Cute.  I'll have to get out the Kapton tape before I go adding a heat sink to this little guy to avoid accidents... ;)  Power consumption numbers on it would be interesting to see, especially if this is as cheap as I would hope given the low connector count and the SoC being a "cost-improved" model of the S905(x) family.
Now, it would be really fun to be able to buy this with nothing but the HDMI populated to use like a SOM.
I hope a media player experience will be improved sooner or later. @TonyMac32 I see only two holes for heatsink mounting (probably). I hope it just a prototype issue.
  On 10/11/2018 at 1:50 PM, vlad59 said:
2 mounting holes on the same side will make any heatsink design "mechanically interesting"
Expand
This is exactly the reason why I think it is just a prototype or they have a different purpose (I hope not).
The two holes are for eMMC module securement. You can use double sided stickie stuff since the heat dissipation isn't that bad at 1.2GHz.
@Da XueI'm afraid you will have many complains about lack of SD card. I mean It would be good to have a big flashing banner >>[[ There is no SD card folks ]]<<
  On 10/12/2018 at 12:28 PM, Igor_K said:
lack of SD card
Expand
instead 128Mb SPI NOR or buy eMMC.  Yes, it is better to advise in advance than getting a bad reputation. I couldn't agree more.
Edit:
customized booting of upstream Linux from a variety of sources including USB flash drives,  USB hard drives  and PXE.
Edited by Tido
added the other media
smart! :thumbup:  the connector the user normally only touches once (HDMI, Network, Powering) is on the back-side and connectors which are touched more often (USB) are on the front (assuming IR is normally on the front side). A bit risky but IMO interesting is to throw out the microSD slot. It may solve a bunch of those support questions which end normally here: https://forum.armbian.com/forum/31-sd-card-and-power-supply/ (at least the SD related ones :P) and 12MB SPI flash is more than enough. :thumbup: IMO an important 'what if' question:
  • What if I mess up the bootloader and brick it? I'm not familiar with enough with Amlogic SoCs, are they 'failsave' to unbrick SPI once it's messed up (e.g. something like RKs recovery tools?). I've a talent in messing up u-boot, luckily this only happened on SD-card (of fail-save sunxi) yet, where it wasn't much an issue.
I probably pledge for a 1gb version if there are still some left for 19$ when I'm back at home.. :P Not that I'm interested in Kodi on Linux stuff, still a mystery to me why people want Kodi on Linux (anyway, I don't need to understand everything)..  But I appreciate your contribution towards mainline support for hardware accelerated video en/decoding and it could be a cute little IoT end-node for systems where you can't trust that your device doesn't magically disappears (others would call it someone steals your stuff). At least potential confidential information of this node is not in the wrong hands as soon as they cut power. A cute little toy to get a feeling for PXE related stuff.
  On 10/12/2018 at 6:48 PM, Igor_K said:
@chwe just out of my curiosity what is a better option in your opinion?
Expand
Well, I'm likely the wrong person for such a topic (I don't even own an TV anymore :ph34r: the last one got trashed after some big caps inside dried out and I wasn't comfortable to solder high voltage caps inside a TV - I don't miss it). I watch streams on my Ipad. But if I would go back to streaming on TV I would probably go for an android TV box which gets regular updates (well, this board supports android as well so why not) or something like an apple TV. I happily waste hours in bringing up some IoT stuff or server stuff to my boards, but I wouldn't have the nerves to 'teach my TV' what I expect from it.. :lol: If my android box/appleTV doesn't do what it is supposed to do I can piss off their customers service - at least they get payed for it. If it doesn't work on linux I mostly had to piss off people doing this in their spare time (something I don't want) or doing the work on my own to get it working (IMO not worth my time - not experienced to solve such issues in a reasonable time frame).
If you know (partly) what you're doing go out and bring up kodi on linux, if you're just a consumer which then complains that "but it doesn't run as smooth as I expected" go for a android box and complain there that it doesn't work, they'll likely just ignore you whereas in 'opensource linux world' someone is again and again polite enough to explain you why *random codec* doesn't run smoothly yet. But we have people here more familiar/interested with such task here. E.g. @JMCC or @balbes150 do amazing work here for multimedia on arm-linux. Besides a waveshare knock off on an RPi3 all HDMIs on my SBCs are still unused..  (you need an HDMI connector? I can unsolder them with a heatgun, I won't miss them... :lol:).
The cool kid in those days has a TV box with linux, cause even the uncool kid can buy and set up an android TV box.. If it does the needed research to buy the right board and invest the time needed to bring his board up properly working :thumbup: if you just buy *random crap* to complain after its that it's not perfect.. Please go somewhere else.. for example drinking crafts beer, it's also cool in those days. :P
Expand
and others may wonder were you place your stuff :o
  On 10/13/2018 at 6:48 AM, Igor_K said:
"TV box with Linux" means TV box with Android?
Expand
technically yes. Android is based on Linux. How is: "still a mystery to me why people want Kodi on Linux where you have root access per default" sounding? :lol:
Well people say then this could also be possible for Android. The fist definition with an exception for Android.. I do understand, people might not feel comfortable anymore to potentially share all their information with google they balance privacy concerns against business opportunities every day (well, it's a company, per definition a company has to make profit so if the software is for free, you pay with your data - not clear to me why people don't get this) but going away from a "free beer for your data" company towards *something else* comes normally with a price.
I'm going off topic here:
  Reveal hidden contents
Expand
the BUZZ-word term for it is to my knowledge 'shared workspace' or 'workplace as a service' sorry, not familiar with the newest bull-shit terms anymore.. :lol:
Still interested if someone has an answer towards this one:
Expand
Where are all those Amlogic hackers being familiar with their boot logic?
Missed the 19$ for 1GB pledge.. hmm @Da Xue is your PSU/eMMC worth 20$?:lol: The eMMC will likely collecting dust cause I want to do PXE stuff with it, but having one might be good in case I go for another of your products in the future, looks sane to me that they're compatible to each other :):thumbup:
You sell:
USB Type A to USB Type A cable for programming eMMC with vendor tools.
Expand
AML-S905X-CC, well I assume the same approach works for S805X but also SPI NOR?
Too bad the best perks have already gone...
I was not fast enough.
The ones that are left are interesting too, but more expensive.
May I expect a support for this board one of these days?
  On 10/17/2018 at 4:07 AM, TonyMac32 said:
but a proposal for support needs to be under the board bringup thread
Expand
then it should be a real 'proposal' with an intention to contribute to the board bring up process.. If it's just an 'I want armbian on it' but don't even summarize specs and a pro/cons, better keep it here..  @constantius thread was merged from development subforum (but not board bring up) by myself to this one cause it didn't make sense to have a second thread with the same infos yo get here.  We have a search engine to spot such threads before you've to open a new one:
Before the board isn't on the table it IMO doesn't make sense to discuss a 'board bring up'..
Expand
Correct of course.  In theory this should be straightforward, but only experience will tell for sure.
Now that this is getting closer to physically existing (ideally I'll have one soon, whether we support it here or not)
1) No SD initially worried me because of the normal proprietary loaders/etc.  However we support FEL on Sunxi, UMS on Tinker, and @Neil Armstrong / BayLibre is shoving a ton of patches to get the Amlogic USB boot support into u-boot (2018.11?)
2) SPI flash for u-boot, or at least the u-boot environment.  I don't have all the details, but if done correctly this board could keep a consistent hardware profile across distros (MAC address/etc).  ASUS tried this halfway, but didn't go full on for a SPI flash boot.
3) The SoC is a Meson64, and has nothing to do with an S805, so think low-power S905X
4) This thing should be able to run in very low power mode, assuming the Amlogic blob behaves.
Until the campaign ends and they send the boards, I should receive one (1GB). I'll be able to test if there is any armbian build for it.
I'm impressed (if verified when testing the board) by the current support status of this board. It often requires several months (years) when we look at existing boards (even if open source communities are doing a really great job).
Expand
It is extremely helpful that this is billed as a low-cost S905X.  What I've read so far just basically says it's a clocked down Meson GXL with a few missing hardware supports (Max 1 GB RAM, 1080p, simpler vdec, etc). So software support should be mainly the same drivers, just a sparser device tree (I'm obviously glossing over some specifics that could be theoretically be an issue, but this is nothing like using an all-new SoC).
