  2. It would save you (and others) a lot of time if you would have a USB serial console/debug cable and with verbosity=7 in armbianEnv.txt I actually only got triggered because of 'Btrfs' in the topic title, but it might be a totally unrelated issue. Also note that besides the kernel provided .dtb file (is in /boot/dtb but and same file is also somewhere in /usr/lib/linux-image-<KVER> ), U-Boot has its own DeviceTree version/variant. Might be older, newer, broken, incomplete, vendor, mainline, patched, custom. So what U-Boot is loaded/used, also is important to know. Extract that info from SD-card where the U-Boot blob is written (sits at fixed sector offset, between partition table and 1st partition). You can look into U-Boot writing scripts to get to know the offset for Allwinner, but something like this is quicker:
  4. thanks, it is settled now, apt-get update behaves normally.
  5. sven-ola
    Hello @VBB, those log snippets show no reason why system can freeze. Recompling bcmdhd internal SDIO Wifi driver on kernel updates works as intended. Disabling lightdm and enabling gdm3 is part of the spacemit-gpu-addon.sh you run - gdm3 is the display-manager to use if you want a DM with Wayland (b/c only Wayland works with those closed source GPU stuff). If it's stuck, just rise the loglevel= in /boot/extlinux/extlinux.conf for more output or simply download one of my images and retry running that script (Image -> https://privat-in.de under "Downloads"). HTH // Sven-Ola
  6. meco any update on this? dual NVME also does not work on non vendor kernels as well as second HDMI port.
  7. Yesterday
  8. @Sergioclr I remember someone was able to get Ethernet working by changing 16 to 0. There's two locations ethernet-phy@16 and reg = <16>; +&mdio1 { + rmii_phy: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; +};
  9. 45mbps Down / 4.5mbps UP with device more closer to the router root@rk322x-box:~# speedtest Retrieving speedtest.net configuration... Testing from Vivo (REDACTED)... Retrieving speedtest.net server list... Selecting best server based on ping... Hosted by Redel Internet (Balneário Camboriu) [424.68 km]: 23.94 ms Testing download speed................................................................................ Download: 45.84 Mbit/s Testing upload speed...................................................................................................... Upload: 4.46 Mbit/s
  10. This likely means the I2S overlay doesn’t exist yet. Someone would need to implement it and add it upstream (or just here to Armbian build framework). You can try enabling it manually via the Device Tree editor: https://docs.armbian.com/User-Guide_Armbian-Config/System/#device-tree-editor No guarantees it will work — hardware descriptions are often incomplete or inaccurate, and that’s outside our control.
  11. Does sway eat a lot of RAM? Can it be used fine in a 640x480 display? I've been staying with my labwc setup, because it's known to be minimalistic. Orange Pi Zero3 and Raspberries with 1GB RAM can run it fluidly.
  12. Hi, I upgraded to the stable version of Debian (Trixie) Armbian Linux 6.18.23-current-rockchip64. And the USB 3.0 port stopped working. Other USB 2.0 works fine. orangepi3b:~$ lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp. JMS578 SATA 6Gb/s Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub orangepi3b:~$ sudo dmesg|grep usb6 [ 2.474823] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.18 [ 2.474852] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.474867] usb usb6: Product: Generic Platform OHCI controller [ 2.474881] usb usb6: Manufacturer: Linux 6.18.23-current-rockchip64 ohci_hcd [ 2.474893] usb usb6: SerialNumber: fd840000.usb orangepi3b:~$ sudo dmesg|grep usb7 [ 2.416665] usb usb7: We don't know the algorithms for LPM for this host, disabling LPM. [ 2.416917] usb usb7: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18 [ 2.416940] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.416956] usb usb7: Product: xHCI Host Controller [ 2.416969] usb usb7: Manufacturer: Linux 6.18.23-current-rockchip64 xhci-hcd [ 2.416983] usb usb7: SerialNumber: xhci-hcd.1.auto [ 5.223412] usb usb7-port1: connect-debounce failed
  13. @humanus Which A7S image are you using? Mind sharing it? I'm only getting a Mixed score of 1700+ with my script on the official A7S image.
  14. I updated to my self-build 6.6.135 [1] kernel today. I soft-rebooted, and the issue did not reappear. Hopefully it stays this way. [1] https://github.com/armbian/build/pull/9705
  15. Also interested in this. Was able to install using `sudo ./sunxi-fel -p spiflash-write 0 u-boot-sunxi-with-spl.bin`, where the u-boot image came from the Armbian I downloaded (scp'd it off). That makes use of a patch submitted to the sunxi-tools repo (https://github.com/linux-sunxi/sunxi-tools/pull/232), which does actually work. It is quite happy to boot the image from SD card, and runs even when there is no SD card installed, which is great! However, I don't see any SPI or mtdblock messages in dmesg, and naturally, none exist in /dev/. Am I missing something? Or is SPI not enabled currently for some reason?
  16. Native Steam Client For ARM Linux https://interfacinglinux.com/community/sbcsoftware/native-steam-client-for-arm-linux/ I have tested: the Steam client works (+ Proton11-ARM64 works). The memory usage was much reduced. Non-Steam games also work
  17. Upstream support for rk3588 is still wip. For desktop usage I suggest to either try "edge" which may have the feature you want already merged in or try "vendor" kernel which is based on Rockchip BSP.
  18. @DaBo Thanks for sharing this. Are you able to run Armbian on this? Is LAN, HDMI, etc working fine on this?
  19. Hello, good evening. I'll check again tomorrow; I don't remember which version of Armbian I have installed, but the microphone works without any problems in Armbian. I simply installed the Armbian version and didn't have to modify anything.
  20. The problem (Armbian on U9-H requires physical button after power loss) The discovery process (MCU at I2C bus 0, address 0x15, register 0x11) The fix: i2cset -y 0 0x15 0x11 0x00 The systemd service for persistence That 0x01 = button required, 0x00 = auto power on Note it likely applies to the Minix NEO U1 as well since it uses the same MCU
  21. Last week
  22. From your logs: Healthy: 6.12.32-current-meson64 Unhealthy: 6.18.15-current-meson64 Certainly sounds like something changed/broke in a major kernel update? For the near term, I would grab a copy of the 6.12 kernel and keep a copy. The apt tool should have saved a copy in /var/cache/apt/archives, so you should be able to pull a copy from the good system, and use "sudo dpkg -i" to downgrade the other two boards for the time being. If the working node has been upgraded, it's fan will probably stop working as intended after a power cycle. In parallel, the next thing to do is to take a look at the .dtb files for both kernels (amlogic/meson-sm1-odroid-hc4.dtb), and see what's changed. If I have a free evening, I'll take a peek. As @Igor as the board maintainer, you can also file a bug at https://github.com/armbian/build/issues, but could be a bit to get addressed.
  23. @BacchusIX Odroid H4 Plus
  24. @Sponzo that image also doesnt work for me, did you have to unlock to bootloader or something else in dev settings?
  25. @Alexander Polko Do you still have stock firmware in eMMC? You should get some output from the serial uart if you have the stock firmware, otherwise your serial is not working correctly. Also, boot from sdcard only works via u-boot from stock firmware on this board, for the reason I stated above.
  26. Collabora is headed to Stuttgart for XR Expo 2026! Visit us in Hall 2, booth 2C22, to experience the latest around Monado and ElectricMaple, and catch our 2 talks! View the full article
  27. I see. I actually tried to educate myself to see if I could help out, that is why I extracted the code in the first place. I would love to be able to help, but it seems outside of my capabilities. But I'll keep reading trying to learn, and maybe some day I will be able to make a pr rather than just a post on the forum. Thank you AGAIN for ALL you do!!
  28. This week in Armbian development saw significant progress across board support, desktop environments, and infrastructure. Notably, NanoPC T6 LTS Plus was added as a reusable board, and support for Ubuntu 26.04 LTS ("Resolute") expanded to desktop package coverage and testing. Multiple improvements targeted desktop environments, including package updates, installation fixes, and branding enhancements for browsers. Kernel and bootloader updates were implemented for various boards, with mainline kernel bumped to 7.0 stable and u-boot upgrades for Rockchip devices. Infrastructure enhancements included new CI workflows, multi-arch unit tests, and migration to a REST API. Several bug fixes, optimizations, and cosmetic cleanups rounded out the release, ensuring greater stability and usability for Armbian users. ChangesAdd Beaglebadge. by @Grippy98 in armbian/armbian.github.io#284Add few images. by @igorpecovnik in armbian/configng#858Add NanoPC T6 LTS Plus as reusable board. by @igorpecovnik in armbian/armbian.github.io#275Add NanoPC-T6 LTS Plus board support. by @igorpecovnik in armbian/build#9617arduino-uno-q: bump edge kernel to 7.0.0-unoq. by @SuperKali in armbian/build#9696base-files: symlink upstream distro logos to Armbian's. by @igorpecovnik in armbian/build#9688boot: stop emitting splash=verbose to the kernel cmdline. by @igorpecovnik in armbian/build#9653bsp: drop /etc/apt/preferences.d/armbian — desktop pin moves to armbian-config. by @igorpecovnik in armbian/build#9664bsp: ship Armbian distributor logo (svg + wordmark png variants). by @igorpecovnik in armbian/build#9674chore(deps): patch rustls-webpki and rand advisories. by @SuperKali in armbian/imager#132ci: add dependabot config (github-actions, daily). by @igorpecovnik in armbian/docker-armbian-build#16ci: build repository-update images for armhf. by @igorpecovnik in armbian/docker-armbian-build#22ci: build repository-update images for riscv64. by @igorpecovnik in armbian/docker-armbian-build#15ci: drop deprecated golint. by @SuperKali in armbian/armbian-router#41ci: multi-arch unit tests + JSON report published to armbian.github.io. by @igorpecovnik in armbian/configng#872ci: run unit tests under qemu-user for armhf + riscv64. by @igorpecovnik in armbian/configng#875ci: validate board config required fields on PR. by @igorpecovnik in armbian/build#9678copyright: match website footer. by @igorpecovnik in armbian/documentation#916cosmetic: clean up build warnings (locale, setfont, GPG, oras). by @igorpecovnik in armbian/build#9684desktops/common: strip armbian-imager on armhf/riscv64/loong64. by @igorpecovnik in armbian/configng#867desktops/common: use epiphany-browser on Ubuntu/riscv64. by @igorpecovnik in armbian/configng#870desktops/gnome: drop loong64 from sid. by @igorpecovnik in armbian/configng#877desktops/gnome: fix gnome-bluetooth-sendto install failure on jammy. by @igorpecovnik in armbian/configng#876desktops/mate: drop brisk-menu + mate-applet-trash from minimal. by @igorpecovnik in armbian/configng#866desktops/postinst: drop stray 'fi' from five scripts that fail bash -n. by @igorpecovnik in armbian/configng#879desktops/xfce: drop apport stack from packages_uninstall. by @igorpecovnik in armbian/configng#869desktops: add mode=build to skip user-dependent steps at image build time. by @igorpecovnik in armbian/configng#859desktops: availability + editorial-status filters, CSC menu. by @igorpecovnik in armbian/configng#863desktops: brand Chromium / Chrome / Firefox(-esr) first-run + homepage. by @igorpecovnik in armbian/configng#854desktops: disable DM in mode=build after install. by @igorpecovnik in armbian/configng#862desktops: drop libu2f-udev from resolute (no installation candidate). by @igorpecovnik in armbian/configng#853desktops: drop NetworkManager override from postinst scripts. by @igorpecovnik in armbian/configng#861desktops: drop plucky and questing release blocks. by @igorpecovnik in armbian/configng#849desktops: fix forky minimal installs (drop obsoleted/moved pkgs). by @igorpecovnik in armbian/configng#871desktops: flip netplan renderer to NetworkManager on live install. by @igorpecovnik in armbian/configng#880desktops: install runtime apt pin so apt.armbian.com .debs. by @igorpecovnik in armbian/configng#851desktops: route apt.armbian.com browsers + add code, armbian-imager, restore thunderbird. by @igorpecovnik in armbian/configng#848desktops: skip plymouth-theme install when mode=build. by @igorpecovnik in armbian/configng#865desktops: suppress dpkg conffile prompt on install (non-interactive). by @igorpecovnik in armbian/configng#856Disable Sk-am64b as its not compiling on Resolute. by @igorpecovnik in armbian/armbian.github.io#280distributions: mark questing (Ubuntu 25.10) as eos. by @igorpecovnik in armbian/build#9693Drop anubis and aptly. by @igorpecovnik in armbian/os#447extension: fix importlib_resources detection for U-Boot v2024.x-v2025.04. by @iav in armbian/build#9692external: add resolute (Ubuntu 26.04 LTS) to desktop package coverage. by @igorpecovnik in armbian/os#444external: add resolute (Ubuntu 26.04 LTS) to desktop package coverage. by @igorpecovnik in armbian/os#446external: consolidate chromium configs + add armhf/amd64 coverage. by @igorpecovnik in armbian/os#448external: drop jammy from desktop multi-release RELEASE lists. by @igorpecovnik in armbian/os#445external: pull libwidevinecdm0 for noble from liujianfeng1994 rockchip-multimedia PPA. by @igorpecovnik in armbian/os#451feat(api): migrate to api.armbian.com REST v1. by @SuperKali in armbian/imager#129Feature Proposal - armbian-firstlogin add support for web setup fallback. by @Grippy98 in armbian/build#9639Fix. by @igorpecovnik in armbian/os#453Fix copyright formatting in mkdocs.yml. by @igorpecovnik in armbian/documentation#917fix recomputer rk35xx dts. by @ackPeng in armbian/linux-rockchip#470Fix USB Type-C port for Orangepi 5/5B. by @chaitan3 in armbian/build#9624fix(cache): switch to sort_by_key for LRU ordering. by @SuperKali in armbian/imager#131fix(download): use direct_url so filename keeps its extension. by @SuperKali in armbian/imager#130fix(kernel-config): append missing newline to .config before edits. by @iav in armbian/build#9681fix: armbian-resize-filesystem diskdevname fallback for /dev/sda* devices. by @mvanhorn in armbian/build#9595gateway-dk-ask: pin ASK with libxml2 2.12+ compat fix for fmc. by @tomazzaman in armbian/build#9677json-generation: handle .tar.xz image archives. by @SuperKali in armbian/armbian.github.io#283kernel-headers: add version to linux-headers virtual package. by @iav in armbian/build#9686mainline: bump to 7.0 stable. by @EvilOlaf in armbian/build#9661make-yaml-redirector: add more special extensions. by @SuperKali in armbian/actions#18map: accept .tar.xz and register boot-payload / hyperv.zip.xz specialExtensions. by @SuperKali in armbian/armbian-router#40Minor fixes and improvements. by @tomazzaman in armbian/build#9655module_devicetree_overlays: rewrite — atomic writes + subcommand interface + rename. by @igorpecovnik in armbian/configng#846mvebu: helios4 edge → 6.18 LTS, restore orphaned patches. by @iav in armbian/build#9694nanopi-r3s-lts: bump uboot to v2026.04. by @EvilOlaf in armbian/build#9671nightly: blacklist gateway-dk. by @igorpecovnik in armbian/armbian.github.io#281Optimized config. by @igorpecovnik in armbian/os#452Orangepi-5-max: Remove upstreamed patches and use mainline bluetooth.. by @fbernier in armbian/build#9673partitioning: fix #9201 /etc/fstab entry (double comma). by @iav in armbian/build#9488patch/misc: rtw88: fix patch rtw88 driver in 6.12.y, remove in 6.18. by @EvilOlaf in armbian/build#9652readme: add desktops bullet to the feature list. by @igorpecovnik in armbian/configng#857remove stray left-over patch. by @EvilOlaf in armbian/build#9670Rockchip family tweaks: add to group only if group doesn't exists yet. by @igorpecovnik in armbian/build#8479rockchip-rk3588: add Rock 5 ITX PWM fan control overlay. by @ccarpinteri in armbian/build#9695rockchip64: bump some boards u-boot to v2026.04. by @paolosabatino in armbian/build#9662rockchip: migrate xt-q8l-v10 uboot patches. by @paolosabatino in armbian/build#9669rockchip: upgrade u-boot to v2026.04. by @paolosabatino in armbian/build#9663software/jellyfin: gate udevadm reload on udevd presence. by @igorpecovnik in armbian/configng#873sunxi: remove old patchsets. by @EvilOlaf in armbian/build#9687targets: align with armbian/build desktop-to-armbian-config PR. by @igorpecovnik in armbian/os#449tests: enable resolute on every desktop test. by @igorpecovnik in armbian/configng#852ti: configs: family: k3: Update baseline to 12.00.00.07. by @jonaswood01 in armbian/build#9643Try with this. by @igorpecovnik in armbian/os#454u-boot: v2026.01: fix BTRFS zstd decompression failure (error 70). by @iav in armbian/build#9651Update board_slug and board_name for NanoPC T6. by @igorpecovnik in armbian/armbian.github.io#285Update RELEASE version in google-chrome.conf. by @igorpecovnik in armbian/os#450workflows: chunk external-download matrix across 4 parallel invocations. by @igorpecovnik in armbian/armbian.github.io#282workflows: run external-package purge once per workflow, not per chunk. by @igorpecovnik in armbian/armbian.github.io#286xt-q8l-v10: forward-port u-boot board patches to v2026.04. by @igorpecovnik in armbian/build#9666 View the full article
  29. This week in Armbian development saw significant progress across board support, desktop environments, and infrastructure. Notably, NanoPC T6 LTS Plus was added as a reusable board, and support for Ubuntu 26.04 LTS ("Resolute") expanded to desktop package coverage and testing. Multiple improvements targeted desktop environments, including package updates, installation fixes, and branding enhancements for browsers. Kernel and bootloader updates were implemented for various boards, with mainline kernel bumped to 7.0 stable and u-boot upgrades for Rockchip devices. Infrastructure enhancements included new CI workflows, multi-arch unit tests, and migration to a REST API. Several bug fixes, optimizations, and cosmetic cleanups rounded out the release, ensuring greater stability and usability for Armbian users. ChangesAdd Beaglebadge. by @Grippy98 in armbian/armbian.github.io#284Add few images. by @igorpecovnik in armbian/configng#858Add NanoPC T6 LTS Plus as reusable board. by @igorpecovnik in armbian/armbian.github.io#275Add NanoPC-T6 LTS Plus board support. by @igorpecovnik in armbian/build#9617arduino-uno-q: bump edge kernel to 7.0.0-unoq. by @SuperKali in armbian/build#9696base-files: symlink upstream distro logos to Armbian's. by @igorpecovnik in armbian/build#9688boot: stop emitting splash=verbose to the kernel cmdline. by @igorpecovnik in armbian/build#9653bsp: drop /etc/apt/preferences.d/armbian — desktop pin moves to armbian-config. by @igorpecovnik in armbian/build#9664bsp: ship Armbian distributor logo (svg + wordmark png variants). by @igorpecovnik in armbian/build#9674chore(deps): patch rustls-webpki and rand advisories. by @SuperKali in armbian/imager#132ci: add dependabot config (github-actions, daily). by @igorpecovnik in armbian/docker-armbian-build#16ci: build repository-update images for armhf. by @igorpecovnik in armbian/docker-armbian-build#22ci: build repository-update images for riscv64. by @igorpecovnik in armbian/docker-armbian-build#15ci: drop deprecated golint. by @SuperKali in armbian/armbian-router#41ci: multi-arch unit tests + JSON report published to armbian.github.io. by @igorpecovnik in armbian/configng#872ci: run unit tests under qemu-user for armhf + riscv64. by @igorpecovnik in armbian/configng#875ci: validate board config required fields on PR. by @igorpecovnik in armbian/build#9678copyright: match website footer. by @igorpecovnik in armbian/documentation#916cosmetic: clean up build warnings (locale, setfont, GPG, oras). by @igorpecovnik in armbian/build#9684desktops/common: strip armbian-imager on armhf/riscv64/loong64. by @igorpecovnik in armbian/configng#867desktops/common: use epiphany-browser on Ubuntu/riscv64. by @igorpecovnik in armbian/configng#870desktops/gnome: drop loong64 from sid. by @igorpecovnik in armbian/configng#877desktops/gnome: fix gnome-bluetooth-sendto install failure on jammy. by @igorpecovnik in armbian/configng#876desktops/mate: drop brisk-menu + mate-applet-trash from minimal. by @igorpecovnik in armbian/configng#866desktops/postinst: drop stray 'fi' from five scripts that fail bash -n. by @igorpecovnik in armbian/configng#879desktops/xfce: drop apport stack from packages_uninstall. by @igorpecovnik in armbian/configng#869desktops: add mode=build to skip user-dependent steps at image build time. by @igorpecovnik in armbian/configng#859desktops: availability + editorial-status filters, CSC menu. by @igorpecovnik in armbian/configng#863desktops: brand Chromium / Chrome / Firefox(-esr) first-run + homepage. by @igorpecovnik in armbian/configng#854desktops: disable DM in mode=build after install. by @igorpecovnik in armbian/configng#862desktops: drop libu2f-udev from resolute (no installation candidate). by @igorpecovnik in armbian/configng#853desktops: drop NetworkManager override from postinst scripts. by @igorpecovnik in armbian/configng#861desktops: drop plucky and questing release blocks. by @igorpecovnik in armbian/configng#849desktops: fix forky minimal installs (drop obsoleted/moved pkgs). by @igorpecovnik in armbian/configng#871desktops: flip netplan renderer to NetworkManager on live install. by @igorpecovnik in armbian/configng#880desktops: install runtime apt pin so apt.armbian.com .debs. by @igorpecovnik in armbian/configng#851desktops: route apt.armbian.com browsers + add code, armbian-imager, restore thunderbird. by @igorpecovnik in armbian/configng#848desktops: skip plymouth-theme install when mode=build. by @igorpecovnik in armbian/configng#865desktops: suppress dpkg conffile prompt on install (non-interactive). by @igorpecovnik in armbian/configng#856Disable Sk-am64b as its not compiling on Resolute. by @igorpecovnik in armbian/armbian.github.io#280distributions: mark questing (Ubuntu 25.10) as eos. by @igorpecovnik in armbian/build#9693Drop anubis and aptly. by @igorpecovnik in armbian/os#447extension: fix importlib_resources detection for U-Boot v2024.x-v2025.04. by @iav in armbian/build#9692external: add resolute (Ubuntu 26.04 LTS) to desktop package coverage. by @igorpecovnik in armbian/os#444external: add resolute (Ubuntu 26.04 LTS) to desktop package coverage. by @igorpecovnik in armbian/os#446external: consolidate chromium configs + add armhf/amd64 coverage. by @igorpecovnik in armbian/os#448external: drop jammy from desktop multi-release RELEASE lists. by @igorpecovnik in armbian/os#445external: pull libwidevinecdm0 for noble from liujianfeng1994 rockchip-multimedia PPA. by @igorpecovnik in armbian/os#451feat(api): migrate to api.armbian.com REST v1. by @SuperKali in armbian/imager#129Feature Proposal - armbian-firstlogin add support for web setup fallback. by @Grippy98 in armbian/build#9639Fix. by @igorpecovnik in armbian/os#453Fix copyright formatting in mkdocs.yml. by @igorpecovnik in armbian/documentation#917fix recomputer rk35xx dts. by @ackPeng in armbian/linux-rockchip#470Fix USB Type-C port for Orangepi 5/5B. by @chaitan3 in armbian/build#9624fix(cache): switch to sort_by_key for LRU ordering. by @SuperKali in armbian/imager#131fix(download): use direct_url so filename keeps its extension. by @SuperKali in armbian/imager#130fix(kernel-config): append missing newline to .config before edits. by @iav in armbian/build#9681fix: armbian-resize-filesystem diskdevname fallback for /dev/sda* devices. by @mvanhorn in armbian/build#9595gateway-dk-ask: pin ASK with libxml2 2.12+ compat fix for fmc. by @tomazzaman in armbian/build#9677json-generation: handle .tar.xz image archives. by @SuperKali in armbian/armbian.github.io#283kernel-headers: add version to linux-headers virtual package. by @iav in armbian/build#9686mainline: bump to 7.0 stable. by @EvilOlaf in armbian/build#9661make-yaml-redirector: add more special extensions. by @SuperKali in armbian/actions#18map: accept .tar.xz and register boot-payload / hyperv.zip.xz specialExtensions. by @SuperKali in armbian/armbian-router#40Minor fixes and improvements. by @tomazzaman in armbian/build#9655module_devicetree_overlays: rewrite — atomic writes + subcommand interface + rename. by @igorpecovnik in armbian/configng#846mvebu: helios4 edge → 6.18 LTS, restore orphaned patches. by @iav in armbian/build#9694nanopi-r3s-lts: bump uboot to v2026.04. by @EvilOlaf in armbian/build#9671nightly: blacklist gateway-dk. by @igorpecovnik in armbian/armbian.github.io#281Optimized config. by @igorpecovnik in armbian/os#452Orangepi-5-max: Remove upstreamed patches and use mainline bluetooth.. by @fbernier in armbian/build#9673partitioning: fix #9201 /etc/fstab entry (double comma). by @iav in armbian/build#9488patch/misc: rtw88: fix patch rtw88 driver in 6.12.y, remove in 6.18. by @EvilOlaf in armbian/build#9652readme: add desktops bullet to the feature list. by @igorpecovnik in armbian/configng#857remove stray left-over patch. by @EvilOlaf in armbian/build#9670Rockchip family tweaks: add to group only if group doesn't exists yet. by @igorpecovnik in armbian/build#8479rockchip-rk3588: add Rock 5 ITX PWM fan control overlay. by @ccarpinteri in armbian/build#9695rockchip64: bump some boards u-boot to v2026.04. by @paolosabatino in armbian/build#9662rockchip: migrate xt-q8l-v10 uboot patches. by @paolosabatino in armbian/build#9669rockchip: upgrade u-boot to v2026.04. by @paolosabatino in armbian/build#9663software/jellyfin: gate udevadm reload on udevd presence. by @igorpecovnik in armbian/configng#873sunxi: remove old patchsets. by @EvilOlaf in armbian/build#9687targets: align with armbian/build desktop-to-armbian-config PR. by @igorpecovnik in armbian/os#449tests: enable resolute on every desktop test. by @igorpecovnik in armbian/configng#852ti: configs: family: k3: Update baseline to 12.00.00.07. by @jonaswood01 in armbian/build#9643Try with this. by @igorpecovnik in armbian/os#454u-boot: v2026.01: fix BTRFS zstd decompression failure (error 70). by @iav in armbian/build#9651Update board_slug and board_name for NanoPC T6. by @igorpecovnik in armbian/armbian.github.io#285Update RELEASE version in google-chrome.conf. by @igorpecovnik in armbian/os#450workflows: chunk external-download matrix across 4 parallel invocations. by @igorpecovnik in armbian/armbian.github.io#282workflows: run external-package purge once per workflow, not per chunk. by @igorpecovnik in armbian/armbian.github.io#286xt-q8l-v10: forward-port u-boot board patches to v2026.04. by @igorpecovnik in armbian/build#9666 View the full article
