  2. This week saw significant development activity across the Armbian ecosystem, with numerous enhancements to desktop environment support, including the addition of KDE Neon, KDE Plasma, MATE, and i3-wm, as well as improved branding and menu documentation. The desktop module was refactored for greater modularity and YAML-driven configuration, alongside fixes for theming and package removal tracking. Hardware support expanded with new device trees for NanoPC-T6 LTS Plus and Gateway DK, plus initial support for Arduino UNO Q (Qualcomm QRB2210) and additional USB Ethernet drivers. The build system received updates for kernel versions and distribution releases, notably bumping Ubuntu from plucky/noble to resolute. Automation and audit scripts were improved for reliability and scope, and documentation was updated to reflect the new tier model and branding. Overall, these changes strengthen Armbian's usability, hardware compatibility, and developer tooling. ChangesAdd board_introduced field to reusable boards and JSON output. by @igorpecovnik in armbian/armbian.github.io#272Add desktop descriptions and disable host check. by @igorpecovnik in armbian/configng#802Add Desktops menu header documentation. by @igorpecovnik in armbian/configng#803Add Gateway DK board image and Mono vendor logo. by @igorpecovnik in armbian/armbian.github.io#273Add i3-wm desktop support with branding. by @igorpecovnik in armbian/configng#811Add INTRODUCED property to all board configs. by @igorpecovnik in armbian/build#9634Add KDE Neon desktop support (Ubuntu only). by @igorpecovnik in armbian/configng#814Add KDE Plasma desktop support. by @igorpecovnik in armbian/configng#812Add MATE desktop support with branding and menu. by @igorpecovnik in armbian/configng#810add more special extensions. by @efectn in armbian/actions#16Add python3-yaml to package dependencies. by @igorpecovnik in armbian/configng#816Add support for Arduino UNO Q (Qualcomm QRB2210). by @SuperKali in armbian/build#9623arduino-uno-q: fix CI build by fetching qcombin at image creation time. by @SuperKali in armbian/build#9642arduino-uno-q: install USB gadget scripts unconditionally in BSP. by @SuperKali in armbian/build#9649arm64: dts: rockchip: add NanoPC-T6 LTS Plus device tree. by @igorpecovnik in armbian/linux-rockchip#462audit: allow Claude to write edits + stash execution log. by @igorpecovnik in armbian/configng#836audit: fix git-dir error and path references for claude-code-action. by @igorpecovnik in armbian/configng#832audit: fix git-dir, output ref, and bump max-turns to 30. by @igorpecovnik in armbian/configng#833audit: scope bot PR to YAML changes only. by @igorpecovnik in armbian/configng#835audit: skip status:unsupported DEs + relocate audit scripts. by @igorpecovnik in armbian/configng#826audit: switch to claude-code-action with OAuth token. by @igorpecovnik in armbian/configng#831audit_apply: handle calls larger than the per-minute budget. by @igorpecovnik in armbian/configng#828audit_apply: throttle + retry around the per-minute rate limit. by @igorpecovnik in armbian/configng#827bianbu: bump noble snapshot from v2.2 to v2.3. by @igorpecovnik in armbian/configng#839Bump rockchip armhf edge kernel to 7.0.0. by @paolosabatino in armbian/build#9635config/distributions: plucky -> eos, resolute -> supported. by @igorpecovnik in armbian/build#9657desktops: disable cinnamon on armhf. by @igorpecovnik in armbian/configng#823desktops: enable armhf for XFCE, MATE, i3-wm, Xmonad, Enlightenment, Cinnamon. by @igorpecovnik in armbian/configng#820desktops: enable riscv64 for XFCE, MATE, i3-wm, Xmonad, Enlightenment, Cinnamon. by @igorpecovnik in armbian/configng#822desktops: optional APT pin preferences in repo block. by @igorpecovnik in armbian/configng#838desktops: ship YAML/parser/branding assets in the .deb. by @igorpecovnik in armbian/configng#817desktops: tier system, install/remove correctness, and a pile of small fixes. by @igorpecovnik in armbian/configng#824docs: rewrite Desktops-header.md for the tier model. by @igorpecovnik in armbian/configng#825extensions: skip git fetches during config-dump-json. by @igorpecovnik in armbian/build#9648feat: add device tree editor module. by @igorpecovnik in armbian/configng#797feat: add QDL flash support for Qualcomm EDL devices. by @SuperKali in armbian/imager#127feat: track desktop packages for clean removal. by @igorpecovnik in armbian/configng#799Fix desktop module variable scoping and cleanup. by @igorpecovnik in armbian/configng#796gateway-dk-ask: build kernel modules in-tree for CI compatibility. by @tomazzaman in armbian/build#9650Increase timeout for unit tests from 15 to 30 minutes. by @igorpecovnik in armbian/configng#800initialize: add script-wide debug_log and --debug flag. by @igorpecovnik in armbian/configng#818json-generation: fix some app edge cases. by @efectn in armbian/armbian.github.io#276mainline: bump to 7.0-rc7. by @EvilOlaf in armbian/build#9637Mono gateway dk. by @tomazzaman in armbian/build#9640nightly: bump Ubuntu release from plucky/noble to resolute. by @igorpecovnik in armbian/armbian.github.io#278Optimize Cinnamon desktop and fix theming. by @igorpecovnik in armbian/configng#805Refactor desktop module: YAML-driven, modular architecture. by @igorpecovnik in armbian/configng#815rockchip: add rtl8152 and dm9601 usb ethernet. by @netrunnereve in armbian/build#9638rockchip: RK3506: Increase DMA coherent pool. by @vidplace7 in armbian/build#9636SLO: fixing few sentences in Slo language that sounds weird. by @igorpecovnik in armbian/website#1u-boot: v2026.04 (final) fixes and bumps for some boards. by @rpardini in armbian/build#9654Update Desktops header: add Imager URL and auto-login note. by @igorpecovnik in armbian/configng#804Update theme colors and fonts to match armbian.com. by @igorpecovnik in armbian/documentation#902View the full article
  3. This week saw significant development activity across the Armbian ecosystem, with numerous enhancements to desktop environment support, including the addition of KDE Neon, KDE Plasma, MATE, and i3-wm, as well as improved branding and menu documentation. The desktop module was refactored for greater modularity and YAML-driven configuration, alongside fixes for theming and package removal tracking. Hardware support expanded with new device trees for NanoPC-T6 LTS Plus and Gateway DK, plus initial support for Arduino UNO Q (Qualcomm QRB2210) and additional USB Ethernet drivers. The build system received updates for kernel versions and distribution releases, notably bumping Ubuntu from plucky/noble to resolute. Automation and audit scripts were improved for reliability and scope, and documentation was updated to reflect the new tier model and branding. Overall, these changes strengthen Armbian's usability, hardware compatibility, and developer tooling. ChangesAdd board_introduced field to reusable boards and JSON output. by @igorpecovnik in armbian/armbian.github.io#272Add desktop descriptions and disable host check. by @igorpecovnik in armbian/configng#802Add Desktops menu header documentation. by @igorpecovnik in armbian/configng#803Add Gateway DK board image and Mono vendor logo. by @igorpecovnik in armbian/armbian.github.io#273Add i3-wm desktop support with branding. by @igorpecovnik in armbian/configng#811Add INTRODUCED property to all board configs. by @igorpecovnik in armbian/build#9634Add KDE Neon desktop support (Ubuntu only). by @igorpecovnik in armbian/configng#814Add KDE Plasma desktop support. by @igorpecovnik in armbian/configng#812Add MATE desktop support with branding and menu. by @igorpecovnik in armbian/configng#810add more special extensions. by @efectn in armbian/actions#16Add python3-yaml to package dependencies. by @igorpecovnik in armbian/configng#816Add support for Arduino UNO Q (Qualcomm QRB2210). by @SuperKali in armbian/build#9623arduino-uno-q: fix CI build by fetching qcombin at image creation time. by @SuperKali in armbian/build#9642arduino-uno-q: install USB gadget scripts unconditionally in BSP. by @SuperKali in armbian/build#9649arm64: dts: rockchip: add NanoPC-T6 LTS Plus device tree. by @igorpecovnik in armbian/linux-rockchip#462audit: allow Claude to write edits + stash execution log. by @igorpecovnik in armbian/configng#836audit: fix git-dir error and path references for claude-code-action. by @igorpecovnik in armbian/configng#832audit: fix git-dir, output ref, and bump max-turns to 30. by @igorpecovnik in armbian/configng#833audit: scope bot PR to YAML changes only. by @igorpecovnik in armbian/configng#835audit: skip status:unsupported DEs + relocate audit scripts. by @igorpecovnik in armbian/configng#826audit: switch to claude-code-action with OAuth token. by @igorpecovnik in armbian/configng#831audit_apply: handle calls larger than the per-minute budget. by @igorpecovnik in armbian/configng#828audit_apply: throttle + retry around the per-minute rate limit. by @igorpecovnik in armbian/configng#827bianbu: bump noble snapshot from v2.2 to v2.3. by @igorpecovnik in armbian/configng#839Bump rockchip armhf edge kernel to 7.0.0. by @paolosabatino in armbian/build#9635config/distributions: plucky -> eos, resolute -> supported. by @igorpecovnik in armbian/build#9657desktops: disable cinnamon on armhf. by @igorpecovnik in armbian/configng#823desktops: enable armhf for XFCE, MATE, i3-wm, Xmonad, Enlightenment, Cinnamon. by @igorpecovnik in armbian/configng#820desktops: enable riscv64 for XFCE, MATE, i3-wm, Xmonad, Enlightenment, Cinnamon. by @igorpecovnik in armbian/configng#822desktops: optional APT pin preferences in repo block. by @igorpecovnik in armbian/configng#838desktops: ship YAML/parser/branding assets in the .deb. by @igorpecovnik in armbian/configng#817desktops: tier system, install/remove correctness, and a pile of small fixes. by @igorpecovnik in armbian/configng#824docs: rewrite Desktops-header.md for the tier model. by @igorpecovnik in armbian/configng#825extensions: skip git fetches during config-dump-json. by @igorpecovnik in armbian/build#9648feat: add device tree editor module. by @igorpecovnik in armbian/configng#797feat: add QDL flash support for Qualcomm EDL devices. by @SuperKali in armbian/imager#127feat: track desktop packages for clean removal. by @igorpecovnik in armbian/configng#799Fix desktop module variable scoping and cleanup. by @igorpecovnik in armbian/configng#796gateway-dk-ask: build kernel modules in-tree for CI compatibility. by @tomazzaman in armbian/build#9650Increase timeout for unit tests from 15 to 30 minutes. by @igorpecovnik in armbian/configng#800initialize: add script-wide debug_log and --debug flag. by @igorpecovnik in armbian/configng#818json-generation: fix some app edge cases. by @efectn in armbian/armbian.github.io#276mainline: bump to 7.0-rc7. by @EvilOlaf in armbian/build#9637Mono gateway dk. by @tomazzaman in armbian/build#9640nightly: bump Ubuntu release from plucky/noble to resolute. by @igorpecovnik in armbian/armbian.github.io#278Optimize Cinnamon desktop and fix theming. by @igorpecovnik in armbian/configng#805Refactor desktop module: YAML-driven, modular architecture. by @igorpecovnik in armbian/configng#815rockchip: add rtl8152 and dm9601 usb ethernet. by @netrunnereve in armbian/build#9638rockchip: RK3506: Increase DMA coherent pool. by @vidplace7 in armbian/build#9636SLO: fixing few sentences in Slo language that sounds weird. by @igorpecovnik in armbian/website#1u-boot: v2026.04 (final) fixes and bumps for some boards. by @rpardini in armbian/build#9654Update Desktops header: add Imager URL and auto-login note. by @igorpecovnik in armbian/configng#804Update theme colors and fonts to match armbian.com. by @igorpecovnik in armbian/documentation#902View the full article
  4. Yesterday
  5. I encountered the same issue. When I used the Orange Pi 3B image based on the 6.18 kernel, USB was not available, but when using the 6.1 vendor image, USB worked.
  6. @Nick A Thank you! That would be very helpful.⭐
  7. @Sergioclr Search the forums for "PL2303HXA". I think it will work. After you compile your build, check build/cache/sources/u-boot-worktree/u-boot*; you should find root_key.pem there
  8. Nice @Kevin su. my results with the eth0 working was similar to yours. but after an "ip link set down dev eth0" got those lower. whatever. Its alive after all!
  9. Kernel 7.0 is out with broad hardware enablement and performance updates. Collabora contributed 227 patches from 24 developers, spanning major graphics work, multimedia fixes, and substantial enablement for Rockchip and MediaTek. View the full article
  10. Good afternoon. I bought a NanoPi R76s rev. 2 (3GB RAM + 0 EMMC). It works fine with the manufacturer's firmware. However, it doesn't boot on Armbian (26.02.1). I assume rev. 2 isn't supported. Is it possible to add support? Armbian_26.2.1_Nanopi-r76s_noble_vendor_6.1.115_gnome_desktop.img.xz --- my build from tag 26.02.1: (log https://paste.armbian.com/poduzitifu ) --- vendor ubuntu boot log https://drive.google.com/file/d/1OZqZk48LsbSzFz63fcqMKVp5YkhyNOoT/view?usp=drive_link (rk3576-sd-ubuntu-noble-gnome-desktop-6.1-arm64-20260403.img.gz)
  11. Video here: https://drive.google.com/file/d/1kv2QVMMgRizKrjZIGVVMYK3QxkswTA9K/view?usp=sharing Hi there, I have the following stack: Model: ROC-RK3588S-PC V12 (Linux) SoC: Rockchip RK3588 GPU: Mali-G610 (Panfrost/Panfork) Kernel: 6.1.0-1025-rockchip OS: Ubuntu 24.04.1 LTS (Joshua-Riek image v2.4.0) Mesa: Panfork 23.0.5 (git221210 — December 2022) Chromium: 114.0.5735.35 (rkmpp7 from jjriek/rockchip-multimedia PPA) Display: HDMI-1, 1920x1080@60Hz The problem: I'm running a kiosk application in Chromium that plays video fullscreen. The display is physically mounted in portrait mode (9:16), so I need to rotate the output 270°. When rotation is applied, a visible vertical line artifact appears running from top to bottom, approximately 5cm from the right edge of the screen. Without rotation, the image is perfectly clean — no artifacts at all. What I've tried (all failed to fix the issue): CSS rotation (current method): Using transform: rotate(270deg) on the body element. The line artifact appears consistently. xrandr rotation: xrandr --output HDMI-1 --rotate left — same vertical line artifact appears. Kernel DRM rotation: Added video=HDMI-A-1:1920x1080@60,rotate=270 to kernel cmdline in extlinux.conf. Parameter is visible in /proc/cmdline but has no effect — Rockchip DRM driver does not support the rotate parameter. Chromium flags (tested individually and in combinations): --disable-gpu-compositing — moved the line to the center of the screen --disable-gpu-rasterization / --disable-gpu-vsync — made it worse --use-gl=egl — no effect --enable-gpu-rasterization --enable-zero-copy — no effect --default-tile-width=1920 --default-tile-height=1080 — no effect --gpu-rasterization-msaa-sample-count=0 — no effect --force-device-scale-factor=1 — no effect --use-gl=angle --use-angle=gles-egl --use-cmd-decoder=passthrough — crashed Chromium CSS GPU optimization properties: Tested translateZ(0), backface-visibility: hidden, will-change: transform on the rotation container — no effect on the artifact. Chromium 132 upgrade: Installed chromium 132.0.6834.159-1~deb12u1+rkmpp from liujianfeng1994/chromium PPA. The vertical line remained, and video playback became unstable (freezing). Reverted to Chromium 114. Mesa upgrade to Ubuntu noble-updates 25.2.8: Removed Panfork PPA and installed standard Ubuntu Mesa 25.2.8. GPU fell back to llvmpipe (software rendering) — no Panfrost support for Mali-G610 in standard Mesa. Display showed tearing in the center. Reverted to Panfork 23.0.5. Conclusion: The artifact appears with any rotation method (CSS, xrandr, kernel) and persists across Chromium versions and various GPU flags. This strongly suggests the issue is in the Panfork Mesa / Panfrost compositing layer when handling rotated output on Mali-G610. Has anyone encountered this issue? Is there a known fix or workaround? Would upgrading to Panthor (with kernel 6.10+ or the 6.1 backport) potentially resolve this? Any help would be greatly appreciated.
  12. What's new in armbian-config desktops Pick how much desktop you want — at install time and after Three tiers (minimal / mid / full) instead of one monolithic install. Minimal = DE + display manager + a terminal (~500 MB). Mid adds a browser and everyday apps (~1 GB). Full adds office + creative tools (~2.5 GB). And you can move between tiers later — armbian-config knows the delta and only adds or removes what changed, no reinstall. Clean uninstall, every time Every install records a manifest of exactly which packages it added. Removal undoes only those — packages that were already on the system before you installed the desktop stay put. No more "I uninstalled XFCE and lost half my system." One YAML per desktop, no per-distro hacks Each DE is a single declarative file in tools/modules/desktops/yaml/. Adding or maintaining a desktop no longer means editing scripts; you describe what you want and the engine figures out releases, arches, browsers, and overrides. Adding a new desktop is a YAML edit and a parser smoke test, not a hunt through bash. Same desktop, every supported distro and arch Per-release and per-arch overrides handle the awkward edges: missing packages on armhf, the riscv64 ports that lag behind, the package that got renamed in Ubuntu noble. Same YAML works on Debian bookworm/trixie and Ubuntu noble across amd64 / arm64 / armhf / riscv64. Smart browser selection The literal token browser resolves to the right package per platform automatically — Chromium where it exists, Epiphany on platforms where Chromium is broken, Firefox-ESR on Debian riscv64. No more bug reports about "Chromium won't install on RISC-V." Custom vendor archives, done right Optional repo: block per DE with full support for: signed-by GPG keyring (no apt-key), per-release suite paths (e.g. SpacemiT's per-snapshot bianbu archive), multi-suite fan-out (one archive, six deb lines for security/updates/customization channels), wider component lists than main, and APT pin preferences in the same place. Removed cleanly on uninstall. Auto-login that doesn't trash your config Enable / disable autologin for gdm3, sddm, or lightdm via in-place sed edits — your WaylandEnable=false and other customizations stay intact. Branches on ID=ubuntu from /etc/os-release, so it writes to the right file (Debian's daemon.conf vs Ubuntu's custom.conf) without guessing from the codename. A weekly AI driven self-audit catches drift A scheduled workflow scans the YAML matrix against armbian/build's supported releases and the live Debian/Ubuntu archives — flags releases not yet covered, flags packages that no longer exist upstream — then opens a draft PR with proposed YAML fixes. Dead packages and missing releases stop accumulating silently. armbian-config --api module_desktops User documentation: https://docs.armbian.com/User-Guide_Armbian-Config/System/#desktop
  13. This was discussed some time ago. Everybody has the same problem with the 2.5Gb interface. The best you can do is to switch to linux 6.6.xx, replace the dtb, update the firmware in /lib/firmware/rtl_nic and run a script in /etc/rc.local (see here).
  14. use balena etcher or rufus, would work just fine! also you can use Hqnicolas have provided earlier, use a USB to TTL converter. works great if nothing works
  15. After over five years of development and collaboration across the Open Source community, mainline Linux support for Rockchip RK3588's video capture hardware has finally landed. View the full article
  16. Last week
  17. @Jugo Slaven it seems you are running Android not Armbian. These forums are for Armbian Linux not Android. You should ask your question at a site that deals with Android.
  18. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  19. The only thing I could manage to get information from was this: I had to rewrite the SPI-flash and now I see: Not sure if this helps: Btw, this is the output when I was using the official OrangePI Ubuntu distro:
  20. Problem solved. Rather than using an electrical connection I overcame the issue mechanically. When the board was mounted in the box I drilled a hole directly opposite the switch and inserted an old self propelling biro which I cut down to the right length. I left the spting in place but removed the latching mechanism in the lid. Pressing the top of the biro activated the switch🤪
  21. Looks like you are right. Did not want to modify uboot to make it understand f2fs , so i had to move /boot to ext4 and keep rest of / on f2fs. Now it boots. Thx for help.
  22. Hello, good afternoon. I'm using a translator, so I apologize if it's not clear. I have an Orange Pi 5 Plus SBC which I have Android installed on the m2 drive. I install Armbian on a microSD card. I don't remember what problem I was having, but I had to format the SPI Flash. After that, the Armbian version worked fine. Also, after formatting the SPI Flash, my microphone stopped working on Android (it works on Armbian). Could this be due to formatting the SPI Flash? Thank you.
  23. It will only work for h265, as that is the only hardware decoder available in the Pi 5. So it won't help you with for instance YouTube, as they use VP9 and AV1 (or you can force h264 with a browser plugin). You can try Firefox. https://bugzilla.mozilla.org/show_bug.cgi?id=1833354 Or change some of the flags in Chromium, but it feels as if they keep changing, so you might find other suggested flags all over the internet. You can set the mentioned flags in: chrome://flags/ https://bbs.archlinux.org/viewtopic.php?id=244031
  24. savznkvo
    @sven-ola it works with official ubuntu image and with debian 13 image from romanrm, so this ssd is 100% works
  25. Then it should not be an issue to find somebody from the community to come up with support. From official POV we do not add new boards without some sort of funding. Our resources are simply too limited.
  26. hey i seem ho have same exact issues have you found any fix yet!
  27. From an OS's point of view, only a Mesa build with Teflon and Rocket driver support is needed (available since Mesa 25.3). Inferences can then be executed with ai-edge-litert. I have been experimenting with this for some time on all my devices equipped with Rockchip RK3588/RK3588s.
  28. @Rajiv Singh where is this dkms package? thank you!
