Attempting to build this image gives me the following error: [π³|π¨] Image 'itb' is missing external blobs and is non-functional: opensbi [π³|π¨] [π³|π¨] /binman/itb/fit/images/opensbi/opensbi (fw_dynamic.bin): [π³|π¨] See the documentation for your board. The OpenSBI git repo is at [π³|π¨] https://github.com/riscv/opensbi.git [π³|π¨] You may need to build fw_dynamic.bin first and re-build u-boot with [π³|π¨] OPENSBI=/path/to/fw_dynamic.bin [π³|π¨] [π³|π¨] Some images are invalid [π³|π¨] make: *** [Makefile:1124: .binman_stamp] Error 103 Any help would be appreciated.
- 176 replies
- MangoPi MQ Pro
- Sipeed Nezha
(and 1 more)
Β Tagged with:
@voapilro Thanks To try to get it to boot, try applying the patches https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3/tree/main/patches in particular: https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3/blob/main/patches/THS_fix.patch https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3/blob/main/patches/enable_GPU.patch note that these are for mainline u-boot 2024-04 release (tag), the patches are for the same found in Armbian. I really disliked all these 'black magic', but that these are really the 'state-of-the-art'. After I did my initial 1.5GB 'hack' patches, originally I've got that 'gpu overheating' issue. But with that 2 patches, it booted to the prompt ! As for 'vendor' u-boot, I'm suspecting that orange pi customized u-boot to pass some additional variables (possibly hard coded) to boot.scr, boot.cmd. When something fails there, I'd guess it dropped to the u-boot prompt. It'd take figuring out what is the statement that the boot.scr, or boot.cmd aborted and what it needs. When that is figured out, you may also be able to do that same 'black magic', passing the variables boot.scr or boot.cmd is expecting. I kind of disliked these 'black magic', the 'right' way is for these to goto the device tree source or overlays (dts files), so that the relevant board use the correct board dts file instead of hard coding them in u-boot. But it is somewhat the 'state-of-the-art' as well as of current, the catch is mainline u-boot won't boot those custom boot.scr and boot.cmd as those 'special' hard coded variables won't be there. if you clone my repository, I've updated a build guide https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3/blob/main/build.md those steps should compile the mainline u-boot for Orange Pi Zero 3 - note with the '1.5GB hack' my repository is managed using quilt https://wiki.debian.org/UsingQuilt to make edits quilt series quilt push patches/1.5GB_OPZ3_fix.patch vi u-boot/arch/arm/mach-sunxi/dram_sun50i_h616.c <- or use any editor you prefer quilt refresh <- note this would update patches/1.5GB_OPZ3_fix.patch quilt push -a <- this applies the remaining of the patches # compile it cd arm-trusted-firmware bash arm-trust-fw-make.sh cd u-boot bash build.sh # test it if necessary # you can rollback all the patches using # quilt pop -a
does Armbian image use same DDR blobs as Joshua's?
@ebin-dev Thanks for the explanation (i failed to notice that you were setting io_is_busy to a different value). I know that you are still working to stabilize this board. But at the end of this process, it should be possible to submit a PR to incorporate your settings into the base builds. Thus I'm looking for things that will make that difficult. I just added a comment to PR6507 stating that the way io_is_busy is now set doesn't allow it to be overridden if needed.
Description Quick fix to hdmi patch due to mainlined hunks. How Has This Been Tested? [x] New fixed patch apply on 6.8.9 edge kernel [x] Compiled rockchip drm code on the fly to check it works Did not check the real functionality, but I hope I did not break anything, the patch is minimal... Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings View the full article
The USB power has been a growing issue with my C2 for years now. To have the board use the SSD through a USB/SATA adapter, I now have to power the adapter (which has a Y cable) from a neighbour board. It used to work long time ago without the other board "help". So there is probably a weakening component on my C2. Right now the voltage drops between the +5V barrel alim centre, and USB connectors' 5V. I see no rationale in this. My C2 is now decommissioned (I bought a OPi 3 LTS instead). So I will try to to solder a wire under the board to have the incoming 5V straight to the USB ports. It should not be worse than the Y USB cable bringing the 5V from the neighbour board.
_Rick replied to Igor's topic in Software, Applications, Userspace
Hi Igor, I understand, I agree, this forum is for the Armbian, not the board. Thank you again for your time, for what is working now, it is waaaayyy faster than my Pi3b !!! In any case, a big thank you for your time! Richard. -
@z28z34man See Werner's post
Looking to /boot/dtb-6.6.30-current-sunxi64/allwinner/overlay/ for h616 not exit dtbo sun50i-h616-w1-gpio.dtbo So for this reason not available in armbina-config in HARDWARE setup w1-gpio so we can not at current use 1-Wire sensor to define on which GPIO is connected 1-Wire sensor DS18B20 uses the 1-wire bus so it will be nice to have possibility use 1-Wire sensors with OZPI v3
@cad 435 No you aren't really missing anything. In the stable channel, kernel .debs generally only get pushed out every three months when a new stable release is put out (24.05 will be out the end of this month for example). If you want to get regular updates of kernels you need to switch to the nightly builds repository in armbian-config. Right now there is no in between.
Description Devicetree is already in https://github.com/armbian/linux-rockchip so just a board config is enough How Has This Been Tested? [x] ./compile.sh BOARD=rock-5-itx BRANCH=vendor BUILD_DESKTOP=no BUILD_MINIMAL=no DEB_COMPRESS=xz KERNEL_CONFIGURE=no RELEASE=bookworm KERNEL_GIT=shallow, flashed to emmc and boot Checklist: Please delete options that are not relevant. [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
Its a bug. You need to make sure the wireless country code is set, even when its not being used.
Hi all, I decided today to give an Armbian build a whirl as a virtual machine (guest). In particular, Armbian_24.2.4_Uefi-x86_jammy_current_6.6.21_kde-neon_desktop.img. As is usual with installing a virtual machine, it comes up with a default video resolution of 1024x768; I can usually quickly get it full screen on my system as 1920x1080 by going to the System Settings : Hardware : Display and Monitor : etc. However, here there is no hardware subsection at all, and a search didn't turn up a setting to change the display. Any advice on where to find it? I installed the spice guest driver and related packages on the guest. Thanks!
nand-sata-install no bootloader option to SPI flash
SteeMan replied to Rim Bru's topic in Allwinner sunxi
That board is no longer a valid armbian board. It is EOS status (end of support). So there is no Armbian support and no community support for that board. -
First attempt to add support for Radxa Rock 3C
Laurent D replied to Endian's topic in Advanced users - Development
Hi all, Armbian is now working on Rock 3C. You can download a community build: https://github.com/armbian/community/ -
Odroid C2 never starting after a soft reboot (reboot command)
technik007_cz replied to yandritos's topic in Beginners
It happens also with the latest Linux 6.7.4-edge-meson64 kernel. This problem could be related to a power switch which could be optionally connected to the J4 pin? -
@elysiuMAccording to a user from a russian forum, the published stock firmware does not match the device. Maybe someone will find a solution soon!? https://4pda.to/forum/index.php?showtopic=1088113#entry129825636
Hello all I have broken my installation when I tried to install the kernel 6.1 my current kernel 5.10.160-legacy-rk35xx. My nanopc t6 do not start. My installation is on EMMC and start on it. Could you please help me to recover it ? I have a backup file from OMV but I don't know how to push the backup to the EMMC? other possibility I guess copy the boot folder backup to EMMC boot folder but I do not know if it is enough. I really appreciate an help furthermore a clear turial could help evryone to recover an installation on EMMC memory. Thanks in advance for your support.
Debian Buster is EOL. Remove Armbian related entries from apt sources and you are good to go. There won't be any further updates from Armbian for this userspace. https://docs.armbian.com/User-Guide_FAQ/#how-do-i-upgrade-from-armbian-buster-to-bullseye Debug boot issue: https://debug.armbian.de Put SD card into your Linux computer and mount it.
so, I tried it again with the kernel 6.1.43 and with the instructions from the howto. That resulted in the scrambled picture when opening kodi. (see above post) Then I built mpp, rga, ffmpeg_rockchip and kodi new. After a restart I could not open kodi as it complained about the missing fbdev module. Then I build drm-package and the mesa driver again. Then kodi opened again only to give the following errors when opening a movie: 2024-05-06 09:43:53.882 T:6596 info <general>: Creating InputStream 2024-05-06 09:43:53.916 T:6596 info <general>: Creating Demuxer 2024-05-06 09:43:53.990 T:6596 info <general>: Opening stream: 0 source: 256 2024-05-06 09:43:53.990 T:6596 info <general>: Creating video codec with codec id: 173 2024-05-06 09:43:53.990 T:6596 info <general>: CDVDVideoCodecDRMPRIME::Open - using decoder Rockchip MPP (Media Process Platform) HEVC decoder 2024-05-06 09:43:53.991 T:6596 info <general>: Creating video thread 2024-05-06 09:43:53.991 T:6600 info <general>: running thread: video_thread 2024-05-06 09:43:53.992 T:6596 info <general>: Opening stream: 1 source: 256 2024-05-06 09:43:53.992 T:6596 info <general>: Finding audio codec for: 86060 2024-05-06 09:43:53.992 T:6596 info <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder truehd 2024-05-06 09:43:53.992 T:6596 info <general>: OpenStream: Allowing max Out-Of-Sync Value of 10 ms 2024-05-06 09:43:53.992 T:6596 info <general>: Creating audio thread 2024-05-06 09:43:53.992 T:6601 info <general>: running thread: CVideoPlayerAudio::Process() 2024-05-06 09:43:53.992 T:6596 info <general>: Opening stream: 9 source: 256 2024-05-06 09:43:54.003 T:6601 info <general>: Creating audio stream (codec id: 86060, channels: 8, sample rate: 48000, no pass-through) 2024-05-06 09:43:54.032 T:1329 error <general>: CEGLImage::SupportsFormat - format not supported: YU10 2024-05-06 09:43:54.033 T:1329 info <general>: GLES: Selecting single pass rendering 2024-05-06 09:43:54.033 T:1329 info <general>: GLES: Selecting YUV 2 RGB shader 2024-05-06 09:43:54.033 T:1329 error <general>: CBaseRenderer::GetShaderFormat - unsupported format 179 2024-05-06 09:43:54.033 T:1329 error <general>: GLES: BaseYUV2RGBGLSLShader - unsupported format none 2024-05-06 09:43:54.034 T:1674 info <general>: Skipped 1 duplicate messages.. So this means, that the original howto's for Rock 5b do not work anymore. And I did not find any working or reproducible collection of steps needed to get kodi reliably working with hw acceleration. This is quite a nightmare. I have this thing for over a year now and i am not able to use it.
Helios64 u-boot does not build anymore after we bumped to 2022.07
BipBip1981 replied to Igor's topic in Rockchip
Hi, uptime more 5 days with my pattern test and ebin-dev's file for voltage change, not crash. now i use helios64 on normal condition to see if better than before for information my pattern test never pass before today on my helios64 with ondemand gov and 408-1800 freqs since i have it Keep in touch root@helios64:~# uptime 10:06:08 up 5 days, 40 min, 2 users, load average: 1.94, 2.49, 2.65 root@helios64:~# uname -a Linux helios64 6.6.29-current-rockchip64 #1 SMP PREEMPT Sat Apr 27 15:11:44 UTC 2024 aarch64 GNU/Linux helios64@helios64:~$ cat /etc/fancontrol # Helios64 PWM Fan Control Configuration # Temp source : /dev/thermal-cpu #INTERVAL=10 INTERVAL=30 FCTEMPS=/dev/fan-p6/pwm1=/dev/thermal-cpu/temp1_input /dev/fan-p7/pwm1=/dev/thermal-cpu/temp1_input MINTEMP=/dev/fan-p6/pwm1=40 /dev/fan-p7/pwm1=40 #MAXTEMP=/dev/fan-p6/pwm1=110 /dev/fan-p7/pwm1=110 MAXTEMP=/dev/fan-p6/pwm1=50 /dev/fan-p7/pwm1=50 #MINSTART=/dev/fan-p6/pwm1=60 /dev/fan-p7/pwm1=60 MINSTART=/dev/fan-p6/pwm1=20 /dev/fan-p7/pwm1=20 #MINSTOP=/dev/fan-p6/pwm1=40 /dev/fan-p7/pwm1=40 MINSTOP=/dev/fan-p6/pwm1=20 /dev/fan-p7/pwm1=20 MINPWM=20 root@helios64:~# cat /etc/default/cpufrequtils ENABLE=true MIN_SPEED=408000 MAX_SPEED=1800000 GOVERNOR=ondemand -
Hello, I hope someone might help me on this. Is anyone here using the ENC28J60 Ethernet port on an Orange Pi Zero 2W or Orange Pi Zero 3? If so, can you please share the file .dts (or .dtbo) that is working for you? I've generated a .dtbo using the file in https://github.com/armbian/sunxi-DT-overlays/blob/master/examples/spi-enc28j60.dts, with: dtc -I dts -O dtb -o /boot/overlay-user/spi-enc28j60.dtbo spi-enc28j60.dts but still it doesn't work. It says "chip not found". I'm using the same cable pinout as in my Raspberry Pi Zero 2W and it works successfully, but not in the Orange Pi Zero 2W. Any idea?
Hello, I have recently setup Armbian on my Orange Pi Zero 2W for a project I am working on. Everything works great so far but one thing I have noticed is that permissions feel much reduced to my user account. I require sudo to do basically everything from create a file in the home folder to use apt. This feels very different from the feel of the Raspbian install on like a Raspberry Pi. Is there any way I can change the user permissions so I won't have to use sudo for everything? Its been a bigger problem for a project I'm using Clion for where files are synced between my laptop to the pi using SFTP and Rsync but I constantly get errors about unable to create or transfer files and folders due to permission errors causing me to need to delete the remote changes and manually copy them over with sudo. I understand that doing this compromises security and is riskier but I'm fine with that. Any and all help would be great
