From the log I see: Model: Radxa ROCK 5B 272910 bytes read in 34 ms (7.7 MiB/s) I would expect Radxa ROCK 5B+ Or is it 1 DTB nowadays? The bytes read should represent the DTB file that is loaded, I use extlinux so can see what files are loaded, seems this 2025.10 build does not show this. Also be aware it first tries EFI booting, it fails as one can see, so no issue here, but I got confused on my ROCK5B (not the newer upgraded + board) because I had an NVME connectod with a working bootaa64.efi grub.cfg etc as well, so it booted something else than the image from SD-card. I was my own tuned rootfs, so was rather easy to see, but other occasion I did not notice and wasted a lot of time. For this case, what does the kernel spit out ? set loglevel to 7 in armbianEnv.txt
Try what? Do I need to guess what "the most current stable Armbian" is ? Best post an URL + sha256sum what you are doing/using. In theory, I could fairly easy merge it into booting in a KVM, it has then properly working (virtual) RTC from the host (ROCK5B or NanoPi-R6C or RPi4B), but likely needs generic Debian Trixie kernel+initrd/(DTB). That can hide potential errors with your hardware, like a dangling wire in your cable or RJ45 connector or duplicate DHCPserver in LAN or worse (criminals). Or you have ethernet time protocol working, various ethernet HW supports it, like on RPi. Or what do you use to manage your network? Recently netplan.io got pushed, that was a disaster for me, such that I banned Ubuntu now.
Thanks geoW, I look to be having some success with the 25.2.3 build I just have to see if it survives the ugrades
In general it can be done what you want. You just need to understand how Arm SBCs boot/work and Linux in general. Simply stated, it is: ROM -> bootloader -> kernel -> userspace ROM is very specific for the SoC of course, also bootloader is specific as well as the kernel. You can make a kernel that includes all various drivers and methods, like there is for x86 (works with Intel chips and AMD chips). userspace (rootfs) is normally generic, so if you take RPi bootloader+kernel and Libre userspace, it can work. I have done such things several times, but then the other way around: RPi userspace from my 5 years always in-place upgraded rootfs running on Rockchip RK3588 SBCs (Armbian bootloader and kernel). That way no lengthy and boring re-install of all sorts of debian packages and configs tuning etc. Even browser bookmarks are the same then. So very fast up and running with the new SBC. You need to know or start to study the differences in bootloader methods of course. In your case looking into the Libre script/tool would be a good start I think.
From the serial_log.txt I can conclude that your SPI-flash must be empty, as it uses the u-boot version that is on the SD-card. So if you also don't have an eMMC attatched, that is now more simple. It is that older legacy based U-Boot, so should work with kernel 6.1.x. But kernellogging level is default set to 1, so I cannot see from the txt file what kernel it is, it might be older 6.1.x, I had lots of trouble with those. At least the 6.1.115 runs very solid on my ROCK3A now; it does all I/O I want: SPI, NVME, SATA (and SD-card as well but slot normally empty). This U-Boot: root@rock3a:~# strings /dev/mtdblock0 | grep "U-Boot SPL 20" U-Boot SPL 2017.09-armbian (May 20 2024 - 00:46:51) You can set loglevel to 7 in armbianEnv.txt (or directly on kernel commandline is more generic), then you see much more what is going on, it even might spit out info about crashing itself. A key thing for ROCK3A is to have proper PSU: Mine is never stable with whatever 5V only PSU, so also not the RPI5 PSU for example. Various U-Boot versions don't support USB-C PD, so I just soldered my own USB-C cable/connector that I connect to a 12V old car battery or some random 12V PSU that can do 2A or so. Then the onboard DC-DC converter is used to create a stable 5V etc. I don't remember how the ROCK3C should be powered, also not sure if it has own DC-DC converter onboard, so in that case it is just 5V and you are quite dependent on the quality of your PSU. If only an SD-card, it should be fine, but when PCIe is used fort NVME, I think expect freezes. Also think what you want with the ROCK3C; If you want a generic Arm64 Linux computer, you might be better off with 'edge' (both u-boot and kernel). You can't use quite some specific RK35xx features, but should be stable and easier to maintain. You can always compile/build an image yourself.
@Nick A do you know how to remove key ring error? [🐳|🌱] git: Fetch from remote completed, rev-parsing... [ 'debootstrap-debian-devel' 'master' 'FETCH_HEAD' ] [🐳|🌱] Debootstrap version [ '1.0.142' for /armbian/cache/sources/debootstrap-debian-devel/debootstrap ] [🐳|🌱] Installing base system with 5 packages [ Stage 1/2 ] [🐳|🔨] I: Retrieving InRelease [🐳|🔨] I: Checking Release signature [🐳|🔨] E: Release signed by unknown key (key id F8D2585B8783D481) [🐳|🔨] The specified keyring /usr/share/keyrings/debian-archive-keyring.gpg may be incorrect or out of date. [🐳|🔨] You can find the latest Debian release key at https://ftp-master.debian.org/keys.html [🐳|💥] error! [ Debootstrap first stage failed /armbian/cache/sources/debootstrap-debian-devel/debootstrap bookworm yes ]
Thanks a lot @Nick A I will give a try now. I see few more device support added on your fork https://github.com/NickAlilovic/build Can I get the change log only for IK316/H616 with LPDDR2 RAM support? I would like to sync those changes with the most recent upstream source code.
These are forums for Armbian Linux, not Android.
Did someone managed to make it work on this model below? I tried creating the image with different allwinner chips but its not booting when I burn the sd and insert on the device. The tv box is a Mortal T1 Android 13 2gb ram and 16gb rom
I am glad that you have the first 15% done: get your kernel module in the OS, and the uboot accepting the DTBO Now you are stuck in correcting the DTS, so that it configures the SPI pins correctly. My last advice for you (through this stage) is: make sure you don't have anything else using SPI pins. Deactivate "spi_dev" in armbian-config. Since I only had experience with H3 and H618 CPUs, I can't help with confidence. Post your question in the appropriate Rockchip forum section for up-to-date reliable advice. I can say that Radxa/Waveshare DTS is very out of date: it uses the fb_ili9486, which is "framebuffer" (poor fps), instead of the modern "DRM" display driver (high fps, will allow wayland). You should stay with that DTS with fb_ili9486, because it is still the closest starting point for you, and when you have it working, claiming all the GPIO pins needed, I can help again to use the DRM driver panel-mipi-dbi. Regarding MISO and MOSI, I only meant to change that nomenclature in the graphic that you show in the forum. I did't mean to change it in the DTS, if that's how other people make it work. Maybe you need to have the full linux source, so you can decompile the DTBO correctly, showing the gpio pin addresses or symbols. Is it possible that you get the Radxa/Waveshare original DTS? - Yesterday
@thanh_tan You found one armbian image to boot on Orangepi4A?
We don't deal with Android here. Ask vendor or at some place like xda developer forums.
Hi @djurny, Yes it’s nice to tinker just so busy/tired that I’m not even doing that on the Windows side anymore. Still like the helios64 and would love to bring it up and running stable when needed, was just curious if worth the effort so looking for some success stories. I only plan to use it as a handy backup device which does sound strange for something unsupported. I think I’m still on buster as well on the sd card and never had the instability issues discussed around here (I think I mostly let it run 3 or 4 days at once in the first couple of years just to see if anything happens and did not). But I do read around here every couple of weeks. Thank you for your time!
I used the latest official image for a brand new install and set up OMV afterwards. So far everything works, but I ran into the "sata-reboot" bug. That said: Once I reboot after an update for example the sata drive is not being recognized. M2 nvme does come up as usual but not the sata ssd. Only remedy: Shutdown the M1, unplug, replug power cable and this cold reboot does the trick and the sata drive comes up again properly. It seems to be a kernel bug somehow and via armbian-config I tried several kernels but the bug unfortunately persists. Any ideas?
I tried several options, each time on a clean system. 1) echo "deb http://apt.armbian.com bookworm main bookworm-utils" | sudo tee /etc/apt/sources.list.d/armbian.list wget -qO - https://apt.armbian.com/armbian.key | sudo gpg --dearmor -o /etc/apt/trusted.gpg.d/armbian.gpg sudo apt-get update sudo apt-get install make sudo apt-get install git sudo apt-get upgrade sudo reboot sudo apt install linux-headers-current-meson64 -y git clone https://github.com/xProbe/aic8800d80-wifi-driver.git sudo cp aic.rules /lib/udev/rules.d/ sudo cp -r ./fw/aic8800D80 /lib/firmware/ cd ./drivers/aic8800 make sudo make install sudo modprobe aic8800_fdrv lsmod | grep aic Вывод aic8800_fdrv 499712 0 aic_load_fw 65536 1 aic8800_fdrv cfg80211 385024 3 mac80211,rtl8xxxu,aic8800_fdrv dmesg выдаёт: [ 14.463892] Bluetooth: hci0: command 0xfc18 tx timeout [ 14.471627] Bluetooth: hci0: BCM: failed to write update baudrate (-110) [ 14.477696] Bluetooth: hci0: Failed to set baudrate [ 14.765636] wlan0: authenticate with 58:f8:5c:58:72:6c (local address=00:c6:a 2:25:44:eb) [ 14.770507] systemd[1]: Finished armbian-ramlog.service - Armbian memory supp orted logging. [ 14.772632] wlan0: send auth to 58:f8:5c:58:72:6c (try 1/3) [ 14.783084] wlan0: authenticated [ 14.791828] wlan0: associate with 58:f8:5c:58:72:6c (try 1/3) [ 14.796409] wlan0: RX AssocResp from 58:f8:5c:58:72:6c (capab=0x411 status=0 aid=4) [ 14.803902] usb 1-2: rtl8xxxu_bss_info_changed: HT supported [ 14.809513] wlan0: associated [ 14.809799] systemd[1]: Starting systemd-journald.service - Journal Service.. . [ 14.972227] systemd-journald[1340]: Collecting audit messages is disabled. [ 15.122032] systemd[1]: Started systemd-journald.service - Journal Service. [ 15.252235] systemd-journald[1340]: Received client request to flush runtime journal. [ 15.342582] systemd-journald[1340]: /var/log/journal/d44cb1f74dea4809a2af30db 6816ca18/system.journal: Realtime clock jumped backwards relative to last journa l entry, rotating. [ 15.410914] systemd-journald[1340]: Rotating system journal. [ 16.511866] Bluetooth: hci0: command 0xfc18 tx timeout [ 16.514129] Bluetooth: hci0: BCM: Reset failed (-110) [ 17.317977] systemd-journald[1340]: Received client request to relinquish /va r/log/journal/d44cb1f74dea4809a2af30db6816ca18 access. [ 950.587521] aic_load_fw: loading out-of-tree module taints kernel. [ 950.600781] aic_bluetooth_mod_init [ 950.606085] RELEASE DATE:2025_0423_71b66e7b [ 950.611193] AICWFDBG(LOGINFO) aicwf_prealloc_init enter [ 950.635622] AICWFDBG(LOGINFO) pre alloc rxbuff list len: 1000 [ 950.640969] usbcore: registered new interface driver aic_load_fw [ 950.678054] AICWFDBG(LOGINFO) rwnx v6.4.3.0 - 1a4b0054d2M (master) [ 950.680449] AICWFDBG(LOGINFO) RELEASE DATE:2025_0423_71b66e7b [ 950.686449] usbcore: registered new interface driver aic8800_fdrv 2) 3) 4) I tried it, it didn't help. 5)
keep pushing, this device is not brickable, you can make your trip worry-free -
try and tell us
Because they sell you the hardware only. Their software support is very poorly made since for the price they cannot afford proper software support and - even more important - maintenance. They leave this burden to - mostly unpaid - random developers across the world like us. At least I'd go for a device with Standard Support which the Ultra and Max hasn't: https://www.armbian.com/download/?device_support=Standard support For the raspberry you would need additional hardware (an AI kit I guess). No clue though about how they both perform in comparsion. For RK3588 you have two choices for now: The rockchip bsp implementation and https://github.com/rockchip-linux/rknn-toolkit2. Or using 6.18 kernel using the reverse engineered Rocket driver and latest bleeding edge mesa to get npu access. I personally did not play with either of these options and have no intention to do so for the moment.
Armbian 25.8.1 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + wine-10.15-staging-tkg-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.15) + DXVK-stripped v2.7.1 ~20fps@720p (low settings) Skyrim SE -
I have a working img that boots fine from sd card. However the dtb is not perfectly working. Below are dts from android and linux (partial working). I hope that someone can help me with rewriting device tree source for it. Thank you! rk3399-emb3531.dts.txtrk3399-emb3531-android.dts.txt
Scroll back and read all my posts from April 11 onwards (page 17). On Radxa's github there are Wifi/BT drivers for AIC8800. They are at version 4 now : https://github.com/radxa-pkg/aic8800/releases/tag/4.0%2Bgit20250410.b99ca8b6-3 Also to fix BT : sudo crontab -e then add the line : @reboot sudo hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep then reboot the H96. -
We are slowly releasing v25.11 images and here I did some mess-up, fixed now. We don't offer Bookworm anymore, so Trixie it is. If you need to Bookworm for some reason, you can build on your own or use the one from archive: http://archive.armbian.com/ Attached torrent will download super fast. Armbian_25.11.1_Helios64_trixie_current_6.12.58_minimal.img.xz.torrent
Im trying to flash armbian into the eMMC but its not detected, only the SD card. What should i do? Useful info: CPU/Chip/Idk: sun8iw7p1 PCB Model(?): H3 Q44 V4.0 Uname -a: Linux orangepipcplus 6.12.58-current-sunxi #1 SMP Thu Nov 13 20:34:41 UTC 2025 armv7l GNU/Linux dmesg | grep -i mmc [ 0.000000] Kernel command line: root=UUID=cf60c629-17b3-4fb8-91bb-24bd021f8c6b rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=def8ba6d-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory [ 0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=def8ba6d-01 ubootsource=mmc sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory", will be passed to user space. [ 4.995824] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 5.019105] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB [ 5.031030] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB [ 5.048053] mmc2: Failed to initialize a non-removable card [ 5.063249] mmc0: host does not support reading read-only switch, assuming write-enable [ 5.067129] mmc0: new high speed SDXC card at address aaaa [ 5.071189] mmcblk0: mmc0:aaaa SC64G 59.5 GiB [ 5.080563] mmcblk0: p1 [ 5.316321] ubootsource=mmc [ 7.603641] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq [ 7.635175] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB [ 7.687081] mmc1: new high speed SDIO card at address 0001 [ 8.364751] EXT4-fs (mmcblk0p1): mounted filesystem cf60c629-17b3-4fb8-91bb-24bd021f8c6b ro with writeback data mode. Quota mode: none. [ 14.091111] EXT4-fs (mmcblk0p1): re-mounted cf60c629-17b3-4fb8-91bb-24bd021f8c6b r/w. dmesg | grep -i mmc2 [ 5.048053] mmc2: Failed to initialize a non-removable card I also extracted a DTB file and DTS file from the android of the TV box, if that is useful (I used AI for that, and dont really know if they are useful) Thanks. dts.txt
