balbes150 Posted September 11, 2018 Author Posted September 11, 2018 11 hours ago, yurek_m said: dear k1plus s905d 1gb ram model dtb image linux 4.18 help???????????????????? Alas, I can not help you, I do not have such equipment. 6 hours ago, Reddwarf said: Did not work on my Mini M8S, after running the script it didn't even boot from the SD card anymore Most likely on your model there is no eMMC (old NAND is used).
lizzacore Posted September 11, 2018 Posted September 11, 2018 7 hours ago, Reddwarf said: Did not work on my Mini M8S, after running the script it didn't even boot from the SD card anymore I had the same issue. thats because your sd card is mmcblk0 and your nand/emmc is mmcblk1. In the install and create_mbr script this is wrong. You have to make some changes by yourself. After that your box wont boot because the boot partition search for mmcblk1p2 but its actually mmcblk0p2. may you write me personal, may i can help you with that. kind regards,
Reddwarf Posted September 11, 2018 Posted September 11, 2018 6 hours ago, balbes150 said: Most likely on your model there is no eMMC (old NAND is used). I see, so there is no way to install on old NAND? I'm trying on a MXQ Pro+ and seems to have more success but boot hangs. I'll investigte further. Another question, is there a way to get accelerated video on 4.18?
balbes150 Posted September 11, 2018 Author Posted September 11, 2018 8 hours ago, lizzacore said: I had the same issue. thats because your sd card is mmcblk0 and your nand/emmc is mmcblk1. In the install and create_mbr script this is wrong. You have to make some changes by yourself. After that your box wont boot because the boot partition search for mmcblk1p2 but its actually mmcblk0p2. may you write me personal, may i can help you with that. There are no errors in scripts. The reason is the incorrect operation of u-boot (your u-boot is very outdated and contains an error), which changes the eMMC number depending on the connection or disconnection of the SD card. 2 hours ago, Reddwarf said: Another question, is there a way to get accelerated video on 4.18?  It's possible, but I don't plan to add it yet.
Reddwarf Posted September 11, 2018 Posted September 11, 2018 16 minutes ago, balbes150 said: It's possible, but I don't plan to add it yet. Any particular reason for that? Armbian is much more versatile and useful WITH HW acceleration.... And is it impossible to install to old NAND?
Tommy21 Posted September 11, 2018 Posted September 11, 2018 If it is possible, could you provide links to the stuff needed to watch hw accelerated videos?I do believe it's not an easy task, but if it isn't too complicated, why not, i would try.I know you are doing this in your free time for free, and that is why we all wish to thank you.I would help you if i've had the knowledge, but i don't know much about Linux and programming.
Reddwarf Posted September 11, 2018 Posted September 11, 2018 1 minute ago, Tommy21 said: If it is possible, could you provide links to the stuff needed to watch hw accelerated videos? I do believe it's not an easy task, but if it isn't too complicated, why not, i would try. I know you are doing this in your free time for free, and that is why we all wish to thank you. I would help you if i've had the knowledge, but i don't know much about Linux and programming. +1
balbes150 Posted September 12, 2018 Author Posted September 12, 2018 15 hours ago, Reddwarf said: Any particular reason for that? Armbian is much more versatile and useful WITH HW acceleration.... HW for kernel 4.18 while in the process of active development (it is actively working in the community of developers LE), when it will take the finished form, you can try to move to Armbian. 15 hours ago, Reddwarf said: And is it impossible to install to old NAND? You can try to set manually. First, check the reaction to the command mount /dev/system /mnt 13 hours ago, Tommy21 said: If it is possible, could you provide links to the stuff needed to watch hw accelerated videos? I do believe it's not an easy task, but if it isn't too complicated, why not, i would try. I know you are doing this in your free time for free, and that is why we all wish to thank you. I would help you if i've had the knowledge, but i don't know much about Linux and programming. http://www.linux-meson.com/doku.php http://lists.infradead.org/pipermail/linux-amlogic/
lizzacore Posted September 13, 2018 Posted September 13, 2018 On 9/12/2018 at 8:33 AM, balbes150 said: HW for kernel 4.18 while in the process of active development (it is actively working in the community of developers LE), when it will take the finished form, you can try to move to Armbian. You can try to set manually. First, check the reaction to the command mount /dev/system /mnt http://www.linux-meson.com/doku.php http://lists.infradead.org/pipermail/linux-amlogic/ I've fixed that issue by myself with editing the script to the "right" mcc. After that and fixing the boot partition everything works finde now. Now issues about that anymore. Kind regards,
lizzacore Posted September 13, 2018 Posted September 13, 2018 On 9/9/2018 at 11:01 AM, lizzacore said: So guys, i have a new issue which i cannot fix by myself. wifi dont work. I Tried every dtb file But my wifi modul never worked. so i googled. i found that i have a rare Chip: aigale aw-cm273sm is there any way to get the driver for this Modul? kind regards One can help me about that? Kind regards, 1
lizzacore Posted September 13, 2018 Posted September 13, 2018 Other question: How do i Update from 5.59 20180829 to 5.59 20180908 without dataloss?
Reddwarf Posted September 13, 2018 Posted September 13, 2018 12 minutes ago, lizzacore said: Other question: How do i Update from 5.59 20180829 to 5.59 20180908 without dataloss? Easiest is to back up your /home directory first, also any other directory you have placed stuff in.
8a8asik Posted September 14, 2018 Posted September 14, 2018 Hi. I search debian stretch 9 image with odroid-c2 kernel, or with compiled mali_drm in kernel. Give me please links. Thx.
Thang Posted September 14, 2018 Posted September 14, 2018 @balbes150 I'm trying to follow the official guide to build the wireless driver for my mini m8s ii box: https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver The wireless chip is realtek RTL8189FTV. Driver build procedure is in the following link: http://linux-sunxi.org/Wifi#RTL8189FTV However, when I run armbian-config and try to install kernel headers, it does nothing. The progress bar goes from 0% to 100% instantly, twice. I've tried to make a bash script as in the official guide, but it just hang up. How can I get the kernel headers for the latest 5.59 build? (4.18.0-aml-s9xxx)? I also do apt update and search for the corresponding linux-headers-, but there is no linux-headers-4.18.0-aml-s9xxx. The closest one is linux-headers-4.18.0-rc5-meson or something like that. I installed it and was able to compile the driver, but could not insmod it. The kernel name does not match. The driver rtl8189fs (which is for rtl8189ftv) is included in all armbian releases for kernel 3.14.29, but are missing/removed from kernel 4.x. Is there any problem that prevent such driver to be compiled and included in kernel 4.18? If not, can you build it and include it to subsequent release? Thanks!
flm Posted September 15, 2018 Posted September 15, 2018 I'm thinking about buying tv box just for linux experiments. My choices are: - TANIX TX3 MINI-L Amlogic S905W 64-bit 4K TV Box 1GB+8GB Android 7.1 - T96 Mars Android 7.1 Amlogic S905W Quad Core TV Box 1GB RAM 8GB ROM - MXQ Pro 4K TV Box Amlogic S905W Android 7.1 1G+8G WiFi - A95X R1 Amlogic S905W TV Box Android 7.1 1GB+8GB 4K x 2K WiFi Ethernet - TANIX TX3 MINI-H Amlogic S905W 64-bit 4K TV Box 2GB+16GB Android 7.1 - TX3 Mini Amlogic S905W 4K UHD TV Box 2G+16G Android 7.1 DLNA Any recommendations?
dbsharpe Posted September 15, 2018 Posted September 15, 2018 13 hours ago, Thang said: @balbes150 I'm trying to follow the official guide to build the wireless driver for my mini m8s ii box: https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver I can't help you with native compilation of kernel modules but I can tell you how I cross compile the latest aml-s9xxx kernel source under linux on intel to make executable modules and bootable zimage. The official way to compile a kernel is to build everything as per https://github.com/150balbes/Build-Armbian or /build but its time and space consuming. Download commit version around 19th August 2018 from https://github.com/150balbes/Amlogic_s905-kernel I get the impression 150balbes kernel is a clone of LE development which is mainline with a number of patches. Toolchain I use is gcc-linaro-7.2.1-2017.11-i686_aarch64-linux-gnu so you will need to setup your environment to run it. Unpack the kernel download and copy /boot/config-4.18.0-aml-s9xxx to .config in your source. command to build is: make EXTRAVERSION=-rc5-amlogics905x ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- -j2 Not sure about but your chip k RTL8189FTV but I would have thought it was already in the current kernel
dbsharpe Posted September 15, 2018 Posted September 15, 2018 5 hours ago, flm said: I'm thinking about buying tv box just for linux experiments. My choices are: - TANIX TX3 MINI-L Amlogic S905W 64-bit 4K TV Box 1GB+8GB Android 7.1 Any recommendations? S905X based H/W is recommended as per https://forum.armbian.com/topic/2419-armbian-for-amlogic-s905-and-s905x/?do=findComment&comment=56629
neik Posted September 15, 2018 Posted September 15, 2018 Hi guys, just ran into this and find it quite interesting! I am wondering how good is the HW decoding working? Is it possible to decode h.264/h.265 up to 4k? I would like to use this with Emby for Linux, maybe someone have experience with this combination and can give some feedback. Thanks!
balbes150 Posted September 16, 2018 Author Posted September 16, 2018 On 9/14/2018 at 10:34 PM, Thang said: How can I get the kernel headers for the latest 5.59 build? https://yadi.sk/d/tNM7NdyB3afohU On 9/15/2018 at 7:10 AM, flm said: Any recommendations?  Try and tell the others ... (personally for me, not familiar with any of the models).
flm Posted September 16, 2018 Posted September 16, 2018 2 hours ago, balbes150 said: personally for me, not familiar with any of the models Can you recommend me some cheap and easy-to-do-linux models not on my list?
Reddwarf Posted September 16, 2018 Posted September 16, 2018 20 hours ago, neik said: Hi guys, just ran into this and find it quite interesting! I am wondering how good is the HW decoding working? Is it possible to decode h.264/h.265 up to 4k? I would like to use this with Emby for Linux, maybe someone have experience with this combination and can give some feedback. Thanks! The hardware should be good enough for 4k since they advertice it with Android, I haven't tested it myself, but full HD works fine under linux with the kernels that support HW acceleration.
neik Posted September 16, 2018 Posted September 16, 2018 54 minutes ago, Reddwarf said: The hardware should be good enough for 4k since they advertice it with Android, I haven't tested it myself, but full HD works fine under linux with the kernels that support HW acceleration. Thanks for the feedback! Although being a bit off-topic I just want to ask one more question: Is this also valid for the S912 SoC? My father has a Beelink GT1 with S912 on which I could play around.
Reddwarf Posted September 17, 2018 Posted September 17, 2018 9 hours ago, neik said: Thanks for the feedback! Although being a bit off-topic I just want to ask one more question: Is this also valid for the S912 SoC? My father has a Beelink GT1 with S912 on which I could play around. Yes, the 912 has its own Armbian thread 1
lizzacore Posted September 17, 2018 Posted September 17, 2018 22 hours ago, lizzacore said: Where I can find the Changelog ? Guys?
talraash Posted September 17, 2018 Posted September 17, 2018 On 9/16/2018 at 10:33 PM, lizzacore said: Where I can find the Changelog ? balbes150 freeze support legacy kernel, so you don't need check changelog. for mainline use github and commits history.
lizzacore Posted September 20, 2018 Posted September 20, 2018 On 9/17/2018 at 11:52 PM, talraash said: balbes150 freeze support legacy kernel, so you don't need check changelog. for mainline use github and commits history. what do you mean what Im searching for?
dbsharpe Posted September 23, 2018 Posted September 23, 2018 On 9/5/2018 at 7:24 PM, lizzacore said: I have a new issue, only a small thing. I don't now if this needed or can be fixed but when please give me an advice to do so. grep "armbian-zram" /var/log/daemon.log Sep 5 19:56:46 S905xNAS systemd[1]: armbian-zram-config.service: Main process exited, code=exited, status=1/FAILURE Sep 5 19:56:46 S905xNAS systemd[1]: armbian-zram-config.service: Unit entered failed state. Sep 5 19:56:46 S905xNAS systemd[1]: armbian-zram-config.service: Failed with result 'exit-code'. No Swap, no l4z and no zram? If this is required for something? I read about it but I don't know. No zram shouldn't be too much on an issue but the reason (for 4.18.0-aml-s9xxx based kernels) your seeing this is that no zram.ko kernel module has been built (see /boot/config-4.18.0-aml-s9xxx). I've compiled the kernel from soruce http://github.com/150balbes/ to build some additional modules and zram builds and loads. I'm no expert on zram but it seems to be operational when loaded at boot on my Aml system, giving compressed swap. I assume kernel stability issues are the reasons zram has not been included in the current kernel .config
talraash Posted September 23, 2018 Posted September 23, 2018 On 9/20/2018 at 8:35 PM, lizzacore said: what do you mean what Im searching for? github commits history for armbin and basbes150 fork... if you need "complete changelog"
Constantin Piffer Posted September 28, 2018 Posted September 28, 2018 Is it possible to use xrdp with armbian? I still got connection problems and I don't know why. SSH works fine. BTW.: I made a video about flashing a TV box in German. You can check it here: 1
