ilchenko Evgeny Posted April 10, 2019 Posted April 10, 2019 Guys. is in this image "Armbian_5.78.190409_Orangepi3_Ubuntu_bionic_dev_5.0.7.7z" already fixed reboot problrm or not? If not, help pls with recompile u-boot. I'm boot from eMMC. thx
dolphs Posted April 10, 2019 Posted April 10, 2019 12 minutes ago, ilchenko Evgeny said: Guys. is in this image "Armbian_5.78.190409_Orangepi3_Ubuntu_bionic_dev_5.0.7.7z" already fixed reboot problrm or not? If not, help pls with recompile u-boot. I'm boot from eMMC. thx reboot issue, please check here for me was NOK so far, both stretch and bionic. You might want to try the nightly build, to be found here and report back in this section please rgd reboot issue, although I tested things building from scratch ( opiplus ) I did not test the nightly but for me so far NOK cheers!
GeorgeP Posted April 10, 2019 Posted April 10, 2019 42 minutes ago, dolphs said: You might want to try the nightly build, to be found here and report back in this section please rgd reboot issue, Erm... Careful people, that link is to nightly images for the OPi One Plus and not the OPi Three
dolphs Posted April 10, 2019 Posted April 10, 2019 1 minute ago, GeorgeP said: Erm... Careful people, that link is to nightly images for the OPi One Plus and not the OPi Three err I did put https://dl.armbian.com/orangepi3/nightly/ for OpiOnePlus: https://dl.armbian.com/orangepioneplus/nightly/ hope this is clear now
moneyrain Posted April 10, 2019 Posted April 10, 2019 do the wifi trick still work in latest nightly? It work before for me, and when i flash the latest nightly and apply the trick, nmtui wont show my wifi network any more. Any one can give me the idea for this ?
betepok Posted April 10, 2019 Posted April 10, 2019 @moneyrain cp /lib/firmware/rkwifi/fw_bcm43456c5_ag.bin /lib/firmware/brcm/brcmfmac43456-sdio.bin cp /lib/firmware/rkwifi/nvram_ap6256.txt /lib/firmware/brcm/brcmfmac43456-sdio.txt reboot
Kiel Posted April 11, 2019 Posted April 11, 2019 11 hours ago, moneyrain said: do the wifi trick still work in latest nightly? i was able to use betepok's suggestion with a slight modification on the april 10th (5.0.7) nightly. cp /lib/firmware/rkwifi/fw_bcm43456c5_ag.bin /lib/firmware/brcm/brcmfmac43456-sdio.bin cp /lib/firmware/rkwifi/nvram_ap6256.txt /lib/firmware/brcm/brcmfmac43456-sdio.xunlong,orangepi-3.txt the second command is a bit more complex; got the magic filename from dmesg errors. hope this helps.
moneyrain Posted April 11, 2019 Posted April 11, 2019 10 hours ago, Kiel said: i was able to use betepok's suggestion with a slight modification on the april 10th (5.0.7) nightly. cp /lib/firmware/rkwifi/fw_bcm43456c5_ag.bin /lib/firmware/brcm/brcmfmac43456-sdio.bin cp /lib/firmware/rkwifi/nvram_ap6256.txt /lib/firmware/brcm/brcmfmac43456-sdio.xunlong,orangepi-3.txt the second command is a bit more complex; got the magic filename from dmesg errors. hope this helps. Thx u alot, it works for me now
megi Posted April 12, 2019 Posted April 12, 2019 I now have Bluetooth working with mainline linux on Orange Pi 3. It's in my opi3-5.1 branch. So, test if you like. 1
moneyrain Posted April 12, 2019 Posted April 12, 2019 1 hour ago, megi said: I now have Bluetooth working with mainline linux on Orange Pi 3. It's in my opi3-5.1 branch. So, test if you like. could u plz give us a link to ur branch? Sorry i tried to find but found none edit: i google megous and found a github but the last commit is 16 days ago
greg798 Posted April 12, 2019 Posted April 12, 2019 1 hour ago, megi said: It's in my opi3-5.1 branch. So, test if you like. Thanks I will try later
kexec Posted April 12, 2019 Posted April 12, 2019 @megi i guess you compile kernel manually and put it to correct place ? i just have changed https://github.com/armbian/build/blob/master/config/sources/sun50iw6.conf to your suggested branch and fired up armbian image creation which have failed. scripts/Makefile.lib:311: recipe for target 'arch/arm64/boot/dts/allwinner/sun50i-h5-nanopi-m1-plus2.dtb' failed scripts/Makefile.build:486: recipe for target 'arch/arm64/boot/dts/allwinner' failed Makefile:1228: recipe for target 'dtbs' failed
wm5 Posted April 12, 2019 Posted April 12, 2019 Thanks to betepok, Kiel and moneyrain postes I was able to tune WiFi in my OrangePi 3+. but according to my dmesg I have: cp /lib/firmware/rkwifi/fw_bcm43456c5_ag.bin /lib/firmware/brcm/brcmfmac43455-sdio.bin cp /lib/firmware/rkwifi/nvram_ap6256.txt /lib/firmware/brcm/brcmfmac43455-sdio.xunlong,orangepi-3.txt Thanks to all.
kexec Posted April 12, 2019 Posted April 12, 2019 ok, I didn't expected that this would work but it did on opi3 armbian build git clone https://github.com/megous/linux.git cd linux make oldconfig make -j5 make Image make modules_install mv /boot/Image /boot/Image_backup cp arch/arm64/boot/Image /boot/Image reboot ---- edid still a problem root@orangepi3:~# cat /sys/class/drm/card0-HDMI-A-1/edid root@orangepi3:~# cat /sys/class/drm/card0-HDMI-A-1/modes 1024x768 800x600 800x600 848x480 640x480 root@orangepi3:~# uname -a Linux orangepi3 5.1.0-rc4+ #1 SMP Fri Apr 12 09:34:47 UTC 2019 aarch64 GNU/Linux @megi how about those patches https://lkml.org/lkml/2019/4/5/857 ? any changes that one of those 2 branches opi3-5.1 or orange-pi-5.1 have them ? and what difference between them ?
megi Posted April 12, 2019 Posted April 12, 2019 No meaningful difference. I also have pre-built kernel/u-boot with all the firmwares included here: https://xff.cz/kernels
megi Posted April 12, 2019 Posted April 12, 2019 My HDMI looks like this: cat /sys/class/drm/card0-HDMI-A-1/modes 1920x1080 1920x1080 1920x1080 1920x1080i 1920x1080i 1920x1080 1920x1080i 1680x1050 1280x1024 1280x1024 1440x900 1280x960 1152x864 1280x720 1280x720 1280x720 1280x720 1280x720 1440x576 1440x576 1024x768 1024x768 1024x768 1440x480 1440x480 1440x480 1440x480 832x624 800x600 800x600 800x600 800x600 720x576 720x576 720x576 720x480 720x480 720x480 720x480 720x480 640x480 640x480 640x480 640x480 640x480 640x480 720x400 Perhaps some problem with your board/monitor?
megi Posted April 12, 2019 Posted April 12, 2019 You need to use the same config I use. I don't use defconfig, so maybe your kernel is missing something. My config can be found in those pre-built packages, I linked above.
kexec Posted April 12, 2019 Posted April 12, 2019 @megi thank you, you were right, video is working as it should with your kernel. HDMI-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 160mm x 90mm 1920x1080 60.00*+ 50.00 59.94 30.00 25.00 24.00 29.97 23.98 1920x1080i 60.00 50.00 59.94 1680x1050 59.88 1600x900 60.00 1280x1024 75.02 60.02 1440x900 59.90 1366x768 59.79 1280x800 59.91 1152x864 75.00 1280x720 60.00 50.00 59.94 1024x768 75.03 70.07 60.00 832x624 74.55 800x600 72.19 75.00 60.32 720x576 50.00 720x480 60.00 59.94 640x480 75.00 72.81 66.67 60.00 59.94 720x400 70.08 fast and dirty way to test wget https://xff.cz/kernels/pi3-5.1-20190412.tar.gz tar -xf pi3-5.1-20190412.tar.gz cd pi3-5.1/ dd if=uboot.bin of=/dev/mmcblk0 bs=1024 seek=8 #assuming that booting from sdcard cp Image /boot/Image cp board.dtb /boot/dtb/allwinner/sun50i-h6-orangepi-3.dtb cp -r modules/lib/modules /lib reboot that was enough to get video. @megi all modules are compiled in kernel ? P.S wifi device is also present without any firmware file rename hacks 1
megi Posted April 12, 2019 Posted April 12, 2019 Everything necessary is built in. It's just a dd for u-boot and cp for kernel and dtb, and that's it. You don't even need /lib/firmware or /lib/modules. 2
greg798 Posted April 12, 2019 Posted April 12, 2019 4 hours ago, megi said: Everything necessary is built in. It's just a dd for u-boot and cp for kernel and dtb, and that's it. You don't even need /lib/firmware or /lib/modules. thanks your method maybe you know up midgard mali hard support 2D-3D?
Frank Kettenbeil Posted April 13, 2019 Posted April 13, 2019 10 hours ago, kexec said: ... dd if=uboot.bin of=/dev/mmcblk0 bs=1024 seek=8 #assuming that booting from sdcard ... Thanks for your command lines. - Could you please give us the right device instead of /dev/mmcblk0 for boot from emmc?
martinayotte Posted April 13, 2019 Posted April 13, 2019 8 hours ago, Frank Kettenbeil said: the right device instead of /dev/mmcblk0 for boot from emmc? Thee eMMC should be at /dev/mmcblk2 ...
dolphs Posted April 13, 2019 Posted April 13, 2019 I was Just wondering if the " sun8i-ce " kernel module can be used for a hardware true number generator (TRNG) already ? This page reads "(10): The TRNG is not really random due do lack of documentation", although H6 is not listed, perhaps one knows this will be improved in kernel 5.0 already or in upcoming 5.1/5.2 kernels ? entropy is decent enough already ( at least does not drop below 500 ): cat /proc/sys/kernel/random/entropy_avail #2565 ( highest I noticed did not watch it every second just random ) However this could be doubled IMHO with a hardware driver, Yet I played a little with urandom, which improved somewhat adding ""HRNGDEVICE=/dev/urandom" before starting rng-tools : <snip snip> -- Unit rng-tools.service has finished starting up. -- -- The start-up result is done. Apr 14 01:36:24 orangepioneplus[6776]: rngd 2-unofficial-mt.14 starting up... Apr 14 01:36:24 orangepioneplus rngd[6776]: entropy feed to the kernel ready <snip snip> It's result after a little while: cat /proc/sys/kernel/random/entropy_avail #3510 Anyway was just playing with my OrangePiOnePlus little more and don't want to move away from my initial question. " I was Just wondering if the " sun8i-ce " kernel module can be used for a hardware true number generator (TRNG) already ? " cheers
dolphs Posted April 13, 2019 Posted April 13, 2019 (edited) 1 minute ago, dolphs said: . Edited April 13, 2019 by dolphs posted twice apologies
ilchenko Evgeny Posted April 15, 2019 Posted April 15, 2019 Guys help please! I have already tune so many things and do not want to re-install the image. My problem started with the fact that in one moment I was missing xorg.conf.d but that's not all. At the beginning of loading writes that [Failed] to load kernel modules. I understand why it broke the mali driver. I wanted to try to change the kernel but armbin-config utility not found. I tried reinstalling it. And after the installation config I have it displayed as in the screenshot. For some reason it appears as rockpro64. Help how to fix it without reinstalling the image.
ilchenko Evgeny Posted April 15, 2019 Posted April 15, 2019 24 minutes ago, GeorgeP said: If it's important - Backup, backup, backup! yep bro. i know it now((
Igor Posted April 15, 2019 Posted April 15, 2019 And if its important, don't use developers preview unstable testing images. There are big chances of failure!
FrancescoT Posted April 15, 2019 Posted April 15, 2019 3 hours ago, ilchenko Evgeny said: Guys help please! I have already tune so many things and do not want to re-install the image. My problem started with the fact that in one moment I was missing xorg.conf.d but that's not all. At the beginning of loading writes that [Failed] to load kernel modules. I understand why it broke the mali driver. I wanted to try to change the kernel but armbin-config utility not found. I tried reinstalling it. And after the installation config I have it displayed as in the screenshot. For some reason it appears as rockpro64. Help how to fix it without reinstalling the image. If you have spare sd cards you can "diff" a new image against the one you customized, for example mounting both on a host computer. It takes time and patience and you can cherry-pick only what's working This is my approach: put all or most of your configuration into the build process itself (https://docs.armbian.com/Developer-Guide_User-Configurations/) BTW kudos to the guys behind these incredible tools. Thanks!
johanvdw Posted April 15, 2019 Posted April 15, 2019 Too late now, but I save all of my configuration using etckeeper . You will not regret doing the same.
