MMGen replied to XXXBold's topic in Orange Pi 5
With the official friendlyelec image for Nano Pi M6 (trixie, gnome, 6.1 kernel), I'm getting hardware acceleration with the plain vanilla mpv from Debian: mpv --vo=gpu my.mp4 mpp[2968]: mpp_platform: client 18 driver is not ready! ● Video --vid=1 (h264 1080x1920 59.9998 fps) [default] ● Audio --aid=1 (aac 2ch 44100 Hz 128 kbps) [default] arm_release_ver: g24p0-00eac0, rk_so_ver: 10-616430-r0 mpp[2968]: mpp_info: mpp version: 958803d7 author: Herman Chen 2026-02-26 fix[h265d_rkv]: Fix rkv ref and poc setup overflow Using hardware decoding (rkmpp). AO: [pipewire] 44100Hz stereo 2ch floatp VO: [gpu] 1080x1920 drm_prime[nv12] Everything works wonderfully, and CPU usage is about 25%, compared to 500% for Armbian. Why can't rkmpp be enabled on Armbian to give us harware accel out of the box? @Igor: The overlay link you provided above (mesa-vpu) is broken. And no such overlay exists in the prebuilt images for the Nano Pi M6. Result: still no hardware acceleration for my M6 with Armbian. - Today
@JamesCL This is a fantastic report — thank you, James. 🙏 You've actually confirmed two things I couldn't test on my own hardware… 1) eMMC works (detection + HS200 + read/write)… booting from eMMC is a separate step I haven't wired up yet. 2) 4GB variant confirmed (free -m shows 3830 MB)… The two warnings — you read it right, secure SRAM for OP-TEE/BL31, harmless, cosmetic DTS cleanup I'll tidy up. …that's the most useful kind of report there is. Thanks again! 🙌
I discovered via an only partly working ssh (I thought was WiFi signal strenght issue or so) that a new version of firewalld was installed and also new conf file that had default set to public instead of trusted (what should be fine for LAN only direct traffic). On a typical generic client-only laptop/computer you probably won't notice. Best is to keep that default and add a zone= statement to the NM profile for a specific connection. I have seen the same for systemd-networkd, but not done anything myself with it. Also should not happen on Debian Stable, but rolling distro is another story.
Guation replied to chapeaufer's topic in Allwinner sunxi
Hi xaja34, The patches and all code modifications used to build the 1 GB Cubie A5E images are already present in my repository. I pushed the complete Git commits alongside the prebuilt images that I published in the Releases section. You can find the changes here: radxa-cubie-a5e-armbian-build@202f1bf Best regards, Guation - Yesterday
Mint packages its own Chromium as a deb package, whereas Ubuntu's Chromium is a snap (even `apt install` just installs a snap by default). So, all x64 packages work (and I confirmed by testing xtradeb PPA's x64 package, which works). However, it's also not ARM64 related, as the Chromium ARM64 Snap from Ubuntu 24.04 (I just tested that too) works perfectly fine. It's just the ARM64 deb package from xtradeb that seems broken, which is bizarre.
that looks like a very ambitious undertaking
Kernel 6.12.13 Breaks WiFi on Xiaomi Elish
leynyasha replied to armbian_user_1's topic in Xiaomi Elish
sudo ip link set dev wlp1s0 down sudo ip link set dev wlp1s0 address 02:00:00:00:00:01 sudo ip link set dev wlp1s0 up sudo systemctl restart NetworkManager -
/etc/armbian-release outdated
quaSimba replied to Tinchonet's topic in Software, Applications, Userspace
Same problem here. There are two other (older) threads without a real solution. Has anyone found a fix? -
Hello @BipBip1981, with Kernel 6.18.35 / Armbian 26.5.1, are you using @iav's new DTP patch or the old DTP file? I'm not sure if it makes any difference, so I was curious what you're using.
How to install Armbian on a Netgate SG-2100 (mvebu_armada-37xx)?
Frank SIerra replied to Saitama's topic in Other families
Now that I posted this I revisited the debian install the only thing missing was to add the root partition before booting setenv bootargs root=/dev/sda3 rw Of course the networking does not work as the interfaces on the dtb are for freebsd If I manage to properly build this I will post the steps to create the installer (if possible having network enabled so netinst could be used arm debian has the drivers for the network controllers already compiled mv88e6xxx) and some kind of step by step guide how to -
@Sancho this is really cool, and helped to turn that device from paperweight to usable linux OS. Everything seems "ok", though wifi is jittery at best. I also tried building my own image from the github repo, but after completing the build and repack steps, it fails to send to the device. $ sudo ~/Linux_Upgrade_Tool/upgrade_tool uf output/factory/apftool-rs-patched/Armbian-unofficial_26.08.0-trunk_Linknlink-isg-box-se_bookworm_vendor_6.1.115-factorytool.img Loading firmware... Support Type:3528 FW Ver:c.0.00 FW Time:2026-07-16 02:46:46 Loader ver:1.04 Loader Time:2023-12-13 16:28:48 Start to upgrade firmware... Test Device Start Test Device Success Check Chip Start Check Chip Success Get FlashInfo Start Get FlashInfo Success Prepare IDB Start Prepare IDB Success Download IDB Start Download IDB Success Download Firmware Start Download Firmware Fail I'd love to experiment more with it, but no idea how to get past this part. - Last week
Hello, I am experiencing the same issue: CPU1-3 are offline, and they can't be activated by echo 1 > /sys/devices/system/cpu/cpu1/online or similar commands, the system is responding with "invalid argument" error. I did not notice this nuisance until last week. I would like not having to reinstall the hole system, because it is running my Nextcloud and some other home services. Is there any way to install a kernel that uses all 4 CPU, without having to reinstall the hole system? Will it work, if I just copy /boot from one of the older images onto the sdcard in use?
Unnoficial Image: Download Link enabled CMA, increased CMA to 32mb and enabled rknn Board logs: https://paste.armbian.com/hoqejiqeno Build logs: https://paste.armbian.eu/cekehuhule Installing ffmpeg with encoders and decoders, armhf - armv7: ffmpeg-rockchip-armhf.zip On rv1126 armbian device: cd /media/usb/esp32-rv1126-ffmpeg-rockchip ./install-on-target.sh Verify: /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -encoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -decoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -filters | grep -Ei 'rkrga|rga' Please don't trust pre-compiled files. compile yourself: Use this only if you really want hardware H.264 encode for the go2rtc bridge. A normal upstream FFmpeg build with --enable-rkmpp may expose Rockchip decoders but not the encoder set needed here. For encoder support, use an encoder-capable Rockchip FFmpeg fork such as nyanmisaka/ffmpeg-rockchip, which documents h264_rkmpp, hevc_rkmpp, and mjpeg_rkmpp under encoders. Build FFmpeg With RKMpp Encoders: sudo apt update sudo apt install -y \ git build-essential pkg-config cmake meson ninja-build \ yasm nasm libdrm-dev libudev-dev The MPP and RGA sources below are hosted on Gitee. If git clone prompts with Username for 'https://gitee.com':, sign in with a Gitee account. That prompt is expected for these URLs and is not an FFmpeg/RKMpp build error. Build and install Rockchip MPP runtime and headers: mkdir -p ~/src cd ~/src if [ -d rkmpp/.git ]; then git -C rkmpp pull --ff-only elif [ -e rkmpp ]; then echo "rkmpp exists but is not a git checkout; move it aside or choose a new directory" >&2 exit 1 else git clone -b jellyfin-mpp --depth=1 https://gitee.com/nyanmisaka/mpp.git rkmpp fi cd rkmpp cmake -S . -B build \ -DCMAKE_BUILD_TYPE=Release \ -DCMAKE_INSTALL_PREFIX=/usr/local \ -DBUILD_SHARED_LIBS=ON \ -DBUILD_TEST=OFF cmake --build build -j"$(nproc)" sudo cmake --install build sudo ldconfig Build and install RGA. The FFmpeg fork can use RGA for hardware color conversion/scaling; this is useful because the ESP32 camera enters as raw YUYV and encoders usually want a YUV420/NV12-style input. cd ~/src if [ -d rkrga/.git ]; then git -C rkrga pull --ff-only elif [ -e rkrga ]; then echo "rkrga exists but is not a git checkout; move it aside or choose a new directory" >&2 exit 1 else git clone -b jellyfin-rga --depth=1 https://gitee.com/nyanmisaka/rga.git rkrga fi if [ -d rkrga_build ]; then meson setup --reconfigure rkrga_build else meson setup rkrga rkrga_build \ --prefix=/usr/local \ --libdir=lib \ --buildtype=release \ --default-library=shared \ -Dcpp_args=-fpermissive \ -Dlibdrm=false \ -Dlibrga_demo=false fi meson compile -C rkrga_build sudo meson install -C rkrga_build sudo ldconfig Build FFmpeg to /opt/ffmpeg-rockchip so it does not overwrite the system FFmpeg: set -e cd ~/src if [ -d ffmpeg-rockchip/.git ]; then git -C ffmpeg-rockchip pull --ff-only elif [ -e ffmpeg-rockchip ]; then echo "ffmpeg-rockchip exists but is not a git checkout; move it aside or choose a new directory" >&2 exit 1 else git clone --depth=1 https://github.com/nyanmisaka/ffmpeg-rockchip.git ffmpeg-rockchip fi cd ffmpeg-rockchip make distclean >/dev/null 2>&1 || true # RV1126 is ARMv7-A. Disabling ARMv5TE avoids assembler failures in # libavcodec/arm/mlpdsp_armv5te.S on some armhf toolchains. PKG_CONFIG_PATH=/usr/local/lib/pkgconfig:/usr/local/lib/arm-linux-gnueabihf/pkgconfig:/usr/lib/arm-linux-gnueabihf/pkgconfig \ ./configure \ --prefix=/opt/ffmpeg-rockchip \ --enable-gpl \ --enable-version3 \ --enable-libdrm \ --enable-rkmpp \ --enable-rkrga \ --disable-armv5te \ --enable-shared \ --disable-static \ --disable-doc \ --disable-debug make -j"$(nproc)" sudo make install echo /opt/ffmpeg-rockchip/lib | sudo tee /etc/ld.so.conf.d/ffmpeg-rockchip.conf sudo ldconfig This only disables FFmpeg's CPU hand-written assembly. It does not disable the Rockchip MPP encoder or RGA support, and it is acceptable for this camera path because the input is only 320x240 @ 3 fps. Verify that FFmpeg was built with actual encoders: /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -encoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -decoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -filters | grep -Ei 'rkrga|rga' Expected Result: /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -encoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -decoders | grep -Ei 'rkmpp|mpp' /opt/ffmpeg-rockchip/bin/ffmpeg -hide_banner -filters | grep -Ei 'rkrga|rga' V..... h264_rkmpp Rockchip MPP (Media Process Platform) H264 encoder (codec h264) V..... hevc_rkmpp Rockchip MPP (Media Process Platform) HEVC encoder (codec hevc) V..... mjpeg_rkmpp Rockchip MPP (Media Process Platform) MJPEG encoder (codec mjpeg) V..... av1_rkmpp Rockchip MPP (Media Process Platform) AV1 decoder (codec av1) V..... h263_rkmpp Rockchip MPP (Media Process Platform) H263 decoder (codec h263) V..... h264_rkmpp Rockchip MPP (Media Process Platform) H264 decoder (codec h264) V..... hevc_rkmpp Rockchip MPP (Media Process Platform) HEVC decoder (codec hevc) V..... mjpeg_rkmpp Rockchip MPP (Media Process Platform) MJPEG decoder (codec mjpeg) V..... mpeg1_rkmpp Rockchip MPP (Media Process Platform) MPEG1VIDEO decoder (codec mpeg1video) V..... mpeg2_rkmpp Rockchip MPP (Media Process Platform) MPEG2VIDEO decoder (codec mpeg2video) V..... mpeg4_rkmpp Rockchip MPP (Media Process Platform) MPEG4 decoder (codec mpeg4) V..... vp8_rkmpp Rockchip MPP (Media Process Platform) VP8 decoder (codec vp8) V..... vp9_rkmpp Rockchip MPP (Media Process Platform) VP9 decoder (codec vp9) ... overlay_rkrga VV->V Rockchip RGA (2D Raster Graphic Acceleration) video compositor ... scale_rkrga V->V Rockchip RGA (2D Raster Graphic Acceleration) video resizer and format converter ... vpp_rkrga V->V Rockchip RGA (2D Raster Graphic Acceleration) video post-process (scale/crop/transpose)
Gemini info 😞 ..... In the official, pure Armbian for Banana Pi M2 Pro, enabling SPI is currently extremely difficult (and even impossible for the average user) If you absolutely need the SPI bus for your project: Operating system change: SPI works without any problems on official system images provided directly by the board manufacturer (BPI-M2 Pro Debian/Ubuntu with kernel 4.9 from Amlogic). The manufacturer uses an older but fully modified kernel (Kernel BSP), where all pins are rigidly and correctly assigned. Or... Staying with Armbian: If you must stick with Armbian, it's safer to abandon SPI attempts and—if possible—connect the target device to a free I2C bus or UART serial communication (which work flawlessly in Armbian on this board). But ultimately, the Armbian system developer will have to decide. (Maybe there is some method to enable SPI on the latest Armbian images/firmware?) 🙂 Check https://docs.banana-pi.org/en/BPI-M2_Pro/BananaPi_BPI-M2_Pro Armbian older firmware (bananapi manufacturer's firmware) (bookworm): https://drive.google.com/drive/folders/1DPkc7AHEZVS7PT_yzhNH1Dfuiz99mE0p
I'm facing the same issue and haven't found a way to enable USB 3.0. There doesn't seem to be an overlay like the one in Radxa OS for enabling it. If anyone knows how to get USB 3.0 working, I'd really appreciate the help.
Hi, I can confirm that the issue is present in Armbian v26.5.1 with current kernel versions 6.18.x, and that it is resolved in the edge kernels 6.19.x and 7.1.x. Armbian v26.5.1 - current kernel 6.18.x - NOT OK (many retrans and ~368 Mb/sec): root@odroidtest:~# grep -a --null-data U-Boot /dev/mtd0ro U-Boot SPL 2026.01_armbian-2026.01-S127a-Pb401-H8652-Vab81-Bd0d2-R448a (May 20 2026 - 22:28:40 +0000) root@odroidtest:~# uname -a Linux odroidtest 6.18.35-current-rockchip64 #2 SMP PREEMPT Tue Jun 9 10:28:53 UTC 2026 aarch64 GNU/Linux root@odroidtest:~# iperf3 -c 192.168.0.1 Connecting to host 192.168.0.1, port 5201 [ 5] local 192.168.0.15 port 42940 connected to 192.168.0.1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 43.0 MBytes 360 Mbits/sec 199 26.9 KBytes [ 5] 1.00-2.00 sec 44.9 MBytes 376 Mbits/sec 172 26.9 KBytes [ 5] 2.00-3.00 sec 41.8 MBytes 350 Mbits/sec 188 39.6 KBytes [ 5] 3.00-4.00 sec 45.1 MBytes 379 Mbits/sec 178 33.9 KBytes [ 5] 4.00-5.00 sec 41.9 MBytes 351 Mbits/sec 185 17.0 KBytes [ 5] 5.00-6.00 sec 46.5 MBytes 390 Mbits/sec 168 35.4 KBytes [ 5] 6.00-7.00 sec 42.8 MBytes 359 Mbits/sec 170 24.0 KBytes [ 5] 7.00-8.00 sec 47.0 MBytes 394 Mbits/sec 164 31.1 KBytes [ 5] 8.00-9.00 sec 41.0 MBytes 344 Mbits/sec 178 18.4 KBytes [ 5] 9.00-10.00 sec 44.8 MBytes 375 Mbits/sec 167 15.6 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 439 MBytes 368 Mbits/sec 1769 sender [ 5] 0.00-10.00 sec 438 MBytes 368 Mbits/sec receiver iperf Done. Armbian v26.5.1 - edge kernel 6.19 - OK root@odroidtest:~# grep -a --null-data U-Boot /dev/mtd0ro U-Boot SPL 2026.01_armbian-2026.01-S127a-Pb401-H8652-Vab81-Bd0d2-R448a (May 20 2026 - 22:28:40 +0000) root@odroidtest:~# uname -a Linux odroidtest 6.19.0-edge-rockchip64 #1 SMP PREEMPT Sun Feb 8 21:03:27 UTC 2026 aarch64 GNU/Linux root@odroidtest:~# iperf3 -c 192.168.0.1 Connecting to host 192.168.0.1, port 5201 [ 5] local 192.168.0.15 port 35634 connected to 192.168.0.1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 113 MBytes 950 Mbits/sec 0 1.81 MBytes [ 5] 1.00-2.00 sec 111 MBytes 933 Mbits/sec 0 1.81 MBytes [ 5] 2.00-3.00 sec 112 MBytes 944 Mbits/sec 0 1.81 MBytes [ 5] 3.00-4.00 sec 113 MBytes 947 Mbits/sec 0 1.81 MBytes [ 5] 4.00-5.00 sec 112 MBytes 941 Mbits/sec 0 1.81 MBytes [ 5] 5.00-6.00 sec 111 MBytes 933 Mbits/sec 0 1.81 MBytes [ 5] 6.00-7.00 sec 113 MBytes 948 Mbits/sec 0 1.81 MBytes [ 5] 7.00-8.00 sec 111 MBytes 934 Mbits/sec 1 929 KBytes [ 5] 8.00-9.00 sec 113 MBytes 948 Mbits/sec 0 929 KBytes [ 5] 9.00-10.00 sec 113 MBytes 944 Mbits/sec 0 929 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.10 GBytes 942 Mbits/sec 1 sender [ 5] 0.00-10.00 sec 1.09 GBytes 939 Mbits/sec receiver iperf Done. Armbian v26.5.1 - edge kernel 7.1 - OK root@odroidtest:~# grep -a --null-data U-Boot /dev/mtd0ro U-Boot SPL 2026.01_armbian-2026.01-S127a-Pb401-H8652-Vab81-Bd0d2-R448a (May 20 2026 - 22:28:40 +0000) root@odroidtest:~# uname -a Linux odroidtest 7.1.0-edge-rockchip64 #1 SMP PREEMPT Sun Jun 14 14:58:38 UTC 2026 aarch64 GNU/Linux root@odroidtest:~# iperf3 -c 192.168.0.1 Connecting to host 192.168.0.1, port 5201 [ 5] local 192.168.0.15 port 37256 connected to 192.168.0.1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 114 MBytes 958 Mbits/sec 0 1.72 MBytes [ 5] 1.00-2.00 sec 111 MBytes 933 Mbits/sec 0 1.72 MBytes [ 5] 2.00-3.00 sec 113 MBytes 948 Mbits/sec 0 1.72 MBytes [ 5] 3.00-4.00 sec 112 MBytes 944 Mbits/sec 0 1.72 MBytes [ 5] 4.00-5.00 sec 112 MBytes 936 Mbits/sec 0 1.72 MBytes [ 5] 5.00-6.00 sec 113 MBytes 947 Mbits/sec 0 1.72 MBytes [ 5] 6.00-7.00 sec 112 MBytes 935 Mbits/sec 0 1.72 MBytes [ 5] 7.00-8.00 sec 113 MBytes 945 Mbits/sec 0 1.72 MBytes [ 5] 8.00-9.00 sec 112 MBytes 943 Mbits/sec 0 2.19 MBytes [ 5] 9.00-10.00 sec 112 MBytes 937 Mbits/sec 0 2.19 MBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.10 GBytes 943 Mbits/sec 0 sender [ 5] 0.00-10.00 sec 1.10 GBytes 941 Mbits/sec receiver iperf Done.
Werner replied to Scrumpper's topic in Rockchip CPU Boxes
moved to tvboxes -
This week's updates center on expanded board support, Rockchip and Qualcomm platform maturation, and build system refinements. New hardware coverage grew across multiple SoC families, with the Lubancat 5IO (RK3588), KickPi K3B, Mellow Fly C5 3D printer board, and community support for the Orange Pi Zero 3W (Allwinner A733). The Arduino UNO Q advanced to mainline 7.1 on the edge kernel and gained desktop hardware acceleration via Mesa pinned to Trixie backports, while the BeagleY-AI received ISP, IMX219, and VPAC patches. Companion fixes addressed NVMe/SD boot conflicts on the NanoPi M6, Ethernet on the BigTreeTech CB1, and AIC8800 UART Bluetooth on Orange Pi A733 hardware. Rockchip work concentrated on the YY3588 and CM3588-NAS platforms, with device tree cleanups, a corrected HDMI-RX detect GPIO, and quieter DRM logging for dw-hdmi-qp and dw-dp bridges. Newer bl31, bl32, and DDR blobs landed for RK3576, and stale U-Boot was refreshed fleet-wide to resolve a SWIG build break. On the Qualcomm side, SC8280XP was refactored from a board to a family configuration, and the Radxa Dragon Q8B gained UFS image provisioning, QDL flashing support via the imager, and a mainline 7.1 edge target for the Q6A variant. Build and tooling improvements included a new show-extensions CLI command, a switch from the adduser suite to useradd/groupadd during first login, non-interactive Dpkg conffile handling in chroot, and clang compatibility fixes for carried Rockchip64 patches and SpacemiT RTL8852BS builds. The mainline kernel target advanced to 7.2-rc2, and MGLRU was enabled across sunxi, sunxi64, and sun60iw2 kernel configurations. #Armbian #EmbeddedLinux #Rockchip #Qualcomm #SBC ChangesAdd board: Lubancat 5IO (RK3588). by @lch08 in armbian/build#10029Add kickpi-k3b board and KICKPI vendor image. by @retro98boy in armbian/armbian.github.io#355Arduino UNO Q: bump edge kernel to mainline 7.1. by @SuperKali in armbian/build#10171arduino-uno-q: add BOARD_MAINTAINER, INTRODUCED, KERNEL_TEST_TARGET. by @igorpecovnik in armbian/build#10161arduino-uno-q: enable desktop hardware acceleration in Debian Trixie by pinning Mesa to trixie-backports. by @sdeleeuw in armbian/build#10160arm64: dts: rockchip: fix dynamic dclk for CM3588-NAS. by @rpardini in armbian/linux-rockchip#502arm64: dts: rockchip: overlay: yy3588: disable eDP overlay temporarily. by @SuperKali in armbian/linux-rockchip#509arm64: dts: rockchip: yy3588: drop non-existent SPI NOR flash. by @SuperKali in armbian/linux-rockchip#512arm64: dts: rockchip: yy3588: drop unused wifi_disable regulator. by @SuperKali in armbian/linux-rockchip#510BeagleY-AI Add Patches for ISP + IMX219 & VPAC. by @Grippy98 in armbian/build#10129Bigtreetech CB2: bump u-boot to 2026.04. by @JohnTheCoolingFan in armbian/build#10144boards/youyeetoo-yy3588: name audio outputs on pipewire too. by @SuperKali in armbian/build#10146cli: add show-extensions command to list extension hook points. by @iav in armbian/build#10023config: build and expose q8b UFS images on the debian:trixie base. by @SuperKali in armbian/os#478config: drop radxa-dragon-q6a from apps and community trixie base. by @SuperKali in armbian/os#479desktops: add libspa-0.2-bluetooth for OOB Bluetooth headphone audio. by @igorpecovnik in armbian/configng#948drm/bridge: dw-hdmi-qp: limit DDC i2c retries on NACK. by @SuperKali in armbian/linux-rockchip#513drm/rockchip: dw-dp: ratelimit AUX timeout logging. by @SuperKali in armbian/linux-rockchip#514feat(qdl): serve the board registry from the API. by @SuperKali in armbian/imager#163Feat: Add support for the Mellow Fly C5 3D Printer board. by @deece in armbian/build#9584feat: flash locally-built UFS images over QDL. by @SuperKali in armbian/imager#164firstlogin: use useradd/groupadd instead of the adduser suite. by @igorpecovnik in armbian/build#10127Fix ethernet on BigTreeTech CB1. by @JohnTheCoolingFan in armbian/build#10155fix(chroot): add Dpkg conffile options to prevent interactive prompts. by @Grippy98 in armbian/build#10134fix: stop setting LC_ALL in armbian-lang.sh. by @saschabuehrle in armbian/build#10132generate-build-lists: only gate manual runs on team membership. by @igorpecovnik in armbian/armbian.github.io#353jethome: fix jethub-burn extension: add BETA=yes support. by @adeepn in armbian/build#10152k3-beagle: fix malformed csi0-imx219 overlay patch (bad hunk count). by @igorpecovnik in armbian/build#10136kde-neon: switch to resolute base, then disable (broken). by @igorpecovnik in armbian/configng#949kickpik2b: Change vendor from SoC-level to board-level (KICKPI). by @retro98boy in armbian/build#10143mainline: bump to 7.2-rc2. by @EvilOlaf in armbian/build#10150Makena: add SC8280XP firehose and Radxa Dragon Q8B UFS provisioning. by @SuperKali in armbian/qcombin#3media: rockchip: hdmirx: quiet signal-not-lock polling spam. by @SuperKali in armbian/linux-rockchip#515Meson64: Update Waveshare CM4-IO-BASE-B DTS and add emc2305 fixups for driver to BLEEDINGEDGE branch. by @pyavitz in armbian/build#10169nanopi-m6: fix nvme prevents sd card from booting. by @efectn in armbian/build#10170orangepizero3w: Add community support for Orange Pi Zero 3W (Allwinner A733). by @shkolnik in armbian/build#10103Radxa Dragon Q6A: add mainline 7.1 edge kernel target. by @SuperKali in armbian/build#10162release-targets: add radxa-dragon-q8b with ufs extension. by @SuperKali in armbian/armbian.github.io#354rk3576: newer blobs bl31/bl32/ddr. by @rpardini in armbian/rkbin#49rockchip64: fix clang -Wincompatible-pointer-types-discards-qualifiers in carried patches. by @iav in armbian/build#10140rockchip64: yy3588: fix HDMI-RX detect GPIO to GPIO1_D5. by @SuperKali in armbian/build#10151rockchip: bump stale u-boot to fix the SWIG build break (fleet). by @igorpecovnik in armbian/build#10107SC8280XP: Initial refactor from board to family config. by @HeyMeco in armbian/build#9818SpacemiT: Add a current branch to the K3 and update K1 current kernel source URL. by @pyavitz in armbian/build#10138spacemit: rtl8852bs: guard GCC-only warning flags for clang builds. by @iav in armbian/build#10139sun60iw2: bring up AIC8800 UART Bluetooth on the Orange Pi A733 boards. by @shkolnik in armbian/build#10149sunxi, sunxi64, sun60iw2: enable MGLRU in kernel config. by @ValdikSS in armbian/build#10133sunxi: mellowflyc5: port U-Boot to v2026.07 & enable network boot. by @deece in armbian/build#10165Use relative symbolic links for some BSP files. by @retro98boy in armbian/build#10145View the full article
Link Star H68K is, according to multiple sources, exactly the same as Hinlink H68K. But that's not the problem (yet). I'd been using an old version of RKDevTool (2.84 IIRC) which was unable to load the .img file from the Armbian site, but uninformative as to the nature of the problem. Updating to RKDevTool 3.37 at least yielded an error message when attempting to load the image: Googling this suggests a corrupted download (not the problem here, the SHA sum matches) or a raw .img format rather than the packed .img format expected by RKDevTool. So I compiled an image according to the Armbian Build Framework instructions. Same error message. More Googling suggests that a couple of Linux CLI utilities, upgrade_tool or rkdeveloptool, may be able to flash a raw image to the board's EMMC. More later...
With the aid of Claude.Ai .. v26.5.1 for Rock 5A running Armbian Linux 6.18.35-current-rockchip64 Starting Point is the Radxa DTS needed to add an include ... #include <dt-bindings/soc/rockchip,vop2.h> Modified this section. Changed the compatible string, added the power-supply key and fixed the active area (width and height) dsi0_panel: panel@0 { status = "okay"; compatible = "panel-dsi-simple"; reg = <0>; backlight = <&dsi0_backlight>; power-supply = <&vcc_lcd_mipi0>; vdd-supply = <&vcc_lcd_mipi0>; vccio-supply = <&vcc_1v8_s0>; reset-gpios = <&gpio3 RK_PC1 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&dsi0_lcd_rst_gpio>; prepare-delay-ms = <120>; reset-delay-ms = <120>; init-delay-ms = <120>; enable-delay-ms = <100>; disable-delay-ms = <120>; unprepare-delay-ms = <120>; width-mm = <135>; height-mm = <217>; Modified this section (renamed the endpoint) &mipi_dcphy0 { status = "okay"; }; &route_dsi0 { status = "okay"; connect = <&vp3_out_dsi0>; }; &dsi0_in_vp2 { status = "disabled"; }; &dsi0_in_vp3 { status = "okay"; }; to simply &mipidcphy0 { status = "okay"; }; Added this section / endpoint &vp3 { #address-cells = <1>; #size-cells = <0>; vp3_out_dsi0: endpoint@ROCKCHIP_VOP2_EP_MIPI0 { reg = <ROCKCHIP_VOP2_EP_MIPI0>; remote-endpoint = <&dsi0_in_vp3>; }; }; And then completely redid the i2c touch controller section to be &i2c5 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c5m2_xfer>; clock-frequency = <400000>; #address-cells = <1>; #size-cells = <0>; gt9xx: gt9271@14 { status = "okay"; compatible = "goodix,gt9271"; reg = <0x14>; pinctrl-names = "default"; pinctrl-0 = <>9xx_gpio>; interrupt-parent = <&gpio3>; interrupts = <RK_PC6 IRQ_TYPE_EDGE_FALLING>; irq-gpios = <&gpio3 RK_PC6 GPIO_ACTIVE_HIGH>; reset-gpios = <&gpio3 RK_PC5 GPIO_ACTIVE_HIGH>; touchscreen-size-x = <1200>; touchscreen-size-y = <1920>; AVDD28-supply = <&vcc_tp>; VDDIO-supply = <&vcc_tp>; }; Final DTS is attached. Worked for 6.18.53. I had Claude write a bash script to pull everything and make the required changes and compile the device tree and can make it available, if needed. rock-5a-radxa-display-10fhd.dts
I successfully got the Radxa Display10FHD display working this weekend on Armbian 26.5.1 (Gnome) after extensive Claude AI help in fixing default Radxa DTS. I'll do a separate post / topic for that but it involved refactoring some of the endpoints, adding a missing header and fixing the touchscreen driver name. I used Claude and it was really helpful.
