hjc Posted June 3, 2018 Posted June 3, 2018 Recently I've been trying to build Armbian for Firefly RK3399, since I've purchased this board last year, and it has been lacking proper software support for a long time. Here is my fork https://github.com/hjc4869/build/tree/development Basically, It is a copy & paste of what's already done to support Odroid N1, by replacing the Hardkernel's kernel to what Firefly provides (an older 4.4.77 kernel), and replacing the Hardkernel u-boot with rockchip u-boot. I created a new 'firefly' board family for convenience. Also tried to build the image with some other kernel variants (Rockchip 4.4 bsp and mainline 4.17-rc6) without success, still investigating reasons. The image boots and runs flawlessly as a headless OS, but that's far from complete. Remaining work: Kernel 1. Replace mali r13 driver with r14. Since r14 supports fbdev and xf86-video-armsoc while r13 does not. Fbdev performance is terrible, though. 2. (Maybe) Use the latest rockchip 4.4.126 kernel instead of Firefly's old (and buggy) 4.4.77, since this branch seems to be a port-and-forget one, while Rockchip kernel is still been actively developed. Userland 1. Rockchip xserver and libmali This makes the desktop experience much better (glamor, and enables GLES for X11 window programs), but there are some problems related to desktop composition. In Firefly's official Ubuntu release, the desktop composition works just fine, but I haven't figure out how to enable that with my own build. Firefly team never provide any scripts/docs to build a usable rootfs. Even without this, the desktop is definitely usable, including Chromium/Firefox, with mesa llvmpipe properly disabled. 2. Firmware Rockchip's rootfs-build repo contains several firmware required by the board (WiFi/BT/DP/etc). These firmware are currently not packed into the image. 3. Rockchip Gstreamer for hardware video decoding 4. Bluetooth This is troublesome even with Firefly's own Ubuntu image. They put some sort of magic in a `/usr/local/bin/enable_bt` script, and it must be executed right after user logon, or Bluetooth simply won't work. Really terribly documented, never want to mess up with it again. 5. Sound The board uses a rt5640 chip, which needs some tweaks related to ALSA. Most userland tweaks are likely to be the same as other RK3399 boards, given the only difference should be bootloader/kernel related stuff. Will it be possible to merge these into armbian/build as a community supported board in the future when RK3399 board family gets stable? (Of course with cleanup, e.g. use the rk3399 board family instead of a dedicated firefly family)
TonyMac32 Posted June 3, 2018 Posted June 3, 2018 Someone in the devs would need the hardware. As these RK3399 boards are a bit expensive to buy without need, I'm not sure that will happen. Some ideas though, should you put together a solid PR against the Armbian build system: Kernel: Mali Midgard, right? current rockchip is r18, but there are some config woes. Rockchip x: yes, there are some issues, @JMCC is better understanding from his work on RK3288, the other "fast" Rockchip processor. He has the 3288 set up for mali and mpp, once we get the newest Rockchip drop stabilized again... Firmware: Can be pushed to the appropriate folder in the build system. Rockchip gstreamer: See my earlier statement, gstreamer is not the only option. :-) Bluetooth: AP6356S, is this correct? You may want to completely ignore the rockchip bluetooth rfkill system and use something like (obviously different based on the chip/gpio's/HCIattach used):https://github.com/armbian/build/commit/ac8d0d86687007c894caf18b0ba85d99c38eb8b1#diff-720eab911ea238eb515a7dd36d99234e The service calls the script on boot and enables it, then, if called again, resets the BT and re-initializes it. It also required defining the UART fully in the DTS, as by default, at least on Tinker it didn't have the CTS and RTS assigned under the UART. Sound: can be adjusted during image build time in the script (Tinker does this, as do some others IIRC) For a merge, you would need to make the needed changes and put in a PR, and some more discussion would have to go on about the potential risks/etc of supporting it.
Igor Posted June 3, 2018 Posted June 3, 2018 17 minutes ago, hjc said: Will it be possible to merge these into armbian/build as a community supported board in the future Sure, why not, but we need to stick to one RK3399 family and for CSC targets it is recommended that atf and u-boot patches - if needed - are defined per board. The best legacy kernel is probably from Pine64 or/and Rockchip upstream while I am not aware how far is mainline support. Currently, we haven't done much - we have few Odroids N1 and we are about to get FriendlyArm T4, ... so I expect more progress with RK3399 during the summer time.
TonyMac32 Posted June 3, 2018 Posted June 3, 2018 3 minutes ago, Igor said: we have few Odroids N1 and we are about to get FriendlyArm T4 My addiction got the best of me and I picked up a RockPro 64 as well. ;-) OK, back to the cellar... 2
hjc Posted June 4, 2018 Author Posted June 4, 2018 17 hours ago, Igor said: The best legacy kernel is probably from Pine64 or/and Rockchip upstream while I am not aware how far is mainline support. Managed to boot rockchip kernel with two patches (this and this), so far it worked fine (headlessly. Mali Android drivers are causing compiler errors). These two patches are just to revert two commits in rockchip kernel (first and second). The first change is causing strange clock issues on Firefly board, and the second one causes a kernel panic. These may be board specific issues. AFAIK RockPro64's kernel source included these changes (Odroid N1 and NanoPC T4 did not). Maybe I should keep my fork and wait for a few more months, until it is decided which specific rk3399 kernel source will be used by other boards.
hjc Posted June 4, 2018 Author Posted June 4, 2018 https://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip.git/ Got this kernel booted up successfully (tag v4.18-rockchip-drivers-2). Haven't confirmed what's working and what's not. 1
TonyMac32 Posted June 4, 2018 Posted June 4, 2018 3 hours ago, hjc said: Mali Android drivers are causing compiler errors) Yes, TinkerBoard is likewise all messed up wrt Mali drivers with latest Rockchip updates. Enable the mali_pwrsoft option.
guidol Posted June 9, 2018 Posted June 9, 2018 On 6/4/2018 at 6:48 PM, hjc said: https://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip.git/ Got this kernel booted up successfully (tag v4.18-rockchip-drivers-2). Haven't confirmed what's working and what's not. and it seems you did this also at the NanoPC T4? - https://twitter.com/hjc4869/status/1005321514432933888
hjc Posted June 9, 2018 Author Posted June 9, 2018 31 minutes ago, guidol said: and it seems you did this also at the NanoPC T4? - https://twitter.com/hjc4869/status/1005321514432933888 Yes, with some patches, in the same repo. Only succeeded to boot the 4.4 legacy kernel, though. Copy the device tree from FriendlyELEC's kernel, and it boots with Rockchip u-boot and kernel. Their kernel modifications are mostly for their accessories, like several LCD screens, touch screens, etc. It's a rough port, especially for u-boot. Since T4 does not have upstream u-boot support, and I only spent a few minutes creating the dts file from the Linux one. (Still a lot of bugs, like USB is not functional, so you cannot load kernel from a USB device. but that's sufficient for booting linux kernel from emmc/sd) As for 4.17 mainline kernel, it's still far from complete. 1. CPU-bound tasks are not pinned to the Cortex-A72 core automatically 2. HDMI not working 3. USB3/USB-C not working so I did not spend time investigating on that running on T4. It may be a lot better later this year, though. 2
chwe Posted June 9, 2018 Posted June 9, 2018 On 6/3/2018 at 9:52 PM, Igor said: The best legacy kernel is probably from Pine64 or/and Rockchip upstream while I am not aware how far is mainline support. Let's hope that they don't mess up the kernel to much/often, so that a 'rockchip-default' branch is not often needed to bring back the devices... Having all RK devices under the same kernelsource (with different kernelconfigs for RK3288/RK3328/RK3399 could be beneficial due to only one kernel has to be checked for updates). On 6/3/2018 at 9:15 PM, hjc said: This makes the desktop experience much better (glamor, and enables GLES for X11 window programs), but there are some problems related to desktop composition. In Firefly's official Ubuntu release, the desktop composition works just fine, but I haven't figure out how to enable that with my own build. Firefly team never provide any scripts/docs to build a usable rootfs. You may discuss with @JMCC he did a lot of tests and adjustments for the RK3288 with HW-acceleration (I think also for desktop). Probably he has some useful tips.
hjc Posted June 11, 2018 Author Posted June 11, 2018 On 6/9/2018 at 5:41 PM, guidol said: and it seems you did this also at the NanoPC T4? - https://twitter.com/hjc4869/status/1005321514432933888 Update: Tried to boot the 4.17 kernel on NanoPC T4. Works, but same issues as Firefly RK3399 above. It seems that RK3399's upstream support still needs some time to complete, especially for newer boards. 1
chwe Posted June 11, 2018 Posted June 11, 2018 small hint: by disable https://github.com/hjc4869/armbian-build/blob/58af252c2b7c3acb6160f7ea456c56ef8f7412b6/config/kernel/linux-firefly-dev.config#L50 you should get rid of the 'g42568f34-dirty' in your kernel naming. 1
JMCC Posted June 11, 2018 Posted June 11, 2018 On 6/3/2018 at 9:15 PM, hjc said: This makes the desktop experience much better (glamor, and enables GLES for X11 window programs), but there are some problems related to desktop composition. From my many tests with the RK3288, regarding desktop composition you have basically four options: Use framebuffer, so you will have no 3D nor video acceleration, but you will be able to enable desktop compositing. Use the rockchip xf86-video-armsoc driver: It will provide 3D and video accel, though with very poor performance. You can enable desktop compositing, with an even higher performance loss. Use a version of the Rockchip X server with glamor enabled, that has this commit reverted. It will give you good performance, but will be unstable. You can choose either to use the commit referenced here (not available in the main tree), or the older rockchip-1.18 branch. But those are unstable, and the old version doesn't have video vsync. Use the rockchip-1.19 version of the driver, which does not allow compositing, but is stable and gives good performance in everything else. Personally, I don't think compositing is worth losing all the other features. Plus, it is possible that future versions of the mali driver can fix the issue. More info here. 1
codnoscope Posted June 13, 2018 Posted June 13, 2018 (edited) It seems OP overclocked his firefly RK3399 to 2.2GHz! Very nice! Have you tried the offical aluminium case for your firefly? There is a internal aluminium "piller" the push against the CPU so the entire case acts as a large heat sink. https://shop.t-firefly.com/goods.php?id=62 Edited June 13, 2018 by codnoscope
hjc Posted June 13, 2018 Author Posted June 13, 2018 5 hours ago, codnoscope said: It seems OP overclocked his firefly RK3399 to 2.2GHz! Very nice! Overclock isn't really recommended, and I'm just doing that for fun. Though, 2.2/1.8GHz is the max supported clock speed in Rockchip's driver code, so it's not really "over"clocking. There's a slight performance gain, but it does not mean that you can run workloads that you can't do before the overclock. (In other words, it does not change the board's use case) It just made the numbers a little better, by significantly sacrificing power consumption and cooling. 5 hours ago, codnoscope said: Have you tried the offical aluminium case for your firefly? No, I don't think that it could be more efficient than a fan.
martinayotte Posted August 3, 2018 Posted August 3, 2018 @hjc, I've used your dev tree to make an image for my newly received NanoPC-T4 ! Thanks for your work ! Do you planing having this effort merged into main branch by issuing a PR ? 1
TonyMac32 Posted August 3, 2018 Posted August 3, 2018 @martinayotte I'm glad you said something, I was going to start playing with that in the next few days. Do you have a RockPro64?
tkaiser Posted August 3, 2018 Posted August 3, 2018 1 hour ago, martinayotte said: Do you planing having this effort merged into main branch by issuing a PR ? The discussion how to proceed with the various upstream kernel branches for RK devices started and unfortunately also ended here: https://forum.armbian.com/topic/7498-nanopc-t4/ (no idea why there are zero responses to @ayufan's ideas) Same here: https://forum.armbian.com/topic/7661-one-bsp-kernel-f-rk3399rk3328-and-rk3288/?do=findComment&comment=58352
hjc Posted August 3, 2018 Author Posted August 3, 2018 5 hours ago, martinayotte said: @hjc, I've used your dev tree to make an image for my newly received NanoPC-T4 ! Thanks for your work ! Do you planing having this effort merged into main branch by issuing a PR ? I'd be glad to do so, but recently I've just graduated and begun working full time, and not having much time to re-organize those development efforts into a solid PR. I'm also lack of usable RK3399 boards for developing & testing, since some of my home services have already been deployed to NanoPC T4. I'll buy some NanoPi M4/NEO4 boards once available. Besides, I still have some other boards to play with (Dragonboard 820c based on Qualcomm APQ8096), so maybe I could not contribute to Armbian for RK3399 directly these days. Sorry for that.
martinayotte Posted August 3, 2018 Posted August 3, 2018 11 hours ago, TonyMac32 said: Do you have a RockPro64? Hi Tony ! Yes, I've received one last week. But until now, I'm only been able to run it with Ayufan build stretch-minimal-rockpro64-0.7.9-1067-arm64.img.xz, trying the image built for T4 on it didn't even start booting.
martinayotte Posted August 3, 2018 Posted August 3, 2018 7 hours ago, hjc said: Sorry for that. No problem, I understand ... Time is always the missing ingredient (for me too) ! I didn't compared your tree with the Armbian master yet, is there tons of changes or only few ?
martinayotte Posted August 3, 2018 Posted August 3, 2018 10 hours ago, tkaiser said: unfortunately also ended here Yes, that's why searching for some work already done ends me here with @hjc work ...
hjc Posted August 3, 2018 Author Posted August 3, 2018 1 hour ago, martinayotte said: No problem, I understand ... Time is always the missing ingredient (for me too) ! I didn't compared your tree with the Armbian master yet, is there tons of changes or only few ? Only a few changes. It's basically about creating a new board family with appropriate kernel/u-boot config and patches (called "firefly" here, but actually should be called rockchip64) and adding two boards' definition (Firefly-RK3399 & NanoPC T4). see https://github.com/hjc4869/armbian-build/compare/56d614d1e5cb4d7ec3c803cfcf83bbe5bad04622...6d59a4fc93b46fd4de86bc8b1fa6a0adee4e7bc4
martinayotte Posted August 3, 2018 Posted August 3, 2018 @hjc Thanks for doing the compare from your side, that way, I won't forget something. I will try to merge that from my side as soon as "time ingredient" get back in stock ...
hjc Posted August 11, 2018 Author Posted August 11, 2018 I've fixed the build on GitHub, and it now uses latest 4.4.143 kernel from rockchip. Armbian seems to have changed a lot in recent days, haven't got time to rebase my work.,and haven't verified what works and what does not, but at least it builds and runs on my Firefly RK3399 (NanoPC T4 not tested).
jerryg Posted August 11, 2018 Posted August 11, 2018 Thanks @hjc I was able to boot Xenial desktop on my T4 from a Vagrant build.
Igor Posted August 11, 2018 Posted August 11, 2018 @martinayotte @hjc Successfully merged. https://github.com/armbian/build/commit/6d82a8974872ee261006d2cdf6726b7d13df5032 2
TonyMac32 Posted August 12, 2018 Posted August 12, 2018 Very nice, built a 4.4 image, working well so far! Need to dig up an nvme, suggestions on an affordable one? My build machine and main desktop aren't giving up theirs. ;-)
Igor Posted August 12, 2018 Posted August 12, 2018 1 hour ago, TonyMac32 said: Need to dig up an nvme, suggestions on an affordable one? Samsung OEM SM961 512GB, new or used is also good enough for such use, 150-100USD? Yes, works well. Some small things, overclock, @JMCC media scripting, ...
martinayotte Posted August 12, 2018 Posted August 12, 2018 15 hours ago, Igor said: Successfully merged. Did you tried also to build a Mainline ? ...
