  2. Hello Thanks for you answer, I understand the point that if even though M2B & M2U are very close, it does not mean it will work. I really thought it was a simple thing to change "just" to turn off/on the board, as all the rest is perfect. I had a look to https://docs.armbian.com/Developer-Guide_Build-Preparation/ but honestly I am not skilled enough to to this, I did not understand how building it on my PC will make it work on the BananaPi, and the config ./compile.sh build \ BOARD=uefi-x86 \ #bananapim2b does not seem to exist BRANCH=current \ BUILD_DESKTOP=no \ BUILD_MINIMAL=yes \ KERNEL_CONFIGURE=no \ RELEASE=trixie does not help on which string using for my board. Regards
  3. In the world of cheap ARM sbcs you cannot simply use image for board X and assume it works for board Y. It may up to a certain point, even boot, but you have to live with regressions. https://docs.armbian.com/User-Guide_FAQ/#why-no-universal-image If there is no pre-made image for a specific board, then you can DIY if it is even supported by the framework. keep in mind, boards in eos or csc status may or may not work. We don't know, we don't pay attention, we don't support.
  5. Hello, Thanks for armbian on Banana PI, it is really wonderful compared to official releases. I installed the image "Armbian_community_26.2.0-trunk.904_Bananapim2ultra_trixie_current_6.18.29_minimal.img.xz" on my Banana PI M2 Berry (there is no image for this type), and all is working wonderfully well ... except rebooting or shutting down the Banana PI. When typing reboot, all services stop but the screen blocks on systemd-shutdown[1]: Rebooting. and it never reboots. It does the same for shutdown, stuck on same kind of message. Could you help me please ? Regards
  6. Perhaps send fix here: https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-6.18/board-nanopi-m5-add-wifi-bt-ufs-and-misc.patch
  7. **Board:** NanoPi M5 (RK3576) **Kernel:** 6.18.33-current-rockchip64 (#1 SMP PREEMPT Sat May 23 11:07:21 UTC 2026) **Armbian build:** v26.8.0-trunk.53 ## Problem Gigabit RX is completely non-functional on `end0` (GMAC0, `ethernet@2a220000`). The interface comes up at 1000Mb/s, TX works, but no packets are ever received. DHCP never gets an OFFER, `ethtool -S end0` shows RX counters stuck at zero. Forcing 100Mb/s via `ethtool -s end0 speed 100 duplex full autoneg off` works around the issue — RX starts working immediately. ## Root cause The DTB sets `phy-mode = "rgmii-id"` together with `rx_delay = <0x3f>`. The RTL8211F PHY in `-id` mode already applies its own internal RX delay, and the driver applies an additional hardware delay on top of it. The double delay breaks gigabit RX entirely. ``` # /boot/dtb/rockchip/rk3576-nanopi-m5.dtb — broken phy-mode = "rgmii-id"; tx_delay = <0x21>; rx_delay = <0x3f>; # <-- causes double RX delay ``` ## Fix Change `phy-mode` to `rgmii-rxid` (PHY applies RX delay internally) and remove `rx_delay`. This applies to both GMAC0 (`ethernet@2a220000`) and GMAC1 (`ethernet@2a230000`). ``` # Fixed phy-mode = "rgmii-rxid"; tx_delay = <0x21>; # rx_delay removed ``` After applying this fix gigabit works correctly at 1000Mb/s with full RX functionality. ## Workaround ```bash ethtool -s end0 speed 100 duplex full autoneg off ``` Or patch the DTB manually: ```bash dtc -I dtb -O dts -o /tmp/nanopi.dts /boot/dtb/rockchip/rk3576-nanopi-m5.dtb sed -i 's/phy-mode = "rgmii-id"/phy-mode = "rgmii-rxid"/g' /tmp/nanopi.dts sed -i '/rx_delay/d' /tmp/nanopi.dts dtc -I dts -O dtb -o /boot/dtb/rockchip/rk3576-nanopi-m5.dtb /tmp/nanopi.dts reboot ```
  8. Yesterday
  9. Android DTB itself is broken in many ways, mainly because wifi gpios from DTB do not show up in the gpioinfo output. It is more important to put the brcm4335-sdio firmware in /lib/firmware/brcm, which is missing in the armbian repository. iw phy0 info shows support of the 5GHz channels, but i don't have such access points nearby. I will check tomorrow with my dual-band AP.
  10. It happened a few days ago that I rebuilt my complete firmware package to try something with another device. An HC4 firmware binary also automatically falls out in this process. If you like, you can put it on a microSD card (dd bs=512 seek=1 conv=notrunc,fsync if=u-boot-meson.bin of=/dev/${entire-device-to-be-used}), place the prepared microSD card in your HC4 and start it with the boot button pressed. Check whether it meets your expectations, and if all tests are successful, you can transfer it to the SPI flash.
  11. Board: Orangepione Testing results for the three available images. Should there be more images available? Armbian_26.5.1_Orangepione_resolute_current_6.18.33_minimal.img Tested working: Boot from SD card with uboot and then to a USB SSD. Reboot Connect via ssh iperf3 after installing iperf3 gpio after installing gpiod HDMI video HDMI audio after installing mpg123 Used usb keyboard/mouse to test HDMI. Note that resolute now uses gpiod for gpio instead of sys. Gpiod had to be installed whereas trixie minimal comes with gpiod installed. Armbian_2Armbian_26.5.1_Orangepione_trixie_current_6.18.33_minimal.img Tested working: Boot from SD card with uboot and then to a USB SSD. Reboot Connect via ssh iperf3 after installing iperf3 gpio HDMI video HDMI audio after installing mpg123 Used usb keyboard/mouse to test HDMI. Armbian_26.5.1_Orangepione_resolute_current_6.18.33_xfce_desktop.img Tested working: Boot from SD card with uboot and then to a USB SSD. Reboot On HDMI connecter screen with usb keyboard/mouse Using terminal emulatori tested perf3 and gpio HDMI audio with vlc media player. Not working: Ran chromium to get to Armbian download page but took over a minute for each page to load and then the system crashed. With only 512MB RAM this system is under powered for general purpose desktop use. ubuntu_resolute_minimal.txt debian_trixie_minimal.txt ubuntu_resolute_xfce.txt
  12. The longer answer is that for standard releases, updates only occur with each release cycle (i.e. every three months in Feb, May, Aug, and Nov each year. So you will get new kernel release on that schedule. Armbian also has rolling release repositories and these put out new versions on a frequent basis. And you should be able to switch between stable releases and rolling release apt repositories using armbian-config. Note that rolling releases don't get any testing (other than automated builds) and therefore may not be suitable for many users needs. But those are your two options.
  13. We're in the middle of the May release, so new packages should eventually hit repo in a few days/weeks.
  14. Hi, I have been running armbian with the minmal debian trixie image on a odroid M1 for a few month now and I noticed that since I installed the image there has not been a single kernel upgrade. the kernel is still at 6.18.10 despite current debian install image for this board being shipped with 6.18.28 so I am assuming I am doing something wrong. The apt update and apt dist-upgrade logs show clearly all current package information are being downloaded from both debian and the armbian mirrors, and both armbian-config updates and upstream debian packages have been upgraded whenever I run the apt dist-upgrade commands, but the kernel is still the same old version from several month ago. Any clue what I should look at to find the issue? Thanks
  15. Board: MKS-Klipad50 Images: * Armbian_26.5.1_Mksklipad50_resolute_current_6.18.33_minimal.img.xz * Armbian_26.5.1_Mksklipad50_trixie_current_6.18.33_minimal.img.xz Passed tests: * gpg and sha checksum files * boot from emmc, leds, display, touch, usb, internal wifi * initial setup, uboot-console, reboot Result: All expected images do exist, verify and work properly. Sidenote: The Klipper ecosystem does not yet run on Ubuntu-Resolute (Python-3.14 incompatibility), but that shouldn't be a stopper for the release.
  16. You can send your DTB, that has wi-fi?
  17. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  18. I recognize this is an old thread - but there are no newer ones open and I figure having one thread instead of many is best. I'm trying to do the same thing as you OP, getting a raspberry pi DSI display working on a rockpi 4b+. I tried to adapt Radxa's DTS in a similar way you did from Armbian's Base DTS, and seeing what definitions changed and I came up with this non working DTS: Which gives the following DMESG error, very similar to yours: `[ 21.477004] rpi-ts-dsi ff960000.dsi.0: failed to attach dsi to host: -517 [ 21.477086] mipi-dsi ff960000.dsi.0: deferred probe pending: (reason unknown)` You'll note various differences between our DTS, like panel_in instead of panel_in_dsi, and mipi_dsi instead of mipi_dsi1. I based these off looking at the base DTS in Armbian kernel 6.18.32, but also on this project I found recently that brings support for 7 and 10 inch Osoyoo brand of DSI panels to the RockPi 4b+. I think that's really promising and will help with bringing DTS support to the raspberry pi panel (and others that are compatible). I recommend you look into it. I will continue iterating and update this thread with results if any. I don't think OP was pinning the problem on Armbian. OP was asking how to configure a custom DTS to work with the hardware they have. This is the community support forum, which is the correct place for this kind of discussion.
  19. You could flash armbian to an SDcard, then set Jumper P10 to force UBoot to skip booting from EMMC and pick the sdcard instead. From there you can directly mount the internal storage and chroot into it to run armbian-config and enable the overlay.
  20. Last week
  21. Hello, I flashed the latest KDE version to the SD card of my Orange Pi 3B using Armbian Imager, but for some reason the USB ports are not working at all. There's no power coming from the USB ports, and the keyboard backlight isn't working at all. What could be the reason? Can you help me? I've never experienced anything like this before.
  22. https://libre.computer/products/roc-rk3399-pc/ Can the computer run entirely on free software which is software you can use, share, modify and redistribute? The question includes firmware, microcode, etc, any piece of software that is running on the computer. If some devices on the computer requires non free software in order to work then what devices are they? And will the computer still work if you choose to not install the pieces of non free software in question? Thank you.
  23. For those who want to compile from source: a) locate file ~ /armbian-build-mxpro/patch/kernel/archive/sunxi-6.12/series.conf b) delete the following lines before issuing ./compile.sh: spi-rockchip-Fix-runtime-PM-and-other-issues and spi-fixes c) save the file and proceed to compilation (./compile.sh) Note: if you want to upgrade the Armbian firmware be aware that: linux-dtb-current-sunxi64/trixie 26.5.1 arm64 [upgradable from: 26.02.0-trunk] linux-image-current-sunxi64/trixie 26.5.1 arm64 [upgradable from: 26.02.0-trunk] will render the ethernet interface inoperable. You can prevent this by issuing sudo apt-mark hold armbian-firmware before sudo apt upgrade -y
  24. JamesCL
    Is it possible to change the boot order? For my use case, I would like the boot priority to be: eMMC, NVMe, and microSD card. Can this be configured?
  25. I've created a guide here how to run a Home Assistant OS suprisingly it run mostly natively. Didn't do anything except replacing the DTB. Also right away flashed it into a emmc. On my board emmc is from Samsung and has a read speed on 180Mb/s...
  26. Tested orangepi5 current and vendor. works as expected
  27. Known issue on multiple older 64 bit Allwinner socs Try these: https://fi.mirror.armbian.de/incoming/igorpecovnik/pine64/archive/
  28. Armbian 26.05 Test images: https://fi.mirror.armbian.de/incoming/igorpecovnik/ Tested by me: - x86 and arm64 UEFI images - Odroid M1 - Radxa 5T https://paste.armbian.com/jizuhuweru - Inovato Quadra - RPi 400 - Musepipro - Orangepi 5 Plus (BROKEN) - Odroid N2 https://paste.armbian.com/ipoyatajuj - Nanopi M4V2 https://paste.armbian.com/rewiqijizi - Nanopi R4S https://paste.armbian.com/sesemehohi - NanoPC T6 LTS / plus https://paste.armbian.com/cupifefofe - Nanopi R6S/C https://paste.armbian.com/igesulided ..
  29. I'd like to run the mainline kernel https://github.com/nickfox-taterli/avaota-a1-mainline-linux The board used to have a page and downloads here: https://armbian.com/boards/avaota-a1 but it's gone. Has support for this board been dropped?
