There are 2 packages that don't seem to download, all the others do.
Err:382 http://ports.ubuntu.com hirsute/main arm64 libvpx6 arm64 1.9.0-1
  Error reading from server. Remote end closed connection [IP: ::1 3142]
Err:419 http://ports.ubuntu.com hirsute/universe arm64 librubberband2 arm64 1.9.0-1
  Connection timed out [IP: ::1 3142]
Fetched 595 MB in 4min 53s (2035 kB/s)
E: Failed to fetch http://ports.ubuntu.com/pool/main/libv/libvpx/libvpx6_1.9.0-1_arm64.deb  Error reading from server. Remote end closed connection [IP: ::1 3142]
E: Failed to fetch http://ports.ubuntu.com/pool/universe/r/rubberband/librubberband2_1.9.0-1_arm64.deb  Connection timed out [IP: ::1 3142]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
[ error ] ERROR in function create_rootfs_cache [ debootstrap.sh:278 ]
[ error ] Installation of Armbian desktop packages failed
[ o.k. ] Process terminated
[ o.k. ] Unmounting [ /home/nicod/build-desktop/.tmp/rootfs-9fd0506ee413f6916aff1957275eafda/ ]
[ error ] ERROR in function unmount_on_exit [ image-helpers.sh:66 ]
[ error ] debootstrap-ng was interrupted
Maybe because it's hirsute?
I'll try building a focal. I should do this with ethernet to be sure. And maybe with the N2+. I'll put it next to my router and ssh.
This morning was just the kernel.
14 часов назад, NicoD сказал:
It didn't work :( no images in output. I'm trying again to see what's going wrong.
18 часов назад, NicoD сказал:
KERNEL_ONLY=yes
You have specified a kernel-only build.  :)
I recommend that you start setting build parameters via the GUI (run the command without parameters).
./compile.sh
The system will offer you a graphical interface for sequentially selecting all the parameters and at the output you will get a non-compressed image that you can write to the media.
9 часов назад, NicoD сказал:
Start by building a server image, it doesn't need a lot of packets and traffic.
That worked. I've got the image in /output/images. Still need to test the image. But seems ok.
[ .... ] Updating initramfs... [ update-initramfs -uv -k 5.9.16-rockchip64 ]
[ o.k. ] Updated initramfs. [ for details see: /home/nicod/build-desktop/output/debug/install.log ]
[ .... ] Re-enabling [ initramfs-tools hook for kernel ]
[ o.k. ] Unmounting [ /home/nicod/build-desktop/.tmp/mount-865a5d3b423ee6bce9320d2ec8206f44/ ]
[ o.k. ] Free SD cache [ 71% ]
[ o.k. ] Mount point [ 89% ]
[ o.k. ] Writing U-boot bootloader [ /dev/loop0 ]
[ o.k. ] SHA256 calculating [ Armbian_21.02.0-trunk_Station-p1_hirsute_current_5.9.16_.img ]
[ warn ] GPG signing skipped - no GPG_PASS [ Armbian_21.02.0-trunk_Station-p1_hirsute_current_5.9.16_.img ]
[ .... ] Fingerprinting
[ o.k. ] Done building [ /home/nicod/build-desktop/output/images/Armbian_21.02.0-trunk_Station-p1_hirsute_current_5.9.16_.img ]
[ o.k. ] Runtime [ 67 min ]
[ o.k. ] Repeat Build Options [ ./compile.sh  BOARD=station-p1 BRANCH=current RELEASE=hirsute BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,img  ]
nicod@arm-64:~/build-desktop$
:D
The server image does work. And I might have found what the problem is. There's a server not found in apt repos.
Get:1 http://ports.ubuntu.com hirsute InRelease [269 kB]
Hit:2 http://ports.ubuntu.com hirsute-security InRelease
Hit:3 http://ports.ubuntu.com hirsute-updates InRelease
Hit:4 http://ports.ubuntu.com hirsute-backports InRelease
Ign:5 https://minio.k-space.ee/armbian/apt hirsute InRelease
Err:6 https://mirrors.dotsrc.org/armbian-apt hirsute Release
  404  Not Found [IP: 130.225.254.116 443]
Reading package lists... Done
E: The repository 'http://apt.armbian.com hirsute Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Unable to install the Armbian desktop with armbian-config.
I was able to install ubuntu-mate-desktop. Doesn't boot into desktop but can start it with startx.
I think the reason my SBC builds didn't work was because I always tried hirsute desktop. All others worked. So I'm happy to know I now can easily build images with my SBCs.
Wasn't an ARM problem.
I'll need a new 12V adapter so I can put my N2 next to my router as build server. The P1 stole the N2 its adapter.
I'm glad the troubles been found because I was starting to doubt in myself :) Thank you @balbes150
Video coming soon.
Had the same issue. The reason was that I did not create another user than root. lightdm refuses to start if there is no normal user present.
I did create my user before installing the desktop. Was logged in with my user when installing the desktop. It doesn't seem to perform very good. So nothing here to see for me.
@IgorI'm making a video about building Armbian images on Armbian. I've got a few question I'd need to answer before I can finish it.
1. Does this work on other distros than Focal? (I only tried it on Focal)
2. Does this work on armhf? (I guess not)
3. Will the /lib64/Id-linux-x86-64.so.2 file be installed by default on supported Armbian images? Any link to that files for download?
4. Anything else I should know?
I've now build 3 different images successfully. So I'm convinced the problems I had were just with the Hirsute desktop.
I'll make a video now about building on arm. Later I will make a video about all the different desktops. But I'll already talk about it here.
1. Probably works, but elsewhere was always a lottery / unsupported.
2. Try. I didn't.
3. Once we will support this type of building, we will ship what's needed. Currently this is still formally in development and it doesn't have high priority. Desktop has. We are aware that certain things doesn't work at all.
4. Desktop and native arm building is still months to go to reach v1.0 / user level. We plan to merge support in 1/2021 but only XFCE setup will be officially supported. Further official support will remain dependent from community involvement. We expanded that tool can handle desktops pretty easy, but maintaining more than 1-3 configurations is not planned / not possible. We are also considering partnership with desktop designers, which could develop this further. Our focus was not to provide good looking desktops with top UX. We actually didn't do anything about that ... we were focused only on a framework which now supports much easier desktop development ...
Building latest trunk Ubuntu userland is related with a great portion of luck and its most likely not related to our build engine. There are no plans nor resources to support Canonical beta userland development. Official Armbian support will be tied to stable / LTS versions as we do it since ever.
1 час назад, NicoD сказал:
I planned to create a simple DEB package with these files for easy installation as a dependency of the build environment, but so far there is not enough free time for this (after creating the package, it still needs to be placed in a network repository and check how it will work on different versions of distributions). So for now, I limit myself to "simple dumb copying" and including these files in all my images. :(
p.s. Unfortunately, those who want to help, at least in such simple operations, are not observed. Everyone wants to get everything for free, beautiful and that everything would work out of the box ....
No problem. I've said it's still in beta and it is best to use one of your images to build. I'll link to your download page.
I also show the /lib64/... file that is needed.
Thank you for your amazing efforts and help(and @Werner and @Igor and the others).
I'd love to help out more with coding, but then I'd have no time left for my tasks like making videos.
And I'm no coder anymore, I don't have the overview that I used to have. Brain damage makes me be not so smart :mellow: You don't need to be smart to be happy :D
8 минут назад, NicoD сказал:
You do your job well.  :)
It is not necessary to know everything, in the modern world only specialization in a narrow direction will allow you to achieve good results. Unfortunately, the number of "narrow specialists" who work on the development of Armbian is scanty and they have a huge load ....
I've just tried the Buster legacy xfce4 image I've build for the Station P1.
No display, the heartbeat led is on.
@Werner Didin't you have these issue's too?
I'll try @balbes150 Buster P1 images.
Yeah had the same issues and ended up using one of @balbes150 images which worked oob.
13 часов назад, NicoD сказал:
Try using my "armbian-tv-next" branch to build images for P1\M1. It has changes that use a different kernel for legacy. I am not creating a PR yet, until it is agreed with the rest of the interested developers which legacy kernel is best to use for P1\M1.
@TonyMac32 @piter75 @Igor would be nice to get your opinion here to provide proper official images again.
If we are talking about moving the P1 from RK3399 to rockchip64, I don't know, my opinion is do what is best. But if we are talking about introducing a completely new Legacy kernel, I think it is a very bad idea. Two kernels is already a mess for RK3399 boards, and introducing a third one would be a nightmare.
I suggest it is better to do some work in making the P1 work with some of our existing kernels. After all, the P1 came into scene just a few weeks ago, it is normal that everything is not working yet.
There is no "new" kernel for P1, I use the rockchip64 kernel (all patches are regular from the build system only added patches for DTB), the difference is only in the kernel configuration + adding drivers for WiFi.
@balbes150If it doesn't hinder other boards I would not know why not to use your configuration. All seems fine here.
But I've no clue why the default kernel doesn't work.
I think you're knowledgeable enough to do what is right.
Are the kernel config differences unable to be added to our current ones? Same with the wifi, is there some kind of incompatibility?
Ultimately we should have a single kernel source for all rockchip64 devices ;p
At this point neither rockchip64 nor rk3399 is really fit for that. They do not support rk3308 as a simple example. It should probably be some more or less stable cut from Rockchip's master.
Until recently I was actually more inclined to move devices from rockchip64 to rk3399 and make it a base for switching to Rockchip's master whether it would be 4.4 or 4.19 (FriendlyElec is already using 4.19 for R4S).
On the other hand boards are now divided ~50/50 between those kernels so we can move Station P1 to rockchip64 if it fits there better.
We will worry about switching to some form of Rockchip's master later - most probably not earlier than with first rk3568 boards...
As stated above I see no harm in that.
My NVMe hat ain't coming.
And the price also gone up. But will you receive it when you order??? I asked the seller what's wrong and didn't get a response. Too bad, I really wanted to try this.
I had the same.
They explained after a few days that it had some outgoing customs issues and asked me to place the order again.
Yesterday I opened a dispute which was resolved by Aliexpress within an hour in my favour and today I got the money back.
Seeing how well it went with the dispute I ordered it again - it was 0.25EUR more expensive now. Let's see how it fares this time ;-)
@NicoD Can you shoot a video on how to download and burn an Armbian image to an SD card using only a regular Android on P1 ? I. e. I am interested in a video how to run Armbian with only P1. This instruction allows any user, without any additional devices (PC, laptop, etc.) to get a working Armbian on any supported device. :)
That's a good idea. I'll see what tool is best used in Android to burn the image. I've never used android for it, but since people with P1/M1 certainly have Android it is a great idea.
I've got a video planned where I show a full installation of Armbian Buster Legacy. I can start it in Android. I'll make the video when my NVMe hat arrives. Thanks for the idea. I wouldn't have thought about it.
p.s. I've got a Mecool KM6 with S905X4 to review Android 10 on it. I don't suppose there will be Armbian for this? Just asking so I don't say anything wrong.
I like the box, but I can't get used to Android. For watching video it's ok, but for productivity tasks it is bad.
6 минут назад, NicoD сказал:
For TV boxes, there is no official Armbian, so there is no point in wasting time on this, on each TV box, the process will be different and users will be tormented by questions about why they do not find the elements that you will tell about. :)
