AndrewDB Posted April 1, 2019 Posted April 1, 2019 5 minutes ago, Zumbara98 said: I ask for help in the launch. Read the instructions in the first post of this thread, or here: https://github.com/150balbes/Amlogic_s905/wiki/s905_multi_boot
Zumbara98 Posted April 1, 2019 Posted April 1, 2019 I read this manual, the SD card is true for 32 gigabytes, but less is not. And there is no u boot section in the stock firmware, but there is a bootioader section. Maybe that's why it does not start?
balbes150 Posted April 1, 2019 Author Posted April 1, 2019 42 minutes ago, Zumbara98 said: Gi spark 3 combo Is that a satellite receiver ?
Zumbara98 Posted April 1, 2019 Posted April 1, 2019 Yes, it is a combo receiver, with dvb-c, t2, s2 and android 5.1.1.The firmware is here:https://giclub.tv/index.php?board=451.0
balbes150 Posted April 1, 2019 Author Posted April 1, 2019 38 minutes ago, Zumbara98 said: Yes, it is a combo receiver, with dvb-c, t2, s2 and android 5.1.1.The firmware is here It will not work, there is a different type of CPU.
Zumbara98 Posted April 1, 2019 Posted April 1, 2019 Amlogic S905 Quad Core A53 64bit 2.0 GHZ processor Built-in graphics 3D processor with support for Mali-450MP RAM: 1 GB Flash memory: 8 GB DVB-S / S2 Tuner: TS2022 DVB-T / T2 / C Tuner: MX608 Fully compatible with DVB-S / S2 (UHD, HEVC), DVB-T / T2 / C standards Android 5.1.1 operating systems (Lollipop)Why a different type of cpu? Is it the Amlogic s905?
balbes150 Posted April 2, 2019 Author Posted April 2, 2019 12 hours ago, Zumbara98 said: Amlogic S905 Quad Core A53 64bit 2.0 GHZ processor What exactly is the error of multi-boot activation ? Write in detail all the steps.
Zumbara98 Posted April 2, 2019 Posted April 2, 2019 The steps are:write armbian 5.77 desktop with Rufus on SD card 32 GB,pre-othermaterial in NTFS .Step two insert the card into the receivers previously de-energized.I pinch the button on the rear panel with a toothpick,connect the power.I wait 15 seconds,let go of the toothpick,but nothing happens,the usual stock Android is loaded.When using amlogic autoscript.zip via stock updater gives error:Software packade error
AndrewDB Posted April 2, 2019 Posted April 2, 2019 @Zumbara98 Try to update your Android firmware to a newer version from the vendor website.
haimd Posted April 3, 2019 Posted April 3, 2019 Hello, I'm new member. I am using a T95M (S905X -1G RAM, 8G ROM) and boot ubuntu 16.04 with kernel 13.14.29. Now I want to boot from emmc . What can I do ? Thank you. I tried coppy gxbb_p201.dtb and gxl_p212_1g.dtb and rename dtb.img But I taked Black screen.With gxl_p212_1g.dtb -> dtb.img root@amlogic:~# sudo ./install.sh Start copy system for DATA partition. Formatting DATA partition... umount: /dev/data: not mounted /dev/data contains a ext4 file system last mounted on /ddbr/install on Wed Apr 3 02:55:57 2019 e2fsck 1.42.13 (17-May-2015) /dev/data: clean, 11/289728 files, 53226/1158144 blocks done. Copying ROOTFS. Copy BIN Copy BOOT tar: boot/System Volume Information/WPSettings.dat: time stamp 2019-04-03 08:53:46 is 19790.731671312 s in the future tar: boot/System Volume Information/IndexerVolumeGuid: time stamp 2019-04-03 08:53:46 is 19790.729878895 s in the future tar: boot/System Volume Information: time stamp 2019-04-03 08:53:46 is 19790.729112228 s in the future Create DEV Copy ETC Copy HOME Copy LIB Create MEDIA Create MNT Copy OPT Create PROC Copy ROOT Create RUN Copy SBIN Copy SELINUX Copy SRV Create SYS Create TMP Copy USR Copy VAR Copy fstab ******************************************* Done copy ROOTFS ******************************************* Writing new kernel image... 65536+0 records in 65536+0 records out 33554432 bytes (34 MB, 32 MiB) copied, 0.653492 s, 51.3 MB/s /dev/boot: no Android Magic Value /dev/boot: not a valid Android Boot Image. /dev/boot: no Android Magic Value /dev/boot: not a valid Android Boot Image. /dev/boot: no Android Magic Value /dev/boot: not a valid Android Boot Image. /dev/boot: no Android Magic Value /dev/boot: not a valid Android Boot Image. done. Writing new dtb ... done. Write env bootargs ******************************************* Complete copy OS to eMMC parted DATA ******************************************* With gxbb_p201.dtb -> dtb.img I give same proplem. I done boot from emmc with Ubuntu 18.04 kernel 4.20 But I need Ubuntu 16.04 I found link img : https://yadi.sk/d/pHxaRAs-tZiei
amirul Posted April 3, 2019 Posted April 3, 2019 sorry wrong post (this post). Is there a way to delete a post?
haimd Posted April 4, 2019 Posted April 4, 2019 On 10/23/2018 at 2:57 PM, balbes150 said: 1. Run Armbian version with kernel 3.14 from external media (SD card or USB flash drive). And look how much RAM there is. 2. If there is also 1GB of RAM, then your model does not have 2 GB , open the case and check the marking of chips or contact the seller. 3. If you have a firmware file with Android, you can restore the system to its original state using a USB cable and a firmware program. How do boot from emmc on kernel 3.14 ??
balbes150 Posted April 4, 2019 Author Posted April 4, 2019 On 4/3/2019 at 6:38 AM, haimd said: /dev/boot: no Android Magic Value /dev/boot: not a valid Android Boot Image. Your firmware cannot work with kernel 3.14
thanxx Posted April 4, 2019 Posted April 4, 2019 Hi @balbes150 First of all, thank you for your work! I have a few questions: 1. How to update your armbian builds? is it possible over armbian-config? 2. Can I install latest v 5.77 to eMMC?
haimd Posted April 5, 2019 Posted April 5, 2019 19 hours ago, balbes150 said: Your firmware cannot work with kernel 3.14 Thank you.!
thatchunkylad1989 Posted April 9, 2019 Posted April 9, 2019 Hi, quick question.. I tried to use this (and did, it worked) but I can't see the actual eMMC when I type "lsblk" or within gparted. Is there a recommended kernel to use or version? So I'm getting this right... Download: Armbian_5.41_S9xxx_Debian_stretch_4.9.40_xfce_20180315.img flash to SD, go onto the TV box and make sure I update it so it boots from the SD. Now what? I can't see the eMMC that android is installed on and when I even try to install to the eMMC, it gives errors.... What do I need to do so I can remove android and just use armbian? I've read the OP: Quote 1. Download the image for your device 2. Unpack 3. Burn the image on the medium 4. boot into Android 5. open the app "Update&Backup" 6. click on "Select" local update and chose the file on the removable media (aml_update.zip) aml_autoscript.zip 7. start "Update" 8. System will reboot twice and start running the system from external media. 9. If after 7-10 minutes on the monitor not to receive any messages on system startup. Turn off TV box and manual copy into the first partition BOOT (FAT) the file "dtb.img". On the media there is a directory "dtb" from where you can take the file and copy it to the root of /boot rename it to "dtb.img". But still don't get it; where is the dtb file located? Yeah, I've flashed the img to the SD and looked in "media" it's not there....... please, someone; help!
martinayotte Posted April 9, 2019 Posted April 9, 2019 2 hours ago, thatchunkylad1989 said: I can't see the eMMC that android is installed on Are you sure that you have an eMMC ? Some box have NAND, which is not the same as eMMC, two different technologies, two different drivers, and most Mainline don't support NAND at all. Just to make sure, run "dmesg | grep mmc" and look if there are lines with "mmc1" or "mmc2" (knowing that "mmc0" should be the SDCard)
thatchunkylad1989 Posted April 9, 2019 Posted April 9, 2019 31 minutes ago, martinayotte said: Are you sure that you have an eMMC ? Some box have NAND, which is not the same as eMMC, two different technologies, two different drivers, and most Mainline don't support NAND at all. Just to make sure, run "dmesg | grep mmc" and look if there are lines with "mmc1" or "mmc2" (knowing that "mmc0" should be the SDCard) Will have a look now. do you have any idea about the dtb file? My English isn't the best and neither is the OP's. I flashed this: https://yadi.sk/d/pHxaRAs-tZiei/5.44/kernel_3.14_20180729 by icewm. Don't see the S905w in boot/media ? It's definitely emmc, just checked. mount: ddbr/install special device /dev/data does not exist. What am I doing wrong? Damnit! now android won't boot. sigh. Just put the SD card back into it and it booted. I didn't do a backup of android though... Can I get android back on it? I give up.
balbes150 Posted April 10, 2019 Author Posted April 10, 2019 10 hours ago, thatchunkylad1989 said: mount: ddbr/install special device /dev/data does not exist. What are these commands you're trying to execute ? 10 hours ago, thatchunkylad1989 said: I didn't do a backup of android though... I am always amazed by people who do not study anything, do not ask for advice before doing something, and immediately rush to poke everything, and then ask for help. 10 hours ago, thatchunkylad1989 said: Can I get android back on it? Use USB Burn Tool.
thatchunkylad1989 Posted April 10, 2019 Posted April 10, 2019 3 hours ago, balbes150 said: What are these commands you're trying to execute ? I am always amazed by people who do not study anything, do not ask for advice before doing something, and immediately rush to poke everything, and then ask for help. Use USB Burn Tool. I ran the install.sh and it gave the error I posted above. I tried using the usb tool but my device isn't recognised and I don't know how to put it in recovery... It's the MXQ PRO S905W.
balbes150 Posted April 10, 2019 Author Posted April 10, 2019 2 hours ago, thatchunkylad1989 said: I ran the install.sh and it gave the error I posted above. I tried using the usb tool but my device isn't recognised and I don't know how to put it in recovery... It's the MXQ PRO S905W. Start Armbian and erase /dev/bootloader "dd if=/dev/zero of=/dev/bootloader". After that, the USB Burn Tool should start. In the future, if you don't understand what you're doing, don't take it.
thatchunkylad1989 Posted April 10, 2019 Posted April 10, 2019 5 hours ago, balbes150 said: Start Armbian and erase /dev/bootloader "dd if=/dev/zero of=/dev/bootloader". After that, the USB Burn Tool should start. In the future, if you don't understand what you're doing, don't take it. I would try that but I tried flashing a rom for it and now I keep getting a disk error at 7%.... This is the file I'm trying to flash: https://mega.nz/#!VnhjTSYa!t6w10yz0zXHFCRugsvZJibyjISz_g7uN-jAJp9OVKZI and it's for the: amlogic s905w 1gb 8gb firmware mxq pro 4k and youtube link: I keep getting a disc write error???????????????? How long does android take to boot after a successful flash? Hi, are you there??????????????????
almotra Posted April 14, 2019 Posted April 14, 2019 Hello, I am French, sorry for my bad English . For me, impossible to activate auto login, etc/lightdm ... not exist . I use the latest version 5.78 for S905 without desktop. Cordialement Alex
balbes150 Posted April 15, 2019 Author Posted April 15, 2019 On 4/10/2019 at 5:42 PM, thatchunkylad1989 said: I keep getting a disc write error???????????????? How long does android take to boot after a successful flash? Hi, are you there?????????????????? Issues firmware Android looking forum Freacktab, there is a lot of information. You may need to use a different USB port, or a different order of steps for your model. 16 hours ago, almotra said: I am French, sorry for my bad English . For me, impossible to activate auto login, etc/lightdm ... not exist . I use the latest version 5.78 for S905 without desktop. use nodm
thanh_tan Posted April 16, 2019 Posted April 16, 2019 Hi @balbes150 I use the X96 Mini with S905W, i tried all the fw in this list but no fw can activate the wifi https://yadi.sk/d/pHxaRAs-tZiei Can you help?
balbes150 Posted April 16, 2019 Author Posted April 16, 2019 6 hours ago, thanh_tan said: I use the X96 Mini with S905W, i tried all the fw in this list but no fw can activate the wifi https://yadi.sk/d/pHxaRAs-tZiei Can you help? x96mini -> WiFi ssv6051 -> You can forget about it, the chip manufacturer has long disappeared and no one will make a driver for it
anonymox Posted April 27, 2019 Posted April 27, 2019 Hi @balbes150, I flashed Debian 5.77 to my SDcard. It booted ok with my new TX3 mini (type A). But now, when I ejected the SDcard from box, I can't boot to Android anymore. It stucked at device's booting logo. I dont't install Armbian to eMMC. Just boot from SDcard and than eject it. Currently, I still can boot to SDcard, but Android is not. The only way to back to Android is re-flash the Android firmware. I used "dmesg | grep mmc" command to check my device is eMMC or NAND, I found this: mmc2: new high speed SDIO card at address 0001 Can you help me? How to dual boot?
balbes150 Posted April 27, 2019 Author Posted April 27, 2019 25 minutes ago, anonymox said: Can you help me? How to dual boot? For the analysis, you need the output of the "printenv" "help" commands from the UART console.
anonymox Posted April 28, 2019 Posted April 28, 2019 19 hours ago, balbes150 said: For the analysis, you need the output of the "printenv" "help" commands from the UART console. Are there other ways to do that? My device will lost warranty if I open it.
balbes150 Posted April 28, 2019 Author Posted April 28, 2019 1 hour ago, anonymox said: Are there other ways to do that? My device will lost warranty if I open it. Try to start the system with kernel 3.14 and run "fw_printenv" commands there.
