hippo5329 Posted January 25, 2020 Posted January 25, 2020 On 1/25/2020 at 9:22 AM, noname said: I have a Tronsmart S95 Pro (s905, 1/8 G). The latest version (5.5.0-rc7) is not loaded, the logo just flashes cyclically. With version legacy_5.5.0-rc1 , everything loads and works fine. In all cases I use bionic (console and desktop), meson-gxbb-vega-s95-pro.dtb Expand 1. Did you edit uEnv.txt file for aml and correct FDT in BOOT partition? 2. Did you apply u-boot with sudo dd if=u-boot-odroid-n2.img of=Armbian_19.11.5_Arm-64_bionic_dev_5.5.0-rc7_desktop_20200124.img conv=notrunc bs=1 count=442 sudo dd if=u-boot-odroid-n2.img of=Armbian_19.11.5_Arm-64_bionic_dev_5.5.0-rc7_desktop_20200124.img conv=notrunc bs=512 skip=1 seek=1
balbes150 Posted January 25, 2020 Author Posted January 25, 2020 New version 20200125 with launch fix on S905 and running sound s905\s905x\s912.
noname Posted January 25, 2020 Posted January 25, 2020 On 1/25/2020 at 2:04 PM, hippo5329 said: 1. Did you edit uEnv.txt file for aml and correct FDT in BOOT partition? Expand Yes. On 1/25/2020 at 2:04 PM, hippo5329 said: 2. Did you apply u-boot with Expand No.
noname Posted January 25, 2020 Posted January 25, 2020 On 1/25/2020 at 2:35 PM, balbes150 said: New version 20200125 with launch fix on S905 and running sound s905\s905x\s912. Expand Thanks! Now system is booting.
sivark Posted January 25, 2020 Posted January 25, 2020 Could anyone guide me for A5X MAX, trying to boot "New version 20200125" from sdcard. Amended uEnv.txt for RK3328 and used all dtb for FDT in BOOT partition but still unable to boot.
stut Posted January 25, 2020 Posted January 25, 2020 On 1/25/2020 at 2:35 PM, balbes150 said: New version 20200125 with launch fix on S905 and running sound s905\s905x\s912. Expand This installed to internal without panics, running smoothly but still cpu speed is wrong for me on p212. Only 1000mhz max instead of 1200mhz.
K200_Noob Posted January 25, 2020 Posted January 25, 2020 Hello, Anyone know if this works with s905X3 with HW video decoder. Planning on getting a box to convert to Armbian running on emmc? appreciate any input please..
balbes150 Posted January 26, 2020 Author Posted January 26, 2020 On 1/25/2020 at 6:23 PM, sivark said: Could anyone guide me for A5X MAX, trying to boot "New version 20200125" from sdcard. Amended uEnv.txt for RK3328 and used all dtb for FDT in BOOT partition but still unable to boot. Expand If you do not have a new version of u-boot installed in eMMC (with support for direct launch from USB), you only need to use the SD card to start it, and after writing the image Armbian to the SD card, additionally write the correct version of u-boot for your model to the SD card. This is described in the first message of the topic. Either use the SD+USB combination (if you have windows and can't use the add u-boot commands to the SD card), write only the new u-boot to the SD card, and write the Armbian image to a USB storage device. And connect them together to the TV box. On 1/25/2020 at 7:23 PM, stut said: This installed to internal without panics, running smoothly but still cpu speed is wrong for me on p212. Only 1000mhz max instead of 1200mhz. Expand Search the forum for information about frequency settings, via cpufrequtils. And check the dtb that you are using.
stut Posted January 26, 2020 Posted January 26, 2020 On 1/26/2020 at 8:56 AM, balbes150 said: Search the forum for information about frequency settings, via cpufrequtils. And check the dtb that you are using. Expand There is only 1 p212 dtb file available. Cpufrequtils is configured ok and cpufrequtils doesn't decide with frequencies are available. I linked a full uart boot log and output of /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies in my previous post. The right frequencies are missing so cpufrequtil config doesn't matter. It runs around 5-10c higher than on CE or stock Android, I had hoped getting the right scaling steps could help there. Thanks for your answer.
xadieu01 Posted January 26, 2020 Posted January 26, 2020 I have x96 air with lan gigabit version. Everything boot ok with meson-sm1-sei610.dtb but lan didn't work. Can everyone help me to fix it? I tested coreelec with s905x3-4gb-1G.dtb, lan gigabit worked fine Thanks!
DevShanky Posted January 26, 2020 Posted January 26, 2020 Is it possible to include the Wifi driver ssv6015 with the kernel in the new builds? Or can you point me to the kernel source for the latest builds so that I can attempt to include this for a custom build? Thanks Rajesh
Juanjo Posted January 27, 2020 Posted January 27, 2020 On 12/8/2019 at 4:51 PM, balbes150 said: Good news. Managed to find a way to work around the color issue on G12 platform + kernel =>5.4 with corrupted AML u-boot. You need to download and copy all the files from this directory to the media. New versions 20191208 already have some of the necessary files, you only need to add one file u-boot.ext Additional file download and copying (u-boot.ext) only need if your device screen color is not correct. https://yadi.sk/d/MC2brPBu5bmW2Q Expand Balbes Maybe you remind I sent you the gt1-mini-a DTB time ago Now I'm playing with GT1-Mini-2 which is a S905X3, anyway it does boot with the GT1-Mini-A DTB (SEI610 boots but no Ethernet) when I get some time I'll mix both DTBs if some new stuff on the S905X3 merits But as you now this new GT1-Mini-2 has the messed HDMI colors so I installed your u-boot.sd on my card and everything works fine. I noted that basically you load the new uBoot if a u-boot.ext exists but this is on s905_autoscript So I wonder if I burn the eMMC (using your install-aml.sh) will this work also ? Because there is a emmc_autoscript which doesn't check for u-boot.ext existance. Do I need to create a custom emmc_autoscript ? Thanks in advance
balbes150 Posted January 27, 2020 Author Posted January 27, 2020 On 1/27/2020 at 12:37 AM, Juanjo said: So I wonder if I burn the eMMC (using your install-aml.sh) will this work also ? Because there is a emmc_autoscript which doesn't check for u-boot.ext existance. Do I need to create a custom emmc_autoscript ? Expand All new versions of universal images have scripts that support color correction, including installation in eMMC.
zainali84 Posted January 28, 2020 Posted January 28, 2020 (edited) @balbes150 Hi, Thanks for your efforts. I have been using your image "ARMBIAN 5.73 Debian (stretch) 4.20.2-aml-s912" for quite long. I deleted the image from my pc by mistake and i can't find it in https://yadi.sk/d/srrtn6kpnsKz2. Can you please re upload it. I need it, its very important for me. Thanks Edited January 28, 2020 by zainali84
balbes150 Posted January 28, 2020 Author Posted January 28, 2020 On 1/28/2020 at 6:33 AM, zainali84 said: Can you please re upload it Expand Sori, I don't have the resources to store all versions.
balbes150 Posted January 28, 2020 Author Posted January 28, 2020 Version 20200127. EMMC installation fixes for NanoPC T4. Added deb files with the new kernel to the site for manual kernel updates. 3
stut Posted January 28, 2020 Posted January 28, 2020 On 1/28/2020 at 7:36 AM, balbes150 said: Added deb files with the new kernel to the site for manual kernel updates. Expand Thank you! I'm glad to see them return. Was missing those kernel and kernel header .deb files.
Andypoo Posted January 28, 2020 Posted January 28, 2020 Attempting to use the unified image on H96 Max X2 (S905X2). Previously, I could run Armbian_19.11.3_Aml-g12_buster_legacy_5.3.0_20191126.img from SD using the meson-g12a-x96-max-rmii.dtb and the toothpick start method. Also install to eMMC was successful after editing DTB in extlinux.conf. Now attempting to use Armbian_19.11.5_Arm-64_buster_current_5.5.0-rc6_20200127.img from SD using the same named dtb and toothpick start method but without success. HDMI output is lost when boot process should start (unsure if it gets anywhere). EDIT: I tried both the u-boot-odroid-n2.img and u-boot-odroid-c2.img for patching without success. Any tips appreciated. Andrew.
hippo5329 Posted January 29, 2020 Posted January 29, 2020 On 1/26/2020 at 3:25 PM, Rajesh said: Is it possible to include the Wifi driver ssv6015 with the kernel in the new builds? Or can you point me to the kernel source for the latest builds so that I can attempt to include this for a custom build? Thanks Rajesh Expand It should be main-line kernel with tag v5.5-rc6. You should use gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu from developer.arm.com. I have successfully build modules.
balbes150 Posted January 29, 2020 Author Posted January 29, 2020 On 1/28/2020 at 11:40 PM, Andypoo said: using the meson-g12a-x96-max-rmii.dtb and the toothpick start method. Expand There is no such method for starting Armbian. There is a one-time procedure for activating a universal multi-upload, for which it is possible to use the toothpick method (this is not the only way to activate it). However, this is a one-time procedure and cannot be used for continuous system startup. What systems did you run on this device before ? On 1/28/2020 at 11:40 PM, Andypoo said: EDIT: I tried both the u-boot-odroid-n2.img and u-boot-odroid-c2.img for patching without success. Expand Where did you get the instructions that you need to use these files ?
Andypoo Posted January 29, 2020 Posted January 29, 2020 On 1/29/2020 at 9:45 AM, balbes150 said: There is no such method for starting Armbian. There is a one-time procedure for activating a universal multi-upload, for which it is possible to use the toothpick method (this is not the only way to activate it). However, this is a one-time procedure and cannot be used for continuous system startup. What systems did you run on this device before ? Where did you get the instructions that you need to use these files ? Expand The system was running Android (unchanged) before. I understood I needed to do the toothpick method to boot from SD card, maybe I was mistaken. I understood from this thread that for the universal image, a u-boot file would need to be used, and above in this thread, it was suggested to someone else to use u-boot-odroid-n2 on an S905. Andrew. Update: It seems that the image does actually boot with odroid-n2 u-boot, but no HDMI out. Network is working. (And yes, no toothpick was necessary to boot from SD)
balbes150 Posted January 29, 2020 Author Posted January 29, 2020 On 1/29/2020 at 10:19 AM, Andypoo said: I understood from this thread that for the universal image, a u-boot file would need to be used, and above in this thread, it was suggested to someone else to use u-boot-odroid-n2 on an S905. Expand This is incorrect information, show this message, it needs to be corrected. The order of starting with color fixing is described in the first message of the theme, it specifies exactly what files you need to use and how to configure the system.
starman345 Posted January 29, 2020 Posted January 29, 2020 On 1/28/2020 at 7:36 AM, balbes150 said: Version 20200127. EMMC installation fixes for NanoPC T4. Added deb files with the new kernel to the site for manual kernel updates. Expand Do you have nvme drive for your NanoPC-T4?
balbes150 Posted January 30, 2020 Author Posted January 30, 2020 On 1/29/2020 at 7:40 PM, starman345 said: Do you have nvme drive for your NanoPC-T4? Expand Yes, there is (for the test, I tried a cheap NVMe Orico 128GB model). and it is immediately visible in the system. I can use it to host data. Now I have an Armbian version installed in eMMC with the new u-boot and I can run any system from USB media (SD card is no longer required). By the way, the regular fan also works, it works silently. I liked this model, it is well balanced and has everything you need to use as a mini PC. It remains only to deal with analog sound via Jack 3.5. 1
balbes150 Posted January 30, 2020 Author Posted January 30, 2020 ver 20.02.0-rc1 20200129 The sound works on all models S9xxx, rk3399 , rk3328 , aw h6. Please note that to enable audio on g12 chips s922x s905x2 (models Ugoos AM6, Ugoos x2, Odroid N2 etc), you must follow the instructions specified in the first message. 4
Tommy21 Posted January 30, 2020 Posted January 30, 2020 Hi, i do not understand how to boot latest image, do i need to delete all the options in uenv.ini and leave only amlogic lines with correct dtb, in my case khadas vim3 dtb? I did those steps, and the board only shows khadas logo and reboots after few seconds, nothing is wrong with the board, Android works normally. Is there maybe something specific with g12-b boarda that doesn't allow the board to boot armbian. I did a search, but don't really understand what am i doing wrong, as far as i understood, this u-boot fix is already included in the last image?
Juanjo Posted January 30, 2020 Posted January 30, 2020 On 1/26/2020 at 1:21 PM, xadieu01 said: I have x96 air with lan gigabit version. Everything boot ok with meson-sm1-sei610.dtb but lan didn't work. Can everyone help me to fix it? I tested coreelec with s905x3-4gb-1G.dtb, lan gigabit worked fine Thanks! Expand Try GT1-Mini-A DTB
hexdump Posted January 31, 2020 Posted January 31, 2020 @balbes150 - with "sound works" you mean sound over hdmi and not sound via the analog 3.5mm jack directly on the box - right? i tried the image on a s905x box and got proper sound over hdmi but nothing out of the boxes jack directly ... best wishes - hexdump
dgm78 Posted January 31, 2020 Posted January 31, 2020 On 1/30/2020 at 7:46 AM, balbes150 said: ver 20.02.0-rc1 20200129 The sound works on all models S9xxx, rk3399 , rk3328 , aw h6. Please note that to enable audio on g12 chips s922x s905x2 (models Ugoos AM6, Ugoos x2, Odroid N2 etc), you must follow the instructions specified in the first message. Expand My sound still not working. Removed pulseaudio and ran script, but in alsamixer seems the same. Any other tip?
xadieu01 Posted January 31, 2020 Posted January 31, 2020 On 1/30/2020 at 10:47 PM, Juanjo said: Try GT1-Mini-A DTB Expand Thank you! My x96 Air ethernet connection ok but internet not work. I don't understand why? @balbes150 Can you help me please?
