Da Alchemist Posted April 4, 2019 Posted April 4, 2019 I have build a new image and feed it to my pineh64 (A). It runs up to 1.8GHz now with temperatures going up to 80°C. I think the real improvement is concerning USB3. my attached SSD is showing up UAS mode now! BTW is it possible to get a fixed MAC Adress?
martinayotte Posted April 4, 2019 Posted April 4, 2019 30 minutes ago, Da Alchemist said: BTW is it possible to get a fixed MAC Adress? Is it random on PineH64 too ? I've fixed OPi3 and OPiOnePlus recently, maybe the same medicine could be applied ... I will check tomorrow ...
NicoD Posted April 5, 2019 Posted April 5, 2019 I've got almost the same with the PineH64 at 1.8Ghz. Using 7zip benchmark without heatsink it's 75°C after 3seconds. With the heatsink this takes longer, but after a minute full load it's also throttling heavily. 7zip isn't the heaviest load, it doesn't use full 100%. Here Pine64 at 1.5Ghz no heatsink : CPU miner is a little faster than 1.8Ghz with heatsink, 7-zip is a little slower(CPU miner uses more of the cpu, so it throttles more than 7zip)http://ix.io/1Ffr Here Pine64 at 1.8Ghz with heatsink no fanhttp://ix.io/1Flu Here Orange Pi 3 at 1.8Ghz with heatsink no fanhttp://ix.io/1EOn I'm now doing SBC-bench @ 1.8Ghz no heatsink no fan. I'm sure it's worse than 1.5Ghz no heatsink no fan. The base temperature does seem a bit lower on the PineH64. 45°C vs +50°C. The temperatures at full load seem the same. Both throttling. I do these tests after running in the heatsink, and then let it cool to it's idle temp. @TonyMac32 Could you try sbc-bench on it please? I'd wished they'd sold a nice flat wide and long heatsink for it, from emmc to ethernet, and from hdmi to gpio's. There's enough room, and nothing's in the way. Only Hardkernel and FriendlyElec seem to care about that. P.S.: 1.8Ghz no heatsink/fanhttp://ix.io/1FlD 7-zip is as fast as 1.5Ghz no heatsink/fan, cpu miner is quite a bit slower. A bit a pitty. But with small 5V fan at 3.3V you get max performance. So it's not like the Tinker Board/XU4, throttling with heatsink and fan.
TonyMac32 Posted April 5, 2019 Posted April 5, 2019 2 hours ago, NicoD said: Could you try sbc-bench on it please? I'll try that tomorrow, was working on other projects tonight. I do have a question for the general public: Why is there not an opp between 1.488 and 1.8? To be honest the spacing of the frequencies seems a bit strange in general, some are 240 MHz spaced, others are completely seemingly random numbers. Is there a 1.6 GHz hiding in there somewhere? I honestly haven't done any researching, just wondering if maybe this got overlooked, or if the clockspeeds are controlled by schizophrenic multipliers
constantius Posted April 5, 2019 Posted April 5, 2019 I have not received yet the board but i'm prepared for 1.8 GHZ.
NicoD Posted April 5, 2019 Posted April 5, 2019 8 hours ago, TonyMac32 said: I do have a question for the general public: Why is there not an opp between 1.488 and 1.8? To be honest the spacing of the frequencies seems a bit strange in general, some are 240 MHz spaced, others are completely seemingly random numbers. Is there a 1.6 GHz hiding in there somewhere? I honestly haven't done any researching, just wondering if maybe this got overlooked, or if the clockspeeds are controlled by schizophrenic multipliers Indeed a bit strange 1.8Ghz 1.49Ghz 1.32Ghz 1.08Ghz 888Mhz 816Mhz 720Mhz 480Mhz Those 2 in 800??? What the point of that? And then too much change with the higher numbers. 1 hour ago, constantius said: I have not received yet the board but i'm prepared for 1.8 GHZ. That will be more than sufficient. It's not that hard to cool it. I'm thinking of the people who will run it without heatsink/fan that will just throttle the board constantly without even knowing. And not having good results what again brings complaints...
TonyMac32 Posted April 5, 2019 Posted April 5, 2019 Perhaps a menu utility to set governor's and maximum/minimum clockspeeds for noobs?Sent from my Pixel using Tapatalk
NicoD Posted April 5, 2019 Posted April 5, 2019 29 minutes ago, TonyMac32 said: Perhaps a menu utility to set governor's and maximum/minimum clockspeeds for noobs? Yes. Exactly! Just like with the Odroid'shttps://github.com/mad-ady/odroid-cpu-control I also notice the H64 has a lower base temperature than the OPi3. In idle this is a difference of 10°C. Maxed out this difference is smaller, but still 5°C less. This is so without heatsink, the same with theatsink and also with heatsink + 3.3V. Here the H64 at the start of SBC-bench, so starts with idle temps. With heatsink +3.3V Time CPU load %cpu %sys %usr %nice %io %irq Temp 13:30:50: 1800MHz 0.38 6% 1% 4% 0% 0% 0% 30.8°C 13:32:50: 1800MHz 1.22 32% 1% 31% 0% 0% 0% 44.8°C 13:34:50: 1800MHz 1.35 33% 1% 32% 0% 0% 0% 37.6°C 13:36:50: 1800MHz 1.20 29% 0% 29% 0% 0% 0% 38.2°C 13:38:50: 1800MHz 1.30 29% 0% 28% 0% 0% 0% 37.9°C 13:40:50: 1800MHz 1.19 29% 0% 29% 0% 0% 0% 38.5°C 13:42:50: 1800MHz 1.12 29% 0% 29% 0% 0% 0% 38.5°C Here the same with the OPi3 Time CPU load %cpu %sys %usr %nice %io %irq Temp 17:09:32: 1800MHz 0.30 30% 1% 29% 0% 0% 0% 45.4°C 17:11:32: 1800MHz 1.16 32% 1% 31% 0% 0% 0% 50.1°C 17:13:32: 1800MHz 1.22 32% 1% 31% 0% 0% 0% 48.4°C 17:15:32: 1800MHz 1.14 29% 0% 29% 0% 0% 0% 44.6°C 17:17:32: 1800MHz 1.18 29% 0% 28% 0% 0% 0% 44.4°C 17:19:32: 1800MHz 1.37 29% 0% 28% 0% 0% 0% 44.7°C 17:21:32: 1800MHz 1.15 29% 0% 28% 0% 0% 0% 44.7°C The OPi3 throttled a little bit with 3.3V at CPUMiner. The H64 with everything the same doesn't throttle a bit. H64 System health while running cpuminer: Time CPU load %cpu %sys %usr %nice %io %irq Temp 13:53:23: 1800MHz 4.16 17% 1% 16% 0% 0% 0% 48.7°C 13:53:44: 1800MHz 4.35 99% 0% 99% 0% 0% 0% 68.7°C 13:54:06: 1800MHz 4.25 100% 0% 99% 0% 0% 0% 70.0°C 13:54:27: 1800MHz 4.26 100% 0% 99% 0% 0% 0% 70.6°C 13:54:49: 1800MHz 4.55 100% 0% 99% 0% 0% 0% 70.9°C 13:55:11: 1800MHz 4.73 100% 0% 99% 0% 0% 0% 71.2°C 13:55:32: 1800MHz 4.61 100% 0% 99% 0% 0% 0% 71.6°C 13:55:54: 1800MHz 4.56 100% 0% 99% 0% 0% 0% 71.6°C 13:56:16: 1800MHz 4.53 100% 0% 99% 0% 0% 0% 71.6°C 13:56:38: 1800MHz 4.51 100% 0% 99% 0% 0% 0% 71.7°C 13:56:59: 1800MHz 4.39 100% 0% 99% 0% 0% 0% 71.9°C 13:57:21: 1800MHz 4.48 100% 0% 99% 0% 0% 0% 71.8°C 13:57:43: 1800MHz 4.40 100% 0% 99% 0% 0% 0% 72.3°C 13:58:05: 1800MHz 4.32 100% 0% 99% 0% 0% 0% 71.8°C OPi3 Time CPU load %cpu %sys %usr %nice %io %irq Temp 00:08:38: 1800MHz 4.60 29% 1% 28% 0% 0% 0% 57.3°C 00:08:59: 1800MHz 4.50 99% 0% 99% 0% 0% 0% 74.3°C 00:09:21: 1800MHz 4.64 100% 0% 99% 0% 0% 0% 65.5°C 00:09:42: 1800MHz 4.46 100% 0% 99% 0% 0% 0% 70.7°C 00:10:04: 1800MHz 4.43 100% 0% 99% 0% 0% 0% 74.5°C 00:10:26: 1800MHz 4.31 100% 0% 99% 0% 0% 0% 75.1°C 00:10:47: 1800MHz 4.22 100% 0% 99% 0% 0% 0% 75.2°C 00:11:09: 1800MHz 4.26 100% 0% 99% 0% 0% 0% 74.7°C 00:11:31: 1800MHz 4.19 100% 0% 99% 0% 0% 0% 71.3°C 00:11:52: 1800MHz 4.13 100% 0% 99% 0% 0% 0% 71.2°C 00:12:14: 1800MHz 4.23 100% 0% 99% 0% 0% 0% 74.9°C 00:12:36: 1800MHz 4.16 100% 0% 99% 0% 0% 0% 65.7°C 00:12:57: 1800MHz 4.11 100% 0% 99% 0% 0% 0% 74.7°C 00:13:19: 1800MHz 4.25 100% 0% 99% 0% 0% 0% 74.8°C Frequency doesn't show it here, but it is throttling, but only a little.
TonyMac32 Posted April 5, 2019 Posted April 5, 2019 A couple possibilities, one is a better thermal coupling to the power plane, a thicker copper layer somewhere, or, if these run the thermal sensors like an H3, a difference in the Vref for the circuit. Do you have a temperature sensor you could use to compare the two with external measurements?Sent from my Pixel using Tapatalk
NicoD Posted April 5, 2019 Posted April 5, 2019 3 minutes ago, TonyMac32 said: A couple possibilities, one is a better thermal coupling to the power plane, a thicker copper layer somewhere, or, if these run the thermal sensors like an H3, a difference in the Vref for the circuit. Do you have a temperature sensor you could use to compare the two with external measurements? I'll see if I can use my Voltage meter it's thermometer by sticking it onto the heatsink. Don't think it's very scientific, but well
NicoD Posted April 5, 2019 Posted April 5, 2019 29 minutes ago, TonyMac32 said: Do you have a temperature sensor you could use to compare the two with external measurements? I've already learned that the heatsink heats up very slowly. Started at 35°C, always takes about 30seconds to rise a °C. Now at 50°C while the cpu is throttling from 75°C to 70°C. So a very small temperature difference in the heatsink makes for a large difference in the chip. Also takes longer to cool down than to heat up. (the heatsink that is) In the cooldown the temperature shown is almost the same as shown on my volt meter. 48°C on the H64, 47°C on the volt meter. And while it goes down, it also shows the same on the H64. I know my heatsink isn't very good, but it's the kind of heatsink everybody uses. It does show that the energy has trouble getting out of the chip. When you let the heatsink warm up to about 60°C then it will be in constant throttle mode. Can you do a SBC-bench now with your heatsink and without a fan? (I let it cool down, and started 7z b again, now again 50°C and throttling)Pictures here : Spoiler Cooldown after benchmark. 52°C on the meter, 53°C on the H64. During benchmark, 51°C on the heatsink, throttling at the chip. (here 73°C, but it jumps between 77°C and 70°C constantly. The hotter the heatsink the faster the frequency of throttling.
Dark26 Posted April 5, 2019 Posted April 5, 2019 Thanks a lot for the image. My little test : I try the debian desktop version in my rev A board. Boot just fine. when i try the last image from last year, problems appears for me : - Lan was block à 100 mbits - Usb3 not working - pci express is a joke - no graphical display In this version, - Usb3 works fine. it's a very good news but not with a usb3 hub. - Still the same for the lan, block at 100 mbits. But i think it's hardware problem, because with android image, i have only 100 mbits too. If i put a usb3 hub to have a usb 1000 mbits adaptateur, with a usb3 hard drive, then the performance shut down, like everything is in usb2. Too bad. But it's working. Thanks again for the great jobs. Dark26
NicoD Posted April 5, 2019 Posted April 5, 2019 8 minutes ago, Dark26 said: when i try the last image from last year, problems appears for me : Hi. That's a very old image. They are working on perfecting Armbian for the Pine H64 model B. Only on-board sound doesn't work. Otherwise it's very good. You can try these images.https://dl.armbian.com/pineh64/nightly/ They've been build last night. Should be a lot better than what you've tried now. Otherwise you can build your own image.https://docs.armbian.com/Developer-Guide_Build-Preparation/
Dark26 Posted April 5, 2019 Posted April 5, 2019 Just now, NicoD said: Hi. That's a very old image. They are working on perfecting Armbian for the Pine H64 model B. Only on-board sound doesn't work. Otherwise it's very good. You can try these images.https://dl.armbian.com/pineh64/nightly/ They've been build last night. Should be a lot better than what you've tried now. Otherwise you can build your own image.https://docs.armbian.com/Developer-Guide_Build-Preparation/ That's the one i try today.
NicoD Posted April 5, 2019 Posted April 5, 2019 6 minutes ago, Dark26 said: That's the one i try today. https://dl.armbian.com/pineh64/nightly/Armbian_5.77.190404_Pineh64_Debian_stretch_dev_5.0.5_desktop.7z That one? From 04/04/19? Sorry. I didn't completely read your post. I thought you had just tried the image of last year.
TonyMac32 Posted April 8, 2019 Posted April 8, 2019 On 4/5/2019 at 8:52 AM, NicoD said: indeed a bit strange 1.8Ghz 1.49Ghz https://github.com/armbian/build/commit/d11511ab2d1490a57c02e25a8eb324159de9ba79 So 1.8, 1.64, 1.49 1
NicoD Posted April 8, 2019 Posted April 8, 2019 15 hours ago, TonyMac32 said: So 1.8, 1.64, 1.49 Great job. It's a lot better at 1.64Ghz without a fan. For normal use this is perfect. Doesn't overheat quickly, and it's quite a bit faster than 1.5Ghz. It now also throttles to 1.5Ghz instead of 1.3Ghz. This seems fine. Even without a heatsink it's a lot better maxed out. It is faster without a heatsink/fan than 1.5Ghz, and it's faster than 1.8Ghz. And only when truly 100% maxed out it throttles. At 1.8Ghz even with only 1 core maxed it was throttling. When throttling it's always inbetween 72°C - 82°C. It's not going to 85°C, but I do think above 80°C it goes to 1.3Ghz since once it reaches 80°C it immediatly goes down to 72°C. But it will be only a very small time at 1.3Ghz since my monitors don't show it. I see you've kept the same voltage as 1.8Ghz. Can this be lowered to get an even better result? I also tried the OPi+2 with the H3. That one has improved a lot since I last tried it. It now clocks to 1.37Ghz. But still performs the worst of all my sbc's( a lot worse than other armhf's at the same clockspeed). It also throttles at 65°C to 1.1Ghz, but then the temperature keeps rising, so that can't be improved much this way. I wanted to know if HDMI sound really doesn't work on H3, it doesn't. 3.5mm audio jack is super quiet on it.
NicoD Posted April 9, 2019 Posted April 9, 2019 The answer is probably just no. My Pine H64 model B has got 4GB ram, but only 3GB is useable by the system. Is there any way of accessing that extra GB? Maybe for a ram disk to run the OS on. I think it will not have all the pins connected of the 2nd chip, but I don't know.
Stephen_m64 Posted April 9, 2019 Posted April 9, 2019 The memory controller for the h6 is 32 bits, 4gb may be there but only 3 will ever be usable. Which is why they are being sold as 2gb/3gb options. 2
renky Posted April 27, 2019 Posted April 27, 2019 https://youtu.be/HUsQaSZ0KhE?t=199 What is the significance of a battery connector? Does it make it easier to make a battery notebook which you can connect and disconnect a power supply unit to while notebook is running and charge while running? Free software is software you can use, share, modify and redistribute. Does the wifi work on free software? Quote ROCK64 4GB board designated as LTS This computer is not? Does the rock64 have a battery port? Thanks.
TonyMac32 Posted April 27, 2019 Posted April 27, 2019 To my knowledge it is for RTC, so not to power the unit. Sent from my Pixel using Tapatalk
martinayotte Posted April 27, 2019 Posted April 27, 2019 42 minutes ago, TonyMac32 said: To my knowledge it is for RTC, so not to power the unit. Right ! It is clear by looking at schematic. 47 minutes ago, renky said: Does the rock64 have a battery port? Nope !
NicoD Posted April 27, 2019 Posted April 27, 2019 2 hours ago, renky said: What is the significance of a battery connector? Does it make it easier to make a battery notebook which you can connect and disconnect a power supply unit to while notebook is running and charge while running? As they said. That's the real time clock connector(RTC). That's for a module with a battery that keeps the time. I should not have said battery connector. You can power the PineH64 with a power bank that can give stable 5V at 2A. I use the Odroid C2 as a laptop with huge powerbanks of 26 800 mAh and a 7" or a 13" display. I can use it while maxed out for about 10 hours. I've got 2 of those powerbanks. Some can be charged while in use. Mine can.
andrw Posted May 7, 2019 Posted May 7, 2019 Hi guys Sorry for a noob question, but I'm trying to boot latest nightly on this board and see nothing in UART. On the first page here it was mentioned that GND/TX/RX pins from EXT 6-pin connector should be used. Is that enough? I'm using CH340G USB-serial console from Pine store. 5V and 3.3V pins not connected. Tried both positions of S1 jumper on it. Image: Armbian_5.83.190502_Pineh64_Debian_stretch_dev_5.0.10_desktop, connecting from laptop by `minicom -D /dev/ttyUSB1 -o -w -c on -b 115200`
Igor Posted May 8, 2019 Posted May 8, 2019 9 hours ago, andrw said: but I'm trying to boot latest nightly on this board and see nothing in UART. To my knowing they are all broken. I was too late to salvage last known good working, but soon there will be new builds with K5.1.y ... which will probably work.
Igor Posted May 8, 2019 Posted May 8, 2019 5.1.y images are out, but untested.https://dl.armbian.com/orangepi3/nightly/ 1
andrw Posted May 10, 2019 Posted May 10, 2019 Will they be available for Pine H64 as well? Or OrangePi images are suitable for Pine too?
martinayotte Posted May 10, 2019 Posted May 10, 2019 4 hours ago, andrw said: Will they be available for Pine H64 as well? Or OrangePi images are suitable for Pine too? PineH64 should have their own nightly images, but it seems that build servers still sleeping there recent days ... @Igor ?
Igor Posted May 10, 2019 Posted May 10, 2019 44 minutes ago, martinayotte said: PineH64 should have their own nightly images, but it seems that build servers still sleeping there recent days ... Small maintenance. Later/perhaps tomorrow. This service doesn't have a backup ATM but its planned.
