  2. A733 User Manual: GitLab Link https://gitlab.com/tina5.0_aiot/product/docs/-/blob/product-aiot-stable/A733/Hardware硬件类文档/芯片手册/A733_User Manual_V0.92.pdf?ref_type=heads Decompiled boot0: https://paste.armbian.eu/akajigufep.kotlin My ATF Fork: https://github.com/rvdr/arm-trusted-firmware/tree/sun60i-a733 My Armbian Build Tree (containing the U-Boot/Kernel patches): https://github.com/rvdr/build/tree/cubie-a7a-7.0 Can somebody look into the u-boot patches (in the v2026.01 directory). I cant even get UART output and I would be grateful if somebody could look into it to check for errors or if something is missing entirely.
  4. I am not using WOL on any of my devices, I have no personal experience with the software on the Helios or any other platform.
  5. Hi @Ross Cawston I've been using your patch for a few months on Orange Pi 5 Plus/Max SBCs with Linux kernels from 6.19 to 7.0.3 and it works well encoding H.264 streams (didn't try H.265, though) Thank you for your contribution. There's still no support for `rkvenc` in edge kernels (as of 7.1rc2).
  6. This week's work centers on release pipeline modernization, desktop and userland refinements, and board and kernel platform maintenance. On the release and CI side, the build matrix gained codename parameterisation with Ubuntu 26.04 "resolute" set as default, a dedicated Bianbu target, and exposed map overrides, while standard-support targets now include UEFI desktops and a plain cloud variant. The KDE fast-HDMI matrix was switched from kde-neon to kde-plasma, mesa-vpu was dropped from auto-attached extensions, and external CI now skips slots with a warning when upstream sources break. Supporting fixes route forky/loong64 base-files lookups to the main archive and add AI cover image generation to the blog workflow. Desktop and userland changes focus on the Bianbu environment, where PVR DRI was enabled, detection corrected, menu entries added, systemd suspend re-enabled on K1, and gnome-initial-setup purged post-install. Broader fixes pass --allow-downgrades on pinned package installs, align LAN/WAN labels across IPv4 and IPv6 rows in the MOTD, harden console-width handling against invalid COLUMNS values, and correct output to /etc/armbian-image-release. Platform support sees explicit ARCH=arm64 declarations on five inheriting boards, validate-board-config now following inheritance from ${SRC}/config/boards, and targeted fixes for imx8m binman hooks and rockchip family tweaks under forky (addgroup → groupadd). Kernel and DTS work restores 6.18.y on sm8550, syncs CAINIAO CNIoT-CORE DTS from 6.18 to 6.12, disables broken drm/xe patches under uefi-loong64-7.0, and improves the SMART AM40 and Retroid Pocket board definitions. AX210 firmware lands for mainline, and Seeed Studio reComputer images join the catalogue. #Armbian #EmbeddedLinux #ARM64 #Rockchip #Ubuntu #KDE #Mainline ChangesAdd AX210 firmware for mainline kernel. by @ginkage in armbian/firmware#126Add Seeed Studio reComputer board images and vendor logo. by @baorepo in armbian/armbian.github.io#297boards: declare ARCH=arm64 explicitly on five inheriting boards. by @igorpecovnik in armbian/build#9747ci/external: skip slot with warning when upstream source breaks. by @igorpecovnik in armbian/armbian.github.io#301ci/maintenance-unit-tests: list docker state on the runner. by @igorpecovnik in armbian/configng#903desktops/bianbu: enable PVR DRI, fix detection, add menu entries. by @igorpecovnik in armbian/configng#897desktops/bianbu: purge gnome-initial-setup after install. by @igorpecovnik in armbian/configng#902desktops/bianbu: re-enable systemd suspend on K1. by @igorpecovnik in armbian/configng#900desktops: pass --allow-downgrades on pinned package install. by @igorpecovnik in armbian/configng#899DTS: Sync CAINIAO CNIoT-CORE from 6.18 to 6.12. by @retro98boy in armbian/build#9736Fix workflow bugs and add AI cover image generation. by @igorpecovnik in armbian/armbian.github.io#298fix: rename imx8m bare hook so binman pkg_resources patch can run. by @igorpecovnik in armbian/build#9752fix: rockchip family_tweaks fails on forky — addgroup → groupadd. by @igorpecovnik in armbian/build#9753fix: route forky/loong64 base-files lookups to the main archive. by @igorpecovnik in armbian/armbian.github.io#299fixing output to /etc/armbian-image-release. by @dittodhole in armbian/build#9729Handle invalid data in COLUMNS env var when determining console width. by @scollinson in armbian/build#9631kernel: add linux-initramfs-tool as dep of linux-image package. by @amazingfate in armbian/build#9731motd/20-ip-info: align (LAN)/(WAN) labels across IPv4 + IPv6 rows. by @igorpecovnik in armbian/build#9728os-info: add Ubuntu 26.04 (resolute). by @igorpecovnik in armbian/imager#134patch: disable broken drm/xe patches under uefi-loong64-7.0. by @igorpecovnik in armbian/build#9745release-targets/standard-support.manual: add UEFI desktops + plain cloud. by @igorpecovnik in armbian/armbian.github.io#304release-targets: codename parameterisation, resolute default, Bianbu target, exposed.map overrides. by @igorpecovnik in armbian/armbian.github.io#295release-targets: drop mesa-vpu from auto-attached extensions. by @igorpecovnik in armbian/armbian.github.io#302release-targets: switch fast-HDMI KDE matrix from kde-neon to kde-plasma. by @igorpecovnik in armbian/armbian.github.io#303Retroidpocket: fix current and add edge as target. by @EvilOlaf in armbian/build#9724sm8550: Restore kernel 6.18.y for current and edge branch. by @kasimling in armbian/build#9737SMART AM40 improve. by @retro98boy in armbian/build#9735userpatches: skip jammy in items-from-inventory. by @igorpecovnik in armbian/os#460validate-board-config: follow source ${SRC}/config/boards inheritance. by @igorpecovnik in armbian/build#9748View the full article
  7. This week's work centers on release pipeline modernization, desktop and userland refinements, and board and kernel platform maintenance. On the release and CI side, the build matrix gained codename parameterisation with Ubuntu 26.04 "resolute" set as default, a dedicated Bianbu target, and exposed map overrides, while standard-support targets now include UEFI desktops and a plain cloud variant. The KDE fast-HDMI matrix was switched from kde-neon to kde-plasma, mesa-vpu was dropped from auto-attached extensions, and external CI now skips slots with a warning when upstream sources break. Supporting fixes route forky/loong64 base-files lookups to the main archive and add AI cover image generation to the blog workflow. Desktop and userland changes focus on the Bianbu environment, where PVR DRI was enabled, detection corrected, menu entries added, systemd suspend re-enabled on K1, and gnome-initial-setup purged post-install. Broader fixes pass --allow-downgrades on pinned package installs, align LAN/WAN labels across IPv4 and IPv6 rows in the MOTD, harden console-width handling against invalid COLUMNS values, and correct output to /etc/armbian-image-release. Platform support sees explicit ARCH=arm64 declarations on five inheriting boards, validate-board-config now following inheritance from ${SRC}/config/boards, and targeted fixes for imx8m binman hooks and rockchip family tweaks under forky (addgroup → groupadd). Kernel and DTS work restores 6.18.y on sm8550, syncs CAINIAO CNIoT-CORE DTS from 6.18 to 6.12, disables broken drm/xe patches under uefi-loong64-7.0, and improves the SMART AM40 and Retroid Pocket board definitions. AX210 firmware lands for mainline, and Seeed Studio reComputer images join the catalogue. #Armbian #EmbeddedLinux #ARM64 #Rockchip #Ubuntu #KDE #Mainline ChangesAdd AX210 firmware for mainline kernel. by @ginkage in armbian/firmware#126Add Seeed Studio reComputer board images and vendor logo. by @baorepo in armbian/armbian.github.io#297boards: declare ARCH=arm64 explicitly on five inheriting boards. by @igorpecovnik in armbian/build#9747ci/external: skip slot with warning when upstream source breaks. by @igorpecovnik in armbian/armbian.github.io#301ci/maintenance-unit-tests: list docker state on the runner. by @igorpecovnik in armbian/configng#903desktops/bianbu: enable PVR DRI, fix detection, add menu entries. by @igorpecovnik in armbian/configng#897desktops/bianbu: purge gnome-initial-setup after install. by @igorpecovnik in armbian/configng#902desktops/bianbu: re-enable systemd suspend on K1. by @igorpecovnik in armbian/configng#900desktops: pass --allow-downgrades on pinned package install. by @igorpecovnik in armbian/configng#899DTS: Sync CAINIAO CNIoT-CORE from 6.18 to 6.12. by @retro98boy in armbian/build#9736Fix workflow bugs and add AI cover image generation. by @igorpecovnik in armbian/armbian.github.io#298fix: rename imx8m bare hook so binman pkg_resources patch can run. by @igorpecovnik in armbian/build#9752fix: rockchip family_tweaks fails on forky — addgroup → groupadd. by @igorpecovnik in armbian/build#9753fix: route forky/loong64 base-files lookups to the main archive. by @igorpecovnik in armbian/armbian.github.io#299fixing output to /etc/armbian-image-release. by @dittodhole in armbian/build#9729Handle invalid data in COLUMNS env var when determining console width. by @scollinson in armbian/build#9631kernel: add linux-initramfs-tool as dep of linux-image package. by @amazingfate in armbian/build#9731motd/20-ip-info: align (LAN)/(WAN) labels across IPv4 + IPv6 rows. by @igorpecovnik in armbian/build#9728os-info: add Ubuntu 26.04 (resolute). by @igorpecovnik in armbian/imager#134patch: disable broken drm/xe patches under uefi-loong64-7.0. by @igorpecovnik in armbian/build#9745release-targets/standard-support.manual: add UEFI desktops + plain cloud. by @igorpecovnik in armbian/armbian.github.io#304release-targets: codename parameterisation, resolute default, Bianbu target, exposed.map overrides. by @igorpecovnik in armbian/armbian.github.io#295release-targets: drop mesa-vpu from auto-attached extensions. by @igorpecovnik in armbian/armbian.github.io#302release-targets: switch fast-HDMI KDE matrix from kde-neon to kde-plasma. by @igorpecovnik in armbian/armbian.github.io#303Retroidpocket: fix current and add edge as target. by @EvilOlaf in armbian/build#9724sm8550: Restore kernel 6.18.y for current and edge branch. by @kasimling in armbian/build#9737SMART AM40 improve. by @retro98boy in armbian/build#9735userpatches: skip jammy in items-from-inventory. by @igorpecovnik in armbian/os#460validate-board-config: follow source ${SRC}/config/boards inheritance. by @igorpecovnik in armbian/build#9748View the full article
  8. Yesterday
  9. You aren't telling us much, like what software you are using. I would expect you to need to give it something like smb://10.10.2.101/NAME_OF_SHARE/ or sftp://10.10.2.101:/path/to/folder You will also need to give it a username and password somehow. But first; have you checked you can reach it on the network?
  10. On my Debian13 VM that I use to build images for my boards, I have started to notice new errors that I have not seen before after this part of the logs... [🐳|🌱] After updating and cleaning image apt list cache [ 30 files ] [🐳|🌱] Image installed package hash [ ✅ base-files = 1-trixie-1armbian1-Bb095-U13.8--deb13u4-R55fa ] [🐳|🌱] Image installed package hash [ ✅ linux-image-current-rockchip64 = 6.18.26-S1fe0-Dedd0-P1f35-Cc077-H8200-HK01ba-Vc222-Bed86-R448a ] [🐳|🌱] Image installed package hash [ ✅ armbian-firmware = 1-SAa38b-B96c8-R448a ] [🐳|🌱] Image installed package hash [ ✅ armbian-bsp-cli-rockpro64-current = 1-PC1e15-V9ab0-H3400-Bd2e9-Rf36a ] [🐳|🌱] Image installed package hash [ ✅ linux-u-boot-rockpro64-current = 2025.01-S6d41-P6e2c-Hbf76-V6f3c-Be4e9-R448a ] [🐳|🌱] Image installed package hash [ ✅ linux-dtb-current-rockchip64 = 6.18.26-S1fe0-Dedd0-P1f35-Cc077-H8200-HK01ba-Vc222-Bed86-R448a ] [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/etc/resolv.conf' [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sbin/initctl' [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sbin/start-stop-daemon' [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/usr/sbin/policy-rc.d' [🐳|🌱] Removing qemu-user-static binary from chroot [ qemu-aarch64-static during image ] [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/usr/bin/qemu-aarch64-static' [🐳|🌱] Unmounting [ /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210 ] Once the unmounting of rootfs-nouuidgen-yet begins I notice the following errors spam in the logs, 1000+ lines, and finally the target unmounts successfully and the image finishes building. The images still boot fine. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev: target is busy. [🐳|🔨] tmpfs /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev tmpfs rw,nosuid,size=65536k,mode=755,inode64 0 0 umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev/pts: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev: target is busy. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/proc: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sys: not mounted umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/tmp: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/var/tmp: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/run/user/0: not mounted. Is there a way to adjust some kind of timeout for this to prevent the massive amount of "target is busy" outputs in the logs? Thank you for any help or insights!
  11. I don't own that box so I can only give you generic help. You really would need to hook up a usb-uart adapter to access the uboot debug output to see what is happening. The second thing I would say is that I have no idea what ophub builds do as they are not Armbian builds, ophub is a fork, they don't contribute to Armbian development nor do they participate in these forums. So per the Armbian amlogic TV box instructions, the boot environment must be a clean android boot environment. Installing or running any other distribution may cause Armbian to not boot. So I'd recommend either reinstalling a clean Android image to test from, or investigate any differences in boot scripts to see what might be going on. But again getting access to the new boot serial console would help a lot.
  12. Hi Everyone! I'm trying to install it on a TV Box with an Allwinner IK316 SOC and a NANYA 1303 eMMC, but Armbian can't find the eMMC at all... has anyone found a solution for this NAND?
  13. Has anyone installed Waydroid on Armbian 26.2.4? Are there any manual for this?
  14. Good morning. Is there any means of writing an Armbian image to Allwinner H313 emmc? Phoenixsuit does not allow Armbiam images to be written. I have tried to compile (Make) Livesuit, but I gave up due to several incompatibilities (kernel, libraries, etc.). Thanks in advance.
  15. You need to provide more informations. I wasn't able to repreoduce. I works here.
  16. What you’re seeing is open-source maintenance in practice. It’s not centrally orchestrated. We only manage to do this for some key features while DVB support is present in some kernels, but it’s not guaranteed to be consistently enabled across all targets unless someone explicitly maintains this functionality. -> https://github.com/armbian/build/pulls
  17. Last week
  18. $ grep -i error /var/log/armbian-hardware-monitor.log [ 2.990779] rockchip-pcie f8000000.pcie: probe with driver rockchip-pcie failed with error -110 Looking at this I see the following: https://patchwork.ozlabs.org/project/linux-pci/patch/20210421083115.30213-1-jinsiyu940203@163.com/ "In function rockchip_pcie_host_init_port(), it defines a timeout value of 500ms to wait for pcie training. However, it is not enough for samsung PM953 SSD drive and realtek RTL8111F network adapter, which leads to the following errors: [ 0.879663] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 0.880284] rockchip-pcie f8000000.pcie: deferred probe failed [ 0.880932] rockchip-pcie: probe of f8000000.pcie failed with error -110 The pcie spec only defines the min time of training, not the max one. So set a proper timeout value is important. Change the value to 1000ms will fix this bug." Is it possible for team to add patch such as ../patch/kernel/rockchip64-current/0002-rockchip-pcie-increase-timeout.patch which contains the fix specified in the patchwork.ozlabs.org link above? A humble thank you for any more help and consideration on this!
  19. @well0nez I didn't even think about that. When I made the original post almost two years ago, AI was much less capable than today. You just gave me a few ideas for different projects. As I said, unfortunately I don't have the HY300 anymore, but I do have a Magcubic L018(same chip I think), though it's in use every day as a bedroom TV. I don't think my girlfriend would appreciate if I started to hack it 😉 Especially if core functions like projecting the things coming through the HDMI port to the wall. The L018 has worse software than the HY300, in my opinion, so I've connected it to a certified Android TV 14 Box.
  20. Hello, I updated to Armbian 26.2.1 trixie installaed on emmc. If I poweroff the nas and power on again it does't work, but if I attach an usb cable to the console it works. I think the problem must be related to the u-boot part.
  21. It worked seamlessly! Thanks!
  22. Hi everyone! I tried installing hardware decoding from this link - https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/ , but it didn't work for me. My board version is 5.1. Has anyone been able to fix this?
  23. I tried to enable the I2S / PCM5102 service with AI, but unfortunately, despite numerous attempts, I couldn't. But anyone can use a USB audio card. Maybe someone else will figure out how to enable it 🙂 Best regards
  24. yes, i've studied the schematic well to see if that gave any clues and I have learned that it ties into the Power Management Unit. It remains that the button doesn't work on mainline kernels but does on the vendor kernel. There must be some init step or configuration that's missing.
  25. Looks like the current-rockchip64 kernel that one receives with apt on PINE64 rockpro64 is 3.18.10 (6.18.10-current-rockchip64), vulnerable to copy-fail. This seems weird because if you go to https://armbian.com/boards/rockpro64 that page says that the "current" kernel for these systems is 6.18.26 and that is what you get when you download the image file. Is there an issue with updating the apt repos?
  26. Things are still very sad with Ethernet. Is this could be related to some low-level timings in device configuration?
  27. First of all, thanks for your reply. Even though you said there are no "vendor-lockin" i felt like so that's why i created a post on this forum as this issue came only after armbian os flash. As i said, after flashing armbian os, i was not able to use MASK button to bypass emmc boot and about a dozen of different os other than armbian failed to boot from SD card. Then i experimented on different methods including the PC connectivity but changing bootloader or os image didn't work as the mask communication is getting lost during flash command run. I deleted boot files from armbian boot partition to check if that fall back to SD card, but there was no luck. However armbian SD card boot still worked. So i confirmed that it is the change in bootloader that armbian made. Then i re installed armbian os inside emmc and used dd command to write the original bootloader images which is taken from the nanopi r6s official eflasher download link. It worked! Now i am able to install other os than armbian. Kindly fix this issue and acknowledge the same, otherwise people like me will think twice before testing latest armbian os next time. Best regards
  28. Ah, this board has n out of tree dt as well which most likely overwrites the patch. Try adjusting this file: ~/build/patch/kernel/archive/rockchip64-6.18/dt/rk3576-nanopi-r76s.dts
