Igor Posted May 13, 2023 Posted May 13, 2023 I made a first round of testing, some manually: khadas edge 2, installed to eMMC, logs: https://paste.armbian.com/iviwutanag bananapi m2+, installed to eMMC, logs: orangepi lite2, logs: https://paste.armbian.com/awicabotod khadas vim1, installed to eMMC, logs: https://paste.armbian.com/ulopiziseb , maintainer needed khadas vim2, installed to eMMC, logs: https://paste.armbian.com/editiyaziv orangepi2e, installed to eMMC, logs: https://paste.armbian.com/ekuyaporil and some via auto-testing machinery. Most of images works: Reveal hidden contents We need to fix Rpi4, Jetson nano, perhaps other media?
Igor Posted May 18, 2023 Author Posted May 18, 2023 More tests done by @rpardini - khadas-vim3 - rockpro64 - Tinkerboard 2 - Odroid M1 - Rpi 4b - T95Z Plus - Mekotronics R58x - khadas-vim3l - Radxa Zero2
Igor Posted May 19, 2023 Author Posted May 19, 2023 More tests by @jock - Orange Pi 4 LTS (rk3399) - Radxa Rock-Pi E (rk3328) - a couple of tvboxes rk3318/rk3328
schwar3kat Posted May 22, 2023 Posted May 22, 2023 - Orange Pi PC - Pine64 Images boot (xfce_desktop), network connection functions (iperf3). USB ports function, HDMI video and audio work. 1
Igor Posted May 22, 2023 Author Posted May 22, 2023 Rock 3a (Armbian_23.5.0-trunk.219_Rock-3a_jammy_edge_6.3.3_minimal.img.xz) also tested by @monkaBlyat installed gnome DE network working hdmi / audio jack sound output working all 4 usb ports working image boot nice and smooth without issues from sd card
TonyMac32 Posted May 23, 2023 Posted May 23, 2023 Le Potato -boot, hdmi audio, USB, NIC Tritium H2/3 and H5 - Boot, NIC, USB 1
teknoid Posted May 23, 2023 Posted May 23, 2023 Nanopi Neo Plus 2 (H5) linux-u-boot-nanopineoplus2-current_23.05.0-trunk--2022.07-Se092-P6b27-Ha9af-Vaada-B4b55_arm64.deb linux-image-current-sunxi64_23.05.0-trunk--6.1.26-Sca1c-D4008-P8596-C1438Hfe66-HK01ba-Vc222-Ba98e_arm64.deb OK, but distorted audio output over USB, I believe this came up since kernel 5.16+ and is still present in 6.x Banana Pi Pro (A20) linux-u-boot-bananapipro-current_23.05.0-trunk--2022.07-Se092-P6b27-H0429-Vaada-B4b55_armhf.deb linux-image-current-sunxi_23.05.0-trunk--6.1.26-Sca1c-D4008-P8596-C596bHfe66-HK01ba-V014b-Ba98e_armhf.deb OK Odroid C2 linux-u-boot-odroidc2-current_23.05.0-trunk--2022.01-Sd637-P6c67-H7ff5-V603e-B4b55_arm64.deb linux-image-current-meson64_23.05.0-trunk--6.1.27-Sca48-D4008-Pc5ba-C072bHfe66-HK01ba-Ve377-Ba98e_arm64.deb OK Armbian_23.05.0-trunk_Odroidc2_bullseye_current_6.1.29_minimal.img full image test: OK new build system is a very good improvement 👍 1
schwar3kat Posted May 23, 2023 Posted May 23, 2023 Orangepi R1 Plus LTS (RK3328) - networking issue AR-1747. Caused by one of the network interface logical names changing from eth0 to end0. I can can submit a PR to fix this with a rename in /etc/udev/rules.d/70-rename-lan.rules which is already created from a hook in the board config file (to rename the other network interface). Already tested and works as expected on current and edge, Ubuntu and Debian. Before I take this route, I'm just wondering if anyone knows a reason for this happening that could possibly lead to a better fix? I didn't find anything obvious in the PR's.
Igor Posted May 23, 2023 Author Posted May 23, 2023 On 5/23/2023 at 10:52 AM, schwar3kat said: better fix? Expand IMO lets wait a day then proceed with a proposed fix. Still better then leaving as is.
Werner Posted May 23, 2023 Posted May 23, 2023 Armbian_23.5.0-trunk.219_Station-p1_jammy_current_6.1.29_gnome_desktop - boot: first install tells "no internet connection found" but wired was connected and location based detected also worked. - HDMI video: Gnome desktop works decent on WQHD - HDMI sound could not be tested, lacking equipment - USB 2 and 3 work with mouse and keyboard - Installation to eMMC + boot w/o microSD works - Sound via 3.5 jack PARTIALLY works. Only got right channel on my headphones. Headphones work properly on other computer.
TonyMac32 Posted May 24, 2023 Posted May 24, 2023 @Werner that device is on the Media kernel, is it not? Unless I'm mistaken it isn't going to see any updates or... ?
Werner Posted May 24, 2023 Posted May 24, 2023 On 5/24/2023 at 2:14 AM, TonyMac32 said: that device is on the Media kernel, is it not? Unless I'm mistaken it isn't going to see any updates or... ? Expand Yes. Maybe all media should be moved to csc for this reason.
TonyMac32 Posted May 24, 2023 Posted May 24, 2023 Libre Computer Renegade - Boot, all USB, Gb NIC, desktop Missing audio
brentr Posted May 24, 2023 Posted May 24, 2023 RockPI-S patch to assign wlan0 a unique MAC address derived from the rk3308 serial number relied on ifconfig I need to submit a patch to switch it to use ip link set wlan0 address aa:bb:...
brentr Posted May 24, 2023 Posted May 24, 2023 RockPI-S Armbian_23.5.0-trunk.219_Rockpi-s_bookworm_current_6.1.29_minimal.img is unusable. It drops keystrokes from the serial console if one types quickly and appears to put the terminal emulator into a strange state. If one is patient enough with the keyboard, one can get through the setup, but the nmtui for connecting to WiFi cannot be used. Pressing down arrow in nmtui exits it. Is anyone else having trouble configuring the minimal bookworm images? The corresponding full image is fine. Tested: Bluetooth Ethernet WiFi audio (at least the audio devices appear and the mixer works) Boot up messages on the serial console appear to be truncated at 70 columns or so. But, that's probably someone's idea of "progress" (or, am I the only one noticing this?) As noted earlier, the system failed to assign a repeatable wlan0 MAC address due to its missing ifconfig. I'll submit a PR to fix this.
schwar3kat Posted May 24, 2023 Posted May 24, 2023 On 5/23/2023 at 11:23 AM, Igor said: IMO lets wait a day then proceed with a proposed fix. Expand PR submitted. https://github.com/armbian/build/pull/5231
balbes150 Posted May 24, 2023 Posted May 24, 2023 On 5/24/2023 at 4:06 AM, Werner said: Maybe all media should be moved to csc for this reason. Expand there are no such devices in any form on the official page (there is no point in testing them). the media kernel obtained from armbian-next is useless and dangerous for users, it should not be in network repositories (getting it on existing systems will lead to problems). the same goes for u-boot.
schwar3kat Posted May 24, 2023 Posted May 24, 2023 Orangepi zero plus Images boot, network connection functions (iperf3). USB ports function. Orangepi R1 Images boot, both ethernet ports and wifi function as expected (iperf3).
ahoneybun Posted May 24, 2023 Posted May 24, 2023 (edited) # Pinebook Pro testing ## Armbian_23.5.0-trunk.219_Pinebook-pro_jammy_current_6.1.29_gnome_desktop - Boots live disk [x] - Installs to eMMC - ext4 [x] - Fn keys works [] : NOTE F9 and F10 are swapped - Fn1 [x] - Fn2 [x] - Fn3 [] - Fn4 [x] - Fn5 [x] - Fn6 [x] - Fn7 [x] - Fn8 [] - Fn9 [] - Fn10 [] - Fn11 [] - Fn12 [] - Wi-Fi works [x] - Bluetooth works [] - Touchpad works [x] - Ports - USB-C - data [x] - USB-C - power [x] - USB-A - data [x] BUG: Screen locking does not work without GDM. ## Armbian_23.5.0-trunk.219_Pinebook-pro_jammy_current_6.1.29_xfce_desktop - Boots live disk [x] - Installs to eMMC - ext4 [x] - Fn keys works [] : NOTE F9 and F10 are swapped - ESC [] - Fn1 [x] - Fn2 [x] - Fn3 [x] - Fn4 [] - Fn5 [] - Fn6 [] - Fn7 [x] - Fn8 [] - Fn9 [] - Fn10 [] - Fn11 [] - Fn12 [] - Wi-Fi works [x] - Bluetooth works [] - Touchpad works [x] - Ports - USB-C - data [x] - USB-C - power [x] - USB-A - data [x] BUG1: Ubuntu artwork is being used instead of Armbian during live disk boot once in the desktop. Shows the Ubuntu artwork during boot once installed to eMMC, it does show Armbian artwork at login screen/desktop. BUG2: Touchpad is very jumpy. ## Armbian_23.5.0-trunk.219_Pinebook-pro_jammy_current_6.1.29_i3-wm_desktop - Boots live disk [x] - Installs to eMMC - ext4 [x] - Fn keys works [] : NOTE F9 and F10 are swapped - Fn1 [x] - Fn2 [x] - Fn3 [x] - Fn4 [] - Fn5 [] - Fn6 [] - Fn7 [x] - Fn8 [] - Fn9 [] - Fn10 [] - Fn11 [] - Fn12 [] - Wi-Fi works [x] - Bluetooth works [] - Touchpad works [x] - Ports - USB-C - data [x] - USB-C - power [x] - USB-A - data [x] BUG1: Battery indicator says no battery, I have opened a report of it here: https://armbian.atlassian.net/browse/AR-1756 BUG2: Touchpad is very jumpy. # Not tested yet ## Armbian_23.5.0-trunk.219_Pinebook-pro_jammy_current_6.1.29_minimal - Boots live disk [] - Installs to eMMC [] - Fn keys works [] - Fn1 [] - Fn2 [] - Fn3 [] - Fn4 [] - Fn5 [] - Fn6 [] - Fn7 [] - Fn8 [] - Fn9 [] - Fn10 [] - Fn11 [] - Fn12 [] - Wi-Fi works [] - Bluetooth works [] - Touchpad works [] - Ports - USB-C - data [] - USB-C - power [] - USB-A - data [] Edited May 24, 2023 by ahoneybun 1
Igor Posted May 24, 2023 Author Posted May 24, 2023 On 5/24/2023 at 5:28 AM, brentr said: It drops keystrokes from the serial console if one types quickly and appears to put the terminal emulator into a strange state. If one is patient enough with the keyboard, one can get through the setup, but the nmtui for connecting to WiFi cannot be used. Pressing down arrow in nmtui exits it. Expand I have seen this before, but some time ago. Today I have tested numerous of minimal builds on different boards and can't recreate this behaviour. I will try on Rockpi S when I get to it - its not easily accessible.
clee Posted May 26, 2023 Posted May 26, 2023 (edited) Rock Pi 4A and 4C boot to working gigabit ethernet with bookworm-current minimal image, USB ports all work. HDMI output not tested yet. Rock 3A also boots to working gigabit ethernet with jammy-edge minimal image. USB ports all work. HDMI output not tested yet here either. Rock64 also boots to working gigabit ethernet with bookworm-current minimal image. USB ports all work. HDMI output not tested. Edited May 27, 2023 by clee 1
fraz0815 Posted May 28, 2023 Posted May 28, 2023 (edited) Rock Pi-4B - Armbian_23.05.1_Rockpi-4b_jammy_current_6.1.30_gnome_desktop.img installed to emmc: logs wlan, hdmi, nvme working Rock-5B - Armbian_23.05.1_Rock-5b_jammy_legacy_5.10.160_gnome_desktop.img Took me a while to boot from SD, was using an older 23.05-trunk version. Even 'sudo dd if=zero.img of=/dev/mtdblock0' with radxa zero.img would continue to boot happily from nvme instead of sd, changed armbianEnv.txt to sd root, updated bootloaderon mtd -> worked. besides mtd being a mystical thing for me, almost anything worked: installed to mtd+nvme: logs using btrfs on nvme + mtd did not work (don't know if supported, but installer lets you pick it). performance with panfrost ppa's enabled is absolutely stunning. Btw, this time for testing I used my 45W PD PSU (+ PD C<->C Cable 60W) instead of fixed 5V@4A w/o errors and activated the max 12V PD option in armbian-config just for fun. Sensors report ed in0: 12.00 V (min = +12.00 V, max = +12.00 V) curr1: 1.50 A (max = +1.50 A) and had no reboots or whatsoever. Edited May 28, 2023 by fraz0815 added rock-5b, some PSU infos 1
Igor Posted June 12, 2023 Author Posted June 12, 2023 @Contributor/Maintainer - added missing Rockpi 4C plus - enabled Mekotronic boards https://www.armbian.com/download/?device_support=Supported&tx_maker=mekotronics - added Orangepi 5 Plus In case there is another missing or broken images, please report, here or to Jira directly https://armbian.atlassian.net/browse/AR-1765 2
