  2. @pochopsp You would need to use the information in that readme and patch and apply it to a newer u-boot (i.e port the patch to a newer u-boot) and build then a newer u-boot than the 2020.07 currently shipped.
  4. Addendum: How To Include Devicetree Overlays Since Grub does not have devicetree overlay support, we need to merge the desired overlay(s) in with the main devicetree (.dtb) file we're using. Part of the device-tree-compiler package is this command: fdtoverlay An example from Armbian 25.8.1 Trixie running on the Orange Pi 5 Plus, to enable GPU acceleration in the Vendor (6.1) kernel. In sudo: cd /boot/dtb-6.1.115-vendor-rk35xx/rockchip fdtoverlay -i rk3588-orangepi-5-plus.dtb -o rk3588-orangepi-5-plus-panthor.dtb overlay/rockchip-rk3588-panthor-gpu.dtbo Of course, to have that load automatically from grub using the modification above, you'll need to rename (or move) the original .dtb to something else, then rename the one with the -panthor suffix to the original name to take its place.
  5. I think it will run out or RAM... but try it anyway
  6. @Werner, I merged the Panthor overlay with the Vendor devicetree using the fdtoverlay command (since I'm using efi/grub instead of u-boot), and now Vendor kernel with GPU is an option!! Thank you so much!! https://forum.armbian.com/topic/55266-add-devicetree-to-grub-automatically-heres-how/#findComment-226070 Question: I've noticed (at least in Debian on the Orange PI 5 Plus) that the Vendor kernel (with Panthor GPU overlay) works well under X and Wayland, but the Edge kernel only works well under Wayland. With the Edge kernel under X, the GPU is "there", but it doesn't seem to offer any kind of acceleration. I noticed this the first time I tried the Edge kernel several months ago, and it's still the case. Do you know of a fix for this as well?
  7. @DiplDi I was doing some experiments on Armbian 25.8.1 Trixie, and I decided to do a quick try of installing the XFCE desktop (along with some others): sudo apt-get -o APT::Install-Recommends="true" install task-xfce-desktop It works under X, but not under Wayland. I found out that its Wayland support is experimental, and that if you install the labwc package, that will get it running (very very badly) under Wayland. But it does work well under X. It's possible a different wayland compositor (than labwc) will work better? I also tried with the Vendor kernel (with the Panthor GPU overlay), and the edge kernel. Edge GPU performs seemingly not at all under X, but vendor with Panthor overlay performs well in X. I initially logged in via the SDDM display manager, but I switched to LightDM, and that worked as well, although with a hiccup.
  8. Hello, I just apt upgrade-ed my Armbian 25.5 from mid-August to 25.8.1 and it doesn't start after software reboot. It is usually headless, I plugged it into a monitor and all I get is a uboot logo in the top left corner. No message, nothing. The board is the Rockpi 4A. The system is on eMMC 😩 What do I do now to at least roll back ? At worst make a browsable copy of the eMMC ? Thanks! Antoine
  9. That change is already merged into Armbian for the orange pi zero LTS. It was such a long time ago, I don't remember how to use it right now. https://github.com/armbian/build/blob/9ef5b99b220c5e77b55514136e025008c16ccbfd/patch/kernel/archive/sunxi-6.12/patches.armbian/enable-TV-Output-on-OrangePi-Zero-LTE.patch#L8 https://github.com/armbian/build/commit/41260ac309b487d241fec97ffbdeced730bc2d04 Partial progress log https://forum.armbian.com/topic/22226-orange-pi-zero-lts-tv-out-in-2022/#findComment-162035
  10. Is it the 128x160 1.8" red screen? Combine the knowledge of https://forums.raspberrypi.com/viewtopic.php?t=380704&hilit=ST7735S#p2275556 and https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/ To use the panel-mipi-dbi-spi driver, which is more universal for SPI screens Warning: you will not get the spidev, and the linux OS will handle all the rendering. Also, X11 may have a problem with Linux 6.14, unless someone fixes a bug
  11. I'm not sure what this adds? I saw a user struggling to get it working, I managed to get it working, so thought I would give my steps that they may help other people. I apologize. I have not read what you wrote earlier. Please write whatever you see fit your work can be very useful. Success to you in your endeavor.
  12. Abandoned vendor-provided BSP roadblocks can be overcome when mainline Open Source projects like the Linux kernel are integrated directly. Get your upstreamed BSPs from day one. View the full article
  13. I tested the upstream Debian and I only got 4GB as well, I don't know if that was stable or not. Actually some upstream Debian images I tried didn't work at all at first. Then I upgraded the firmwares on my board, following these instructions: https://forum.rvspace.org/t/visionfive-2-debian-image-released/994/75 Bu I was more precise than that, first I used the sdcard image and fimware files from 2.6.0 (said to work in that page): https://github.com/starfive-tech/VisionFive2/releases/tag/VF2_v2.6.0 Note: I had no display, I ran the firmware update commands over SSH. Then I rebooted, using the sdcard image from 2.11.5 (arbitrary chosen): https://github.com/starfive-tech/VisionFive2/releases/tag/VF2_v2.11.5 But I used the latest (5.11.3) firmware files to update the firmware: https://github.com/starfive-tech/VisionFive2/releases/tag/JH7110_VF2_515_v5.11.3 After that, I flased the latest image (202409), for sdcard: starfive-jh7110-202409-SD-minimal-desktop-wayland.img The whole 8GB is displayed and everything looks stable, the board is running since 9 hours without problem. But one problem is that this Debian image is based on an now-old Debian Trixie/Sid snapshot, which is painful to deal whit. I'll try again the Armbian image later to see if the firmware update fixed the memory size problem and the stability.
  14. S905W2 I didn't find a solution to my problem on the forum.
  15. Armbian 25.8.1 Noble XFCE (mainline Kernel: 6.16.6-edge-rockchip64) + PanVk - mesa 23.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.7 (https://ryanfortner.github.io/box64-debs/) + wine-10.15-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.15) + DXVK-stripped v2.7.1 ~30fps@720p Dark Souls 2 - SotFS
  16. I've just been through this process myself. Those instructions are not close to working, and I'm not sure they ever worked. I have documented how I got the LCD display working on the T3-Mini here:
  17. Yesterday
  18. My brief experience in trying out a USB-C display wasn't great. I was never able to get any video at all until / unless I was fully booted into an OS, and even then it was shotty. Both USB-C connectors on the Orange PI 5 Plus (on mine anyway) are poorly made and intermittently lose connection if moved around at all. I recently read that's a real problem with SBCs in general that get their power over USB-C... clearly a very poor design. I also read somewhere that a similar board required proprietary drivers for USB-C display output to function. My experience indicates at least something like that likely applies here as well. Dysfunctional hardware design.
  19. @laibsch thank you for reaching out. I apologize for the delay in responding. I want to inform you that I am actively seeking assistance from the community and am willing to contribute by developing code to address the issues I've observed on this board. However, despite my efforts to engage with the community, I have not received any responses and am not sufficiently experienced to thoroughly troubleshoot and resolve these problems on my own. Although I have some knowledge of programming languages, I am not well-versed in Linux. For example, this morning, I suggested a potential solution to the Bluetooth issue on the IRC channel but received no feedback. For the GPU, it appears that acceleration is now present, as the CPU is no longer at 100%. However, I am unable to set the resolution to 4K without encountering screen artifacts, and I can only achieve Full HD resolution.
  20. Next week, Collabora will be taking part in the 2025 edition X.Org Developer's Conference! Taking place in Vienna, our engineers will be presenting 6 talks and a workshop to help local students discover the embedded graphics stack! Join us! View the full article
  21. Kernel packages comes from the same (main) repository. This won't cause you problems, if you upgrade from bookworm to trixie, but we can't guarantee for packages that comes from Debian. You might try this way: https://docs.armbian.com/User-Guide_Armbian-Config/System/#stable-distro-upgrade Note that you might need to download updated Armbian key: wget -qO - https://apt.armbian.com/armbian.key | gpg --dearmor | \ sudo tee /usr/share/keyrings/armbian.gpg > /dev/null cat << EOF | sudo tee /etc/apt/sources.list.d/armbian-config.sources > /dev/null Types: deb URIs: https://github.armbian.com/configng Suites: stable Components: main Signed-By: /usr/share/keyrings/armbian.gpg EOF
  22. Hard to tell without any logs whatsoever In general it works on x86 since a few month ago I used it to move the OS from an old NUC-like pc from sd to built-in emmc which was flawless (besides I had to get rid of Ventoy since it messes up Armbian boot).
  23. Last week
  24. has any progress been made toward fixing this
  25. here is my dts for android rkr7.1 sdk 6.1.141 with everything working usb2 host usb3 otg/host hdmi ethernet 3.5mm spdif IR + wakeup wifi BT collect info for adding your remote to dts echo 1 > /sys/module/rk_pwm_remotectl/parameters/code_print m9.dts
  26. Hi @jock, Thanks for suggestion, led me to dig down and found your update on R29 GPIO. Since multitool hdmi was working, I used it's bash to mount emmc and add overlays=led-config7 to armbianEnv.txt. It worked!!!! Thanks a lot for all your contribution!
  27. I don't know and I won't spend time investigating. We cannot provide support for 3rd party images/software. Moved to off-topic since OP is not using Armbian.
  28. You just have to create the nginx folder in /var/log with owner www-data (it is not created automatically): mkdir /var/log/nginx chown -R www-data:www-data /var/log/nginx systemctl restart nginx
