Myy Posted July 1, 2018 Posted July 1, 2018 Okay, I've been able to boot an Armbian and I'm now trying to get a mainline kernel working. I've been able to get a seemingly working HDMI output, but I got no Ethernet and the logs were spammed about some iio.device and dwmc3 devices badly configured, in my port of @hjc DTSI and DTS. Also getting to X11 takes at least 30 seconds. Anyway here are the issues I encountered https://github.com/Miouyouyou/RockMyy64/issues I'll play with the RK3399 again next week. Meanwhile, I guess I'll take a tour of all the others repositories mentioned, see if at least I could solve a few issues. Also, since my repository also generates fragmentation, I guess I should add in the README that, yes, you can take, and modify, my patches and do whatever you want with them.
ayufan Posted July 16, 2018 Posted July 16, 2018 I actively rebase my kernel on top of rockchip-linux to keep a list of patches somehow compact. My current workflow is not very good for community contribution, still: this is rebase of commit history, but I'm happy to change that. One thing that is probably unique about my kernel that I release a new kernel version after every: https://gitlab.com/ayufan-repos/rock64/linux-kernel/ and https://github.com/ayufan-rock64/linux-kernel and this is released as debian packages that you can put on any distro and apt-get install: http://deb.ayufan.eu/ayufan-rock64/linux-kernel. In my latest builds, I effectively moved from building kernel each time to installing kernel/u-boot package for simplicity and split of responsibility (single resp repository). Anyway. I don't want to be a bottleneck, so I would say that the best would be to start a new common repo branch and rebase all our work on this branch, give a few people review/merging capabilities and based the work on the good will of people. I know that being alone and reviewing/accepting is a job that can get boring, as you also need to ensure the quality, splitting the responsibility here is desirable. Now, I do all the stuff there myself, but also I only have to check rock64/rockpro64 which is to be fair not a lot of hurdle for me, but with more dependence on this work we simply need more people. I somehow like the rebase workflow that we always keep a small number of patches, but I'm fine with merge workflow too 2
Carlos Eduardo De Paula Posted July 23, 2018 Posted July 23, 2018 Hey guys, since I've recently got a couple of RK3399 boards (FriendlyARM NanoPC-T4, Firefly RK3399 and OrangePi RK3399), I'm trying to get the best option for my use cases that is server workloads in a Kubernetes cluster lab to test new technologies. There are a couple of articles on https://medium.com/@carlosedp. The Linux distributions the manufacturers create are usually bloated (with desktop software) and with missing Kernel options and modules so I've been in a crusade to build the kernels suited to these boards. The first thing I've found is that each board have it's own kernel tree and lots of DTSs and DTSIs differ from each other. I've built the base Rockchip kernel for both but had to fiddle and replace files to build the DTBs for each board. Do you guys have any news on integrating all this mess maybe into Rockchip or the Mainline kernel trees? Is there anything that I can help? Thanks!
Igor Posted August 7, 2018 Posted August 7, 2018 I have to boot it and I have one NvME SAMSUNG MZVKW512HMJP (960 PRO OEM 512GB) drive lying around so I did some tests with: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 CPU settings were the same. FriendlyARM Bionic image: random random kB reclen write rewrite read reread read write 102400 4 41338 78901 99988 100857 45198 78653 102400 16 139298 214581 231273 233098 104223 208826 102400 512 484706 533139 479387 489203 430695 533633 102400 1024 528153 570248 501469 511199 477028 567310 102400 16384 566544 586036 563672 576738 573686 582514 Armbian from here https://github.com/hjc4869/armbian-build/issues/1 (could not build my own - have to try again later) random random kB reclen write rewrite read reread read write 102400 4 49152 74567 92929 93279 41268 69268 102400 16 156724 234831 294344 254141 101716 236869 102400 512 958208 1027143 952072 983620 582711 1044034 102400 1024 1064030 1127356 1007844 1036058 743726 1123484 102400 16384 1127636 1189732 1097192 1139916 1107548 1071900 Why is Armbian I/O so much faster? 1
tkaiser Posted August 8, 2018 Author Posted August 8, 2018 11 hours ago, Igor said: Why is Armbian I/O so much faster? Since https://forum.armbian.com/topic/7310-rockpro64/?do=findComment&comment=56184 There's PCIe link training but if DT defines a conservative link speed then no higher speeds will be negotiated. Checking lspci output is mandatory in such cases (and that's the reason why I added this to our hardware logging. But I don't remember whether lspci is present on Armbian images by default or not) Edit: the kernel version and settings matter too of course. With RK's 4.4 there's /sys/module/pcie_aspm/parameters/policy which defaults to powersave.
tkaiser Posted August 8, 2018 Author Posted August 8, 2018 18 hours ago, Igor said: Why is Armbian I/O so much faster? BTW: in case you re-test can you please test also with a much larger test data size? iozone -e -I -a -s 1000M -r 1024k -r 16384k -i 0 -i 1 See https://forum.armbian.com/topic/1925-some-storage-benchmarks-on-sbcs/?do=findComment&comment=51350 -- with your SSD combined with RK3399 and mainline kernel when using the 'right' benchmark even 1.6GB/s can be measured. Here ayufan's scores from RockPro64 also using the same Samsung SSD: https://gist.github.com/ayufan/30c46381c5e4e5c5264a834a752946db
Igor Posted August 12, 2018 Posted August 12, 2018 On 8/8/2018 at 2:46 PM, tkaiser said: BTW: in case you re-test can you please test also with a much larger test data size? It doesn't help. It's even slower on 4.18 http://ix.io/1jXb
tkaiser Posted August 12, 2018 Author Posted August 12, 2018 1 hour ago, Igor said: It doesn't help Did you prefix the iozone call with 'taskset -c 4-5 '?
Igor Posted August 12, 2018 Posted August 12, 2018 11 hours ago, tkaiser said: Did you prefix the iozone call with 'taskset -c 4-5 '? Now I did. K4.4 until mainline is not sorted out. Better! Spoiler kB reclen write rewrite read reread 1024000 1024 1279569 1307621 1243836 1252293 1024000 16384 1292840 1322563 1267157 1272861
tkaiser Posted August 16, 2018 Author Posted August 16, 2018 So in the end we discussed a lot and then @Igor decided to use another kernel branch: https://github.com/armbian/build/blob/6d82a8974872ee261006d2cdf6726b7d13df5032/config/sources/rk3399.conf#L34
Igor Posted August 16, 2018 Posted August 16, 2018 36 minutes ago, tkaiser said: So in the end we discussed a lot and then @Igor decided to use another kernel branch: https://github.com/armbian/build/blob/6d82a8974872ee261006d2cdf6726b7d13df5032/config/sources/rk3399.conf#L34 I only merged the working configuration without major changes. Step one.
s_frit Posted August 16, 2018 Posted August 16, 2018 On 6/18/2018 at 12:26 AM, tkaiser said: heatsink too small for continous loads Are the heatsink mounting holes compatible with "every Northbridge cooler with a mounting hole distance of 60 mm" as for the RockPro64?
TonyMac32 Posted August 16, 2018 Posted August 16, 2018 15 hours ago, tkaiser said: decided to use another kernel We'll, there's very little difference in them fundamentally, it should take very little work to say Ayufan instead of Rockchip. I can try it and we can just swap. Same for RK3288
TonyMac32 Posted August 17, 2018 Posted August 17, 2018 I know this is irrelevant, but it's too cool for me not share: (Rockchip kernel 4.4 via HJC's work, Samsung 256 GB Disk /dev/nvme0n1: 238.5 GiB, 256060514304 bytes, 500118192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 63148 98717 117726 103704 32253 74841 102400 16 200588 282047 286796 312951 89631 242632 102400 512 472102 577041 458541 430672 540748 557106 102400 1024 506514 560837 485540 455210 498891 576875 102400 16384 951626 994023 920260 996905 973086 994344 Command line used: iozone -e -I -a -s 1000M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 1024000 4 72776 85094 109072 121242 34017 98562 1024000 16 221422 302439 331772 333805 88144 290576 1024000 512 565209 639164 465860 473754 602073 599450 1024000 1024 759673 793099 669950 684237 721181 748267 1024000 16384 1045977 1095899 1070003 1079163 1075869 1066718
konstantin Posted August 30, 2018 Posted August 30, 2018 Hello. I tried Armbian build based on Ubuntu. Feels better than official friendlyelec's builds, interface is much much more responcive, but I have two problems with Armbian: If I start fullscreen video from youtube (checking on this video) it stucks approximately at 2.5 minute. Picture freezes and repeated sound sample, not responding to anything. Tried it on Chromium, on Firefox and even with Smtube, everytime stucks at approximately same place. What is the problem? Video memory leaking and filling all the place? or what? On official builds I didn't have this problem (but there was plenty others). And second problem - Synaptic. Search in Synaptic is dead slow. It takes about 15 minutes ant uses about 16% of CPU according to the Monitor. When searching and after package installation, when returning to the same search list. Strange thing, but on official builds it works as fast as on desktop. Based on same Ubuntu. Do not know, should I create another topic? As I see all about NanoPC-T4 is happening here for now.
Igor Posted August 30, 2018 Posted August 30, 2018 2 hours ago, konstantin said: And second problem - Synaptic. Search in Synaptic is dead slow. https://forum.armbian.com/topic/8021-orange-pi-one-synaptic-package-manager-search-very-slow/ 2 hours ago, konstantin said: If I start fullscreen video from youtube https://forum.armbian.com/topic/8043-orange-pi-one-general-performance-browser-performance/?do=findComment&comment=60618 I have to add here that I don't know how is with video acceleration in general with this board, so "playing outside the browser" might not solve anything ... yet. 2 hours ago, konstantin said: should I create another topic? No, but start to use forum search first. We talked about many times:https://www.armbian.com/search I found both answers in less than 10seconds.
JMCC Posted August 30, 2018 Posted August 30, 2018 1 hour ago, Igor said: I have to add here that I don't know how is with video acceleration in general with this board, Within the web browser, basically quite as good as RK3288 and XU4. That means that it can play up to 1080p@30 youtube smoothly. Outside the browser, MPV and Gstreamer can play 4K@60 with no problem. But, as is the case for RK3288 and XU4, you need to configure it first; that is what my media scripts do. I already made a media script, but it was 32-bit, based on the RK3288 one (with God's help, I plan to make a 64-bit version, now that the board reached the WIP status). The link for the 32-bit script is a few posts above, together with some test results about the SoC GPU and VPU capabilities:
Malz Posted September 19, 2018 Posted September 19, 2018 Hi, I tried Armbian on my NanoPC-T4 and installed it to eMMC using ‚armbian-config‘. I wanted to try the official FriendlyELEC image, but the ‚eflasher‘ utility doesn’t recognise any eMMC. Then I tried booting from Armbian from SD and using ‚armbian-config‘ again to check if it recognised, but the option for installing to eMMC isn‘t present anymore. I can still boot Armbian from eMMC but can‘t install anything new to eMMC. Are there any advices for fixing the problem?
tkaiser Posted September 19, 2018 Author Posted September 19, 2018 1 hour ago, Malz said: I can still boot Armbian from eMMC but can‘t install anything new to eMMC. Are there any advices for fixing the problem? Boot priority with Rockchip boards is AFAIK always eMMC first then SD card. So once RK3399 finds a bootloader signature on the eMMC it will boot from there even if a bootable SD card is inserted. If you want to reflash eMMC in this situation you either need to use Maskrom mode (or how it's called exactly) which requires another host and USB delete the bootloader on the eMMC (can be done from the running system: 'dd if=/dev/null of=/dev/mmcblk1 bs=1M count=64 ; sync') I successfully bricked my NanoPC-T4 while developing with nand-sata-install and now have working bootloader on the eMMC that is not able to boot a kernel so I'm locked out and would need to try variants 2) or 3) here: http://wiki.friendlyarm.com/wiki/index.php/NanoPC-T4#Flash_Image_to_eMMC (which is not that easy since my physical x86 machines all run macOS and my Linux boxes are all ARM based -- I might try a VM with USB pass-thru soon) I asked @mindee for help but his advice to boot an eflasher image from SD card doesn't work since I have a working bootloader on the eMMC (but an otherwise bricked system). Would be great to temporarily disable the eMMC as it can be done on Rock64 and RockPro64 (a jumper allows the eMMC to be grounded or something like that so you can boot with this jumper set from a bootable SD card inserted and if you remove the jumper within 2 seconds after boot you can even access the eMMC afterwards to flash a new image)
chwe Posted September 19, 2018 Posted September 19, 2018 1 hour ago, tkaiser said: either need to use Maskrom mode (or how it's called exactly) which requires another host and USB did you try https://github.com/rockchip-linux/rkdeveloptool? And then a 'rkdeveloptool ef' might do it.. As far as I see this is plain c++ without any blobs so you could probably compile it on one of your arm boards as well.. chwe@chwe-acer:~$ rkdeveloptool ---------------------Tool Usage --------------------- Help: -h or --help Version: -v or --version ListDevice: ld DownloadBoot: db <Loader> UpgradeLoader: ul <Loader> ReadLBA: rl <BeginSec> <SectorLen> <File> WriteLBA: wl <BeginSec> <File> WriteLBA: wlx <PartitionName> <File> WriteGPT: gpt <gpt partition table> WriteParameter: prm <parameter> PrintPartition: ppt EraseFlash: ef TestDevice: td ResetDevice: rd [subcode] ReadFlashID: rid ReadFlashInfo: rfi ReadChipInfo: rci ReadCapability: rcb PackBootLoader: pack UnpackBootLoader: unpack <boot loader> TagSPL: tagspl <tag> <U-Boot SPL> -------------------------------------------------------
hjc Posted September 19, 2018 Posted September 19, 2018 1 hour ago, tkaiser said: Boot priority with Rockchip boards is AFAIK always eMMC first then SD card. Rockchip boot sequence is typically BOOTROM -> u-boot SPL -> u-boot, AFAIK bootrom tries eMMC first, but u-boot SPL tries loading u-boot from SD card first (reference), so if there's a valid SPL on eMMC, you might still have a chance to boot from SD...
martinayotte Posted September 19, 2018 Posted September 19, 2018 4 hours ago, tkaiser said: Would be great to temporarily disable the eMMC as it can be done on Rock64 and RockPro64 Is it not what the "boot" button does by shorting the eMMC-D0 line ? Simply press this "boot" button during "reset" for 2 seconds ....
tkaiser Posted September 19, 2018 Author Posted September 19, 2018 4 hours ago, hjc said: u-boot SPL tries loading u-boot from SD card first (reference), so if there's a valid SPL on eMMC, you might still have a chance to boot from SD... Doesn't work for me. 37 minutes ago, martinayotte said: Is it not what the "boot" button does by shorting the eMMC-D0 line ? Just tested this too and it also does not work. Quoting the wiki: Quote Press BOOT key to prevent the board from eMMC booting, making the board enter MASKROM mode Well, I need to do my homework first. Set up another SBC for serial console access (don't want to install CH340T drivers on my new MacBook), then check for a working USB-C cable and so on...
martinayotte Posted September 19, 2018 Posted September 19, 2018 4 minutes ago, tkaiser said: Just tested this too and it also does not work. It did work for me 2 weeks ago, then I've used nand-sata-install ...
tkaiser Posted September 19, 2018 Author Posted September 19, 2018 4 minutes ago, martinayotte said: It did work for me 2 weeks ago, then I've used nand-sata-install ... And you did not use nand-sata-install prior to this? Since then eMMC would've been empty anyway and booting from SD card would be normal behavior even without pressing boot button?
martinayotte Posted September 19, 2018 Posted September 19, 2018 1 minute ago, tkaiser said: And you did not use nand-sata-install prior to this? Since then eMMC would've been empty anyway and booting from SD card would be normal behavior even without pressing boot button? No, first time, it was booting some other unknown image already present if I remember. Later, I had a build done from @hjc old branch, and when I wanted to use latest Armbian, I had to press "boot" again this time. 1
Malz Posted September 19, 2018 Posted September 19, 2018 Thanks a lot! I finally fixed my eMMC problem. Booting into MASKROM and erasing flash by using Chinese Rockchip Tool let me install armbian again to eMMC. I had some problems identifying the device with the Rockchip utility. Switching from Win10 to old Win7 laptop fixed connection issues. Now trying to configure armbian as my new ‚all-in-one‘ livingroom device. Are there experiences with running Kodi on armbian?
Merblud Posted September 20, 2018 Posted September 20, 2018 Hi. Recommend what battery CMOS can be used? For example, cr2032 will normally work?
martinayotte Posted September 20, 2018 Posted September 20, 2018 2 hours ago, Merblud said: Recommend what battery CMOS can be used? For example, cr2032 will normally work? Battery for what ? For the whole board ? ... CR2032, you're kidding ...
TonyMac32 Posted September 21, 2018 Posted September 21, 2018 9 hours ago, Merblud said: Recommend what battery CMOS can be used? For example, cr2032 will normally work? For RTC? Yes, that can work.
