balbes150 Posted May 23, 2019 Author Posted May 23, 2019 New image 5.87_20190523 Update kernel and add new dtb
Reddwarf Posted May 23, 2019 Posted May 23, 2019 On 5/23/2019 at 1:14 PM, balbes150 said: New image 5.87_20190523 Update kernel and add new dtb Expand Does the 5.2-kernel images have support for mali decoding og video?
cyber Posted May 25, 2019 Posted May 25, 2019 Sorry for double posting. Hope this post is here in the right thread. Hello, I have installed Armbian 5.8.2 (strectch) with with 5.1.0 rc1 kernel (on internal emmc) onto a X96Max box. I want to use the box as NAS to substitute an old dockstar device. NFS and SMB is running well. But i have problems with the USB3 port, a powered USB3 hub disappears under heavy load. And with it all 4 connected drives. The drives are all powered with it's own power supply. The USB2 port runs like in slow motion. Much less then the expected USB2 speed. An unpowered USB2 hub connected to the USB3 port runs stable with all the drives with the expected speed. I think it is a firmware issue. So i have two questions. How can i update the firmware of the box and how can i update the kernel to 5.2 without doing a fresh install into the emmc. I am lucky that the system runs in emmc after a lot of tries. Regards cyber
cyber Posted May 30, 2019 Posted May 30, 2019 I have updated from stretch to buster with apt by modifying the sources.list. Went fine. How to manualy update the kernel out of Armbian_5.87_Aml-s905_Debian_buster_default_5.1.0_20190529, Armbian-config does not find the new kernel. Another issue i have, i cant change the locales. Stuck to LNG=en_US.UTF-8 and most of the LC_.. = "C" Armbian-config and MC e.g. looks wierd of this issue. Regards cyber
jeanrhum Posted May 30, 2019 Posted May 30, 2019 On 5/30/2019 at 8:16 AM, cyber said: Another issue i have, i cant change the locales. Stuck to LNG=en_US.UTF-8 and most of the LC_.. = "C" Expand Hi, I also noticed this issue with other debian images since 2 months. You have to edit manually /etc/environment to set you locales and LC_ALL settings. It seems to be a debian issue, not armbian specific. 1
cyber Posted May 30, 2019 Posted May 30, 2019 Tnx for the information. I did it just a minute before this way and it works :-) Anyhow, tnx a lot.
amirul Posted May 30, 2019 Posted May 30, 2019 On 5/29/2019 at 1:35 PM, balbes150 said: Update image for s9xxx 5.87_20190529 Expand
Carles Posted May 30, 2019 Posted May 30, 2019 Hi, everyone. I've got a X96 Mini 2gb 16gb. Is there a recommended image for this box? One where everything works out of the box? or the most compatible one? I've been able to run Armbian_5.34_S9xxx_Ubuntu_xenial_4.9.40_mate_20171112 using p212, but no WIFI. Any recommended image? If it works fine I would move to installing it on internal memory. Thank you very much.
balbes150 Posted May 31, 2019 Author Posted May 31, 2019 Update image ver 5.88 I received an Ugoos AM6 sample yesterday. My goal is full launch and support for Armbian and LibreELEC. First impressions are very positive. This TV box has a really great metal case (by the way, the price of a good metal case can reach 30-40$). For 90% of use cases, this completely solves the issue with cooling, i.e. the user does not need to modify anything himself. At the same time it solves the problem of protection of components from external radio interference and so solves the problem of radio interference from the component for regular WiFi\BT. 1
Seasalt Posted June 1, 2019 Posted June 1, 2019 On 5/31/2019 at 6:29 AM, balbes150 said: I received an Ugoos AM6 sample yesterday. My goal is full launch and support for Armbian and LibreELEC. First impressions are very positive. Expand Fantastic News RE UGOOS AM6 Can you do some benchmarks against the RK3399. I have the NanoPI M4 RK3399 2GB and am curious about buying a s922x board but if the CPU improvement is less than 10 to 20% then I can not see the point.
balbes150 Posted June 1, 2019 Author Posted June 1, 2019 On 6/1/2019 at 4:38 AM, Seasalt said: Fantastic News RE UGOOS AM6 Can you do some benchmarks against the RK3399. I have the NanoPI M4 RK3399 2GB and am curious about buying a s922x board but if the CPU improvement is less than 10 to 20% then I can not see the point. Expand A General comparison S922 and rk3399 you can see the topics Odroid N2. I am only preparing Armbian and Libreelec images for AM6, when they are ready, I will be able to perform a check. Write specifically what tests you want to learn. But I warn you right away, I have little time for tests, all the free time I spend on developing systems and performing work for customers.
cyber Posted June 1, 2019 Posted June 1, 2019 On 5/31/2019 at 6:29 AM, balbes150 said: Update image ver 5.88 Expand System works well. Armbian-config option "Set CPU .." is broken.
Budiarno Posted June 3, 2019 Posted June 3, 2019 On 5/31/2019 at 6:29 AM, balbes150 said: Update image ver 5.88 Expand Is this a bug on this version? collect2: fatal error: ld terminated with signal 11 [Segmentation fault] compilation terminated. I try to compile oscam on the debian buster, but it always ends up there.
Gossamer Posted June 3, 2019 Posted June 3, 2019 On 3/22/2019 at 12:47 AM, arcps said: To anyone who needs a Linux 4.20/5.0 8189es driver, I successfully compiled one from here https://github.com/jwrdegoede/rtl8189ES_linux/ I installed the headers .deb but needed some files from source kernel, so cloned the https://github.com/150balbes/Amlogic_s905-kernel/ and copied the scripts/mod folder to the /lib/modules/<kernel version>/build/ Then, on the rtl8189es_linux folder make ARCH=arm64 KSRC=/lib/modules/<kernel version>/build/ CONFIG_POWER_SAVING=n To install, for some reason sudo make install not worked, so I typed: sudo install -p -m 644 8189es.ko /lib/modules/<kernel version>/kernel/drivers/net/wireless/ sudo /sbin/depmod -a sudo modprobe 8189es And voilà, wifi working Expand Hey guys, I was trying to do this but I was unable to do it! like this. and I tryed also the example from the armbian docs on how to build a wireless driver. Can anyony one help me with a more detailed or step by step guided help? I have a x96 khadas model 1Gb/8Gb trv box S905. Linux aml 5.0.2-aml-s905 #5.77 SMP PREEMPT Mon Mar 18 12:17:48 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux I got this as the last error: odones@aml:~/rtl8189ES_linux$ sudo make ARCH=arm64 KSRC=/lib/modules/5.0.2-aml-s905/build/ [sudo] password for odones: make ARCH=arm64 CROSS_COMPILE= -C /lib/modules/5.0.2-aml-s905/build/ M=/home/odones/rtl8189ES_linux modules make[1]: Entering directory '/usr/src/linux-headers-5.0.2-aml-s905' make[1]: *** No rule to make target 'modules'. Stop. make[1]: Leaving directory '/usr/src/linux-headers-5.0.2-aml-s905' Makefile:1640: recipe for target 'modules' failed make: *** [modules] Error 2
balbes150 Posted June 3, 2019 Author Posted June 3, 2019 Good news. The latest versions of Armbian and LE work well on Ugoos AM6. By the way, LE is running the sound through HDMI on Odroid N2 and Ugoos AM6. https://yadi.sk/d/OKl5cdXZGEOwpQ 1
Gossamer Posted June 3, 2019 Posted June 3, 2019 On 6/3/2019 at 9:57 AM, talraash said: @Gossamer Don't use " " (space) in folder path. Expand Building modules, stage 2. MODPOST 1 modules /bin/sh: 1: scripts/mod/modpost: Exec format error scripts/Makefile.modpost:92: recipe for target '__modpost' failed make[2]: *** [__modpost] Error 2 Makefile:1556: recipe for target 'modules' failed make[1]: *** [modules] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-5.0.2-aml-s905' Makefile:1640: recipe for target 'modules' failed make: *** [modules] Error 2 this time I got this after some time compiling....
balbes150 Posted June 4, 2019 Author Posted June 4, 2019 New images for S905X2 and S922X (5.88_20190604). The images have support for sound on S905X2 and S922X. But for the sound to work, you need to add settings. In LibreELEC the sound works. The changes that are made to the sound work are in these files. I tried to add them to Armbian, but the sound did not work. If you want to find out what is missing and write the result, I will be very grateful. https://github.com/150balbes/LibreELEC.tv/tree/master/packages/audio/alsa-utils https://github.com/150balbes/LibreELEC.tv/tree/master/projects/Amlogic/filesystem/usr/share/alsa/cards
balbes150 Posted June 5, 2019 Author Posted June 5, 2019 https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s922x/767132-amlogic-s922x-let-s-get-things-interesting?p=774820#post774820 1
sekarpdkt Posted June 5, 2019 Posted June 5, 2019 For A95X, S905X2, 4GB RAM, 32GB ROM, which one shall I use? https://www.banggood.in/A95X-F2-S905X2-4GB-RAM-32GB-ROM-2_4G-WIFI-bluetooth-Android-9_0-4K-TV-Box-p-1470702.html?rmmds=myorder&ID=533601&cur_warehouse=CN I am bit worried, as already bricked one Ugoos M8S :-) Already downloaded Armbian_5.88_Aml-s905_Ubuntu_disco_default_5.1.0_20190530 (which i believe common for all S9xx boxes). Thanks.
balbes150 Posted June 5, 2019 Author Posted June 5, 2019 On 6/5/2019 at 2:15 PM, sekarpdkt said: I am bit worried, as already bricked one Ugoos M8S :-) Expand Are you right ? I have not seen such a model in Ugoos. For S905X2 it is better to use images where the name of this chip (s905x2) is specified. But you can try any of the latest versions, where there is a desired DTB.
sekarpdkt Posted June 5, 2019 Posted June 5, 2019 On 6/5/2019 at 2:42 PM, balbes150 said: Are you right ? I have not seen such a model in Ugoos. For S905X2 it is better to use images where the name of this chip (s905x2) is specified. But you can try any of the latest versions, where there is a desired DTB. Expand Sorry. That one was 905W. So bought this one.
sekarpdkt Posted June 5, 2019 Posted June 5, 2019 (edited) On 6/5/2019 at 2:42 PM, balbes150 said: Are you right ? I have not seen such a model in Ugoos. For S905X2 it is better to use images where the name of this chip (s905x2) is specified. But you can try any of the latest versions, where there is a desired DTB. Expand When I try to update multi boot from android, getting this error. I selected boot/aml_autoscript.zip and it rebooted. Gives this error. I am again writing image to SD card and going to retry. Same SD card for RK3328 devices are working ok. So, not suspecting SD Card. Let me update again after second attempt Update #1: I tried with different SD card, but same error. Edited June 5, 2019 by sekarpdkt Tried with different SD card, same result
hanguofu Posted June 6, 2019 Posted June 6, 2019 Where is /boot/uInitrd ? I tried to build a specific version 5.77 myself . So I checked out https://github.com/150balbes/Build-Armbian and reset the header ( commit ) to f4dfe5f4bcfd261b10954504bc1be0f7537ddb69 ( the one dated 20190323 ) However , the generated img. does not has the uInitrd : ( excerpt from build log ) sent 350.16M bytes received 262.89K bytes 77.87M bytes/sec total size is 355.44M speedup is 1.01 [ .... ] Copying files to /boot directory symlink has no referent: "/home/hanguofu/build_armbian_577/Build-Armbian/.tmp/rootfs-default-aml-s905-bionic-no/boot/uInitrd" 54.52M 100% 302.10MB/s 0:00:00 (xfr#78, to-chk=0/82) The file list at /boot : Mode LastWriteTime Length Name ---- ------------- ------ ---- d----- 2019/6/6 14:34 .Thumbnail d----- 2019/6/6 14:34 Android d----- 2019/6/6 14:34 dtb d----- 2019/6/6 14:34 dtb-5.0.2-aml-s905 d----- 2019/6/6 14:34 extlinux d----- 2019/6/6 13:10 LOST.DIR -a---- 2019/6/1 16:00 829 aml_autoscript -a---- 2019/6/1 16:00 757 aml_autoscript.cmd -a---- 2019/6/1 16:00 651 aml_autoscript.zip -a---- 2019/6/1 16:00 1536 armbian_first_run.txt.template -a---- 2019/6/1 16:00 4882 boot-desktop.png -a---- 2019/6/1 16:00 38518 boot.bmp -a---- 2019/6/1 15:56 160374 config-5.0.2-aml-s905 -a---- 2019/6/1 16:00 521 emmc_autoscript -a---- 2019/6/1 16:00 449 emmc_autoscript.cmd -a---- 2019/6/1 16:01 7658731 initrd.img-5.0.2-aml-s905 -a---- 2019/6/1 16:00 901632 s905x-uboot.img -a---- 2019/6/1 16:00 1765 s905_autoscript -a---- 2019/6/1 16:00 1693 s905_autoscript.cmd -a---- 2019/6/1 15:56 4029826 System.map-5.0.2-aml-s905 -a---- 2019/6/1 16:00 215 uEnv.ini -a---- 2019/6/1 15:56 20090888 vmlinuz-5.0.2-aml-s905 -a---- 2019/6/1 15:56 20090888 zImage Is there sth. I missed ? Should I delete anything and rebuild the img. again ? Regards ! Guofu Han
balbes150 Posted June 7, 2019 Author Posted June 7, 2019 Update images 5.88_20190607. Fixed sound operation via BT.
balbes150 Posted June 7, 2019 Author Posted June 7, 2019 On 6/5/2019 at 3:10 PM, sekarpdkt said: Update #1: I tried with different SD card, but same error. Expand Perhaps your firmware has changed and can not work with the current option to activate multiload. For analyzing the desired output from the console UART parameters ENV (command "printenv"). On 6/6/2019 at 7:35 AM, hanguofu said: Is there sth. I missed ? Should I delete anything and rebuild the img. again ? Expand You must follow the build order exactly.
ajh1999 Posted June 7, 2019 Posted June 7, 2019 Installing to emmc failed I'm really enjoying Armbian on my Nexbox a95x as installed on an SD card. Thanks for the continious improvements on this opportunity. However, when I tried to install Armbian to the emmc, through the Armbian config option, I don't get the option menu and warning screen but immediately all files on the SD card get 'modified' and the SD card gets renamed to emmc. After that, the box can only be booted into Android, SD card boot no longer works. Any idea what I'm doing wrong? I:m using the latest debian build... Thanks.
hanguofu Posted June 8, 2019 Posted June 8, 2019 What is wrong with my compiled kernel ? I played with the official img : Armbian_5.77_Aml-s905_Ubuntu_bionic_default_5.0.2_20190401.img.xz on my usb stick and everything is good. However , a fter I replaced the original zImage with the one I compiled , there are a lot of failed to start services . The compiled kernel is built in the followin g way : git clone https://github.com/150balbes/Amlogic_s905-kernel.git git checkout 20190319 copy the official kernel config : config-5.0.2-aml-s905 to Amlogic_s905-kernel/.config export ARCH=arm64 export CROSS_COMPILE=/home/hanguofu/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- and I built the kernel with a make flag : LOCALVERSION="-aml-s905" The compiled kernel has the same size as the zImage at the Armbian_5.77_Aml-s905_Ubuntu_bionic_default_5.0.2_20190401.img.xz However , the compiled kernel is not as good as the oringinal one . The startup process ( running at the USB stick ) shows a lot of failed services but it finally reached the login prompt. Is there sth. wrong with my built process ?
