Armbian 23.05 (Suni) Testings
I made a first round of testing, some manually:
and some via auto-testing machinery. Most of images works:
We need to fix Rpi4, Jetson nano, perhaps other media?
Link to comment
Share on other sites
Donate your old hardware to community. Start a giveaway Raffle!
More tests done by @rpardini
- khadas-vim3
- rockpro64
- Tinkerboard 2
- Odroid M1
- Rpi 4b
- T95Z Plus
- Mekotronics R58x
- khadas-vim3l
- Radxa Zero2
Link to comment
More tests by @jock
- Orange Pi 4 LTS (rk3399)
- Radxa Rock-Pi E (rk3328)
- a couple of tvboxes rk3318/rk3328
Link to comment
  • Igor pinned this topic
Rock 3a (Armbian_23.5.0-trunk.219_Rock-3a_jammy_edge_6.3.3_minimal.img.xz) also tested by @monkaBlyat
  • installed gnome DE
  • network working
  • hdmi / audio jack sound output working
  • all 4 usb ports working
  • image boot nice and smooth without issues from sd card
Link to comment
Nanopi Neo Plus 2 (H5)
linux-u-boot-nanopineoplus2-current_23.05.0-trunk--2022.07-Se092-P6b27-Ha9af-Vaada-B4b55_arm64.deb
linux-image-current-sunxi64_23.05.0-trunk--6.1.26-Sca1c-D4008-P8596-C1438Hfe66-HK01ba-Vc222-Ba98e_arm64.deb
OK, but distorted audio output over USB, I believe this came up since kernel 5.16+ and is still present in 6.x
Banana Pi Pro (A20)
linux-u-boot-bananapipro-current_23.05.0-trunk--2022.07-Se092-P6b27-H0429-Vaada-B4b55_armhf.deb
linux-image-current-sunxi_23.05.0-trunk--6.1.26-Sca1c-D4008-P8596-C596bHfe66-HK01ba-V014b-Ba98e_armhf.deb
OK
Odroid C2
linux-u-boot-odroidc2-current_23.05.0-trunk--2022.01-Sd637-P6c67-H7ff5-V603e-B4b55_arm64.deb
linux-image-current-meson64_23.05.0-trunk--6.1.27-Sca48-D4008-Pc5ba-C072bHfe66-HK01ba-Ve377-Ba98e_arm64.deb
OK
Armbian_23.05.0-trunk_Odroidc2_bullseye_current_6.1.29_minimal.img
full image test: OK
new build system is a very good improvement 👍
Link to comment
Orangepi R1 Plus LTS (RK3328) - networking issue AR-1747.
Caused by one of the network interface logical names changing from eth0 to end0.
I can can submit a PR to fix this with a rename in /etc/udev/rules.d/70-rename-lan.rules which is already created from a hook in the board config file (to rename the other network interface).  Already tested and works as expected on current and edge, Ubuntu and Debian.
Before I take this route, I'm just wondering if anyone knows a reason for this happening that could possibly lead to a better fix?  I didn't find anything obvious in the PR's.
Link to comment
31 minutes ago, schwar3kat said:
better fix?
IMO lets wait a day then proceed with a proposed fix. Still better then leaving as is.
Link to comment
Armbian_23.5.0-trunk.219_Station-p1_jammy_current_6.1.29_gnome_desktop
- boot: first install tells "no internet connection found" but wired was connected and location based detected also worked.
- HDMI video: Gnome desktop works decent on WQHD
- HDMI sound could not be tested, lacking equipment
- USB 2 and 3 work with mouse and keyboard
- Installation to eMMC + boot w/o microSD works
- Sound via 3.5 jack  PARTIALLY works. Only got right channel on my headphones. Headphones work properly on other computer.
Link to comment
RockPI-S
Armbian_23.5.0-trunk.219_Rockpi-s_bookworm_current_6.1.29_minimal.img
is unusable.  It drops keystrokes from the serial console if one types quickly and appears to put the terminal emulator into a strange state.
If one is patient enough with the keyboard, one can get through the setup, but the nmtui for connecting to WiFi cannot be used.
Pressing down arrow in nmtui exits it.
Is anyone else having trouble configuring the minimal bookworm images?
The corresponding full image is fine.
Tested:
  Bluetooth
  Ethernet
  WiFi
  audio (at least the audio devices appear and the mixer works)
Boot up messages on the serial console appear to be truncated at 70 columns or so.
But, that's probably someone's idea of "progress"
(or, am I the only one noticing this?)
As noted earlier, the system failed to assign a repeatable wlan0 MAC address due to its missing ifconfig.
I'll submit a PR to fix this.
Link to comment
2 часа назад, Werner сказал:
Maybe all media should be moved to csc for this reason.
there are no such devices in any form on the official page (there is no point in testing them). the media kernel obtained from armbian-next is useless and dangerous for users, it should not be in network repositories (getting it on existing systems will lead to problems). the same goes for u-boot.
Link to comment
# Pinebook Pro testing
## Armbian_23.5.0-trunk.219_Pinebook-pro_jammy_current_6.1.29_gnome_desktop
- Boots live disk [x]
- Installs to eMMC - ext4 [x]
   - Fn keys works [] : NOTE F9 and F10 are swapped
      - Fn1 [x]
      - Fn2 [x]
      - Fn3 []
      - Fn4 [x]
      - Fn5 [x]
      - Fn6 [x]
      - Fn7 [x]
      - Fn8 []
      - Fn9 []
      - Fn10 []
      - Fn11 []
      - Fn12 []
   - Wi-Fi works [x]
   - Bluetooth works []
   - Touchpad works [x]
      - Ports
      - USB-C - data [x]
      - USB-C - power [x]
      - USB-A - data [x]
BUG: Screen locking does not work without GDM.
## Armbian_23.5.0-trunk.219_Pinebook-pro_jammy_current_6.1.29_xfce_desktop
      - ESC []
      - Fn1 [x]
      - Fn2 [x]
      - Fn3 [x]
      - Fn4 []
      - Fn5 []
      - Fn6 []
      - Fn7 [x]
      - Fn8 []
      - Fn9 []
      - Fn10 []
      - Fn11 []
      - Fn12 []
   - Wi-Fi works [x]
      - Ports
      - USB-C - data [x]
      - USB-C - power [x]
      - USB-A - data [x]
BUG1: Ubuntu artwork is being used instead of Armbian during live disk boot once in the desktop. Shows the Ubuntu artwork during boot once installed to eMMC, it does show Armbian artwork at login screen/desktop.
BUG2: Touchpad is very jumpy.
## Armbian_23.5.0-trunk.219_Pinebook-pro_jammy_current_6.1.29_i3-wm_desktop
      - Fn1 [x]
      - Fn2 [x]
      - Fn3 [x]
      - Fn4 []
      - Fn5 []
      - Fn6 []
      - Fn7 [x]
      - Fn8 []
      - Fn9 []
      - Fn10 []
      - Fn11 []
      - Fn12 []
   - Wi-Fi works [x]
   - Ports
      - USB-C - data [x]
      - USB-C - power [x]
      - USB-A - data [x]
BUG1: Battery indicator says no battery, I have opened a report of it here: https://armbian.atlassian.net/browse/AR-1756
# Not tested yet
## Armbian_23.5.0-trunk.219_Pinebook-pro_jammy_current_6.1.29_minimal
- Boots live disk []
- Installs to eMMC []
   - Fn keys works []
      - Fn1 []
      - Fn2 []
      - Fn3 []
      - Fn4 []
      - Fn5 []
      - Fn6 []
      - Fn7 []
      - Fn8 []
      - Fn9 []
      - Fn10 []
      - Fn11 []
      - Fn12 []
   - Wi-Fi works []
   - Touchpad works []
      - Ports
      - USB-C - data []
      - USB-C - power []
      - USB-A - data []
Edited by ahoneybun
Link to comment
I have seen this before, but some time ago. Today I have tested numerous of minimal builds on different boards and can't recreate this behaviour. I will try on Rockpi S when I get to it - its not easily accessible.
Link to comment
Rock Pi 4A and 4C boot to working gigabit ethernet with bookworm-current minimal image, USB ports all work. HDMI output not tested yet.
Rock 3A also boots to working gigabit ethernet with jammy-edge minimal image. USB ports all work. HDMI output not tested yet here either.
Rock64 also boots to working gigabit ethernet with bookworm-current minimal image. USB ports all work. HDMI output not tested.
Edited by clee
Link to comment
Rock Pi-4B - Armbian_23.05.1_Rockpi-4b_jammy_current_6.1.30_gnome_desktop.img
installed to emmc: logs
wlan, hdmi, nvme working
Rock-5B - Armbian_23.05.1_Rock-5b_jammy_legacy_5.10.160_gnome_desktop.img
Took me a while to boot from SD, was using an older 23.05-trunk version.
Even 'sudo dd if=zero.img of=/dev/mtdblock0' with radxa zero.img would continue to boot happily from nvme instead of sd, changed armbianEnv.txt to sd root, updated bootloaderon mtd -> worked.
besides mtd being a mystical thing for me, almost anything worked:
installed to mtd+nvme: logs
using btrfs on nvme + mtd did not work (don't know if supported, but installer lets you pick it).
performance with panfrost ppa's enabled is absolutely stunning.
Btw, this time for testing I used my 45W PD PSU (+ PD C<->C Cable 60W) instead of fixed 5V@4A w/o errors and activated the max 12V PD option in armbian-config just for fun.
Sensors report ed
in0:          12.00 V  (min = +12.00 V, max = +12.00 V)
curr1:         1.50 A  (max =  +1.50 A)
and had no reboots or whatsoever.
Edited by fraz0815
added rock-5b, some PSU infos
Link to comment
