Still not booting for me. Sorry but I don't have a serial interface here with me so I can't provide any logs at this stage :(.
did you try to boot the orange pi one plus image, does this boot ?
I have tried the OrangePi One Plus image. It boots fine, but has no networking:
U-Boot SPL 2018.09-rc1-armbian (Aug 23 2018 - 13:31:33 +0200)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: v1.5(debug):936c673
NOTICE:  BL31: Built : 11:43:13, Aug 23 2018
NOTICE:  BL31: Detected Allwinner H6 SoC (1728)
NOTICE:  BL31: Detected device tree named sun50i-h6-orangepi-one-plus
INFO:    ARM GICv2 driver initialized
WARNING: PMIC: Unknown board, default to AXP805 according to H6 reference design.
NOTICE:  PMIC: AXP805 detected
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2018.09-rc1-armbian (Aug 23 2018 - 13:31:33 +0200) Allwinner Technology
CPU:   Allwinner H6 (SUN50I)
Model: OrangePi One Plus
DRAM:  2 GiB
MMC:   SUNXI SD/MMC: 0
Loading Environment from FAT... Unable to use mmc 0:1... Failed (-5)
Using device 'sun50i_dw_hdmi', disp_uc_priv=00000000b9f33320
sunxi_de3_init: device 'sunxi_de3' display won't probe (ret=-1)
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3090 bytes read in 31 ms (96.7 KiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
116 bytes read in 26 ms (3.9 KiB/s)
13084 bytes read in 66 ms (193.4 KiB/s)
** File not found /boot/dtb/allwinner/overlay/sun50i-h6-fixup.scr **
8396315 bytes read in 896 ms (8.9 MiB/s)
13776904 bytes read in 1433 ms (9.2 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Data Size:    8396251 Bytes = 8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 497fe000, end 49fffddb ... OK
   reserving fdt memory region: addr=4fa00000 size=69000
   Loading Device Tree to 0000000049792000, end 00000000497fdfff ... OK
Setting up simplefb
DE3 present but not probed
Starting kernel ...
Loading, please wait...
starting version 237
done.
Begin: Will now check root file system ... fsck from util-linux 2.31.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: clean, 35261/61440 files, 215552/245760 blocks
done.
done.
Welcome to Ubuntu 18.04.1 LTS!
[  OK  ] Set up automount Arbitrary Executab…rmats File System Automount Point.
[  OK  ] Started ntp-systemd-netif.path.
[  OK  ] Created slice System Slice.
[  OK  ] Listening on Journal Socket.
         Starting Nameserver information manager...
         Starting Set the console keyboard layout...
         Starting Load Kernel Modules...
[  OK  ] Listening on Journal Audit Socket.
[  OK  ] Listening on Syslog Socket.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Reached target Swap.
         Starting Restore / save the current clock...
[  OK  ] Listening on udev Control Socket.
         Mounting POSIX Message Queue File System...
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Listening on fsck to fsckd communication Socket.
         Mounting Huge Pages File System...
[  OK  ] Listening on Journal Socket (/dev/log).
         Starting Journal Service...
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
         Starting Create list of required st…ce nodes for the current kernel...
         Starting Remount Root and Kernel File Systems...
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Reached target Remote File Systems.
         Starting udev Coldplug all Devices...
[  OK  ] Reached target System Time Synchronized.
         Mounting Kernel Debug File System...
[  OK  ] Started Load Kernel Modules.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Mounted Kernel Debug File System.
         Starting Create Static Device Nodes in /dev...
         Mounting Kernel Configuration File System...
         Starting Apply Kernel Variables...
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Nameserver information manager.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Reached target Network (Pre).
         Starting Load/Save Random Seed...
[  OK  ] Started Journal Service.
[  OK  ] Started udev Coldplug all Devices.
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Restore / save the current clock.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Set the console keyboard layout.
[  OK  ] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /tmp...
[  OK  ] Mounted /tmp.
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
         Starting Raise network interfaces...
         Starting Armbian ZRAM config...
         Starting Set console font and keymap...
[  OK  ] Started Set console font and keymap.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Name Resolution...
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Raise network interfaces.
[  OK  ] Found device /dev/ttyS0.
[   13.616994] dwc3 5200000.dwc3: failed to initialize core
[   13.704844] dwc3 5200000.dwc3: failed to initialize core
[  OK  ] Started Armbian ZRAM config.
         Starting Armbian memory supported logging...
[  OK  ] Started Armbian memory supported logging.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Message of the Day.
[  OK  ] Started resolvconf-pull-resolved.path.
[  OK  ] Reached target Paths.
[  OK  ] Started Discard unused blocks once a week.
         Starting Armbian hardware optimization...
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Reached target Timers.
         Starting Armbian hardware monitoring...
         Starting Armbian filesystem resize...
[  OK  ] Started Armbian hardware optimization.
[  OK  ] Started Armbian hardware monitoring.
[FAILED] Failed to start Armbian filesystem resize.
See 'systemctl status armbian-resize-filesystem.service' for details.
[  OK  ] Reached target Basic System.
         Starting resolvconf-pull-resolved.service...
[  OK  ] Started Armbian first run tasks.
         Starting LSB: Load kernel modules needed to enable cpufreq scaling...
[  OK  ] Started D-Bus System Message Bus.
         Starting Network Manager...
         Starting Login Service...
         Starting System Logging Service...
         Starting Resets System Activity Data Collector...
         Starting Dispatcher daemon for systemd-networkd...
[  OK  ] Started Regular background program processing daemon.
[  OK  ] Started ntp-systemd-netif.service.
         Starting WPA supplicant...
[  OK  ] Started Set the CPU Frequency Scaling governor.
[  OK  ] Started resolvconf-pull-resolved.service.
[  OK  ] Started Resets System Activity Data Collector.
[  OK  ] Started Login Service.
[  OK  ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
         Starting LSB: set CPUFreq kernel parameters...
[  OK  ] Started LSB: set CPUFreq kernel parameters.
         Starting LSB: Set sysfs variables from /etc/sysfs.conf...
[  OK  ] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[  OK  ] Started System Logging Service.
[  OK  ] Started WPA supplicant.
         Starting Hostname Service...
[  OK  ] Started Hostname Service.
[  OK  ] Started Network Manager.
[  OK  ] Reached target Network.
[  OK  ] Started Unattended Upgrades Shutdown.
         Starting OpenBSD Secure Shell server...
         Starting Permit User Sessions...
         Starting Network Manager Wait Online...
[  OK  ] Started Permit User Sessions.
         Starting Set console scheme...
         Starting Network Manager Script Dispatcher Service...
[  OK  ] Started Set console scheme.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Started Network Manager Script Dispatcher Service.
[  OK  ] Started OpenBSD Secure Shell server.
         Starting Authorization Manager...
[  OK  ] Started Dispatcher daemon for systemd-networkd.
[  OK  ] Started Authorization Manager.
         Stopping OpenBSD Secure Shell server...
[  OK  ] Stopped OpenBSD Secure Shell server.
[FAILED] Failed to start Network Manager Wait Online.
See 'systemctl status NetworkManager-wait-online.service' for details.
[  OK  ] Reached target Network is Online.
         Starting LSB: Advanced IEEE 802.11 management daemon...
         Starting Message of the Day...
         Starting /etc/rc.local Compatibility...
[  OK  ] Started LSB: Advanced IEEE 802.11 management daemon.
[FAILED] Failed to start Message of the Day.
See 'systemctl status motd-news.service' for details.
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started Getty on tty1.
[  OK    OK  ] Reached target Login Prompts.
[  OK  ] Reached target Multi-User System.
[  OK  tarting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
Ubuntu 18.04.1 LTS orangepioneplus ttyS0
orangepioneplus login: root
Password:
You are required to change your password immediately (root enforced)
Changing password for root.
(current) UNIX password:
Enter new UNIX password:
Retype new UNIX password:
  ___                               ____  _    ___
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_)  / _ \ _ __   ___   _
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | | | | '_ \ / _ \_| |_
| |_| | | | (_| | | | | (_| |  __/ |  __/| | | |_| | | | |  __/_   _|
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_|  \___/|_| |_|\___| |_|
                       |___/
Welcome to ARMBIAN 5.59.180824 testing Ubuntu 18.04.1 LTS 4.18.0-rc7-sunxi64
System load:   0.25 0.74 0.42   Up time:       6 min
Memory usage:  3 % of 2002MB    IP:
CPU temp:      35°C
Usage of /:    3% of 29G
[ General system configuration (beta): armbian-config ]
New to Armbian? Check the documentation first: https://docs.armbian.com
Thank you for choosing Armbian! Support: www.armbian.com
The networking chip seems to start and show activity on the status LEDs, but fails to complete DCHP discovery:
Aug 23 11:38:16 orangepioneplus dhclient[1065]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 17 (xid=0xab73374d)
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <warn>  [1535024309.9054] dhcp4 (eth0): request timed out
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9056] dhcp4 (eth0): state changed unknown -> timeout
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9220] dhcp4 (eth0): canceled DHCP transaction, DHCP client pid 1065
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9221] dhcp4 (eth0): state changed timeout -> done
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9233] device (eth0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9242] manager: NetworkManager state is now DISCONNECTED
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <warn>  [1535024309.9257] device (eth0): Activation: failed for connection 'Wired connection 1'
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9281] device (eth0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9382] policy: auto-activating connection 'Wired connection 1'
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9440] device (eth0): Activation: starting connection 'Wired connection 1' (3c388474-b660-365f-8a3d-6a77f12ac2c2)
ate: 'managed')
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9460] manager: NetworkManager state is now CONNECTING
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9481] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9504] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9520] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Aug 23 11:38:29 orangepioneplus NetworkManager[958]: <info>  [1535024309.9576] dhcp4 (eth0): dhclient started with pid 1206
Aug 23 11:38:29 orangepioneplus dhclient[1206]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3 (xid=0xf267bc21)
Aug 23 11:38:32 orangepioneplus dhclient[1206]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3 (xid=0xf267bc21)
Aug 23 11:38:35 orangepioneplus dhclient[1206]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 8 (xid=0xf267bc21)
Aug 23 11:38:43 orangepioneplus dhclient[1206]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 21 (xid=0xf267bc21)
Aug 23 11:39:04 orangepioneplus dhclient[1206]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 20 (xid=0xf267bc21)
Aug 23 11:39:14 orangepioneplus NetworkManager[958]: <warn>  [1535024354.9116] dhcp4 (eth0): request timed out
Aug 23 11:39:14 orangepioneplus NetworkManager[958]: <info>  [1535024354.9118] dhcp4 (eth0): state changed unknown -> timeout
Aug 23 11:39:14 orangepioneplus NetworkManager[958]: <info>  [1535024354.9280] dhcp4 (eth0): canceled DHCP transaction, DHCP client pid 1206
Aug 23 11:39:14 orangepioneplus NetworkManager[958]: <info>  [1535024354.9281] dhcp4 (eth0): state changed timeout -> done
Aug 23 11:39:14 orangepioneplus NetworkManager[958]: <info>  [1535024354.9290] device (eth0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Aug 23 11:39:14 orangepioneplus NetworkManager[958]: <info>  [1535024354.9298] manager: NetworkManager state is now DISCONNECTED
Aug 23 11:39:14 orangepioneplus NetworkManager[958]: <warn>  [1535024354.9308] device (eth0): Activation: failed for connection 'Wired connection 1'
Aug 23 11:39:14 orangepioneplus NetworkManager[958]: <info>  [1535024354.9325] device (eth0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
I'll test your new image now.
Edited by gnjack
added spoiler - for better reading
1 hour ago, krachlatte said:
many thanks for testing this fast, i did not expext that, i uploaded a new image, this time without desktop, server only.
direct link
https://github.com/krachlatte/armbian-orangepi3/releases/download/v0.01/Armbian_5.75_Orangepi3_Ubuntu_bionic_dev_4.20.7.img.bz2
it looks like i mist out some stuff for the mmc....
many thanks
Still not booting past the U-Boot SPL into the main image, here is the serial output:
U-Boot SPL 2018.09-rc1-armbian (Feb 11 2019 - 08:44:18 +0100)
DRAM: 2048 MiB
NOTICE:  BL31: v2.0(debug):32bcba0
NOTICE:  BL31: Built : 23:07:19, Feb  8 2019
NOTICE:  BL31: Found U-Boot DTB at 0xc070e20, model: OrangePi 3
NOTICE:  PMIC: Probing AXP805
INFO:    SPSR = 0x3c9
Okay, managed to find a USB-TTL converter :). This is the output (it just hangs at that point):
DRAM: 2048 MiB
INFO:    SPSR = 0x3c9
I get the same results as gnjack - the OrangePi One Plus image boots (and correctly outputs over HDMI), but has no networking.
The new image gets further, but stalls at 'Starting kernel':
U-Boot SPL 2018.09-rc1-armbian (Feb 11 2019 - 11:07:17 +0100)
DRAM: 2048 MiB
INFO:    SPSR = 0x3c9
U-Boot 2018.09-rc1-armbian (Feb 11 2019 - 11:07:17 +0100) Allwinner Technology
Model: OrangePi 3
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
starting USB...
Scanning mmc 0:1...
3042 bytes read in 32 ms (92.8 KiB/s)
116 bytes read in 28 ms (3.9 KiB/s)
18884 bytes read in 80 ms (230.5 KiB/s)
4155 bytes read in 96 ms (42 KiB/s)
Applying kernel provided DT fixup script (sun50i-h6-fixup.scr)
## Executing script at 44000000
8821800 bytes read in 938 ms (9 MiB/s)
14356488 bytes read in 1492 ms (9.2 MiB/s)
   Image Name:   uInitrd
   Data Size:    8821736 Bytes = 8.4 MiB
   Loading Ramdisk to 49796000, end 49fffbe8 ... OK
   reserving fdt memory region: addr=4fa00000 size=6a000
   Loading Device Tree to 0000000049729000, end 0000000049795fff ... OK
Setting up simplefb
Starting kernel ...
Edited by gnjack
Actually, not sure what happened there, it is booting fine now. Maybe I just didn't wait long enough. There is no debug output between 'Starting kernel ...' and the login prompt (unlike the one plus image).
The image has the same networking / DCHP issues as the one plus image.
Here is the output from lsmod:
cpufreq_dt             16384  0
sun50i_h6_ths          16384  0
zstd                   16384  4
thermal_sys            65536  2 cpufreq_dt,sun50i_h6_ths
zram                   24576  5
realtek                20480  1
dmsg:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 4.20.7-sunxi64 (root@krachlatte-1804) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #5.75 SMP Mon Feb 11 11:10:22 CET 2019
[    0.000000] Machine model: Orange Pi 3
[    0.000000] cma: Reserved 128 MiB at 0x00000000b8000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xb7fdd840-0xb7fdefff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] On node 0 totalpages: 524288
[    0.000000]   DMA32 zone: 8192 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 524288 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0xa8/0x3f0 with crng_init=0
[    0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52696 r8192 d29224 u90112
[    0.000000] pcpu-alloc: s52696 r8192 d29224 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=e20a272e-7ec9-477b-a4cd-0330537d9f93 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=e0ad089a-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=memory swapaccount=1
[    0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
[    0.000000] printk: log_buf_len total cpu_extra contributions: 12288 bytes
[    0.000000] printk: log_buf_len min size: 16384 bytes
[    0.000000] printk: log_buf_len: 32768 bytes
[    0.000000] printk: early log buf free: 13792(84%)
[    0.000000] Memory: 1909236K/2097152K available (10174K kernel code, 708K rwdata, 2500K rodata, 576K init, 289K bss, 56844K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000180] Console: colour dummy device 80x25
[    0.000192] printk: console [tty1] enabled
[    0.000254] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000262] pid_max: default: 32768 minimum: 301
[    0.000340] LSM: Security Framework initializing
[    0.000349] AppArmor: AppArmor disabled by boot time parameter
[    0.001112] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.001495] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.001530] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.001546] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.002727] ASID allocator initialised with 32768 entries
[    0.002794] rcu: Hierarchical SRCU implementation.
[    0.003237] smp: Bringing up secondary CPUs ...
[    0.003907] Detected VIPT I-cache on CPU1
[    0.003957] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.004575] Detected VIPT I-cache on CPU2
[    0.004604] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.005164] Detected VIPT I-cache on CPU3
[    0.005190] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.005251] smp: Brought up 1 node, 4 CPUs
[    0.005255] SMP: Total of 4 processors activated.
[    0.005259] CPU features: detected: 32-bit EL0 Support
[    0.005263] CPU features: detected: CRC32 instructions
[    0.007666] CPU: All CPU(s) started at EL2
[    0.007679] alternatives: patching kernel code
[    0.008864] devtmpfs: initialized
[    0.012443] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.012474] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.016178] xor: measuring software checksum speed
[    0.056082]    8regs     :  1750.000 MB/sec
[    0.096119]    8regs_prefetch:  1560.000 MB/sec
[    0.136160]    32regs    :  2151.000 MB/sec
[    0.176202]    32regs_prefetch:  1808.000 MB/sec
[    0.176205] xor: using function: 32regs (2151.000 MB/sec)
[    0.176255] pinctrl core: initialized pinctrl subsystem
[    0.176955] NET: Registered protocol family 16
[    0.177406] audit: initializing netlink subsys (disabled)
[    0.177550] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
[    0.177975] cpuidle: using governor menu
[    0.178230] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.178236] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.179613] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.179685] Serial: AMBA PL011 UART driver
[    0.188090] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.188497] cryptd: max_cpu_qlen set to 1000
[    0.256498] raid6: int64x1  gen()   335 MB/s
[    0.324459] raid6: int64x1  xor()   333 MB/s
[    0.392613] raid6: int64x2  gen()   515 MB/s
[    0.460646] raid6: int64x2  xor()   457 MB/s
[    0.528689] raid6: int64x4  gen()   790 MB/s
[    0.596777] raid6: int64x4  xor()   575 MB/s
[    0.664911] raid6: int64x8  gen()   747 MB/s
[    0.732958] raid6: int64x8  xor()   570 MB/s
[    0.801099] raid6: neonx1   gen()   552 MB/s
[    0.869167] raid6: neonx1   xor()   647 MB/s
[    0.937270] raid6: neonx2   gen()   884 MB/s
[    1.005329] raid6: neonx2   xor()   917 MB/s
[    1.073451] raid6: neonx4   gen()  1148 MB/s
[    1.141504] raid6: neonx4   xor()  1098 MB/s
[    1.209600] raid6: neonx8   gen()  1256 MB/s
[    1.277691] raid6: neonx8   xor()  1167 MB/s
[    1.277694] raid6: using algorithm neonx8 gen() 1256 MB/s
[    1.277696] raid6: .... xor() 1167 MB/s, rmw enabled
[    1.277699] raid6: using neon recovery algorithm
[    1.278667] SCSI subsystem initialized
[    1.278823] usbcore: registered new interface driver usbfs
[    1.278855] usbcore: registered new interface driver hub
[    1.278910] usbcore: registered new device driver usb
[    1.279111] pps_core: LinuxPPS API ver. 1 registered
[    1.279114] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.279125] PTP clock support registered
[    1.280082] clocksource: Switched to clocksource arch_sys_counter
[    1.280197] VFS: Disk quotas dquot_6.6.0
[    1.280247] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.285642] NET: Registered protocol family 2
[    1.286140] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[    1.286193] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.286366] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.286646] TCP: Hash tables configured (established 16384 bind 16384)
[    1.286750] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.286805] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.286983] NET: Registered protocol family 1
[    1.287350] RPC: Registered named UNIX socket transport module.
[    1.287353] RPC: Registered udp transport module.
[    1.287355] RPC: Registered tcp transport module.
[    1.287358] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.287559] Unpacking initramfs...
[    1.732695] Freeing initrd memory: 8612K
[    1.880048] Initialise system trusted keyrings
[    1.880231] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    1.884986] zbud: loaded
[    1.886285] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.886892] NFS: Registering the id_resolver key type
[    1.886910] Key type id_resolver registered
[    1.886913] Key type id_legacy registered
[    1.886922] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.886926] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.887699] 9p: Installing v9fs 9p2000 file system support
[    2.013551] NET: Registered protocol family 38
[    2.016493] Key type asymmetric registered
[    2.016499] Asymmetric key parser 'x509' registered
[    2.016555] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    2.016722] io scheduler noop registered
[    2.016727] io scheduler deadline registered
[    2.016881] io scheduler cfq registered (default)
[    2.016885] io scheduler mq-deadline registered
[    2.016888] io scheduler kyber registered
[    2.016984] io scheduler bfq registered
[    2.017646] sun4i-usb-phy 5100400.phy: Couldn't get regulator usb0_vbus... Deferring probe
[    2.021209] sun50i-h6-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
[    2.026051] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.027957] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.031989] loop: module loaded
[    2.032880] libphy: Fixed MDIO Bus: probed
[    2.033413] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.033417] ehci-platform: EHCI generic platform driver
[    2.033575] ehci-platform 5101000.usb: EHCI Host Controller
[    2.033594] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1
[    2.034762] ehci-platform 5101000.usb: irq 14, io mem 0x05101000
[    2.048086] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[    2.048289] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.048295] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.048300] usb usb1: Product: EHCI Host Controller
[    2.048305] usb usb1: Manufacturer: Linux 4.20.7-sunxi64 ehci_hcd
[    2.048310] usb usb1: SerialNumber: 5101000.usb
[    2.048735] hub 1-0:1.0: USB hub found
[    2.048772] hub 1-0:1.0: 1 port detected
[    2.049272] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.049290] ohci-platform: OHCI generic platform driver
[    2.049407] ohci-platform 5101400.usb: Generic Platform OHCI controller
[    2.049422] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 2
[    2.049685] ohci-platform 5101400.usb: irq 15, io mem 0x05101400
[    2.112316] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.20
[    2.112323] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.112328] usb usb2: Product: Generic Platform OHCI controller
[    2.112333] usb usb2: Manufacturer: Linux 4.20.7-sunxi64 ohci_hcd
[    2.112337] usb usb2: SerialNumber: 5101400.usb
[    2.112690] hub 2-0:1.0: USB hub found
[    2.112725] hub 2-0:1.0: 1 port detected
[    2.113387] usbcore: registered new interface driver usb-storage
[    2.113744] mousedev: PS/2 mouse device common for all mice
[    2.114102] sun6i-rtc 7000000.rtc: rtc core: registered rtc-sun6i as rtc0
[    2.114107] sun6i-rtc 7000000.rtc: RTC enabled
[    2.114150] i2c /dev entries driver
[    2.114705] axp20x-i2c 0-0036: AXP20x variant AXP806 found
[    2.118838] dcdca: supplied by regulator-dummy
[    2.119877] dcdcc: supplied by regulator-dummy
[    2.120444] dcdcd: supplied by regulator-dummy
[    2.120885] vdd-sys: Bringing 900000uV into 960000-960000uV
[    2.121315] dcdce: supplied by regulator-dummy
[    2.121775] vcc-dram: Bringing 1200000uV into 1400000-1400000uV
[    2.122194] aldo1: supplied by regulator-dummy
[    2.122764] aldo2: supplied by regulator-dummy
[    2.123204] vcc-ac200: Bringing 700000uV into 3300000-3300000uV
[    2.123628] aldo3: supplied by regulator-dummy
[    2.124093] vcc-3v3-1: Bringing 700000uV into 3300000-3300000uV
[    2.124819] bldo1: supplied by regulator-dummy
[    2.125793] bldo2: supplied by regulator-dummy
[    2.126350] bldo3: supplied by regulator-dummy
[    2.126808] vcc-wifi-io: Bringing 700000uV into 1800000-1800000uV
[    2.127227] bldo4: supplied by regulator-dummy
[    2.127778] cldo1: supplied by regulator-dummy
[    2.128341] cldo2: supplied by regulator-dummy
[    2.128800] vcc-wifi-1: Bringing 700000uV into 3300000-3300000uV
[    2.129237] cldo3: supplied by regulator-dummy
[    2.129680] vcc-wifi-2: Bringing 700000uV into 3300000-3300000uV
[    2.130101] sw: supplied by regulator-dummy
[    2.130232] axp20x-i2c 0-0036: AXP20X driver loaded
[    2.130820] sdhci: Secure Digital Host Controller Interface driver
[    2.130822] sdhci: Copyright(c) Pierre Ossman
[    2.130841] Synopsys Designware Multimedia Card Interface Driver
[    2.131069] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.131652] ledtrig-cpu: registered to indicate activity on CPUs
[    2.131885] hidraw: raw HID events driver (C) Jiri Kosina
[    2.131971] usbcore: registered new interface driver usbhid
[    2.131974] usbhid: USB HID core driver
[    2.133092] NET: Registered protocol family 10
[    2.150693] Segment Routing with IPv6
[    2.150772] NET: Registered protocol family 17
[    2.150939] 8021q: 802.1Q VLAN Support v1.8
[    2.151092] 9pnet: Installing 9P2000 support
[    2.151143] Key type dns_resolver registered
[    2.151771] registered taskstats version 1
[    2.151773] Loading compiled-in X.509 certificates
[    2.151846] zswap: loaded using pool lzo/zbud
[    2.152852] Btrfs loaded, crc32c=crc32c-generic
[    2.163098] Key type encrypted registered
[    2.170980] sun4i-usb-phy 5100400.phy: Linked as a consumer to regulator.18
[    2.175265] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    2.175791] printk: console [ttyS0] disabled
[    2.196557] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 12, base_baud = 1500000) is a 16550A
[    2.196609] printk: console [ttyS0] enabled
[    2.197387] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    2.197806] ehci-platform 5311000.usb: EHCI Host Controller
[    2.197825] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 3
[    2.198369] ehci-platform 5311000.usb: irq 17, io mem 0x05311000
[    2.212095] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
[    2.212248] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.212254] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.212259] usb usb3: Product: EHCI Host Controller
[    2.212264] usb usb3: Manufacturer: Linux 4.20.7-sunxi64 ehci_hcd
[    2.212269] usb usb3: SerialNumber: 5311000.usb
[    2.212654] hub 3-0:1.0: USB hub found
[    2.212681] hub 3-0:1.0: 1 port detected
[    2.213244] ohci-platform 5311400.usb: Generic Platform OHCI controller
[    2.213260] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 4
[    2.213496] ohci-platform 5311400.usb: irq 18, io mem 0x05311400
[    2.276297] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.20
[    2.276304] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.276309] usb usb4: Product: Generic Platform OHCI controller
[    2.276314] usb usb4: Manufacturer: Linux 4.20.7-sunxi64 ohci_hcd
[    2.276319] usb usb4: SerialNumber: 5311400.usb
[    2.276666] hub 4-0:1.0: USB hub found
[    2.276692] hub 4-0:1.0: 1 port detected
[    2.277296] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    2.277364] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
[    2.277596] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    2.277604] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[    2.277748] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.277755] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.277760] usb usb5: Product: MUSB HDRC host driver
[    2.277765] usb usb5: Manufacturer: Linux 4.20.7-sunxi64 musb-hcd
[    2.277769] usb usb5: SerialNumber: musb-hdrc.1.auto
[    2.278080] hub 5-0:1.0: USB hub found
[    2.278109] hub 5-0:1.0: 1 port detected
[    2.279066] vcc-gmac-3v3: supplied by vcc-ac200
[    2.279378] sunxi-mmc 4020000.mmc: Linked as a consumer to regulator.1
[    2.279787] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    2.279847] dwmac-sun8i 5020000.ethernet: Linked as a consumer to regulator.19
[    2.280139] sunxi-mmc 4020000.mmc: Got CD GPIO
[    2.305534] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    2.357038] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.361245] mmc0: new high speed SDHC card at address e624
[    2.362127] mmcblk0: mmc0:e624 SU32G 29.7 GiB
[    2.365742]  mmcblk0: p1
[    2.388228] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 0)
[    2.388249] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[    2.388254] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[    2.388259] dwmac-sun8i 5020000.ethernet: COE Type 2
[    2.388263] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[    2.388268] dwmac-sun8i 5020000.ethernet: Normal descriptors
[    2.388272] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[    2.388376] libphy: stmmac: probed
[    2.393423] of_cfs_init
[    2.393491] of_cfs_init: OK
[    2.393670] vcc1v8: disabling
[    2.394057] Freeing unused kernel memory: 576K
[    2.416155] Run /init as init process
[    2.851468] random: fast init done
[    5.179339] random: crng init done
[    6.450096] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    8.393348] systemd[1]: System time before build time, advancing clock.
[    8.452694] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    8.453004] systemd[1]: Detected architecture arm64.
[    8.483664] systemd[1]: Set hostname to <orangepi3>.
[    9.497042] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    9.497057] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    9.879920] systemd[1]: Started ntp-systemd-netif.path.
[    9.881313] systemd[1]: Created slice System Slice.
[    9.882051] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    9.882498] systemd[1]: Listening on udev Control Socket.
[    9.883056] systemd[1]: Listening on Journal Audit Socket.
[   10.185826] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   10.380248] systemd-journald[385]: Received request to flush runtime journal from PID 1
[   11.548819] zram: Added device: zram0
[   11.549138] zram: Added device: zram1
[   11.549438] zram: Added device: zram2
[   11.549787] zram: Added device: zram3
[   11.550136] zram: Added device: zram4
[   11.550457] zram: Added device: zram5
[   11.792442] zram1: detected capacity change from 0 to 262336512
[   11.916056] Adding 256184k swap on /dev/zram1.  Priority:5 extents:1 across:256184k SSFS
[   11.919289] zram2: detected capacity change from 0 to 262336512
[   11.947174] Adding 256184k swap on /dev/zram2.  Priority:5 extents:1 across:256184k SSFS
[   11.958041] zram3: detected capacity change from 0 to 262336512
[   11.986667] Adding 256184k swap on /dev/zram3.  Priority:5 extents:1 across:256184k SSFS
[   11.992760] zram4: detected capacity change from 0 to 262336512
[   12.014966] Adding 256184k swap on /dev/zram4.  Priority:5 extents:1 across:256184k SSFS
[   12.328800] thermal thermal_zone0: failed to read out thermal zone (-16)
[   12.328842] thermal thermal_zone1: failed to read out thermal zone (-16)
[   12.359352] zram0: detected capacity change from 0 to 52428800
[   12.437302] cpu cpu0: Linked as a consumer to regulator.3
[   12.437341] cpu cpu0: Dropping the link to regulator.3
[   12.437481] cpu cpu0: Linked as a consumer to regulator.3
[   12.437893] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 912000 KHz
[   12.438381] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1008000 KHz
[   12.438623] thermal thermal_zone0: failed to read out thermal zone (-16)
[   12.770051] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   19.294547] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   19.294705] dwmac-sun8i 5020000.ethernet eth0: device MAC address 5e:64:51:98:bd:d3
[   19.295015] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[   19.296305] dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found
[   19.296318] dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available
[   19.296324] dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW
[   19.296619] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   26.464889] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[   26.464920] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Edited by gnjack
2 hours ago, krachlatte said:
ok then it looks like it is best toi start with a ported DTS file from the orangepioneplus
i uploaded a new image that is a copy of the oneplus device tree..
could you please check, also send a lsmod, lspci -v and demsg is a good start... many thanks waiting for my HW to arrive
This is now booting for me, but without network or HDMI output. There is quite a long delay where it just sits at 'Starting kernel ...', but eventually the login prompt appears :)
This is the serial boot log:
DRAM: 2048 MiB
INFO:    SPSR = 0x3c9
Model: OrangePi 3
DRAM:  2 GiB
fb=be000000, size=3840 2160
In:    serial
Out:   vidconsole
Err:   vidconsole
starting USB...
Scanning mmc 0:1...
3042 bytes read in 16 ms (185.5 KiB/s)
165 bytes read in 19 ms (7.8 KiB/s)
18884 bytes read in 40 ms (460.9 KiB/s)
4155 bytes read in 47 ms (85.9 KiB/s)
8821800 bytes read in 910 ms (9.2 MiB/s)
14356488 bytes read in 1467 ms (9.3 MiB/s)
   Image Name:   uInitrd
Setting up simplefb
Cannot setup simplefb: node not found
Starting kernel ...
Ubuntu 18.04.1 LTS orangepi3 ttyS0
orangepi3 login: root
Password:
Last login: Mon Feb 11 10:16:23 UTC 2019 on ttyS0
  ___                               ____  _   _____
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_) |___ /
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | |   |_ \
| |_| | | | (_| | | | | (_| |  __/ |  __/| |  ___) |
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| |____/
                       |___/
Welcome to ARMBIAN 5.75 user-built Ubuntu 18.04.1 LTS 4.20.7-sunxi64
System load:   0.98 0.27 0.09   Up time:       0 min
Memory usage:  4 % of 2001MB    IP:
CPU temp:      38°C
Usage of /:    7% of 15G
[ 0 security updates available, 1 updates total: apt upgrade ]
Last check: 2019-02-11 12:09
root@orangepi3:~# dmesg
[    0.000183] Console: colour dummy device 80x25
[    0.000195] printk: console [tty1] enabled
[    0.000261] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000269] pid_max: default: 32768 minimum: 301
[    0.000348] LSM: Security Framework initializing
[    0.000357] AppArmor: AppArmor disabled by boot time parameter
[    0.001137] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.001524] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.001558] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.001575] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.002806] ASID allocator initialised with 32768 entries
[    0.002874] rcu: Hierarchical SRCU implementation.
[    0.003322] smp: Bringing up secondary CPUs ...
[    0.003999] Detected VIPT I-cache on CPU1
[    0.004049] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.004678] Detected VIPT I-cache on CPU2
[    0.004706] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.005266] Detected VIPT I-cache on CPU3
[    0.005292] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.005354] smp: Brought up 1 node, 4 CPUs
[    0.005358] SMP: Total of 4 processors activated.
[    0.005363] CPU features: detected: 32-bit EL0 Support
[    0.005366] CPU features: detected: CRC32 instructions
[    0.007935] CPU: All CPU(s) started at EL2
[    0.007949] alternatives: patching kernel code
[    0.009223] devtmpfs: initialized
[    0.012899] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.012930] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.016818] xor: measuring software checksum speed
[    0.056211]    8regs     :  1750.000 MB/sec
[    0.096247]    8regs_prefetch:  1560.000 MB/sec
[    0.136295]    32regs    :  2151.000 MB/sec
[    0.176332]    32regs_prefetch:  1867.000 MB/sec
[    0.176335] xor: using function: 32regs (2151.000 MB/sec)
[    0.176390] pinctrl core: initialized pinctrl subsystem
[    0.177136] NET: Registered protocol family 16
[    0.177603] audit: initializing netlink subsys (disabled)
[    0.177757] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
[    0.178194] cpuidle: using governor menu
[    0.178452] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.178458] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.179957] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.180031] Serial: AMBA PL011 UART driver
[    0.188527] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.188947] cryptd: max_cpu_qlen set to 1000
[    0.256580] raid6: int64x1  gen()   335 MB/s
[    0.324580] raid6: int64x1  xor()   334 MB/s
[    0.392654] raid6: int64x2  gen()   514 MB/s
[    0.460790] raid6: int64x2  xor()   458 MB/s
[    0.528813] raid6: int64x4  gen()   790 MB/s
[    0.596929] raid6: int64x4  xor()   577 MB/s
[    0.665048] raid6: int64x8  gen()   747 MB/s
[    0.733096] raid6: int64x8  xor()   570 MB/s
[    0.801233] raid6: neonx1   gen()   552 MB/s
[    0.869254] raid6: neonx1   xor()   647 MB/s
[    0.937349] raid6: neonx2   gen()   883 MB/s
[    1.005442] raid6: neonx2   xor()   917 MB/s
[    1.073549] raid6: neonx4   gen()  1148 MB/s
[    1.141613] raid6: neonx4   xor()  1098 MB/s
[    1.209736] raid6: neonx8   gen()  1256 MB/s
[    1.277811] raid6: neonx8   xor()  1167 MB/s
[    1.277814] raid6: using algorithm neonx8 gen() 1256 MB/s
[    1.277817] raid6: .... xor() 1167 MB/s, rmw enabled
[    1.277820] raid6: using neon recovery algorithm
[    1.278803] SCSI subsystem initialized
[    1.278965] usbcore: registered new interface driver usbfs
[    1.278997] usbcore: registered new interface driver hub
[    1.279053] usbcore: registered new device driver usb
[    1.279255] pps_core: LinuxPPS API ver. 1 registered
[    1.279259] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.279270] PTP clock support registered
[    1.280256] clocksource: Switched to clocksource arch_sys_counter
[    1.280373] VFS: Disk quotas dquot_6.6.0
[    1.280423] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.285935] NET: Registered protocol family 2
[    1.286452] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[    1.286505] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.286684] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.287006] TCP: Hash tables configured (established 16384 bind 16384)
[    1.287124] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.287180] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.287360] NET: Registered protocol family 1
[    1.287743] RPC: Registered named UNIX socket transport module.
[    1.287746] RPC: Registered udp transport module.
[    1.287748] RPC: Registered tcp transport module.
[    1.287751] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.287958] Unpacking initramfs...
[    1.734341] Freeing initrd memory: 8612K
[    1.885426] Initialise system trusted keyrings
[    1.885577] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    1.890393] zbud: loaded
[    1.891668] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.892341] NFS: Registering the id_resolver key type
[    1.892363] Key type id_resolver registered
[    1.892366] Key type id_legacy registered
[    1.892377] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.892380] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.893183] 9p: Installing v9fs 9p2000 file system support
[    2.021709] NET: Registered protocol family 38
[    2.024796] Key type asymmetric registered
[    2.024804] Asymmetric key parser 'x509' registered
[    2.024871] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    2.025023] io scheduler noop registered
[    2.025027] io scheduler deadline registered
[    2.025185] io scheduler cfq registered (default)
[    2.025189] io scheduler mq-deadline registered
[    2.025193] io scheduler kyber registered
[    2.025290] io scheduler bfq registered
[    2.025978] sun4i-usb-phy 5100400.phy: Couldn't get regulator usb0_vbus... Deferring probe
[    2.029572] sun50i-h6-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
[    2.034483] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.036432] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.040812] loop: module loaded
[    2.041683] libphy: Fixed MDIO Bus: probed
[    2.042247] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.042251] ehci-platform: EHCI generic platform driver
[    2.042414] ehci-platform 5101000.usb: EHCI Host Controller
[    2.042433] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1
[    2.043549] ehci-platform 5101000.usb: irq 14, io mem 0x05101000
[    2.056266] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[    2.056468] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.056475] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.056480] usb usb1: Product: EHCI Host Controller
[    2.056485] usb usb1: Manufacturer: Linux 4.20.7-sunxi64 ehci_hcd
[    2.056490] usb usb1: SerialNumber: 5101000.usb
[    2.056902] hub 1-0:1.0: USB hub found
[    2.056935] hub 1-0:1.0: 1 port detected
[    2.057446] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.057464] ohci-platform: OHCI generic platform driver
[    2.057579] ohci-platform 5101400.usb: Generic Platform OHCI controller
[    2.057595] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 2
[    2.057883] ohci-platform 5101400.usb: irq 15, io mem 0x05101400
[    2.120481] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.20
[    2.120488] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.120493] usb usb2: Product: Generic Platform OHCI controller
[    2.120498] usb usb2: Manufacturer: Linux 4.20.7-sunxi64 ohci_hcd
[    2.120503] usb usb2: SerialNumber: 5101400.usb
[    2.120872] hub 2-0:1.0: USB hub found
[    2.120906] hub 2-0:1.0: 1 port detected
[    2.121577] usbcore: registered new interface driver usb-storage
[    2.121941] mousedev: PS/2 mouse device common for all mice
[    2.122296] sun6i-rtc 7000000.rtc: rtc core: registered rtc-sun6i as rtc0
[    2.122301] sun6i-rtc 7000000.rtc: RTC enabled
[    2.122344] i2c /dev entries driver
[    2.122884] axp20x-i2c 0-0036: AXP20x variant AXP806 found
[    2.126989] dcdca: supplied by regulator-dummy
[    2.128010] dcdcc: supplied by regulator-dummy
[    2.128609] dcdcd: supplied by regulator-dummy
[    2.129057] vdd-sys: Bringing 900000uV into 960000-960000uV
[    2.129491] dcdce: supplied by regulator-dummy
[    2.129935] vcc-dram: Bringing 1200000uV into 1400000-1400000uV
[    2.130375] aldo1: supplied by regulator-dummy
[    2.130952] aldo2: supplied by regulator-dummy
[    2.131395] vcc-ac200: Bringing 700000uV into 3300000-3300000uV
[    2.131821] aldo3: supplied by regulator-dummy
[    2.132265] vcc-3v3-1: Bringing 700000uV into 3300000-3300000uV
[    2.132991] bldo1: supplied by regulator-dummy
[    2.133997] bldo2: supplied by regulator-dummy
[    2.134565] bldo3: supplied by regulator-dummy
[    2.135008] vcc-wifi-io: Bringing 700000uV into 1800000-1800000uV
[    2.135420] bldo4: supplied by regulator-dummy
[    2.136005] cldo1: supplied by regulator-dummy
[    2.136571] cldo2: supplied by regulator-dummy
[    2.137014] vcc-wifi-1: Bringing 700000uV into 3300000-3300000uV
[    2.137453] cldo3: supplied by regulator-dummy
[    2.137895] vcc-wifi-2: Bringing 700000uV into 3300000-3300000uV
[    2.138338] sw: supplied by regulator-dummy
[    2.138472] axp20x-i2c 0-0036: AXP20X driver loaded
[    2.139071] sdhci: Secure Digital Host Controller Interface driver
[    2.139074] sdhci: Copyright(c) Pierre Ossman
[    2.139093] Synopsys Designware Multimedia Card Interface Driver
[    2.139322] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.139893] ledtrig-cpu: registered to indicate activity on CPUs
[    2.140121] hidraw: raw HID events driver (C) Jiri Kosina
[    2.140203] usbcore: registered new interface driver usbhid
[    2.140205] usbhid: USB HID core driver
[    2.141336] NET: Registered protocol family 10
[    2.159332] Segment Routing with IPv6
[    2.159422] NET: Registered protocol family 17
[    2.159587] 8021q: 802.1Q VLAN Support v1.8
[    2.159760] 9pnet: Installing 9P2000 support
[    2.159814] Key type dns_resolver registered
[    2.160468] registered taskstats version 1
[    2.160471] Loading compiled-in X.509 certificates
[    2.160548] zswap: loaded using pool lzo/zbud
[    2.161518] Btrfs loaded, crc32c=crc32c-generic
[    2.170171] Key type encrypted registered
[    2.178343] sun4i-usb-phy 5100400.phy: Linked as a consumer to regulator.18
[    2.182674] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    2.183224] printk: console [ttyS0] disabled
[    2.204035] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 12, base_baud = 1500000) is a 16550A
[    2.204090] printk: console [ttyS0] enabled
[    2.204902] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    2.205335] ehci-platform 5311000.usb: EHCI Host Controller
[    2.205353] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 3
[    2.205962] ehci-platform 5311000.usb: irq 17, io mem 0x05311000
[    2.220271] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
[    2.220429] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.220435] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.220440] usb usb3: Product: EHCI Host Controller
[    2.220445] usb usb3: Manufacturer: Linux 4.20.7-sunxi64 ehci_hcd
[    2.220450] usb usb3: SerialNumber: 5311000.usb
[    2.220867] hub 3-0:1.0: USB hub found
[    2.220894] hub 3-0:1.0: 1 port detected
[    2.221473] ohci-platform 5311400.usb: Generic Platform OHCI controller
[    2.221493] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 4
[    2.221738] ohci-platform 5311400.usb: irq 18, io mem 0x05311400
[    2.284444] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.20
[    2.284450] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.284456] usb usb4: Product: Generic Platform OHCI controller
[    2.284461] usb usb4: Manufacturer: Linux 4.20.7-sunxi64 ohci_hcd
[    2.284465] usb usb4: SerialNumber: 5311400.usb
[    2.284821] hub 4-0:1.0: USB hub found
[    2.284848] hub 4-0:1.0: 1 port detected
[    2.285470] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    2.285517] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
[    2.285749] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    2.285758] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[    2.285911] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.285917] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.285922] usb usb5: Product: MUSB HDRC host driver
[    2.285927] usb usb5: Manufacturer: Linux 4.20.7-sunxi64 musb-hcd
[    2.285932] usb usb5: SerialNumber: musb-hdrc.1.auto
[    2.286268] hub 5-0:1.0: USB hub found
[    2.286296] hub 5-0:1.0: 1 port detected
[    2.287439] vcc-gmac-3v3: supplied by vcc-ac200
[    2.287691] sunxi-mmc 4020000.mmc: Linked as a consumer to regulator.1
[    2.288155] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    2.288217] dwmac-sun8i 5020000.ethernet: Linked as a consumer to regulator.19
[    2.288541] sunxi-mmc 4020000.mmc: Got CD GPIO
[    2.312988] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    2.364164] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.368191] mmc0: new high speed SDHC card at address aaaa
[    2.369172] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[    2.371053]  mmcblk0: p1
[    2.396380] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 0)
[    2.396401] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[    2.396406] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[    2.396411] dwmac-sun8i 5020000.ethernet: COE Type 2
[    2.396415] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[    2.396420] dwmac-sun8i 5020000.ethernet: Normal descriptors
[    2.396425] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[    2.396535] libphy: stmmac: probed
[    2.401712] of_cfs_init
[    2.401806] of_cfs_init: OK
[    2.401994] vcc1v8: disabling
[    2.402372] Freeing unused kernel memory: 576K
[    2.428324] Run /init as init process
[    2.835878] random: fast init done
[    4.550065] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.431973] systemd[1]: System time before build time, advancing clock.
[    6.486388] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    6.486695] systemd[1]: Detected architecture arm64.
[    6.515650] systemd[1]: Set hostname to <orangepi3>.
[    7.472650] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    7.472666] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    7.790786] random: systemd: uninitialized urandom read (16 bytes read)
[    7.790844] systemd[1]: Reached target System Time Synchronized.
[    7.791503] random: systemd: uninitialized urandom read (16 bytes read)
[    7.791538] systemd[1]: Reached target Swap.
[    7.791703] random: systemd: uninitialized urandom read (16 bytes read)
[    7.791872] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    7.792036] systemd[1]: Reached target Remote File Systems.
[    7.792888] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.080372] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    8.249262] systemd-journald[386]: Received request to flush runtime journal from PID 1
[    9.341925] zram: Added device: zram0
[    9.342257] zram: Added device: zram1
[    9.342568] zram: Added device: zram2
[    9.342909] zram: Added device: zram3
[    9.343243] zram: Added device: zram4
[    9.343553] zram: Added device: zram5
[    9.578133] zram1: detected capacity change from 0 to 262336512
[    9.939933] thermal thermal_zone0: failed to read out thermal zone (-16)
[    9.939973] thermal thermal_zone1: failed to read out thermal zone (-16)
[    9.979655] cpu cpu0: Linked as a consumer to regulator.3
[    9.979700] cpu cpu0: Dropping the link to regulator.3
[    9.979838] cpu cpu0: Linked as a consumer to regulator.3
[    9.980323] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 912000 KHz
[    9.980795] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1008000 KHz
[    9.981026] thermal thermal_zone0: failed to read out thermal zone (-16)
[   10.324907] random: crng init done
[   10.324915] random: 7 urandom warning(s) missed due to ratelimiting
[   10.421896] Adding 256184k swap on /dev/zram1.  Priority:5 extents:1 across:256184k SSFS
[   10.427303] zram2: detected capacity change from 0 to 262336512
[   10.440223] Adding 256184k swap on /dev/zram2.  Priority:5 extents:1 across:256184k SSFS
[   10.442049] zram3: detected capacity change from 0 to 262336512
[   10.452922] Adding 256184k swap on /dev/zram3.  Priority:5 extents:1 across:256184k SSFS
[   10.454510] zram4: detected capacity change from 0 to 262336512
[   10.465949] Adding 256184k swap on /dev/zram4.  Priority:5 extents:1 across:256184k SSFS
[   10.566467] zram0: detected capacity change from 0 to 52428800
[   10.729139] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   18.111650] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   18.111833] dwmac-sun8i 5020000.ethernet eth0: device MAC address ea:29:84:4f:50:6e
[   18.112146] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[   18.113825] dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found
[   18.113837] dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available
[   18.113842] dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW
[   18.114122] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
root@orangepi3:~# lsmod
zstd                   16384  4
cpufreq_dt             16384  0
zram                   24576  5
realtek                20480  1
root@orangepi3:~# lspci -v
pcilib: Cannot open /proc/bus/pci
lspci: Cannot find any working access method.
root@orangepi3:~#
Edited by Tido
added spoiler - for better reading, please do that yourself next time. thx
This is because /boot/amrbianEnv.txt has "console=both", change it to "console=serial" make it more verbose.
Hi
i created a new image, please test again if you have time.
https://github.com/krachlatte/armbian-orangepi3/releases/download/v0.03/Armbian_5.75_Orangepi3_Ubuntu_bionic_dev_4.20.7.img.bz2
how can i tun of the git check before compling the linux-mainline kernel, becuase it ovverrides my changes
still not received the HW yet..... to do test myself ;(
could you check these below outputs ?
ifconfig
ethtool -S eth0
ethtool eth0
cat /etc/udev/rules.d/70-persistent-net.rules
if it shows up as eth0 or this stmmac-0:01 ?
uploaded the DTS files on my git
The new image boots, but again no network or HDMI output. This time the local eMMC (/dev/mmcblk1) appears to be detected.
Boot log:
U-Boot SPL 2018.09-rc1-armbian (Feb 11 2019 - 19:33:45 +0100)
DRAM: 2048 MiB
NOTICE:  BL31: v2.0(debug):873e394
NOTICE:  BL31: Built : 12:34:11, Feb 11 2019
INFO:    SPSR = 0x3c9
U-Boot 2018.09-rc1-armbian (Feb 11 2019 - 19:33:45 +0100) Allwinner Technology
Model: OrangePi 3
DRAM:  2 GiB
In:    serial
Out:   vidconsole
Err:   vidconsole
starting USB...
Scanning mmc 0:1...
116 bytes read in 14 ms (7.8 KiB/s)
19016 bytes read in 40 ms (463.9 KiB/s)
4155 bytes read in 52 ms (77.1 KiB/s)
8821876 bytes read in 913 ms (9.2 MiB/s)
14356488 bytes read in 1469 ms (9.3 MiB/s)
   Image Name:   uInitrd
   Data Size:    8821812 Bytes = 8.4 MiB
   Loading Ramdisk to 49796000, end 49fffc34 ... OK
Setting up simplefb
Starting kernel ...
orangepi3 login:
ifconfig:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet6 fe80::690f:a673:70d0:688f  prefixlen 64  scopeid 0x20<link>
        ether 06:fd:b0:67:04:f5  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 30  bytes 5044 (5.0 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 17
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        TX packets 0  bytes 0 (0.0 B)
ethtool -S eth0:
NIC statistics:
     tx_underflow: 0
     tx_carrier: 0
     tx_losscarrier: 0
     vlan_tag: 0
     tx_deferred: 0
     tx_vlan: 0
     tx_jabber: 0
     tx_frame_flushed: 0
     tx_payload_error: 0
     tx_ip_header_error: 0
     rx_desc: 0
     sa_filter_fail: 0
     overflow_error: 0
     ipc_csum_error: 0
     rx_collision: 0
     rx_crc_errors: 0
     dribbling_bit: 0
     rx_length: 0
     rx_mii: 0
     rx_multicast: 0
     rx_gmac_overflow: 0
     rx_watchdog: 0
     da_rx_filter_fail: 0
     sa_rx_filter_fail: 0
     rx_missed_cntr: 0
     rx_overflow_cntr: 0
     rx_vlan: 0
     tx_undeflow_irq: 0
     tx_process_stopped_irq: 1
     tx_jabber_irq: 0
     rx_overflow_irq: 0
     rx_buf_unav_irq: 0
     rx_process_stopped_irq: 0
     rx_watchdog_irq: 0
     tx_early_irq: 1
     fatal_bus_error_irq: 0
     rx_early_irq: 0
     threshold: 1
     tx_pkt_n: 40
     rx_pkt_n: 0
     normal_irq_n: 0
     rx_normal_irq_n: 0
     napi_poll: 39
     tx_normal_irq_n: 1
     tx_clean: 39
     tx_set_ic_bit: 1
     irq_receive_pmt_irq_n: 0
     mmc_tx_irq_n: 0
     mmc_rx_irq_n: 0
     mmc_rx_csum_offload_irq_n: 0
     irq_tx_path_in_lpi_mode_n: 0
     irq_tx_path_exit_lpi_mode_n: 0
     irq_rx_path_in_lpi_mode_n: 0
     irq_rx_path_exit_lpi_mode_n: 0
     phy_eee_wakeup_error_n: 0
     ip_hdr_err: 0
     ip_payload_err: 0
     ip_csum_bypassed: 0
     ipv4_pkt_rcvd: 0
     ipv6_pkt_rcvd: 0
     no_ptp_rx_msg_type_ext: 0
     ptp_rx_msg_type_sync: 0
     ptp_rx_msg_type_follow_up: 0
     ptp_rx_msg_type_delay_req: 0
     ptp_rx_msg_type_delay_resp: 0
     ptp_rx_msg_type_pdelay_req: 0
     ptp_rx_msg_type_pdelay_resp: 0
     ptp_rx_msg_type_pdelay_follow_up: 0
     ptp_rx_msg_type_announce: 0
     ptp_rx_msg_type_management: 0
     ptp_rx_msg_pkt_reserved_type: 0
     ptp_frame_type: 0
     ptp_ver: 0
     timestamp_dropped: 0
     av_pkt_rcvd: 0
     av_tagged_pkt_rcvd: 0
     vlan_tag_priority_val: 0
     l3_filter_match: 0
     l4_filter_match: 0
     l3_l4_filter_no_match: 0
     irq_pcs_ane_n: 0
     irq_pcs_link_n: 0
     irq_rgmii_n: 0
     mtl_tx_status_fifo_full: 0
     mtl_tx_fifo_not_empty: 0
     mmtl_fifo_ctrl: 0
     mtl_tx_fifo_read_ctrl_write: 0
     mtl_tx_fifo_read_ctrl_wait: 0
     mtl_tx_fifo_read_ctrl_read: 0
     mtl_tx_fifo_read_ctrl_idle: 0
     mac_tx_in_pause: 0
     mac_tx_frame_ctrl_xfer: 0
     mac_tx_frame_ctrl_idle: 0
     mac_tx_frame_ctrl_wait: 0
     mac_tx_frame_ctrl_pause: 0
     mac_gmii_tx_proto_engine: 0
     mtl_rx_fifo_fill_level_full: 0
     mtl_rx_fifo_fill_above_thresh: 0
     mtl_rx_fifo_fill_below_thresh: 0
     mtl_rx_fifo_fill_level_empty: 0
     mtl_rx_fifo_read_ctrl_flush: 0
     mtl_rx_fifo_read_ctrl_read_data: 0
     mtl_rx_fifo_read_ctrl_status: 0
     mtl_rx_fifo_read_ctrl_idle: 0
     mtl_rx_fifo_ctrl_active: 0
     mac_rx_frame_ctrl_fifo: 0
     mac_gmii_rx_proto_engine: 0
     tx_tso_frames: 0
     tx_tso_nfrags: 0
ethtool eth0:
Settings for eth0:
        Supported ports: [ TP MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Half 1000baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: No
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                             1000baseT/Full
        Link partner advertised pause frame use: No
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 1000Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 1
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: d
        Wake-on: d
        Current message level: 0x0000003f (63)
                               drv probe link timer ifdown ifup
        Link detected: yes
/etc/udev/rules.d/70-persistent-net.rules does not exist.
lsmod:
zstd                   16384  4
cpufreq_dt             16384  0
zram                   24576  5
realtek                20480  1
lspci -v:
dmesg:
[    0.000000] Linux version 4.20.7-sunxi64 (root@krachlatte-1804) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #5.75 SMP Mon Feb 11 19:38:23 CET 2019
[    0.000000] Kernel command line: root=UUID=ffec1bde-b2be-406e-b8dc-a748f6acd471 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=ebca8bb7-01 usb-storage.quirks=   cgroup_enable=memory swapaccount=1
[    0.000000] printk: early log buf free: 13824(84%)
[    0.000182] Console: colour dummy device 80x25
[    0.000194] printk: console [tty1] enabled
[    0.000262] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000270] pid_max: default: 32768 minimum: 301
[    0.000358] AppArmor: AppArmor disabled by boot time parameter
[    0.001131] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.001521] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.001555] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.001572] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.002796] ASID allocator initialised with 32768 entries
[    0.002864] rcu: Hierarchical SRCU implementation.
[    0.003316] smp: Bringing up secondary CPUs ...
[    0.004000] Detected VIPT I-cache on CPU1
[    0.004672] Detected VIPT I-cache on CPU2
[    0.004701] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.005258] Detected VIPT I-cache on CPU3
[    0.005284] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.005346] smp: Brought up 1 node, 4 CPUs
[    0.005350] SMP: Total of 4 processors activated.
[    0.005355] CPU features: detected: 32-bit EL0 Support
[    0.005358] CPU features: detected: CRC32 instructions
[    0.007883] CPU: All CPU(s) started at EL2
[    0.007897] alternatives: patching kernel code
[    0.009161] devtmpfs: initialized
[    0.012850] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.012879] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.016802] xor: measuring software checksum speed
[    0.056157]    8regs     :  1750.000 MB/sec
[    0.096193]    8regs_prefetch:  1560.000 MB/sec
[    0.136240]    32regs    :  2151.000 MB/sec
[    0.176276]    32regs_prefetch:  1808.000 MB/sec
[    0.176279] xor: using function: 32regs (2151.000 MB/sec)
[    0.176330] pinctrl core: initialized pinctrl subsystem
[    0.177072] NET: Registered protocol family 16
[    0.177547] audit: initializing netlink subsys (disabled)
[    0.177700] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
[    0.178134] cpuidle: using governor menu
[    0.178392] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.178398] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.179883] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.179960] Serial: AMBA PL011 UART driver
[    0.188595] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.188978] cryptd: max_cpu_qlen set to 1000
[    0.256574] raid6: int64x1  gen()   335 MB/s
[    0.324587] raid6: int64x1  xor()   335 MB/s
[    0.392605] raid6: int64x2  gen()   514 MB/s
[    0.460723] raid6: int64x2  xor()   458 MB/s
[    0.528763] raid6: int64x4  gen()   790 MB/s
[    0.596856] raid6: int64x4  xor()   574 MB/s
[    0.665004] raid6: int64x8  gen()   747 MB/s
[    0.733041] raid6: int64x8  xor()   570 MB/s
[    0.801204] raid6: neonx1   gen()   552 MB/s
[    0.869222] raid6: neonx1   xor()   647 MB/s
[    0.937312] raid6: neonx2   gen()   883 MB/s
[    1.005404] raid6: neonx2   xor()   917 MB/s
[    1.073479] raid6: neonx4   gen()  1148 MB/s
[    1.141580] raid6: neonx4   xor()  1099 MB/s
[    1.209676] raid6: neonx8   gen()  1256 MB/s
[    1.277745] raid6: neonx8   xor()  1167 MB/s
[    1.277748] raid6: using algorithm neonx8 gen() 1256 MB/s
[    1.277750] raid6: .... xor() 1167 MB/s, rmw enabled
[    1.277753] raid6: using neon recovery algorithm
[    1.278743] SCSI subsystem initialized
[    1.278893] usbcore: registered new interface driver usbfs
[    1.278928] usbcore: registered new interface driver hub
[    1.278985] usbcore: registered new device driver usb
[    1.279198] pps_core: LinuxPPS API ver. 1 registered
[    1.279202] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.279213] PTP clock support registered
[    1.280186] clocksource: Switched to clocksource arch_sys_counter
[    1.280306] VFS: Disk quotas dquot_6.6.0
[    1.280360] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.285791] NET: Registered protocol family 2
[    1.286308] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[    1.286362] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.286536] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.286854] TCP: Hash tables configured (established 16384 bind 16384)
[    1.286967] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.287022] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.287201] NET: Registered protocol family 1
[    1.287584] RPC: Registered named UNIX socket transport module.
[    1.287587] RPC: Registered udp transport module.
[    1.287590] RPC: Registered tcp transport module.
[    1.287592] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.287807] Unpacking initramfs...
[    1.734327] Freeing initrd memory: 8612K
[    1.885434] Initialise system trusted keyrings
[    1.885604] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    1.890424] zbud: loaded
[    1.891727] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.892404] NFS: Registering the id_resolver key type
[    1.892427] Key type id_resolver registered
[    1.892429] Key type id_legacy registered
[    1.892439] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.892442] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.893237] 9p: Installing v9fs 9p2000 file system support
[    2.021564] NET: Registered protocol family 38
[    2.024583] Key type asymmetric registered
[    2.024589] Asymmetric key parser 'x509' registered
[    2.024646] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    2.024798] io scheduler noop registered
[    2.024802] io scheduler deadline registered
[    2.024961] io scheduler cfq registered (default)
[    2.024966] io scheduler mq-deadline registered
[    2.024969] io scheduler kyber registered
[    2.025068] io scheduler bfq registered
[    2.025758] sun4i-usb-phy 5100400.phy: Couldn't get regulator usb0_vbus... Deferring probe
[    2.029407] sun50i-h6-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
[    2.034385] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.036388] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.040644] loop: module loaded
[    2.041534] libphy: Fixed MDIO Bus: probed
[    2.042099] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.042103] ehci-platform: EHCI generic platform driver
[    2.042263] ehci-platform 5101000.usb: EHCI Host Controller
[    2.042282] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1
[    2.043450] ehci-platform 5101000.usb: irq 15, io mem 0x05101000
[    2.056194] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[    2.056391] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.056397] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.056402] usb usb1: Product: EHCI Host Controller
[    2.056407] usb usb1: Manufacturer: Linux 4.20.7-sunxi64 ehci_hcd
[    2.056412] usb usb1: SerialNumber: 5101000.usb
[    2.056841] hub 1-0:1.0: USB hub found
[    2.056878] hub 1-0:1.0: 1 port detected
[    2.057384] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.057402] ohci-platform: OHCI generic platform driver
[    2.057525] ohci-platform 5101400.usb: Generic Platform OHCI controller
[    2.057540] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 2
[    2.057821] ohci-platform 5101400.usb: irq 16, io mem 0x05101400
[    2.120454] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.20
[    2.120461] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.120466] usb usb2: Product: Generic Platform OHCI controller
[    2.120471] usb usb2: Manufacturer: Linux 4.20.7-sunxi64 ohci_hcd
[    2.120476] usb usb2: SerialNumber: 5101400.usb
[    2.120845] hub 2-0:1.0: USB hub found
[    2.120879] hub 2-0:1.0: 1 port detected
[    2.121563] usbcore: registered new interface driver usb-storage
[    2.121926] mousedev: PS/2 mouse device common for all mice
[    2.122275] sun6i-rtc 7000000.rtc: rtc core: registered rtc-sun6i as rtc0
[    2.122280] sun6i-rtc 7000000.rtc: RTC enabled
[    2.122323] i2c /dev entries driver
[    2.122866] axp20x-i2c 0-0036: AXP20x variant AXP806 found
[    2.127025] dcdca: supplied by regulator-dummy
[    2.128044] dcdcc: supplied by regulator-dummy
[    2.128642] dcdcd: supplied by regulator-dummy
[    2.129089] vdd-sys: Bringing 900000uV into 960000-960000uV
[    2.129522] dcdce: supplied by regulator-dummy
[    2.129967] vcc-dram: Bringing 1200000uV into 1400000-1400000uV
[    2.130394] aldo1: supplied by regulator-dummy
[    2.130971] aldo2: supplied by regulator-dummy
[    2.131434] vcc-ac200: Bringing 700000uV into 3300000-3300000uV
[    2.131856] aldo3: supplied by regulator-dummy
[    2.132299] vcc-3v3-1: Bringing 700000uV into 3300000-3300000uV
[    2.133026] bldo1: supplied by regulator-dummy
[    2.134038] bldo2: supplied by regulator-dummy
[    2.134599] bldo3: supplied by regulator-dummy
[    2.135041] vcc-wifi-io: Bringing 700000uV into 1800000-1800000uV
[    2.135465] bldo4: supplied by regulator-dummy
[    2.136043] cldo1: supplied by regulator-dummy
[    2.136608] cldo2: supplied by regulator-dummy
[    2.137055] vcc-wifi-1: Bringing 700000uV into 3300000-3300000uV
[    2.137488] cldo3: supplied by regulator-dummy
[    2.137933] vcc-wifi-2: Bringing 700000uV into 3300000-3300000uV
[    2.138374] sw: supplied by regulator-dummy
[    2.138508] axp20x-i2c 0-0036: AXP20X driver loaded
[    2.139111] sdhci: Secure Digital Host Controller Interface driver
[    2.139114] sdhci: Copyright(c) Pierre Ossman
[    2.139133] Synopsys Designware Multimedia Card Interface Driver
[    2.139376] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.139958] ledtrig-cpu: registered to indicate activity on CPUs
[    2.140212] hidraw: raw HID events driver (C) Jiri Kosina
[    2.140295] usbcore: registered new interface driver usbhid
[    2.140297] usbhid: USB HID core driver
[    2.141428] NET: Registered protocol family 10
[    2.159509] Segment Routing with IPv6
[    2.159591] NET: Registered protocol family 17
[    2.159763] 8021q: 802.1Q VLAN Support v1.8
[    2.159919] 9pnet: Installing 9P2000 support
[    2.159971] Key type dns_resolver registered
[    2.160625] registered taskstats version 1
[    2.160628] Loading compiled-in X.509 certificates
[    2.160712] zswap: loaded using pool lzo/zbud
[    2.161696] Btrfs loaded, crc32c=crc32c-generic
[    2.170432] Key type encrypted registered
[    2.178556] sun4i-usb-phy 5100400.phy: Linked as a consumer to regulator.18
[    2.182938] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    2.183481] printk: console [ttyS0] disabled
[    2.204374] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 13, base_baud = 1500000) is a 16550A
[    2.204427] printk: console [ttyS0] enabled
[    2.205216] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    2.205630] ehci-platform 5311000.usb: EHCI Host Controller
[    2.205649] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 3
[    2.206298] ehci-platform 5311000.usb: irq 18, io mem 0x05311000
[    2.220193] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
[    2.220347] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.220354] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.220359] usb usb3: Product: EHCI Host Controller
[    2.220364] usb usb3: Manufacturer: Linux 4.20.7-sunxi64 ehci_hcd
[    2.220369] usb usb3: SerialNumber: 5311000.usb
[    2.220772] hub 3-0:1.0: USB hub found
[    2.220803] hub 3-0:1.0: 1 port detected
[    2.221379] ohci-platform 5311400.usb: Generic Platform OHCI controller
[    2.221396] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 4
[    2.221621] ohci-platform 5311400.usb: irq 19, io mem 0x05311400
[    2.284454] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.20
[    2.284461] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.284466] usb usb4: Product: Generic Platform OHCI controller
[    2.284471] usb usb4: Manufacturer: Linux 4.20.7-sunxi64 ohci_hcd
[    2.284476] usb usb4: SerialNumber: 5311400.usb
[    2.284825] hub 4-0:1.0: USB hub found
[    2.284851] hub 4-0:1.0: 1 port detected
[    2.285485] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    2.285532] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
[    2.285762] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    2.285771] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[    2.285918] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.285924] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.285929] usb usb5: Product: MUSB HDRC host driver
[    2.285934] usb usb5: Manufacturer: Linux 4.20.7-sunxi64 musb-hcd
[    2.285939] usb usb5: SerialNumber: musb-hdrc.1.auto
[    2.286289] hub 5-0:1.0: USB hub found
[    2.286315] hub 5-0:1.0: 1 port detected
[    2.287600] vcc-gmac-3v3: supplied by vcc-ac200
[    2.287756] sunxi-mmc 4020000.mmc: Linked as a consumer to regulator.1
[    2.288235] sunxi-mmc 4022000.mmc: Linked as a consumer to regulator.1
[    2.288287] sunxi-mmc 4022000.mmc: Linked as a consumer to regulator.12
[    2.288411] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    2.288474] dwmac-sun8i 5020000.ethernet: Linked as a consumer to regulator.19
[    2.288802] sunxi-mmc 4020000.mmc: Got CD GPIO
[    2.312927] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    2.314359] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    2.363897] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.367583] mmc0: new high speed SDHC card at address aaaa
[    2.368568] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[    2.370448]  mmcblk0: p1
[    2.396344] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 0)
[    2.396364] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[    2.396369] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[    2.396374] dwmac-sun8i 5020000.ethernet: COE Type 2
[    2.396378] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[    2.396383] dwmac-sun8i 5020000.ethernet: Normal descriptors
[    2.396388] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[    2.396497] libphy: stmmac: probed
[    2.401896] of_cfs_init
[    2.401983] of_cfs_init: OK
[    2.402167] vcc1v8: disabling
[    2.402536] Freeing unused kernel memory: 576K
[    2.408499] random: fast init done
[    2.420258] Run /init as init process
[    2.524354] mmc1: new high speed MMC card at address 0001
[    2.525370] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[    2.526109] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[    2.526836] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[    2.529600]  mmcblk1: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 >
[    2.529633] mmcblk1: p1 size 6840320 extends beyond EOD, truncated
[    7.995612] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    9.877928] systemd[1]: System time before build time, advancing clock.
[    9.932664] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    9.932971] systemd[1]: Detected architecture arm64.
[    9.962250] systemd[1]: Set hostname to <orangepi3>.
[   10.922099] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[   10.922113] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[   11.243119] random: systemd: uninitialized urandom read (16 bytes read)
[   11.243180] systemd[1]: Reached target Swap.
[   11.243721] random: systemd: uninitialized urandom read (16 bytes read)
[   11.244450] systemd[1]: Created slice User and Session Slice.
[   11.244648] random: systemd: uninitialized urandom read (16 bytes read)
[   11.244833] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.245099] systemd[1]: Started ntp-systemd-netif.path.
[   11.245430] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   11.504065] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   11.638599] systemd-journald[380]: Received request to flush runtime journal from PID 1
[   12.845632] zram: Added device: zram0
[   12.845949] zram: Added device: zram1
[   12.846258] zram: Added device: zram2
[   12.846570] zram: Added device: zram3
[   12.846880] zram: Added device: zram4
[   12.847184] zram: Added device: zram5
[   12.997581] zram1: detected capacity change from 0 to 262336512
[   13.408634] thermal thermal_zone0: failed to read out thermal zone (-16)
[   13.408674] thermal thermal_zone1: failed to read out thermal zone (-16)
[   13.417047] cpu cpu0: Linked as a consumer to regulator.3
[   13.417093] cpu cpu0: Dropping the link to regulator.3
[   13.417239] cpu cpu0: Linked as a consumer to regulator.3
[   13.417697] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 912000 KHz
[   13.418148] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1008000 KHz
[   13.418363] thermal thermal_zone0: failed to read out thermal zone (-16)
[   13.627729] random: crng init done
[   13.627738] random: 7 urandom warning(s) missed due to ratelimiting
[   13.705986] Adding 256184k swap on /dev/zram1.  Priority:5 extents:1 across:256184k SSFS
[   13.708315] zram2: detected capacity change from 0 to 262336512
[   13.721870] Adding 256184k swap on /dev/zram2.  Priority:5 extents:1 across:256184k SSFS
[   13.723661] zram3: detected capacity change from 0 to 262336512
[   13.734693] Adding 256184k swap on /dev/zram3.  Priority:5 extents:1 across:256184k SSFS
[   13.736376] zram4: detected capacity change from 0 to 262336512
[   13.748155] Adding 256184k swap on /dev/zram4.  Priority:5 extents:1 across:256184k SSFS
[   13.846773] zram0: detected capacity change from 0 to 52428800
[   14.013466] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   16.428525] EXT4-fs (mmcblk0p1): resizing filesystem from 269312 to 3849616 blocks
[   30.038130] EXT4-fs (mmcblk0p1): resized to 1572864 blocks
[   41.167833] EXT4-fs (mmcblk0p1): resized to 2621440 blocks
[   52.146486] EXT4-fs (mmcblk0p1): resized to 3670016 blocks
[   54.317705] EXT4-fs (mmcblk0p1): resized filesystem to 3849616
[   64.284071] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   64.284265] dwmac-sun8i 5020000.ethernet eth0: device MAC address 06:fd:b0:67:04:f5
[   64.284556] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[   64.286481] dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found
[   64.286489] dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available
[   64.286494] dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW
[   64.286720] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   69.408962] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   69.408993] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Edited by Samon
Added spoilers to condense output
Thanks for all of your work on this @krachlatte - I hope your hardware arrives soon!
I'm also trying to get a armbian build environment set up so I can build and test the images locally at some point...
Tested the latest image, still no network, here's the output:
Serial Boot log
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: Detected Allwinner H6 SoC (1728)
NOTICE:  BL31: Found U-Boot DTB at 0xc070e20, model: OrangePi 3
INFO:    ARM GICv2 driver initialized
NOTICE:  PMIC: Probing AXP805
NOTICE:  PMIC: AXP805 detected
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
CPU:   Allwinner H6 (SUN50I)
Model: OrangePi 3
DRAM:  2 GiB
MMC:   SUNXI SD/MMC: 0
Loading Environment from FAT... Unable to use mmc 0:1... Failed (-5)
Using device 'sun50i_dw_hdmi', disp_uc_priv=00000000b9f33320
sunxi_de3_init: device 'sunxi_de3' display won't probe (ret=-1)
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
No controllers found
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3042 bytes read in 32 ms (92.8 KiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
116 bytes read in 29 ms (3.9 KiB/s)
19016 bytes read in 80 ms (231.4 KiB/s)
4155 bytes read in 95 ms (42 KiB/s)
Applying kernel provided DT fixup script (sun50i-h6-fixup.scr)
## Executing script at 44000000
8821876 bytes read in 938 ms (9 MiB/s)
14356488 bytes read in 1490 ms (9.2 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   reserving fdt memory region: addr=4fa00000 size=6a000
   Loading Device Tree to 0000000049729000, end 0000000049795fff ... OK
Setting up simplefb
DE3 present but not probed
Starting kernel ...
Password:
You are required to change your password immediately (root enforced)
Changing password for root.
(current) UNIX password:
Enter new UNIX password:
Retype new UNIX password:
  ___                               ____  _   _____
                       |___/
System load:   0.85 0.80 0.36   Up time:       4 min
CPU temp:      34°C
Usage of /:    3% of 29G
[ General system configuration (beta): armbian-config ]
New to Armbian? Check the documentation first: https://docs.armbian.com
Thank you for choosing Armbian! Support: www.armbian.com
dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Machine model: Orange Pi 3
[    0.000000] cma: Reserved 128 MiB at 0x00000000b8000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xb7fdd840-0xb7fdefff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000] On node 0 totalpages: 524288
[    0.000000]   DMA32 zone: 8192 pages used for memmap
[    0.000000]   DMA32 zone: 0 pages reserved
[    0.000000]   DMA32 zone: 524288 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0xa8/0x3f0 with crng_init=0
[    0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52696 r8192 d29224 u90112
[    0.000000] pcpu-alloc: s52696 r8192 d29224 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Policy zone: DMA32
[    0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
[    0.000000] printk: log_buf_len total cpu_extra contributions: 12288 bytes
[    0.000000] printk: log_buf_len min size: 16384 bytes
[    0.000000] printk: log_buf_len: 32768 bytes
[    0.000000] Memory: 1909236K/2097152K available (10174K kernel code, 708K rwdata, 2500K rodata, 576K init, 289K bss, 56844K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000180] Console: colour dummy device 80x25
[    0.000192] printk: console [tty1] enabled
[    0.000253] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000261] pid_max: default: 32768 minimum: 301
[    0.000338] LSM: Security Framework initializing
[    0.000347] AppArmor: AppArmor disabled by boot time parameter
[    0.001111] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.001492] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.001526] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.001542] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.002721] ASID allocator initialised with 32768 entries
[    0.002787] rcu: Hierarchical SRCU implementation.
[    0.003236] smp: Bringing up secondary CPUs ...
[    0.003906] Detected VIPT I-cache on CPU1
[    0.003958] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.004576] Detected VIPT I-cache on CPU2
[    0.004604] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.005163] Detected VIPT I-cache on CPU3
[    0.005190] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.005250] smp: Brought up 1 node, 4 CPUs
[    0.005254] SMP: Total of 4 processors activated.
[    0.005259] CPU features: detected: 32-bit EL0 Support
[    0.005262] CPU features: detected: CRC32 instructions
[    0.007661] CPU: All CPU(s) started at EL2
[    0.007675] alternatives: patching kernel code
[    0.008867] devtmpfs: initialized
[    0.012493] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.012521] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.016218] xor: measuring software checksum speed
[    0.056086]    8regs     :  1750.000 MB/sec
[    0.096123]    8regs_prefetch:  1560.000 MB/sec
[    0.136165]    32regs    :  2151.000 MB/sec
[    0.176206]    32regs_prefetch:  1808.000 MB/sec
[    0.176210] xor: using function: 32regs (2151.000 MB/sec)
[    0.176259] pinctrl core: initialized pinctrl subsystem
[    0.176959] NET: Registered protocol family 16
[    0.177417] audit: initializing netlink subsys (disabled)
[    0.177559] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
[    0.177984] cpuidle: using governor menu
[    0.178236] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.178242] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.179606] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.179682] Serial: AMBA PL011 UART driver
[    0.188178] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.188584] cryptd: max_cpu_qlen set to 1000
[    0.256385] raid6: int64x1  gen()   334 MB/s
[    0.324435] raid6: int64x1  xor()   335 MB/s
[    0.392627] raid6: int64x2  gen()   515 MB/s
[    0.460638] raid6: int64x2  xor()   458 MB/s
[    0.528766] raid6: int64x4  gen()   791 MB/s
[    0.596824] raid6: int64x4  xor()   571 MB/s
[    0.664924] raid6: int64x8  gen()   747 MB/s
[    0.732974] raid6: int64x8  xor()   570 MB/s
[    0.801119] raid6: neonx1   gen()   552 MB/s
[    0.869162] raid6: neonx1   xor()   647 MB/s
[    0.937234] raid6: neonx2   gen()   883 MB/s
[    1.005345] raid6: neonx2   xor()   917 MB/s
[    1.073442] raid6: neonx4   gen()  1147 MB/s
[    1.141497] raid6: neonx4   xor()  1098 MB/s
[    1.209600] raid6: neonx8   gen()  1256 MB/s
[    1.277687] raid6: neonx8   xor()  1167 MB/s
[    1.277690] raid6: using algorithm neonx8 gen() 1256 MB/s
[    1.277692] raid6: .... xor() 1167 MB/s, rmw enabled
[    1.277695] raid6: using neon recovery algorithm
[    1.278661] SCSI subsystem initialized
[    1.278808] usbcore: registered new interface driver usbfs
[    1.278843] usbcore: registered new interface driver hub
[    1.278897] usbcore: registered new device driver usb
[    1.279108] pps_core: LinuxPPS API ver. 1 registered
[    1.279111] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.279122] PTP clock support registered
[    1.280070] clocksource: Switched to clocksource arch_sys_counter
[    1.280185] VFS: Disk quotas dquot_6.6.0
[    1.280237] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.285699] NET: Registered protocol family 2
[    1.286203] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[    1.286256] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.286437] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.286720] TCP: Hash tables configured (established 16384 bind 16384)
[    1.286822] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.286877] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.287052] NET: Registered protocol family 1
[    1.287413] RPC: Registered named UNIX socket transport module.
[    1.287416] RPC: Registered udp transport module.
[    1.287418] RPC: Registered tcp transport module.
[    1.287421] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.287619] Unpacking initramfs...
[    1.732797] Freeing initrd memory: 8612K
[    1.880444] Initialise system trusted keyrings
[    1.880593] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    1.885380] zbud: loaded
[    1.886656] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.887287] NFS: Registering the id_resolver key type
[    1.887306] Key type id_resolver registered
[    1.887308] Key type id_legacy registered
[    1.887317] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.887320] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.888113] 9p: Installing v9fs 9p2000 file system support
[    2.013708] NET: Registered protocol family 38
[    2.016665] Key type asymmetric registered
[    2.016671] Asymmetric key parser 'x509' registered
[    2.016725] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    2.016872] io scheduler noop registered
[    2.016875] io scheduler deadline registered
[    2.017026] io scheduler cfq registered (default)
[    2.017031] io scheduler mq-deadline registered
[    2.017035] io scheduler kyber registered
[    2.017132] io scheduler bfq registered
[    2.017812] sun4i-usb-phy 5100400.phy: Couldn't get regulator usb0_vbus... Deferring probe
[    2.021398] sun50i-h6-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
[    2.026280] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.028270] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.032324] loop: module loaded
[    2.033205] libphy: Fixed MDIO Bus: probed
[    2.033766] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.033770] ehci-platform: EHCI generic platform driver
[    2.033927] ehci-platform 5101000.usb: EHCI Host Controller
[    2.033960] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1
[    2.035137] ehci-platform 5101000.usb: irq 15, io mem 0x05101000
[    2.048085] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[    2.048289] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.048296] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.048301] usb usb1: Product: EHCI Host Controller
[    2.048306] usb usb1: Manufacturer: Linux 4.20.7-sunxi64 ehci_hcd
[    2.048310] usb usb1: SerialNumber: 5101000.usb
[    2.048719] hub 1-0:1.0: USB hub found
[    2.048750] hub 1-0:1.0: 1 port detected
[    2.049241] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.049280] ohci-platform: OHCI generic platform driver
[    2.049403] ohci-platform 5101400.usb: Generic Platform OHCI controller
[    2.049419] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 2
[    2.049685] ohci-platform 5101400.usb: irq 16, io mem 0x05101400
[    2.112289] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.20
[    2.112296] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.112301] usb usb2: Product: Generic Platform OHCI controller
[    2.112306] usb usb2: Manufacturer: Linux 4.20.7-sunxi64 ohci_hcd
[    2.112311] usb usb2: SerialNumber: 5101400.usb
[    2.112673] hub 2-0:1.0: USB hub found
[    2.112707] hub 2-0:1.0: 1 port detected
[    2.113366] usbcore: registered new interface driver usb-storage
[    2.113728] mousedev: PS/2 mouse device common for all mice
[    2.114067] sun6i-rtc 7000000.rtc: rtc core: registered rtc-sun6i as rtc0
[    2.114072] sun6i-rtc 7000000.rtc: RTC enabled
[    2.114116] i2c /dev entries driver
[    2.114643] axp20x-i2c 0-0036: AXP20x variant AXP806 found
[    2.118795] dcdca: supplied by regulator-dummy
[    2.119833] dcdcc: supplied by regulator-dummy
[    2.120406] dcdcd: supplied by regulator-dummy
[    2.120845] vdd-sys: Bringing 900000uV into 960000-960000uV
[    2.121277] dcdce: supplied by regulator-dummy
[    2.121736] vcc-dram: Bringing 1200000uV into 1400000-1400000uV
[    2.122162] aldo1: supplied by regulator-dummy
[    2.122731] aldo2: supplied by regulator-dummy
[    2.123168] vcc-ac200: Bringing 700000uV into 3300000-3300000uV
[    2.123588] aldo3: supplied by regulator-dummy
[    2.124048] vcc-3v3-1: Bringing 700000uV into 3300000-3300000uV
[    2.124791] bldo1: supplied by regulator-dummy
[    2.125762] bldo2: supplied by regulator-dummy
[    2.126321] bldo3: supplied by regulator-dummy
[    2.126777] vcc-wifi-io: Bringing 700000uV into 1800000-1800000uV
[    2.127195] bldo4: supplied by regulator-dummy
[    2.127750] cldo1: supplied by regulator-dummy
[    2.128316] cldo2: supplied by regulator-dummy
[    2.128775] vcc-wifi-1: Bringing 700000uV into 3300000-3300000uV
[    2.129203] cldo3: supplied by regulator-dummy
[    2.129644] vcc-wifi-2: Bringing 700000uV into 3300000-3300000uV
[    2.130064] sw: supplied by regulator-dummy
[    2.130196] axp20x-i2c 0-0036: AXP20X driver loaded
[    2.130792] sdhci: Secure Digital Host Controller Interface driver
[    2.130795] sdhci: Copyright(c) Pierre Ossman
[    2.130814] Synopsys Designware Multimedia Card Interface Driver
[    2.131047] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.131640] ledtrig-cpu: registered to indicate activity on CPUs
[    2.131873] hidraw: raw HID events driver (C) Jiri Kosina
[    2.131958] usbcore: registered new interface driver usbhid
[    2.131961] usbhid: USB HID core driver
[    2.133090] NET: Registered protocol family 10
[    2.150632] Segment Routing with IPv6
[    2.150711] NET: Registered protocol family 17
[    2.150872] 8021q: 802.1Q VLAN Support v1.8
[    2.151027] 9pnet: Installing 9P2000 support
[    2.151076] Key type dns_resolver registered
[    2.151695] registered taskstats version 1
[    2.151698] Loading compiled-in X.509 certificates
[    2.151773] zswap: loaded using pool lzo/zbud
[    2.152757] Btrfs loaded, crc32c=crc32c-generic
[    2.161338] Key type encrypted registered
[    2.169305] sun4i-usb-phy 5100400.phy: Linked as a consumer to regulator.18
[    2.173559] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    2.174075] printk: console [ttyS0] disabled
[    2.194817] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 13, base_baud = 1500000) is a 16550A
[    2.194866] printk: console [ttyS0] enabled
[    2.195634] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    2.196075] ehci-platform 5311000.usb: EHCI Host Controller
[    2.196095] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 3
[    2.196689] ehci-platform 5311000.usb: irq 18, io mem 0x05311000
[    2.212081] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
[    2.212236] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.212242] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.212248] usb usb3: Product: EHCI Host Controller
[    2.212253] usb usb3: Manufacturer: Linux 4.20.7-sunxi64 ehci_hcd
[    2.212257] usb usb3: SerialNumber: 5311000.usb
[    2.212656] hub 3-0:1.0: USB hub found
[    2.212682] hub 3-0:1.0: 1 port detected
[    2.213236] ohci-platform 5311400.usb: Generic Platform OHCI controller
[    2.213252] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 4
[    2.213519] ohci-platform 5311400.usb: irq 19, io mem 0x05311400
[    2.276254] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.20
[    2.276260] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.276266] usb usb4: Product: Generic Platform OHCI controller
[    2.276271] usb usb4: Manufacturer: Linux 4.20.7-sunxi64 ohci_hcd
[    2.276275] usb usb4: SerialNumber: 5311400.usb
[    2.276630] hub 4-0:1.0: USB hub found
[    2.276656] hub 4-0:1.0: 1 port detected
[    2.277267] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    2.277313] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
[    2.277538] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    2.277546] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[    2.277697] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
[    2.277704] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.277709] usb usb5: Product: MUSB HDRC host driver
[    2.277714] usb usb5: Manufacturer: Linux 4.20.7-sunxi64 musb-hcd
[    2.277718] usb usb5: SerialNumber: musb-hdrc.1.auto
[    2.278024] hub 5-0:1.0: USB hub found
[    2.278052] hub 5-0:1.0: 1 port detected
[    2.279367] vcc-gmac-3v3: supplied by vcc-ac200
[    2.279555] sunxi-mmc 4020000.mmc: Linked as a consumer to regulator.1
[    2.279782] sunxi-mmc 4022000.mmc: Linked as a consumer to regulator.1
[    2.279827] sunxi-mmc 4022000.mmc: Linked as a consumer to regulator.12
[    2.280126] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    2.280190] dwmac-sun8i 5020000.ethernet: Linked as a consumer to regulator.19
[    2.280500] sunxi-mmc 4020000.mmc: Got CD GPIO
[    2.304814] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    2.306054] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    2.356745] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.360592] mmc0: new high speed SDHC card at address e624
[    2.361480] mmcblk0: mmc0:e624 SU32G 29.7 GiB
[    2.365050]  mmcblk0: p1
[    2.388215] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 0)
[    2.388236] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[    2.388240] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[    2.388245] dwmac-sun8i 5020000.ethernet: COE Type 2
[    2.388250] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[    2.388255] dwmac-sun8i 5020000.ethernet: Normal descriptors
[    2.388260] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[    2.388359] libphy: stmmac: probed
[    2.393600] of_cfs_init
[    2.393667] of_cfs_init: OK
[    2.393845] vcc1v8: disabling
[    2.394206] Freeing unused kernel memory: 576K
[    2.412143] Run /init as init process
[    2.424731] random: fast init done
[    2.492211] mmc1: new high speed MMC card at address 0001
[    2.493289] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[    2.494121] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[    2.494939] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[    2.496757]  mmcblk1: p1 p2
[    4.944260] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.887373] systemd[1]: System time before build time, advancing clock.
[    6.946751] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    6.947060] systemd[1]: Detected architecture arm64.
[    6.977440] systemd[1]: Set hostname to <orangepi3>.
[    7.985841] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    7.985856] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    8.365217] random: systemd: uninitialized urandom read (16 bytes read)
[    8.365276] systemd[1]: Reached target System Time Synchronized.
[    8.365952] random: systemd: uninitialized urandom read (16 bytes read)
[    8.366123] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.366291] random: systemd: uninitialized urandom read (16 bytes read)
[    8.366425] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    8.366588] systemd[1]: Reached target Remote File Systems.
[    8.366745] systemd[1]: Reached target Local Encrypted Volumes.
[    8.691623] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    8.810509] systemd-journald[376]: Received request to flush runtime journal from PID 1
[    9.975099] zram: Added device: zram0
[    9.975417] zram: Added device: zram1
[    9.975743] zram: Added device: zram2
[    9.976125] zram: Added device: zram3
[    9.976471] zram: Added device: zram4
[    9.976795] zram: Added device: zram5
[   10.228750] zram1: detected capacity change from 0 to 262336512
[   10.649238] thermal thermal_zone0: failed to read out thermal zone (-16)
[   10.649278] thermal thermal_zone1: failed to read out thermal zone (-16)
[   10.661958] cpu cpu0: Linked as a consumer to regulator.3
[   10.661996] cpu cpu0: Dropping the link to regulator.3
[   10.662127] cpu cpu0: Linked as a consumer to regulator.3
[   10.662546] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 912000 KHz
[   10.663014] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1008000 KHz
[   10.663234] thermal thermal_zone0: failed to read out thermal zone (-16)
[   10.879199] random: crng init done
[   10.879209] random: 7 urandom warning(s) missed due to ratelimiting
[   10.972526] Adding 256184k swap on /dev/zram1.  Priority:5 extents:1 across:256184k SSFS
[   10.974791] zram2: detected capacity change from 0 to 262336512
[   10.988028] Adding 256184k swap on /dev/zram2.  Priority:5 extents:1 across:256184k SSFS
[   10.989872] zram3: detected capacity change from 0 to 262336512
[   11.000885] Adding 256184k swap on /dev/zram3.  Priority:5 extents:1 across:256184k SSFS
[   11.002451] zram4: detected capacity change from 0 to 262336512
[   11.014011] Adding 256184k swap on /dev/zram4.  Priority:5 extents:1 across:256184k SSFS
[   11.119127] zram0: detected capacity change from 0 to 52428800
[   11.292113] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   13.630534] EXT4-fs (mmcblk0p1): resizing filesystem from 269312 to 7712800 blocks
[   34.979035] EXT4-fs (mmcblk0p1): resized to 1048576 blocks
[   48.962691] EXT4-fs (mmcblk0p1): resized to 1572864 blocks
[   61.869271] EXT4-fs (mmcblk0p1): resized to 2097152 blocks
[   72.883456] EXT4-fs (mmcblk0p1): resized to 2621440 blocks
[   85.109389] EXT4-fs (mmcblk0p1): resized to 3145728 blocks
[   96.114426] EXT4-fs (mmcblk0p1): resized to 3670016 blocks
[  107.202950] EXT4-fs (mmcblk0p1): resized to 4194304 blocks
[  119.349646] EXT4-fs (mmcblk0p1): resized to 4718592 blocks
[  130.377654] EXT4-fs (mmcblk0p1): resized to 5242880 blocks
[  141.457778] EXT4-fs (mmcblk0p1): resized to 5767168 blocks
[  152.490327] EXT4-fs (mmcblk0p1): resized to 6291456 blocks
[  163.520142] EXT4-fs (mmcblk0p1): resized to 6815744 blocks
[  174.582026] EXT4-fs (mmcblk0p1): resized to 7340032 blocks
[  182.958542] EXT4-fs (mmcblk0p1): resized filesystem to 7712800
[  194.929676] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  194.929824] dwmac-sun8i 5020000.ethernet eth0: device MAC address 16:9b:f5:c8:67:dc
[  194.930121] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[  194.931187] dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found
[  194.931195] dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available
[  194.931200] dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW
[  194.931426] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  206.178458] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[  206.178487] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
ifconfig / ethtool (not expecting 1000baseT/Full - I need to find a spare gigabit capable Ethernet cable)
root@orangepi3:~# ifconfig
        ether 16:9b:f5:c8:67:dc  txqueuelen 1000  (Ethernet)
        TX packets 61  bytes 10430 (10.4 KB)
        device interrupt 17
root@orangepi3:~# ethtool -S eth0
NIC statistics:
     tx_underflow: 0
     tx_carrier: 0
     tx_losscarrier: 0
     vlan_tag: 0
     tx_deferred: 0
     tx_vlan: 0
     tx_jabber: 0
     tx_frame_flushed: 0
     tx_payload_error: 0
     rx_desc: 0
     sa_filter_fail: 0
     overflow_error: 0
     ipc_csum_error: 0
     rx_collision: 0
     rx_crc_errors: 0
     dribbling_bit: 0
     rx_length: 0
     rx_mii: 0
     rx_multicast: 0
     rx_gmac_overflow: 0
     rx_watchdog: 0
     rx_missed_cntr: 0
     rx_overflow_cntr: 0
     rx_vlan: 0
     tx_undeflow_irq: 0
     tx_process_stopped_irq: 2
     tx_jabber_irq: 0
     rx_overflow_irq: 0
     rx_buf_unav_irq: 0
     rx_watchdog_irq: 0
     tx_early_irq: 2
     rx_early_irq: 0
     threshold: 1
     tx_pkt_n: 61
     rx_pkt_n: 0
     normal_irq_n: 0
     rx_normal_irq_n: 0
     napi_poll: 59
     tx_normal_irq_n: 2
     tx_clean: 59
     tx_set_ic_bit: 2
     mmc_tx_irq_n: 0
     mmc_rx_irq_n: 0
     ip_hdr_err: 0
     ip_payload_err: 0
     ip_csum_bypassed: 0
     ipv4_pkt_rcvd: 0
     ipv6_pkt_rcvd: 0
     ptp_frame_type: 0
     ptp_ver: 0
     av_pkt_rcvd: 0
     l3_filter_match: 0
     l4_filter_match: 0
     irq_pcs_ane_n: 0
     irq_pcs_link_n: 0
     irq_rgmii_n: 0
     mmtl_fifo_ctrl: 0
     mac_tx_in_pause: 0
     tx_tso_frames: 0
     tx_tso_nfrags: 0
root@orangepi3:~# ethtool eth0
Settings for eth0:
        Speed: 100Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 1
        Supports Wake-on: d
        Wake-on: d
        Link detected: yes
root@orangepi3:~# cat /etc/udev/rules.d/70-persistent-net.rules
cat: /etc/udev/rules.d/70-persistent-net.rules: No such file or directory
root@orangepi3:~# ls -al /etc/udev/rules.d/
total 12
drwxr-xr-x 2 root root 4096 Feb 11 18:42 .
drwxr-xr-x 4 root root 4096 Feb  7 18:28 ..
-rw-r--r-- 1 root root   70 Jan 23 17:52 10-wifi-disable-powermanagement.rules
armbian-hardware-monitor.log
### Activated 4 lzo zram swap devices with 250 MB each
### Activated Armbian ramlog partition with zstd compression
Mon Feb 11 18:41:41 UTC 2019 | Orange Pi 3 | 5.75 | arm64 | aarch64 | 4.20.7-sunxi64
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepi3
BOARD_NAME="Orange Pi 3"
BOARDFAMILY=sun50iw6
VERSION=5.75
LINUXFAMILY=sunxi64
BRANCH=dev
ARCH=arm64
IMAGE_TYPE=user-built
BOARD_TYPE=wip
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=Image
### boot environment:
verbosity=1
console=both
overlay_prefix=sun50i-h6
rootdev=UUID=ffec1bde-b2be-406e-b8dc-a748f6acd471
rootfstype=ext4
### lsusb:
### [resize2fs] Leaving 1 percent spare area. Start resizing partition /dev/mmcblk0p1 now:
major minor  #blocks  name
 179        0   31166976 mmcblk0
 179        1    1077248 mmcblk0p1
 179       32    7634944 mmcblk1
 179       33      65536 mmcblk1p1
 179       34    7548928 mmcblk1p2
 254        0      51200 zram0
 254        1     256188 zram1
 254        2     256188 zram2
 254        3     256188 zram3
 254        4     256188 zram4
Executing fdisk, fsck and partprobe:
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
### lscpu:
Architecture:        aarch64
Byte Order:          Little Endian
CPU(s):              4
On-line CPU(s) list: 0-3
Thread(s) per core:  1
Core(s) per socket:  4
Socket(s):           1
NUMA node(s):        1
Vendor ID:           ARM
Model:               4
Model name:          Cortex-A53
Stepping:            r0p4
CPU max MHz:         1800.0000
CPU min MHz:         888.0000
BogoMIPS:            48.00
NUMA node0 CPU(s):   0-3
Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
### cpuinfo:
processor       : 0
Processor       : AArch64 Processor rev 4 (aarch64)
Hardware        : sun50iw1p1
BogoMIPS        : 48.00
Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 1
BogoMIPS        : 48.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 2
BogoMIPS        : 48.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 3
BogoMIPS        : 48.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
### meminfo:
MemTotal:        2049496 kB
MemFree:         1943104 kB
MemAvailable:    1930116 kB
Buffers:            6652 kB
Cached:            33496 kB
SwapCached:            0 kB
Active:            32480 kB
Inactive:          18024 kB
Active(anon):      10540 kB
Inactive(anon):     5384 kB
Active(file):      21940 kB
Inactive(file):    12640 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       1024736 kB
SwapFree:        1024736 kB
Dirty:                32 kB
Writeback:             0 kB
AnonPages:         10300 kB
Mapped:            10304 kB
Shmem:              5468 kB
KReclaimable:       7024 kB
Slab:              24300 kB
SReclaimable:       7024 kB
SUnreclaim:        17276 kB
KernelStack:        1600 kB
PageTables:          576 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     2049484 kB
Committed_AS:      41784 kB
VmallocTotal:   135290290112 kB
VmallocUsed:           0 kB
VmallocChunk:          0 kB
Percpu:              496 kB
AnonHugePages:         0 kB
ShmemHugePages:        0 kB
ShmemPmdMapped:        0 kB
CmaTotal:         131072 kB
CmaFree:          128984 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
Hugetlb:               0 kB
### virtual memory:
Welcome to fdisk (util-linux 2.31.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help): Selected partition 1
Partition 1 has been deleted.
Command (m for help): Partition type
   p   primary (0 primary, 0 extended, 4 free)
   e   extended (container for logical partitions)
Select (default p): Partition number (1-4, default 1): First sector (2048-62333951, default 2048): Last sector, +sectors or +size{K,M,G,T,P} (8192-62333951, default 62333951): vm.admin_reserve_kbytes = 8192
vm.block_dump = 0
vm.compact_unevictable_allowed = 1
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirtytime_expire_seconds = 43200
vm.dirty_writeback_centisecs = 500
vm.drop_caches = 0
vm.extfrag_threshold = 500
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256   32      0
vm.max_map_count = 65530
vm.min_free_kbytes = 22528
Created a new partition 1 of type 'Linux' and of size 29.4 GiB.
Partition #1 contains a ext4 signature.
Command (m for help): vm.min_slab_ratio = 5
vm.min_unmapped_ratio = 1
The partition table has been altered.
Syncing disks.
vm.mmap_min_addr = 32768
vm.mmap_rnd_bits = 18
vm.mmap_rnd_compat_bits = 11
vm.nr_hugepages = 0
vm.nr_hugepages_mempolicy = 0
vm.nr_overcommit_hugepages = 0
vm.numa_stat = 1
vm.numa_zonelist_order = Node
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_kbytes = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.percpu_pagelist_fraction = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 63493
vm.vfs_cache_pressure = 100
vm.watermark_scale_factor = 10
vm.zone_reclaim_mode = 0
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
### partitions:
 179        1   30851200 mmcblk0p1
 254        0      51200 zram0
 254        1     256188 zram1
 254        2     256188 zram2
 254        3     256188 zram3
 254        4     256188 zram4
### df:
udev            933M     0  933M   0% /dev
tmpfs           201M  5.4M  195M   3% /run
/dev/mmcblk0p1 1004M  855M  113M  89% /
tmpfs          1001M     0 1001M   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs          1001M     0 1001M   0% /sys/fs/cgroup
tmpfs          1001M  4.0K 1001M   1% /tmp
/dev/zram0       49M  744K   45M   2% /var/log
### lsblk:
NAME         FSTYPE   SIZE MOUNTPOINT UUID
mmcblk0              29.7G
└─mmcblk0p1  ext4    29.4G /          ffec1bde-b2be-406e-b8dc-a748f6acd471
mmcblk1               7.3G
├─mmcblk1p1  vfat      64M            2FF5-F9F2
└─mmcblk1p2  ext4     7.2G            3ea64fb3-8084-4cc1-82ed-5d037222d611
mmcblk1boot0            4M
mmcblk1boot1            4M
zram0                  50M /var/log
New partition table:
### zramctl:
NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram4 lzo         250.2M    4K    78B   12K       4 [SWAP]
/dev/zram3 lzo         250.2M    4K    78B   12K       4 [SWAP]
/dev/zram2 lzo         250.2M    4K    78B   12K       4 [SWAP]
/dev/zram1 lzo         250.2M    4K    78B   12K       4 [SWAP]
/dev/zram0                50M  824K 123.5K  484K       4 /var/log
### mtab:
 254        0      51200 zram0
 254        1     256188 zram1
 254        2     256188 zram2
 254        3     256188 zram3
 254        4     256188 zram4
Now trying to resize ext4 filesystem on /dev/mmcblk0p1 to the limits:
/dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
/dev/zram0 /var/log ext4 rw,relatime,block_validity,discard,delalloc,nojournal_checksum,barrier,user_xattr,acl 0 0
resize2fs 1.44.1 (24-Mar-2018)
### mmc0:e624 info:
               fwrev: 0x0
              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SU32G MODALIAS=mmc:block
                 cid: 03534453553332478012e5ae9f00bbf3
                 rca: 0xe624
                 csd: 400e00325b590000edc87f800a4040c3
              manfid: 0x000003
                 ocr: 0x00200000
preferred_erase_size: 4194304
                type: SD
               hwrev: 0x8
                date: 11/2011
                 dsr: 0x404
          erase_size: 512
               oemid: 0x5344
              serial: 0x12e5ae9f
                 ssr: 0000000005000000020290000b050000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
                 scr: 0235800100000000
### mmc1:0001 info:
               fwrev: 0x0600000000000000
              uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block
                 cid: 15010038475446345206f97a8ca0c53d
         rel_sectors: 0x1
                 rca: 0x0001
        pre_eol_info: 0x01
                 csd: d02701320f5903fff6dbffef8e40400d
              manfid: 0x000015
                 ocr: 0x00200000
enhanced_area_offset: 18446744073709551594
  raw_rpmb_size_mult: 0x4
                type: MMC
               hwrev: 0x0
                date: 12/2018
                 prv: 0x6
         ffu_capable: 1
                 dsr: 0x404
          erase_size: 524288
           life_time: 0x01 0x01
  enhanced_area_size: 4294967274
               oemid: 0x0100
              serial: 0xf97a8ca0
             cmdq_en: 0
                 rev: 0x8
### Boot system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
18:41:45: 1800MHz  0.82  44%   9%   8%   0%  26%   0% 28.2°C  0/4
18:41:47: 1800MHz  0.82  29%   0%   0%   0%  28%   0% 28.2°C  0/4
18:41:47: 1800MHz  0.82  26%   2%   0%   0%  23%   0% 28.4°C  0/4
18:41:47: 1800MHz  0.82  28%   2%   0%   1%  25%   0% 28.8°C  0/4
18:41:48: 1800MHz  0.82  27%   2%   0%   0%  24%   0% 28.6°C  0/4
Filesystem at /dev/mmcblk0p1 is mounted on /; on-line resizing required
old_desc_blocks = 1, new_desc_blocks = 2
The filesystem on /dev/mmcblk0p1 is now 7712800 (4k) blocks long.
### [resize2fs] Start resizing ext4 partition /dev/mmcblk0p1 now
The filesystem is already 7712800 (4k) blocks long.  Nothing to do!
### quick iozone test: 4      155      346     3344     3344     3241      231
### [firstrun] Recreated SSH keys (entropy: 1651 1611)
journalctl
-- Logs begin at Sun 2018-01-28 15:58:18 UTC, end at Mon 2019-02-11 18:47:55 UTC. --
Jan 28 15:58:18 orangepi3 kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Jan 28 15:58:18 orangepi3 kernel: Linux version 4.20.7-sunxi64 (root@krachlatte-1804) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #5.75 SMP Mon Feb 11 19:38:23 CET 2019
Jan 28 15:58:18 orangepi3 kernel: Machine model: Orange Pi 3
Jan 28 15:58:18 orangepi3 kernel: cma: Reserved 128 MiB at 0x00000000b8000000
Jan 28 15:58:18 orangepi3 kernel: NUMA: No NUMA configuration found
Jan 28 15:58:18 orangepi3 kernel: NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff]
Jan 28 15:58:18 orangepi3 kernel: NUMA: NODE_DATA [mem 0xb7fdd840-0xb7fdefff]
Jan 28 15:58:18 orangepi3 kernel: Zone ranges:
Jan 28 15:58:18 orangepi3 kernel:   DMA32    [mem 0x0000000040000000-0x00000000bfffffff]
Jan 28 15:58:18 orangepi3 kernel:   Normal   empty
Jan 28 15:58:18 orangepi3 kernel: Movable zone start for each node
Jan 28 15:58:18 orangepi3 kernel: Early memory node ranges
Jan 28 15:58:18 orangepi3 kernel:   node   0: [mem 0x0000000040000000-0x00000000bfffffff]
Jan 28 15:58:18 orangepi3 kernel: Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
Jan 28 15:58:18 orangepi3 kernel: On node 0 totalpages: 524288
Jan 28 15:58:18 orangepi3 kernel:   DMA32 zone: 8192 pages used for memmap
Jan 28 15:58:18 orangepi3 kernel:   DMA32 zone: 0 pages reserved
Jan 28 15:58:18 orangepi3 kernel:   DMA32 zone: 524288 pages, LIFO batch:63
Jan 28 15:58:18 orangepi3 kernel: psci: probing for conduit method from DT.
Jan 28 15:58:18 orangepi3 kernel: psci: PSCIv1.1 detected in firmware.
Jan 28 15:58:18 orangepi3 kernel: psci: Using standard PSCI v0.2 function IDs
Jan 28 15:58:18 orangepi3 kernel: psci: MIGRATE_INFO_TYPE not supported.
Jan 28 15:58:18 orangepi3 kernel: psci: SMC Calling Convention v1.1
Jan 28 15:58:18 orangepi3 kernel: random: get_random_bytes called from start_kernel+0xa8/0x3f0 with crng_init=0
Jan 28 15:58:18 orangepi3 kernel: percpu: Embedded 22 pages/cpu @(____ptrval____) s52696 r8192 d29224 u90112
Jan 28 15:58:18 orangepi3 kernel: pcpu-alloc: s52696 r8192 d29224 u90112 alloc=22*4096
Jan 28 15:58:18 orangepi3 kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Jan 28 15:58:18 orangepi3 kernel: Detected VIPT I-cache on CPU0
Jan 28 15:58:18 orangepi3 kernel: CPU features: enabling workaround for ARM erratum 845719
Jan 28 15:58:18 orangepi3 kernel: Speculative Store Bypass Disable mitigation not required
Jan 28 15:58:18 orangepi3 kernel: CPU features: detected: Kernel page table isolation (KPTI)
Jan 28 15:58:18 orangepi3 kernel: Built 1 zonelists, mobility grouping on.  Total pages: 516096
Jan 28 15:58:18 orangepi3 kernel: Policy zone: DMA32
Jan 28 15:58:18 orangepi3 kernel: Kernel command line: root=UUID=ffec1bde-b2be-406e-b8dc-a748f6acd471 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=ebca8bb7-01 usb-storage.quirks=   cgroup_enable=memory swapaccount=1
Jan 28 15:58:18 orangepi3 kernel: printk: log_buf_len individual max cpu contribution: 4096 bytes
Jan 28 15:58:18 orangepi3 kernel: printk: log_buf_len total cpu_extra contributions: 12288 bytes
Jan 28 15:58:18 orangepi3 kernel: printk: log_buf_len min size: 16384 bytes
Jan 28 15:58:18 orangepi3 kernel: printk: log_buf_len: 32768 bytes
Jan 28 15:58:18 orangepi3 kernel: printk: early log buf free: 13824(84%)
Jan 28 15:58:18 orangepi3 kernel: Memory: 1909236K/2097152K available (10174K kernel code, 708K rwdata, 2500K rodata, 576K init, 289K bss, 56844K reserved, 131072K cma-reserved)
Jan 28 15:58:18 orangepi3 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Jan 28 15:58:18 orangepi3 kernel: rcu: Hierarchical RCU implementation.
Jan 28 15:58:18 orangepi3 kernel: rcu:         RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
Jan 28 15:58:18 orangepi3 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Jan 28 15:58:18 orangepi3 kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Jan 28 15:58:18 orangepi3 kernel: GIC: Using split EOI/Deactivate mode
Jan 28 15:58:18 orangepi3 kernel: arch_timer: cp15 timer(s) running at 24.00MHz (phys).
Jan 28 15:58:18 orangepi3 kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
Jan 28 15:58:18 orangepi3 kernel: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Jan 28 15:58:18 orangepi3 kernel: Console: colour dummy device 80x25
Jan 28 15:58:18 orangepi3 kernel: printk: console [tty1] enabled
Jan 28 15:58:18 orangepi3 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
Jan 28 15:58:18 orangepi3 kernel: pid_max: default: 32768 minimum: 301
Jan 28 15:58:18 orangepi3 kernel: LSM: Security Framework initializing
Jan 28 15:58:18 orangepi3 kernel: AppArmor: AppArmor disabled by boot time parameter
Jan 28 15:58:18 orangepi3 kernel: Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Jan 28 15:58:18 orangepi3 kernel: Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Jan 28 15:58:18 orangepi3 kernel: Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
Jan 28 15:58:18 orangepi3 kernel: Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
Jan 28 15:58:18 orangepi3 kernel: ASID allocator initialised with 32768 entries
Jan 28 15:58:18 orangepi3 kernel: rcu: Hierarchical SRCU implementation.
Jan 28 15:58:18 orangepi3 kernel: smp: Bringing up secondary CPUs ...
Jan 28 15:58:18 orangepi3 kernel: Detected VIPT I-cache on CPU1
Jan 28 15:58:18 orangepi3 kernel: CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Jan 28 15:58:18 orangepi3 kernel: Detected VIPT I-cache on CPU2
Jan 28 15:58:18 orangepi3 kernel: CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Jan 28 15:58:18 orangepi3 kernel: Detected VIPT I-cache on CPU3
Jan 28 15:58:18 orangepi3 kernel: CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Jan 28 15:58:18 orangepi3 kernel: smp: Brought up 1 node, 4 CPUs
Jan 28 15:58:18 orangepi3 kernel: SMP: Total of 4 processors activated.
Jan 28 15:58:18 orangepi3 kernel: CPU features: detected: 32-bit EL0 Support
Jan 28 15:58:18 orangepi3 kernel: CPU features: detected: CRC32 instructions
Jan 28 15:58:18 orangepi3 kernel: CPU: All CPU(s) started at EL2
Jan 28 15:58:18 orangepi3 kernel: alternatives: patching kernel code
Jan 28 15:58:18 orangepi3 kernel: devtmpfs: initialized
Jan 28 15:58:18 orangepi3 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jan 28 15:58:18 orangepi3 kernel: futex hash table entries: 1024 (order: 4, 65536 bytes)
Jan 28 15:58:18 orangepi3 kernel: xor: measuring software checksum speed
Jan 28 15:58:18 orangepi3 kernel:    8regs     :  1750.000 MB/sec
Jan 28 15:58:18 orangepi3 kernel:    8regs_prefetch:  1560.000 MB/sec
Jan 28 15:58:18 orangepi3 kernel:    32regs    :  2151.000 MB/sec
Jan 28 15:58:18 orangepi3 kernel:    32regs_prefetch:  1808.000 MB/sec
Jan 28 15:58:18 orangepi3 kernel: xor: using function: 32regs (2151.000 MB/sec)
Jan 28 15:58:18 orangepi3 kernel: pinctrl core: initialized pinctrl subsystem
Jan 28 15:58:18 orangepi3 kernel: NET: Registered protocol family 16
Jan 28 15:58:18 orangepi3 kernel: audit: initializing netlink subsys (disabled)
Jan 28 15:58:18 orangepi3 kernel: audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
Jan 28 15:58:18 orangepi3 kernel: cpuidle: using governor menu
Jan 28 15:58:18 orangepi3 kernel: vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
Jan 28 15:58:18 orangepi3 kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jan 28 15:58:18 orangepi3 kernel: DMA: preallocated 2048 KiB pool for atomic allocations
Jan 28 15:58:18 orangepi3 kernel: Serial: AMBA PL011 UART driver
Jan 28 15:58:18 orangepi3 kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Jan 28 15:58:18 orangepi3 kernel: cryptd: max_cpu_qlen set to 1000
Jan 28 15:58:18 orangepi3 kernel: raid6: int64x1  gen()   334 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: int64x1  xor()   335 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: int64x2  gen()   515 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: int64x2  xor()   458 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: int64x4  gen()   791 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: int64x4  xor()   571 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: int64x8  gen()   747 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: int64x8  xor()   570 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: neonx1   gen()   552 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: neonx1   xor()   647 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: neonx2   gen()   883 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: neonx2   xor()   917 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: neonx4   gen()  1147 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: neonx4   xor()  1098 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: neonx8   gen()  1256 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: neonx8   xor()  1167 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: using algorithm neonx8 gen() 1256 MB/s
Jan 28 15:58:18 orangepi3 kernel: raid6: .... xor() 1167 MB/s, rmw enabled
Jan 28 15:58:18 orangepi3 kernel: raid6: using neon recovery algorithm
Jan 28 15:58:18 orangepi3 kernel: SCSI subsystem initialized
Jan 28 15:58:18 orangepi3 kernel: usbcore: registered new interface driver usbfs
Jan 28 15:58:18 orangepi3 kernel: usbcore: registered new interface driver hub
Jan 28 15:58:18 orangepi3 kernel: usbcore: registered new device driver usb
Jan 28 15:58:18 orangepi3 kernel: pps_core: LinuxPPS API ver. 1 registered
Jan 28 15:58:18 orangepi3 kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jan 28 15:58:18 orangepi3 kernel: PTP clock support registered
Jan 28 15:58:18 orangepi3 kernel: clocksource: Switched to clocksource arch_sys_counter
Jan 28 15:58:18 orangepi3 kernel: VFS: Disk quotas dquot_6.6.0
Jan 28 15:58:18 orangepi3 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jan 28 15:58:18 orangepi3 kernel: NET: Registered protocol family 2
Jan 28 15:58:18 orangepi3 kernel: tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
Jan 28 15:58:18 orangepi3 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Jan 28 15:58:18 orangepi3 kernel: TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
Jan 28 15:58:18 orangepi3 kernel: TCP: Hash tables configured (established 16384 bind 16384)
Jan 28 15:58:18 orangepi3 kernel: UDP hash table entries: 1024 (order: 3, 32768 bytes)
Jan 28 15:58:18 orangepi3 kernel: UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
Jan 28 15:58:18 orangepi3 kernel: RPC: Registered named UNIX socket transport module.
Jan 28 15:58:18 orangepi3 kernel: RPC: Registered udp transport module.
Jan 28 15:58:18 orangepi3 kernel: RPC: Registered tcp transport module.
Jan 28 15:58:18 orangepi3 kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan 28 15:58:18 orangepi3 kernel: Unpacking initramfs...
Jan 28 15:58:18 orangepi3 kernel: Freeing initrd memory: 8612K
Jan 28 15:58:18 orangepi3 kernel: Initialise system trusted keyrings
Jan 28 15:58:18 orangepi3 kernel: workingset: timestamp_bits=44 max_order=19 bucket_order=0
Jan 28 15:58:18 orangepi3 kernel: zbud: loaded
Jan 28 15:58:18 orangepi3 kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 28 15:58:18 orangepi3 kernel: NFS: Registering the id_resolver key type
Jan 28 15:58:18 orangepi3 kernel: Key type id_resolver registered
Jan 28 15:58:18 orangepi3 kernel: Key type id_legacy registered
Jan 28 15:58:18 orangepi3 kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
d.swb.de).
Jan 28 15:58:18 orangepi3 kernel: 9p: Installing v9fs 9p2000 file system support
Jan 28 15:58:18 orangepi3 kernel: NET: Registered protocol family 38
Jan 28 15:58:18 orangepi3 kernel: Key type asymmetric registered
Jan 28 15:58:18 orangepi3 kernel: Asymmetric key parser 'x509' registered
Jan 28 15:58:18 orangepi3 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
Jan 28 15:58:18 orangepi3 kernel: io scheduler noop registered
Jan 28 15:58:18 orangepi3 kernel: io scheduler deadline registered
Jan 28 15:58:18 orangepi3 kernel: io scheduler cfq registered (default)
Jan 28 15:58:18 orangepi3 kernel: io scheduler mq-deadline registered
Jan 28 15:58:18 orangepi3 kernel: io scheduler kyber registered
Jan 28 15:58:18 orangepi3 kernel: io scheduler bfq registered
Jan 28 15:58:18 orangepi3 kernel: sun4i-usb-phy 5100400.phy: Couldn't get regulator usb0_vbus... Deferring probe
Jan 28 15:58:18 orangepi3 kernel: sun50i-h6-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
Jan 28 15:58:18 orangepi3 kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Jan 28 15:58:18 orangepi3 kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0
Jan 28 15:58:18 orangepi3 kernel: loop: module loaded
Jan 28 15:58:18 orangepi3 kernel: libphy: Fixed MDIO Bus: probed
Jan 28 15:58:18 orangepi3 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 28 15:58:18 orangepi3 kernel: ehci-platform: EHCI generic platform driver
Jan 28 15:58:18 orangepi3 kernel: ehci-platform 5101000.usb: EHCI Host Controller
Jan 28 15:58:18 orangepi3 kernel: ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1
Jan 28 15:58:18 orangepi3 kernel: ehci-platform 5101000.usb: irq 15, io mem 0x05101000
Jan 28 15:58:18 orangepi3 kernel: ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
Jan 28 15:58:18 orangepi3 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
Jan 28 15:58:18 orangepi3 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 28 15:58:18 orangepi3 kernel: usb usb1: Product: EHCI Host Controller
Jan 28 15:58:18 orangepi3 kernel: usb usb1: Manufacturer: Linux 4.20.7-sunxi64 ehci_hcd
Jan 28 15:58:18 orangepi3 kernel: usb usb1: SerialNumber: 5101000.usb
Jan 28 15:58:18 orangepi3 kernel: hub 1-0:1.0: USB hub found
Jan 28 15:58:18 orangepi3 kernel: hub 1-0:1.0: 1 port detected
Jan 28 15:58:18 orangepi3 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan 28 15:58:18 orangepi3 kernel: ohci-platform: OHCI generic platform driver
Jan 28 15:58:18 orangepi3 kernel: ohci-platform 5101400.usb: Generic Platform OHCI controller
Jan 28 15:58:18 orangepi3 kernel: ohci-platform 5101400.usb: new USB bus registered, assigned bus number 2
Jan 28 15:58:18 orangepi3 kernel: ohci-platform 5101400.usb: irq 16, io mem 0x05101400
Jan 28 15:58:18 orangepi3 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.20
Jan 28 15:58:18 orangepi3 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 28 15:58:18 orangepi3 kernel: usb usb2: Product: Generic Platform OHCI controller
Jan 28 15:58:18 orangepi3 kernel: usb usb2: Manufacturer: Linux 4.20.7-sunxi64 ohci_hcd
Jan 28 15:58:18 orangepi3 kernel: usb usb2: SerialNumber: 5101400.usb
Jan 28 15:58:18 orangepi3 kernel: hub 2-0:1.0: USB hub found
Jan 28 15:58:18 orangepi3 kernel: hub 2-0:1.0: 1 port detected
Jan 28 15:58:18 orangepi3 kernel: usbcore: registered new interface driver usb-storage
Jan 28 15:58:18 orangepi3 kernel: mousedev: PS/2 mouse device common for all mice
c-sun6i as rtc0
Jan 28 15:58:18 orangepi3 kernel: sun6i-rtc 7000000.rtc: RTC enabled
Jan 28 15:58:18 orangepi3 kernel: i2c /dev entries driver
Jan 28 15:58:18 orangepi3 kernel: axp20x-i2c 0-0036: AXP20x variant AXP806 found
Jan 28 15:58:18 orangepi3 kernel: dcdca: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: dcdcc: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: dcdcd: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: vdd-sys: Bringing 900000uV into 960000-960000uV
Jan 28 15:58:18 orangepi3 kernel: dcdce: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: vcc-dram: Bringing 1200000uV into 1400000-1400000uV
Jan 28 15:58:18 orangepi3 kernel: aldo1: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: aldo2: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: vcc-ac200: Bringing 700000uV into 3300000-3300000uV
Jan 28 15:58:18 orangepi3 kernel: aldo3: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: vcc-3v3-1: Bringing 700000uV into 3300000-3300000uV
Jan 28 15:58:18 orangepi3 kernel: bldo1: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: bldo2: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: bldo3: supplied by regulator-dummy
00000uV
Jan 28 15:58:18 orangepi3 kernel: bldo4: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: cldo1: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: cldo2: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: vcc-wifi-1: Bringing 700000uV into 3300000-3300000uV
Jan 28 15:58:18 orangepi3 kernel: cldo3: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: vcc-wifi-2: Bringing 700000uV into 3300000-3300000uV
Jan 28 15:58:18 orangepi3 kernel: sw: supplied by regulator-dummy
Jan 28 15:58:18 orangepi3 kernel: axp20x-i2c 0-0036: AXP20X driver loaded
Jan 28 15:58:18 orangepi3 kernel: sdhci: Secure Digital Host Controller Interface driver
Jan 28 15:58:18 orangepi3 kernel: sdhci: Copyright(c) Pierre Ossman
Jan 28 15:58:18 orangepi3 kernel: Synopsys Designware Multimedia Card Interface Driver
Jan 28 15:58:18 orangepi3 kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jan 28 15:58:18 orangepi3 kernel: ledtrig-cpu: registered to indicate activity on CPUs
Jan 28 15:58:18 orangepi3 kernel: hidraw: raw HID events driver (C) Jiri Kosina
Jan 28 15:58:18 orangepi3 kernel: usbcore: registered new interface driver usbhid
Jan 28 15:58:18 orangepi3 kernel: usbhid: USB HID core driver
Jan 28 15:58:18 orangepi3 kernel: NET: Registered protocol family 10
Jan 28 15:58:18 orangepi3 kernel: Segment Routing with IPv6
Jan 28 15:58:18 orangepi3 kernel: NET: Registered protocol family 17
Jan 28 15:58:18 orangepi3 kernel: 8021q: 802.1Q VLAN Support v1.8
Jan 28 15:58:18 orangepi3 kernel: 9pnet: Installing 9P2000 support
Jan 28 15:58:18 orangepi3 kernel: Key type dns_resolver registered
Jan 28 15:58:18 orangepi3 kernel: registered taskstats version 1
Jan 28 15:58:18 orangepi3 kernel: Loading compiled-in X.509 certificates
Jan 28 15:58:18 orangepi3 kernel: zswap: loaded using pool lzo/zbud
Jan 28 15:58:18 orangepi3 kernel: Btrfs loaded, crc32c=crc32c-generic
Jan 28 15:58:18 orangepi3 kernel: Key type encrypted registered
Jan 28 15:58:18 orangepi3 kernel: sun4i-usb-phy 5100400.phy: Linked as a consumer to regulator.18
Jan 28 15:58:18 orangepi3 kernel: sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
Jan 28 15:58:18 orangepi3 kernel: printk: console [ttyS0] disabled
Jan 28 15:58:18 orangepi3 kernel: 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 13, base_baud = 1500000) is a 16550A
Jan 28 15:58:18 orangepi3 kernel: printk: console [ttyS0] enabled
Jan 28 15:58:18 orangepi3 kernel: dwmac-sun8i 5020000.ethernet: PTP uses main clock
r
Jan 28 15:58:18 orangepi3 kernel: ehci-platform 5311000.usb: new USB bus registered, assigned bus number 3
Jan 28 15:58:18 orangepi3 kernel: ehci-platform 5311000.usb: irq 18, io mem 0x05311000
Jan 28 15:58:18 orangepi3 kernel: ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
Jan 28 15:58:18 orangepi3 kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
Jan 28 15:58:18 orangepi3 kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 28 15:58:18 orangepi3 kernel: usb usb3: Product: EHCI Host Controller
Jan 28 15:58:18 orangepi3 kernel: usb usb3: Manufacturer: Linux 4.20.7-sunxi64 ehci_hcd
Jan 28 15:58:18 orangepi3 kernel: usb usb3: SerialNumber: 5311000.usb
Jan 28 15:58:18 orangepi3 kernel: hub 3-0:1.0: USB hub found
Jan 28 15:58:18 orangepi3 kernel: hub 3-0:1.0: 1 port detected
Jan 28 15:58:18 orangepi3 kernel: ohci-platform 5311400.usb: Generic Platform OHCI controller
Jan 28 15:58:18 orangepi3 kernel: ohci-platform 5311400.usb: new USB bus registered, assigned bus number 4
Jan 28 15:58:18 orangepi3 kernel: ohci-platform 5311400.usb: irq 19, io mem 0x05311400
Jan 28 15:58:18 orangepi3 kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.20
Jan 28 15:58:18 orangepi3 kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 28 15:58:18 orangepi3 kernel: usb usb4: Product: Generic Platform OHCI controller
Jan 28 15:58:18 orangepi3 kernel: usb usb4: Manufacturer: Linux 4.20.7-sunxi64 ohci_hcd
Jan 28 15:58:18 orangepi3 kernel: usb usb4: SerialNumber: 5311400.usb
Jan 28 15:58:18 orangepi3 kernel: hub 4-0:1.0: USB hub found
Jan 28 15:58:18 orangepi3 kernel: hub 4-0:1.0: 1 port detected
Jan 28 15:58:18 orangepi3 kernel: usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
Jan 28 15:58:18 orangepi3 kernel: usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
Jan 28 15:58:18 orangepi3 kernel: musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
Jan 28 15:58:18 orangepi3 kernel: musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
Jan 28 15:58:18 orangepi3 kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
Jan 28 15:58:18 orangepi3 kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 28 15:58:18 orangepi3 kernel: usb usb5: Product: MUSB HDRC host driver
Jan 28 15:58:18 orangepi3 kernel: usb usb5: Manufacturer: Linux 4.20.7-sunxi64 musb-hcd
Jan 28 15:58:18 orangepi3 kernel: usb usb5: SerialNumber: musb-hdrc.1.auto
Jan 28 15:58:18 orangepi3 kernel: hub 5-0:1.0: USB hub found
Jan 28 15:58:18 orangepi3 kernel: hub 5-0:1.0: 1 port detected
Jan 28 15:58:18 orangepi3 kernel: vcc-gmac-3v3: supplied by vcc-ac200
Jan 28 15:58:18 orangepi3 kernel: sunxi-mmc 4020000.mmc: Linked as a consumer to regulator.1
Jan 28 15:58:18 orangepi3 kernel: sunxi-mmc 4022000.mmc: Linked as a consumer to regulator.1
Jan 28 15:58:18 orangepi3 kernel: sunxi-mmc 4022000.mmc: Linked as a consumer to regulator.12
Jan 28 15:58:18 orangepi3 kernel: dwmac-sun8i 5020000.ethernet: Linked as a consumer to regulator.19
Jan 28 15:58:18 orangepi3 kernel: sunxi-mmc 4020000.mmc: Got CD GPIO
Jan 28 15:58:18 orangepi3 kernel: sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
Jan 28 15:58:18 orangepi3 kernel: sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
Jan 28 15:58:18 orangepi3 kernel: mmc0: new high speed SDHC card at address e624
Jan 28 15:58:18 orangepi3 kernel: mmcblk0: mmc0:e624 SU32G 29.7 GiB
Jan 28 15:58:18 orangepi3 kernel:  mmcblk0: p1
Jan 28 15:58:18 orangepi3 kernel: dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 0)
Jan 28 15:58:18 orangepi3 kernel: dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
Jan 28 15:58:18 orangepi3 kernel: dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
Jan 28 15:58:18 orangepi3 kernel: dwmac-sun8i 5020000.ethernet: COE Type 2
Jan 28 15:58:18 orangepi3 kernel: dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
Jan 28 15:58:18 orangepi3 kernel: dwmac-sun8i 5020000.ethernet: Normal descriptors
Jan 28 15:58:18 orangepi3 kernel: dwmac-sun8i 5020000.ethernet: Chain mode enabled
Jan 28 15:58:18 orangepi3 kernel: libphy: stmmac: probed
Jan 28 15:58:18 orangepi3 kernel: of_cfs_init
Jan 28 15:58:18 orangepi3 kernel: of_cfs_init: OK
Jan 28 15:58:18 orangepi3 kernel: vcc1v8: disabling
Jan 28 15:58:18 orangepi3 kernel: Freeing unused kernel memory: 576K
Jan 28 15:58:18 orangepi3 kernel: Run /init as init process
Jan 28 15:58:18 orangepi3 kernel: random: fast init done
Jan 28 15:58:18 orangepi3 kernel: mmc1: new high speed MMC card at address 0001
Jan 28 15:58:18 orangepi3 kernel: mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
Jan 28 15:58:18 orangepi3 kernel: mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
Jan 28 15:58:18 orangepi3 kernel: mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
Jan 28 15:58:18 orangepi3 kernel:  mmcblk1: p1 p2
Jan 28 15:58:18 orangepi3 kernel: EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
Jan 28 15:58:18 orangepi3 systemd[1]: System time before build time, advancing clock.
Jan 28 15:58:18 orangepi3 systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
Jan 28 15:58:18 orangepi3 systemd[1]: Detected architecture arm64.
Jan 28 15:58:18 orangepi3 systemd[1]: Set hostname to <orangepi3>.
Jan 28 15:58:18 orangepi3 systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
Jan 28 15:58:18 orangepi3 systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
Jan 28 15:58:18 orangepi3 kernel: random: systemd: uninitialized urandom read (16 bytes read)
Jan 28 15:58:18 orangepi3 systemd[1]: Reached target System Time Synchronized.
Jan 28 15:58:18 orangepi3 systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Jan 28 15:58:18 orangepi3 systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jan 28 15:58:18 orangepi3 systemd[1]: Reached target Remote File Systems.
Jan 28 15:58:18 orangepi3 systemd[1]: Reached target Local Encrypted Volumes.
Jan 28 15:58:18 orangepi3 systemd-journald[376]: Journal started
Jan 28 15:58:18 orangepi3 systemd-journald[376]: Runtime journal (/run/log/journal/b4b8bfe0dc694ac08409b14c71c1f1c3) is 2.5M, max 20.0M, 17.5M free.
Jan 28 15:58:18 orangepi3 kernel: EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
Jan 28 15:58:18 orangepi3 systemd[1]: Started Remount Root and Kernel File Systems.
Jan 28 15:58:18 orangepi3 systemd[1]: Starting Load/Save Random Seed...
Jan 28 15:58:18 orangepi3 systemd[1]: Starting Flush Journal to Persistent Storage...
Jan 28 15:58:18 orangepi3 systemd[1]: Started Nameserver information manager.
Jan 28 15:58:18 orangepi3 systemd[1]: Reached target Network (Pre).
Jan 28 15:58:18 orangepi3 keyboard-setup.sh[380]: kbd_mode: invalid option -- 'x'
Jan 28 15:58:18 orangepi3 keyboard-setup.sh[380]: usage: kbd_mode [-a|-u|-k|-s] [-C device]
Feb 11 18:41:38 orangepi3 fake-hwclock[371]: Mon Feb 11 18:41:38 UTC 2019
Feb 11 18:41:38 orangepi3 systemd[1]: Started Restore / save the current clock.
Feb 11 18:41:38 orangepi3 keyboard-setup.sh[380]: kbd_mode: invalid option -- 'x'
Feb 11 18:41:38 orangepi3 keyboard-setup.sh[380]: usage: kbd_mode [-a|-u|-k|-s] [-C device]
Feb 11 18:41:38 orangepi3 systemd-sysctl[384]: Couldn't write '1' to 'kernel/yama/ptrace_scope', ignoring: No such file or directory
Feb 11 18:41:38 orangepi3 systemd-journald[376]: Runtime journal (/run/log/journal/b4b8bfe0dc694ac08409b14c71c1f1c3) is 5.0M, max 20.0M, 15.0M free.
Feb 11 18:41:38 orangepi3 systemd[1]: Started Flush Journal to Persistent Storage.
/core/default_qdisc', ignoring: No such file or directory
Feb 11 18:41:38 orangepi3 systemd[1]: Started Apply Kernel Variables.
Feb 11 18:41:38 orangepi3 systemd[1]: Started Load/Save Random Seed.
Feb 11 18:41:38 orangepi3 resolvconf[394]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /run/resolvconf/resolv.conf
Feb 11 18:41:38 orangepi3 systemd[1]: Started Create Static Device Nodes in /dev.
Feb 11 18:41:38 orangepi3 systemd[1]: Starting udev Kernel Device Manager...
Feb 11 18:41:38 orangepi3 systemd[1]: Started Set the console keyboard layout.
Feb 11 18:41:38 orangepi3 systemd[1]: Reached target Local File Systems (Pre).
Feb 11 18:41:38 orangepi3 systemd[1]: Mounting /tmp...
Feb 11 18:41:38 orangepi3 systemd[1]: Mounted /tmp.
Feb 11 18:41:38 orangepi3 systemd[1]: Reached target Local File Systems.
Feb 11 18:41:38 orangepi3 systemd[1]: Starting Armbian ZRAM config...
Feb 11 18:41:38 orangepi3 systemd[1]: Starting Set console font and keymap...
Feb 11 18:41:38 orangepi3 systemd[1]: Starting Create Volatile Files and Directories...
Feb 11 18:41:38 orangepi3 systemd[1]: Starting Raise network interfaces...
Feb 11 18:41:38 orangepi3 systemd[1]: Started Set console font and keymap.
Feb 11 18:41:38 orangepi3 systemd[1]: Started Create Volatile Files and Directories.
Feb 11 18:41:38 orangepi3 systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
Feb 11 18:41:38 orangepi3 systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Feb 11 18:41:38 orangepi3 systemd[1]: Starting Network Time Synchronization...
Feb 11 18:41:38 orangepi3 systemd[1]: Starting Network Name Resolution...
Feb 11 18:41:38 orangepi3 systemd[1]: Started Update UTMP about System Boot/Shutdown.
Feb 11 18:41:39 orangepi3 kernel: zram: Added device: zram0
Feb 11 18:41:39 orangepi3 kernel: zram: Added device: zram1
Feb 11 18:41:39 orangepi3 kernel: zram: Added device: zram2
Feb 11 18:41:39 orangepi3 kernel: zram: Added device: zram3
Feb 11 18:41:39 orangepi3 kernel: zram: Added device: zram4
Feb 11 18:41:39 orangepi3 kernel: zram: Added device: zram5
Feb 11 18:41:39 orangepi3 systemd[1]: Started Network Time Synchronization.
Feb 11 18:41:39 orangepi3 systemd-resolved[441]: Positive Trust Anchors:
Feb 11 18:41:39 orangepi3 systemd-resolved[441]: . IN DS 19036 8 2 49aac11d7b6f6446702e54a1607371607a1a41855200fd2ce1cdde32f24e8fb5
Feb 11 18:41:39 orangepi3 systemd-resolved[441]: . IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e880409bbc683457104237c7f8ec8d
Feb 11 18:41:39 orangepi3 systemd-resolved[441]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.iddr.arpa 168.192.in-addr.arpa d.f.ip6.arpa corp home internal intranet lan local private test
Feb 11 18:41:39 orangepi3 systemd-resolved[441]: Using system hostname 'orangepi3'.
Feb 11 18:41:39 orangepi3 systemd[1]: Started Network Name Resolution.
Feb 11 18:41:39 orangepi3 systemd[1]: Reached target Host and Network Name Lookups.
Feb 11 18:41:39 orangepi3 kernel: zram1: detected capacity change from 0 to 262336512
Feb 11 18:41:39 orangepi3 systemd[1]: Started udev Kernel Device Manager.
Feb 11 18:41:39 orangepi3 systemd-udevd[499]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Feb 11 18:41:39 orangepi3 systemd-udevd[499]: link_config: could not get ethtool features for eth0
Feb 11 18:41:39 orangepi3 systemd-udevd[499]: Could not set offload features of eth0: Device or resource busy
Feb 11 18:41:39 orangepi3 systemd[1]: Found device /dev/ttyS0.
Feb 11 18:41:39 orangepi3 systemd[1]: Started Raise network interfaces.
Feb 11 18:41:39 orangepi3 systemd-udevd[495]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Feb 11 18:41:39 orangepi3 kernel: thermal thermal_zone0: failed to read out thermal zone (-16)
mal zone (-16)
Feb 11 18:41:39 orangepi3 kernel: cpu cpu0: Linked as a consumer to regulator.3
Feb 11 18:41:39 orangepi3 kernel: cpu cpu0: Dropping the link to regulator.3
Feb 11 18:41:39 orangepi3 kernel: cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 912000 KHz
Feb 11 18:41:39 orangepi3 kernel: cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1008000 KHz
Feb 11 18:41:40 orangepi3 haveged[436]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 6.4.0 CTV); collect: 128K
Feb 11 18:41:40 orangepi3 haveged[436]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 10/40; sz: 15464/70644
Feb 11 18:41:40 orangepi3 haveged[436]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 7.99958
Feb 11 18:41:40 orangepi3 haveged[436]: haveged: fills: 0, generated: 0
Feb 11 18:41:40 orangepi3 kernel: random: crng init done
Feb 11 18:41:40 orangepi3 kernel: random: 7 urandom warning(s) missed due to ratelimiting
Feb 11 18:41:40 orangepi3 armbian-zram-config[413]: Setting up swapspace version 1, size = 250.2 MiB (262332416 bytes)
-4ff7-81c2-b026cb814e10
Feb 11 18:41:40 orangepi3 kernel: Adding 256184k swap on /dev/zram1.  Priority:5 extents:1 across:256184k SSFS
Feb 11 18:41:40 orangepi3 kernel: zram2: detected capacity change from 0 to 262336512
Feb 11 18:41:40 orangepi3 armbian-zram-config[413]: no label, UUID=816e19b0-f378-437b-af97-e150d6213599
Feb 11 18:41:40 orangepi3 kernel: Adding 256184k swap on /dev/zram2.  Priority:5 extents:1 across:256184k SSFS
Feb 11 18:41:40 orangepi3 kernel: zram3: detected capacity change from 0 to 262336512
Feb 11 18:41:40 orangepi3 armbian-zram-config[413]: no label, UUID=63e0244b-db18-4b23-8120-5f34765b898e
Feb 11 18:41:40 orangepi3 kernel: Adding 256184k swap on /dev/zram3.  Priority:5 extents:1 across:256184k SSFS
Feb 11 18:41:40 orangepi3 kernel: zram4: detected capacity change from 0 to 262336512
Feb 11 18:41:40 orangepi3 armbian-zram-config[413]: no label, UUID=e1e01cfe-47bd-4c40-9aae-95bd699f9c0b
Feb 11 18:41:40 orangepi3 kernel: Adding 256184k swap on /dev/zram4.  Priority:5 extents:1 across:256184k SSFS
Feb 11 18:41:40 orangepi3 kernel: zram0: detected capacity change from 0 to 52428800
Feb 11 18:41:40 orangepi3 armbian-zram-config[413]: mke2fs 1.44.1 (24-Mar-2018)
Feb 11 18:41:40 orangepi3 armbian-zram-config[413]: [74B blob data]
Feb 11 18:41:40 orangepi3 armbian-zram-config[413]: Creating filesystem with 12800 4k blocks and 12800 inodes
Feb 11 18:41:40 orangepi3 armbian-zram-config[413]: [41B blob data]
Feb 11 18:41:40 orangepi3 armbian-zram-config[413]: [38B blob data]
Feb 11 18:41:40 orangepi3 armbian-zram-config[413]: [75B blob data]
Feb 11 18:41:40 orangepi3 systemd[1]: Started Armbian ZRAM config.
Feb 11 18:41:40 orangepi3 systemd[1]: Starting Armbian memory supported logging...
Feb 11 18:41:40 orangepi3 kernel: EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: Mounting /dev/zram0 as /var/log/
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: Mon Feb 11 18:41:40 UTC 2019: Loading logs from storage to zram
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: sending incremental file list
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: deleting lost+found/
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: ./
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: alternatives.log
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: armbian-hardware-monitor.log
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: bootstrap.log
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: btmp
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: dpkg.log
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: faillog
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: lastlog
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: tallylog
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: wtmp
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: apt/
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: apt/eipp.log.xz
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: apt/history.log
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: apt/term.log
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: journal/
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: ntpstats/
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: sysstat/
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: unattended-upgrades/
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: sent 660,367 bytes  received 290 bytes  1,321,314.00 bytes/sec
Feb 11 18:41:40 orangepi3 armbian-ramlog[620]: total size is 659,094  speedup is 1.00
Feb 11 18:41:41 orangepi3 systemd[1]: Started Armbian memory supported logging.
Feb 11 18:41:41 orangepi3 systemd[1]: Reached target System Initialization.
Feb 11 18:41:41 orangepi3 systemd[1]: Started Daily Cleanup of Temporary Directories.
Feb 11 18:41:41 orangepi3 systemd[1]: Started Daily apt download activities.
Feb 11 18:41:41 orangepi3 systemd[1]: Starting Armbian hardware optimization...
Feb 11 18:41:41 orangepi3 systemd[1]: Listening on D-Bus System Message Bus Socket.
Feb 11 18:41:41 orangepi3 systemd[1]: Reached target Sockets.
Feb 11 18:41:41 orangepi3 systemd[1]: Starting Armbian filesystem resize...
Feb 11 18:41:41 orangepi3 systemd[1]: Starting Armbian hardware monitoring...
Feb 11 18:41:41 orangepi3 systemd[1]: Started resolvconf-pull-resolved.path.
Feb 11 18:41:41 orangepi3 systemd[1]: Reached target Paths.
Feb 11 18:41:41 orangepi3 systemd[1]: Started Message of the Day.
Feb 11 18:41:41 orangepi3 systemd[1]: Started Daily apt upgrade and clean activities.
Feb 11 18:41:41 orangepi3 systemd[1]: Started Discard unused blocks once a week.
Feb 11 18:41:41 orangepi3 systemd[1]: Reached target Timers.
Feb 11 18:41:41 orangepi3 systemd[1]: Started Armbian hardware optimization.
Feb 11 18:41:41 orangepi3 systemd[1]: Started Armbian hardware monitoring.
Feb 11 18:41:41 orangepi3 armbian-hardware-optimization[662]: /usr/lib/armbian/armbian-hardware-optimization: line 31: echo: write error: Invalid argument
Feb 11 18:41:41 orangepi3 armbian-hardware-optimization[662]: [ ok ] Setting noop I/O scheduler for mmcblk0
Feb 11 18:41:41 orangepi3 armbian-hardware-optimization[662]: [ ok ] Setting noop I/O scheduler for mmcblk1
Feb 11 18:41:41 orangepi3 armbian-hardware-optimization[662]: [ ok ] Setting noop I/O scheduler for mmcblk1boot0
Feb 11 18:41:41 orangepi3 armbian-hardware-optimization[662]: [ ok ] Setting noop I/O scheduler for mmcblk1boot1
Feb 11 18:41:41 orangepi3 armbian-hardware-optimization[662]: sed: no input files
Feb 11 18:41:41 orangepi3 armbian-hardware-optimization[662]: /usr/lib/armbian/armbian-hardware-optimization: line 268: /proc/irq/$(awk -F":" "/eth/ {print \$1}" </proc/interrupts | sed 's/\ //g' | head -n1)/smp_affinity: No such file or directory
Feb 11 18:41:42 orangepi3 kernel: EXT4-fs (mmcblk0p1): resizing filesystem from 269312 to 7712800 blocks
Feb 11 18:42:04 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 1048576 blocks
Feb 11 18:42:18 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 1572864 blocks
Feb 11 18:42:31 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 2097152 blocks
Feb 11 18:42:42 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 2621440 blocks
Feb 11 18:42:54 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 3145728 blocks
Feb 11 18:43:05 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 3670016 blocks
Feb 11 18:43:16 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 4194304 blocks
Feb 11 18:43:28 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 4718592 blocks
Feb 11 18:43:39 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 5242880 blocks
Feb 11 18:43:50 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 5767168 blocks
Feb 11 18:44:01 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 6291456 blocks
Feb 11 18:44:12 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 6815744 blocks
Feb 11 18:44:23 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized to 7340032 blocks
Feb 11 18:44:32 orangepi3 kernel: EXT4-fs (mmcblk0p1): resized filesystem to 7712800
Feb 11 18:44:33 orangepi3 armbian-resize-filesystem[663]: Removed /etc/systemd/system/basic.target.wants/armbian-resize-filesystem.service.
Feb 11 18:44:33 orangepi3 systemd[1]: Reloading.
Feb 11 18:44:34 orangepi3 systemd[1]: Started Armbian filesystem resize.
Feb 11 18:44:34 orangepi3 systemd[1]: Reached target Basic System.
Feb 11 18:44:34 orangepi3 systemd[1]: Starting Dispatcher daemon for systemd-networkd...
Feb 11 18:44:34 orangepi3 systemd[1]: Started Armbian first run tasks.
Feb 11 18:44:34 orangepi3 systemd[1]: Started D-Bus System Message Bus.
Feb 11 18:44:34 orangepi3 dbus-daemon[1316]: dbus[1316]: Unknown username "whoopsie" in message bus configuration file
Feb 11 18:44:34 orangepi3 systemd[1]: Starting System Logging Service...
Feb 11 18:44:34 orangepi3 systemd[1]: Starting Login Service...
Feb 11 18:44:34 orangepi3 systemd[1]: Starting Resets System Activity Data Collector...
Feb 11 18:44:34 orangepi3 systemd[1]: Starting resolvconf-pull-resolved.service...
Feb 11 18:44:34 orangepi3 systemd[1]: Starting WPA supplicant...
Feb 11 18:44:34 orangepi3 systemd[1]: Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Feb 11 18:44:34 orangepi3 systemd[1]: Starting Network Manager...
Feb 11 18:44:34 orangepi3 sh[1326]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /run/resolvconf/resolv.conf
Feb 11 18:44:34 orangepi3 systemd[1]: Started Regular background program processing daemon.
Feb 11 18:44:34 orangepi3 systemd[1]: Started ntp-systemd-netif.service.
Feb 11 18:44:34 orangepi3 systemd[1]: Started resolvconf-pull-resolved.service.
Feb 11 18:44:34 orangepi3 systemd[1]: Started Resets System Activity Data Collector.
Feb 11 18:44:34 orangepi3 loadcpufreq[1330]:  * Loading cpufreq kernel modules...
Feb 11 18:44:35 orangepi3 loadcpufreq[1330]:    ...done.
Feb 11 18:44:35 orangepi3 systemd[1]: Started LSB: Load kernel modules needed to enable cpufreq scaling.
Feb 11 18:44:35 orangepi3 systemd[1]: Starting LSB: set CPUFreq kernel parameters...
Feb 11 18:44:35 orangepi3 cron[1351]: (CRON) INFO (pidfile fd = 3)
Feb 11 18:44:35 orangepi3 cpufrequtils[1386]:  * CPUFreq Utilities: Setting ondemand CPUFreq governor...
Feb 11 18:44:35 orangepi3 cpufrequtils[1386]:  * CPU0...
Feb 11 18:44:35 orangepi3 systemd-logind[1324]: New seat seat0.
Feb 11 18:44:35 orangepi3 systemd[1]: Started Login Service.
Feb 11 18:44:35 orangepi3 cpufrequtils[1386]:  * CPU1...
Feb 11 18:44:35 orangepi3 cpufrequtils[1386]:  * CPU2...
Feb 11 18:44:35 orangepi3 cpufrequtils[1386]:  * CPU3...
Feb 11 18:44:35 orangepi3 cpufrequtils[1386]:    ...done.
Feb 11 18:44:35 orangepi3 systemd[1]: Started LSB: set CPUFreq kernel parameters.
Feb 11 18:44:35 orangepi3 systemd[1]: Starting LSB: Set sysfs variables from /etc/sysfs.conf...
Feb 11 18:44:35 orangepi3 sysfsutils[1405]:  * Setting sysfs variables...
Feb 11 18:44:35 orangepi3 sysfsutils[1405]:    ...done.
Feb 11 18:44:35 orangepi3 systemd[1]: Started LSB: Set sysfs variables from /etc/sysfs.conf.
Feb 11 18:44:35 orangepi3 cron[1351]: (CRON) INFO (Running @reboot jobs)
Feb 11 18:44:35 orangepi3 rsyslogd[1323]: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.32.0]
Feb 11 18:44:35 orangepi3 rsyslogd[1323]: rsyslogd's groupid changed to 106
Feb 11 18:44:35 orangepi3 systemd[1]: Started System Logging Service.
Feb 11 18:44:35 orangepi3 rsyslogd[1323]: rsyslogd's userid changed to 102
Feb 11 18:44:35 orangepi3 rsyslogd[1323]: [origin software="rsyslogd" swVersion="8.32.0" x-pid="1323" x-info="http://www.rsyslog.com"] start
Feb 11 18:44:36 orangepi3 systemd[1]: Started WPA supplicant.
Feb 11 18:44:36 orangepi3 wpa_supplicant[1327]: Successfully initialized wpa_supplicant
Feb 11 18:44:38 orangepi3 CRON[1413]: pam_unix(cron:account): expired password for user root (root enforced)
Feb 11 18:44:38 orangepi3 CRON[1413]: Authentication token is no longer valid; new one required
Feb 11 18:44:38 orangepi3 cron[1351]: Authentication token is no longer valid; new one required
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.0092] NetworkManager (version 1.10.6) is starting... (for the first time)
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.0093] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 10-dns-resolved.conf, 10-override-random-mac.conf, no-mac-addr-change.conf, zz-override-wifi-powersave-off.conf) (run: 10-globally-managed-devices.conf) (etc: default-wifi-powersave-on.conf)
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.1875] manager[0xaaab06bfb050]: monitoring kernel firmware directory '/lib/firmware'.
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.1876] monitoring ifupdown state file '/run/network/ifstate'.
Feb 11 18:44:42 orangepi3 dbus-daemon[1316]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.3' (uid=0 pid=1334 comm="/usr/sbin/NetworkManager --no-daemon ")
Feb 11 18:44:42 orangepi3 systemd[1]: Starting Hostname Service...
Feb 11 18:44:42 orangepi3 dbus-daemon[1316]: [system] Successfully activated service 'org.freedesktop.hostname1'
Feb 11 18:44:42 orangepi3 systemd[1]: Started Hostname Service.
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.3883] hostname: hostname: using hostnamed
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.3884] hostname: hostname changed from (none) to "orangepi3"
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.3893] dns-mgr[0xaaab06c19970]: init: dns=default, rc-manager=file
Feb 11 18:44:42 orangepi3 networkd-dispatcher[1314]: WARNING: systemd-networkd is not running, output will be incomplete.
Feb 11 18:44:42 orangepi3 systemd[1]: Started Network Manager.
Feb 11 18:44:42 orangepi3 systemd[1]: Reached target Network.
Feb 11 18:44:42 orangepi3 systemd[1]: Started Unattended Upgrades Shutdown.
Feb 11 18:44:42 orangepi3 systemd[1]: Starting Permit User Sessions...
rvice name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=1334 comm="/usr/sbin/NetworkManager --no-daemon ")
Feb 11 18:44:42 orangepi3 systemd[1]: Starting OpenBSD Secure Shell server...
Feb 11 18:44:42 orangepi3 systemd[1]: Starting Network Manager Wait Online...
Feb 11 18:44:42 orangepi3 systemd[1]: Started Dispatcher daemon for systemd-networkd.
Feb 11 18:44:42 orangepi3 systemd[1]: Started Permit User Sessions.
Feb 11 18:44:42 orangepi3 systemd[1]: Starting Network Manager Script Dispatcher Service...
Feb 11 18:44:42 orangepi3 systemd[1]: Starting Set console scheme...
Feb 11 18:44:42 orangepi3 systemd[1]: Started Set console scheme.
Feb 11 18:44:42 orangepi3 systemd[1]: Created slice system-getty.slice.
Feb 11 18:44:42 orangepi3 dbus-daemon[1316]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Feb 11 18:44:42 orangepi3 systemd[1]: Started Network Manager Script Dispatcher Service.
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9804] init!
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9807]       interface-parser: parsing file /etc/network/interfaces
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9808]       interface-parser: source line includes interfaces file(s) /etc/network/interfaces.d/*
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <warn>  [1549910682.9809] interfaces file /etc/network/interfaces.d/* doesn't exist
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9809]       interface-parser: finished parsing file /etc/network/interfaces
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9810] management mode: managed
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9818] devices added (path: /sys/devices/platform/soc/5020000.ethernet/net/eth0, iface: eth0)
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9819] device added (path: /sys/devices/platform/soc/5020000.ethernet/net/eth0, iface: eth0): no ifupdown configuration found.
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9819] devices added (path: /sys/devices/virtual/net/lo, iface: lo)
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9819] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found.
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9820] end _init.
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9820] settings: loaded plugin ifupdown: (C) 2008 Canonical Ltd.  To report bugs please use the NetworkManager mailing list. (/usr/lib/aarch64-linux-gnu/NetworkManager/libnm-settings-plugin-ifupdown.so)
gs: loaded plugin keyfile: (c) 2007 - 2016 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9823] (113467456) ... get_connections.
Feb 11 18:44:42 orangepi3 NetworkManager[1334]: <info>  [1549910682.9823] (113467456) connections count: 0
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0199] manager: rfkill: WiFi enabled by radio killswitch; enabled by state file
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0201] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0201] manager: Networking is enabled by state file
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0206] dhcp-init: Using DHCP client 'dhclient'
Feb 11 18:44:43 orangepi3 nm-dispatcher[1433]: req:1 'hostname': new request (2 scripts)
Feb 11 18:44:43 orangepi3 nm-dispatcher[1433]: req:1 'hostname': start running ordered scripts...
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0802] Loaded device plugin: NMBondDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0803] Loaded device plugin: NMBridgeDeviceFactory (internal)
 device plugin: NMDummyDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0804] Loaded device plugin: NMEthernetDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0805] Loaded device plugin: NMInfinibandDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0805] Loaded device plugin: NMIPTunnelDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0806] Loaded device plugin: NMMacsecDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0806] Loaded device plugin: NMMacvlanDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0806] Loaded device plugin: NMPppDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0807] Loaded device plugin: NMTunDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0807] Loaded device plugin: NMVethDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0808] Loaded device plugin: NMVlanDeviceFactory (internal)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.0808] Loaded device plugin: NMVxlanDeviceFactory (internal)
evice-plugin-team.so)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.3376] Loaded device plugin: NMAtmManager (/usr/lib/aarch64-linux-gnu/NetworkManager/libnm-device-plugin-adsl.so)
Feb 11 18:44:43 orangepi3 sshd[1442]: Server listening on 0.0.0.0 port 22.
Feb 11 18:44:43 orangepi3 sshd[1442]: Server listening on :: port 22.
Feb 11 18:44:43 orangepi3 systemd[1]: Started OpenBSD Secure Shell server.
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.9301] Loaded device plugin: NMBluezManager (/usr/lib/aarch64-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so)
Feb 11 18:44:43 orangepi3 NetworkManager[1334]: <info>  [1549910683.9883] Loaded device plugin: NMWwanFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/libnm-device-plugin-wwan.so)
Feb 11 18:44:44 orangepi3 NetworkManager[1334]: <info>  [1549910684.0714] Loaded device plugin: NMWifiFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/libnm-device-plugin-wifi.so)
Feb 11 18:44:44 orangepi3 NetworkManager[1334]: <info>  [1549910684.1256] device (lo): carrier: link connected
Feb 11 18:44:44 orangepi3 NetworkManager[1334]: <info>  [1549910684.1279] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Feb 11 18:44:44 orangepi3 NetworkManager[1334]: <info>  [1549910684.1292] device (eth0): driver '(null)' does not support carrier detection.
 (eth0): driver 'dwmac-sun8i' does not support carrier detection.
Feb 11 18:44:44 orangepi3 NetworkManager[1334]: <info>  [1549910684.1325] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Feb 11 18:44:44 orangepi3 NetworkManager[1334]: <info>  [1549910684.1361] device (eth0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Feb 11 18:44:44 orangepi3 kernel: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Feb 11 18:44:44 orangepi3 kernel: dwmac-sun8i 5020000.ethernet eth0: device MAC address 16:9b:f5:c8:67:dc
Feb 11 18:44:44 orangepi3 kernel: RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
Feb 11 18:44:44 orangepi3 kernel: dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found
Feb 11 18:44:44 orangepi3 kernel: dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available
Feb 11 18:44:44 orangepi3 kernel: dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW
ion 1")
Feb 11 18:44:44 orangepi3 NetworkManager[1334]: <info>  [1549910684.1470] settings: (eth0): created default wired connection 'Wired connection 1'
Feb 11 18:44:44 orangepi3 dbus-daemon[1316]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.3' (uid=0 pid=1334 comm="/usr/sbin/NetworkManager --no-daemon ")
Feb 11 18:44:44 orangepi3 systemd[1]: Starting Authorization Manager...
Feb 11 18:44:44 orangepi3 polkitd[1444]: started daemon version 0.105 using authority implementation `local' version `0.105'
Feb 11 18:44:44 orangepi3 dbus-daemon[1316]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Feb 11 18:44:44 orangepi3 systemd[1]: Started Authorization Manager.
Feb 11 18:44:50 orangepi3 NetworkManager[1334]: <info>  [1549910690.1463] manager: startup complete
Feb 11 18:44:50 orangepi3 systemd[1]: Started Network Manager Wait Online.
Feb 11 18:44:50 orangepi3 systemd[1]: Reached target Network is Online.
Feb 11 18:44:50 orangepi3 systemd[1]: Starting /etc/rc.local Compatibility...
Feb 11 18:44:50 orangepi3 systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemon...
Feb 11 18:44:51 orangepi3 systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon.
Feb 11 18:44:51 orangepi3 systemd[1]: Started /etc/rc.local Compatibility.
Feb 11 18:44:51 orangepi3 systemd[1]: Started Serial Getty on ttyS0.
Feb 11 18:44:51 orangepi3 systemd[1]: Started Getty on tty1.
Feb 11 18:44:51 orangepi3 systemd[1]: Reached target Login Prompts.
Feb 11 18:44:51 orangepi3 systemd[1]: Reached target Multi-User System.
Feb 11 18:44:51 orangepi3 systemd[1]: Reached target Graphical Interface.
Feb 11 18:44:51 orangepi3 systemd[1]: Starting Update UTMP about System Runlevel Changes...
Feb 11 18:44:51 orangepi3 systemd[1]: Started Update UTMP about System Runlevel Changes.
Feb 11 18:44:51 orangepi3 systemd[1]: Startup finished in 6.572s (kernel) + 3min 15.409s (userspace) = 3min 21.981s.
Feb 11 18:44:55 orangepi3 NetworkManager[1334]: <info>  [1549910695.3869] device (eth0): carrier: link connected
Feb 11 18:44:55 orangepi3 kernel: dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Feb 11 18:44:55 orangepi3 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Feb 11 18:44:55 orangepi3 NetworkManager[1334]: <info>  [1549910695.3891] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Feb 11 18:44:55 orangepi3 NetworkManager[1334]: <info>  [1549910695.3915] policy: auto-activating connection 'Wired connection 1'
6-84e6-d4df6164fd1e)
Feb 11 18:44:55 orangepi3 NetworkManager[1334]: <info>  [1549910695.3965] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Feb 11 18:44:55 orangepi3 NetworkManager[1334]: <info>  [1549910695.3971] manager: NetworkManager state is now CONNECTING
Feb 11 18:44:55 orangepi3 NetworkManager[1334]: <info>  [1549910695.3984] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Feb 11 18:44:55 orangepi3 NetworkManager[1334]: <info>  [1549910695.4003] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Feb 11 18:44:55 orangepi3 NetworkManager[1334]: <info>  [1549910695.4110] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Feb 11 18:44:55 orangepi3 NetworkManager[1334]: <info>  [1549910695.4375] dhcp4 (eth0): dhclient started with pid 1604
Feb 11 18:44:55 orangepi3 dhclient[1604]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3 (xid=0xa84c1e56)
Feb 11 18:44:58 orangepi3 dhclient[1604]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7 (xid=0xa84c1e56)
Feb 11 18:45:01 orangepi3 CRON[1797]: pam_unix(cron:account): expired password for user root (root enforced)
Feb 11 18:45:01 orangepi3 cron[1351]: Authentication token is no longer valid; new one required
Feb 11 18:45:01 orangepi3 CRON[1797]: Authentication token is no longer valid; new one required
Feb 11 18:45:01 orangepi3 CRON[1796]: Authentication token is no longer valid; new one required
Feb 11 18:45:01 orangepi3 systemd[1]: Reloading.
Feb 11 18:45:01 orangepi3 systemd[1]: Starting resolvconf-pull-resolved.service...
Feb 11 18:45:01 orangepi3 systemd[1]: Started resolvconf-pull-resolved.service.
Feb 11 18:45:01 orangepi3 systemd[1]: Stopping OpenBSD Secure Shell server...
Feb 11 18:45:01 orangepi3 sshd[1442]: Received signal 15; terminating.
Feb 11 18:45:01 orangepi3 systemd[1]: Stopped OpenBSD Secure Shell server.
Feb 11 18:45:01 orangepi3 systemd[1]: Starting OpenBSD Secure Shell server...
Feb 11 18:45:01 orangepi3 sshd[1856]: Server listening on 0.0.0.0 port 22.
Feb 11 18:45:01 orangepi3 sshd[1856]: Server listening on :: port 22.
Feb 11 18:45:01 orangepi3 systemd[1]: Started OpenBSD Secure Shell server.
Feb 11 18:45:03 orangepi3 systemd[1]: Stopping OpenBSD Secure Shell server...
Feb 11 18:45:03 orangepi3 sshd[1856]: Received signal 15; terminating.
Feb 11 18:45:03 orangepi3 systemd[1]: Stopped OpenBSD Secure Shell server.
Feb 11 18:45:03 orangepi3 systemd[1]: Starting OpenBSD Secure Shell server...
Feb 11 18:45:03 orangepi3 sshd[1864]: Server listening on 0.0.0.0 port 22.
Feb 11 18:45:03 orangepi3 sshd[1864]: Server listening on :: port 22.
Feb 11 18:45:03 orangepi3 systemd[1]: Started OpenBSD Secure Shell server.
Feb 11 18:45:03 orangepi3 armbian-firstrun[1315]: Removed /etc/systemd/system/multi-user.target.wants/armbian-firstrun.service.
Feb 11 18:45:03 orangepi3 systemd[1]: Reloading.
Feb 11 18:45:03 orangepi3 systemd[1]: Starting resolvconf-pull-resolved.service...
Feb 11 18:45:03 orangepi3 systemd[1]: Started resolvconf-pull-resolved.service.
Feb 11 18:45:05 orangepi3 dhclient[1604]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 14 (xid=0xa84c1e56)
Feb 11 18:45:11 orangepi3 systemd[1]: serial-getty@ttyS0.service: Service hold-off time over, scheduling restart.
Feb 11 18:45:11 orangepi3 systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 1.
Feb 11 18:45:11 orangepi3 systemd[1]: Stopped Serial Getty on ttyS0.
Feb 11 18:45:11 orangepi3 systemd[1]: Started Serial Getty on ttyS0.
Feb 11 18:45:19 orangepi3 dhclient[1604]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 20 (xid=0xa84c1e56)
Feb 11 18:45:30 orangepi3 login[1893]: pam_unix(login:account): expired password for user root (root enforced)
Feb 11 18:45:39 orangepi3 dhclient[1604]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 19 (xid=0xa84c1e56)
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <warn>  [1549910740.2252] dhcp4 (eth0): request timed out
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2254] dhcp4 (eth0): state changed unknown -> timeout
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2418] dhcp4 (eth0): canceled DHCP transaction, DHCP client pid 1604
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2419] dhcp4 (eth0): state changed timeout -> done
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2430] device (eth0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2440] manager: NetworkManager state is now DISCONNECTED
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <warn>  [1549910740.2453] device (eth0): Activation: failed for connection 'Wired connection 1'
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2483] device (eth0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2575] policy: auto-activating connection 'Wired connection 1'
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2631] device (eth0): Activation: starting connection 'Wired connection 1' (e32ba09f-6d74-36d6-84e6-d4df6164fd1e)
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2643] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2651] manager: NetworkManager state is now CONNECTING
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2670] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2690] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2705] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Feb 11 18:45:40 orangepi3 NetworkManager[1334]: <info>  [1549910740.2765] dhcp4 (eth0): dhclient started with pid 1896
Feb 11 18:45:40 orangepi3 dhclient[1896]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3 (xid=0xf6c4fe38)
Feb 11 18:45:43 orangepi3 dhclient[1896]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4 (xid=0xf6c4fe38)
Feb 11 18:45:46 orangepi3 login[1893]: pam_unix(login:chauthtok): password changed for root
Feb 11 18:45:47 orangepi3 dhclient[1896]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 11 (xid=0xf6c4fe38)
Feb 11 18:45:47 orangepi3 login[1893]: pam_unix(login:session): session opened for user root by LOGIN(uid=0)
Feb 11 18:45:47 orangepi3 systemd[1]: Created slice User Slice of root.
Feb 11 18:45:47 orangepi3 systemd[1]: Starting User Manager for UID 0...
Feb 11 18:45:47 orangepi3 systemd-logind[1324]: New session 1 of user root.
Feb 11 18:45:47 orangepi3 systemd[1]: Started Session 1 of user root.
Feb 11 18:45:47 orangepi3 systemd[1978]: pam_unix(systemd-user:session): session opened for user root by (uid=0)
Feb 11 18:45:47 orangepi3 systemd[1978]: Listening on GnuPG cryptographic agent and passphrase cache.
Feb 11 18:45:47 orangepi3 systemd[1978]: Reached target Timers.
Feb 11 18:45:47 orangepi3 systemd[1978]: Listening on GnuPG network certificate management daemon.
Feb 11 18:45:47 orangepi3 systemd[1978]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Feb 11 18:45:47 orangepi3 systemd[1978]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Feb 11 18:45:47 orangepi3 systemd[1978]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Feb 11 18:45:47 orangepi3 systemd[1978]: Reached target Sockets.
Feb 11 18:45:47 orangepi3 systemd[1978]: Reached target Paths.
Feb 11 18:45:47 orangepi3 systemd[1978]: Reached target Basic System.
Feb 11 18:45:47 orangepi3 systemd[1978]: Reached target Default.
Feb 11 18:45:47 orangepi3 systemd[1978]: Startup finished in 217ms.
Feb 11 18:45:47 orangepi3 systemd[1]: Started User Manager for UID 0.
Feb 11 18:45:47 orangepi3 login[1989]: ROOT LOGIN  on '/dev/ttyS0'
Feb 11 18:45:58 orangepi3 dhclient[1896]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 15 (xid=0xf6c4fe38)
Feb 11 18:46:13 orangepi3 dhclient[1896]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 8 (xid=0xf6c4fe38)
Feb 11 18:46:21 orangepi3 dhclient[1896]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 10 (xid=0xf6c4fe38)
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <warn>  [1549910785.2250] dhcp4 (eth0): request timed out
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2251] dhcp4 (eth0): state changed unknown -> timeout
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2576] dhcp4 (eth0): canceled DHCP transaction, DHCP client pid 1896
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2577] dhcp4 (eth0): state changed timeout -> done
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2589] device (eth0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2599] manager: NetworkManager state is now DISCONNECTED
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <warn>  [1549910785.2612] device (eth0): Activation: failed for connection 'Wired connection 1'
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2636] device (eth0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2729] policy: auto-activating connection 'Wired connection 1'
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2786] device (eth0): Activation: starting connection 'Wired connection 1' (e32ba09f-6d74-36d6-84e6-d4df6164fd1e)
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2797] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2825] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2844] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2860] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Feb 11 18:46:25 orangepi3 NetworkManager[1334]: <info>  [1549910785.2914] dhcp4 (eth0): dhclient started with pid 1999
Feb 11 18:46:25 orangepi3 dhclient[1999]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 3 (xid=0x8072ef3d)
Feb 11 18:46:28 orangepi3 dhclient[1999]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 8 (xid=0x8072ef3d)
Feb 11 18:46:36 orangepi3 dhclient[1999]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 12 (xid=0x8072ef3d)
Feb 11 18:46:48 orangepi3 dhclient[1999]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 20 (xid=0x8072ef3d)
Feb 11 18:47:08 orangepi3 dhclient[1999]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7 (xid=0x8072ef3d)
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <warn>  [1549910830.2247] dhcp4 (eth0): request timed out
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2248] dhcp4 (eth0): state changed unknown -> timeout
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2413] dhcp4 (eth0): canceled DHCP transaction, DHCP client pid 1999
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2414] dhcp4 (eth0): state changed timeout -> done
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2425] device (eth0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2435] manager: NetworkManager state is now DISCONNECTED
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <warn>  [1549910830.2449] device (eth0): Activation: failed for connection 'Wired connection 1'
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2565] policy: auto-activating connection 'Wired connection 1'
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2622] device (eth0): Activation: starting connection 'Wired connection 1' (e32ba09f-6d74-36d6-84e6-d4df6164fd1e)
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2633] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2643] manager: NetworkManager state is now CONNECTING
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2662] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2681] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2697] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Feb 11 18:47:10 orangepi3 NetworkManager[1334]: <info>  [1549910830.2752] dhcp4 (eth0): dhclient started with pid 2025
5 port 67 interval 3 (xid=0x94e94d77)
Feb 11 18:47:20 orangepi3 dhclient[2025]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 9 (xid=0x94e94d77)
Feb 11 18:47:29 orangepi3 dhclient[2025]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 20 (xid=0x94e94d77)
Feb 11 18:47:49 orangepi3 dhclient[2025]: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 14 (xid=0x94e94d77)
Feb 11 18:47:55 orangepi3 NetworkManager[1334]: <warn>  [1549910875.2256] dhcp4 (eth0): request timed out
Feb 11 18:47:55 orangepi3 NetworkManager[1334]: <info>  [1549910875.2257] dhcp4 (eth0): state changed unknown -> timeout
Feb 11 18:47:55 orangepi3 NetworkManager[1334]: <info>  [1549910875.2421] dhcp4 (eth0): canceled DHCP transaction, DHCP client pid 2025
Feb 11 18:47:55 orangepi3 NetworkManager[1334]: <info>  [1549910875.2422] dhcp4 (eth0): state changed timeout -> done
Feb 11 18:47:55 orangepi3 NetworkManager[1334]: <info>  [1549910875.2434] device (eth0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Feb 11 18:47:55 orangepi3 NetworkManager[1334]: <info>  [1549910875.2444] manager: NetworkManager state is now DISCONNECTED
Feb 11 18:47:55 orangepi3 NetworkManager[1334]: <warn>  [1549910875.2458] device (eth0): Activation: failed for connection 'Wired connection 1'
managed')
this looks promissing,  ethtool output shows:
       Speed: 100Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 1
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: d
        Wake-on: d
        Current message level: 0x0000003f (63)
                               drv probe link timer ifdown ifup
        Link detected: yes
could you also set the ip adress manualy in /etc/network/interfaces ?
and then do ifconfig eth0 up ?
could you also check what happens if you use ethtool to set speed to fixed 100 full duplex, does this bring up the connection.
/etc/udev/rules.d/70-persistent-net.rules
this file should not be missing, could you try to generated it manualy?
sudo udevadm trigger --subsystem-match=net --action=add
do you have the orangepi with EMMC onboard ? could you cehck if this shows up with mount and blkid?
Thanks again so much for all your work, @krachlatte!
I have tried setting a static IP, as well as using ethtool to set the link speed to both 100 and 1000 full duplex, but no luck. The static IP is applied, but the device is still not able to reach the network.
Running the udevadm command does not appear to generate anything - the /etc/udev/rules.d/70-persistent-net.rules file is still not present afterwards.
Yes, I have the 8GB eMMC version, and this appears to be detected in this build (mmcblk1):
root@orangepi3:~# lsblk -d
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
mmcblk0      179:0    0  14.9G  0 disk
mmcblk1      179:32   0   7.3G  0 disk
mmcblk1boot0 179:64   0     4M  1 disk
mmcblk1boot1 179:96   0     4M  1 disk
zram0        254:0    0    50M  0 disk /var/log
zram1        254:1    0 250.2M  0 disk [SWAP]
zram2        254:2    0 250.2M  0 disk [SWAP]
zram3        254:3    0 250.2M  0 disk [SWAP]
zram4        254:4    0 250.2M  0 disk [SWAP]
doesn't boot for my Orange pi 3 with emmc
8 hours ago, krachlatte said:
p.s. i have some problem with docker on standart ubuntu image. Ubuntu (and Debian) has kernel 3.10.65+, that not supporting aufs or overlay2. Anyone know how to upgrade this kerner for a newer version, or how to install aufs support?
3.10.65 on OPi 3? Armbian will never deal with the BSP kernel for H6 boards, you may ask in Xunlongs supportforum.
it would be worth to have your buildscript and it's changes (as a fork) on your github as well, so that people interested in your work can see what you tried so far or even contribute to it.
the code is here https://github.com/krachlatte/armbian-orangepi3, i had problems setting up this repsoitory, it consists only of the dts files and Makefiles form the dts folders. the last stuff i have added is in the git. commit is "usb3 and eth0" and this is release v0.04. so v.0.03 is still booting and v0.04 is not ?
i still do not have the hardware, waiting fo it....
how can i prevent the ./comple.h to override my changes before compling with my changed files, if this is not possible how can i do this, is theer guide  ?
or am i doing the changes the wrong way with the armiabn build system.... do i need to fork the whole stuff and then comit the changes to my FORKED stuff, would this be the better way ?
forking ##################
Check CREATE_PATCHES="yes" switch.
12 hours ago, krachlatte said:
This boots for me - I've enabled verbosity=7 in /boot/armbianEnv.txt and can see it booting the kernel, it sits for about 30 seconds at the following line:
systemd-journald[385]: Received request to flush runtime journal from PID 1
...but eventually does boot to the login prompt.
USB3 seems to work on this build, but still no luck on the ethernet side of things. Out of interest, I plugged in an external USB3 ethernet adapter and that works perfectly.
many thanks igor,
i forked the whole thing and added my changes as patches, id did not have the time to build the whole thing again and upload a new release, but this should be the changes i have done to get release v0.04 compiled
https://github.com/krachlatte/build
https://github.com/krachlatte/build/commit/683669a83144a4802275794cb690095cff8e0330
27 minutes ago, krachlatte said:
many thanks igor,
and a few follow up posts describe 'my workflow' for patching... up to the one from jan. 19th.
hi could you send in a dmesg, does the boot always take that long? or has this been the first boot that took some time longer, maybe it is rleated to the rezising:
[   11.292113] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[   13.630534] EXT4-fs (mmcblk0p1): resizing filesystem from 269312 to 7712800 blocks
[   34.979035] EXT4-fs (mmcblk0p1): resized to 1048576 blocks
[   48.962691] EXT4-fs (mmcblk0p1): resized to 1572864 blocks
[   61.869271] EXT4-fs (mmcblk0p1): resized to 2097152 blocks
[   72.883456] EXT4-fs (mmcblk0p1): resized to 2621440 blocks
[   85.109389] EXT4-fs (mmcblk0p1): resized to 3145728 blocks
[   96.114426] EXT4-fs (mmcblk0p1): resized to 3670016 blocks
[  107.202950] EXT4-fs (mmcblk0p1): resized to 4194304 blocks
[  119.349646] EXT4-fs (mmcblk0p1): resized to 4718592 blocks
[  130.377654] EXT4-fs (mmcblk0p1): resized to 5242880 blocks
[  141.457778] EXT4-fs (mmcblk0p1): resized to 5767168 blocks
[  152.490327] EXT4-fs (mmcblk0p1): resized to 6291456 blocks
[  163.520142] EXT4-fs (mmcblk0p1): resized to 6815744 blocks
[  174.582026] EXT4-fs (mmcblk0p1): resized to 7340032 blocks
[  182.958542] EXT4-fs (mmcblk0p1): resized filesystem to 7712800
example dmesg
  Hide contents
example dmesg
This is normal when it is the first boot. The filesystem will expand itself over the whole sd card. The bigger the card, the longer this will take. Just be patient. When successful all further boot processes will be faster.
Any advice on what to test before I flash the board? Just in case.
I was not home when my shipping arrived and the box is thrown 15 feet into my house. Luckily my brother's car didn't squashed it.
This image should just boot from MicroSD once written with dd, right? The OPi3 is just skipping past it to the eMMC. The contents of the partitions appear to be intact.
