We are opening public testing for upcoming Armbian images. The goal is to verify that the right images are built and that basic functionality works before boards are moved to the main download pages.
You don’t need to be a developer. Simple testing and short reports are enough.
1. Download testing images
Testing images are available here: https://fi.mirror.armbian.de/incoming/igorpecovnik/  Pick the image matching your board and choose desktop if applicable.
Once image is confirmed working, the board will be:
  • Moved to the main download pages
  • Added to Armbian Imager
2. Check that expected images exist
Before testing, please verify that:
  • Your board is listed
  • The expected image variants exist
If an image (variant) seems to be missing:
  1. Check the release target definitions:
    https://github.com/armbian/armbian.github.io/tree/main/release-targets
  2. If the image should exist, check build logs to see if it failed:
    https://github.com/armbian/os/actions/runs/21642728389
If you are unsure, report it anyway.
3. Flash and boot
Flash the image using Armbian Imager: https://imager.armbian.com
Boot the board and check whether it reaches:
  • Login prompt (CLI images)
  • Desktop (Desktop images)
If the board does not boot, serial output or photos help.
4. What to test
Please focus on basic functionality:
  • Boot reliability and reboot
  • Networking (Ethernet, Wi-Fi, Bluetooth)
  • Display and GPU, if applicable
  • Installer and first-boot experience
Advanced features can wait. Stability comes first.
5. UEFI ARM64 images
If your board might support UEFI on ARM64, please test those images on them. Working UEFI images allow us to reuse targets and reduce the number of generated images.
Reference:
https://github.com/armbian/armbian.github.io/blob/main/release-targets/reusable.yml
6. Community-supported boards
Some boards are currently released as community-supported: https://github.com/armbian/community/releases
We want to promote suitable boards to standard support which brings more image variants and much faster download. This requires:
  • Confirmation that basic functionality works
  • Send a PR to change status from .csc to .conf
  • A community member willing to step up as maintainer
If you rely on such a board and want it promoted, this is the time to help.
7. Reporting (here in this topic!)
When reporting test results, please include:
  • Board model
  • Image name and variant
  • What works and what does not
  • Logs or serial output if available
Even short reports like “Board X, image Y, boots and networking works” are useful.
Thanks to everyone helping with testing. Early feedback directly improves the release quality!
  • Igor pinned this topic
What was already tested:
  • UEFI x86 KDE Neon, Gnome, Ubuntu minimal
  • MusePI Pro Xfce
  • Odroid M1 KDE Neon
  • Odroid N2 Xfce https://paste.armbian.com/oqegebaqey
  • Orangepi 5
  • Nanopi M4V2
  • Odroid M2
  • Radxa E54
  • Rock 5C
  • Orangepi 3LTS
  • Odroid C4
  • Bananapi
  • Rock 3A
  • Orangepi PC2
  • Nanopi K1plus
  • Khadas Edge 2
  • Bananapi F3
  • Nanopi M6 / R6S
  • Rock 2F / 2A / 3A
  • Rpi (all)
Posted (edited)
I am currently on the community Odroid M2 CURRENT (6.18) (not edge 6.19) rolling release.
Does this differ significantly enough from the images provided here: https://fi.mirror.armbian.de/incoming/igorpecovnik/  that I should download afresh and re-install before submitting any test results?
Reporting!   Where?   (Every other section 1 - 7 had a necessary link)
Much appreciated in advance.  Willing to help or donate a M2 board if necessary.
Edited by Walter Zambotti
Posted (edited)
I download Armbian_26.2.1_Odroidm2_noble_current_6.18.8_gnome_desktop.img.xz and burnt to a new SD card.
Tested:
Install OK
Initial startup to desktop OK
shutdown OK
boot OK
HDMI OK
HDMI audio FAILED only dummy sound device
Wifi via PCI  M-key to E-key adapter Intel Wifi 6 AX200 OK
USB-2 OK multiple devices including HUB
USB-3 OK thumb drive
USB-C FAILED nil buses detected or exposed
I have managed to add a user device tree overlay to expose the USB-C port in non OTG mode and get some USB-C devices working.  A USB-C thumb drive was consistent.  But I only managed to connect my Pixel 8a successfully once at 480m speed.
10 hours ago, Walter Zambotti said:
Reporting!   Where?
Here, yes. Thank you!
No, but we need to test images made for release. There is another last minute change
https://github.com/armbian/build/commit/1890d7f6566a65202f73730b469d024c20f863b8
than can, in theory, make unbootable image.
OK. Bugs will be present and we won't be fixing them at this stage. Here - if basic things works - that image boots, have connectivity and video output ... its ready to ship. All other things can be fixed with an update. If / when they are fixed.
Armbian exists to save users time so you don't need to waste your private time dealing with bad software experience which would exists without our work. Sadly most people don't understand the value Armbian projecst make.
Average Armbian developer have 100+ boards. We drown in issues they generate. All board manufacturer are happy to send us board for free and we decline many of their offers. I still have many unpacked boxes ... Without your help / engagement, we have no alternative but to keep images in automated untested (theoretically community maintained images) loop. Standard support costs us more then automated unchecked images.
Device: Orange Pi 5 Plus
Image:  Armbian_26.2.1_Orangepi5-plus_noble_current_6.18.8_kde-neon_desktop.img.xz
Installation on SD Card without issue.
Ethernet works
WiFi (RTW89_8852BE): Works
Bluetooth: Available but did not test pairing with bluetooth device
Chromium_v144: vpu hardware acceleration working
USB-3.0 & USB-2.0 Ports working
PCIE-NVMe: Accessible
HDMI Display: working
HDMI-Audio: working
Headphone Jack-Audio: Working (After using alsamixer to increase "output1" volume")
Out of the box, konsole (terminal-emulator) and dolphin (file manager) not pre-installed.
Posted (edited)
I have two boards I can test. ODroid C4 and NanoPi M4v2.
I'll pull down the C4 build and give it a go.
I don't see a build for the M4v2? (EDIT - Doesn't look like the Github action failed)
Edited by tparys
Board: ODroid C4
Image: Armbian_26.2.1_Odroidc4_noble_current_6.18.8_xfce_desktop.img.xz
Tested OK:
 - Installation to SD card
 - Boot to desktop, login
 - OpenGL / Panfrost
 - USB 2.0
 - Ethernet
Not tested:
 - Audio via HDMI (Though alsamixer reports there's stuff there)
If anything, the serial console seems rather quiet. But attached ...
minicom.cap
Armbian_26.2.1_Bananapi_trixie_current_6.12.68_minimal.img.xz (Bananapi M1)
- only power, ethernet and serial console cable connected: 1st boot and user creation all fine
- network up, WAN IP shown
- then connecting a SATA SSD ('hotplug'), pops up in dmesg, so recognized OK
Armbian_26.2.1_Rock-3a_trixie_current_6.18.8_minimal.img.xz (ROCK3A)
- system has NVME inserted and SATA M.2 E-key adaptor where HDD is connected to
- SPI has Armbian legacy U-Boot, but that is skipped as SD-card with new image is inserted
- further only power, ethernet and serial console cable connected: 1st boot and user creation all fine
- NVME is available (but OS is running from SD-card for the test)
- SATA is not available as not supported mainline based kernel (and needs adding overlay manually when vendor kernel)
- reboot does not reboot (but 'echo 1 > /proc/sys/kernel/sysrq ; echo b > /proc/sysrq-trigger' works)
- also poweroff is only shutdown, no powerdown (and HDD keeps also spinning)
Posted (edited)
Update on NanoPi M4v2 ... I pulled the most recent Armbian build, and manually ran the build for the M4v2, and it fails on kernel patch "general-gpio-driver-no-sleep". See pastebin at https://paste.armbian.com/puvorasuco for failed build.
Checking upstream at https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git, it looks like branch 6.18.y already has the subject patch, and was pushed today.
Since both the rockchip and rockchip64 families use mainline kernel, I just submitted a PR that kills that patch for both. See https://github.com/armbian/build/pull/9368.
Edited by tparys
Once board is tested, its moved to its final destination https://www.armbian.com/nanopi-m4-v2/ I tested it
KDE was enabled "as is" / at last moment. I am not familiar with KDE much, so I don't know what to enable. I know that there could be issues between Neon and Ubuntu packages, so we kept this minimal.
https://github.com/armbian/build/blob/main/config/desktop/noble/environments/kde-neon/config_base/packages
Tested boards are moving to /dl
Thank you for help.
Posted (edited)
I have an Orange Pi Zero 3, Opi z2w, Opi z LTS, and Banana Pi M2 Zero.
If the OS image is not in your download page, does it mean you don't need help with these boards?
I didn't have any problems with opiz3 Armbian.com or self built image ever (last time I tried was 2 months ago). The others: haven't used in 1 year.
Edited by robertoj
Boards that've tested:
NanoPC T6 LTS:
  • Kernel: Vendor (6.1) - Current (6.18)
  • Variant: Desktop - Gnome
What was tested:
  1. GPU works as expected
  2. WI-FI Card works as expected
  3. NVME, eMMC, SPI and SD Card works as expected
  4. Ethernets: 2x 2.5GbE works as expected
  5. HDMI both works as expected
  6. AUDIO: HDMI & via jack works as expected
  7. HDMI-IN video works as expected
NanoPi M5:
What was tested: Image not boot, i have to investigate more, The previous image works without any problems.
I will check soon and maybe migrate it to mainline uboot :)
@Igor Can you do a double check if your board have the same issue?
What was tested with the new build:
  3. NVME, SPI and SD Card works as expected
  4. UFS: I have to working on it, maybe with new mainline patches that will add the support on it
  5. Ethernets: 2x 1GbE works as expected
  6. HDMI both works as expected
  7. AUDIO: HDMI & via jack works as expected
NanoPi R76S:
What was tested:
  3. eMMC and SD Card works as expected
  6. AUDIO: HDMI works as expected
All are interesting. However, H3, H5 and H6 boards will receive additional fixing to DVFS during this week. After that, I will rebuild them, but those are all CSC, so there are additional tasks:
We only generate and test boards with at least "standard support", where a known maintainer is around. If you (or someone else) step up as a maintainer:
https://docs.armbian.com/User-Guide_Board-Support-Rules/
following by PR as such
https://github.com/armbian/build/pull/8981
boards will automatically be added to automatically generated build lists
https://github.armbian.com/release-targets/targets-release-standard-support.yaml
and images can be (auto) generated:
https://docs.armbian.com/Process_CI/#automation-for-developers-and-maintainers
If you wanna cover those steps, report status at release periods, step up.
In most cases, boards work but during those tests we usually always found something to fix. And boot loader compilation is checked this way - end user upgrades don't upgrade that by default so you could be running a board for years while freshly build images would have borked uboot ...
Perfect - new use case: Armbian QA :)
Board: MKS-Klipad50
Images:
* Armbian_26.2.1_Mksklipad50_noble_current_6.18.8_minimal.img.xz
* Armbian_26.2.1_Mksklipad50_trixie_current_6.18.8_minimal.img.xz
Passed tests:
* gpg and sha checksum files
* boot from emmc, leds, display, touch, usb, internal wifi
* initial setup, uboot-console, full klipper/klipperscreen install, reboot
Result: All expected images do exist, verify and work properly.
Posted (edited)
The last update installed a broken firmware package which prevents the system from rebooting and there is no heartbeat.
This is the tail end of the upgrade:
Preparing to unpack .../40-libnss-myhostname_255.4-1ubuntu8.14_arm64.deb ...
Unpacking libnss-myhostname:arm64 (255.4-1ubuntu8.14) over (255.4-1ubuntu8.12) ...
Errors were encountered while processing:
 /tmp/apt-dpkg-install-QRewUS/02-armbian-firmware_26.2.1_all.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
Since the install is on the internal eMMc that pretty much prevents any recovery
So just retested.  Brand new download and reburnt image to eMMc.   Booted completed install setup.  Performed a sudo apt update and sudo apt upgrade and it immediately breaks and becomes non bootable.
Armbian 26.05
Test images: https://fi.mirror.armbian.de/incoming/igorpecovnik/
Tested by me:
- x86 and arm64 UEFI images
- Odroid M1
- Radxa 5T https://paste.armbian.com/jizuhuweru
- Inovato Quadra
- RPi 400
- Musepipro
- Orangepi 5 Plus (vendor BROKEN, wrong DT)
- Odroid N2 https://paste.armbian.com/ipoyatajuj
- Nanopi M4V2 https://paste.armbian.com/rewiqijizi
- Nanopi R4S https://paste.armbian.com/sesemehohi
- NanoPC T6 LTS / plus https://paste.armbian.com/cupifefofe
- Nanopi R6S/C https://paste.armbian.com/igesulided
  • Igor changed the title to How you can help test upcoming Armbian 26.05 images?
Board: MKS-Klipad50
Images:
* Armbian_26.5.1_Mksklipad50_resolute_current_6.18.33_minimal.img.xz
* Armbian_26.5.1_Mksklipad50_trixie_current_6.18.33_minimal.img.xz
Passed tests:
* initial setup, uboot-console, reboot
Sidenote: The Klipper ecosystem does not yet run on Ubuntu-Resolute (Python-3.14 incompatibility), but that shouldn't be a stopper for the release.
Board: Orangepione
Testing results for the three available images.  Should there be more images available?
Armbian_26.5.1_Orangepione_resolute_current_6.18.33_minimal.img
Tested working:
Boot from SD card with uboot and then to a USB SSD.
Reboot
Connect via ssh
iperf3 after installing iperf3
gpio after installing gpiod
HDMI video
HDMI audio after installing mpg123
Used usb keyboard/mouse to test HDMI.
Note that resolute now uses gpiod for gpio instead of sys. Gpiod had to be installed whereas trixie minimal comes with gpiod installed.
Armbian_2Armbian_26.5.1_Orangepione_trixie_current_6.18.33_minimal.img
Tested working:
Reboot
Connect via ssh
gpio
HDMI video
Armbian_26.5.1_Orangepione_resolute_current_6.18.33_xfce_desktop.img
Tested working:
Reboot
On HDMI connecter screen with usb keyboard/mouse
Using terminal emulatori tested perf3 and gpio
HDMI audio with vlc media player.
Not working:
Ran chromium to get to Armbian download page but took over a minute for each page to load and then the system crashed.
With only 512MB RAM this system is under powered for general purpose desktop use.
ubuntu_resolute_minimal.txt debian_trixie_minimal.txt ubuntu_resolute_xfce.txt
NanoPi M5 test report for 26.5.1 vendor images
Board: NanoPi M5
Boot media: SD card
Kernel branch tested: vendor 6.1.115
Test scope: quick first-boot / first-login / desktop smoke test only. I mainly tested the vendor kernel images because my intended use case requires vendor kernel support, especially for NPU-related use later.
1. Image: `Armbian_26.5.1_Nanopi-m5_resolute_vendor_6.1.115_gnome_desktop.img.xz`
Result: OK
What worked:
* Booted from SD card successfully.
* Armbian initial configuration completed successfully.
* After initial configuration, the GNOME desktop started normally.
* I was able to enter the desktop and open a few basic applications.
Notes:
* I did not do a full hardware validation in this round.
* I did not collect serial logs because the image reached the desktop successfully.
2. Image: `Armbian_26.5.1_Nanopi-m5_resolute_vendor_6.1.115_kde-plasma_desktop.img.xz`
Result: FAILED
What worked:
* Armbian initial configuration started normally.
What did not work:
* The system got stuck at the Armbian first-login / initialization screen when it was supposed to start the desktop.
* It did not proceed to a usable KDE Plasma desktop.
Notes:
* I only did a basic desktop startup test.
* I have not collected serial logs yet, but I can retest and provide logs if needed.
3. Image: `Armbian_26.5.1_Nanopi-m5_trixie_vendor_6.1.115_minimal.img.xz`
Result: CLI OK, XFCE installation failed
What worked:
* Login to the terminal worked normally.
* Basic CLI usage appeared normal.
What did not work:
* I tried installing XFCE through `armbian-config`, using the XFCE mid option.
* The desktop package dependencies appeared to download successfully.
* After that, the screen switched to a black screen with a blinking terminal cursor in the top-left corner.
* I waited for about 10 minutes, but it stayed stuck there and did not continue to a usable desktop.
Notes:
* The base minimal image itself seemed to work correctly from the terminal.
* The issue happened during or after the XFCE installation/startup process via `armbian-config`.
* I have not collected detailed logs yet, but I can retest and provide logs if needed.
Summary:
* `resolute_vendor_6.1.115_gnome_desktop`: boots from SD card and reaches GNOME desktop successfully.
* `resolute_vendor_6.1.115_kde-plasma_desktop`: boots from SD card, but gets stuck at the Armbian first-login / initialization screen and does not reach KDE Plasma.
* `trixie_vendor_6.1.115_minimal`: boots from SD card and CLI works, but installing XFCE mid through `armbian-config` gets stuck on a black screen with a blinking cursor.
Board: Orangepi3-lts
Images:
* Armbian_26.5.1_Orangepi3-lts_trixie_current_6.18.33_minimal.img.xz
Passed tests:
* SHA-256  passed
All below testing done via wired and wireless console connection(headless)
* initial setup passed
* create main user passed
* update/upgrade check as root passed
* log in as created user pass
* update/upgrade check as the created user passed
Result: All tested images do exist, are verified, and work properly
