Constantin Piffer Posted August 31, 2018 Share Posted August 31, 2018 2 minutes ago, Reddwarf said: Yes you could try that, it should boot but wifi would probably not work Mh... it doesn't work Link to comment Share on other sites More sharing options...
chpasha Posted August 31, 2018 Share Posted August 31, 2018 25 minutes ago, Constantin Piffer said: Thats the box I bought on Gearbest: https://www.gearbest.com/tv-box/pp_009445581349.html?wid=1433363 I hope that will help you. it is s905x, it should have gxl and/or p212 in name and 2gb as ram amount if there multiple dtb files for gxl_p212 Link to comment Share on other sites More sharing options...
lizzacore Posted August 31, 2018 Share Posted August 31, 2018 20 minutes ago, chpasha said: it is s905x, it should have gxl and/or p212 in name and 2gb as ram amount if there multiple dtb files for gxl_p212 Question, with this on my device i only get 3 Cores and 2 GB RAM. One core is missing. Should i Try other DTB-Files? Kind regards Link to comment Share on other sites More sharing options...
chpasha Posted August 31, 2018 Share Posted August 31, 2018 2 minutes ago, lizzacore said: Question, with this on my device i only get 3 Cores and 2 GB RAM. One core is missing. how do you know, that you have only 3? what the command lscpu shows? Link to comment Share on other sites More sharing options...
lizzacore Posted August 31, 2018 Share Posted August 31, 2018 Just now, chpasha said: how do you know, that you have only 3? what the command lscpu shows? I tried OMV and OMV says only 3 cores. I Install 5.59 after that i copy the right DTB. When the issue is still present i will send you some information about it. Kind regards, Link to comment Share on other sites More sharing options...
lizzacore Posted August 31, 2018 Share Posted August 31, 2018 41 minutes ago, lizzacore said: I tried OMV and OMV says only 3 cores. I Install 5.59 after that i copy the right DTB. When the issue is still present i will send you some information about it. Kind regards, Okay now i get this issue back. Systemload only shows 3 Cores: Welcome to ARMBIAN 5.59 user-built Debian GNU/Linux 9 (stretch) 4.18.0-aml-s9xxx System load: 0.47 0.46 0.19 Up time: 2 min Memory usage: 4 % of 1846MB IP: 192.168.178.33 CPU temp: 41°C Usage of /: 4% of 29G LSCpu says 4 cores (0-3): lscpu Architecture: aarch64 Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0-3 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Model: 4 Model name: ARMv8 Processor rev 4 (v8l) CPU max MHz: 2016.0000 CPU min MHz: 100.0000 BogoMIPS: 48.00 L1d cache: unknown size L1i cache: unknown size L2 cache: unknown size Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid mpstat -P ALL Linux 4.18.0-aml-s9xxx (aml) 08/31/2018 _aarch64_ (4 CPU) 07:37:09 PM CPU %usr %nice %sys %iowait %irq %soft %steal %guest %gnice %idle 07:37:09 PM all 7.73 0.03 2.96 6.23 0.00 0.01 0.00 0.00 0.00 83.05 07:37:09 PM 0 4.20 0.03 3.10 4.93 0.00 0.03 0.00 0.00 0.00 87.71 07:37:09 PM 1 6.46 0.03 2.62 6.08 0.00 0.00 0.00 0.00 0.00 84.81 07:37:09 PM 2 6.98 0.02 3.19 4.51 0.00 0.00 0.00 0.00 0.00 85.30 07:37:09 PM 3 13.24 0.03 2.91 9.37 0.00 0.00 0.00 0.00 0.00 74.45 Any idea? Kind regards Link to comment Share on other sites More sharing options...
chpasha Posted August 31, 2018 Share Posted August 31, 2018 1 hour ago, lizzacore said: Okay now i get this issue back. Any idea? install something like stress-ng and check if all 4 cores are working for instance with htop - or just run htop and wait, usually the load is distributed among all cores randomly even if system is idle - if they do work, who cares what system information is showing P. S. or just save your time - you do have 4 cores. I just looked at my s912 that has 8 cores and armbian shows the load for only 3 of them after login Link to comment Share on other sites More sharing options...
lizzacore Posted August 31, 2018 Share Posted August 31, 2018 30 minutes ago, chpasha said: install something like stress-ng and check if all 4 cores are working for instance with htop - or just run htop and wait, usually the load is distributed among all cores randomly even if system is idle - if the do work, who cares what system information is showing Works! Thanks! Link to comment Share on other sites More sharing options...
Constantin Piffer Posted August 31, 2018 Share Posted August 31, 2018 2 hours ago, chpasha said: it is s905x, it should have gxl and/or p212 in name and 2gb as ram amount if there multiple dtb files for gxl_p212 I tried that, but it doesn't work Link to comment Share on other sites More sharing options...
dbsharpe Posted August 31, 2018 Share Posted August 31, 2018 24 minutes ago, Constantin Piffer said: I tried that, but it doesn't work >it is s905x, it should have gxl and/or p212 in name and 2gb as ram amount if there multiple dtb files for gxl_p212 Try the troubleshooting tips I've put on this post: https://forum.armbian.com/topic/2419-armbian-for-amlogic-s905-and-s905x/?do=findComment&comment=58673 May be worth stepping back to an image with older kernel 3.14.xx to see if that works. Link to comment Share on other sites More sharing options...
Paco Martos Posted September 1, 2018 Share Posted September 1, 2018 (edited) First of all I wanted to thank all those who make this world possible. I'm not an expert in linux / kernel / coding and similar things I have been trying for several days to make tvheadend work in the decoder ferguson ariva 4k combo without any success. I have tried: armbian s905: debian / desktop 5.37 5.44 5.55 5.59 with different dtb.img several made it boot Only in 5.59 with meson-gxbb-nanopi-k2.dtb did the wifi work and none detected the dvbs2: I have also tried without success to add to the dtb the lines related to dvb of the original dtb file of the deco ls / dev / dvb ls: can not access '/ dev / dvb': No such file or directory root @ aml: ~ # lspci | grep Multimedia pcilib: Can not open / proc / bus / pci lspci: Can not find any working access method. root @ aml: ~ # dmesg | grep -i dvb root @ aml: ~ # dmesg | grep -i media [1.419062] media: Linux media interface: v0.10 [3.538397] Synopsys Designware Multimedia Card Interface Driver -libreelec / coreelec: I have tried it with different versions combining with different dtbs. Wi-Fi never worked though if it worked eth. dvbs2 is detected with gxbb-k1-plus.dtb. but it is impossible to tune anything. I am disappointed and I do not know if it will be possible to make it work. Can someone help me? More deco information: s905 1gb / 8gb tuner dvb s-s2 avl2011 dvb t-t2 avl6762 (I only need dvb S s2 working, dvbt isnt important for me) Im looking to upload the original dtb file from deco but i dont see how to do it, so i put on the spoiler the dts content Spoiler /dts-v1/; / { model = "Amlogic"; compatible = "amlogic, Gxbb"; interrupt-parent = <0x1>; #address-cells = <0x2>; #size-cells = <0x2>; cpus { #address-cells = <0x2>; #size-cells = <0x0>; cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x0>; enable-method = "psci"; timer = <0x2>; }; cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x1>; enable-method = "psci"; timer = <0x3>; }; cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x2>; enable-method = "psci"; timer = <0x4>; }; cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a53", "arm,armv8"; reg = <0x0 0x3>; enable-method = "psci"; timer = <0x5>; }; }; timer { compatible = "arm, meson-timer"; #address-cells = <0x2>; #size-cells = <0x2>; ranges; reg = <0x0 0xc1109990 0x0 0x4 0x0 0xc1109988 0x0 0x4>; timer-f { timer_name = "MESON TIMER-F"; clockevent-rating = <0x12c>; clockevent-shift = <0x14>; clockevent-features = <0x3>; interrupts = <0x0 0x3c 0x1>; bit_enable = <0x10>; bit_mode = <0xc>; bit_resolution = <0x0>; reg = <0x0 0xc1109994 0x0 0x4>; linux,phandle = <0x2>; phandle = <0x2>; }; timer-g { timer_name = "MESON TIMER-G"; clockevent-rating = <0x12c>; clockevent-shift = <0x14>; clockevent-features = <0x3>; interrupts = <0x0 0x3d 0x1>; bit_enable = <0x11>; bit_mode = <0xd>; bit_resolution = <0x2>; reg = <0x0 0xc1109998 0x0 0x4>; linux,phandle = <0x3>; phandle = <0x3>; }; timer-h { timer_name = "MESON TIMER-H"; clockevent-rating = <0x12c>; clockevent-shift = <0x14>; clockevent-features = <0x3>; interrupts = <0x0 0x3e 0x1>; bit_enable = <0x12>; bit_mode = <0xe>; bit_resolution = <0x4>; reg = <0x0 0xc110999c 0x0 0x4>; linux,phandle = <0x4>; phandle = <0x4>; }; timer-i { timer_name = "MESON TIMER-I"; clockevent-rating = <0x12c>; clockevent-shift = <0x14>; clockevent-features = <0x3>; interrupts = <0x0 0x3f 0x1>; bit_enable = <0x13>; bit_mode = <0xf>; bit_resolution = <0x6>; reg = <0x0 0xc11099a0 0x0 0x4>; linux,phandle = <0x5>; phandle = <0x5>; }; }; arm_pmu { compatible = "arm,armv8-pmuv3"; interrupts = <0x0 0x89 0x4 0x0 0x8a 0x4 0x0 0x99 0x4 0x0 0x9a 0x4>; }; pm { compatible = "amlogic, pm"; device_name = "aml_pm"; gxbaby-suspend; reg = <0x0 0xc81000a8 0x0 0x4 0x0 0xc810023c 0x0 0x4>; }; mali@d00c0000 { compatible = "arm,mali-450"; interrupt-parent = <0x1>; reg = <0x0 0xd00c0000 0x0 0x40000 0x0 0xc883c000 0x0 0x4 0x0 0xc8100000 0x0 0x4>; interrupts = <0x0 0xa0 0x4 0x0 0xa1 0x4 0x0 0xa2 0x4 0x0 0xa3 0x4 0x0 0xa4 0x4 0x0 0xa5 0x4 0x0 0xa6 0x4 0x0 0xa7 0x4 0x0 0xa8 0x4 0x0 0xa9 0x4>; interrupt-names = "IRQGP", "IRQGPMMU", "IRQPP", "IRQPMU", "IRQPP0", "IRQPPMMU0", "IRQPP1", "IRQPPMMU1", "IRQPP2", "IRQPPMMU2"; pmu_domain_config = <0x1 0x2 0x4 0x4 0x0 0x0 0x0 0x0 0x0 0x1 0x2 0x0>; pmu_switch_delay = <0xffff>; num_of_pp = <0x3>; def_clock = <0x3>; sc_mpp = <0x3>; tbl = <0x6 0x7 0x8 0x9 0xa 0xb>; clocks = <0xc 0x8 0xc 0x9 0xc 0x11 0xc 0x12 0xc 0x1e 0xc 0x15 0xc 0x13 0xc 0x14>; clock-names = "fclk_div3", "fclk_div4", "fclk_div5", "fclk_div7", "gp0_pll", "clk_mali", "clk_mali_0", "clk_mali_1"; control_interval = <0xc8>; dvfs_tbl = <0xd>; clk125_cfg { clk_freq = <0x7735940>; clk_parent = "fclk_div4"; clkp_freq = <0x1dcd6500>; voltage = <0x47e>; keep_count = <0x5>; threshold = <0x1e 0x78>; linux,phandle = <0x6>; phandle = <0x6>; }; clk250_cfg { clk_freq = <0xee6b280>; clk_parent = "fclk_div4"; clkp_freq = <0x1dcd6500>; voltage = <0x47e>; keep_count = <0x5>; threshold = <0x50 0xaa>; }; clk285_cfg { clk_freq = <0x10fcc140>; clk_parent = "fclk_div7"; clkp_freq = <0x10fcc140>; voltage = <0x47e>; keep_count = <0x5>; threshold = <0x64 0xbe>; linux,phandle = <0x7>; phandle = <0x7>; }; clk400_cfg { clk_freq = <0x17d78400>; clk_parent = "fclk_div5"; clkp_freq = <0x17d78400>; voltage = <0x47e>; keep_count = <0x5>; threshold = <0x98 0xcf>; linux,phandle = <0x8>; phandle = <0x8>; }; clk500_cfg { clk_freq = <0x1dcd6500>; clk_parent = "fclk_div4"; clkp_freq = <0x1dcd6500>; voltage = <0x47e>; keep_count = <0x5>; threshold = <0xb4 0xdc>; linux,phandle = <0x9>; phandle = <0x9>; }; clk666_cfg { clk_freq = <0x27b25a80>; clk_parent = "fclk_div3"; clkp_freq = <0x27b25a80>; voltage = <0x47e>; keep_count = <0x5>; threshold = <0xd2 0xec>; linux,phandle = <0xa>; phandle = <0xa>; }; clk800_cfg { clk_freq = <0x2f34f600>; clk_parent = "gp0_pll"; clkp_freq = <0x2f34f600>; voltage = <0x47e>; keep_count = <0x5>; threshold = <0xe6 0xff>; linux,phandle = <0xb>; phandle = <0xb>; }; }; interrupt-controller@2c001000 { compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic"; #interrupt-cells = <0x3>; #address-cells = <0x0>; interrupt-controller; reg = <0x0 0xc4301000 0x0 0x1000 0x0 0xc4302000 0x0 0x100>; interrupts = <0x1 0x9 0xf04>; linux,phandle = <0x1>; phandle = <0x1>; }; aml_restart { compatible = "aml, restart"; sys_reset = <0x84000009>; sys_poweroff = <0x84000008>; }; psci { compatible = "arm,psci"; method = "smc"; cpu_suspend = <0xc4000001>; cpu_off = <0x84000002>; cpu_on = <0xc4000003>; migrate = <0xc4000005>; }; secmon { compatible = "aml,secmon"; memory-region = <0xe>; in_base_func = <0x82000020>; out_base_func = <0x82000021>; }; secos { compatible = "aml,secos"; memory-region = <0xf>; }; securitykey { compatible = "aml, securitykey"; storage_query = <0x82000060>; storage_read = <0x82000061>; storage_write = <0x82000062>; storage_tell = <0x82000063>; storage_verify = <0x82000064>; storage_status = <0x82000065>; storage_list = <0x82000067>; storage_remove = <0x82000068>; storage_in_func = <0x82000023>; storage_out_func = <0x82000024>; storage_block_func = <0x82000025>; storage_size_func = <0x82000027>; }; cpu_iomap { compatible = "amlogic,iomap"; #address-cells = <0x2>; #size-cells = <0x2>; ranges; io_cbus_base { reg = <0x0 0xc1100000 0x0 0x100000>; }; io_apb_base { reg = <0x0 0xd0000000 0x0 0x200000>; }; io_aobus_base { reg = <0x0 0xc8100000 0x0 0x100000>; }; }; cpufreq-meson { compatible = "amlogic, cpufreq-scpi"; status = "okay"; clocks = <0x10 0x0>; clock-names = "cpu_clk"; }; amlogic-watchdog { compatible = "amlogic, gx-wdt"; status = "disable"; default_timeout = <0xa>; reset_watchdog_method = <0x1>; reset_watchdog_time = <0x2>; shutdown_timeout = <0xa>; firmware_timeout = <0x6>; suspend_timeout = <0x6>; reg = <0x0 0xc11098d0 0x0 0x10>; clocks = <0xc 0x2>; }; meson_clock { compatible = "amlogic, gxbb-clock"; reg = <0x0 0xc883c000 0x0 0x1000 0x0 0xc8100000 0x0 0x1000>; #clock-cells = <0x1>; #reset-cells = <0x1>; sys_max = <0x5b8d8000>; linux,phandle = <0xc>; phandle = <0xc>; }; pinmux { compatible = "amlogic, pinmux-gxbb"; dev_name = "pinmux"; #pinmux-cells = <0x2>; #address-cells = <0x2>; #size-cells = <0x2>; reg = <0x0 0xc1109880 0x0 0x10>; ranges; banks@c11080b0 { reg = <0x0 0xc88344b0 0x0 0x28 0x0 0xc88344e8 0x0 0x14 0x0 0xc8834120 0x0 0x14 0x0 0xc8834430 0x0 0x40>; reg-names = "mux", "pull", "pull-enable", "gpio"; gpio-controller; #gpio-cells = <0x2>; linux,phandle = <0x20>; phandle = <0x20>; }; ao-bank@c1108030 { reg = <0x0 0xc8100014 0x0 0x8 0x0 0xc810002c 0x0 0x4 0x0 0xc8100024 0x0 0x8>; reg-names = "mux", "pull", "gpio"; gpio-controller; #gpio-cells = <0x2>; linux,phandle = <0x69>; phandle = <0x69>; }; eth_pins { amlogic,setmask = <0x6 0x3dfb>; amlogic,clrmask = <0x6 0xc000 0x5 0x3c0000f0 0x4 0x300>; amlogic,pins = "GPIOZ_0", "GPIOZ_1", "GPIOZ_2", "GPIOZ_3", "GPIOZ_4", "GPIOZ_5", "GPIOZ_9", "GPIOZ_10", "GPIOZ_11", "GPIOZ_15"; linux,phandle = <0x1f>; phandle = <0x1f>; }; remote_pin { amlogic,setmask = <0x10 0x1>; amlogic,pins = "GPIOAO_7"; linux,phandle = <0x1b>; phandle = <0x1b>; }; ao_uart { amlogic,setmask = <0x10 0x1800>; amlogic,pins = "GPIOAO_0", "GPIOAO_1"; }; ao_b_uart { amlogic,setmask = <0x10 0x1800000>; amlogic,pins = "GPIOAO_4", "GPIOAO_5"; }; a_uart { amlogic,setmask = <0x4 0x3c00>; amlogic,pins = "GPIOX_12", "GPIOX_13", "GPIOX_14", "GPIOX_15"; linux,phandle = <0x57>; phandle = <0x57>; }; b_uart { amlogic,setmask = <0x2 0x30000000>; amlogic,pins = "GPIODV_24", "GPIODV_25"; }; c_uart { amlogic,setmask = <0x1 0xc0000>; amlogic,pins = "GPIOY_13", "GPIOY_14"; linux,phandle = <0x58>; phandle = <0x58>; }; wifi_32k_pins { amlogic,setmask = <0x2 0x40000000>; amlogic,clrmask = <0x2 0x400000 0x3 0x8000>; amlogic,pins = "GPIOX_19"; linux,phandle = <0x24>; phandle = <0x24>; }; sd_clk_cmd_pins { amlogic,setmask = <0x2 0xc00 0x10 0x1800>; amlogic,pins = "CARD_2", "CARD_3"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x25>; phandle = <0x25>; }; sd_all_pins { amlogic,setmask = <0x2 0xfc00 0x10 0x1800>; amlogic,pins = "CARD_0", "CARD_1", "CARD_2", "CARD_3", "CARD_4", "CARD_5"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x26>; phandle = <0x26>; }; sd_1bit_pins { amlogic,setmask = <0x2 0x8c00 0x10 0x1800>; amlogic,pins = "CARD_1", "CARD_2", "CARD_3"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x27>; phandle = <0x27>; }; sd_clk_cmd_uart_pins { amlogic,setmask = <0x2 0xc00 0x8 0x600>; amlogic,pins = "CARD_2", "CARD_3"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x28>; phandle = <0x28>; }; sd_1bit_uart_pins { amlogic,setmask = <0x2 0x8c00 0x8 0x600>; amlogic,pins = "CARD_1", "CARD_2", "CARD_3"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x29>; phandle = <0x29>; }; sd_to_ao_uart_pins { amlogic,setmask = <0x10 0x1800>; amlogic,clrmask = <0x8 0x600>; amlogic,pins = "GPIOAO_0", "GPIOAO_1"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x2a>; phandle = <0x2a>; }; ao_to_sd_uart_pins { amlogic,setmask = <0x8 0x600>; amlogic,clrmask = <0x10 0x1800 0x2 0x3000>; amlogic,pins = "CARD_4", "CARD_5"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x2b>; phandle = <0x2b>; }; emmc_clk_cmd_pins { amlogic,setmask = <0x4 0xc00c0000>; amlogic,pins = "BOOT_8", "BOOT_10"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x2c>; phandle = <0x2c>; }; emmc_all_pins { amlogic,setmask = <0x4 0xc00c0000>; amlogic,pins = "BOOT_0", "BOOT_1", "BOOT_2", "BOOT_3", "BOOT_4", "BOOT_5", "BOOT_6", "BOOT_7", "BOOT_8", "BOOT_10"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x2d>; phandle = <0x2d>; }; sdio_clk_cmd_pins { amlogic,setmask = <0x8 0x3>; amlogic,pins = "GPIOX_4", "GPIOX_5"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x2e>; phandle = <0x2e>; }; sdio_all_pins { amlogic,setmask = <0x8 0x3f>; amlogic,pins = "GPIOX_0", "GPIOX_1", "GPIOX_2", "GPIOX_3", "GPIOX_4", "GPIOX_5"; amlogic,enable-output = <0x1>; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x2f>; phandle = <0x2f>; }; conf_nand_pulldown { amlogic,pins = "BOOT_0", "BOOT_1", "BOOT_2", "BOOT_3", "BOOT_4", "BOOT_5", "BOOT_6", "BOOT_7", "BOOT_15"; amlogic,pullup = <0x0>; amlogic,pullupen = <0x1>; linux,phandle = <0x30>; phandle = <0x30>; }; conf_nand_pullup { amlogic,pins = "BOOT_8", "BOOT_10"; amlogic,pullup = <0x1>; amlogic,pullupen = <0x1>; linux,phandle = <0x31>; phandle = <0x31>; }; all_nand_pins { amlogic,setmask = <0x4 0x7ff00000>; amlogic,clrmask = <0x0 0x80000 0x4 0x800c0000 0x5 0xf>; amlogic,pins = "BOOT_0", "BOOT_1", "BOOT_2", "BOOT_3", "BOOT_4", "BOOT_5", "BOOT_6", "BOOT_7", "BOOT_8", "BOOT_9", "BOOT_10", "BOOT_11", "BOOT_12", "BOOT_13", "BOOT_14", "BOOT_15", "BOOT_16", "BOOT_17"; amlogic,enable-output = <0x1>; linux,phandle = <0x32>; phandle = <0x32>; }; nand_cs { amlogic,setmask = <0x4 0xc000000>; amlogic,clrmask = <0x4 0x40000>; amlogic,pins = "BOOT_8", "BOOT_9"; linux,phandle = <0x33>; phandle = <0x33>; }; hdmitx_hpd { amlogic,setmask = <0x1 0x4000000>; amlogic,pins = "GPIOH_0"; linux,phandle = <0x53>; phandle = <0x53>; }; hdmitx_ddc { amlogic,setmask = <0x1 0x3000000>; amlogic,pins = "GPIOH_1", "GPIOH_2"; linux,phandle = <0x54>; phandle = <0x54>; }; hdmitx_aocec { amlogic,setmask = <0x10 0x8000>; amlogic,clrmask = <0x10 0x24000 0x11 0x1>; amlogic,pins = "GPIOAO_12"; linux,phandle = <0x56>; phandle = <0x56>; }; hdmitx_eecec { amlogic,setmask = <0x10 0x4000>; amlogic,clrmask = <0x10 0x28000 0x11 0x1>; amlogic,pins = "GPIOAO_12"; }; a_i2c { amlogic,setmask = <0x7 0xc000000>; amlogic,clrmask = <0x0 0x18c0 0x2 0x30000000 0x5 0x1800>; amlogic,pins = "GPIODV_24", "GPIODV_25"; linux,phandle = <0x11>; phandle = <0x11>; }; b_i2c { amlogic,setmask = <0x7 0x3000000>; amlogic,clrmask = <0x0 0x600 0x2 0xc000000 0x5 0x700>; amlogic,pins = "GPIODV_26", "GPIODV_27"; linux,phandle = <0x12>; phandle = <0x12>; }; c_i2c { amlogic,setmask = <0x7 0xc00000>; amlogic,clrmask = <0x3 0x700000>; amlogic,pins = "GPIODV_28", "GPIODV_29"; linux,phandle = <0x13>; phandle = <0x13>; }; d_i2c { amlogic,setmask = <0x4 0xc>; amlogic,clrmask = <0x2 0x3000000 0x3 0x1000>; amlogic,pins = "GPIOX_16", "GPIOX_17"; linux,phandle = <0x14>; phandle = <0x14>; }; dvb_p_ts0_pins { amlogic,setmask = <0x3 0x37>; amlogic,clrmask = <0x2 0xf0000 0x1 0x30ff>; amlogic,pins = "GPIOY_0", "GPIOY_1", "GPIOY_2", "GPIOY_3", "GPIOY_4", "GPIOY_5", "GPIOY_6", "GPIOY_7", "GPIOY_8", "GPIOY_9", "GPIOY_10"; }; dvb_s_ts0_pins { amlogic,setmask = <0x3 0x797>; amlogic,clrmask = <0x1 0x7 0x2 0xf0000 0x3 0x60060000 0x4 0xc0 0x8 0x800>; amlogic,pins = "GPIOY_0", "GPIOY_1", "GPIOY_2", "GPIOY_3"; linux,phandle = <0x6a>; phandle = <0x6a>; }; audio_pin { amlogic,setmask = <0x10 0x78000000>; amlogic,clrmask = <0x10 0x40000>; amlogic,pins = "GPIOAO_8", "GPIOAO_9", "GPIOAO_10", "GPIOAO_11"; linux,phandle = <0x5a>; phandle = <0x5a>; }; audio_pin1 { amlogic,setmask = <0x1 0x200>; amlogic,clrmask = <0x1 0x10000>; amlogic,pins = "GPIOY_12"; linux,phandle = <0x59>; phandle = <0x59>; }; dvb_s_ts1_pins { amlogic,setmask = <0x3 0x797>; amlogic,clrmask = <0x1 0x7 0x2 0xf0000 0x3 0x60060000 0x4 0xc0 0x8 0x800>; amlogic,pins = "GPIOY_0", "GPIOY_1", "GPIOY_2", "GPIOY_3", "GPIOX_6", "GPIOX_7", "GPIOX_8", "GPIOX_9"; linux,phandle = <0x6b>; phandle = <0x6b>; }; smc_pins { amlogic,setmask = <0x1 0x3000>; amlogic,clrmask = <0x2 0x10000 0x3 0x20>; amlogic,pins = "GPIOY_4", "GPIOY_5"; linux,phandle = <0x6c>; phandle = <0x6c>; }; }; cpu_version { reg = <0x0 0xc8100220 0x0 0x4>; }; meson_clk_msr { compatible = "amlogic, gxbb_measure"; reg = <0x0 0xc110875c 0x0 0x4 0x0 0xc1108764 0x0 0x4>; }; i2c@c1108500 { compatible = "amlogic, meson-i2c"; dev_name = "i2c-A"; status = "okay"; reg = <0x0 0xc1108500 0x0 0x20>; device_id = <0x1>; pinctrl-names = "default"; pinctrl-0 = <0x11>; #address-cells = <0x1>; #size-cells = <0x0>; use_pio = <0x0>; master_i2c_speed = <0x493e0>; clocks = <0xc 0xa>; clock-names = "clk_i2c"; resets = <0xc 0x9>; }; i2c@c11087c0 { compatible = "amlogic, meson-i2c"; dev_name = "i2c-B"; status = "okay"; reg = <0x0 0xc11087c0 0x0 0x20>; device_id = <0x2>; pinctrl-names = "default"; pinctrl-0 = <0x12>; #address-cells = <0x1>; #size-cells = <0x0>; use_pio = <0x0>; master_i2c_speed = <0x493e0>; clocks = <0xc 0xa>; clock-names = "clk_i2c"; resets = <0xc 0x9>; }; i2c@c11087e0 { compatible = "amlogic, meson-i2c"; dev_name = "i2c-C"; status = "disabled"; reg = <0x0 0xc11087e0 0x0 0x20>; device_id = <0x3>; pinctrl-names = "default"; pinctrl-0 = <0x13>; #address-cells = <0x1>; #size-cells = <0x0>; use_pio = <0x0>; master_i2c_speed = <0x493e0>; clocks = <0xc 0xa>; clock-names = "clk_i2c"; resets = <0xc 0x9>; }; i2c@c1108d20 { compatible = "amlogic, meson-i2c"; dev_name = "i2c-D"; status = "disabled"; reg = <0x0 0xc1108d20 0x0 0x20>; device_id = <0x4>; pinctrl-names = "default"; pinctrl-0 = <0x14>; #address-cells = <0x1>; #size-cells = <0x0>; use_pio = <0x0>; master_i2c_speed = <0x493e0>; clocks = <0xc 0xa>; clock-names = "clk_i2c"; resets = <0xc 0x9>; }; efuse { compatible = "amlogic, efuse"; read_cmd = <0x82000030>; write_cmd = <0x82000031>; get_max_cmd = <0x82000033>; key = <0x15>; resets = <0xc 0x3e>; reset-names = "efuse_clk"; status = "okay"; }; efusekey { keynum = <0x4>; key0 = <0x16>; key1 = <0x17>; key2 = <0x18>; key3 = <0x19>; linux,phandle = <0x15>; phandle = <0x15>; key0 { keyname = "mac"; offset = <0x0>; size = <0x6>; linux,phandle = <0x16>; phandle = <0x16>; }; key1 { keyname = "mac_bt"; offset = <0x6>; size = <0x6>; linux,phandle = <0x17>; phandle = <0x17>; }; key2 { keyname = "mac_wifi"; offset = <0xc>; size = <0x6>; linux,phandle = <0x18>; phandle = <0x18>; }; key3 { keyname = "usid"; offset = <0x12>; size = <0x10>; linux,phandle = <0x19>; phandle = <0x19>; }; }; mhu@c883c400 { compatible = "amlogic, meson_mhu"; reg = <0x0 0xc883c400 0x0 0x4c 0x0 0xc8013000 0x0 0x800>; interrupts = <0x0 0xd1 0x8 0x0 0xd2 0x8>; #mbox-cells = <0x1>; mbox-names = "cpu_to_scp_low", "cpu_to_scp_high"; mboxes = <0x1a 0x0 0x1a 0x1>; linux,phandle = <0x1a>; phandle = <0x1a>; }; scpi_clocks { compatible = "arm,scpi-clks"; scpi_clocks@0 { compatible = "arm,scpi-clk-indexed"; #clock-cells = <0x1>; clock-indices = <0x0>; clock-output-names = "vcpu"; linux,phandle = <0x10>; phandle = <0x10>; }; }; meson-remote { compatible = "amlogic, aml_remote"; dev_name = "meson-remote"; status = "disable"; remote_ao_offset = <0x580>; interrupts = <0x0 0xc4 0x1>; pinctrl-names = "default"; pinctrl-0 = <0x1b>; }; encryption_chip { compatible = "amlogic,aml_encryption"; dev_name = "encryption_chip"; i2c_num = <0x1>; status = "okay"; }; sen5-remote { compatible = "sen5, sen5_remote"; dev_name = "sen5-remote"; status = "ok"; remote_ao_offset = <0x580>; interrupts = <0x0 0xc4 0x1>; pinctrl-names = "default"; pinctrl-0 = <0x1b>; }; rng { compatible = "amlogic,meson-rng"; reg = <0x0 0xc8834000 0x0 0x4>; }; audio_data { compatible = "amlogic, audio_data"; query_licence_cmd = <0x82000050>; status = "okay"; }; saradc { compatible = "amlogic, saradc"; status = "okay"; interrupts = <0x0 0x9 0x1>; interrupt-names = "saradc_int"; clocks = <0xc 0x2>; clock-names = "saradc_clk"; resets = <0xc 0x56>; reg = <0x0 0xc1108680 0x0 0x30 0x0 0xc883c3d8 0x0 0x8>; }; aliases { serial0 = "/serial@c81004c0"; serial1 = "/serial@c11084c0"; serial3 = "/serial@c1108700"; }; gpu_dvfs_tbl { sc_mpp = <0x3>; tbl = <0x7 0x8 0x9 0xa 0xb>; linux,phandle = <0xd>; phandle = <0xd>; }; memory@00000000 { device_type = "memory"; linux,usable-memory = <0x0 0x1000000 0x0 0x3f000000>; }; reserved-memory { #address-cells = <0x2>; #size-cells = <0x2>; ranges; linux,secmon { compatible = "aml_secmon_memory"; reg = <0x0 0x10000000 0x0 0x200000>; no-map; linux,phandle = <0xe>; phandle = <0xe>; }; linux,secos { compatible = "amlogic, secos_memory"; reg = <0x0 0x5300000 0x0 0x2000000>; no-map; linux,phandle = <0xf>; phandle = <0xf>; }; aml_pstore { compatible = "amlogic, pstore"; reg = <0x0 0x20000000 0x0 0x100000>; no-map; }; linux,meson-fb { compatible = "amlogic, fb-memory"; size = <0x0 0x2000000>; no-map; linux,phandle = <0x1c>; phandle = <0x1c>; }; linux,di { compatible = "amlogic, di-mem"; size = <0x0 0x1e00000>; multi-use; linux,phandle = <0x23>; phandle = <0x23>; }; linux,ion-dev { compatible = "amlogic, idev-mem"; size = <0x0 0x2000000>; multi-use; linux,phandle = <0x21>; phandle = <0x21>; }; linux,codec_mm_cma { compatible = "shared-dma-pool"; reusable; size = <0x0 0xf800000>; alignment = <0x0 0x400000>; linux,contiguous-region; linux,phandle = <0x1d>; phandle = <0x1d>; }; linux,picdec { compatible = "shared-dma-pool"; reusable; size = <0x0 0x3000000>; alignment = <0x0 0x400000>; linux,contiguous-region; linux,phandle = <0x22>; phandle = <0x22>; }; linux,codec_mm_reserved { compatible = "amlogic, codec-mm-reserved"; size = <0x0 0x4100000>; alignment = <0x0 0x100000>; linux,phandle = <0x1e>; phandle = <0x1e>; }; }; meson-vout { compatible = "amlogic, meson-vout"; dev_name = "meson-vout"; status = "okay"; }; meson-fb { compatible = "amlogic, meson-fb"; memory-region = <0x1c>; dev_name = "meson-fb"; status = "okay"; interrupts = <0x0 0x3 0x1 0x0 0x59 0x1>; interrupt-names = "viu-vsync", "rdma"; mem_size = <0x1800000 0x100000>; vmode = <0x3>; scale_mode = <0x1>; display_size_default = <0x780 0x438 0x780 0xca8 0x20>; }; ge2d { compatible = "amlogic, ge2d"; dev_name = "ge2d"; status = "okay"; interrupts = <0x0 0x96 0x1>; interrupt-names = "ge2d"; clocks = <0xc 0x17 0xc 0x19>; clock-names = "clk_vapb_0", "clk_ge2d"; resets = <0xc 0x34>; reset-names = "ge2d"; }; codec_io { compatible = "amlogic, codec_io"; #address-cells = <0x2>; #size-cells = <0x2>; ranges; io_cbus_base { reg = <0x0 0xc1100000 0x0 0x100000>; }; io_dos_base { reg = <0x0 0xc8820000 0x0 0x10000>; }; io_hiubus_base { reg = <0x0 0xc883c000 0x0 0x2000>; }; io_aobus_base { reg = <0x0 0xc8100000 0x0 0x100000>; }; io_vcbus_base { reg = <0x0 0xd0100000 0x0 0x40000>; }; io_dmc_base { reg = <0x0 0xc8838000 0x0 0x400>; }; }; codec_mm { compatible = "amlogic, codec, mm"; memory-region = <0x1d 0x1e>; dev_name = "codec_mm"; status = "okay"; }; ethernet@0xc9410000 { compatible = "amlogic, gxbb-rmii-dwmac"; reg = <0x0 0xc9410000 0x0 0x10000 0x0 0xc8834540 0x0 0x8>; interrupts = <0x0 0x8 0x1>; phy-mode = "rmii"; pinctrl-names = "eth_pins"; pinctrl-0 = <0x1f>; rst_pin-gpios = <0x20 0xe 0x0>; mc_val = <0x1800>; resets = <0xc 0x23>; reset-names = "ethpower"; interrupt-names = "macirq"; clocks = <0xc 0xa>; clock-names = "ethclk81"; }; mesonstream { compatible = "amlogic, codec, streambuf"; dev_name = "mesonstream"; status = "okay"; resets = <0xc 0x39 0xc 0x59 0xc 0x24 0xc 0x1>; reset-names = "parser_top", "vpu_intr", "demux", "vdec"; }; amvideocap { compatible = "amlogic, amvideocap"; dev_name = "amvideocap.0"; status = "okay"; }; ion_dev { compatible = "amlogic, ion_dev"; memory-region = <0x21>; }; vdec { compatible = "amlogic, vdec"; dev_name = "vdec.0"; status = "okay"; interrupts = <0x0 0x3 0x1 0x0 0x17 0x1 0x0 0x20 0x1 0x0 0x2b 0x1 0x0 0x2c 0x1 0x0 0x2d 0x1>; interrupt-names = "vsync", "demux", "parser", "mailbox_0", "mailbox_1", "mailbox_2"; }; picdec { compatible = "amlogic, picdec"; memory-region = <0x22>; dev_name = "picdec"; status = "okay"; }; ppmgr { compatible = "amlogic, ppmgr"; memory-region = <0x21>; dev_name = "ppmgr"; status = "okay"; }; deinterlace { compatible = "amlogic, deinterlace"; status = "okay"; memory-region = <0x23>; interrupts = <0x0 0x2e 0x1 0x0 0x6 0x1>; interrupt-names = "de_irq", "timerc"; buffer-size = <0x2fd000>; hw-version = <0x2>; }; amvdec_656in0 { compatible = "amlogic, amvdec_656in"; dev_name = "amvdec_656in0"; status = "ok"; reg = <0x0 0xd0048000 0x0 0x7c>; clocks = <0xc 0x7 0xc 0x26>; clock-names = "fclk_div2", "cts_bt656_clk0"; bt656_id = <0x0>; }; amvdec_656in1 { compatible = "amlogic, amvdec_656in"; dev_name = "amvdec_656in1"; status = "ok"; reg = <0x0 0xd0050000 0x0 0x7c>; clocks = <0xc 0x7 0xc 0x27>; clock-names = "fclk_div2", "cts_bt656_clk1"; bt656_id = <0x1>; }; amvenc_avc { compatible = "amlogic, amvenc_avc"; dev_name = "amvenc_avc"; status = "okay"; interrupts = <0x0 0x2d 0x1>; interrupt-names = "mailbox_2"; }; vpu { compatible = "amlogic, vpu"; dev_name = "vpu"; status = "ok"; clk_level = <0x7>; }; bt-dev { compatible = "amlogic, bt-dev"; dev_name = "bt-dev"; status = "ok"; gpio_reset = <0x20 0x70 0x0>; }; rtc { compatible = "amlogic, aml_vrtc"; alarm_reg_addr = <0xc81000a8>; timer_e_addr = <0xc1109988>; init_date = "2015/01/01"; status = "okay"; }; wifi { compatible = "amlogic, aml_broadcm_wifi"; dev_name = "aml_broadcm_wifi"; status = "okay"; interrupt_pin = <0x20 0x66 0x0>; interrupts = <0x0 0x44 0x4>; irq_trigger_type = "GPIO_IRQ_LOW"; power_on_pin = <0x20 0x67 0x0>; dhd_static_buf; pinctrl-names = "wifi_32k_pins"; pinctrl-0 = <0x24>; }; wifi_power { compatible = "amlogic, wifi_power"; dev_name = "wifi_power"; status = "okay"; power_gpio = <0x20 0x67 0x0>; }; sd { compatible = "amlogic, aml_sd_emmc"; dev_name = "aml_newsd.0"; status = "okay"; reg = <0x0 0xd0072000 0x0 0x2000>; interrupts = <0x0 0xd9 0x1 0x0 0x43 0x1 0x0 0x45 0x1>; pinctrl-names = "sd_clk_cmd_pins", "sd_all_pins", "sd_1bit_pins", "sd_clk_cmd_uart_pins", "sd_1bit_uart_pins", "sd_to_ao_uart_pins", "ao_to_sd_uart_pins"; pinctrl-0 = <0x25>; pinctrl-1 = <0x26>; pinctrl-2 = <0x27>; pinctrl-3 = <0x28>; pinctrl-4 = <0x29>; pinctrl-5 = <0x2a>; pinctrl-6 = <0x2b>; sd { status = "okay"; port = <0x1>; pinname = "sd"; ocr_avail = <0x200080>; caps = "MMC_CAP_4_BIT_DATA", "MMC_CAP_MMC_HIGHSPEED", "MMC_CAP_SD_HIGHSPEED"; f_min = <0x61a80>; f_max = <0x17d7840>; max_req_size = <0x20000>; gpio_dat3 = <0x20 0x2a 0x0>; jtag_pin = <0x20 0x26 0x0>; gpio_cd = <0x20 0x2c 0x0>; irq_in = <0x3>; irq_out = <0x5>; card_type = <0x5>; }; }; emmc { compatible = "amlogic, aml_sd_emmc"; dev_name = "aml_newsd.0"; status = "okay"; reg = <0x0 0xd0074000 0x0 0x2000>; interrupts = <0x0 0xda 0x1>; pinctrl-names = "emmc_clk_cmd_pins", "emmc_all_pins"; pinctrl-0 = <0x2c>; pinctrl-1 = <0x2d>; emmc { status = "okay"; pinname = "emmc"; ocr_avail = <0x200080>; caps = "MMC_CAP_8_BIT_DATA", "MMC_CAP_MMC_HIGHSPEED", "MMC_CAP_SD_HIGHSPEED", "MMC_CAP_NONREMOVABLE", "MMC_CAP_1_8V_DDR", "MMC_CAP_HW_RESET", "MMC_CAP_ERASE", "MMC_CAP_CMD23"; caps2 = "MMC_CAP2_HS200"; f_min = <0x493e0>; f_max = <0x9e4f580>; max_req_size = <0x20000>; gpio_dat3 = <0x20 0x17 0x0>; hw_reset = <0x20 0x1d 0x0>; card_type = <0x1>; }; }; sdio { compatible = "amlogic, aml_sd_emmc"; dev_name = "aml_newsd.0"; status = "okay"; reg = <0x0 0xd0070000 0x0 0x2000>; interrupts = <0x0 0xd8 0x4>; pinctrl-names = "sdio_clk_cmd_pins", "sdio_all_pins"; pinctrl-0 = <0x2e>; pinctrl-1 = <0x2f>; sdio { status = "okay"; pinname = "sdio"; ocr_avail = <0x200080>; caps = "MMC_CAP_4_BIT_DATA", "MMC_CAP_MMC_HIGHSPEED", "MMC_CAP_SD_HIGHSPEED", "MMC_CAP_NONREMOVABLE", "MMC_CAP_UHS_SDR12", "MMC_CAP_UHS_SDR25", "MMC_CAP_UHS_SDR50", "MMC_CAP_UHS_SDR104", "MMC_PM_KEEP_POWER", "MMC_CAP_SDIO_IRQ"; f_min = <0x61a80>; f_max = <0xbebc200>; max_req_size = <0x20000>; card_type = <0x3>; }; }; nand { compatible = "amlogic, aml_nand"; dev_name = "nand"; status = "ok"; reg = <0x0 0xd0074800 0x0 0x200>; interrupts = <0x0 0x22 0x1>; pinctrl-names = "nand_rb_mod", "nand_norb_mod", "nand_cs_pins_only"; pinctrl-0 = <0x30 0x31 0x32>; pinctrl-1 = <0x30 0x31 0x32>; pinctrl-2 = <0x33>; device_id = <0x0>; plat-names = "nandnormal"; plat-num = <0x1>; plat-part-0 = <0x34>; normal { enable_pad = "ce0", "ce1", "ce2", "ce3"; busy_pad = "rb0"; linux,phandle = <0x34>; phandle = <0x34>; }; }; aml_nftl { compatible = "amlogic, nftl"; }; partitions { parts = <0xc>; part-0 = <0x35>; part-1 = <0x36>; part-2 = <0x37>; part-3 = <0x38>; part-4 = <0x39>; part-5 = <0x3a>; part-6 = <0x3b>; part-7 = <0x3c>; part-8 = <0x3d>; part-9 = <0x3e>; part-10 = <0x3f>; part-11 = <0x40>; logo { pname = "logo"; size = <0x0 0x2000000>; mask = <0x1>; linux,phandle = <0x35>; phandle = <0x35>; }; recovery { pname = "recovery"; size = <0x0 0x2000000>; mask = <0x1>; linux,phandle = <0x36>; phandle = <0x36>; }; rsv { pname = "rsv"; size = <0x0 0x800000>; mask = <0x1>; linux,phandle = <0x37>; phandle = <0x37>; }; tee { pname = "tee"; size = <0x0 0x800000>; mask = <0x1>; linux,phandle = <0x38>; phandle = <0x38>; }; crypt { pname = "crypt"; size = <0x0 0x2000000>; mask = <0x1>; linux,phandle = <0x39>; phandle = <0x39>; }; misc { pname = "misc"; size = <0x0 0x2000000>; mask = <0x1>; linux,phandle = <0x3a>; phandle = <0x3a>; }; instaboot { pname = "instaboot"; size = <0x0 0x20000000>; mask = <0x1>; linux,phandle = <0x3b>; phandle = <0x3b>; }; boot { pname = "boot"; size = <0x0 0x2000000>; mask = <0x1>; linux,phandle = <0x3c>; phandle = <0x3c>; }; system { pname = "system"; size = <0x0 0x40000000>; mask = <0x1>; linux,phandle = <0x3d>; phandle = <0x3d>; }; cache { pname = "cache"; size = <0x0 0x40000000>; mask = <0x2>; linux,phandle = <0x3e>; phandle = <0x3e>; }; nv { pname = "nv"; size = <0x0 0x1000000>; mask = <0x1>; linux,phandle = <0x3f>; phandle = <0x3f>; }; data { pname = "data"; size = <0xffffffff 0xffffffff>; mask = <0x4>; linux,phandle = <0x40>; phandle = <0x40>; }; }; unifykey { compatible = "amlogic, unifykey"; status = "ok"; unifykey-num = <0x12>; unifykey-index-0 = <0x41>; unifykey-index-1 = <0x42>; unifykey-index-2 = <0x43>; unifykey-index-3 = <0x44>; unifykey-index-4 = <0x45>; unifykey-index-5 = <0x46>; unifykey-index-6 = <0x47>; unifykey-index-7 = <0x48>; unifykey-index-8 = <0x49>; unifykey-index-9 = <0x4a>; unifykey-index-10 = <0x4b>; unifykey-index-11 = <0x4c>; unifykey-index-12 = <0x4d>; unifykey-index-13 = <0x4e>; unifykey-index-14 = <0x4f>; unifykey-index-15 = <0x50>; unifykey-index-16 = <0x51>; unifykey-index-17 = <0x52>; key_0 { key-name = "usid"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x41>; phandle = <0x41>; }; key_1 { key-name = "mac"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x42>; phandle = <0x42>; }; key_2 { key-name = "hdcp"; key-device = "normal"; key-type = "sha1"; key-permit = "read", "write", "del"; linux,phandle = <0x43>; phandle = <0x43>; }; key_3 { key-name = "secure_boot_set"; key-device = "efuse"; key-permit = "write"; linux,phandle = <0x44>; phandle = <0x44>; }; key_4 { key-name = "mac_bt"; key-device = "normal"; key-permit = "read", "write", "del"; key-type = "mac"; linux,phandle = <0x45>; phandle = <0x45>; }; key_5 { key-name = "mac_wifi"; key-device = "normal"; key-permit = "read", "write", "del"; key-type = "mac"; linux,phandle = <0x46>; phandle = <0x46>; }; key_6 { key-name = "hdcp2_tx"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x47>; phandle = <0x47>; }; key_7 { key-name = "hdcp2_rx"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x48>; phandle = <0x48>; }; key_8 { key-name = "widevinekeybox"; key-device = "secure"; key-type = "sha1"; key-permit = "read", "write", "del"; linux,phandle = <0x49>; phandle = <0x49>; }; key_9 { key-name = "deviceid"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x4a>; phandle = <0x4a>; }; key_10 { key-name = "hdcp22_fw_private"; key-device = "secure"; key-permit = "read", "write", "del"; linux,phandle = <0x4b>; phandle = <0x4b>; }; key_11 { key-name = "UUID"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x4c>; phandle = <0x4c>; }; key_12 { key-name = "SERIALNO"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x4d>; phandle = <0x4d>; }; key_13 { key-name = "OrderId"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x4e>; phandle = <0x4e>; }; key_14 { key-name = "DID"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x4f>; phandle = <0x4f>; }; key_15 { key-name = "OTP"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x50>; phandle = <0x50>; }; key_16 { key-name = "hdcp2lc128"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x51>; phandle = <0x51>; }; key_17 { key-name = "hdcp2key"; key-device = "normal"; key-permit = "read", "write", "del"; linux,phandle = <0x52>; phandle = <0x52>; }; }; amhdmitx { compatible = "amlogic, amhdmitx"; dev_name = "amhdmitx"; status = "okay"; pinctrl-names = "hdmitx_hpd", "hdmitx_ddc"; pinctrl-0 = <0x53>; pinctrl-1 = <0x54>; vend-data = <0x55>; interrupts = <0x0 0x39 0x1>; interrupt-names = "hdmitx_hpd"; clocks = <0xc 0xb 0xc 0xc 0xc 0xd 0xc 0xe 0xc 0xf 0xc 0x16>; clock-names = "hdmitx_clk_sys", "hdmitx_clk_encp", "hdmitx_clk_enci", "hdmitx_clk_pixel", "hdmitx_clk_phy", "hdmitx_clk_vid"; hdcp14_en = <0x82000010>; hdcp14_rslt = <0x82000011>; gpio_i2c_en = <0x1>; #address-cells = <0x2>; #size-cells = <0x2>; ranges; vend_data { compatible = "amlogic, amlogic-cec"; status = "okay"; vendor_name = "Amlogic"; vendor_id = <0x0>; product_desc = "GXBB Mbox"; cec_osd_string = "MBox"; interrupts = <0x0 0xc7 0x1>; interrupt-names = "hdmitx_cec"; pinctrl-names = "hdmitx_aocec"; pinctrl-0 = <0x56>; reg = <0x0 0xc810023c 0x0 0x4>; linux,phandle = <0x55>; phandle = <0x55>; }; }; i2c_gpio { compatible = "i2c-gpio"; dev_name = "i2c-gpio"; i2c-gpio,delay-us = <0xa>; gpios = <0x20 0x11 0x0 0x20 0x12 0x0>; #address-cells = <0x2>; #size-cells = <0x2>; i2c_gpio_edid { compatible = "i2c-gpio-edid"; reg = <0x50 0x0 0x0 0x0>; }; }; serial@c81004c0 { compatible = "amlogic, meson-uart"; reg = <0x0 0xc81004c0 0x0 0x14>; interrupts = <0x0 0xc1 0x1>; status = "okay"; clocks = <0xc 0x2>; clock-names = "clk_uart"; fifosize = <0x40>; pinctrl-names = "default"; }; serial@c11084c0 { compatible = "amlogic, meson-uart"; reg = <0x0 0xc11084c0 0x0 0x14>; interrupts = <0x0 0x1a 0x1>; status = "okay"; clocks = <0xc 0x2>; clock-names = "clk_uart"; fifosize = <0x80>; pinctrl-names = "default"; pinctrl-0 = <0x57>; resets = <0xc 0xd>; }; serial@c1108700 { compatible = "amlogic, meson-uart"; reg = <0x0 0xc1108700 0x0 0x14>; interrupts = <0x0 0x5d 0x1>; status = "okay"; clocks = <0xc 0x2>; clock-names = "clk_uart"; fifosize = <0x40>; pinctrl-names = "default"; pinctrl-0 = <0x58>; resets = <0xc 0x4f>; }; canvas { compatible = "amlogic, meson, canvas"; dev_name = "amlogic-canvas"; status = "ok"; reg = <0x0 0xc8838000 0x0 0x400>; }; rdma { compatible = "amlogic, meson, rdma"; dev_name = "amlogic-rdma"; status = "ok"; interrupts = <0x0 0x59 0x1>; interrupt-names = "rdma"; }; dwc2_b { compatible = "amlogic,dwc2"; device_name = "dwc2_b"; reg = <0x0 0xc9100000 0x0 0x40000>; interrupts = <0x0 0x1f 0x4>; status = "okay"; pl-periph-id = <0x1>; clock-src = "usb1"; port-id = <0x1>; port-type = <0x1>; port-speed = <0x0>; port-config = <0x0>; port-dma = <0x0>; port-id-mode = <0x1>; phy-reg = <0xc0000020>; phy-reg-size = <0x20>; usb-fifo = <0x400>; host-only-core = <0x1>; pmu-apply-power = <0x1>; cpu-type = "gxbaby"; resets = <0xc 0x3a 0xc 0x48 0xc 0x36>; reset-names = "usb_general", "usb1", "usb1_to_ddr"; }; dwc2_a { compatible = "amlogic,dwc2"; device_name = "dwc2_a"; reg = <0x0 0xc9000000 0x0 0x40000>; interrupts = <0x0 0x1e 0x4>; status = "okay"; pl-periph-id = <0x0>; clock-src = "usb0"; port-id = <0x0>; port-type = <0x1>; port-speed = <0x0>; port-config = <0x0>; port-dma = <0x0>; port-id-mode = <0x1>; gpio-work-mask = <0x1>; phy-reg = <0xc0000000>; phy-reg-size = <0x20>; usb-fifo = <0x400>; cpu-type = "gxbaby"; resets = <0xc 0x3a 0xc 0x49 0xc 0x35>; reset-names = "usb_general", "usb0", "usb0_to_ddr"; }; I2S { #sound-dai-cells = <0x0>; resets = <0xc 0x26 0xc 0x12 0xc 0x28 0xc 0x29 0xc 0x2a 0xc 0x2b 0xc 0x2c 0xc 0x2d 0xc 0x2f 0xc 0x8e 0xc 0x22>; reset-names = "top_glue", "aud_buf", "i2s_out", "amclk_measure", "aififo2", "aud_mixer", "mixer_reg", "adc", "top_level", "aoclk", "aud_in"; clocks = <0xc 0x1f 0xc 0x22>; clock-names = "mpll0", "mclk"; compatible = "amlogic, aml-i2s-dai"; linux,phandle = <0x63>; phandle = <0x63>; }; SPDIF { #sound-dai-cells = <0x0>; compatible = "amlogic, aml-spdif-dai"; resets = <0xc 0x27 0xc 0x90>; reset-names = "iec958", "iec958_amclk"; clocks = <0xc 0x20 0xc 0x24 0xc 0x22 0xc 0x25>; clock-names = "mpll1", "i958", "mclk", "spdif"; linux,phandle = <0x64>; phandle = <0x64>; }; PCM { #sound-dai-cells = <0x0>; compatible = "amlogic, aml-pcm-dai"; linux,phandle = <0x65>; phandle = <0x65>; }; i2s_platform { compatible = "amlogic, aml-i2s"; linux,phandle = <0x61>; phandle = <0x61>; }; pcm_platform { compatible = "amlogic, aml-pcm"; linux,phandle = <0x62>; phandle = <0x62>; }; spdif_codec { #sound-dai-cells = <0x0>; compatible = "amlogic, aml-spdif-codec"; pinctrl-names = "aml_audio_spdif"; pinctrl-0 = <0x59>; linux,phandle = <0x67>; phandle = <0x67>; }; pcm_codec { #sound-dai-cells = <0x0>; compatible = "amlogic, pcm2BT-codec"; linux,phandle = <0x68>; phandle = <0x68>; }; dummy { #sound-dai-cells = <0x0>; compatible = "amlogic, aml_dummy_codec"; status = "okay"; linux,phandle = <0x66>; phandle = <0x66>; }; aml_m8_snd { compatible = "aml, aml_snd_m8"; status = "okay"; aml-sound-card,format = "i2s"; aml_sound_card,name = "AML-M8AUDIO"; aml,audio-routing = "Ext Spk", "LOUTL", "Ext Spk", "LOUTR"; mute_gpio-gpios = <0x20 0x13 0x0>; hp_disable; hp_paraments = <0x320 0x12c 0x0 0x5 0x1>; pinctrl-names = "aml_snd_m8"; pinctrl-0 = <0x5a>; cpu_list = <0x5b 0x5c 0x5d>; codec_list = <0x5e 0x5f 0x60>; plat_list = <0x61 0x61 0x62>; cpudai0 { sound-dai = <0x63>; linux,phandle = <0x5b>; phandle = <0x5b>; }; cpudai1 { sound-dai = <0x64>; linux,phandle = <0x5c>; phandle = <0x5c>; }; cpudai2 { sound-dai = <0x65>; linux,phandle = <0x5d>; phandle = <0x5d>; }; codec0 { sound-dai = <0x66>; linux,phandle = <0x5e>; phandle = <0x5e>; }; codec1 { sound-dai = <0x67>; linux,phandle = <0x5f>; phandle = <0x5f>; }; codec2 { sound-dai = <0x68>; linux,phandle = <0x60>; phandle = <0x60>; }; }; amlogic_thermals { compatible = "amlogic, amlogic-thermal"; #thermal-cells = <0x7>; device_name = "thermal"; trip_point = <0x46 0x177001 0x177001 0x1ff 0x1ff 0x3 0x2 0x50 0x13c681 0x13c681 0x1b3 0x1b3 0x2 0x1 0x5a 0xfbf41 0xfbf41 0x148 0x148 0x2 0x1 0x104 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0xffffffff 0xffffffff>; cpu_cali_a = <0x0>; idle_interval = <0x3e8>; keep_mode; keep_mode_threshold = <0x55>; keep_mode_max_range = <0x1ec300 0x29a 0x4 0x3>; keep_mode_min_range = <0x1f4 0x190 0x1 0x2>; }; gpio_keypad { compatible = "amlogic, gpio_keypad"; status = "okay"; scan_period = <0x14>; key_num = <0x1>; key_name = "power"; key_code = <0x1f4>; key_pin = <0x69 0x3 0x0>; irq_keyup = <0x6>; irq_keydown = <0x7>; }; adc_keypad { compatible = "amlogic, adc_keypad"; status = "okay"; key_name = "menu", "vol-", "vol+", "esc", "home"; key_num = <0x5>; key_code = <0x8b 0x72 0x73 0x1 0x66>; key_chan = <0x0 0x0 0x0 0x0 0x0>; key_val = <0x0 0x8f 0x10f 0x189 0x1fe>; key_tolerance = <0x28 0x28 0x28 0x28 0x28>; }; sen5led { compatible = "sen5,sen5led"; dev_name = "sen5led"; status = "okay"; power_led_gpio = <0x20 0xc 0x0>; power_led2_gpio = <0x20 0x7 0x0>; bluetooth_led_gpio = <0x20 0x55 0x0>; }; meson-irblaster { compatible = "amlogic, am_irblaster"; dev_name = "meson-irblaster"; status = "ok"; }; fd650 { compatible = "sen5,sen5_fd650"; dev_name = "fd650"; sck_gpio = <0x20 0xd 0x0>; sda_gpio = <0x20 0x6 0x0>; status = "okay"; }; dvb { compatible = "amlogic, dvb"; dev_name = "dvb"; ts0 = "serial"; ts0_control = <0x0>; ts0_invert = <0x0>; ts1 = "serial"; ts1_control = <0x0>; ts1_invert = <0x0>; pinctrl-names = "s_ts0", "s_ts1"; pinctrl-0 = <0x6a>; pinctrl-1 = <0x6b>; resets = <0xc 0x24 0xc 0x10 0xc 0x3d 0xc 0x39>; reset-names = "demux", "asyncfifo", "ahbarb0", "uparsertop"; }; dvbfe { compatible = "amlogic, dvbfe"; dev_name = "dvbfe"; dtv_demod0 = "Avl6762"; dtv_demod0_i2c_adap_id = <0x1>; dtv_demod0_i2c_addr = <0xc0>; dtv_demod0_reset_value = <0x0>; dtv_demod0_reset_gpio-gpios = <0x69 0x5 0x0>; dtv_demod0_tunerpower_on_value = <0x1>; dtv_demod0_tunerpower-gpios = <0x20 0x52 0x0>; dtv_demod0_ant_poweron_value = <0x0>; dtv_demod0_ant_power-gpios = <0x20 0x53 0x0>; fe0_dtv_demod = <0x0>; fe0_ts = <0x1>; fe0_dev = <0x0>; dtv_demod1 = "Avl6211"; dtv_demod1_i2c_adap_id = <0x1>; dtv_demod1_i2c_addr = <0xc>; dtv_demod1_reset_value = <0x0>; dtv_demod1_reset_gpio-gpios = <0x69 0x5 0x0>; dtv_demod1_tunerpower_on_value = <0x1>; dtv_demod1_tunerpower-gpios = <0x20 0x52 0x0>; dtv_demod1_lnb_poweron_value = <0x1>; dtv_demod1_lnb_hz_value = <0x0>; dtv_demod1_spectrum_invert = <0x1>; fe1_dtv_demod = <0x1>; fe1_ts = <0x0>; fe1_dev = <0x1>; }; smartcard { compatible = "amlogic,smartcard"; irq_trigger_type = "GPIO_IRQ_LOW"; smc0_reset_pin-gpios = <0x20 0x5b 0x0>; smc0_detect_pin-gpios = <0x20 0x5a 0x0>; smc0_enable_pin-gpios = <0x20 0x51 0x0>; interrupts = <0x0 0x45 0x4>; smc0_clock_source = <0x0>; smc0_irq = <0x45>; smc0_det_invert = <0x1>; smc0_enable_level = <0x1>; smc0_need_enable_pin = "yes"; smc0_reset_level = <0x0>; smc0_clk_pinmux_reg = <0x2d>; smc0_clk_pinmux_bit = <0x2000>; smc0_clk_oen_reg = <0xf>; smc0_clk_out_reg = <0x10>; smc0_clk_bit = <0x10>; pinctrl-names = "default"; pinctrl-0 = <0x6c>; resets = <0xc 0xb>; reset-names = "smartcard"; status = "okay"; }; }; P.s. sorry for my English and if I made some mistake. Edited September 1, 2018 by Paco Martos Link to comment Share on other sites More sharing options...
balbes150 Posted September 1, 2018 Author Share Posted September 1, 2018 11 hours ago, lizzacore said: LSCpu says 4 cores (0-3): 0 1 2 3 Numbering goes from zero Link to comment Share on other sites More sharing options...
Xiaofan Posted September 1, 2018 Share Posted September 1, 2018 On 8/21/2018 at 4:39 AM, Novato said: I got this result with Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_icewm_20171226.img on my Mecool M8S Pro 2G / 16 S912. This time there was no kernel error or ZRAM, but still did not complete Boot. See the last screen it performs. I also see this in various version. In the end, I think this is due to the fact that somehow the file system permission got messed up. You can try the server version and you will be able to log-in. But then sudo will not work due to permission problems. I suspected that the pp "Update&Backup" is the culprit but I do not know whether it is the problem or not. I have an X96 mini and I did not encounter this issue in the earlier version of the FW. I do have a workaround, since we only need to use "Update&Backup" once, just format the messed-up SD card and do it again -- your next image will work. I've tried this with multiple versions for the past week. Link to comment Share on other sites More sharing options...
KY69 Posted September 1, 2018 Share Posted September 1, 2018 4 hours ago, Xiaofan said: ... I do have a workaround, since we only need to use "Update&Backup" once, just format the messed-up SD card and do it again -- your next image will work. I've tried this with multiple versions for the past week. I remember I had similar problems a few months ago when I tried installing Armbian on my TX3 mini for the first time. I did some tests back then and if I recall correctly mounting any Linux partition (extX) on Android seemed to be changing the file system to use SElinux permissions, which prevented Armbian from even reaching the first login prompt. I had the same problem even after having everything running and simply mounting the SD card or HDD on Android, it simply messed everything up, and changing all permissions back was time consuming, so I simply do NOT mount any linux filesystem when running Android on the box. Actually I never even boot Android, I bought the box specifically to run Armbian, sadly I haven't had time to play with it for over a month now. But the symptom was as you described, I prepared the SD card, updated the box to multiboot (via Android, so it mounted the linux filesystem on the SD card and messed it up right there), and no matter what dtb file I used it would halt somewhere like what you showed. After rewriting the SD card and not mounting it on Android (I already had multiboot), Armbian booted out of the box, but it took me some time to figure that out. After I had the system working I booted Android and inserted the SD card, and I was again not able to fully boot Armbian due to SElinux permissions on certain system files (actually all over the filesystem, but fixing the permissions to a few system files made the system bootable again. Afterwards I still had to fix the whole filesystem nonetheless). I tried a few things after I had the system running from an HDD, and simply mounting this HDD on Android was enough to "update" the file permissions and make Armbian unbootable again. In summary, at least with my TX3 mini, I cannot mount any media with Armbian partitions on Android. I believe my box has Android 7.1 from March/2018. In fewer words, your problem is probably not with the Android Update app, but with Android itself whenever it mounts the extX partition(s). Hope this helps somehow. 1 Link to comment Share on other sites More sharing options...
Xiaofan Posted September 2, 2018 Share Posted September 2, 2018 2 hours ago, KY69 said: I believe my box has Android 7.1 from March/2018. In fewer words, your problem is probably not with the Android Update app, but with Android itself whenever it mounts the extX partition(s). Hope this helps somehow. This makes perfect sense. Thanks for sharing. BTW, interestingly I bought the X96 Mini with the main objective to run Armbian as well. I am relatively new to Arm Linux (not new to Linux, using quite a bit of Linux since 2005 with Ubuntu 5.04) -- only started to play with some boards like Udoo Neo and Nano Pi M1 Plus this year and I like Armbian. One of my main objectives with Armbian is to carry out tests for libusb related open source projects like libftdi/HIDAPI/pyusb/openocd/etc. The other objective is to learn more about embedded Linux. Link to comment Share on other sites More sharing options...
lizzacore Posted September 3, 2018 Share Posted September 3, 2018 On 9/1/2018 at 9:07 AM, balbes150 said: 0 1 2 3 Numbering goes from zero Works now, I saw the problem. Another question I have: Can we Install it to NAND/Flash ? I know there are problem with 4.18 Kernel, do I should a another one? Kind regards, Link to comment Share on other sites More sharing options...
chpasha Posted September 4, 2018 Share Posted September 4, 2018 On 9/3/2018 at 9:56 AM, lizzacore said: Can we Install it to NAND/Flash ? I know there are problem with 4.18 Kernel, do I should a another one? you can try . 3.14 with /root/install.sh command, 4.18 with 1. Execute script “/boot/create-mbr-linux.sh” 2. Execute script “/root/install.sh” and see if that works 1 Link to comment Share on other sites More sharing options...
Zymagoras Posted September 5, 2018 Share Posted September 5, 2018 Hi guys, whenever i try modprobing any of the wifi modules i get fatal error/module not found, everything else seems to work perfect. I have "mini m8s ii". Any clues of what i am doing wrong? Thanks. Link to comment Share on other sites More sharing options...
Nofan Tasi Posted September 5, 2018 Share Posted September 5, 2018 3 hours ago, Zymagoras said: Hi guys, whenever i try modprobing any of the wifi modules i get fatal error/module not found, everything else seems to work perfect. I have "mini m8s ii". Any clues of what i am doing wrong? Thanks. what exact command do you give and what is the exact error output? Link to comment Share on other sites More sharing options...
lizzacore Posted September 5, 2018 Share Posted September 5, 2018 On 9/4/2018 at 3:35 PM, chpasha said: you can try . 3.14 with /root/install.sh command, 4.18 with 1. Execute script “/boot/create-mbr-linux.sh” 2. Execute script “/root/install.sh” and see if that works OH MY GOSH! You are a genius, thanks you very much. IT WORKED!! Best man !! Kind regards, Link to comment Share on other sites More sharing options...
Zymagoras Posted September 5, 2018 Share Posted September 5, 2018 8 hours ago, Nofan Tasi said: what exact command do you give and what is the exact error output? Sorry for late reply, just came back from work Link to comment Share on other sites More sharing options...
lizzacore Posted September 5, 2018 Share Posted September 5, 2018 I have a new issue, only a small thing. I don't now if this needed or can be fixed but when please give me an advice to do so. grep "armbian-zram" /var/log/daemon.log Sep 5 19:56:46 S905xNAS systemd[1]: armbian-zram-config.service: Main process exited, code=exited, status=1/FAILURE Sep 5 19:56:46 S905xNAS systemd[1]: armbian-zram-config.service: Unit entered failed state. Sep 5 19:56:46 S905xNAS systemd[1]: armbian-zram-config.service: Failed with result 'exit-code'. No Swap, no l4z and no zram? If this is required for something? I read about it but I don't know. Kind regards, Link to comment Share on other sites More sharing options...
KY69 Posted September 6, 2018 Share Posted September 6, 2018 19 hours ago, Zymagoras said: Hi guys, whenever i try modprobing any of the wifi modules i get fatal error/module not found, everything else seems to work perfect. I have "mini m8s ii". Any clues of what i am doing wrong? Thanks. A few months ago, in a previous version, you could try something like: sudo ln -s /lib/firmware /usr/lib/firmware It may or may not be what you need now for 4.18, but if you give it a try let us know if it fixes your problem. Link to comment Share on other sites More sharing options...
KY69 Posted September 6, 2018 Share Posted September 6, 2018 On 8/19/2018 at 1:18 PM, ramawatar said: is wifi working for tx3 mini for you? Sent from my Redmi Note 4 using Tapatalk Sorry I hadn't seen your question before. I haven't had time to play with my TX3 mini in the past few months, but yes, wifi was working. Maybe it was not as solid as it could/should be, I didn't make any kind of measurements, but it would sometimes "feel" it was somewhat slower than my laptop, for instance, when transferring the same thing to both of them over wifi. My TX3 mini was/is still running 5.41.1 with 3.14.29, I am still waiting for a chance to try the newer images. I had setup wifi using wifi_dummy, my wifi chip is the SSV6051, and my ROM is from March 2018 (from where I believe Armbian was getting the dtb file), if that helps. Link to comment Share on other sites More sharing options...
martinayotte Posted September 6, 2018 Share Posted September 6, 2018 14 hours ago, KY69 said: sudo ln -s /lib/firmware /usr/lib/firmware I don't see any reason for that since no kernel on earth is looking at /usr/lib/firmware ... Link to comment Share on other sites More sharing options...
Zymagoras Posted September 6, 2018 Share Posted September 6, 2018 So does it matter which dtb file i use? Link to comment Share on other sites More sharing options...
Zymagoras Posted September 6, 2018 Share Posted September 6, 2018 Fixed it by changing to different dtb file. Link to comment Share on other sites More sharing options...
Nofan Tasi Posted September 6, 2018 Share Posted September 6, 2018 On 9/5/2018 at 8:04 PM, Zymagoras said: Sorry for late reply, just came back from work It looks to me you are more after AML specific modules like from, say amlogic 3.14.29 kernel. These may never have reached 4.18.x Link to comment Share on other sites More sharing options...
Tommy21 Posted September 7, 2018 Share Posted September 7, 2018 I believe he has to install package located in balbes150 armbian 5.59 folder, subfolder deb, it solved my wifi issue. Link to comment Share on other sites More sharing options...
Zymagoras Posted September 7, 2018 Share Posted September 7, 2018 Thanks for your replies, i fixed it by changing dtb file. Link to comment Share on other sites More sharing options...
