krachlatte Posted November 8, 2019 Posted November 8, 2019 Hi guys, are ther any plans to upgrade u-boot to 2019.10 from u-boot v2019.04, because libreelec is allready using this and they have a working device tree for the H6 beelink device many thanks
martinayotte Posted November 8, 2019 Posted November 8, 2019 10 minutes ago, krachlatte said: are ther any plans to upgrade u-boot to 2019.10 from u-boot v2019.04 It is planned, I'm already using it for my local builds ...
Igor Posted November 8, 2019 Posted November 8, 2019 13 minutes ago, martinayotte said: It is planned, I'm already using it for my local builds ... You already sort out patches? Then we can perhaps squeeze this in by the end of the month?
martinayotte Posted November 8, 2019 Posted November 8, 2019 11 minutes ago, Igor said: You already sort out patches? Then we can perhaps squeeze this in by the end of the month? I've sorted out patches that were preventing builds, but there still some patches where chunks failed without disturbing builds, let says, for OPi3/OPiLite2/OPiOnePlus/PineH64 as well as H3/H5 ones . Yes, maybe end of the month is a good target ...
Igor Posted November 8, 2019 Posted November 8, 2019 10 minutes ago, martinayotte said: I've sorted out patches that were preventing builds, but there still some patches where chunks failed without disturbing builds, let says, for OPi3/OPiLite2/OPiOnePlus/PineH64 as well as H3/H5 ones . Yes, maybe end of the month is a good target ... IHMO u-boot bumping is not that critical and can wait for next major release. Time for proper testing, not just for adjusting patches, is missing component I would like to start following this if there will be no major oppositions to the plan ... I am probably travelling in the early December. In any case its busy month for all.
kexec Posted November 8, 2019 Posted November 8, 2019 does anyone know where is the trick, older image generates less heat than newer one? is this related with cpu voltage or uboot version ? for example older image: Welcome to Ubuntu Bionic with Armbian Linux 5.1.12-sunxi64 root@orangepi3:~# cat /sys/devices/virtual/thermal/thermal_zone[01]/temp 38168 39109 root@orangepi3:~# cat /sys/devices/virtual/thermal/thermal_zone[01]/type cpu_thermal gpu_thermal newer stays around 48 celsius in same environment (no load on device, room temperature same,small passive cooler on cpu) Welcome to Ubuntu Bionic with Armbian Linux 5.3.9-sunxi64 root@orangepi3:~# cat /sys/devices/virtual/thermal/thermal_zone[01]/temp 47375 48517 root@orangepi3:~# cat /sys/devices/virtual/thermal/thermal_zone[01]/type cpu-thermal gpu-thermal
megi Posted November 9, 2019 Posted November 9, 2019 Did you measure the heatsink/package temperature? It should be a few (~5°C, depending on the difference between room/die temps) centigrades lower than the die temperature that's reported by the driver. For example for me, I see 43°C idle (all cores at 1.8GHz) reported by the driver, and 37-38°C measured by the IR thermometer. (no heatsink, but I use a fan) Without a fan it would be close to 50-55°C idle. Thermal drivers and OPP tables maz be different between those two releases.
dolphs Posted November 11, 2019 Posted November 11, 2019 On 11/8/2019 at 5:54 PM, martinayotte said: I've sorted out patches that were preventing builds, but there still some patches where chunks failed without disturbing builds, let says, for OPi3/OPiLite2/OPiOnePlus/PineH64 as well as H3/H5 ones . Yes, maybe end of the month is a good target ... should be excellent considering kernel 5.4 will be stable by then, will stay tuned chaps. thanks for your efforts!
kexec Posted November 12, 2019 Posted November 12, 2019 On 11/9/2019 at 4:13 PM, megi said: Did you measure the heatsink/package temperature? It should be a few (~5°C, depending on the difference between room/die temps) centigrades lower than the die temperature that's reported by the driver. For example for me, I see 43°C idle (all cores at 1.8GHz) reported by the driver, and 37-38°C measured by the IR thermometer. (no heatsink, but I use a fan) Without a fan it would be close to 50-55°C idle. Thermal drivers and OPP tables maz be different between those two releases. no, i havent measured outside temps as have no IR thermometer. but once I am changing sd card I can feel that little difference. I guess more scientific way would be to measure power consumption. will try to do that and update BSP image from opi page generates highest temp, then goes armbian latest and then older version (for example 5.1.12) which acts like i would expect when there is no action happening on cpu
Werner Posted November 12, 2019 Posted November 12, 2019 There was a - let's say - "controversial" discussed patchset that optimizes the opp table for the H6 SoC and at least in my eyes it turned out that these boards are not really identical. Some even crash with the new table, others (like mines) running decent with it. Their components seem to have quite wide tolerances. A too high voltage for a certain chip could lead to a higher temperature. Check this: https://github.com/armbian/build/pull/1547
JORGETECH Posted November 12, 2019 Posted November 12, 2019 17 hours ago, Werner said: There was a - let's say - "controversial" discussed patchset that optimizes the opp table for the H6 SoC and at least in my eyes it turned out that these boards are not really identical. Some even crash with the new table, others (like mines) running decent with it. Their components seem to have quite wide tolerances. A too high voltage for a certain chip could lead to a higher temperature. Check this: https://github.com/armbian/build/pull/1547 Was this change introduced in the nightlies? Because I'm running nightly and my board boots just fine (I'm writing from it right now).
Werner Posted November 13, 2019 Posted November 13, 2019 I think the "problems" started somewhen around this point: https://github.com/armbian/build/pull/1407
JORGETECH Posted November 13, 2019 Posted November 13, 2019 12 hours ago, Werner said: I think the "problems" started somewhen around this point: https://github.com/armbian/build/pull/1407 Can I run an stability test or does it need to be verified by other means?
Werner Posted November 13, 2019 Posted November 13, 2019 I never dug deeper into this situation as it worked for me nicely out of the box. I just followed the discussion more or less.
kexec Posted November 14, 2019 Posted November 14, 2019 i have checked power consumption when device boots up and nothing is connected to it Ubuntu opi BSP 4.9 kernel 490ma ubuntu armbian 5.1.12 330ma ubuntu/debian armbian 5.3.9 360ma LibreELEC 9.80-nightly-20191108-27a5673 330ma android 7 (from opi site) 490ma 1
Localhost Posted November 14, 2019 Posted November 14, 2019 There is a chance that higher power consumption is coming from graphics unit being used (probably)
jernej Posted November 14, 2019 Posted November 14, 2019 18 minutes ago, Localhost said: There is a chance that higher power consumption is coming from graphics unit being used (probably) LibreELEC uses it too, but admittedly at low frequency, 270 MHz IIRC, because you don't need higher speed for GUI rendering.
JORGETECH Posted November 15, 2019 Posted November 15, 2019 Is there any way to change a dts file when compiling Armbian? The GPU is disabled in the dts file for H6 and I wanted to enable it just for curiosity.
martinayotte Posted November 16, 2019 Posted November 16, 2019 14 hours ago, JORGETECH said: The GPU is disabled in the dts file for H6 Are you sure ? Which image are you using ? What "cat /proc/device-tree/soc/gpu@1800000/status" is reporting ?
JORGETECH Posted November 17, 2019 Posted November 17, 2019 23 hours ago, martinayotte said: Are you sure ? Which image are you using ? What "cat /proc/device-tree/soc/gpu@1800000/status" is reporting ? I guess the GPU is active since the output from that command is "okay". Is there an Armbian patch that enables it? I can see it's disabled in the kernel code (display engine disabled too): https://megous.com/git/linux/tree/arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi?h=opi3-5.3 It's a pity that Mesa has support for this GPU disabled (or not implemented?) I would like to test even though it could be unstable.
martinayotte Posted November 17, 2019 Posted November 17, 2019 15 minutes ago, JORGETECH said: I guess the GPU is active since the output from that command is "okay". Right ! 15 minutes ago, JORGETECH said: I can see it's disabled in the kernel code (display engine disabled too) They are disabled in DTSI, because it common practice, but enabled in Main DTS of OPi3 : https://megous.com/git/linux/tree/arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-3.dts?h=opi3-5.3 This mean it is not a kernel issue, but libraries and applications ...
JORGETECH Posted November 17, 2019 Posted November 17, 2019 4 minutes ago, martinayotte said: They are disabled in DTSI, because it common practice, but enabled in Main DTS of OPi3 : https://megous.com/git/linux/tree/arch/arm64/boot/dts/allwinner/sun50i-h6-orangepi-3.dts?h=opi3-5.3 I was just going to point that out. 6 minutes ago, martinayotte said: This mean it is not a kernel issue, but libraries and applications ... I could ask in Mesa IRC if I can enable it for the Mali T720 MP2 for testing or if it's not implemented yet.
jernej Posted November 17, 2019 Posted November 17, 2019 1 minute ago, JORGETECH said: I could ask in Mesa IRC if I can enable it for the Mali T720 MP2 for testing or if it's not implemented yet. For T720 you need at least kernel 5.4 and mesa master along with this patch. I'll start testing mesa support for T720 in LibreELEC soon, but according to developer who made T720 mesa PR to LE, it is already quiet good. Hopefully by the time of mesa 20, major bugs will be fixed.
JORGETECH Posted November 17, 2019 Posted November 17, 2019 5 hours ago, jernej said: For T720 you need at least kernel 5.4 and mesa master along with this patch. I'll start testing mesa support for T720 in LibreELEC soon, but according to developer who made T720 mesa PR to LE, it is already quiet good. Hopefully by the time of mesa 20, major bugs will be fixed. Just what I was looking for! In that case I'll wait to kernel 5.4 and test.
martinayotte Posted November 17, 2019 Posted November 17, 2019 3 minutes ago, JORGETECH said: In that case I'll wait to kernel 5.4 and test. For sunxi-dev, it is planned to switch to 5.4.y by the end-of-the-month, maybe next week ...
AZ8 Posted November 18, 2019 Posted November 18, 2019 I have 2 questions: 1. how far Armbian on Opi3 from stable point? 2. did someone compare performance Kodi on Armbian over LibreELEC? Is LibreELEC significantly faster?
jcaron Posted November 18, 2019 Posted November 18, 2019 24 minutes ago, AZ8 said: 1. how far Armbian on Opi3 from stable point? This probably depends on your specific use case and the specific features you use. In my case I find it very stable, but I don't use any of the video acceleration features for instance, or sound, or cameras, and I haven't tested WiFi much. The only thing I'm waiting for is 3D GPU support.
GeorgeP Posted November 18, 2019 Posted November 18, 2019 2 hours ago, AZ8 said: 1. how far Armbian on Opi3 from stable point? 2. did someone compare performance Kodi on Armbian over LibreELEC? Is LibreELEC significantly faster? 1: I'm running an OPi3 as a headless server and I have no issues whatsoever.... Welcome to Ubuntu Bionic with Armbian Linux 5.3.0-sunxi64 System load: 0.02 0.07 0.03 Up time: 55 days Memory usage: 36 % of 1993MB Zram usage: 5 % of 996Mb IP: 192.168.x.x CPU temp: 54°C Usage of /: 52% of 7.1G 2: I have no idea. If I wanted a media centre I'd just buy a TV-box
AZ8 Posted November 21, 2019 Posted November 21, 2019 Hi guys! Is it possible to include this patch into Armbian tree? patch: https://lists.freedesktop.org/archives/pulseaudio-discuss/2019-June/031168.html explanation: https://habr.com/ru/post/456476/
Igor Posted November 21, 2019 Posted November 21, 2019 2 hours ago, AZ8 said: Is it possible to include this patch into Armbian tree? If you prepare it and maintain when needed, why not. And for all different kernel options of course: https://github.com/armbian/build/tree/master/config/kernel
