <6>I2C: i2c-2: AW16XX I2C adapter [ace_drv] start!!! [ace_drv] init end!!! [pa_drv] start!!! [pa_drv] init end!!! <6>axp20_ldo1: 1300 mV <6>axp20_ldo2: 1800 <--> 3300 mV at 3000 mV <6>axp20_ldo3: 700 <--> 3500 mV at 2800 mV <6>axp20_ldo4: 1250 <--> 3300 mV at 2800 mV <6>axp20_buck2: 700 <--> 2275 mV at 1425 mV <6>axp20_buck3: 700 <--> 3500 mV at 1300 mV <6>axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV <6>input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-sup plyer.28/input/input1 <4>axp20_ldo2: Failed to create debugfs directory [ 4.646255] axp20_ldo2: Failed to create debugfs directory <6>sunxi_wdt: sunxi WatchDog Timer Driver v1.0 <6>sunxi_wdt: initialized (timeout=23s, nowayout=0) <6>device-mapper: uevent: version 1.0.3 <6>device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat. com <6>device-mapper: multipath: version 1.3.0 loaded <6>device-mapper: multipath round-robin: version 1.0.0 loaded <6>device-mapper: multipath queue-length: version 0.1.0 loaded <6>device-mapper: multipath service-time: version 0.2.0 loaded <6>cpuidle: using governor ladder <6>cpuidle: using governor menu <6>[mmc-msg] sw_mci_init <6>[mmc-msg] MMC host used card: 0x1, boot card: 0x0, io_card 0 <6>[mmc-msg] sdc0 set round clock 400000, src 24000000 <6>[mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(S DR12) dt B <6>[mmc-msg] sdc0 Probe: base:0xf00dc000 irq:64 sg_cpu:ffdf7000(4fc00000) ret 0. [mmc_pm]: failed to fetch sdio card configuration! <6>sunxi_leds driver init <7>Registered led device: green:ph20:led1 <7>Registered led device: blue:ph21:led2 <6>ledtrig-cpu: registered to indicate activity on CPUs <6>usbcore: registered new interface driver usbhid <6>usbhid: USB HID core driver <6>ashmem: initialized <6>logger: created 256K log 'log_main' <6>logger: created 256K log 'log_events' <6>logger: created 256K log 'log_radio' <6>logger: created 256K log 'log_system' <6>IPv4 over IPv4 tunneling driver <6>TCP: bic registered <6>TCP: cubic registered <6>TCP: westwood registered <6>TCP: highspeed registered <6>TCP: hybla registered <6>TCP: htcp registered <6>TCP: vegas registered <6>TCP: veno registered <6>TCP: scalable registered <6>TCP: lp registered <6>TCP: yeah registered <6>TCP: illinois registered <6>Initializing XFRM netlink socket <6>NET: Registered protocol family 10 <6>NET: Registered protocol family 17 <6>NET: Registered protocol family 15 <5>Registering the dns_resolver key type <6>VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4 <5>Registering SWP/SWPB emulation handler <4>axp20_buck2: Failed to create debugfs directory [ 4.847887] axp20_buck2: Failed to create debugfs directory <6>[cpu_freq] INF:-------------------V-F Table------------------- <6>[cpu_freq] INF: voltage = 1450mv frequency = 1008MHz <6>[cpu_freq] INF: voltage = 1425mv frequency = 912MHz <6>[cpu_freq] INF: voltage = 1350mv frequency = 864MHz <6>[cpu_freq] INF: voltage = 1250mv frequency = 720MHz <6>[cpu_freq] INF: voltage = 1150mv frequency = 528MHz <6>[cpu_freq] INF: voltage = 1100mv frequency = 312MHz <6>[cpu_freq] INF: voltage = 1050mv frequency = 144MHz <6>[cpu_freq] INF: voltage = 1000mv frequency = 0MHz <6>[cpu_freq] INF:----------------------------------------------- <6>[cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 1008MHz, min freq: 720MHz <6>registered taskstats version 1 <6>I2C: i2c-3: HDMI I2C adapter <6>disp clks: lcd 74250000 pre_scale 1 hdmi 74250000 pll 297000000 2x 0 <6>Console: switching to colour frame buffer device 160x45 <4>axp20_buck3: incomplete constraints, leaving on [ 5.547341] axp20_buck3: incomplete constraints, leaving on <4>axp20_buck2: incomplete constraints, leaving on [ 5.557695] axp20_buck2: incomplete constraints, leaving on <4>axp20_ldo4: incomplete constraints, leaving on [ 5.567954] axp20_ldo4: incomplete constraints, leaving on <4>axp20_ldo3: incomplete constraints, leaving on [ 5.578115] axp20_ldo3: incomplete constraints, leaving on <4>axp20_ldo2: incomplete constraints, leaving on [ 5.588276] axp20_ldo2: incomplete constraints, leaving on <6>console [netcon0] enabled <6>netconsole: network logging started <6>sunxi-rtc sunxi-rtc: setting system clock to 2010-01-01 00:00:00 UTC (1262304 000) <6>ALSA device list: <6> #0: sunxi-CODEC Audio Codec <6>Freeing init memory: 228K e2fsck 1.41.14 (22-Dec-2010) <6>[mmc-msg] mmc 0 detect change, present 1 /dev/nandd: recovering journal /dev/nandd: clean, 28144/123904 files, 247985/524288 blocks <6>EXT4-fs (nandd): mounted filesystem with ordered data mode. Opts: (null) <6>[mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SD R12) dt B <6>[mmc-msg] sdc0 power on <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>[mmc-msg] sdc0 set round clock 400000, src 24000000 <3>[mmc-err] smc 0 err, cmd 52, RTO [ 6.322938] [mmc-err] smc 0 err, cmd 52, RTO <3>[mmc-err] smc 0 err, cmd 52, RTO [ 6.331458] [mmc-err] smc 0 err, cmd 52, RTO <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <3>[mmc-err] smc 0 err, cmd 5, RTO [ 6.360545] [mmc-err] smc 0 err, cmd 5, RTO <3>[mmc-err] smc 0 err, cmd 5, RTO [ 6.368876] [mmc-err] smc 0 err, cmd 5, RTO <3>[mmc-err] smc 0 err, cmd 5, RTO [ 6.377205] [mmc-err] smc 0 err, cmd 5, RTO <3>[mmc-err] smc 0 err, cmd 5, RTO [ 6.385540] [mmc-err] smc 0 err, cmd 5, RTO <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <4>init: ureadahead main process (75) terminated with status 5 [ 7.383599] init: ureadahead main process (75) terminated with status 5 <30>udevd[175]: starting version 175 <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <4>init: plymouth main process (76) killed by ABRT signal <4>init: plymouth-splash main process (267) terminated with status 2 <6>usbcore: registered new interface driver rtl8192cu <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <6>sunxi_emac sunxi_emac.0: eth0: link down <6>ADDRCONF(NETDEV_UP): eth0: link is not ready <3>mmc0: mmc_sd_init_card() failure (err = -110) [ 16.531674] mmc0: mmc_sd_init_card() failure (err = -110) <3>mmc0: error -110 whilst initialising SD card [ 16.541344] mmc0: error -110 whilst initialising SD card <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGA CY(SDR12) dt B <3>[mmc-err] smc 0 err, cmd 1, RTO [ 16.559878] [mmc-err] smc 0 err, cmd 1, RTO <6>[mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(S DR12) dt B <6>[mmc-msg] sdc0 power off Last login: Fri Jan 1 00:00:09 UTC 2010 on tty1 * Starting web server apache2 Welcome to Linaro 13.06 (GNU/Linux 3.4.43+ armv7l) * Documentation: https://wiki.linaro.org/ root@cubieboard:~# apache2: Could not reliably determine the server's fully qual ified domain name, using 127.0.1.1 for ServerName <4>init: mysql main process (415) terminated with status 1 <4>init: mysql main process ended, respawning [ OK ] <4>init: mysql post-start process (418) terminated with status 1 <4>init: plymouth-stop pre-start process (508) terminated with status 1 <4>init: tty1 main process (509) killed by TERM signal <4>init: mysql main process (518) terminated with status 1 <4>init: mysql main process ended, respawning <4>init: mysql post-start process (519) terminated with status 1 <4>init: mysql main process (587) terminated with status 1 <4>init: mysql respawning too fast, stopped Log with Serial port with hdmi Spoiler U-Boot SPL 2017.01-armbian (Feb 02 2017 - 02:16:24) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2017.01-armbian (Feb 02 2017 - 02:16:24 +0100) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Cubietech Cubieboard2 I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment HDMI connected: Setting up a 1280x800 hdmi console (overscan 0x0) Error: no valid bmp image at 66000000 In: serial Out: vga Err: vga SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@01c50000 Hit any key to stop autoboot: 0 6944 bytes read in 141 ms (47.9 KiB/s) switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2652 bytes read in 166 ms (14.6 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 114 bytes read in 127 ms (0 Bytes/s) 5072030 bytes read in 524 ms (9.2 MiB/s) 5607392 bytes read in 570 ms (9.4 MiB/s) ** File not found /boot/.next ** ** File not found .next ** 46320 bytes read in 327 ms (137.7 KiB/s) ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 5071966 Bytes = 4.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Starting kernel ... <6>Booting Linux on physical CPU 0 <6>Initializing cgroup subsys cpuset <6>Initializing cgroup subsys cpu <5>Linux version 3.4.113-sun7i (root@devel) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #40 SMP PREEMPT Thu Feb 2 01:44:33 CET 2017 CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: sun7i <6>Memory Reserved: <6> SYS : 0x43000000 - 0x4300ffff ( 64 kB) <6> LCD : 0x44000000 - 0x44ffffff ( 16 MB) Memory policy: ECC disabled, Data cache writealloc <6>sunxi: Allwinner A20 (AW1651/sun7i) detected. <7>On node 0 totalpages: 262144 <7>free_area_init_node: node 0, pgdat c0a89440, node_mem_map d0000000 <7> DMA zone: 512 pages used for memmap <7> DMA zone: 0 pages reserved <7> DMA zone: 65024 pages, LIFO batch:15 <7> Normal zone: 1008 pages used for memmap <7> Normal zone: 128016 pages, LIFO batch:31 <7> HighMem zone: 528 pages used for memmap <7> HighMem zone: 67056 pages, LIFO batch:15 <6>PERCPU: Embedded 8 pages/cpu @d0808000 s8256 r8192 d16320 u32768 <7>pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096<c> <7>pcpu-alloc: <c>[0] <c>0 <c>[0] <c>1 <c> Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096 <5>Kernel command line: root=UUID=96527915-88c5-4f1f-b5a5-0b74e0486ea2 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 cgroup_enable=memory swapaccount=1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1 ubootpart=3604cafb-01 ubootsource=mmc sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 <6>PID hash table entries: 4096 (order: 2, 16384 bytes) <6>Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) <6>Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) <6>allocated 2097152 bytes of page_cgroup <6>please try 'cgroup_disable=memory' option if you don't want memory cgroups <6>Memory: 1024MB = 1024MB total <5>Memory: 1003336k/1003336k available, 45240k reserved, 270336K highmem <5>Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) lowmem : 0xc0000000 - 0xef800000 ( 760 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc09e0ef4 (10084 kB) .init : 0xc09e1000 - 0xc0a19040 ( 225 kB) .data : 0xc0a1a000 - 0xc0a91d68 ( 480 kB) .bss : 0xc0a91d8c - 0xc0c66f78 (1877 kB) <6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 <6>Preemptible hierarchical RCU implementation. <6> RCU dyntick-idle grace-period acceleration is enabled. <6> Additional per-CPU info printed with stalls. <6>NR_IRQS:192 <6>Architected local timer running at 24.00MHz. <6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms <2>start_kernel(): bug: interrupts were enabled early <6>Console: colour dummy device 80x30 <6>console [tty1] enabled <6>Calibrating delay loop... <c>1816.98 BogoMIPS (lpj=9084928) <6>pid_max: default: 32768 minimum: 301 <6>Mount-cache hash table entries: 512 <6>Initializing cgroup subsys cpuacct <6>Initializing cgroup subsys memory <6>Initializing cgroup subsys devices <6>Initializing cgroup subsys freezer <6>Initializing cgroup subsys blkio <6>Initializing cgroup subsys perf_event <6>CPU: Testing write buffer coherency: ok <6>CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 <6>hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available <6>Setting up static identity map for 0x407255a8 - 0x40725600 CPU1: Booted secondary processor <6>CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 <6>Brought up 2 CPUs <6>SMP: Total of 2 processors activated (3640.52 BogoMIPS). <6>devtmpfs: initialized <6>dummy: <6>NET: Registered protocol family 16 <6>DMA: preallocated 256 KiB pool for atomic coherent allocations <6>hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. <6>hw-breakpoint: maximum watchpoint size is 8 bytes. <6>[ccu-inf] aw clock manager init <6>[ccu-inf] aw_ccu_init <6>[ccu-inf] script config pll3 to 297MHz <6>[ccu-inf] script config pll4 to 300MHz <6>[ccu-inf] script config pll6 to 600MHz <6>[ccu-inf] script config pll7 to 297MHz <6>[ccu-inf] script config pll8 to 336MHz <6>Init eGon pin module V2.0 <6>bio: create slab <bio-0> at 0 <6>sunxi_gpio driver init ver 1.3 <6>gpiochip_add: registered GPIOs 1 to 2 on device: A1X_GPIO <5>SCSI subsystem initialized <7>libata version 3.00 loaded. <6>usbcore: registered new interface driver usbfs <6>usbcore: registered new interface driver hub <6>usbcore: registered new device driver usb <6>Linux media interface: v0.10 <6>Linux video capture interface: v2.00 <6>Advanced Linux Sound Architecture Driver Version 1.0.25. <6>Switching to clocksource arch_sys_counter <5>FS-Cache: Loaded <6>CacheFiles: Loaded <6>cfg80211: Calling CRDA to update world regulatory domain [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG [sw_hcd0]: usb host driver initialize........ [sw_hcd0]: open_usb_clock [sw_hcd0]: host_init_state = 1 [sw_hcd0]: platform is usb host [sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X), HB-ISO Tx (X), SoftConn) [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 70 <6>sw_hcd_host0 sw_hcd_host0: sw_hcd host driver <6>sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1 <6>hub 1-0:1.0: USB hub found <6>hub 1-0:1.0: 1 port detected wrn: hcd is not enable, need not start hcd [sw_hcd0]: sw_usb_host0_disable start -------sw_hcd0_soft_disconnect--------- is_on = 0, hcd0_set_vbus_cnt = 0 [sw_hcd_host0]: Set USB Power Off wrn: hcd is not enable, need not stop hcd [sw_hcd0]: close_usb_clock [sw_hcd0]: sw_usb_host0_disable end [sw_udc]: udc_init: version 20080411 <6>NET: Registered protocol family 2 <6>IP route cache hash table entries: 32768 (order: 5, 131072 bytes) <6>TCP established hash table entries: 131072 (order: 8, 1048576 bytes) <6>TCP bind hash table entries: 65536 (order: 7, 786432 bytes) <6>TCP: Hash tables configured (established 131072 bind 65536) <6>TCP: reno registered <6>UDP hash table entries: 512 (order: 2, 16384 bytes) <6>UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) <6>NET: Registered protocol family 1 <6>RPC: Registered named UNIX socket transport module. <6>RPC: Registered udp transport module. <6>RPC: Registered tcp transport module. <6>RPC: Registered tcp NFSv4.1 backchannel transport module. <6>Trying to unpack rootfs image as initramfs... <6>Freeing initrd memory: 4952K <6>audit: initializing netlink socket (disabled) <5>type=2000 audit(0.960:1): initialized highmem bounce pool size: 64 pages <5>VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) <6>squashfs: version 4.0 (2009/01/31) Phillip Lougher <5>NFS: Registering the id_resolver key type <6>NTFS driver 2.1.30 [Flags: R/W]. <6>fuse init (API version 7.18) <6>JFS: nTxBlock = 7877, nTxLock = 63018 <6>SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled <6>Btrfs loaded <6>msgmni has been set to 1441 <6>alg: No test for stdrng (krng) <6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) <6>io scheduler noop registered <6>io scheduler deadline registered <6>io scheduler cfq registered (default) <6>sunxi disp driver loaded (/dev/disp api 1.0) <6>Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled <6>[uart]: used uart info.: 0x01 <6>[uart]: serial probe 0 irq 33 mapbase 0x01c28000 <6>sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A <6>console [ttyS0] enabled <7>G2D: drv_g2d_init <6>G2D: Module initialized.major:250 <6>brd: module loaded <6>loop: module loaded [NAND] nand driver version: 0x2 0x9 <4>Dev Sunxi softw311 nand magic does not match for MBR 1: softw411 <4>Dev Sunxi softw311 nand magic does not match for MBR 2: <4>Dev Sunxi softw311 nand magic does not match for MBR 3: <4>Dev Sunxi softw311 nand magic does not match for MBR 4: <4>Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not present. <4>Dev Sunxi softw411 nand: part 1, start 32768, size 65536 <4>Dev Sunxi softw411 nand: part 2, start 98304, size 32768 <4>Dev Sunxi softw411 nand: part 3, start 131072, size 65536 <4>Dev Sunxi softw411 nand: part 4, start 196608, size 4194304 <4>Dev Sunxi softw411 nand: part 5, start 4390912, size 3588096 <6> nand: nand1 nand2 nand3 nand4 nand5 [NAND]nand driver, ok. pwm-sunxi: pwm0 configured - period: 20, duty_percent: 50, duty: 10 <6>sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP <6>ahci: SSS flag set, parallel bus scan disabled <6>sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode <6>sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc <6>scsi0 : sw_ahci_platform <6>ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88 <3>[spi-err] Get spi devices number failed <3>[spi-err] register spi devices board info failed <4>spi: cannot find any using configuration for all 4 spi controllers, return directly! <6>bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) <6>Fixed MDIO Bus: probed <6>sunxi_emac Using mii phy on PortA <6>sunxi_emac Using MAC from SID: 02:8b:06:81:52:22<4>emac_init fetch emac using configuration failed <6>gmac driver is disabled <6>PPP generic driver version 2.4.2 <6>PPP BSD Compression module registered <6>PPP Deflate Compression module registered <6>PPP MPPE Compression module registered <6>NET: Registered protocol family 24 <6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [sw-ehci1]: open clock [sw-ehci1]: Set USB Power ON <6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver <6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2 <6>sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000 <6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00 <6>hub 2-0:1.0: USB hub found <6>hub 2-0:1.0: 1 port detected [sw-ohci1]: open clock <6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver <6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3 <6>sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400 <6>hub 3-0:1.0: USB hub found <6>hub 3-0:1.0: 1 port detected [sw-ehci2]: open clock [sw-ehci2]: Set USB Power ON <6>sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver <6>sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4 <6>sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000 <6>sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00 <6>hub 4-0:1.0: USB hub found <6>hub 4-0:1.0: 1 port detected [sw-ohci2]: open clock <6>ata1: SATA link down (SStatus 0 SControl 300) <6>sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver <6>sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5 <6>sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400 <6>hub 5-0:1.0: USB hub found <6>hub 5-0:1.0: 1 port detected <6>Initializing USB Mass Storage driver... <6>usbcore: registered new interface driver usb-storage <6>USB Mass Storage support registered. <6>usbcore: registered new interface driver ums-alauda <6>usbcore: registered new interface driver ums-cypress <6>usbcore: registered new interface driver ums-datafab <6>usbcore: registered new interface driver ums_eneub6250 <6>usbcore: registered new interface driver ums-freecom <6>usbcore: registered new interface driver ums-isd200 <6>usbcore: registered new interface driver ums-jumpshot <6>usbcore: registered new interface driver ums-karma <6>usbcore: registered new interface driver ums-onetouch <6>usbcore: registered new interface driver ums-realtek <6>usbcore: registered new interface driver ums-sddr09 <6>usbcore: registered new interface driver ums-sddr55 <6>usbcore: registered new interface driver ums-usbat <6>mousedev: PS/2 mouse device common for all mice ===========================hv_keypad_init===================== ========HV Inital =================== <3>tkey_fetch_sysconfig_para: tkey_unused. hv_keypad_init: after fetch_sysconfig_para: normal_i2c: 0x0. normal_i2c[1]: 0x0 <3>sunxi-rtc sunxi-rtc: Warning: RTC time is wrong! <6>sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0 <6>i2c /dev entries driver config i2c gpio with gpio_config api <6>axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected <6>axp_mfd 0-0034: AXP internal temperature monitoring enabled <4>i2c i2c-0: Invalid probe address 0x00 <6>I2C: i2c-0: AW16XX I2C adapter [cedar dev]: not installed! ve_mem_reserve=0 [tt]----- avs_dev driver load... ---- [tt]----- register iomem ---- [tt]--- avs_dev driver load ok!! ----- [ace_drv] start!!! [ace_drv] init end!!! [pa_drv] start!!! [pa_drv] init end!!! <6>axp20_ldo1: 1300 mV <6>axp20_ldo2: 1800 <--> 3300 mV at 3000 mV <6>axp20_ldo3: 700 <--> 3500 mV at 2800 mV <6>axp20_ldo4: 1250 <--> 3300 mV at 2800 mV <6>axp20_buck2: 700 <--> 2275 mV at 1450 mV <3>somebody is trying to set dcdc3 range to (1300000, 1300000) uV <3>but we keep dcdc3 = 1250000 uV from the bootloader <6>axp20_buck3: 700 <--> 3500 mV at 1250 mV <6>axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV <6>input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input0 <4>axp20_ldo2: Failed to create debugfs directory incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) incomplete xfer (0x20) <6>device-mapper: uevent: version 1.0.3 <6>device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com <6>device-mapper: multipath: version 1.3.2 loaded <6>device-mapper: multipath round-robin: version 1.0.0 loaded <6>device-mapper: multipath queue-length: version 0.1.0 loaded <6>device-mapper: multipath service-time: version 0.2.0 loaded <6>cpuidle: using governor ladder <6>cpuidle: using governor menu <6>[mmc-msg] sw_mci_init <6>[mmc-msg] MMC host used card: 0x1, boot card: 0x0, io_card 0 <6>[mmc-msg] sdc0 set round clock 400000, src 24000000 <6>[mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B <6>[mmc-msg] sdc0 Probe: base:0xf05ea000 irq:64 sg_cpu:f05ec000(4fc00000) ret 0. [mmc_pm]: failed to fetch sdio card configuration! <6>sunxi_leds driver init <7>Registered led device: green:ph20:led1 <7>Registered led device: blue:ph21:led2 <6>ledtrig-cpu: registered to indicate activity on CPUs <6>usbcore: registered new interface driver usbhid <6>usbhid: USB HID core driver <6>ashmem: initialized <6>logger: created 256K log 'log_main' <6>logger: created 256K log 'log_events' <6>logger: created 256K log 'log_radio' <6>logger: created 256K log 'log_system' [SPDIF] [spdif_para] isn't defined or spdif_used=0 [I2S-0] Entered sunxi_i2s_init [I2S-0] sunxi-i2s cannot find any using configuration for controllers, return directly! [I2S-0] sndi2s cannot find any using configuration for controllers, return directly! [I2S-0] Entered sunxi_sndi2s_init <6>IPv4 over IPv4 tunneling driver <6>TCP: bic registered <6>TCP: cubic registered <6>TCP: westwood registered <6>TCP: highspeed registered <6>TCP: hybla registered <6>TCP: htcp registered <6>TCP: vegas registered <6>TCP: veno registered <6>TCP: scalable registered <6>TCP: lp registered <6>TCP: yeah registered <6>TCP: illinois registered <6>Initializing XFRM netlink socket <6>NET: Registered protocol family 10 <6>NET: Registered protocol family 17 <6>NET: Registered protocol family 15 [mmc_pm]: No sdio card, please check your config !! <5>Registering the dns_resolver key type <6>VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4 <5>Registering SWP/SWPB emulation handler <4>axp20_buck2: Failed to create debugfs directory <6>[cpu_freq] INF:-------------------V-F Table------------------- <6>[cpu_freq] INF: voltage = 1450mv frequency = 1008MHz <6>[cpu_freq] INF: voltage = 1425mv frequency = 912MHz <6>[cpu_freq] INF: voltage = 1350mv frequency = 864MHz <6>[cpu_freq] INF: voltage = 1250mv frequency = 720MHz <6>[cpu_freq] INF: voltage = 1150mv frequency = 528MHz <6>[cpu_freq] INF: voltage = 1100mv frequency = 312MHz <6>[cpu_freq] INF: voltage = 1050mv frequency = 144MHz <6>[cpu_freq] INF: voltage = 1000mv frequency = 0MHz <6>[cpu_freq] INF:----------------------------------------------- <6>[cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 912MHz, min freq: 720MHz <6>registered taskstats version 1 <6>I2C: i2c-1: HDMI I2C adapter <6>ParseEDID <6>EDID version: 1.3 <6>PCLK=69300000 X 1280 1328 1360 1403 Y 800 803 809 821 fr 60 NN <4>disp_clk: Could not find a matching pll-freq for 69300000 pclk <6>PCLK=79500000 X 1280 1344 1472 1664 Y 768 771 778 798 fr 59 NP <6>Using above mode as preferred EDID mode <4>Unimplemented SVD code 4 <4>Unimplemented SVD code 22 <4>Unimplemented SVD code 17 <4>Unimplemented SVD code 21 <4>Unimplemented SVD code 2 <4>Unimplemented SVD code 6 <4>Unimplemented SVD code 15 <4>disp_clk: Could not find a matching pll-freq for 53900000 pclk <4>disp_clk: Could not find a matching pll-freq for 108100000 pclk <4>disp_clk: Could not find a matching pll-freq for 25150000 pclk <4>disp_clk: Could not find a matching pll-freq for 53900000 pclk <4>disp_clk: Could not find a matching pll-freq for 72650000 pclk <4>disp_clk: Could not find a matching pll-freq for 74600000 pclk <4>disp_clk: Could not find a matching pll-freq for 78800000 pclk <4>disp_clk: Could not find a matching pll-freq for 26150000 pclk <4>disp_clk: Could not find a matching pll-freq for 69300000 pclk <6>Parse_VideoData_Block: VIC 16 support <6>Parse_VideoData_Block: VIC 31 (native) support <6>Parse_VideoData_Block: VIC 20 support <6>Parse_VideoData_Block: VIC 5 support <6>Parse_VideoData_Block: VIC 4 support <6>Parse_VideoData_Block: VIC 19 support <6>Parse_VideoData_Block: VIC 18 support <6>Parse_VideoData_Block: VIC 22 support <6>Parse_VideoData_Block: VIC 17 support <6>Parse_VideoData_Block: VIC 21 support <6>Parse_VideoData_Block: VIC 3 support <6>Parse_VideoData_Block: VIC 7 support <6>Parse_VideoData_Block: VIC 2 support <6>Parse_VideoData_Block: VIC 6 support <6>Parse_VideoData_Block: VIC 1 support <6>Parse_AudioData_Block: max channel=2 <6>Parse_AudioData_Block: SampleRate code=f <6>Parse_AudioData_Block: WordLen code=3 <6>Find HDMI Vendor Specific DataBlock <6>PCLK=69300000 X 1280 1328 1360 1403 Y 800 803 809 821 fr 60 NN <6>PCLK=74250000 X 1920 2448 2492 2640 Y 540 542 547 562 fr 50 PP <6>PCLK=27000000 X 720 736 798 858 Y 480 489 495 525 fr 59 NN <6>PCLK=27000000 X 720 732 796 864 Y 576 581 586 625 fr 50 NN <6>asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok <6>disp clks: lcd 148500000 pre_scale 1 hdmi 148500000 pll 297000000 2x 0 <6>[mmc-msg] mmc 0 detect change, present 1 <6>[mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B <6>[mmc-msg] sdc0 power on <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B <6>[mmc-msg] sdc0 set round clock 400000, src 24000000 <3>[mmc-err] smc 0 err, cmd 52, RTO <3>[mmc-err] smc 0 err, cmd 52, RTO <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B <3>[mmc-err] smc 0 err, cmd 5, RTO <3>[mmc-err] smc 0 err, cmd 5, RTO <3>[mmc-err] smc 0 err, cmd 5, RTO <3>[mmc-err] smc 0 err, cmd 5, RTO <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B <6>Console: switching to colour frame buffer device 240x67 <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B <6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B <6>[mmc-msg] sdc0 set round clock 42857143, src 600000000 <4>axp20_buck3: incomplete constraints, leaving on <4>axp20_buck2: incomplete constraints, leaving on <4>axp20_ldo4: incomplete constraints, leaving on <4>axp20_ldo3: incomplete constraints, leaving on <4>axp20_ldo2: incomplete constraints, leaving on <6>console [netcon0] enabled <6>netconsole: network logging started <3>otg_wakelock_init: No USB transceiver found <6>ALSA device list: <6> #0: sunxi-CODEC Audio Codec <6> #1: sunxi-sndhdmi <6>Freeing init memory: 224K <6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B <6>mmc0: new high speed SDHC card at address e624 <6>mmcblk0: mmc0:e624 SU08G 7.40 GiB <6> mmcblk0: p1 Loading, please wait... starting version 229 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.27.1 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: clean, 48711/91392 files, 258338/365312 blocks done. <6>EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. <30>systemd[1]: System time before build time, advancing clock. <30>systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN) <30>systemd[1]: Detected architecture arm. Welcome to Ubuntu 16.04.1 LTS! <30>systemd[1]: Set hostname to <cubieboard2>. <30>systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. <30>systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. <30>systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). <30>systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. <30>systemd[1]: Listening on Syslog Socket. [ OK ] Listening on Syslog Socket. <30>systemd[1]: Reached target Swap. [ OK ] Reached target Swap. <30>systemd[1]: Reached target Remote File Systems (Pre). [ OK ] Reached target Remote File Systems (Pre). <30>systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ OK ] Set up automount Arbitrary Executab...ats File System Automount Point. <30>systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. <30>systemd[1]: Reached target Encrypted Volumes. [ OK ] Reached target Encrypted Volumes. <30>systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password Requests to Wall Directory Watch. <30>systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. <30>systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. <30>systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. <30>systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. <30>systemd[1]: Created slice System Slice. [ OK ] Created slice System Slice. <30>systemd[1]: Starting Create list of required static device nodes for the current kernel... Starting Create list of required st... nodes for the current kernel... <30>systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. <30>systemd[1]: Starting Nameserver information manager... Starting Nameserver information manager... <30>systemd[1]: Starting Restore / save the current clock... Starting Restore / save the current clock... <30>systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... <30>systemd[1]: Mounting Debug File System... Mounting Debug File System... <30>systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... <30>systemd[1]: Starting Set console keymap... Starting Set console keymap... <30>systemd[1]: Listening on fsck to fsckd communication Socket. [ OK ] Listening on fsck to fsckd communication Socket. <6>Bluetooth: Core ver 2.16 <6>NET: Registered protocol family 31 <6>Bluetooth: HCI device and connection manager initialized <6>Bluetooth: HCI socket layer initialized <6>Bluetooth: L2CAP socket layer initialized <6>Bluetooth: SCO socket layer initialized <6>Bluetooth: HCI UART driver ver 2.2 <6>Bluetooth: HCI H4 protocol initialized <6>Bluetooth: HCI BCSP protocol initialized <6>Bluetooth: HCILL protocol initialized <6>Bluetooth: HCIATH3K protocol initialized <6>Bluetooth: RFCOMM TTY layer initialized <30>systemd[1]: Starting Remount Root and Kernel File Systems... <6>Bluetooth: RFCOMM socket layer initialized <6>Bluetooth: RFCOMM ver 1.11 Starting Remount Root and Kernel File Systems... <6>Bluetooth: HIDP (Human Interface Emulation) ver 1.2 <30>systemd[1]: Reached target Slices. [ OK ] Reached target Slices. <6>input: sunxi-ir as /devices/virtual/input/input1 IR Initial OK <30>systemd[1]: Mounted Debug File System. <6>EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ OK ] Mounted Debug File System. <30>systemd[1]: Mounted POSIX Message Queue File System. [ OK ] Mounted POSIX Message Queue File System. <30>systemd[1]: Started Create list of required static device nodes for the current kernel. [ OK ] Started Create list of required sta...ce nodes for the current kernel. <30>systemd[1]: Started Restore / save the current clock. [ OK ] Started Restore / save the current clock. <30>systemd[1]: Started Load Kernel Modules. [ OK ] Started Load Kernel Modules. <30>systemd[1]: Started Set console keymap. [ OK ] Started Set console keymap. <30>systemd[1]: Started Remount Root and Kernel File Systems. [ OK ] Started Remount Root and Kernel File Systems. <30>systemd[1]: Started Nameserver information manager. [ OK ] Started Nameserver information manager. <30>systemd[1]: Time has been changed <30>systemd[1]: Starting udev Coldplug all Devices... Starting udev Coldplug all Devices... <30>systemd[1]: Starting Load/Save Random Seed... Starting Load/Save Random Seed... <30>systemd[1]: Mounting Configuration File System... Mounting Configuration File System... <30>systemd[1]: Starting Apply Kernel Variables... Starting Apply Kernel Variables... <30>systemd[1]: Mounting FUSE Control File System... Mounting FUSE Control File System... <30>systemd[1]: Starting Create Static Device Nodes in /dev... Starting Create Static Device Nodes in /dev... <30>systemd[1]: Mounted Configuration File System. [ OK ] Mounted Configuration File System. <30>systemd[1]: Mounted FUSE Control File System. [ OK ] Mounted FUSE Control File System. <30>systemd[1]: Started Load/Save Random Seed. [ OK ] Started Load/Save Random Seed. <30>systemd[1]: Started Apply Kernel Variables. [ OK ] Started Apply Kernel Variables. <30>systemd[1]: Started Create Static Device Nodes in /dev. [ OK ] Started Create Static Device Nodes in /dev. <30>systemd[1]: Started udev Coldplug all Devices. [ OK ] Started udev Coldplug all Devices. <30>systemd[1]: Reached target Local File Systems (Pre). [ OK ] Reached target Local File Systems (Pre). <30>systemd[1]: Mounting /tmp... Mounting /tmp... <30>systemd[1]: Starting udev Kernel Device Manager... Starting udev Kernel Device Manager... <30>systemd[1]: Mounted /tmp. [ OK ] Mounted /tmp. <30>systemd[1]: Started Entropy daemon using the HAVEGE algorithm. [ OK ] Started Entropy daemon using the HAVEGE algorithm. <30>systemd[1]: Starting Journal Service... Starting Journal Service... <30>systemd[1]: Reached target Local File Systems. [ OK ] Reached target Local File Systems. <30>systemd[1]: Starting Armbian enhanced Log2Ram... Starting Armbian enhanced Log2Ram... <30>systemd[1]: Starting Set console font and keymap... Starting Set console font and keymap... <30>systemd[1]: Starting Raise network interfaces... Starting Raise network interfaces... <30>systemd[1]: Started udev Kernel Device Manager. [ OK ] Started udev Kernel Device Manager. <30>systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Started Armbian enhanced Log2Ram. [ OK ] Reached target Sound Card. Starting Flush Journal to Persistent Storage... [ OK ] Found device /dev/ttyS0. <46>systemd-journald[197]: Received request to flush runtime journal from PID 1 [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ OK ] Started ifup for eth0. Starting Create Volatile Files and Directories... [ OK ] Started Create Volatile Files and Directories. [ OK ] Started Set console font and keymap. [ OK ] Started Raise network interfaces. [ OK ] Reached target System Time Synchronized. Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Started Daily apt activities. [ OK ] Reached target Timers. Starting Armbian filesystem resize service... [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Reached target Sockets. [ OK ] Reached target Paths. <30>systemd[1]: apt-daily.timer: Adding 6h 45min 18.309851s random time. <30>systemd[1]: apt-daily.timer: Adding 5h 50min 18.302328s random time. <6>sunxi_emac sunxi_emac.0: eth0: link down <6>ADDRCONF(NETDEV_UP): eth0: link is not ready <30>systemd[1]: apt-daily.timer: Adding 1h 49min 37.949470s random time. [ OK ] Started Armbian filesystem resize service. [ OK ] Reached target Basic System. [ OK ] Started Armbian first run tasks. [ OK ] Created slice system-getty.slice. [ OK ] Started D-Bus System Message Bus. Starting LSB: Start/stop sysstat's sadc... [ OK ] Started Regular background program processing daemon. Starting Network Manager... Starting LSB: Starts LIRC daemon.... Starting Permit User Sessions... Starting LSB: Armbian gathering hardware information... Starting Login Service... Starting LSB: Load kernel modules needed to enable cpufreq scaling... Starting Save/Restore Sound Card State... Starting System Logging Service... [ OK ] Started Permit User Sessions. [ OK ] Started System Logging Service. [ OK ] Started Save/Restore Sound Card State. [ OK ] Started LSB: Start/stop sysstat's sadc. [ OK ] Started LSB: Starts LIRC daemon.. [ OK ] Started Network Manager. [ OK ] Started Login Service. Starting Network Manager Script Dispatcher Service... [ OK ] Reached target Network. Starting OpenBSD Secure Shell server... Starting Network Manager Wait Online... Starting Set console scheme... [ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling. [ OK ] Started Set console scheme. [ OK ] Started OpenBSD Secure Shell server. [ OK ] Started Network Manager Script Dispatcher Service. Starting Hostname Service... Starting LSB: set CPUFreq kernel parameters... [ OK ] Started LSB: Armbian gathering hardware information. [ OK ] Started Hostname Service. [ OK ] Started LSB: set CPUFreq kernel parameters. Starting LSB: Set sysfs variables from /etc/sysfs.conf... [ OK ] Started LSB: Set sysfs variables from /etc/sysfs.conf. Starting Authenticate and Authorize Users to Run Privileged Tasks... [ OK ] Started Authenticate and Authorize Users to Run Privileged Tasks. [ OK ] Started Network Manager Wait Online. [ OK ] Reached target Network is Online. Starting LSB: disk temperature monitoring daemon... Starting LSB: Advanced IEEE 802.11 management daemon... Starting /etc/rc.local Compatibility... Starting LSB: Start NTP daemon... [ OK ] Started LSB: Advanced IEEE 802.11 management daemon. [ OK ] Started /etc/rc.local Compatibility. [ OK ] Started LSB: disk temperature monitoring daemon. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS0. [ OK ] Reached target Login Prompts. [ OK ] Started LSB: Start NTP daemon. [ OK ] Reached target Multi-User System. [ OK ] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [ OK ] Started Update UTMP about System Runlevel Changes. Ubuntu 16.04.1 LTS cubieboard2 ttyS0 cubieboard2 login: Edited December 25, 2017 by DrHaos Link to post Share on other sites More sharing options...
vampiro 0 Posted December 27, 2017 Share Posted December 27, 2017 Hello everybody, I have the same problem with an A20-OLinuXino-LIME2 card. I need to connect an HDMI screen for the card to boot. My device was running 24 hours a day for 7 months until the update of this package visibly: u-boot * linux * lime2 *. Link to post Share on other sites More sharing options...
vampiro 0 Posted December 28, 2017 Share Posted December 28, 2017 So for my A20-OLinuXino-LIME2 card to replace the 5.35 version: Package 5.31> http://apt.armbian.com/pool/main/l/linux-u-boot-lime2-next/linux-u-boot-next-lime2_5.31_armhf.deb dpkg -i linux-u-boot-next-lime2_5.31_armhf.deb reboot Enjoy! It works ! Thank you Link to post Share on other sites More sharing options...
Igor 2301 Posted December 30, 2017 Share Posted December 30, 2017 On 25. 12. 2017 at 9:43 PM, DrHaos said: Same problem. Log with Serial port without hdmi without hdmi You are comparing Linux version 3.4.43+ (matson@ubt) and 3.4.113 and both boots well according to your log. I don't think its related. For me, without HDMI it dies this way: U-Boot SPL 2017.11-armbian (Dec 30 2017 - 21:25:48) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2017.11-armbian (Dec 30 2017 - 21:25:48 +0100) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Olimex A20-OLinuXino-LIME2-eMMC I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Card did not respond to voltage select! mmc_init: -95, time 22 *** Warning - MMC init failed, using default environment In: serial Out: serial Err: serial Allwinner mUSB OTG (Peripheral) SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst Net: eth0: ethernet@01c50000 Warning: usb_ether using MAC address from ROM , eth1: usb_ether 6944 bytes read in 151 ms (43.9 KiB/s) ### ERROR ### Please RESET the board ### Last know u-boot was 2017.05, first broken 2017.07 and so far I could not find where is the problem. Will probably try next year Link to post Share on other sites More sharing options...
zador.blood.stained 764 Posted December 30, 2017 Share Posted December 30, 2017 45 minutes ago, Igor said: For me, without HDMI it dies this way: If you can reliably reproduce this, first it needs to be checked with clean, unpatched sources (just in case) and then it needs to be bisected (it can be even automated if the issue can be reproduced when loading the u-boot via FEL) Link to post Share on other sites More sharing options...
Igor 2301 Posted December 31, 2017 Share Posted December 31, 2017 Fixed. Will update patches. Link to post Share on other sites More sharing options...
Toast 23 Posted January 2, 2018 Share Posted January 2, 2018 is the update published yet or is it still on old figure i reinstall if its published so i can get my squeezebox back Link to post Share on other sites More sharing options...
Igor 2301 Posted January 2, 2018 Share Posted January 2, 2018 1 hour ago, Toast said: is the update published yet or is it still on old figure i reinstall if its published so i can get my squeezebox back We place notes if there are any repository updates to the: - www.armbian.com (the last update was 3.December) - twitter Link to post Share on other sites More sharing options...
guidol 277 Posted January 2, 2018 Share Posted January 2, 2018 4 hours ago, Igor said: We place notes if there are any repository updates to the: - www.armbian.com (the last update was 3.December) - twitter @Igor for me it looks like the twitter-version gets more good informational updates Link to post Share on other sites More sharing options...
Jens Bauer 17 Posted January 12, 2018 Share Posted January 12, 2018 Just came across this today (Jan. 12, 2018). This might explain why my CubieBoard2 never started up after a power outage on Christmas Eve 2017 (around 6pm ... 8pm). I wanted to log into my server using SSH. It's located 200 km from where I live, so I don't just go there. It'll cost the price of two CubieBoard2's to get there and back. That means my Armbian torrent server is down for approximately another 5 months. Yesterday, I had another look at the ExpressoBIN and it seems that with a 4x SATA and a USB3.0 Gbit Ethernet (with built-in USB3.0 hub) would be a quite capable server. I know that the ExpressoBIN image is still only in the testing stage, but I'll be quite interested in making the move; especially the day SATA-boot works. Link to post Share on other sites More sharing options...
Igor 2301 Posted January 21, 2018 Share Posted January 21, 2018 This issue should be fixed now with apt update & apt upgrade. Link to post Share on other sites More sharing options...
Evgeny Fadeev 2 Posted January 22, 2018 Share Posted January 22, 2018 21 hours ago, Igor said: This issue should be fixed now with apt update & apt upgrade. I did some experiments about topic issue. I did play with Cubieboard 1 and 2. Cubieboard 1 works fine with Armbian 5.2.5. Cubieboard 2 has starting problem on both Armbian 5.3.5 and 5.2.5 I do not use HDMI interface. I'm just using serial interface with USB - COM. I have used different scenarios to reproduce this issue. BTW I have loaded Cubeez on EMMC. 1. If I'm trying to start from SD card after Cubieboard 2 was unpowered and serial interface unconnected during 10 or more minutes - board unstarted. 2. I start with Cubeez from MMC - board started. After that I put SD card to board and just repower - board started with Armbian good. I can wait a few seconds or few minutes between power off and on and Armbian start good. If board powered off but USB - COM connected, looks like we have powered CPU through contacts TX and RX. And board will started good from SD card even if more period of time power supply unconnected. So looks like some data keeps holding in memory... Link to post Share on other sites More sharing options...
Jens Bauer 17 Posted January 23, 2018 Share Posted January 23, 2018 On January 21, 2018 at 7:29 PM, Igor said: This issue should be fixed now with apt update & apt upgrade. Thank you for digging into this. Unfortunately, my CubieBoard2 has to be kept off for a few more months (likely until June or July), as it's very expensive for me to travel to where it's located. (It would cost approximately one RAM block to go there and back, so I need to be able to stay there for at least a month, before it pays). -But I hope that when I go back there, I have one or two ExpressoBINs so that one can reboot the other if necessary. Link to post Share on other sites More sharing options...
Toast 23 Posted January 23, 2018 Share Posted January 23, 2018 @Igor Seems like the 5.37 update is a dud too. last known good one is 5.31 Link to post Share on other sites More sharing options...
Igor 2301 Posted January 23, 2018 Share Posted January 23, 2018 2 minutes ago, Toast said: @Igor Seems like the 5.37 update is a dud too. last known good one is 5.31 Legacy build ended up in ### ERROR ### Please RESET the board ### ? ... without HDMI and works with HDMI attached? Link to post Share on other sites More sharing options...
Toast 23 Posted January 23, 2018 Share Posted January 23, 2018 Didnt work with HDMI or without.. sorry for sounding dumb its hard to keep track of every OS but how do i get a proper debug log (ie verbose startup ?) Link to post Share on other sites More sharing options...
Toast 23 Posted January 23, 2018 Share Posted January 23, 2018 @Igor seems like its stuck on this, it is a vanilla config no added or modifed sys configs Link to post Share on other sites More sharing options...
Igor 2301 Posted January 23, 2018 Share Posted January 23, 2018 Which bootloader and kernel is this? Link to post Share on other sites More sharing options...
Toast 23 Posted January 23, 2018 Share Posted January 23, 2018 @Igor bootloader: 5.37 kernel: 4.14.0 (think it is alteast forgot to put the version down but it is the lastest available in the repo) Link to post Share on other sites More sharing options...
Igor 2301 Posted January 24, 2018 Share Posted January 24, 2018 Unfortunately, I don't have Cubieboard 2 while my Cubietruck (very similar) boots fine. Can you try this image:https://dl.armbian.com/cubieboard2/archive/Armbian_5.37_Cubieboard2_Debian_stretch_next_4.14.14.7z Link to post Share on other sites More sharing options...
Evgeny Fadeev 2 Posted January 24, 2018 Share Posted January 24, 2018 On 21.01.2018 at 9:29 PM, Igor said: This issue should be fixed now with apt update & apt upgrade. Sure. I can do it now. Link to post Share on other sites More sharing options...
Evgeny Fadeev 2 Posted January 24, 2018 Share Posted January 24, 2018 Igor, it works!!! But something wrong with nmtui. I can't do exit. Forced to do ctrl-c. 1 Link to post Share on other sites More sharing options...
Igor 2301 Posted January 24, 2018 Share Posted January 24, 2018 Strange. I booted Stretch CLI image on my Cubietruck, connected with eth0 ... nmtui-connect and connect to wireless. No problems. http://ix.io/EBc Link to post Share on other sites More sharing options...
Evgeny Fadeev 2 Posted January 24, 2018 Share Posted January 24, 2018 I don't use ethernet connection. I'm using just wifi. I will check once again. BTW. I have executed apt-get install xorg lightdm xfce4 tango-icon-theme gnome-icon-theme Result OK. After that I have executed apt-get install tightvncserver thunar-volman udisks2 gvfs Result negative. Take a look attached. vncserver.txt Link to post Share on other sites More sharing options...
Evgeny Fadeev 2 Posted January 24, 2018 Share Posted January 24, 2018 Ooh, it looks like the problem was on server. Now all loading good. 1 Link to post Share on other sites More sharing options...
Evgeny Fadeev 2 Posted January 24, 2018 Share Posted January 24, 2018 VNC working good. I've attached desktop view. I have got it through remote vnc connection. Desktop.zip Link to post Share on other sites More sharing options...
Evgeny Fadeev 2 Posted January 24, 2018 Share Posted January 24, 2018 Igor, this release has minimal desktop configuration. It has not installed browser? Desktop looks similar as on Orange Pi Zero. It's Debian not Armbian. Link to post Share on other sites More sharing options...
Igor 2301 Posted January 24, 2018 Share Posted January 24, 2018 2 minutes ago, Evgeny Fadeev said: Desktop looks similar as on Orange Pi Zero. It's Debian not Armbian. Armbian desktop is currently available only on desktop images. Working on it to provide a package which would transform CLI image into our desktop. Still some work: https://github.com/armbian/build/blob/master/lib/desktop-ng.sh Only Xenial based desktop is available at the moment, while Stretch you need to build on your own. It looks and acts more or less the same. https://dl.armbian.com/cubieboard2/archive/Armbian_5.37_Cubieboard2_Ubuntu_xenial_next_4.14.14_desktop.7z Link to post Share on other sites More sharing options...
Evgeny Fadeev 2 Posted January 24, 2018 Share Posted January 24, 2018 Thank you, Igor. Спасибо. Link to post Share on other sites More sharing options...
Evgeny Fadeev 2 Posted January 24, 2018 Share Posted January 24, 2018 Igor, just take a look at NMTUI behavior. Maybe I am doing something wrong. Desktop.zip Link to post Share on other sites More sharing options...
