TonyMac32 Posted December 14, 2017 Posted December 14, 2017 Like Le Potato, status of support. Unlike Le Potato, WIP board without official support, 90% of this is incidental to improved mainline support/easy adaptation of fixes for other boards. Current next image kernel: 4.14 Dec. 14 2017: Functions working for me (N=1 sample size) WiFi functioned for me out of the box. HDMI (I added this functionality some time ago) HDMI Sound (Added as of 1:45 Dec.14, not part of any image/build yet) USB Ethernet (no long-term stability testing yet) Jan. 24 2018: small bugfix Board now reports 2 GB RAM instead of 1 July 8, 2018: "Next" kernel (4.17) bugfix HDMI audio repaired (in build system, images not built yet) DVFS better, but still throwing errors [BUG] No USB on K2. 0 Quote
m][sko Posted December 14, 2017 Posted December 14, 2017 So Do you have any idea why odroid c2 don't have working drm driver ( I don't see /dev/dri ) 0 Quote
TonyMac32 Posted December 14, 2017 Author Posted December 14, 2017 On 12/14/2017 at 8:25 PM, m][sko said: So Expand The short answer is no, but I'll take a look at what I have in the K2 / Potato patchset, I haven't looked that closely since more basic functionality was missing/broken. The C2 is presently set up as a different kernel config as well from the other meson64 devices, so I'm not certain where it's development stands, only having access to the K2 and Le Potato, hardware wise. 0 Quote
m][sko Posted December 14, 2017 Posted December 14, 2017 On 12/14/2017 at 8:54 PM, TonyMac32 said: The short answer is no, but I'll take a look at what I have in the K2 / Potato patchset, I haven't looked that closely since more basic functionality was missing/broken. The C2 is presently set up as a different kernel config as well from the other meson64 devices, so I'm not certain where it's development stands, only having access to the K2 and Le Potato, hardware wise. Expand I checked it now and it looks like whole VPU init part is missing 0014-clk-meson-gxbb-Add-VPU-and-VAPB-clockids.patch 0015-clk-meson-gxbb-Add-VPU-and-VAPB-clocks-data.patch 0016-drm-meson-dw_hdmi-Add-support-for-an-optional-extern.patch 0017-drm-meson-Add-missing-VPU-init.patch I will rebuild image with this 4 0 Quote
m][sko Posted December 15, 2017 Posted December 15, 2017 I removed all patch from odroidc2-next and added patch set from meson64-next And /dev/dri is there but [ 0.240500] meson_gx_pwrc_vpu c8100000.sys-ctrl:power-controller-vpu: failed to get reset line it looks like some invalid data in dtsi pwrc_vpu resets 0 Quote
TonyMac32 Posted December 15, 2017 Author Posted December 15, 2017 On 12/15/2017 at 12:38 AM, m][sko said: I removed all patch from odroidc2-next and added patch set from meson64-next And /dev/dri is there but [ 0.240500] meson_gx_pwrc_vpu c8100000.sys-ctrl:power-controller-vpu: failed to get reset line it looks like some invalid data in dtsi pwrc_vpu resets Expand I was about to check for it's existence, but decided to check the forums first. Alright then. As for the patch, these are sort-of-WIP patches from BayLibre, who is working to get GX/L/M mainlined. I expect there will be some rough edges. ;-) Since you completely revised the patch set, make sure you didn't lose anything, I haven't thoroughly gone through the C2 patches to see if anything special is in there that would benefit the other Meson64 boards. 0 Quote
m][sko Posted December 15, 2017 Posted December 15, 2017 this is list of patch set that I use on odroid c2 desktop is working, hdmi too, ethernet too, mali driver loaded fine I didn't check audio 0001-ARM64-dts-meson-gxm-Add-support-for-Khadas-VIM2.patch 0002-ARM64-dts-meson-gxbb-allow-child-devices-on-the-USB-.patch 0003-ARM64-dts-meson-gxbb-odroidc2-take-USB-hub-out-of-re.patch 0004-phy-meson-add-USB3-PHY-support-for-Meson-GXL.patch 0005-usb-host-add-a-generic-platform-USB-roothub-driver.patch 0006-usb-host-xhci-plat-integrate-the-platform-roothub.patch 0007-ARM64-dts-meson-gxl-add-USB-host-support.patch 0008-ARM64-dts-meson-gxm-add-GXM-specific-USB-host-config.patch 0009-ARM64-dts-meson-gx-Enable-USB-on-GXL-and-GXM-boards.patch 0014-clk-meson-gxbb-Add-VPU-and-VAPB-clockids.patch 0015-clk-meson-gxbb-Add-VPU-and-VAPB-clocks-data.patch 0016-drm-meson-dw_hdmi-Add-support-for-an-optional-extern.patch 0017-drm-meson-Add-missing-VPU-init.patch 0018-reset-meson-add-level-reset-support-for-GX-SoC-famil.patch 0019-soc-amlogic-add-Meson-GX-VPU-Domains-driver.patch 0020-soc-amlogic-meson-gx-pwrc-vpu-fix-power-off-when-pow.patch 0021-ASoC-meson-add-meson-audio-core-driver.patch 0022-ASoC-meson-add-register-definitions.patch 0023-ASoC-meson-add-aiu-i2s-dma-support.patch 0024-ASoC-meson-add-initial-i2s-dai-support.patch 0025-snd-meson-activate-HDMI-audio-path.patch 0026-drm-meson-select-dw-hdmi-i2s-audio-for-meson-hdmi.patch 0028-ARM64-dts-meson-gx-add-audio-controller-nodes.patch 0029-ARM64-dts-meson-gxl-add-sound-dai-cells-to-HDMI-node.patch 0031-ARM64-dts-meson-gxl-Take-eMMC-data-strobe-out-of-eMM.patch 0032-ARM64-dts-meson-gx-add-VPU-power-domain.patch 0033-ARM64-dts-meson-gx-Add-HDMI_5V-regulator-on-selected.patch 0034-ARM64-dts-meson-gx-grow-reset-controller-memory-zone.patch 0035-ARM64-dts-odroid-c2-Add-HDMI-and-CEC-Nodes.patch 0036-ARM64-dts-meson-activate-hdmi-audio-HDMI-enabled-boa.patch 1010_GXBB_NanoPi_K2_DTS_HDMI.patch 1020_GXBB_memory_allocation_meson_GX.patch 1030_GXBB_NanoPi_K2_DTS_HDMI_sound.patch 90-01-add_8812au_8821au_with_monitor_mode_and_frame_injection.patch 90-01-add_8812au_8821au_with_monitor_mode_and_frame_injection_update.patch 90-02-add_8814au_with_monitor_mode_and_frame_injection.patch 90-02-add_8814au_with_monitor_mode_and_frame_injection_update.patch arm64_increasing_DMA_block_memory_allocation_to_2048.patch arm64-set-default-target-to-Image.patch aufs.4.14.patch1 bash_to_afterinstall.patch odroidc2-enable-scpi-dvfs.patch packaging-4.x-NEXT-with-postinstall-scripts.patch patch-4.13.10-rt3.patch.disabled 1 Quote
wikrie Posted January 24, 2018 Posted January 24, 2018 On 1/24/2018 at 6:07 AM, TonyMac32 said: Fixed RAM size Expand How do you fix the RAM Size Problem? 0 Quote
TonyMac32 Posted January 24, 2018 Author Posted January 24, 2018 The board the K2 is based from, and so the board support package I started with, #defined ram size explicitly as 1 GB. For the other Amlogic board I have that ram size is detected at boot, so I didn't check on the K2. 1 Quote
constantius Posted April 28, 2018 Posted April 28, 2018 Nanopik2. Works only armbian 5.38 xenial. Lost ethernet connection every time after 10-15 minutes. Wifi works good. Synaptic works on 5.38 . In armbian 5.42 does not..... when you search a package 100% cpu usage system hungs. Armbian 5.38 only chromium works properly. Firefox hungs every time after 5-10 minutes. On Armbian 5.42 no browser works - hungs after 5-10 minutes... ( I think browsers hung when play video i think ) 5.38 and 5.42 no hdmi sound. recognized usb external sound card. Both strange amount of SWAP 789MB. 0 Quote
TonyMac32 Posted May 17, 2018 Author Posted May 17, 2018 There is a memory and firmware allocation issue, unfortunately as a WIP board I haven't spent a ton of time on it, however I should be able to sort it out as I work to end the "blobtastrophy" that was our U-boot situation before. I only have to ask @Neil Armstrong if BayLibre has NanoPi K2 in the list of GXBB devices to get mainlined. Most of the work is done thanks to the Odroid C2, so worst case eventually I'll look at it. 0 Quote
hough Posted May 19, 2018 Posted May 19, 2018 I am new so please forgive me. I had been trying different images on my friendly arm pi k2 and now suddenly i have no hdmi out. i can ssh in but i cant get the display out to work anymore. is this a hardware issue or is there someway to determine if its a software issue? Thanks 0 Quote
Igor Posted May 19, 2018 Posted May 19, 2018 On 5/19/2018 at 2:29 AM, hough said: I had been trying different images on my friendly arm pi k2 and now suddenly i have no hdmi out. Expand Hotplugging might not work but when you boot you should get a screen. I don't recall any troubles of this kind. Try another cable. 0 Quote
constantius Posted May 19, 2018 Posted May 19, 2018 uname -a Linux nanopik2 4.16.0-meson64 #15 SMP PREEMPT Thu Apr 5 16:51:35 CEST 2018 aarch64 aarch64 aarch64 GNU/Linux linux-u-boot 5.38 and armbian-firmware 5.38 linux-xenial-root 5.38., armbian-tools-xenial 5.44, armbian-config 5.45 System is hanging from time to time. I dont know why... every next boot eth0 is loosing connection after 10 minutes, so i disabled et0 and use wifi.... Previous armbians have audio meson audio, now is dummy output - i have to use external usb sound card. I have tried images to ordroid C2 and lapotato but they dont work 0 Quote
TonyMac32 Posted June 6, 2018 Author Posted June 6, 2018 On 5/19/2018 at 6:21 AM, Igor said: Hotplugging might not work Expand I'll check on that. I have the hotplug service on Rockchip (not hardware dependent), and added it to the XU4, should we just move it to bsp/common/lib and add it to the boards that need it? the only other thing in there is 71-axp-power-button.rules at the moment. @constantius If you can build it yourself I've just pushed an update on the K2 to go to u-boot 2018.03, which has a ton of improvements to the handling of memory/device drivers. I need to do some more tests on K2, but since it was broken before I felt the limited testing I've done so far has been sufficient. 0 Quote
Igor Posted June 6, 2018 Posted June 6, 2018 On 6/6/2018 at 1:14 AM, TonyMac32 said: If you can build it yourself Expand In case not, I also enable Bionic Nightly desktop target which will become available once during the day.https://github.com/armbian/build/blob/master/config/boards/nanopik2-s905.csc#L13 1 Quote
TonyMac32 Posted June 6, 2018 Author Posted June 6, 2018 I have discovered that the K2 (S905) appears to not "make up numbers" as the S905X boards do, I'm playing with sysbench. I came to this because it is running significantly hotter than Le Potato, which is S905X. I'm going to switch it to conservative, for the boards with firmwares that "make it up" on the front end this will most likely do nothing, but at least on K2 it will cool it down. 0 Quote
constantius Posted June 6, 2018 Posted June 6, 2018 "Tony MAC.; If you can build it yourself I've just pushed an update on the K2 to go to u-boot 2018.03, which has a ton of improvements to the handling of memory/device drivers. I need to do some more tests on K2, but since it was broken before I felt the limited testing I've done so far has been sufficient". Yes please i will build the image myself 0 Quote
constantius Posted June 6, 2018 Posted June 6, 2018 I have tried to build image... for Nanopik2 bionic ERROR in function source [ main.sh:172 ] [ error ] Board configuration does not define valid kernel config 0 Quote
TonyMac32 Posted June 6, 2018 Author Posted June 6, 2018 Now that is an error I have never seen. I built multiple images last night, but they were all xenial, not that that should impact it... @Igor your thoughts? The board config specifies meson64 like it always has... 0 Quote
Igor Posted June 6, 2018 Posted June 6, 2018 On 6/6/2018 at 12:50 PM, TonyMac32 said: your thoughts? The board config specifies meson64 like it always has... Expand Probably running compilation with wrong parameters ... or using a broken build script. He probably still has the old configuration without -s905 It is working here. 0 Quote
constantius Posted June 6, 2018 Posted June 6, 2018 ./compile.sh BOARD=nanopik2 BRANCH=next KERNEL_ONLY=no RELEASE=bionic xenial the same error 0 Quote
zador.blood.stained Posted June 6, 2018 Posted June 6, 2018 On 6/6/2018 at 2:15 PM, constantius said: BOARD=nanopik2 Expand There is no such config in our current build script: https://github.com/armbian/build/tree/master/config/boards On 6/6/2018 at 1:20 PM, Igor said: Probably running compilation with wrong parameters ... or using a broken build script. He probably still has the old configuration without -s905 Expand Exactly 1 Quote
Igor Posted June 6, 2018 Posted June 6, 2018 If nothing works, start with a clean build. It's much cheaper than abusing our time and energy. 0 Quote
