Beelink x2 wifi problems
Andeser
Hi guys,
I'm sorry for the english but I'm italian.
I'm a noob in Linux so I'm in search of someone that can help me.
First of all, I don't know what is the better h3 armbian version to install in it.
When i download the rtl8189es driver when i do "make" the console release error 2. Thanks a lot for the help.
Inviato dal mio Redmi 4A utilizzando Tapatalk
Link to comment
Share on other sites
Donate your old hardware to community. Start a giveaway Raffle!
Beelink X2 have different Wi-Fi hardware, more or less the last version of armbian support all the main part of the internal Wi-Fi that you can find inside the BX2. If not your case, there was a long and old forum post about running different Wi-Fi "modules" (like the Windows drivers) in armbian to bring your Wi-Fi to life. This weekend I try to search this post and help you.
Link to comment
29 minutes ago, manuti said:
Beelink X2
Depends on the version of the board - older ones have Broadcom BCM43362 in the Ampack module, newer ones have Realtek RTL8189ETV
Ethernet should work with any version as this is hosted by the H3's Designware MAC implementation...
X2 is Allwinner H3... can't remember if realtek drivers are already in the armbian kernel... if not, perhaps it should be, as the WiFi nic is pretty common these days...
worst case would be to DL the source file and kernel headers, and build it...
This post might be helpful...
Keep in mind that X2 was supported, but has moved into EOL, so one is a bit on their own...
Link to comment
2 hours ago, manuti said:
try to follow my steps long time ago ...
Ok, when I do "root@beelinkx2:~# sudo modprobe 8189es" the output is:
root@beelinkx2:~# sudo modprobe 8189es firmware_path=/lib/firmware/ap6210/8189es.bin nvram_path=/lib/firmware/ap6210/nvram.txt
modprobe: ERROR: could not insert '8189es': Unknown symbol in module, or unknown parameter (see dmesg)
The result of dmesg is:
[ 2212.371047] wifi_platform_bus_enumerate device present 0
[ 2212.371081] ======== Card detection to remove SDIO card! ========
[ 2212.371172] dhd_module_init: Failed to load the driver, try cnt 3
[ 2212.371321] ======== bcm_wlan_set_plat_data ========
[ 2212.371368] bcm_wlan_get_oob_irq enter.
[ 2212.371417] gpio [202] map to virq [10] ok
[ 2212.371447] host_oob_irq: 10
[ 2212.371475] host_oob_irq_flags=0x414
[ 2212.371504] dhd_wifi_platform_load: Enter
[ 2212.371592] Power-up adapter 'DHD generic adapter'
[ 2212.371628] wifi_platform_set_power = 1
[ 2212.371657] ======== PULL WL_REG_ON HIGH! ========
[ 2212.371691] [wifi_pm]: set wl_reg_on 0 !
[ 2212.450354] mmc1: card 0001 removed
[ 2212.450609] [mmc]: sdc1 power_supply is null
[ 2212.575663] [wifi_pm]: set wl_reg_on 1 !
[ 2213.080331] wifi_platform_bus_enumerate device present 1
[ 2213.080384] ======== Card detection to detect SDIO card! ========
[ 2213.082231] [mmc]: sdc1 power_supply is null
[ 2213.140907] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2213.142754] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2213.144588] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2213.147842] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2213.169481] mmc1: new high speed SDIO card at address 0001
[ 2213.188314] bcmsdh_register: register client driver
[ 2213.188743] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2213.189015] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2213.189058] bus num (host idx)=1, slot num (rca)=1
[ 2213.189096] found adapter info 'DHD generic adapter'
[ 2213.189256] sdioh_attach: set sd_f2_blocksize 128
[ 2213.190731] F1 signature read @0x18000000=0x1591a962
[ 2213.191538] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2213.198285] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2213.201040] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2213.203183] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2213.203467] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2213.203581] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2213.210676] wl_create_event_handler(): thread:wl_event_handler:17d0 started
[ 2213.211722] tsk Enter, tsk = 0xe6bc1430
[ 2213.212198] dhd_attach(): thread:dhd_watchdog_thread:17d1 started
[ 2213.212563] dhd_attach(): thread:dhd_dpc:17d2 started
[ 2213.212705] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2213.212939] dhd_attach(): thread:dhd_rxf:17d3 started
[ 2213.213005] dhd_deferred_work_init: work queue initialized
[ 2213.214970] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2213.215057] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2213.215112] dhdsdio_download_firmware: set use_rxchain 0
[ 2213.215150] dhdsdio_download_firmware: set txglomsize 16
[ 2213.215191] sdioh_set_mode: set txglom_mode to multi-desc
[ 2213.215226] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2213.215264] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2213.215299] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2213.225918] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2213.225989] _dhdsdio_download_firmware: dongle image file download failed
[ 2213.226132] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2213.226183] dhdsdio_probe: dhd_bus_start failed
[ 2213.226224] bcmsdh_oob_intr_unregister: Enter
[ 2213.226257] bcmsdh_oob_intr_unregister: irq is not registered
[ 2213.226299] dhd_wlfc_deinit():3301, Already disabled!
[ 2213.300185] dhd_detach(): thread:dhd_watchdog_thread:17d1 terminated OK
[ 2213.300226] dhd_detach(): thread:dhd_rxf:17d3 terminated OK
[ 2213.300270] dhd_dpc_thread: Unexpected up_cnt 0
[ 2213.300323] dhd_detach(): thread:dhd_dpc:17d2 terminated OK
[ 2213.300632] wl_event_handler: was terminated
[ 2213.300742] wl_destroy_event_handler(): thread:wl_event_handler:17d0 terminated OK
[ 2213.390492] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2213.390514] bcmsdh_probe: device attach failed
[ 2213.390524] sdioh_probe: bcmsdh_probe failed
[ 2213.390683] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2225.390203] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2225.390587] wifi_platform_set_power = 0
[ 2225.390624] ======== PULL WL_REG_ON LOW! ========
[ 2225.390661] wifi_platform_bus_enumerate device present 0
[ 2225.390697] ======== Card detection to remove SDIO card! ========
[ 2225.390849] unregister wifi platform drivers
[ 2225.390890] wifi_platform_bus_enumerate device present 0
[ 2225.390923] ======== Card detection to remove SDIO card! ========
[ 2225.391003] dhd_module_init: Failed to load the driver, try cnt 2
[ 2225.391152] ======== bcm_wlan_set_plat_data ========
[ 2225.391199] bcm_wlan_get_oob_irq enter.
[ 2225.391247] gpio [202] map to virq [10] ok
[ 2225.391278] host_oob_irq: 10
[ 2225.391305] host_oob_irq_flags=0x414
[ 2225.391334] dhd_wifi_platform_load: Enter
[ 2225.391416] Power-up adapter 'DHD generic adapter'
[ 2225.391451] wifi_platform_set_power = 1
[ 2225.391480] ======== PULL WL_REG_ON HIGH! ========
[ 2225.391515] [wifi_pm]: set wl_reg_on 0 !
[ 2225.460308] mmc1: card 0001 removed
[ 2225.460563] [mmc]: sdc1 power_supply is null
[ 2225.591601] [wifi_pm]: set wl_reg_on 1 !
[ 2226.100264] wifi_platform_bus_enumerate device present 1
[ 2226.100316] ======== Card detection to detect SDIO card! ========
[ 2226.102102] [mmc]: sdc1 power_supply is null
[ 2226.160583] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2226.162428] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2226.164270] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2226.167609] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2226.197041] mmc1: new high speed SDIO card at address 0001
[ 2226.215701] bcmsdh_register: register client driver
[ 2226.216123] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2226.216390] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2226.216433] bus num (host idx)=1, slot num (rca)=1
[ 2226.216470] found adapter info 'DHD generic adapter'
[ 2226.216644] sdioh_attach: set sd_f2_blocksize 128
[ 2226.217950] F1 signature read @0x18000000=0x1591a962
[ 2226.218520] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2226.225415] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2226.227891] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2226.230020] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2226.230434] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2226.230554] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2226.244305] tsk Enter, tsk = 0xe6bc1430
[ 2226.244395] wl_create_event_handler(): thread:wl_event_handler:17d5 started
[ 2226.252761] dhd_attach(): thread:dhd_watchdog_thread:17d7 started
[ 2226.253861] dhd_attach(): thread:dhd_dpc:17d8 started
[ 2226.254042] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2226.254472] dhd_attach(): thread:dhd_rxf:17d9 started
[ 2226.254553] dhd_deferred_work_init: work queue initialized
[ 2226.255577] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2226.255660] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2226.255714] dhdsdio_download_firmware: set use_rxchain 0
[ 2226.255752] dhdsdio_download_firmware: set txglomsize 16
[ 2226.255792] sdioh_set_mode: set txglom_mode to multi-desc
[ 2226.255827] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2226.255864] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2226.255899] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2226.257777] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2226.257848] _dhdsdio_download_firmware: dongle image file download failed
[ 2226.263210] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2226.263280] dhdsdio_probe: dhd_bus_start failed
[ 2226.263320] bcmsdh_oob_intr_unregister: Enter
[ 2226.263352] bcmsdh_oob_intr_unregister: irq is not registered
[ 2226.263396] dhd_wlfc_deinit():3301, Already disabled!
[ 2226.340169] dhd_detach(): thread:dhd_watchdog_thread:17d7 terminated OK
[ 2226.340201] dhd_detach(): thread:dhd_rxf:17d9 terminated OK
[ 2226.340222] dhd_dpc_thread: Unexpected up_cnt 0
[ 2226.340292] dhd_detach(): thread:dhd_dpc:17d8 terminated OK
[ 2226.340582] wl_event_handler: was terminated
[ 2226.340662] wl_destroy_event_handler(): thread:wl_event_handler:17d5 terminated OK
[ 2226.420510] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2226.420532] bcmsdh_probe: device attach failed
[ 2226.420542] sdioh_probe: bcmsdh_probe failed
[ 2226.420708] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2238.420095] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2238.420243] wifi_platform_set_power = 0
[ 2238.420253] ======== PULL WL_REG_ON LOW! ========
[ 2238.420262] wifi_platform_bus_enumerate device present 0
[ 2238.420271] ======== Card detection to remove SDIO card! ========
[ 2238.420330] unregister wifi platform drivers
[ 2238.420340] wifi_platform_bus_enumerate device present 0
[ 2238.420348] ======== Card detection to remove SDIO card! ========
[ 2238.420373] dhd_module_init: Failed to load the driver, try cnt 1
[ 2238.420410] ======== bcm_wlan_set_plat_data ========
[ 2238.420424] bcm_wlan_get_oob_irq enter.
[ 2238.420438] gpio [202] map to virq [10] ok
[ 2238.420446] host_oob_irq: 10
[ 2238.420452] host_oob_irq_flags=0x414
[ 2238.420459] dhd_wifi_platform_load: Enter
[ 2238.420489] Power-up adapter 'DHD generic adapter'
[ 2238.420498] wifi_platform_set_power = 1
[ 2238.420505] ======== PULL WL_REG_ON HIGH! ========
[ 2238.420514] [wifi_pm]: set wl_reg_on 0 !
[ 2238.540258] mmc1: card 0001 removed
[ 2238.540490] [mmc]: sdc1 power_supply is null
[ 2238.620541] [wifi_pm]: set wl_reg_on 1 !
[ 2239.130099] wifi_platform_bus_enumerate device present 1
[ 2239.130117] ======== Card detection to detect SDIO card! ========
[ 2239.131727] [mmc]: sdc1 power_supply is null
[ 2239.187331] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2239.188878] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2239.190441] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2239.193203] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2239.213395] mmc1: new high speed SDIO card at address 0001
[ 2239.232013] bcmsdh_register: register client driver
[ 2239.232495] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2239.232845] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2239.232892] bus num (host idx)=1, slot num (rca)=1
[ 2239.232929] found adapter info 'DHD generic adapter'
[ 2239.233113] sdioh_attach: set sd_f2_blocksize 128
[ 2239.234353] F1 signature read @0x18000000=0x1591a962
[ 2239.234925] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2239.242714] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2239.245100] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2239.247291] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2239.247577] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2239.247684] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2239.260851] wl_create_event_handler(): thread:wl_event_handler:17da started
[ 2239.260902] tsk Enter, tsk = 0xe6bc1430
[ 2239.262376] dhd_attach(): thread:dhd_watchdog_thread:17dc started
[ 2239.262776] dhd_attach(): thread:dhd_dpc:17dd started
[ 2239.262856] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2239.263156] dhd_attach(): thread:dhd_rxf:17de started
[ 2239.263235] dhd_deferred_work_init: work queue initialized
[ 2239.267005] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2239.267094] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2239.267148] dhdsdio_download_firmware: set use_rxchain 0
[ 2239.267186] dhdsdio_download_firmware: set txglomsize 16
[ 2239.267226] sdioh_set_mode: set txglom_mode to multi-desc
[ 2239.267261] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2239.267299] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2239.267333] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2239.269444] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2239.269528] _dhdsdio_download_firmware: dongle image file download failed
[ 2239.269693] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2239.269748] dhdsdio_probe: dhd_bus_start failed
[ 2239.269788] bcmsdh_oob_intr_unregister: Enter
[ 2239.269821] bcmsdh_oob_intr_unregister: irq is not registered
[ 2239.269880] dhd_wlfc_deinit():3301, Already disabled!
[ 2239.312523] dhd_detach(): thread:dhd_watchdog_thread:17dc terminated OK
[ 2239.312557] dhd_detach(): thread:dhd_rxf:17de terminated OK
[ 2239.312599] dhd_dpc_thread: Unexpected up_cnt 0
[ 2239.312634] dhd_detach(): thread:dhd_dpc:17dd terminated OK
[ 2239.312957] wl_event_handler: was terminated
[ 2239.313055] wl_destroy_event_handler(): thread:wl_event_handler:17da terminated OK
[ 2239.360485] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2239.360512] bcmsdh_probe: device attach failed
[ 2239.360523] sdioh_probe: bcmsdh_probe failed
[ 2239.360679] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2251.360189] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2251.360575] wifi_platform_set_power = 0
[ 2251.360613] ======== PULL WL_REG_ON LOW! ========
[ 2251.360650] wifi_platform_bus_enumerate device present 0
[ 2251.360685] ======== Card detection to remove SDIO card! ========
[ 2251.360850] unregister wifi platform drivers
[ 2251.360891] wifi_platform_bus_enumerate device present 0
[ 2251.360925] ======== Card detection to remove SDIO card! ========
[ 2251.361031] dhd_module_init: Failed to load the driver, try cnt 0
[ 2251.361176] dhd_module_init: Failed to load driver max retry reached**
[ 2251.361216] dhd_module_init: Exit err=-62
[ 2251.431031] mmc1: card 0001 removed
[ 2251.431959] [mmc]: sdc1 power_supply is null
[ 2251.461667] dhd_module_init: in
[ 2251.461686] ======== bcm_wlan_set_plat_data ========
[ 2251.461702] bcm_wlan_get_oob_irq enter.
[ 2251.461718] gpio [202] map to virq [10] ok
[ 2251.461725] host_oob_irq: 10
[ 2251.461732] host_oob_irq_flags=0x414
[ 2251.461739] dhd_wifi_platform_load: Enter
[ 2251.461778] Power-up adapter 'DHD generic adapter'
[ 2251.461787] wifi_platform_set_power = 1
[ 2251.461795] ======== PULL WL_REG_ON HIGH! ========
[ 2251.461804] [wifi_pm]: set wl_reg_on 0 !
[ 2251.661838] [wifi_pm]: set wl_reg_on 1 !
[ 2252.170122] wifi_platform_bus_enumerate device present 1
[ 2252.170140] ======== Card detection to detect SDIO card! ========
[ 2252.171733] [mmc]: sdc1 power_supply is null
[ 2252.228311] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2252.230317] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2252.232199] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2252.235457] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2252.257178] mmc1: new high speed SDIO card at address 0001
[ 2252.275821] bcmsdh_register: register client driver
[ 2252.276256] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2252.276532] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2252.276575] bus num (host idx)=1, slot num (rca)=1
[ 2252.276612] found adapter info 'DHD generic adapter'
[ 2252.276775] sdioh_attach: set sd_f2_blocksize 128
[ 2252.277963] F1 signature read @0x18000000=0x1591a962
[ 2252.278540] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2252.285504] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2252.287974] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2252.290281] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2252.290566] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2252.290679] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2252.301595] tsk Enter, tsk = 0xe6041430
[ 2252.301684] wl_create_event_handler(): thread:wl_event_handler:17f3 started
[ 2252.307433] dhd_attach(): thread:dhd_watchdog_thread:17f5 started
[ 2252.308738] dhd_attach(): thread:dhd_dpc:17f6 started
[ 2252.309261] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2252.309607] dhd_attach(): thread:dhd_rxf:17f7 started
[ 2252.309677] dhd_deferred_work_init: work queue initialized
[ 2252.314871] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2252.314960] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2252.315012] dhdsdio_download_firmware: set use_rxchain 0
[ 2252.315050] dhdsdio_download_firmware: set txglomsize 16
[ 2252.315088] sdioh_set_mode: set txglom_mode to multi-desc
[ 2252.315123] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2252.315160] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2252.315195] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2252.316876] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2252.316935] _dhdsdio_download_firmware: dongle image file download failed
[ 2252.317068] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2252.317118] dhdsdio_probe: dhd_bus_start failed
[ 2252.317157] bcmsdh_oob_intr_unregister: Enter
[ 2252.317189] bcmsdh_oob_intr_unregister: irq is not registered
[ 2252.317232] dhd_wlfc_deinit():3301, Already disabled!
[ 2252.363446] dhd_detach(): thread:dhd_watchdog_thread:17f5 terminated OK
[ 2252.363496] dhd_detach(): thread:dhd_rxf:17f7 terminated OK
[ 2252.363547] dhd_dpc_thread: Unexpected up_cnt 0
[ 2252.363631] dhd_detach(): thread:dhd_dpc:17f6 terminated OK
[ 2252.363931] wl_event_handler: was terminated
[ 2252.364343] wl_destroy_event_handler(): thread:wl_event_handler:17f3 terminated OK
[ 2252.432788] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2252.432819] bcmsdh_probe: device attach failed
[ 2252.432830] sdioh_probe: bcmsdh_probe failed
[ 2252.433258] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2264.430084] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2264.430234] wifi_platform_set_power = 0
[ 2264.430244] ======== PULL WL_REG_ON LOW! ========
[ 2264.430254] wifi_platform_bus_enumerate device present 0
[ 2264.430262] ======== Card detection to remove SDIO card! ========
[ 2264.430323] unregister wifi platform drivers
[ 2264.430333] wifi_platform_bus_enumerate device present 0
[ 2264.430341] ======== Card detection to remove SDIO card! ========
[ 2264.430367] dhd_module_init: Failed to load the driver, try cnt 3
[ 2264.430404] ======== bcm_wlan_set_plat_data ========
[ 2264.430419] bcm_wlan_get_oob_irq enter.
[ 2264.430434] gpio [202] map to virq [10] ok
[ 2264.430441] host_oob_irq: 10
[ 2264.430447] host_oob_irq_flags=0x414
[ 2264.430455] dhd_wifi_platform_load: Enter
[ 2264.430484] Power-up adapter 'DHD generic adapter'
[ 2264.430494] wifi_platform_set_power = 1
[ 2264.430501] ======== PULL WL_REG_ON HIGH! ========
[ 2264.430510] [wifi_pm]: set wl_reg_on 0 !
[ 2264.490307] mmc1: card 0001 removed
[ 2264.490564] [mmc]: sdc1 power_supply is null
[ 2264.630537] [wifi_pm]: set wl_reg_on 1 !
[ 2265.140082] wifi_platform_bus_enumerate device present 1
[ 2265.140097] ======== Card detection to detect SDIO card! ========
[ 2265.141790] [mmc]: sdc1 power_supply is null
[ 2265.200252] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2265.202095] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2265.203931] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2265.207185] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2265.229320] mmc1: new high speed SDIO card at address 0001
[ 2265.248067] bcmsdh_register: register client driver
[ 2265.248476] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2265.248748] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2265.248791] bus num (host idx)=1, slot num (rca)=1
[ 2265.248828] found adapter info 'DHD generic adapter'
[ 2265.248997] sdioh_attach: set sd_f2_blocksize 128
[ 2265.250398] F1 signature read @0x18000000=0x1591a962
[ 2265.251088] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2265.257748] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2265.260399] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2265.262587] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2265.262872] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2265.262981] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2265.266783] tsk Enter, tsk = 0xe6041430
[ 2265.266874] wl_create_event_handler(): thread:wl_event_handler:1804 started
[ 2265.276756] dhd_attach(): thread:dhd_watchdog_thread:1805 started
[ 2265.279216] dhd_attach(): thread:dhd_dpc:1806 started
[ 2265.279307] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2265.279689] dhd_attach(): thread:dhd_rxf:1807 started
[ 2265.279794] dhd_deferred_work_init: work queue initialized
[ 2265.283913] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2265.283997] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2265.284051] dhdsdio_download_firmware: set use_rxchain 0
[ 2265.284088] dhdsdio_download_firmware: set txglomsize 16
[ 2265.284127] sdioh_set_mode: set txglom_mode to multi-desc
[ 2265.284163] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2265.284200] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2265.284235] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2265.286894] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2265.286958] _dhdsdio_download_firmware: dongle image file download failed
[ 2265.287201] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2265.287265] dhdsdio_probe: dhd_bus_start failed
[ 2265.287320] bcmsdh_oob_intr_unregister: Enter
[ 2265.287360] bcmsdh_oob_intr_unregister: irq is not registered
[ 2265.287423] dhd_wlfc_deinit():3301, Already disabled!
[ 2265.330186] dhd_detach(): thread:dhd_watchdog_thread:1805 terminated OK
[ 2265.330218] dhd_detach(): thread:dhd_rxf:1807 terminated OK
[ 2265.330258] dhd_dpc_thread: Unexpected up_cnt 0
[ 2265.330302] dhd_detach(): thread:dhd_dpc:1806 terminated OK
[ 2265.330622] wl_event_handler: was terminated
[ 2265.330716] wl_destroy_event_handler(): thread:wl_event_handler:1804 terminated OK
[ 2265.391482] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2265.391505] bcmsdh_probe: device attach failed
[ 2265.391516] sdioh_probe: bcmsdh_probe failed
[ 2265.391668] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2277.390100] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2277.390257] wifi_platform_set_power = 0
[ 2277.390267] ======== PULL WL_REG_ON LOW! ========
[ 2277.390276] wifi_platform_bus_enumerate device present 0
[ 2277.390284] ======== Card detection to remove SDIO card! ========
[ 2277.390347] unregister wifi platform drivers
[ 2277.390359] wifi_platform_bus_enumerate device present 0
[ 2277.390367] ======== Card detection to remove SDIO card! ========
[ 2277.390393] dhd_module_init: Failed to load the driver, try cnt 2
[ 2277.390431] ======== bcm_wlan_set_plat_data ========
[ 2277.390446] bcm_wlan_get_oob_irq enter.
[ 2277.390459] gpio [202] map to virq [10] ok
[ 2277.390467] host_oob_irq: 10
[ 2277.390473] host_oob_irq_flags=0x414
[ 2277.390480] dhd_wifi_platform_load: Enter
[ 2277.390511] Power-up adapter 'DHD generic adapter'
[ 2277.390521] wifi_platform_set_power = 1
[ 2277.390529] ======== PULL WL_REG_ON HIGH! ========
[ 2277.390538] [wifi_pm]: set wl_reg_on 0 !
[ 2277.430274] mmc1: card 0001 removed
[ 2277.430530] [mmc]: sdc1 power_supply is null
[ 2277.590566] [wifi_pm]: set wl_reg_on 1 !
[ 2278.100088] wifi_platform_bus_enumerate device present 1
[ 2278.100105] ======== Card detection to detect SDIO card! ========
[ 2278.101728] [mmc]: sdc1 power_supply is null
[ 2278.158669] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2278.160741] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2278.162655] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2278.165912] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2278.188133] mmc1: new high speed SDIO card at address 0001
[ 2278.206933] bcmsdh_register: register client driver
[ 2278.207370] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2278.207643] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2278.207689] bus num (host idx)=1, slot num (rca)=1
[ 2278.207726] found adapter info 'DHD generic adapter'
[ 2278.207903] sdioh_attach: set sd_f2_blocksize 128
[ 2278.209227] F1 signature read @0x18000000=0x1591a962
[ 2278.209819] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2278.216743] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2278.219216] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2278.221647] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2278.221937] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2278.222048] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2278.233488] wl_create_event_handler(): thread:wl_event_handler:1809 started
[ 2278.233583] tsk Enter, tsk = 0xe6041430
[ 2278.237973] dhd_attach(): thread:dhd_watchdog_thread:180b started
[ 2278.238377] dhd_attach(): thread:dhd_dpc:180c started
[ 2278.238457] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2278.238683] dhd_attach(): thread:dhd_rxf:180d started
[ 2278.238752] dhd_deferred_work_init: work queue initialized
[ 2278.240477] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2278.240557] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2278.240612] dhdsdio_download_firmware: set use_rxchain 0
[ 2278.240653] dhdsdio_download_firmware: set txglomsize 16
[ 2278.240694] sdioh_set_mode: set txglom_mode to multi-desc
[ 2278.240733] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2278.240774] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2278.240811] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2278.245172] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2278.245241] _dhdsdio_download_firmware: dongle image file download failed
[ 2278.245420] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2278.245469] dhdsdio_probe: dhd_bus_start failed
[ 2278.245509] bcmsdh_oob_intr_unregister: Enter
[ 2278.245542] bcmsdh_oob_intr_unregister: irq is not registered
[ 2278.245585] dhd_wlfc_deinit():3301, Already disabled!
[ 2278.310203] dhd_detach(): thread:dhd_watchdog_thread:180b terminated OK
[ 2278.310236] dhd_detach(): thread:dhd_rxf:180d terminated OK
[ 2278.310277] dhd_dpc_thread: Unexpected up_cnt 0
[ 2278.310307] dhd_detach(): thread:dhd_dpc:180c terminated OK
[ 2278.310588] wl_event_handler: was terminated
[ 2278.310642] wl_destroy_event_handler(): thread:wl_event_handler:1809 terminated OK
[ 2278.360548] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2278.360571] bcmsdh_probe: device attach failed
[ 2278.360581] sdioh_probe: bcmsdh_probe failed
[ 2278.360712] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2290.360358] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2290.360788] wifi_platform_set_power = 0
[ 2290.360826] ======== PULL WL_REG_ON LOW! ========
[ 2290.360863] wifi_platform_bus_enumerate device present 0
[ 2290.360898] ======== Card detection to remove SDIO card! ========
[ 2290.361063] unregister wifi platform drivers
[ 2290.361104] wifi_platform_bus_enumerate device present 0
[ 2290.361137] ======== Card detection to remove SDIO card! ========
[ 2290.361226] dhd_module_init: Failed to load the driver, try cnt 1
[ 2290.361376] ======== bcm_wlan_set_plat_data ========
[ 2290.361424] bcm_wlan_get_oob_irq enter.
[ 2290.361471] gpio [202] map to virq [10] ok
[ 2290.361501] host_oob_irq: 10
[ 2290.361529] host_oob_irq_flags=0x414
[ 2290.361559] dhd_wifi_platform_load: Enter
[ 2290.361646] Power-up adapter 'DHD generic adapter'
[ 2290.361683] wifi_platform_set_power = 1
[ 2290.361712] ======== PULL WL_REG_ON HIGH! ========
[ 2290.361747] [wifi_pm]: set wl_reg_on 0 !
[ 2290.403442] mmc1: card 0001 removed
[ 2290.403715] [mmc]: sdc1 power_supply is null
[ 2290.562545] [wifi_pm]: set wl_reg_on 1 !
[ 2291.070115] wifi_platform_bus_enumerate device present 1
[ 2291.070132] ======== Card detection to detect SDIO card! ========
[ 2291.071781] [mmc]: sdc1 power_supply is null
[ 2291.128160] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2291.129863] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2291.131631] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2291.135523] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2291.153293] mmc1: new high speed SDIO card at address 0001
[ 2291.170205] bcmsdh_register: register client driver
[ 2291.170413] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2291.170539] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2291.170550] bus num (host idx)=1, slot num (rca)=1
[ 2291.170560] found adapter info 'DHD generic adapter'
[ 2291.170658] sdioh_attach: set sd_f2_blocksize 128
[ 2291.171164] F1 signature read @0x18000000=0x1591a962
[ 2291.171448] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2291.174366] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2291.175958] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2291.176973] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2291.177051] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2291.177096] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2291.179846] wl_create_event_handler(): thread:wl_event_handler:180e started
[ 2291.179862] tsk Enter, tsk = 0xe6041430
[ 2291.184079] dhd_attach(): thread:dhd_watchdog_thread:1810 started
[ 2291.184197] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2291.184240] dhd_attach(): thread:dhd_dpc:1811 started
[ 2291.184384] dhd_attach(): thread:dhd_rxf:1812 started
[ 2291.184412] dhd_deferred_work_init: work queue initialized
[ 2291.184815] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2291.184846] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2291.184865] dhdsdio_download_firmware: set use_rxchain 0
[ 2291.184874] dhdsdio_download_firmware: set txglomsize 16
[ 2291.184889] sdioh_set_mode: set txglom_mode to multi-desc
[ 2291.184899] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2291.184908] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2291.184917] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2291.185886] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2291.185911] _dhdsdio_download_firmware: dongle image file download failed
[ 2291.185975] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2291.185988] dhdsdio_probe: dhd_bus_start failed
[ 2291.186001] bcmsdh_oob_intr_unregister: Enter
[ 2291.186009] bcmsdh_oob_intr_unregister: irq is not registered
[ 2291.186021] dhd_wlfc_deinit():3301, Already disabled!
[ 2291.230200] dhd_detach(): thread:dhd_watchdog_thread:1810 terminated OK
[ 2291.230229] dhd_detach(): thread:dhd_rxf:1812 terminated OK
[ 2291.230249] dhd_dpc_thread: Unexpected up_cnt 0
[ 2291.230298] dhd_detach(): thread:dhd_dpc:1811 terminated OK
[ 2291.230568] wl_event_handler: was terminated
[ 2291.230644] wl_destroy_event_handler(): thread:wl_event_handler:180e terminated OK
[ 2291.270497] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2291.270518] bcmsdh_probe: device attach failed
[ 2291.270529] sdioh_probe: bcmsdh_probe failed
[ 2291.270687] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2303.270107] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2303.270267] wifi_platform_set_power = 0
[ 2303.270276] ======== PULL WL_REG_ON LOW! ========
[ 2303.270284] wifi_platform_bus_enumerate device present 0
[ 2303.270292] ======== Card detection to remove SDIO card! ========
[ 2303.270354] unregister wifi platform drivers
[ 2303.270364] wifi_platform_bus_enumerate device present 0
[ 2303.270371] ======== Card detection to remove SDIO card! ========
[ 2303.270396] dhd_module_init: Failed to load the driver, try cnt 0
[ 2303.270427] dhd_module_init: Failed to load driver max retry reached**
[ 2303.270436] dhd_module_init: Exit err=-62
[ 2303.370270] mmc1: card 0001 removed
[ 2303.370501] [mmc]: sdc1 power_supply is null
[ 2303.386580] dhd_module_init: in
[ 2303.386597] ======== bcm_wlan_set_plat_data ========
[ 2303.386612] bcm_wlan_get_oob_irq enter.
[ 2303.386625] gpio [202] map to virq [10] ok
[ 2303.386631] host_oob_irq: 10
[ 2303.386637] host_oob_irq_flags=0x414
[ 2303.386643] dhd_wifi_platform_load: Enter
[ 2303.386675] Power-up adapter 'DHD generic adapter'
[ 2303.386683] wifi_platform_set_power = 1
[ 2303.386689] ======== PULL WL_REG_ON HIGH! ========
[ 2303.386696] [wifi_pm]: set wl_reg_on 0 !
[ 2303.586964] [wifi_pm]: set wl_reg_on 1 !
[ 2304.090089] wifi_platform_bus_enumerate device present 1
[ 2304.090108] ======== Card detection to detect SDIO card! ========
[ 2304.091729] [mmc]: sdc1 power_supply is null
[ 2304.154895] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2304.156537] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2304.158182] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2304.162834] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2304.181276] mmc1: new high speed SDIO card at address 0001
[ 2304.198270] bcmsdh_register: register client driver
[ 2304.199744] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2304.199917] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2304.199930] bus num (host idx)=1, slot num (rca)=1
[ 2304.199941] found adapter info 'DHD generic adapter'
[ 2304.200642] sdioh_attach: set sd_f2_blocksize 128
[ 2304.201193] F1 signature read @0x18000000=0x1591a962
[ 2304.201499] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2304.204216] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2304.205179] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2304.206357] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2304.206437] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2304.206486] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2304.213001] wl_create_event_handler(): thread:wl_event_handler:1816 started
[ 2304.213018] tsk Enter, tsk = 0xe6041430
[ 2304.214210] dhd_attach(): thread:dhd_watchdog_thread:1817 started
[ 2304.214348] dhd_attach(): thread:dhd_dpc:1818 started
[ 2304.214509] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2304.214519] dhd_attach(): thread:dhd_rxf:1819 started
[ 2304.214540] dhd_deferred_work_init: work queue initialized
[ 2304.214954] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2304.214981] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2304.214996] dhdsdio_download_firmware: set use_rxchain 0
[ 2304.215005] dhdsdio_download_firmware: set txglomsize 16
[ 2304.215015] sdioh_set_mode: set txglom_mode to multi-desc
[ 2304.215023] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2304.215032] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2304.215040] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2304.230751] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2304.230772] _dhdsdio_download_firmware: dongle image file download failed
[ 2304.230822] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2304.230833] dhdsdio_probe: dhd_bus_start failed
[ 2304.230844] bcmsdh_oob_intr_unregister: Enter
[ 2304.230851] bcmsdh_oob_intr_unregister: irq is not registered
[ 2304.230862] dhd_wlfc_deinit():3301, Already disabled!
[ 2304.320133] dhd_detach(): thread:dhd_watchdog_thread:1817 terminated OK
[ 2304.320162] dhd_detach(): thread:dhd_rxf:1819 terminated OK
[ 2304.320225] dhd_dpc_thread: Unexpected up_cnt 0
[ 2304.320249] dhd_detach(): thread:dhd_dpc:1818 terminated OK
[ 2304.320538] wl_event_handler: was terminated
[ 2304.320614] wl_destroy_event_handler(): thread:wl_event_handler:1816 terminated OK
[ 2304.410426] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2304.410446] bcmsdh_probe: device attach failed
[ 2304.410455] sdioh_probe: bcmsdh_probe failed
[ 2304.410592] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2316.410091] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2316.410258] wifi_platform_set_power = 0
[ 2316.410271] ======== PULL WL_REG_ON LOW! ========
[ 2316.410280] wifi_platform_bus_enumerate device present 0
[ 2316.410289] ======== Card detection to remove SDIO card! ========
[ 2316.410367] unregister wifi platform drivers
[ 2316.410378] wifi_platform_bus_enumerate device present 0
[ 2316.410387] ======== Card detection to remove SDIO card! ========
[ 2316.410411] dhd_module_init: Failed to load the driver, try cnt 3
[ 2316.410448] ======== bcm_wlan_set_plat_data ========
[ 2316.410464] bcm_wlan_get_oob_irq enter.
[ 2316.410478] gpio [202] map to virq [10] ok
[ 2316.410485] host_oob_irq: 10
[ 2316.410492] host_oob_irq_flags=0x414
[ 2316.410499] dhd_wifi_platform_load: Enter
[ 2316.410529] Power-up adapter 'DHD generic adapter'
[ 2316.410538] wifi_platform_set_power = 1
[ 2316.410545] ======== PULL WL_REG_ON HIGH! ========
[ 2316.410554] [wifi_pm]: set wl_reg_on 0 !
[ 2316.520366] mmc1: card 0001 removed
[ 2316.520630] [mmc]: sdc1 power_supply is null
[ 2316.610676] [wifi_pm]: set wl_reg_on 1 !
[ 2317.120102] wifi_platform_bus_enumerate device present 1
[ 2317.120120] ======== Card detection to detect SDIO card! ========
[ 2317.121720] [mmc]: sdc1 power_supply is null
[ 2317.178747] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2317.180444] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2317.182132] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2317.185074] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2317.202336] mmc1: new high speed SDIO card at address 0001
[ 2317.219412] bcmsdh_register: register client driver
[ 2317.219589] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2317.219705] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2317.219717] bus num (host idx)=1, slot num (rca)=1
[ 2317.219728] found adapter info 'DHD generic adapter'
[ 2317.219814] sdioh_attach: set sd_f2_blocksize 128
[ 2317.220519] F1 signature read @0x18000000=0x1591a962
[ 2317.220869] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2317.231404] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2317.232811] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2317.234164] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2317.234253] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2317.234318] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2317.235893] wl_create_event_handler(): thread:wl_event_handler:181a started
[ 2317.236435] tsk Enter, tsk = 0xe4a81430
[ 2317.236609] dhd_attach(): thread:dhd_watchdog_thread:181b started
[ 2317.236729] dhd_attach(): thread:dhd_dpc:181c started
[ 2317.236768] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2317.236830] dhd_attach(): thread:dhd_rxf:181d started
[ 2317.236852] dhd_deferred_work_init: work queue initialized
[ 2317.237288] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2317.237315] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2317.237329] dhdsdio_download_firmware: set use_rxchain 0
[ 2317.237338] dhdsdio_download_firmware: set txglomsize 16
[ 2317.237349] sdioh_set_mode: set txglom_mode to multi-desc
[ 2317.237357] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2317.237366] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2317.237375] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2317.240615] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2317.240637] _dhdsdio_download_firmware: dongle image file download failed
[ 2317.240878] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2317.240897] dhdsdio_probe: dhd_bus_start failed
[ 2317.240908] bcmsdh_oob_intr_unregister: Enter
[ 2317.240917] bcmsdh_oob_intr_unregister: irq is not registered
[ 2317.240929] dhd_wlfc_deinit():3301, Already disabled!
[ 2317.330293] dhd_detach(): thread:dhd_watchdog_thread:181b terminated OK
[ 2317.330387] dhd_detach(): thread:dhd_rxf:181d terminated OK
[ 2317.330411] dhd_dpc_thread: Unexpected up_cnt 0
[ 2317.330461] dhd_detach(): thread:dhd_dpc:181c terminated OK
[ 2317.330802] wl_event_handler: was terminated
[ 2317.330914] wl_destroy_event_handler(): thread:wl_event_handler:181a terminated OK
[ 2317.370468] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2317.370490] bcmsdh_probe: device attach failed
[ 2317.370500] sdioh_probe: bcmsdh_probe failed
[ 2317.370658] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2329.370257] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2329.370654] wifi_platform_set_power = 0
[ 2329.370692] ======== PULL WL_REG_ON LOW! ========
[ 2329.370729] wifi_platform_bus_enumerate device present 0
[ 2329.370764] ======== Card detection to remove SDIO card! ========
[ 2329.370924] unregister wifi platform drivers
[ 2329.370964] wifi_platform_bus_enumerate device present 0
[ 2329.370998] ======== Card detection to remove SDIO card! ========
[ 2329.371085] dhd_module_init: Failed to load the driver, try cnt 2
[ 2329.371235] ======== bcm_wlan_set_plat_data ========
[ 2329.371283] bcm_wlan_get_oob_irq enter.
[ 2329.371330] gpio [202] map to virq [10] ok
[ 2329.371361] host_oob_irq: 10
[ 2329.371388] host_oob_irq_flags=0x414
[ 2329.371417] dhd_wifi_platform_load: Enter
[ 2329.371498] Power-up adapter 'DHD generic adapter'
[ 2329.371535] wifi_platform_set_power = 1
[ 2329.371564] ======== PULL WL_REG_ON HIGH! ========
[ 2329.371598] [wifi_pm]: set wl_reg_on 0 !
[ 2329.480299] mmc1: card 0001 removed
[ 2329.480555] [mmc]: sdc1 power_supply is null
[ 2329.571668] [wifi_pm]: set wl_reg_on 1 !
[ 2330.080347] wifi_platform_bus_enumerate device present 1
[ 2330.080399] ======== Card detection to detect SDIO card! ========
[ 2330.082322] [mmc]: sdc1 power_supply is null
[ 2330.138307] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2330.139950] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2330.141633] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2330.144548] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2330.162955] mmc1: new high speed SDIO card at address 0001
[ 2330.180442] bcmsdh_register: register client driver
[ 2330.180628] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2330.180762] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2330.180774] bus num (host idx)=1, slot num (rca)=1
[ 2330.180784] found adapter info 'DHD generic adapter'
[ 2330.180873] sdioh_attach: set sd_f2_blocksize 128
[ 2330.181426] F1 signature read @0x18000000=0x1591a962
[ 2330.181788] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2330.184647] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2330.185705] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2330.186613] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2330.186686] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2330.186724] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2330.189869] wl_create_event_handler(): thread:wl_event_handler:1829 started
[ 2330.189885] tsk Enter, tsk = 0xe4a81430
[ 2330.190439] dhd_attach(): thread:dhd_watchdog_thread:182a started
[ 2330.190550] dhd_attach(): thread:dhd_dpc:182b started
[ 2330.190594] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2330.193180] dhd_attach(): thread:dhd_rxf:182d started
[ 2330.193209] dhd_deferred_work_init: work queue initialized
[ 2330.193605] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2330.193629] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2330.193643] dhdsdio_download_firmware: set use_rxchain 0
[ 2330.193652] dhdsdio_download_firmware: set txglomsize 16
[ 2330.193662] sdioh_set_mode: set txglom_mode to multi-desc
[ 2330.193671] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2330.193680] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2330.193688] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2330.194411] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2330.194428] _dhdsdio_download_firmware: dongle image file download failed
[ 2330.194482] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2330.194495] dhdsdio_probe: dhd_bus_start failed
[ 2330.194506] bcmsdh_oob_intr_unregister: Enter
[ 2330.194514] bcmsdh_oob_intr_unregister: irq is not registered
[ 2330.194526] dhd_wlfc_deinit():3301, Already disabled!
[ 2330.240506] dhd_detach(): thread:dhd_watchdog_thread:182a terminated OK
[ 2330.240553] dhd_detach(): thread:dhd_rxf:182d terminated OK
[ 2330.240581] dhd_dpc_thread: Unexpected up_cnt 0
[ 2330.240634] dhd_detach(): thread:dhd_dpc:182b terminated OK
[ 2330.241527] wl_event_handler: was terminated
[ 2330.241639] wl_destroy_event_handler(): thread:wl_event_handler:1829 terminated OK
[ 2330.300438] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2330.300460] bcmsdh_probe: device attach failed
[ 2330.300469] sdioh_probe: bcmsdh_probe failed
[ 2330.300628] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2342.300099] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2342.300234] wifi_platform_set_power = 0
[ 2342.300244] ======== PULL WL_REG_ON LOW! ========
[ 2342.300251] wifi_platform_bus_enumerate device present 0
[ 2342.300259] ======== Card detection to remove SDIO card! ========
[ 2342.300314] unregister wifi platform drivers
[ 2342.300322] wifi_platform_bus_enumerate device present 0
[ 2342.300329] ======== Card detection to remove SDIO card! ========
[ 2342.300355] dhd_module_init: Failed to load the driver, try cnt 1
[ 2342.300387] ======== bcm_wlan_set_plat_data ========
[ 2342.300401] bcm_wlan_get_oob_irq enter.
[ 2342.300413] gpio [202] map to virq [10] ok
[ 2342.300420] host_oob_irq: 10
[ 2342.300425] host_oob_irq_flags=0x414
[ 2342.300432] dhd_wifi_platform_load: Enter
[ 2342.300459] Power-up adapter 'DHD generic adapter'
[ 2342.300467] wifi_platform_set_power = 1
[ 2342.300473] ======== PULL WL_REG_ON HIGH! ========
[ 2342.300481] [wifi_pm]: set wl_reg_on 0 !
[ 2342.390317] mmc1: card 0001 removed
[ 2342.390553] [mmc]: sdc1 power_supply is null
[ 2342.500506] [wifi_pm]: set wl_reg_on 1 !
[ 2343.010074] wifi_platform_bus_enumerate device present 1
[ 2343.010091] ======== Card detection to detect SDIO card! ========
[ 2343.011704] [mmc]: sdc1 power_supply is null
[ 2343.067551] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2343.069245] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2343.070929] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2343.073830] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2343.090685] mmc1: new high speed SDIO card at address 0001
[ 2343.107543] bcmsdh_register: register client driver
[ 2343.107699] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2343.107816] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2343.107827] bus num (host idx)=1, slot num (rca)=1
[ 2343.107837] found adapter info 'DHD generic adapter'
[ 2343.107931] sdioh_attach: set sd_f2_blocksize 128
[ 2343.108512] F1 signature read @0x18000000=0x1591a962
[ 2343.108804] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2343.112133] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2343.113191] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2343.114089] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2343.114161] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2343.114201] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2343.118961] wl_create_event_handler(): thread:wl_event_handler:182f started
[ 2343.118977] tsk Enter, tsk = 0xe4a81430
[ 2343.119519] dhd_attach(): thread:dhd_watchdog_thread:1830 started
[ 2343.119621] dhd_attach(): thread:dhd_dpc:1831 started
[ 2343.119639] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2343.119727] dhd_attach(): thread:dhd_rxf:1832 started
[ 2343.119756] dhd_deferred_work_init: work queue initialized
[ 2343.120955] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2343.120987] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2343.121004] dhdsdio_download_firmware: set use_rxchain 0
[ 2343.121016] dhdsdio_download_firmware: set txglomsize 16
[ 2343.121028] sdioh_set_mode: set txglom_mode to multi-desc
[ 2343.121038] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2343.121050] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2343.121058] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2343.122190] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2343.122215] _dhdsdio_download_firmware: dongle image file download failed
[ 2343.122276] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2343.122290] dhdsdio_probe: dhd_bus_start failed
[ 2343.122302] bcmsdh_oob_intr_unregister: Enter
[ 2343.122310] bcmsdh_oob_intr_unregister: irq is not registered
[ 2343.122321] dhd_wlfc_deinit():3301, Already disabled!
[ 2343.171469] dhd_detach(): thread:dhd_watchdog_thread:1830 terminated OK
[ 2343.171505] dhd_detach(): thread:dhd_rxf:1832 terminated OK
[ 2343.171550] dhd_dpc_thread: Unexpected up_cnt 0
[ 2343.171602] dhd_detach(): thread:dhd_dpc:1831 terminated OK
[ 2343.172659] wl_event_handler: was terminated
[ 2343.172843] wl_destroy_event_handler(): thread:wl_event_handler:182f terminated OK
[ 2343.240572] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2343.240596] bcmsdh_probe: device attach failed
[ 2343.240606] sdioh_probe: bcmsdh_probe failed
[ 2343.240748] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
[ 2355.240101] dhd_wifi_platform_load_sdio: sdio_register_driver timeout or error
[ 2355.240257] wifi_platform_set_power = 0
[ 2355.240269] ======== PULL WL_REG_ON LOW! ========
[ 2355.240277] wifi_platform_bus_enumerate device present 0
[ 2355.240285] ======== Card detection to remove SDIO card! ========
[ 2355.240361] unregister wifi platform drivers
[ 2355.240374] wifi_platform_bus_enumerate device present 0
[ 2355.240382] ======== Card detection to remove SDIO card! ========
[ 2355.240409] dhd_module_init: Failed to load the driver, try cnt 0
[ 2355.240441] dhd_module_init: Failed to load driver max retry reached**
[ 2355.240449] dhd_module_init: Exit err=-62
[ 2355.270440] mmc1: card 0001 removed
[ 2355.270738] [mmc]: sdc1 power_supply is null
[ 2355.322465] dhd_module_init: in
[ 2355.322485] ======== bcm_wlan_set_plat_data ========
[ 2355.322500] bcm_wlan_get_oob_irq enter.
[ 2355.322515] gpio [202] map to virq [10] ok
[ 2355.322522] host_oob_irq: 10
[ 2355.322527] host_oob_irq_flags=0x414
[ 2355.322534] dhd_wifi_platform_load: Enter
[ 2355.322576] Power-up adapter 'DHD generic adapter'
[ 2355.322586] wifi_platform_set_power = 1
[ 2355.322594] ======== PULL WL_REG_ON HIGH! ========
[ 2355.322604] [wifi_pm]: set wl_reg_on 0 !
[ 2355.522926] [wifi_pm]: set wl_reg_on 1 !
[ 2356.030224] wifi_platform_bus_enumerate device present 1
[ 2356.030261] ======== Card detection to detect SDIO card! ========
[ 2356.032146] [mmc]: sdc1 power_supply is null
[ 2356.089794] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2356.091657] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2356.093900] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2356.097016] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2356.116342] mmc1: new high speed SDIO card at address 0001
[ 2356.133390] bcmsdh_register: register client driver
[ 2356.133607] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2356.134389] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2356.134411] bus num (host idx)=1, slot num (rca)=1
[ 2356.134424] found adapter info 'DHD generic adapter'
[ 2356.134576] sdioh_attach: set sd_f2_blocksize 128
[ 2356.135159] F1 signature read @0x18000000=0x1591a962
[ 2356.135474] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[ 2356.139275] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[ 2356.141007] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[ 2356.142242] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[ 2356.142319] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/ap6212/config.txt
[ 2356.142364] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2356.143393] tsk Enter, tsk = 0xe6001430
[ 2356.143428] wl_create_event_handler(): thread:wl_event_handler:1834 started
[ 2356.144462] dhd_attach(): thread:dhd_watchdog_thread:1835 started
[ 2356.144600] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2356.144642] dhd_attach(): thread:dhd_dpc:1836 started
[ 2356.144784] dhd_attach(): thread:dhd_rxf:1837 started
[ 2356.144807] dhd_deferred_work_init: work queue initialized
[ 2356.145431] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt
[ 2356.145455] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2356.145469] dhdsdio_download_firmware: set use_rxchain 0
[ 2356.145478] dhdsdio_download_firmware: set txglomsize 16
[ 2356.145489] sdioh_set_mode: set txglom_mode to multi-desc
[ 2356.145497] Final fw_path=/lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2356.145506] Final nv_path=/lib/firmware/ap6212/nvram.txt
[ 2356.145514] Final conf_path=/lib/firmware/ap6212/config.txt
[ 2356.146708] dhdsdio_download_code_file: Open firmware file failed /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2356.146728] _dhdsdio_download_firmware: dongle image file download failed
[ 2356.146790] dhd_bus_start: failed to download firmware /lib/firmware/ap6212/fw_bcm40181a2.bin
[ 2356.146803] dhdsdio_probe: dhd_bus_start failed
[ 2356.146815] bcmsdh_oob_intr_unregister: Enter
[ 2356.146823] bcmsdh_oob_intr_unregister: irq is not registered
[ 2356.146835] dhd_wlfc_deinit():3301, Already disabled!
[ 2356.220183] dhd_detach(): thread:dhd_watchdog_thread:1835 terminated OK
[ 2356.220216] dhd_detach(): thread:dhd_rxf:1837 terminated OK
[ 2356.220238] dhd_dpc_thread: Unexpected up_cnt 0
[ 2356.220297] dhd_detach(): thread:dhd_dpc:1836 terminated OK
[ 2356.220636] wl_event_handler: was terminated
[ 2356.220739] wl_destroy_event_handler(): thread:wl_event_handler:1834 terminated OK
[ 2356.270457] dhd_os_prealloc: failed to alloc memory, section: 7, size: 0bytes
[ 2356.270478] bcmsdh_probe: device attach failed
[ 2356.270488] sdioh_probe: bcmsdh_probe failed
[ 2356.270628] bcmsdh_sdmmc: probe of mmc1:0001:2 failed with error -12
Link to comment
On 1/26/2019 at 12:55 PM, Andeser said:
Ok what can I do for install the driver of this chip?
https://www.itgubben.eu/files/ from @slinde
I thinks this driver in included ... but the steps I remember more or less are download and unzip the driver in /lib/ directory . After that in a Terminal:
sudo modprobe ap6181 firmware_path=/lib/firmware/ap6210/ap6181.bin nvram_path=/lib/firmware/ap6210/nvram.txt
lsmod
sudo ifconfig wlan0 up
sudo iwlist wlan0 scan
Link to comment
The output is:
Module                  Size  Used by
dhd                   666843  1
rfcomm                 32879  4
bnep                    9617  2
bluetooth             174101  8 bnep,rfcomm
zram                    8964  5
rt2800usb              13637  0
rt2800lib              41983  1 rt2800usb
rt2x00usb               8297  1 rt2800usb
bmp085                  3487  0
pcf8591                 3363  0
rt2x00lib              34468  3 rt2x00usb,rt2800lib,rt2800usb
mac80211              358457  3 rt2x00lib,rt2x00usb,rt2800lib
mali_drm                2732  1
ir_lirc_codec           3677  0
lirc_dev                7834  1 ir_lirc_codec
ir_mce_kbd_decoder      2885  0
ir_sanyo_decoder        1480  0
ir_sony_decoder         1422  0
ir_jvc_decoder          1452  0
mali                  123158  2
drm                   178282  2 mali_drm
ir_rc6_decoder          1941  0
ir_rc5_decoder          1412  0
ir_nec_decoder          1556  0
ump                    29379  5 mali
sunxi_cir               1601  0
rc_core                12727  10 ir_lirc_codec,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,sunxi_cir,ir_mce_kbd_decoder,ir_jvc_decoder,ir_rc6_decoder,ir_sanyo_decoder
sunxi_spdma             3707  1
sunxi_spdif             7041  1
sunxi_sndspdif          3885  2
sndspdif                2747  1
btrfs                 712473  0
The output from sudo depmod -ae is:
depmod: WARNING: -e needs -E or -F
Link to comment
I'm having the exact same trouble with my two, same AP6181. I've tested both Xenial (3.4) and Stretch (4.19) but neither have Wifi working. The older kernel image is loading dhd drivers but its a repeat of what Andeser is getting. Stretch says dhd module not found.
using "sudo modprobe brcmfmac" on either kernel adds "registered new interface driver brcmfmac" to dmesg but nothing else.
Edited by wezhayw
Link to comment
Hi, its me again.
After update my old Beelink X2 rev2 with Wi-Fi RTL8189ETV I can`t find anyway to bring up the wireless alive.
I'm running ARMBIAN 5.75 stable Debian 9 (strech) 4.19.20-sunxi
I can load the mod 8189es like I do in the past but nothing comes alive.
Any idea? Any help?
Link to comment
Any idea? Any help?
Update everything. Armbian, Debian and kernel are way outdated.
Link to comment
I'll try this evening.
Is more or less responsive, so I suppose the CPU speed is OK. But I don't know if it's running at fixed speed or changing by some governor.
cpufreq-info didn't show anything.
But is good to have Debian Buster with 5.x kernel on it.
Link to comment
On 5/17/2020 at 1:43 AM, Igor said:
armbianmonitor -u
     1
     2    ### Activated 1 lzo zram swap devices with 483 MB each
     3
     4    ### Activated Armbian ramlog partition with zstd compression
     5
     6    Mon 17 Feb 2020 11:47:46 AM UTC | Orange Pi+ 2E | 20.02.1 | armhf | armv7l | 5.4.20-sunxi
     7
     8    ### dmesg:
     9
    10    [    0.000000] Booting Linux on physical CPU 0x0
    11    [    0.000000] Linux version 5.4.20-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.02.1 SMP Mon Feb 17 02:09:41 CET 2020
    12    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
    13    [    0.000000] CPU: div instructions available: patching division code
    14    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    15    [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi Plus 2E
    16    [    0.000000] Memory policy: Data cache writealloc
    17    [    0.000000] cma: Reserved 128 MiB at 0x75c00000
    18    [    0.000000] On node 0 totalpages: 253952
    19    [    0.000000]   Normal zone: 1728 pages used for memmap
    20    [    0.000000]   Normal zone: 0 pages reserved
    21    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
    22    [    0.000000]   HighMem zone: 57344 pages, LIFO batch:15
    23    [    0.000000] psci: probing for conduit method from DT.
    24    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
    25    [    0.000000] percpu: Embedded 20 pages/cpu s49868 r8192 d23860 u81920
    26    [    0.000000] pcpu-alloc: s49868 r8192 d23860 u81920 alloc=20*4096
    27    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    28    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 252224
    29    [    0.000000] Kernel command line: root=UUID=f972992c-598b-42c9-a9a0-e82ba21ecd3f rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=9acc51ea-01 ubootsource=mmc usb-storage.quirks=   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
    30    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    31    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    32    [    0.000000] allocated 1015808 bytes of page_ext
    33    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    34    [    0.000000] Memory: 850684K/1015808K available (9216K kernel code, 1048K rwdata, 2852K rodata, 1024K init, 316K bss, 34052K reserved, 131072K cma-reserved, 98292K highmem)
    35    [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x3ac with crng_init=0
    36    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    37    [    0.000000] ftrace: allocating 40584 entries in 80 pages
    38    [    0.000000] rcu: Hierarchical RCU implementation.
    39    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    40    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    41    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    42    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    43    [    0.000000] GIC: Using split EOI/Deactivate mode
    44    [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    45    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    46    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    47    [    0.000012] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    48    [    0.000031] Switching to timer-based delay loop, resolution 41ns
    49    [    0.000443] Console: colour dummy device 80x30
    50    [    0.000467] printk: console [tty1] enabled
    51    [    0.000552] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    52    [    0.000573] pid_max: default: 32768 minimum: 301
    53    [    0.001129] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    54    [    0.001155] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    55    [    0.001313] *** VALIDATE tmpfs ***
    56    [    0.002572] *** VALIDATE proc ***
    57    [    0.003134] *** VALIDATE cgroup1 ***
    58    [    0.003148] *** VALIDATE cgroup2 ***
    59    [    0.003258] CPU: Testing write buffer coherency: ok
    60    [    0.004044] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    61    [    0.005101] Setting up static identity map for 0x40100000 - 0x40100054
    62    [    0.005343] rcu: Hierarchical SRCU implementation.
    63    [    0.006411] smp: Bringing up secondary CPUs ...
    64    [    0.017707] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    65    [    0.029270] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    66    [    0.040692] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    67    [    0.040911] smp: Brought up 1 node, 4 CPUs
    68    [    0.040928] SMP: Total of 4 processors activated (192.00 BogoMIPS).
    69    [    0.040936] CPU: All CPU(s) started in HYP mode.
    70    [    0.040941] CPU: Virtualization extensions available.
    71    [    0.042421] devtmpfs: initialized
    72    [    0.056973] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
    73    [    0.057476] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    74    [    0.057511] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    75    [    0.067500] xor: measuring software checksum speed
    76    [    0.104815]    arm4regs  :   508.000 MB/sec
    77    [    0.144954]    8regs     :   354.000 MB/sec
    78    [    0.185096]    32regs    :   334.000 MB/sec
    79    [    0.225244]    neon      :   515.000 MB/sec
    80    [    0.225255] xor: using function: neon (515.000 MB/sec)
    81    [    0.225394] pinctrl core: initialized pinctrl subsystem
    82    [    0.227354] NET: Registered protocol family 16
    83    [    0.230808] DMA: preallocated 256 KiB pool for atomic coherent allocations
    84    [    0.231970] audit: initializing netlink subsys (disabled)
    85    [    0.232310] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
    86    [    0.233486] cpuidle: using governor ladder
    87    [    0.233553] cpuidle: using governor menu
    88    [    0.234784] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    89    [    0.234795] hw-breakpoint: maximum watchpoint size is 8 bytes.
    90    [    0.362136] raid6: neonx8   gen()   286 MB/s
    91    [    0.430292] raid6: neonx8   xor()   235 MB/s
    92    [    0.498485] raid6: neonx4   gen()   294 MB/s
    93    [    0.566688] raid6: neonx4   xor()   246 MB/s
    94    [    0.634948] raid6: neonx2   gen()   266 MB/s
    95    [    0.703052] raid6: neonx2   xor()   237 MB/s
    96    [    0.771295] raid6: neonx1   gen()   195 MB/s
    97    [    0.839394] raid6: neonx1   xor()   178 MB/s
    98    [    0.907830] raid6: int32x8  gen()   108 MB/s
    99    [    0.975772] raid6: int32x8  xor()    70 MB/s
   100    [    1.044303] raid6: int32x4  gen()   114 MB/s
   101    [    1.112156] raid6: int32x4  xor()    77 MB/s
   102    [    1.180445] raid6: int32x2  gen()    99 MB/s
   103    [    1.248792] raid6: int32x2  xor()    75 MB/s
   104    [    1.316905] raid6: int32x1  gen()    75 MB/s
   105    [    1.385403] raid6: int32x1  xor()    59 MB/s
   106    [    1.385413] raid6: using algorithm neonx4 gen() 294 MB/s
   107    [    1.385420] raid6: .... xor() 246 MB/s, rmw enabled
   108    [    1.385428] raid6: using neon recovery algorithm
   109    [    1.388327] iommu: Default domain type: Translated
   110    [    1.389021] SCSI subsystem initialized
   111    [    1.389450] libata version 3.00 loaded.
   112    [    1.389978] usbcore: registered new interface driver usbfs
   113    [    1.390072] usbcore: registered new interface driver hub
   114    [    1.390232] usbcore: registered new device driver usb
   115    [    1.390633] mc: Linux media interface: v0.10
   116    [    1.390702] videodev: Linux video capture interface: v2.00
   117    [    1.390956] pps_core: LinuxPPS API ver. 1 registered
   118    [    1.390965] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   119    [    1.391001] PTP clock support registered
   120    [    1.394517] clocksource: Switched to clocksource arch_sys_counter
   121    [    3.389517] *** VALIDATE bpf ***
   122    [    3.389949] VFS: Disk quotas dquot_6.6.0
   123    [    3.390121] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
   124    [    3.390299] *** VALIDATE ramfs ***
   125    [    3.407598] thermal_sys: Registered thermal governor 'fair_share'
   126    [    3.407609] thermal_sys: Registered thermal governor 'bang_bang'
   127    [    3.407624] thermal_sys: Registered thermal governor 'step_wise'
   128    [    3.407633] thermal_sys: Registered thermal governor 'power_allocator'
   129    [    3.408607] NET: Registered protocol family 2
   130    [    3.409983] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
   131    [    3.410046] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
   132    [    3.410211] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
   133    [    3.410560] TCP: Hash tables configured (established 8192 bind 8192)
   134    [    3.410788] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
   135    [    3.410878] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
   136    [    3.411314] NET: Registered protocol family 1
   137    [    3.412328] RPC: Registered named UNIX socket transport module.
   138    [    3.412338] RPC: Registered udp transport module.
   139    [    3.412345] RPC: Registered tcp transport module.
   140    [    3.412352] RPC: Registered tcp NFSv4.1 backchannel transport module.
   141    [    3.412794] Trying to unpack rootfs image as initramfs...
   142    [    4.460710] Freeing initrd memory: 7172K
   143    [    4.464783] Initialise system trusted keyrings
   144    [    4.465250] workingset: timestamp_bits=14 max_order=18 bucket_order=4
   145    [    4.480117] zbud: loaded
   146    [    4.485111] NFS: Registering the id_resolver key type
   147    [    4.485156] Key type id_resolver registered
   148    [    4.485164] Key type id_legacy registered
   149    [    4.485190] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   150    [    4.485199] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   151    [    4.488212] JFS: nTxBlock = 7726, nTxLock = 61808
   152    [    4.501853] SGI XFS with ACLs, security attributes, realtime, no debug enabled
   153    [    4.628422] Key type asymmetric registered
   154    [    4.628439] Asymmetric key parser 'x509' registered
   155    [    4.628564] bounce: pool size: 64 pages
   156    [    4.628694] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   157    [    4.629098] io scheduler mq-deadline registered
   158    [    4.629109] io scheduler kyber registered
   159    [    4.629234] io scheduler bfq registered
   160    [    4.641407] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
   161    [    4.644854] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
   162    [    4.659246] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
   163    [    4.662913] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
   164    [    4.663748] printk: console [ttyS0] disabled
   165    [    4.684062] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 43, base_baud = 1500000) is a U6_16550A
   166    [    4.684159] printk: console [ttyS0] enabled
   167    [    4.697808] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a8da18)
   168    [    4.698386] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a8a600)
   169    [    4.698563] sun8i-dw-hdmi 1ee0000.hdmi: 1ee0000.hdmi supply hvcc not found, using dummy regulator
   170    [    4.699917] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
   171    [    4.700649] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
   172    [    4.701140] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a8d004)
   173    [    4.701155] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
   174    [    4.701162] [drm] No driver support for vblank timestamp query.
   175    [    4.701950] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
   176    [    5.048747] Console: switching to colour frame buffer device 128x48
   177    [    5.098564] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
   178    [    5.106012] brd: module loaded
   179    [    5.119220] loop: module loaded
   180    [    5.124001] libphy: Fixed MDIO Bus: probed
   181    [    5.125526] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
   182    [    5.125890] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
   183    [    5.125908] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
   184    [    5.126101] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
   185    [    5.128577] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   186    [    5.128588] ehci-platform: EHCI generic platform driver
   187    [    5.128922] ehci-platform 1c1a000.usb: EHCI Host Controller
   188    [    5.128976] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
   189    [    5.129747] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
   190    [    5.142565] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
   191    [    5.143129] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
   192    [    5.143149] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   193    [    5.143165] usb usb1: Product: EHCI Host Controller
   194    [    5.143179] usb usb1: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
   195    [    5.143193] usb usb1: SerialNumber: 1c1a000.usb
   196    [    5.144290] hub 1-0:1.0: USB hub found
   197    [    5.144406] hub 1-0:1.0: 1 port detected
   198    [    5.146197] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   199    [    5.146236] ohci-platform: OHCI generic platform driver
   200    [    5.146665] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
   201    [    5.146716] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
   202    [    5.147058] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
   203    [    5.211080] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
   204    [    5.211099] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   205    [    5.211114] usb usb2: Product: Generic Platform OHCI controller
   206    [    5.211129] usb usb2: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
   207    [    5.211143] usb usb2: SerialNumber: 1c1a400.usb
   208    [    5.212160] hub 2-0:1.0: USB hub found
   209    [    5.212264] hub 2-0:1.0: 1 port detected
   210    [    5.215147] usbcore: registered new interface driver usb-storage
   211    [    5.217835] sun6i-rtc 1f00000.rtc: registered as rtc0
   212    [    5.217852] sun6i-rtc 1f00000.rtc: RTC enabled
   213    [    5.218584] i2c /dev entries driver
   214    [    5.219359] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
   215    [    5.223626] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
   216    [    5.224995] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
   217    [    5.226400] sunxi-mmc 1c0f000.mmc: Got CD GPIO
   218    [    5.252050] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
   219    [    5.252524] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
   220    [    5.254734] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
   221    [    5.278565] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
   222    [    5.281075] ledtrig-cpu: registered to indicate activity on CPUs
   223    [    5.281219] hidraw: raw HID events driver (C) Jiri Kosina
   224    [    5.281459] usbcore: registered new interface driver usbhid
   225    [    5.281466] usbhid: USB HID core driver
   226    [    5.285371] Initializing XFRM netlink socket
   227    [    5.286945] NET: Registered protocol family 10
   228    [    5.288814] mmc0: host does not support reading read-only switch, assuming write-enable
   229    [    5.290912] mmc0: new high speed SDHC card at address 0001
   230    [    5.292545] mmcblk0: mmc0:0001 00000 29.8 GiB
   231    [    5.296212]  mmcblk0: p1
   232    [    5.428661] Segment Routing with IPv6
   233    [    5.428855] NET: Registered protocol family 17
   234    [    5.428912] NET: Registered protocol family 15
   235    [    5.429056] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
   236    [    5.429466] 8021q: 802.1Q VLAN Support v1.8
   237    [    5.429567] Key type dns_resolver registered
   238    [    5.430683] Registering SWP/SWPB emulation handler
   239    [    5.431246] registered taskstats version 1
   240    [    5.431255] Loading compiled-in X.509 certificates
   241    [    5.431439] zswap: loaded using pool lzo/zbud
   242    [    5.432009] Key type ._fscrypt registered
   243    [    5.432020] Key type .fscrypt registered
   244    [    5.437979] Btrfs loaded, crc32c=crc32c-generic
   245    [    5.506104] Key type encrypted registered
   246    [    5.522650] random: fast init done
   247    [    5.522716] mmc1: new DDR MMC card at address 0001
   248    [    5.524597] mmcblk1: mmc1:0001 NCard  7.22 GiB
   249    [    5.525508] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
   250    [    5.526376] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
   251    [    5.529429]  mmcblk1: p1
   252    [    5.529825] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
   253    [    5.530856] simple-framebuffer 7e000000.framebuffer: framebuffer at 0x7e000000, 0x300000 bytes, mapped to 0x(ptrval)
   254    [    5.530883] simple-framebuffer 7e000000.framebuffer: format=x8r8g8b8, mode=1024x768x32, linelength=4096
   255    [    5.531409] simple-framebuffer 7e000000.framebuffer: fb1: simplefb registered!
   256    [    5.531987] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
   257    [    5.535428] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
   258    [    5.535451] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
   259    [    5.535634] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
   260    [    5.535901] dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
   261    [    5.642982] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000)
   262    [    5.643018] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
   263    [    5.643032] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
   264    [    5.643046] dwmac-sun8i 1c30000.ethernet: COE Type 2
   265    [    5.643060] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
   266    [    5.643074] dwmac-sun8i 1c30000.ethernet: Normal descriptors
   267    [    5.643087] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
   268    [    5.643452] libphy: stmmac: probed
   269    [    5.644894] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
   270    [    5.645111] libphy: mdio_mux: probed
   271    [    5.645152] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
   272    [    5.645170] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
   273    [    5.667027] ac200: Unknown symbol ac200_reg_mod (err -2)
   274    [    5.667077] ac200: Unknown symbol ac200_reg_write (err -2)
   275    [    5.669811] libphy: mdio_mux: probed
   276    [    5.669864] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
   277    [    5.769942] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
   278    [    5.770127] dwmac-sun8i 1c30000.ethernet: Error: Failed to register MDIO bus for child /soc/ethernet@1c30000/mdio-mux/mdio@2
   279    [    5.771365] ehci-platform 1c1b000.usb: EHCI Host Controller
   280    [    5.771421] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
   281    [    5.772297] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
   282    [    5.786581] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
   283    [    5.787021] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
   284    [    5.787040] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   285    [    5.787056] usb usb3: Product: EHCI Host Controller
   286    [    5.787071] usb usb3: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
   287    [    5.787085] usb usb3: SerialNumber: 1c1b000.usb
   288    [    5.788223] hub 3-0:1.0: USB hub found
   289    [    5.788316] hub 3-0:1.0: 1 port detected
   290    [    5.790063] ehci-platform 1c1c000.usb: EHCI Host Controller
   291    [    5.790114] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
   292    [    5.790677] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
   293    [    5.806561] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
   294    [    5.806971] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
   295    [    5.806991] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   296    [    5.807006] usb usb4: Product: EHCI Host Controller
   297    [    5.807021] usb usb4: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
   298    [    5.807035] usb usb4: SerialNumber: 1c1c000.usb
   299    [    5.808033] hub 4-0:1.0: USB hub found
   300    [    5.808116] hub 4-0:1.0: 1 port detected
   301    [    5.809763] ehci-platform 1c1d000.usb: EHCI Host Controller
   302    [    5.809827] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
   303    [    5.810321] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
   304    [    5.822566] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
   305    [    5.822958] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
   306    [    5.822977] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   307    [    5.822992] usb usb5: Product: EHCI Host Controller
   308    [    5.823007] usb usb5: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
   309    [    5.823021] usb usb5: SerialNumber: 1c1d000.usb
   310    [    5.824043] hub 5-0:1.0: USB hub found
   311    [    5.824121] hub 5-0:1.0: 1 port detected
   312    [    5.825716] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
   313    [    5.825764] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
   314    [    5.826109] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
   315    [    5.886945] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
   316    [    5.886966] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   317    [    5.886981] usb usb6: Product: Generic Platform OHCI controller
   318    [    5.886996] usb usb6: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
   319    [    5.887010] usb usb6: SerialNumber: 1c1b400.usb
   320    [    5.888017] hub 6-0:1.0: USB hub found
   321    [    5.888100] hub 6-0:1.0: 1 port detected
   322    [    5.889717] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
   323    [    5.889765] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
   324    [    5.890114] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
   325    [    5.950916] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
   326    [    5.950936] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   327    [    5.950952] usb usb7: Product: Generic Platform OHCI controller
   328    [    5.950966] usb usb7: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
   329    [    5.950980] usb usb7: SerialNumber: 1c1c400.usb
   330    [    5.951958] hub 7-0:1.0: USB hub found
   331    [    5.952039] hub 7-0:1.0: 1 port detected
   332    [    5.953629] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
   333    [    5.953698] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
   334    [    5.954080] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
   335    [    6.014931] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
   336    [    6.014951] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   337    [    6.014966] usb usb8: Product: Generic Platform OHCI controller
   338    [    6.014981] usb usb8: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
   339    [    6.014995] usb usb8: SerialNumber: 1c1d400.usb
   340    [    6.015971] hub 8-0:1.0: USB hub found
   341    [    6.016049] hub 8-0:1.0: 1 port detected
   342    [    6.017759] usb_phy_generic usb_phy_generic.2.auto: usb_phy_generic.2.auto supply vcc not found, using dummy regulator
   343    [    6.018723] musb-hdrc musb-hdrc.3.auto: MUSB HDRC host driver
   344    [    6.018770] musb-hdrc musb-hdrc.3.auto: new USB bus registered, assigned bus number 9
   345    [    6.019223] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
   346    [    6.019242] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   347    [    6.019257] usb usb9: Product: MUSB HDRC host driver
   348    [    6.019272] usb usb9: Manufacturer: Linux 5.4.20-sunxi musb-hcd
   349    [    6.019286] usb usb9: SerialNumber: musb-hdrc.3.auto
   350    [    6.020240] hub 9-0:1.0: USB hub found
   351    [    6.020320] hub 9-0:1.0: 1 port detected
   352    [    6.027845] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:22 UTC (22)
   353    [    6.028220] of_cfs_init
   354    [    6.028437] of_cfs_init: OK
   355    [    6.039382] Freeing unused kernel memory: 1024K
   356    [    6.059092] Run /init as init process
   357    [    6.786752] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
   358    [    6.794614] usb 2-1: new full-speed USB device number 2 using ohci-platform
   359    [    7.045892] usb 2-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
   360    [    7.045951] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
   361    [    7.045994] usb 2-1: Product: USB Receiver
   362    [    7.046034] usb 2-1: Manufacturer: Logitech
   363    [    7.048740] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
   364    [    7.061874] input: Logitech USB Receiver as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.0/0003:046D:C52B.0001/input/input1
   365    [    7.074561] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
   366    [    7.104677] mmc2: new high speed SDIO card at address 0001
   367    [    7.119127] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-1c1a400.usb-1/input0
   368    [    7.131233] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input2
   369    [    7.131772] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input3
   370    [    7.191006] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input4
   371    [    7.191869] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1a400.usb-1/input1
   372    [    7.201174] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
   373    [    7.323032] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
   374    [    7.457309] input: Logitech Unifying Device. Wireless PID:4024 Keyboard as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input6
   375    [    7.457745] input: Logitech Unifying Device. Wireless PID:4024 Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input7
   376    [    7.458277] input: Logitech Unifying Device. Wireless PID:4024 Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input8
   377    [    7.458765] hid-generic 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4024] on usb-1c1a400.usb-1/input2:1
   378    [    7.553322] input: Logitech K400 as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input12
   379    [    7.553718] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-1c1a400.usb-1/input2:1
   380    [    8.181320] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
   381    [    9.035622] systemd[1]: System time before build time, advancing clock.
   382    [    9.113905] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
   383    [    9.115519] systemd[1]: Detected architecture arm.
   384    [    9.156707] systemd[1]: Set hostname to <orangepiplus2e>.
   385    [    9.164475] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
   386    [   10.379969] random: systemd: uninitialized urandom read (16 bytes read)
   387    [   10.405794] random: systemd: uninitialized urandom read (16 bytes read)
   388    [   10.406936] systemd[1]: Listening on udev Control Socket.
   389    [   10.408942] random: systemd: uninitialized urandom read (16 bytes read)
   390    [   10.409611] systemd[1]: Listening on udev Kernel Socket.
   391    [   10.412568] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
   392    [   10.423049] systemd[1]: Created slice system-serial\x2dgetty.slice.
   393    [   10.424323] systemd[1]: Reached target System Time Synchronized.
   394    [   10.426966] systemd[1]: Listening on Journal Audit Socket.
   395    [   10.826310] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
   396    [   12.098997] systemd-journald[298]: Received request to flush runtime journal from PID 1
   397    [   12.723257] zram: Added device: zram0
   398    [   12.725343] zram: Added device: zram1
   399    [   12.727252] zram: Added device: zram2
   400    [   12.763691] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
   401    [   12.818730] cedrus 1c0e000.video-codec: Device registered as /dev/video0
   402    [   13.009071] zram1: detected capacity change from 0 to 506855424
   403    [   13.052596] cfg80211: Loading compiled-in X.509 certificates for regulatory database
   404    [   13.232438] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
   405    [   13.234131] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
   406    [   13.234162] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
   407    [   13.435716] lima 1c40000.gpu: IRQ ppmmu2 not found
   408    [   13.435747] lima 1c40000.gpu: IRQ ppmmu3 not found
   409    [   13.435803] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
   410    [   13.435933] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
   411    [   13.436064] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
   412    [   13.436182] lima 1c40000.gpu: IRQ pp2 not found
   413    [   13.436203] lima 1c40000.gpu: IRQ pp3 not found
   414    [   13.436227] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
   415    [   13.474891] lima 1c40000.gpu: bus rate = 200000000
   416    [   13.474918] lima 1c40000.gpu: mod rate = 384000000
   417    [   13.510708] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 1
   418    [   13.518407] sun4i-codec 1c22c00.codec: Failed to register our card
   419    [   13.538625] sun4i-codec 1c22c00.codec: Failed to register our card
   420    [   13.547968] bFWReady == _FALSE call reset 8051...
   421    [   13.548503] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
   422    [   13.553679] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
   423    [   13.592514] Registered IR keymap rc-empty
   424    [   13.592793] rc rc1: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1
   425    [   13.598724] rc rc1: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
   426    [   13.599242] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1/input14
   427    [   13.610095] sunxi-ir 1f02000.ir: initialized sunXi IR driver
   428    [   13.662647] Registered IR keymap rc-cec
   429    [   13.663056] rc rc0: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0
   430    [   13.663528] input: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0/input13
   431    [   14.251216] cfg80211: failed to load regulatory.db
   432    [   14.311605] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok
   433    [   14.366168] Adding 494972k swap on /dev/zram1.  Priority:5 extents:1 across:494972k SSFS
   434    [   14.905754] zram0: detected capacity change from 0 to 52428800
   435    [   17.251786] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
   436    [   17.251868] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
   437    [   18.522734] random: crng init done
   438    [   18.522757] random: 7 urandom warning(s) missed due to ratelimiting
   439
   440    ### armbian-release:
   441
   442    # PLEASE DO NOT EDIT THIS FILE
   443    BOARD=orangepiplus2e
   444    BOARD_NAME="Orange Pi+ 2E"
   445    BOARDFAMILY=sun8i
   446    BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin
   447    BUILD_REPOSITORY_COMMIT=3e533c9
   448    DISTRIBUTION_CODENAME=buster
   449    DISTRIBUTION_STATUS=supported
   450    VERSION=20.02.1
   451    LINUXFAMILY=sunxi
   452    BRANCH=current
   453    ARCH=arm
   454    IMAGE_TYPE=stable
   455    BOARD_TYPE=conf
   456    INITRD_ARCH=arm
   457    KERNEL_IMAGE_TYPE=Image
   458
   459    ### boot environment:
   460
   461    verbosity=1
   462    logo=disabled
   463    console=both
   464    disp_mode=1920x1080p60
   465    overlay_prefix=sun8i-h3
   466    rootdev=UUID=f972992c-598b-42c9-a9a0-e82ba21ecd3f
   467    rootfstype=ext4
   468
   469    ### lsusb:
   470
   471    Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   472    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   473    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   474    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   475    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   476    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   477    Bus 002 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
   478    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   479    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   480    Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   481
   482    ### lscpu:
   483
   484    Architecture:        armv7l
   485    Byte Order:          Little Endian
   486    CPU(s):              4
   487    On-line CPU(s) list: 0-3
   488    Thread(s) per core:  1
   489    Core(s) per socket:  4
   490    Socket(s):           1
   491    Vendor ID:           ARM
   492    Model:               5
   493    Model name:          Cortex-A7
   494    Stepping:            r0p5
   495    BogoMIPS:            48.00
   496    Flags:               half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
   497
   498    ### cpuinfo:
   499
   500    processor    : 0
   501    model name    : ARMv7 Processor rev 5 (v7l)
   502    BogoMIPS    : 48.00
   503    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
   504    CPU implementer    : 0x41
   505    CPU architecture: 7
   506    CPU variant    : 0x0
   507    CPU part    : 0xc07
   508    CPU revision    : 5
   509
   510    processor    : 1
   511    model name    : ARMv7 Processor rev 5 (v7l)
   512    BogoMIPS    : 48.00
   513    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
   514    CPU implementer    : 0x41
   515    CPU architecture: 7
   516    CPU variant    : 0x0
   517    CPU part    : 0xc07
   518    CPU revision    : 5
   519
   520    processor    : 2
   521    model name    : ARMv7 Processor rev 5 (v7l)
   522    BogoMIPS    : 48.00
   523    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
   524    CPU implementer    : 0x41
   525    CPU architecture: 7
   526    CPU variant    : 0x0
   527    CPU part    : 0xc07
   528    CPU revision    : 5
   529
   530    processor    : 3
   531    model name    : ARMv7 Processor rev 5 (v7l)
   532    BogoMIPS    : 48.00
   533    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
   534    CPU implementer    : 0x41
   535    CPU architecture: 7
   536    CPU variant    : 0x0
   537    CPU part    : 0xc07
   538    CPU revision    : 5
   539
   540    Hardware    : Allwinner sun8i Family
   541    Revision    : 0000
   542    Serial        : 02c00081bd8e203d
   543
   544    ### meminfo:
   545
   546    MemTotal:         989952 kB
   547    MemFree:          882900 kB
   548    MemAvailable:     912248 kB
   549    Buffers:            7276 kB
   550    Cached:            28912 kB
   551    SwapCached:            0 kB
   552    Active:            28620 kB
   553    Inactive:          14872 kB
   554    Active(anon):       7448 kB
   555    Inactive(anon):     1524 kB
   556    Active(file):      21172 kB
   557    Inactive(file):    13348 kB
   558    Unevictable:           0 kB
   559    Mlocked:               0 kB
   560    HighTotal:        229364 kB
   561    HighFree:         171192 kB
   562    LowTotal:         760588 kB
   563    LowFree:          711708 kB
   564    SwapTotal:        494972 kB
   565    SwapFree:         494972 kB
   566    Dirty:                96 kB
   567    Writeback:             0 kB
   568    AnonPages:          7192 kB
   569    Mapped:             8424 kB
   570    Shmem:              1672 kB
   571    KReclaimable:      12844 kB
   572    Slab:              35060 kB
   573    SReclaimable:      12844 kB
   574    SUnreclaim:        22216 kB
   575    KernelStack:         936 kB
   576    PageTables:          288 kB
   577    NFS_Unstable:          0 kB
   578    Bounce:                0 kB
   579    WritebackTmp:          0 kB
   580    CommitLimit:      989948 kB
   581    Committed_AS:      15736 kB
   582    VmallocTotal:     245760 kB
   583    VmallocUsed:       15848 kB
   584    VmallocChunk:          0 kB
   585    Percpu:              608 kB
   586    CmaTotal:         131072 kB
   587    CmaFree:          125964 kB
   588
   589    ### virtual memory:
   590
   591    Mon 17 Feb 2020 11:47:47 AM UTC | Orange Pi+ 2E | 20.02.1 | armhf | armv7l | 5.4.20-sunxi
   592    vm.admin_reserve_kbytes = 8192
   593    vm.block_dump = 0
   594    vm.compact_unevictable_allowed = 1
   595    vm.dirty_background_bytes = 0
   596    vm.dirty_background_ratio = 10
   597    vm.dirty_bytes = 0
   598    vm.dirty_expire_centisecs = 3000
   599    vm.dirty_ratio = 20
   600    vm.dirtytime_expire_seconds = 43200
   601    vm.dirty_writeback_centisecs = 500
   602    vm.extfrag_threshold = 500
   603    vm.highmem_is_dirtyable = 0
   604
   605    ### [resize2fs] Leaving 1 percent spare area. Start resizing partition /dev/mmcblk0p1 now:
   606
   607    major minor  #blocks  name
   608
   609       1        0       4096 ram0
   610       1        1       4096 ram1
   611       1        2       4096 ram2
   612       1        3       4096 ram3
   613     179        0   31260672 mmcblk0
   614     179        1    1159168 mmcblk0p1
   615     179        8    7570432 mmcblk1
   616     179        9    7490624 mmcblk1p1
   617     254        0      51200 zram0
   618     254        1     494976 zram1
   619
   620    Executing fdisk, fsck and partprobe:
   621    vm.laptop_mode = 0
   622    vm.legacy_va_layout = 0
   623
   624    Welcome to fdisk (util-linux 2.33.1).
   625    Changes will remain in memory only, until you decide to write them.
   626    Be careful before using the write command.
   627
   628
   629    Command (m for help): Selected partition 1
   630    Partition 1 has been deleted.
   631
   632    Command (m for help): Partition type
   633       p   primary (0 primary, 0 extended, 4 free)
   634       e   extended (container for logical partitions)
   635    Select (default p): Partition number (1-4, default 1): First sector (2048-62521343, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (8192-62521343, default 62521343): vm.lowmem_reserve_ratio = 32    0    0
   636
   637    Created a new partition 1 of type 'Linux' and of size 29.5 GiB.
   638    Partition #1 contains a ext4 signature.
   639
   640    Command (m for help): vm.max_map_count = 65530
   641    vm.min_free_kbytes = 3469
   642    vm.mmap_min_addr = 4096
   643
   644    The partition table has been altered.
   645    Syncing disks.
   646
   647    vm.mmap_rnd_bits = 8
   648    vm.oom_dump_tasks = 1
   649    vm.oom_kill_allocating_task = 0
   650    vm.overcommit_kbytes = 0
   651    vm.overcommit_memory = 0
   652    vm.overcommit_ratio = 50
   653    vm.page-cluster = 0
   654    New partition table:
   655
   656    major minor  #blocks  name
   657
   658       1        0       4096 ram0
   659       1        1       4096 ram1
   660       1        2       4096 ram2
   661       1        3       4096 ram3
   662     179        0   31260672 mmcblk0
   663     179        1   30943968 mmcblk0p1
   664     179        8    7570432 mmcblk1
   665     179        9    7490624 mmcblk1p1
   666     254        0      51200 zram0
   667     254        1     494976 zram1
   668
   669    Now trying to resize ext4 filesystem on /dev/mmcblk0p1 to the limits:
   670
   671    vm.panic_on_oom = 0
   672    resize2fs 1.44.5 (15-Dec-2018)
   673    vm.percpu_pagelist_fraction = 0
   674    vm.stat_interval = 1
   675    vm.swappiness = 100
   676    vm.user_reserve_kbytes = 30552
   677    vm.vfs_cache_pressure = 100
   678    vm.watermark_boost_factor = 15000
   679    vm.watermark_scale_factor = 10
   680
   681    ### ip addr:
   682
   683    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   684        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   685        inet XXX.XXX.0.1/8 scope host lo
   686           valid_lft forever preferred_lft forever
   687        inet6 ::1/128 scope host
   688           valid_lft forever preferred_lft forever
   689    2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
   690        link/ether e6:5a:33:73:7a:c4 brd ff:ff:ff:ff:ff:ff
   691    3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   692        link/ether 02:81:bd:8e:20:3d brd ff:ff:ff:ff:ff:ff
   693    4: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   694        link/ether cc:79:cf:54:c5:4a brd ff:ff:ff:ff:ff:ff
   695
   696    ### partitions:
   697
   698    major minor  #blocks  name
   699
   700     179        0   31260672 mmcblk0
   701     179        1   30943968 mmcblk0p1
   702     179        8    7570432 mmcblk1
   703     179        9    7490624 mmcblk1p1
   704     254        0      51200 zram0
   705     254        1     494976 zram1
   706
   707    ### df:
   708
   709    udev            416M     0  416M   0% /dev
   710    tmpfs            97M  1.7M   96M   2% /run
   711    /dev/mmcblk0p1  1.1G  919M  146M  87% /
   712    tmpfs           484M     0  484M   0% /dev/shm
   713    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
   714    tmpfs           484M     0  484M   0% /sys/fs/cgroup
   715    tmpfs           484M  4.0K  484M   1% /tmp
   716    /dev/zram0       49M  532K   45M   2% /var/log
   717
   718    ### lsblk:
   719
   720    NAME         FSTYPE   SIZE MOUNTPOINT UUID
   721    mmcblk0              29.8G
   722    └─mmcblk0p1  ext4    29.5G /          f972992c-598b-42c9-a9a0-e82ba21ecd3f
   723    mmcblk1               7.2G
   724    └─mmcblk1p1  ext4     7.1G            07520a06-bc92-4f9f-be19-d47f09d82abd
   725    mmcblk1boot0            4M
   726    mmcblk1boot1            4M
   727    zram0                  50M /var/log
   728
   729    ### zramctl:
   730
   731    NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
   732    /dev/zram1 lzo         483.4M    4K   76B    4K       4 [SWAP]
   733    /dev/zram0 zstd           50M  612K 84.4K  392K       4 /var/log
   734
   735    ### mtab:
   736
   737    /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
   738    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
   739    /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
   740
   741    ### mmc1:0001 info:
   742
   743                  manfid: 0x000088
   744                     cid: 8801034e436172642026e16382562375
   745                   fwrev: 0x0000000000000000
   746                     rca: 0x0001
   747                     csd: d0ffff320f5903ffffffffe7964000eb
   748               life_time: 0x01 0x01
   749                     ocr: 0x00200000
   750                    type: MMC
   751    enhanced_area_offset: 18446744073709551594
   752                    date: 02/2016
   753                   hwrev: 0x0
   754                     prv: 0x26
   755                     dsr: 0x404
   756             ffu_capable: 1
   757                  serial: 0xe1638256
   758      raw_rpmb_size_mult: 0x20
   759              erase_size: 524288
   760            pre_eol_info: 0x01
   761             rel_sectors: 0x1
   762                 cmdq_en: 0
   763                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=NCard  MODALIAS=mmc:block
   764      enhanced_area_size: 4294967274
   765                   oemid: 0x0103
   766                     rev: 0x7
   767    preferred_erase_size: 4194304
   768                    name: NCard
   769
   770    ### mmc0:0001 info:
   771
   772                  manfid: 0x00001b
   773                     cid: 1b534d303030303010d24155a7010c67
   774                   fwrev: 0x0
   775                     rca: 0x0001
   776                     csd: 400e00325b590000ee7f7f800a404055
   777                     ocr: 0x00200000
   778                    type: SD
   779                    date: 12/2016
   780                   hwrev: 0x1
   781                     dsr: 0x404
   782                  serial: 0xd24155a7
   783              erase_size: 512
   784                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=00000 MODALIAS=mmc:block
   785                     ssr: 0000000005000000040090000f051d00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   786                     scr: 02b5800200000000
   787                   oemid: 0x534d
   788    preferred_erase_size: 4194304
   789                    name: 00000
   790
   791    ### Boot system health:
   792
   793    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
   794    11:47:55:   ---      0.82  50%  27%  16%   0%   6%   0% 38.6°C
   795    11:47:56:   ---      0.82  29%   6%   0%   1%  21%   0% 39.5°C
   796    11:47:56:   ---      0.82  28%   9%   0%   2%  17%   0% 38.3°C
   797    11:47:57:   ---      0.82  35%   9%   0%   2%  22%   0% 37.5°C
   798    11:47:57:   ---      0.82  31%  11%   0%   2%  18%   0% 38.4°C
   799    Filesystem at /dev/mmcblk0p1 is mounted on /; on-line resizing required
   800    old_desc_blocks = 1, new_desc_blocks = 2
   801    The filesystem on /dev/mmcblk0p1 is now 7735992 (4k) blocks long.
   802
   803
   804    ### [resize2fs] Start resizing ext4 partition /dev/mmcblk0p1 now
   805
   806    resize2fs 1.44.5 (15-Dec-2018)
   807    The filesystem is already 7735992 (4k) blocks long.  Nothing to do!
   808
   809
   810    ### quick iozone test: 4      781      608     4960     5944     5871     2528
   811
   812    ### [firstrun] Recreated SSH keys (entropy: 3015 3014)
   813
   814    ### Activated 1 lzo zram swap devices with 483 MB each
   815
   816    ### Activated Armbian ramlog partition with zstd compression
   817
   818    Mon 17 Feb 2020 11:51:14 AM UTC | Orange Pi+ 2E | 20.02.1 | armhf | armv7l | 5.4.20-sunxi
   819
   820    ### dmesg:
   821
   822    [    0.000000] Booting Linux on physical CPU 0x0
   823    [    0.000000] Linux version 5.4.20-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.02.1 SMP Mon Feb 17 02:09:41 CET 2020
   824    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
   825    [    0.000000] CPU: div instructions available: patching division code
   826    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
   827    [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi Plus 2E
   828    [    0.000000] Memory policy: Data cache writealloc
   829    [    0.000000] cma: Reserved 128 MiB at 0x75c00000
   830    [    0.000000] On node 0 totalpages: 253952
   831    [    0.000000]   Normal zone: 1728 pages used for memmap
   832    [    0.000000]   Normal zone: 0 pages reserved
   833    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
   834    [    0.000000]   HighMem zone: 57344 pages, LIFO batch:15
   835    [    0.000000] psci: probing for conduit method from DT.
   836    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
   837    [    0.000000] percpu: Embedded 20 pages/cpu s49868 r8192 d23860 u81920
   838    [    0.000000] pcpu-alloc: s49868 r8192 d23860 u81920 alloc=20*4096
   839    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
   840    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 252224
   841    [    0.000000] Kernel command line: root=UUID=f972992c-598b-42c9-a9a0-e82ba21ecd3f rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=9acc51ea-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
   842    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
   843    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
   844    [    0.000000] allocated 1015808 bytes of page_ext
   845    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
   846    [    0.000000] Memory: 850684K/1015808K available (9216K kernel code, 1048K rwdata, 2852K rodata, 1024K init, 316K bss, 34052K reserved, 131072K cma-reserved, 98292K highmem)
   847    [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x3ac with crng_init=0
   848    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
   849    [    0.000000] ftrace: allocating 40584 entries in 80 pages
   850    [    0.000000] rcu: Hierarchical RCU implementation.
   851    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
   852    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
   853    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
   854    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
   855    [    0.000000] GIC: Using split EOI/Deactivate mode
   856    [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
   857    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
   858    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
   859    [    0.000012] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
   860    [    0.000032] Switching to timer-based delay loop, resolution 41ns
   861    [    0.000443] Console: colour dummy device 80x30
   862    [    0.000467] printk: console [tty1] enabled
   863    [    0.000552] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
   864    [    0.000573] pid_max: default: 32768 minimum: 301
   865    [    0.001137] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
   866    [    0.001165] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
   867    [    0.001318] *** VALIDATE tmpfs ***
   868    [    0.002581] *** VALIDATE proc ***
   869    [    0.003142] *** VALIDATE cgroup1 ***
   870    [    0.003156] *** VALIDATE cgroup2 ***
   871    [    0.003267] CPU: Testing write buffer coherency: ok
   872    [    0.004040] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
   873    [    0.005094] Setting up static identity map for 0x40100000 - 0x40100054
   874    [    0.005332] rcu: Hierarchical SRCU implementation.
   875    [    0.006424] smp: Bringing up secondary CPUs ...
   876    [    0.017730] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
   877    [    0.029281] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
   878    [    0.040714] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
   879    [    0.040940] smp: Brought up 1 node, 4 CPUs
   880    [    0.040958] SMP: Total of 4 processors activated (192.00 BogoMIPS).
   881    [    0.040965] CPU: All CPU(s) started in HYP mode.
   882    [    0.040971] CPU: Virtualization extensions available.
   883    [    0.042456] devtmpfs: initialized
   884    [    0.057042] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
   885    [    0.057533] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   886    [    0.057567] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
   887    [    0.067575] xor: measuring software checksum speed
   888    [    0.104844]    arm4regs  :   508.000 MB/sec
   889    [    0.144983]    8regs     :   354.000 MB/sec
   890    [    0.185125]    32regs    :   334.000 MB/sec
   891    [    0.225275]    neon      :   515.000 MB/sec
   892    [    0.225286] xor: using function: neon (515.000 MB/sec)
   893    [    0.225427] pinctrl core: initialized pinctrl subsystem
   894    [    0.227346] NET: Registered protocol family 16
   895    [    0.230861] DMA: preallocated 256 KiB pool for atomic coherent allocations
   896    [    0.231992] audit: initializing netlink subsys (disabled)
   897    [    0.232340] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
   898    [    0.233477] cpuidle: using governor ladder
   899    [    0.233770] cpuidle: using governor menu
   900    [    0.235013] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
   901    [    0.235024] hw-breakpoint: maximum watchpoint size is 8 bytes.
   902    [    0.362044] raid6: neonx8   gen()   286 MB/s
   903    [    0.430150] raid6: neonx8   xor()   235 MB/s
   904    [    0.498342] raid6: neonx4   gen()   294 MB/s
   905    [    0.566455] raid6: neonx4   xor()   245 MB/s
   906    [    0.634816] raid6: neonx2   gen()   266 MB/s
   907    [    0.702883] raid6: neonx2   xor()   237 MB/s
   908    [    0.771169] raid6: neonx1   gen()   195 MB/s
   909    [    0.839331] raid6: neonx1   xor()   178 MB/s
   910    [    0.907716] raid6: int32x8  gen()   108 MB/s
   911    [    0.975659] raid6: int32x8  xor()    70 MB/s
   912    [    1.044184] raid6: int32x4  gen()   114 MB/s
   913    [    1.112067] raid6: int32x4  xor()    77 MB/s
   914    [    1.180349] raid6: int32x2  gen()    99 MB/s
   915    [    1.248667] raid6: int32x2  xor()    75 MB/s
   916    [    1.316795] raid6: int32x1  gen()    75 MB/s
   917    [    1.385255] raid6: int32x1  xor()    59 MB/s
   918    [    1.385265] raid6: using algorithm neonx4 gen() 294 MB/s
   919    [    1.385272] raid6: .... xor() 245 MB/s, rmw enabled
   920    [    1.385280] raid6: using neon recovery algorithm
   921    [    1.388193] iommu: Default domain type: Translated
   922    [    1.388912] SCSI subsystem initialized
   923    [    1.389342] libata version 3.00 loaded.
   924    [    1.389845] usbcore: registered new interface driver usbfs
   925    [    1.389942] usbcore: registered new interface driver hub
   926    [    1.390094] usbcore: registered new device driver usb
   927    [    1.390515] mc: Linux media interface: v0.10
   928    [    1.390584] videodev: Linux video capture interface: v2.00
   929    [    1.390839] pps_core: LinuxPPS API ver. 1 registered
   930    [    1.390849] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   931    [    1.390885] PTP clock support registered
   932    [    1.394353] clocksource: Switched to clocksource arch_sys_counter
   933    [    3.388974] *** VALIDATE bpf ***
   934    [    3.389485] VFS: Disk quotas dquot_6.6.0
   935    [    3.389650] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
   936    [    3.389827] *** VALIDATE ramfs ***
   937    [    3.407454] thermal_sys: Registered thermal governor 'fair_share'
   938    [    3.407464] thermal_sys: Registered thermal governor 'bang_bang'
   939    [    3.407479] thermal_sys: Registered thermal governor 'step_wise'
   940    [    3.407487] thermal_sys: Registered thermal governor 'power_allocator'
   941    [    3.408432] NET: Registered protocol family 2
   942    [    3.409754] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
   943    [    3.409819] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
   944    [    3.409984] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
   945    [    3.410257] TCP: Hash tables configured (established 8192 bind 8192)
   946    [    3.410557] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
   947    [    3.410648] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
   948    [    3.411106] NET: Registered protocol family 1
   949    [    3.412119] RPC: Registered named UNIX socket transport module.
   950    [    3.412130] RPC: Registered udp transport module.
   951    [    3.412137] RPC: Registered tcp transport module.
   952    [    3.412144] RPC: Registered tcp NFSv4.1 backchannel transport module.
   953    [    3.412579] Trying to unpack rootfs image as initramfs...
   954    [    4.461390] Freeing initrd memory: 7172K
   955    [    4.465501] Initialise system trusted keyrings
   956    [    4.465968] workingset: timestamp_bits=14 max_order=18 bucket_order=4
   957    [    4.480764] zbud: loaded
   958    [    4.485781] NFS: Registering the id_resolver key type
   959    [    4.485825] Key type id_resolver registered
   960    [    4.485833] Key type id_legacy registered
   961    [    4.485860] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   962    [    4.485868] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   963    [    4.488846] JFS: nTxBlock = 7726, nTxLock = 61808
   964    [    4.502517] SGI XFS with ACLs, security attributes, realtime, no debug enabled
   965    [    4.624355] Key type asymmetric registered
   966    [    4.624373] Asymmetric key parser 'x509' registered
   967    [    4.624521] bounce: pool size: 64 pages
   968    [    4.624649] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   969    [    4.625027] io scheduler mq-deadline registered
   970    [    4.625039] io scheduler kyber registered
   971    [    4.625167] io scheduler bfq registered
   972    [    4.637440] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
   973    [    4.640905] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
   974    [    4.655366] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
   975    [    4.658959] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
   976    [    4.659809] printk: console [ttyS0] disabled
   977    [    4.680126] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 43, base_baud = 1500000) is a U6_16550A
   978    [    4.680222] printk: console [ttyS0] enabled
   979    [    4.693913] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a8da18)
   980    [    4.694488] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a8a600)
   981    [    4.694638] sun8i-dw-hdmi 1ee0000.hdmi: 1ee0000.hdmi supply hvcc not found, using dummy regulator
   982    [    4.696013] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
   983    [    4.696803] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
   984    [    4.697333] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a8d004)
   985    [    4.697348] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
   986    [    4.697354] [drm] No driver support for vblank timestamp query.
   987    [    4.698144] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
   988    [    5.043807] Console: switching to colour frame buffer device 128x48
   989    [    5.093593] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
   990    [    5.100873] brd: module loaded
   991    [    5.114070] loop: module loaded
   992    [    5.118966] libphy: Fixed MDIO Bus: probed
   993    [    5.120487] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
   994    [    5.120850] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
   995    [    5.120868] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
   996    [    5.121061] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
   997    [    5.123549] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   998    [    5.123561] ehci-platform: EHCI generic platform driver
   999    [    5.123891] ehci-platform 1c1a000.usb: EHCI Host Controller
  1000    [    5.123944] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  1001    [    5.124752] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  1002    [    5.138361] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  1003    [    5.138913] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  1004    [    5.138933] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1005    [    5.138948] usb usb1: Product: EHCI Host Controller
  1006    [    5.138963] usb usb1: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  1007    [    5.138977] usb usb1: SerialNumber: 1c1a000.usb
  1008    [    5.140060] hub 1-0:1.0: USB hub found
  1009    [    5.140166] hub 1-0:1.0: 1 port detected
  1010    [    5.141993] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  1011    [    5.142033] ohci-platform: OHCI generic platform driver
  1012    [    5.142476] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  1013    [    5.142542] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
  1014    [    5.142896] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  1015    [    5.206900] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  1016    [    5.206920] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1017    [    5.206936] usb usb2: Product: Generic Platform OHCI controller
  1018    [    5.206951] usb usb2: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  1019    [    5.206965] usb usb2: SerialNumber: 1c1a400.usb
  1020    [    5.208019] hub 2-0:1.0: USB hub found
  1021    [    5.208123] hub 2-0:1.0: 1 port detected
  1022    [    5.210982] usbcore: registered new interface driver usb-storage
  1023    [    5.213691] sun6i-rtc 1f00000.rtc: registered as rtc0
  1024    [    5.213707] sun6i-rtc 1f00000.rtc: RTC enabled
  1025    [    5.214428] i2c /dev entries driver
  1026    [    5.215213] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
  1027    [    5.219393] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  1028    [    5.220735] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
  1029    [    5.222157] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  1030    [    5.247823] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
  1031    [    5.248318] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  1032    [    5.250496] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
  1033    [    5.275038] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
  1034    [    5.277526] ledtrig-cpu: registered to indicate activity on CPUs
  1035    [    5.277692] hidraw: raw HID events driver (C) Jiri Kosina
  1036    [    5.277938] usbcore: registered new interface driver usbhid
  1037    [    5.277945] usbhid: USB HID core driver
  1038    [    5.281736] Initializing XFRM netlink socket
  1039    [    5.283297] NET: Registered protocol family 10
  1040    [    5.284074] mmc0: host does not support reading read-only switch, assuming write-enable
  1041    [    5.286155] mmc0: new high speed SDHC card at address 0001
  1042    [    5.288028] mmcblk0: mmc0:0001 00000 29.8 GiB
  1043    [    5.291991]  mmcblk0: p1
  1044    [    5.422092] Segment Routing with IPv6
  1045    [    5.422287] NET: Registered protocol family 17
  1046    [    5.422397] NET: Registered protocol family 15
  1047    [    5.422524] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  1048    [    5.422905] 8021q: 802.1Q VLAN Support v1.8
  1049    [    5.423004] Key type dns_resolver registered
  1050    [    5.424053] Registering SWP/SWPB emulation handler
  1051    [    5.424590] registered taskstats version 1
  1052    [    5.424599] Loading compiled-in X.509 certificates
  1053    [    5.424810] zswap: loaded using pool lzo/zbud
  1054    [    5.425395] Key type ._fscrypt registered
  1055    [    5.425405] Key type .fscrypt registered
  1056    [    5.431423] Btrfs loaded, crc32c=crc32c-generic
  1057    [    5.434615] mmc1: new DDR MMC card at address 0001
  1058    [    5.436521] mmcblk1: mmc1:0001 NCard  7.22 GiB
  1059    [    5.437491] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
  1060    [    5.438588] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
  1061    [    5.442098]  mmcblk1: p1
  1062    [    5.499545] Key type encrypted registered
  1063    [    5.522516] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  1064    [    5.523438] simple-framebuffer 7e000000.framebuffer: framebuffer at 0x7e000000, 0x300000 bytes, mapped to 0x(ptrval)
  1065    [    5.523462] simple-framebuffer 7e000000.framebuffer: format=x8r8g8b8, mode=1024x768x32, linelength=4096
  1066    [    5.523881] simple-framebuffer 7e000000.framebuffer: fb1: simplefb registered!
  1067    [    5.524301] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  1068    [    5.527354] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  1069    [    5.527375] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  1070    [    5.527551] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  1071    [    5.527757] dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
  1072    [    5.610372] random: fast init done
  1073    [    5.634815] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000)
  1074    [    5.634852] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  1075    [    5.634866] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  1076    [    5.634880] dwmac-sun8i 1c30000.ethernet: COE Type 2
  1077    [    5.634894] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  1078    [    5.634908] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  1079    [    5.634921] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  1080    [    5.635262] libphy: stmmac: probed
  1081    [    5.636715] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
  1082    [    5.636957] libphy: mdio_mux: probed
  1083    [    5.636998] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
  1084    [    5.637017] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
  1085    [    5.658721] ac200: Unknown symbol ac200_reg_mod (err -2)
  1086    [    5.658772] ac200: Unknown symbol ac200_reg_write (err -2)
  1087    [    5.661526] libphy: mdio_mux: probed
  1088    [    5.661576] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
  1089    [    5.761676] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
  1090    [    5.761863] dwmac-sun8i 1c30000.ethernet: Error: Failed to register MDIO bus for child /soc/ethernet@1c30000/mdio-mux/mdio@2
  1091    [    5.763105] ehci-platform 1c1b000.usb: EHCI Host Controller
  1092    [    5.763162] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
  1093    [    5.764046] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  1094    [    5.778412] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  1095    [    5.778890] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  1096    [    5.778909] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1097    [    5.778925] usb usb3: Product: EHCI Host Controller
  1098    [    5.778940] usb usb3: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  1099    [    5.778954] usb usb3: SerialNumber: 1c1b000.usb
  1100    [    5.780063] hub 3-0:1.0: USB hub found
  1101    [    5.780147] hub 3-0:1.0: 1 port detected
  1102    [    5.781869] ehci-platform 1c1c000.usb: EHCI Host Controller
  1103    [    5.781934] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
  1104    [    5.782465] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
  1105    [    5.798398] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
  1106    [    5.798802] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  1107    [    5.798821] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1108    [    5.798837] usb usb4: Product: EHCI Host Controller
  1109    [    5.798852] usb usb4: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  1110    [    5.798866] usb usb4: SerialNumber: 1c1c000.usb
  1111    [    5.799865] hub 4-0:1.0: USB hub found
  1112    [    5.799963] hub 4-0:1.0: 1 port detected
  1113    [    5.801588] ehci-platform 1c1d000.usb: EHCI Host Controller
  1114    [    5.801636] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
  1115    [    5.802133] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
  1116    [    5.814401] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
  1117    [    5.814811] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  1118    [    5.814831] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1119    [    5.814846] usb usb5: Product: EHCI Host Controller
  1120    [    5.814860] usb usb5: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  1121    [    5.814875] usb usb5: SerialNumber: 1c1d000.usb
  1122    [    5.815851] hub 5-0:1.0: USB hub found
  1123    [    5.815928] hub 5-0:1.0: 1 port detected
  1124    [    5.817551] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  1125    [    5.817600] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
  1126    [    5.817947] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  1127    [    5.878806] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  1128    [    5.878825] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1129    [    5.878841] usb usb6: Product: Generic Platform OHCI controller
  1130    [    5.878856] usb usb6: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  1131    [    5.878869] usb usb6: SerialNumber: 1c1b400.usb
  1132    [    5.879864] hub 6-0:1.0: USB hub found
  1133    [    5.879957] hub 6-0:1.0: 1 port detected
  1134    [    5.881610] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
  1135    [    5.881659] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
  1136    [    5.882014] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
  1137    [    5.942745] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  1138    [    5.942765] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1139    [    5.942781] usb usb7: Product: Generic Platform OHCI controller
  1140    [    5.942795] usb usb7: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  1141    [    5.942809] usb usb7: SerialNumber: 1c1c400.usb
  1142    [    5.943808] hub 7-0:1.0: USB hub found
  1143    [    5.943886] hub 7-0:1.0: 1 port detected
  1144    [    5.945519] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
  1145    [    5.945569] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
  1146    [    5.945897] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
  1147    [    6.006751] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  1148    [    6.006772] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1149    [    6.006788] usb usb8: Product: Generic Platform OHCI controller
  1150    [    6.006802] usb usb8: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  1151    [    6.006817] usb usb8: SerialNumber: 1c1d400.usb
  1152    [    6.007788] hub 8-0:1.0: USB hub found
  1153    [    6.007867] hub 8-0:1.0: 1 port detected
  1154    [    6.009596] usb_phy_generic usb_phy_generic.2.auto: usb_phy_generic.2.auto supply vcc not found, using dummy regulator
  1155    [    6.010624] musb-hdrc musb-hdrc.3.auto: MUSB HDRC host driver
  1156    [    6.010670] musb-hdrc musb-hdrc.3.auto: new USB bus registered, assigned bus number 9
  1157    [    6.011119] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  1158    [    6.011138] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1159    [    6.011154] usb usb9: Product: MUSB HDRC host driver
  1160    [    6.011169] usb usb9: Manufacturer: Linux 5.4.20-sunxi musb-hcd
  1161    [    6.011183] usb usb9: SerialNumber: musb-hdrc.3.auto
  1162    [    6.012100] hub 9-0:1.0: USB hub found
  1163    [    6.012180] hub 9-0:1.0: 1 port detected
  1164    [    6.019731] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:04:31 UTC (271)
  1165    [    6.020107] of_cfs_init
  1166    [    6.020313] of_cfs_init: OK
  1167    [    6.031249] Freeing unused kernel memory: 1024K
  1168    [    6.034973] Run /init as init process
  1169    [    6.760093] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
  1170    [    6.782486] usb 2-1: new full-speed USB device number 2 using ohci-platform
  1171    [    7.016008] usb 2-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
  1172    [    7.016044] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1173    [    7.016062] usb 2-1: Product: USB Receiver
  1174    [    7.016077] usb 2-1: Manufacturer: Logitech
  1175    [    7.019541] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  1176    [    7.044108] input: Logitech USB Receiver as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.0/0003:046D:C52B.0001/input/input1
  1177    [    7.050510] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
  1178    [    7.083700] mmc2: new high speed SDIO card at address 0001
  1179    [    7.103083] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-1c1a400.usb-1/input0
  1180    [    7.115072] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input2
  1181    [    7.115626] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input3
  1182    [    7.174823] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input4
  1183    [    7.175601] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1a400.usb-1/input1
  1184    [    7.184869] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
  1185    [    7.294837] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
  1186    [    7.424592] input: Logitech Unifying Device. Wireless PID:4024 Keyboard as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input6
  1187    [    7.425076] input: Logitech Unifying Device. Wireless PID:4024 Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input7
  1188    [    7.425620] input: Logitech Unifying Device. Wireless PID:4024 Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input8
  1189    [    7.426080] hid-generic 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4024] on usb-1c1a400.usb-1/input2:1
  1190    [    7.537164] input: Logitech K400 as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input12
  1191    [    7.537570] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-1c1a400.usb-1/input2:1
  1192    [    8.168060] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  1193    [    9.024341] systemd[1]: System time before build time, advancing clock.
  1194    [    9.099740] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1195    [    9.101232] systemd[1]: Detected architecture arm.
  1196    [    9.151180] systemd[1]: Set hostname to <orangepiplus2e>.
  1197    [    9.158765] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
  1198    [   10.377361] random: systemd: uninitialized urandom read (16 bytes read)
  1199    [   10.403038] random: systemd: uninitialized urandom read (16 bytes read)
  1200    [   10.404187] systemd[1]: Listening on Journal Socket (/dev/log).
  1201    [   10.406240] random: systemd: uninitialized urandom read (16 bytes read)
  1202    [   10.407335] systemd[1]: Listening on udev Control Socket.
  1203    [   10.409122] systemd[1]: Listening on fsck to fsckd communication Socket.
  1204    [   10.410737] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  1205    [   10.421066] systemd[1]: Created slice system-serial\x2dgetty.slice.
  1206    [   10.423830] systemd[1]: Listening on Journal Audit Socket.
  1207    [   10.767624] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  1208    [   12.076396] systemd-journald[298]: Received request to flush runtime journal from PID 1
  1209    [   12.333745] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
  1210    [   12.359684] cedrus 1c0e000.video-codec: Device registered as /dev/video0
  1211    [   12.729939] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1212    [   12.947531] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1213    [   12.955978] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1214    [   12.956005] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
  1215    [   13.043484] sun4i-codec 1c22c00.codec: Failed to register our card
  1216    [   13.139206] Registered IR keymap rc-empty
  1217    [   13.139453] rc rc1: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1
  1218    [   13.208026] rc rc1: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
  1219    [   13.208997] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1/input14
  1220    [   13.224399] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
  1221    [   13.226046] sunxi-ir 1f02000.ir: initialized sunXi IR driver
  1222    [   13.226949] lima 1c40000.gpu: IRQ ppmmu2 not found
  1223    [   13.226976] lima 1c40000.gpu: IRQ ppmmu3 not found
  1224    [   13.227031] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
  1225    [   13.227191] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
  1226    [   13.227359] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
  1227    [   13.227472] lima 1c40000.gpu: IRQ pp2 not found
  1228    [   13.227492] lima 1c40000.gpu: IRQ pp3 not found
  1229    [   13.227515] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
  1230    [   13.232090] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
  1231    [   13.234520] Registered IR keymap rc-cec
  1232    [   13.235068] rc rc0: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0
  1233    [   13.235901] input: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0/input13
  1234    [   13.328053] lima 1c40000.gpu: bus rate = 200000000
  1235    [   13.328106] lima 1c40000.gpu: mod rate = 384000000
  1236    [   13.329242] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 1
  1237    [   13.376014] bFWReady == _FALSE call reset 8051...
  1238    [   13.437414] zram: Added device: zram0
  1239    [   13.441721] zram: Added device: zram1
  1240    [   13.444618] zram: Added device: zram2
  1241    [   13.694058] zram1: detected capacity change from 0 to 506855424
  1242    [   13.951713] cfg80211: failed to load regulatory.db
  1243    [   13.996183] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok
  1244    [   14.834388] Adding 494972k swap on /dev/zram1.  Priority:5 extents:1 across:494972k SSFS
  1245    [   15.143350] zram0: detected capacity change from 0 to 52428800
  1246    [   17.474432] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
  1247    [   17.474510] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  1248    [   18.892818] random: crng init done
  1249    [   18.892839] random: 7 urandom warning(s) missed due to ratelimiting
  1250
  1251    ### armbian-release:
  1252
  1253    # PLEASE DO NOT EDIT THIS FILE
  1254    BOARD=orangepiplus2e
  1255    BOARD_NAME="Orange Pi+ 2E"
  1256    BOARDFAMILY=sun8i
  1257    BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin
  1258    BUILD_REPOSITORY_COMMIT=3e533c9
  1259    DISTRIBUTION_CODENAME=buster
  1260    DISTRIBUTION_STATUS=supported
  1261    VERSION=20.02.1
  1262    LINUXFAMILY=sunxi
  1263    BRANCH=current
  1264    ARCH=arm
  1265    IMAGE_TYPE=stable
  1266    BOARD_TYPE=conf
  1267    INITRD_ARCH=arm
  1268    KERNEL_IMAGE_TYPE=Image
  1269
  1270    ### boot environment:
  1271
  1272    verbosity=1
  1273    logo=disabled
  1274    console=both
  1275    disp_mode=1920x1080p60
  1276    overlay_prefix=sun8i-h3
  1277    rootdev=UUID=f972992c-598b-42c9-a9a0-e82ba21ecd3f
  1278    rootfstype=ext4
  1279    usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  1280
  1281    ### lsusb:
  1282
  1283    Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1284    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1285    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1286    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1287    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1288    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1289    Bus 002 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
  1290    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1291    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1292    Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1293
  1294    ### lscpu:
  1295
  1296    Architecture:        armv7l
  1297    Byte Order:          Little Endian
  1298    CPU(s):              4
  1299    On-line CPU(s) list: 0-3
  1300    Thread(s) per core:  1
  1301    Core(s) per socket:  4
  1302    Socket(s):           1
  1303    Vendor ID:           ARM
  1304    Model:               5
  1305    Model name:          Cortex-A7
  1306    Stepping:            r0p5
  1307    BogoMIPS:            48.00
  1308    Flags:               half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  1309
  1310    ### cpuinfo:
  1311
  1312    processor    : 0
  1313    model name    : ARMv7 Processor rev 5 (v7l)
  1314    BogoMIPS    : 48.00
  1315    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  1316    CPU implementer    : 0x41
  1317    CPU architecture: 7
  1318    CPU variant    : 0x0
  1319    CPU part    : 0xc07
  1320    CPU revision    : 5
  1321
  1322    processor    : 1
  1323    model name    : ARMv7 Processor rev 5 (v7l)
  1324    BogoMIPS    : 48.00
  1325    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  1326    CPU implementer    : 0x41
  1327    CPU architecture: 7
  1328    CPU variant    : 0x0
  1329    CPU part    : 0xc07
  1330    CPU revision    : 5
  1331
  1332    processor    : 2
  1333    model name    : ARMv7 Processor rev 5 (v7l)
  1334    BogoMIPS    : 48.00
  1335    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  1336    CPU implementer    : 0x41
  1337    CPU architecture: 7
  1338    CPU variant    : 0x0
  1339    CPU part    : 0xc07
  1340    CPU revision    : 5
  1341
  1342    processor    : 3
  1343    model name    : ARMv7 Processor rev 5 (v7l)
  1344    BogoMIPS    : 48.00
  1345    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  1346    CPU implementer    : 0x41
  1347    CPU architecture: 7
  1348    CPU variant    : 0x0
  1349    CPU part    : 0xc07
  1350    CPU revision    : 5
  1351
  1352    Hardware    : Allwinner sun8i Family
  1353    Revision    : 0000
  1354    Serial        : 02c00081bd8e203d
  1355
  1356    ### meminfo:
  1357
  1358    MemTotal:         989952 kB
  1359    MemFree:          863128 kB
  1360    MemAvailable:     902872 kB
  1361    Buffers:            7580 kB
  1362    Cached:            38304 kB
  1363    SwapCached:            0 kB
  1364    Active:            35124 kB
  1365    Inactive:          23792 kB
  1366    Active(anon):      13592 kB
  1367    Inactive(anon):     1524 kB
  1368    Active(file):      21532 kB
  1369    Inactive(file):    22268 kB
  1370    Unevictable:           0 kB
  1371    Mlocked:               0 kB
  1372    HighTotal:        229364 kB
  1373    HighFree:         155196 kB
  1374    LowTotal:         760588 kB
  1375    LowFree:          707932 kB
  1376    SwapTotal:        494972 kB
  1377    SwapFree:         494972 kB
  1378    Dirty:              1216 kB
  1379    Writeback:             0 kB
  1380    AnonPages:         13388 kB
  1381    Mapped:            15772 kB
  1382    Shmem:              1664 kB
  1383    KReclaimable:      13960 kB
  1384    Slab:              38232 kB
  1385    SReclaimable:      13960 kB
  1386    SUnreclaim:        24272 kB
  1387    KernelStack:        1136 kB
  1388    PageTables:          780 kB
  1389    NFS_Unstable:          0 kB
  1390    Bounce:                0 kB
  1391    WritebackTmp:          0 kB
  1392    CommitLimit:      989948 kB
  1393    Committed_AS:      67152 kB
  1394    VmallocTotal:     245760 kB
  1395    VmallocUsed:       15904 kB
  1396    VmallocChunk:          0 kB
  1397    Percpu:              704 kB
  1398    CmaTotal:         131072 kB
  1399    CmaFree:          125180 kB
  1400
  1401    ### virtual memory:
  1402
  1403    vm.admin_reserve_kbytes = 8192
  1404    vm.block_dump = 0
  1405    vm.compact_unevictable_allowed = 1
  1406    vm.dirty_background_bytes = 0
  1407    vm.dirty_background_ratio = 10
  1408    vm.dirty_bytes = 0
  1409    vm.dirty_expire_centisecs = 3000
  1410    vm.dirty_ratio = 20
  1411    vm.dirtytime_expire_seconds = 43200
  1412    vm.dirty_writeback_centisecs = 500
  1413    vm.extfrag_threshold = 500
  1414    vm.highmem_is_dirtyable = 0
  1415    vm.laptop_mode = 0
  1416    vm.legacy_va_layout = 0
  1417    vm.lowmem_reserve_ratio = 32    0    0
  1418    vm.max_map_count = 65530
  1419    vm.min_free_kbytes = 3469
  1420    vm.mmap_min_addr = 4096
  1421    vm.mmap_rnd_bits = 8
  1422    vm.oom_dump_tasks = 1
  1423    vm.oom_kill_allocating_task = 0
  1424    vm.overcommit_kbytes = 0
  1425    vm.overcommit_memory = 0
  1426    vm.overcommit_ratio = 50
  1427    vm.page-cluster = 0
  1428    vm.panic_on_oom = 0
  1429    vm.percpu_pagelist_fraction = 0
  1430    vm.stat_interval = 1
  1431    vm.swappiness = 100
  1432    vm.user_reserve_kbytes = 30550
  1433    vm.vfs_cache_pressure = 100
  1434    vm.watermark_boost_factor = 15000
  1435    vm.watermark_scale_factor = 10
  1436
  1437    ### ip addr:
  1438
  1439    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1440        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1441        inet XXX.XXX.0.1/8 scope host lo
  1442           valid_lft forever preferred_lft forever
  1443        inet6 ::1/128 scope host
  1444           valid_lft forever preferred_lft forever
  1445    2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1446        link/ether be:19:40:bc:43:d2 brd ff:ff:ff:ff:ff:ff
  1447    3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1448        link/ether 02:81:bd:8e:20:3d brd ff:ff:ff:ff:ff:ff
  1449    4: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  1450        link/ether cc:79:cf:54:c5:4a brd ff:ff:ff:ff:ff:ff
  1451
  1452    ### partitions:
  1453
  1454    major minor  #blocks  name
  1455
  1456     179        0   31260672 mmcblk0
  1457     179        1   30943968 mmcblk0p1
  1458     179        8    7570432 mmcblk1
  1459     179        9    7490624 mmcblk1p1
  1460     254        0      51200 zram0
  1461     254        1     494976 zram1
  1462
  1463    ### df:
  1464
  1465    udev            416M     0  416M   0% /dev
  1466    tmpfs            97M  3.0M   94M   4% /run
  1467    /dev/mmcblk0p1   30G  921M   28G   4% /
  1468    tmpfs           484M     0  484M   0% /dev/shm
  1469    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  1470    tmpfs           484M     0  484M   0% /sys/fs/cgroup
  1471    tmpfs           484M  4.0K  484M   1% /tmp
  1472    /dev/zram0       49M  1.3M   44M   3% /var/log
  1473
  1474    ### lsblk:
  1475
  1476    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  1477    mmcblk0              29.8G
  1478    └─mmcblk0p1  ext4    29.5G /          f972992c-598b-42c9-a9a0-e82ba21ecd3f
  1479    mmcblk1               7.2G
  1480    └─mmcblk1p1  ext4     7.1G            07520a06-bc92-4f9f-be19-d47f09d82abd
  1481    mmcblk1boot0            4M
  1482    mmcblk1boot1            4M
  1483    zram0                  50M /var/log
  1484
  1485    ### zramctl:
  1486
  1487    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  1488    /dev/zram1 lzo         483.4M    4K    76B    4K       4 [SWAP]
  1489    /dev/zram0 zstd           50M  1.3M 204.2K  528K       4 /var/log
  1490
  1491    ### mtab:
  1492
  1493    /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1494    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1495    /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
  1496
  1497    ### mmc1:0001 info:
  1498
  1499                  manfid: 0x000088
  1500                     cid: 8801034e436172642026e16382562375
  1501                   fwrev: 0x0000000000000000
  1502                     rca: 0x0001
  1503                     csd: d0ffff320f5903ffffffffe7964000eb
  1504               life_time: 0x01 0x01
  1505                     ocr: 0x00200000
  1506                    type: MMC
  1507    enhanced_area_offset: 18446744073709551594
  1508                    date: 02/2016
  1509                   hwrev: 0x0
  1510                     prv: 0x26
  1511                     dsr: 0x404
  1512             ffu_capable: 1
  1513                  serial: 0xe1638256
  1514      raw_rpmb_size_mult: 0x20
  1515              erase_size: 524288
  1516            pre_eol_info: 0x01
  1517             rel_sectors: 0x1
  1518                 cmdq_en: 0
  1519                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=NCard  MODALIAS=mmc:block
  1520      enhanced_area_size: 4294967274
  1521                   oemid: 0x0103
  1522                     rev: 0x7
  1523    preferred_erase_size: 4194304
  1524                    name: NCard
  1525
  1526    ### mmc0:0001 info:
  1527
  1528                  manfid: 0x00001b
  1529                     cid: 1b534d303030303010d24155a7010c67
  1530                   fwrev: 0x0
  1531                     rca: 0x0001
  1532                     csd: 400e00325b590000ee7f7f800a404055
  1533                     ocr: 0x00200000
  1534                    type: SD
  1535                    date: 12/2016
  1536                   hwrev: 0x1
  1537                     dsr: 0x404
  1538                  serial: 0xd24155a7
  1539              erase_size: 512
  1540                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=00000 MODALIAS=mmc:block
  1541                     ssr: 0000000005000000040090000f051d00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1542                     scr: 02b5800200000000
  1543                   oemid: 0x534d
  1544    preferred_erase_size: 4194304
  1545                    name: 00000
  1546
  1547    ### Boot system health:
  1548
  1549    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  1550    11:51:22:   ---      0.84  53%  29%  22%   0%   0%   0% 45.2°C
  1551    11:51:22:   ---      0.85  10%   7%   0%   2%   0%   0% 45.0°C
  1552    11:51:23:   ---      0.85   9%   6%   0%   2%   0%   0% 44.8°C
  1553    11:51:23:   ---      0.85  17%  14%   0%   1%   0%   0% 45.0°C
  1554    11:51:24:   ---      0.85  23%  20%   0%   2%   0%   0% 45.0°C
  1555
  1556    ### Activated 1 lzo zram swap devices with 483 MB each
  1557
  1558    ### Activated Armbian ramlog partition with zstd compression
  1559
  1560    vie may 15 20:14:14 CEST 2020 | Orange Pi+ 2E | 20.02.1 | armhf | armv7l | 5.4.20-sunxi
  1561
  1562    ### dmesg:
  1563
  1564    [    0.000000] Booting Linux on physical CPU 0x0
  1565    [    0.000000] Linux version 5.4.20-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.02.1 SMP Mon Feb 17 02:09:41 CET 2020
  1566    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
  1567    [    0.000000] CPU: div instructions available: patching division code
  1568    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  1569    [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi Plus 2E
  1570    [    0.000000] Memory policy: Data cache writealloc
  1571    [    0.000000] cma: Reserved 128 MiB at 0x75c00000
  1572    [    0.000000] On node 0 totalpages: 253952
  1573    [    0.000000]   Normal zone: 1728 pages used for memmap
  1574    [    0.000000]   Normal zone: 0 pages reserved
  1575    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
  1576    [    0.000000]   HighMem zone: 57344 pages, LIFO batch:15
  1577    [    0.000000] psci: probing for conduit method from DT.
  1578    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
  1579    [    0.000000] percpu: Embedded 20 pages/cpu s49868 r8192 d23860 u81920
  1580    [    0.000000] pcpu-alloc: s49868 r8192 d23860 u81920 alloc=20*4096
  1581    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  1582    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 252224
  1583    [    0.000000] Kernel command line: root=UUID=f972992c-598b-42c9-a9a0-e82ba21ecd3f rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=9acc51ea-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
  1584    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
  1585    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
  1586    [    0.000000] allocated 1015808 bytes of page_ext
  1587    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  1588    [    0.000000] Memory: 850684K/1015808K available (9216K kernel code, 1048K rwdata, 2852K rodata, 1024K init, 316K bss, 34052K reserved, 131072K cma-reserved, 98292K highmem)
  1589    [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x3ac with crng_init=0
  1590    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  1591    [    0.000000] ftrace: allocating 40584 entries in 80 pages
  1592    [    0.000000] rcu: Hierarchical RCU implementation.
  1593    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  1594    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  1595    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  1596    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
  1597    [    0.000000] GIC: Using split EOI/Deactivate mode
  1598    [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  1599    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  1600    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  1601    [    0.000012] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  1602    [    0.000032] Switching to timer-based delay loop, resolution 41ns
  1603    [    0.000446] Console: colour dummy device 80x30
  1604    [    0.000469] printk: console [tty1] enabled
  1605    [    0.000554] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  1606    [    0.000575] pid_max: default: 32768 minimum: 301
  1607    [    0.001133] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  1608    [    0.001160] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  1609    [    0.001314] *** VALIDATE tmpfs ***
  1610    [    0.002580] *** VALIDATE proc ***
  1611    [    0.003137] *** VALIDATE cgroup1 ***
  1612    [    0.003152] *** VALIDATE cgroup2 ***
  1613    [    0.003263] CPU: Testing write buffer coherency: ok
  1614    [    0.004039] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
  1615    [    0.005092] Setting up static identity map for 0x40100000 - 0x40100054
  1616    [    0.005336] rcu: Hierarchical SRCU implementation.
  1617    [    0.006419] smp: Bringing up secondary CPUs ...
  1618    [    0.017717] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
  1619    [    0.029274] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
  1620    [    0.040710] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
  1621    [    0.040938] smp: Brought up 1 node, 4 CPUs
  1622    [    0.040955] SMP: Total of 4 processors activated (192.00 BogoMIPS).
  1623    [    0.040962] CPU: All CPU(s) started in HYP mode.
  1624    [    0.040968] CPU: Virtualization extensions available.
  1625    [    0.042445] devtmpfs: initialized
  1626    [    0.056987] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
  1627    [    0.057484] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  1628    [    0.057517] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  1629    [    0.067504] xor: measuring software checksum speed
  1630    [    0.104832]    arm4regs  :   508.000 MB/sec
  1631    [    0.144971]    8regs     :   354.000 MB/sec
  1632    [    0.185112]    32regs    :   334.000 MB/sec
  1633    [    0.225261]    neon      :   515.000 MB/sec
  1634    [    0.225272] xor: using function: neon (515.000 MB/sec)
  1635    [    0.225413] pinctrl core: initialized pinctrl subsystem
  1636    [    0.227371] NET: Registered protocol family 16
  1637    [    0.230818] DMA: preallocated 256 KiB pool for atomic coherent allocations
  1638    [    0.231976] audit: initializing netlink subsys (disabled)
  1639    [    0.232319] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
  1640    [    0.233493] cpuidle: using governor ladder
  1641    [    0.233565] cpuidle: using governor menu
  1642    [    0.234798] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
  1643    [    0.234809] hw-breakpoint: maximum watchpoint size is 8 bytes.
  1644    [    0.366222] raid6: neonx8   gen()   287 MB/s
  1645    [    0.434317] raid6: neonx8   xor()   235 MB/s
  1646    [    0.502516] raid6: neonx4   gen()   294 MB/s
  1647    [    0.570614] raid6: neonx4   xor()   245 MB/s
  1648    [    0.638960] raid6: neonx2   gen()   266 MB/s
  1649    [    0.707066] raid6: neonx2   xor()   237 MB/s
  1650    [    0.775298] raid6: neonx1   gen()   195 MB/s
  1651    [    0.843412] raid6: neonx1   xor()   178 MB/s
  1652    [    0.911873] raid6: int32x8  gen()   108 MB/s
  1653    [    0.979803] raid6: int32x8  xor()    70 MB/s
  1654    [    1.048333] raid6: int32x4  gen()   114 MB/s
  1655    [    1.116189] raid6: int32x4  xor()    77 MB/s
  1656    [    1.184440] raid6: int32x2  gen()    99 MB/s
  1657    [    1.252797] raid6: int32x2  xor()    75 MB/s
  1658    [    1.320846] raid6: int32x1  gen()    75 MB/s
  1659    [    1.389382] raid6: int32x1  xor()    59 MB/s
  1660    [    1.389392] raid6: using algorithm neonx4 gen() 294 MB/s
  1661    [    1.389399] raid6: .... xor() 245 MB/s, rmw enabled
  1662    [    1.389408] raid6: using neon recovery algorithm
  1663    [    1.392230] iommu: Default domain type: Translated
  1664    [    1.393010] SCSI subsystem initialized
  1665    [    1.393390] libata version 3.00 loaded.
  1666    [    1.393842] usbcore: registered new interface driver usbfs
  1667    [    1.393938] usbcore: registered new interface driver hub
  1668    [    1.394094] usbcore: registered new device driver usb
  1669    [    1.394495] mc: Linux media interface: v0.10
  1670    [    1.394561] videodev: Linux video capture interface: v2.00
  1671    [    1.394811] pps_core: LinuxPPS API ver. 1 registered
  1672    [    1.394821] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  1673    [    1.394858] PTP clock support registered
  1674    [    1.398004] clocksource: Switched to clocksource arch_sys_counter
  1675    [    3.392364] *** VALIDATE bpf ***
  1676    [    3.392827] VFS: Disk quotas dquot_6.6.0
  1677    [    3.392994] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  1678    [    3.393178] *** VALIDATE ramfs ***
  1679    [    3.410754] thermal_sys: Registered thermal governor 'fair_share'
  1680    [    3.410764] thermal_sys: Registered thermal governor 'bang_bang'
  1681    [    3.410778] thermal_sys: Registered thermal governor 'step_wise'
  1682    [    3.410786] thermal_sys: Registered thermal governor 'power_allocator'
  1683    [    3.411717] NET: Registered protocol family 2
  1684    [    3.413061] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
  1685    [    3.413123] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
  1686    [    3.413288] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
  1687    [    3.413561] TCP: Hash tables configured (established 8192 bind 8192)
  1688    [    3.413784] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
  1689    [    3.413875] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
  1690    [    3.414398] NET: Registered protocol family 1
  1691    [    3.415370] RPC: Registered named UNIX socket transport module.
  1692    [    3.415380] RPC: Registered udp transport module.
  1693    [    3.415387] RPC: Registered tcp transport module.
  1694    [    3.415394] RPC: Registered tcp NFSv4.1 backchannel transport module.
  1695    [    3.415842] Trying to unpack rootfs image as initramfs...
  1696    [    4.464888] Freeing initrd memory: 7172K
  1697    [    4.469029] Initialise system trusted keyrings
  1698    [    4.469436] workingset: timestamp_bits=14 max_order=18 bucket_order=4
  1699    [    4.484326] zbud: loaded
  1700    [    4.489230] NFS: Registering the id_resolver key type
  1701    [    4.489282] Key type id_resolver registered
  1702    [    4.489291] Key type id_legacy registered
  1703    [    4.489316] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  1704    [    4.489325] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  1705    [    4.492373] JFS: nTxBlock = 7726, nTxLock = 61808
  1706    [    4.506064] SGI XFS with ACLs, security attributes, realtime, no debug enabled
  1707    [    4.628187] Key type asymmetric registered
  1708    [    4.628205] Asymmetric key parser 'x509' registered
  1709    [    4.628348] bounce: pool size: 64 pages
  1710    [    4.628482] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  1711    [    4.628866] io scheduler mq-deadline registered
  1712    [    4.628876] io scheduler kyber registered
  1713    [    4.629006] io scheduler bfq registered
  1714    [    4.641265] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  1715    [    4.644704] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  1716    [    4.659177] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  1717    [    4.662766] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
  1718    [    4.663573] printk: console [ttyS0] disabled
  1719    [    4.683912] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 43, base_baud = 1500000) is a U6_16550A
  1720    [    4.684008] printk: console [ttyS0] enabled
  1721    [    4.697681] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a8da18)
  1722    [    4.698269] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a8a600)
  1723    [    4.698407] sun8i-dw-hdmi 1ee0000.hdmi: 1ee0000.hdmi supply hvcc not found, using dummy regulator
  1724    [    4.699774] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
  1725    [    4.700506] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
  1726    [    4.701002] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a8d004)
  1727    [    4.701016] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  1728    [    4.701024] [drm] No driver support for vblank timestamp query.
  1729    [    4.701813] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
  1730    [    5.047707] Console: switching to colour frame buffer device 128x48
  1731    [    5.097490] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
  1732    [    5.104699] brd: module loaded
  1733    [    5.117671] loop: module loaded
  1734    [    5.122608] libphy: Fixed MDIO Bus: probed
  1735    [    5.124145] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  1736    [    5.124491] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  1737    [    5.124509] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  1738    [    5.124702] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  1739    [    5.127176] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  1740    [    5.127187] ehci-platform: EHCI generic platform driver
  1741    [    5.127513] ehci-platform 1c1a000.usb: EHCI Host Controller
  1742    [    5.127567] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  1743    [    5.128343] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  1744    [    5.142011] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  1745    [    5.142584] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  1746    [    5.142604] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1747    [    5.142619] usb usb1: Product: EHCI Host Controller
  1748    [    5.142634] usb usb1: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  1749    [    5.142648] usb usb1: SerialNumber: 1c1a000.usb
  1750    [    5.143745] hub 1-0:1.0: USB hub found
  1751    [    5.143847] hub 1-0:1.0: 1 port detected
  1752    [    5.145654] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  1753    [    5.145693] ohci-platform: OHCI generic platform driver
  1754    [    5.146132] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  1755    [    5.146180] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
  1756    [    5.146556] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  1757    [    5.210581] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  1758    [    5.210601] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1759    [    5.210616] usb usb2: Product: Generic Platform OHCI controller
  1760    [    5.210630] usb usb2: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  1761    [    5.210644] usb usb2: SerialNumber: 1c1a400.usb
  1762    [    5.211684] hub 2-0:1.0: USB hub found
  1763    [    5.211816] hub 2-0:1.0: 1 port detected
  1764    [    5.214735] usbcore: registered new interface driver usb-storage
  1765    [    5.217446] sun6i-rtc 1f00000.rtc: registered as rtc0
  1766    [    5.217463] sun6i-rtc 1f00000.rtc: RTC enabled
  1767    [    5.218172] i2c /dev entries driver
  1768    [    5.218943] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
  1769    [    5.223151] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  1770    [    5.224468] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
  1771    [    5.225876] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  1772    [    5.251563] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
  1773    [    5.252042] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  1774    [    5.254261] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
  1775    [    5.281119] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
  1776    [    5.283668] ledtrig-cpu: registered to indicate activity on CPUs
  1777    [    5.283812] hidraw: raw HID events driver (C) Jiri Kosina
  1778    [    5.284054] usbcore: registered new interface driver usbhid
  1779    [    5.284061] usbhid: USB HID core driver
  1780    [    5.287867] Initializing XFRM netlink socket
  1781    [    5.287879] mmc0: host does not support reading read-only switch, assuming write-enable
  1782    [    5.289325] NET: Registered protocol family 10
  1783    [    5.289931] mmc0: new high speed SDHC card at address 0001
  1784    [    5.291632] mmcblk0: mmc0:0001 00000 29.8 GiB
  1785    [    5.295481]  mmcblk0: p1
  1786    [    5.424758] Segment Routing with IPv6
  1787    [    5.424952] NET: Registered protocol family 17
  1788    [    5.425010] NET: Registered protocol family 15
  1789    [    5.425132] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  1790    [    5.425562] 8021q: 802.1Q VLAN Support v1.8
  1791    [    5.425664] Key type dns_resolver registered
  1792    [    5.426782] Registering SWP/SWPB emulation handler
  1793    [    5.427315] registered taskstats version 1
  1794    [    5.427323] Loading compiled-in X.509 certificates
  1795    [    5.427508] zswap: loaded using pool lzo/zbud
  1796    [    5.428104] Key type ._fscrypt registered
  1797    [    5.428114] Key type .fscrypt registered
  1798    [    5.434128] Btrfs loaded, crc32c=crc32c-generic
  1799    [    5.446218] mmc1: new DDR MMC card at address 0001
  1800    [    5.448002] mmcblk1: mmc1:0001 NCard  7.22 GiB
  1801    [    5.448878] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
  1802    [    5.449753] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
  1803    [    5.453281]  mmcblk1: p1
  1804    [    5.506459] Key type encrypted registered
  1805    [    5.529279] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  1806    [    5.530263] simple-framebuffer 7e000000.framebuffer: framebuffer at 0x7e000000, 0x300000 bytes, mapped to 0x(ptrval)
  1807    [    5.530286] simple-framebuffer 7e000000.framebuffer: format=x8r8g8b8, mode=1024x768x32, linelength=4096
  1808    [    5.530700] simple-framebuffer 7e000000.framebuffer: fb1: simplefb registered!
  1809    [    5.531129] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  1810    [    5.534260] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  1811    [    5.534281] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  1812    [    5.534445] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  1813    [    5.534655] dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
  1814    [    5.597609] random: fast init done
  1815    [    5.642505] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000)
  1816    [    5.642541] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  1817    [    5.642555] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  1818    [    5.642569] dwmac-sun8i 1c30000.ethernet: COE Type 2
  1819    [    5.642582] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  1820    [    5.642596] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  1821    [    5.642610] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  1822    [    5.642963] libphy: stmmac: probed
  1823    [    5.644389] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
  1824    [    5.644603] libphy: mdio_mux: probed
  1825    [    5.644644] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
  1826    [    5.644664] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
  1827    [    5.666434] ac200: Unknown symbol ac200_reg_mod (err -2)
  1828    [    5.666485] ac200: Unknown symbol ac200_reg_write (err -2)
  1829    [    5.669309] libphy: mdio_mux: probed
  1830    [    5.669362] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
  1831    [    5.769530] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
  1832    [    5.769718] dwmac-sun8i 1c30000.ethernet: Error: Failed to register MDIO bus for child /soc/ethernet@1c30000/mdio-mux/mdio@2
  1833    [    5.770946] ehci-platform 1c1b000.usb: EHCI Host Controller
  1834    [    5.771003] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
  1835    [    5.771900] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  1836    [    5.786064] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  1837    [    5.786509] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  1838    [    5.786528] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1839    [    5.786544] usb usb3: Product: EHCI Host Controller
  1840    [    5.786559] usb usb3: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  1841    [    5.786573] usb usb3: SerialNumber: 1c1b000.usb
  1842    [    5.787665] hub 3-0:1.0: USB hub found
  1843    [    5.787750] hub 3-0:1.0: 1 port detected
  1844    [    5.789471] ehci-platform 1c1c000.usb: EHCI Host Controller
  1845    [    5.789521] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
  1846    [    5.790064] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
  1847    [    5.806050] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
  1848    [    5.806447] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  1849    [    5.806467] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1850    [    5.806482] usb usb4: Product: EHCI Host Controller
  1851    [    5.806497] usb usb4: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  1852    [    5.806511] usb usb4: SerialNumber: 1c1c000.usb
  1853    [    5.807526] hub 4-0:1.0: USB hub found
  1854    [    5.807605] hub 4-0:1.0: 1 port detected
  1855    [    5.809251] ehci-platform 1c1d000.usb: EHCI Host Controller
  1856    [    5.809300] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
  1857    [    5.809820] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
  1858    [    5.822054] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
  1859    [    5.822445] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  1860    [    5.822465] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1861    [    5.822480] usb usb5: Product: EHCI Host Controller
  1862    [    5.822495] usb usb5: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  1863    [    5.822509] usb usb5: SerialNumber: 1c1d000.usb
  1864    [    5.823469] hub 5-0:1.0: USB hub found
  1865    [    5.823545] hub 5-0:1.0: 1 port detected
  1866    [    5.825162] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  1867    [    5.825209] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
  1868    [    5.825544] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  1869    [    5.886454] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  1870    [    5.886473] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1871    [    5.886489] usb usb6: Product: Generic Platform OHCI controller
  1872    [    5.886503] usb usb6: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  1873    [    5.886517] usb usb6: SerialNumber: 1c1b400.usb
  1874    [    5.887473] hub 6-0:1.0: USB hub found
  1875    [    5.887552] hub 6-0:1.0: 1 port detected
  1876    [    5.889168] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
  1877    [    5.889213] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
  1878    [    5.889570] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
  1879    [    5.950423] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  1880    [    5.950442] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1881    [    5.950457] usb usb7: Product: Generic Platform OHCI controller
  1882    [    5.950472] usb usb7: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  1883    [    5.950486] usb usb7: SerialNumber: 1c1c400.usb
  1884    [    5.951462] hub 7-0:1.0: USB hub found
  1885    [    5.951538] hub 7-0:1.0: 1 port detected
  1886    [    5.953154] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
  1887    [    5.953202] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
  1888    [    5.953545] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
  1889    [    6.014399] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  1890    [    6.014418] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1891    [    6.014434] usb usb8: Product: Generic Platform OHCI controller
  1892    [    6.014448] usb usb8: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  1893    [    6.014463] usb usb8: SerialNumber: 1c1d400.usb
  1894    [    6.015474] hub 8-0:1.0: USB hub found
  1895    [    6.015564] hub 8-0:1.0: 1 port detected
  1896    [    6.017339] usb_phy_generic usb_phy_generic.2.auto: usb_phy_generic.2.auto supply vcc not found, using dummy regulator
  1897    [    6.018366] musb-hdrc musb-hdrc.3.auto: MUSB HDRC host driver
  1898    [    6.018411] musb-hdrc musb-hdrc.3.auto: new USB bus registered, assigned bus number 9
  1899    [    6.018847] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  1900    [    6.018865] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1901    [    6.018881] usb usb9: Product: MUSB HDRC host driver
  1902    [    6.018895] usb usb9: Manufacturer: Linux 5.4.20-sunxi musb-hcd
  1903    [    6.018909] usb usb9: SerialNumber: musb-hdrc.3.auto
  1904    [    6.019839] hub 9-0:1.0: USB hub found
  1905    [    6.019925] hub 9-0:1.0: 1 port detected
  1906    [    6.027352] sun6i-rtc 1f00000.rtc: setting system clock to 2020-05-15T18:13:52 UTC (1589566432)
  1907    [    6.027721] of_cfs_init
  1908    [    6.027919] of_cfs_init: OK
  1909    [    6.038859] Freeing unused kernel memory: 1024K
  1910    [    6.050567] Run /init as init process
  1911    [    6.787866] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
  1912    [    6.794580] usb 2-1: new full-speed USB device number 2 using ohci-platform
  1913    [    7.031255] usb 2-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
  1914    [    7.031282] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1915    [    7.031297] usb 2-1: Product: USB Receiver
  1916    [    7.031312] usb 2-1: Manufacturer: Logitech
  1917    [    7.044549] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  1918    [    7.046411] input: Logitech USB Receiver as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.0/0003:046D:C52B.0001/input/input1
  1919    [    7.070765] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
  1920    [    7.091095] mmc2: new high speed SDIO card at address 0001
  1921    [    7.106543] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-1c1a400.usb-1/input0
  1922    [    7.118582] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input2
  1923    [    7.120802] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input3
  1924    [    7.178545] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input4
  1925    [    7.179327] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1a400.usb-1/input1
  1926    [    7.189003] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
  1927    [    7.306543] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
  1928    [    7.437105] input: Logitech Unifying Device. Wireless PID:4024 Keyboard as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input6
  1929    [    7.437560] input: Logitech Unifying Device. Wireless PID:4024 Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input7
  1930    [    7.438196] input: Logitech Unifying Device. Wireless PID:4024 Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input8
  1931    [    7.438652] hid-generic 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4024] on usb-1c1a400.usb-1/input2:1
  1932    [    7.548787] input: Logitech K400 as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input12
  1933    [    7.549184] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-1c1a400.usb-1/input2:1
  1934    [    8.196781] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  1935    [    9.129294] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1936    [    9.130863] systemd[1]: Detected architecture arm.
  1937    [    9.186867] systemd[1]: Set hostname to <beelinkx2>.
  1938    [    9.194401] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
  1939    [   10.409880] random: systemd: uninitialized urandom read (16 bytes read)
  1940    [   10.435851] random: systemd: uninitialized urandom read (16 bytes read)
  1941    [   10.436002] systemd[1]: Reached target Swap.
  1942    [   10.437759] random: systemd: uninitialized urandom read (16 bytes read)
  1943    [   10.437876] systemd[1]: Reached target Remote File Systems.
  1944    [   10.445320] systemd[1]: Created slice User and Session Slice.
  1945    [   10.447386] systemd[1]: Listening on udev Kernel Socket.
  1946    [   10.449371] systemd[1]: Listening on Journal Socket (/dev/log).
  1947    [   10.450945] systemd[1]: Listening on initctl Compatibility Named Pipe.
  1948    [   10.707966] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  1949    [   11.945536] systemd-journald[298]: Received request to flush runtime journal from PID 1
  1950    [   12.443643] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
  1951    [   12.478260] cedrus 1c0e000.video-codec: Device registered as /dev/video0
  1952    [   12.693120] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1953    [   12.959156] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1954    [   12.960571] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1955    [   12.960593] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
  1956    [   13.248236] bFWReady == _FALSE call reset 8051...
  1957    [   13.357875] lima 1c40000.gpu: IRQ ppmmu2 not found
  1958    [   13.357905] lima 1c40000.gpu: IRQ ppmmu3 not found
  1959    [   13.357961] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
  1960    [   13.358234] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
  1961    [   13.358372] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
  1962    [   13.358493] lima 1c40000.gpu: IRQ pp2 not found
  1963    [   13.358513] lima 1c40000.gpu: IRQ pp3 not found
  1964    [   13.358535] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
  1965    [   13.376670] lima 1c40000.gpu: bus rate = 200000000
  1966    [   13.376724] lima 1c40000.gpu: mod rate = 384000000
  1967    [   13.383382] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 1
  1968    [   13.405352] Registered IR keymap rc-empty
  1969    [   13.405647] rc rc1: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1
  1970    [   13.406190] rc rc1: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
  1971    [   13.406594] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1/input14
  1972    [   13.422922] sunxi-ir 1f02000.ir: initialized sunXi IR driver
  1973    [   13.454132] Registered IR keymap rc-cec
  1974    [   13.454550] rc rc0: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0
  1975    [   13.455016] input: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0/input13
  1976    [   13.465038] sun4i-codec 1c22c00.codec: Failed to register our card
  1977    [   13.472359] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
  1978    [   13.510662] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
  1979    [   13.800199] zram: Added device: zram0
  1980    [   13.809959] zram: Added device: zram1
  1981    [   13.813624] zram: Added device: zram2
  1982    [   14.034832] zram1: detected capacity change from 0 to 506855424
  1983    [   14.421523] cfg80211: failed to load regulatory.db
  1984    [   14.528131] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok
  1985    [   15.202091] Adding 494972k swap on /dev/zram1.  Priority:5 extents:1 across:494972k SSFS
  1986    [   15.614304] zram0: detected capacity change from 0 to 52428800
  1987    [   18.019774] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
  1988    [   18.019862] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  1989    [   18.882076] random: crng init done
  1990    [   18.882103] random: 7 urandom warning(s) missed due to ratelimiting
  1991
  1992    ### armbian-release:
  1993
  1994    # PLEASE DO NOT EDIT THIS FILE
  1995    BOARD=orangepiplus2e
  1996    BOARD_NAME="Orange Pi+ 2E"
  1997    BOARDFAMILY=sun8i
  1998    BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin
  1999    BUILD_REPOSITORY_COMMIT=3e533c9
  2000    DISTRIBUTION_CODENAME=buster
  2001    DISTRIBUTION_STATUS=supported
  2002    VERSION=20.02.1
  2003    LINUXFAMILY=sunxi
  2004    BRANCH=current
  2005    ARCH=arm
  2006    IMAGE_TYPE=stable
  2007    BOARD_TYPE=conf
  2008    INITRD_ARCH=arm
  2009    KERNEL_IMAGE_TYPE=Image
  2010
  2011    ### boot environment:
  2012
  2013    verbosity=1
  2014    logo=disabled
  2015    console=both
  2016    disp_mode=1920x1080p60
  2017    overlay_prefix=sun8i-h3
  2018    rootdev=UUID=f972992c-598b-42c9-a9a0-e82ba21ecd3f
  2019    rootfstype=ext4
  2020    usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  2021
  2022    ### lsusb:
  2023
  2024    Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2025    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2026    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2027    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2028    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2029    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2030    Bus 002 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
  2031    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2032    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2033    Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2034
  2035    ### lscpu:
  2036
  2037    Architecture:        armv7l
  2038    Byte Order:          Little Endian
  2039    CPU(s):              4
  2040    On-line CPU(s) list: 0-3
  2041    Thread(s) per core:  1
  2042    Core(s) per socket:  4
  2043    Socket(s):           1
  2044    Vendor ID:           ARM
  2045    Model:               5
  2046    Model name:          Cortex-A7
  2047    Stepping:            r0p5
  2048    BogoMIPS:            48.00
  2049    Flags:               half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  2050
  2051    ### cpuinfo:
  2052
  2053    processor    : 0
  2054    model name    : ARMv7 Processor rev 5 (v7l)
  2055    BogoMIPS    : 48.00
  2056    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  2057    CPU implementer    : 0x41
  2058    CPU architecture: 7
  2059    CPU variant    : 0x0
  2060    CPU part    : 0xc07
  2061    CPU revision    : 5
  2062
  2063    processor    : 1
  2064    model name    : ARMv7 Processor rev 5 (v7l)
  2065    BogoMIPS    : 48.00
  2066    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  2067    CPU implementer    : 0x41
  2068    CPU architecture: 7
  2069    CPU variant    : 0x0
  2070    CPU part    : 0xc07
  2071    CPU revision    : 5
  2072
  2073    processor    : 2
  2074    model name    : ARMv7 Processor rev 5 (v7l)
  2075    BogoMIPS    : 48.00
  2076    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  2077    CPU implementer    : 0x41
  2078    CPU architecture: 7
  2079    CPU variant    : 0x0
  2080    CPU part    : 0xc07
  2081    CPU revision    : 5
  2082
  2083    processor    : 3
  2084    model name    : ARMv7 Processor rev 5 (v7l)
  2085    BogoMIPS    : 48.00
  2086    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  2087    CPU implementer    : 0x41
  2088    CPU architecture: 7
  2089    CPU variant    : 0x0
  2090    CPU part    : 0xc07
  2091    CPU revision    : 5
  2092
  2093    Hardware    : Allwinner sun8i Family
  2094    Revision    : 0000
  2095    Serial        : 02c00081bd8e203d
  2096
  2097    ### meminfo:
  2098
  2099    MemTotal:         989952 kB
  2100    MemFree:          865768 kB
  2101    MemAvailable:     907068 kB
  2102    Buffers:            8148 kB
  2103    Cached:            39316 kB
  2104    SwapCached:            0 kB
  2105    Active:            33488 kB
  2106    Inactive:          22868 kB
  2107    Active(anon):       9536 kB
  2108    Inactive(anon):     1516 kB
  2109    Active(file):      23952 kB
  2110    Inactive(file):    21352 kB
  2111    Unevictable:           0 kB
  2112    Mlocked:               0 kB
  2113    HighTotal:        229364 kB
  2114    HighFree:         158116 kB
  2115    LowTotal:         760588 kB
  2116    LowFree:          707652 kB
  2117    SwapTotal:        494972 kB
  2118    SwapFree:         494972 kB
  2119    Dirty:                72 kB
  2120    Writeback:            96 kB
  2121    AnonPages:          9424 kB
  2122    Mapped:            13368 kB
  2123    Shmem:              1664 kB
  2124    KReclaimable:      14012 kB
  2125    Slab:              37580 kB
  2126    SReclaimable:      14012 kB
  2127    SUnreclaim:        23568 kB
  2128    KernelStack:        1024 kB
  2129    PageTables:          588 kB
  2130    NFS_Unstable:          0 kB
  2131    Bounce:                0 kB
  2132    WritebackTmp:          0 kB
  2133    CommitLimit:      989948 kB
  2134    Committed_AS:      43948 kB
  2135    VmallocTotal:     245760 kB
  2136    VmallocUsed:       15888 kB
  2137    VmallocChunk:          0 kB
  2138    Percpu:              704 kB
  2139    CmaTotal:         131072 kB
  2140    CmaFree:          124776 kB
  2141
  2142    ### virtual memory:
  2143
  2144    vm.admin_reserve_kbytes = 8192
  2145    vm.block_dump = 0
  2146    vm.compact_unevictable_allowed = 1
  2147    vm.dirty_background_bytes = 0
  2148    vm.dirty_background_ratio = 10
  2149    vm.dirty_bytes = 0
  2150    vm.dirty_expire_centisecs = 3000
  2151    vm.dirty_ratio = 20
  2152    vm.dirtytime_expire_seconds = 43200
  2153    vm.dirty_writeback_centisecs = 500
  2154    vm.extfrag_threshold = 500
  2155    vm.highmem_is_dirtyable = 0
  2156    vm.laptop_mode = 0
  2157    vm.legacy_va_layout = 0
  2158    vm.lowmem_reserve_ratio = 32    0    0
  2159    vm.max_map_count = 65530
  2160    vm.min_free_kbytes = 3469
  2161    vm.mmap_min_addr = 4096
  2162    vm.mmap_rnd_bits = 8
  2163    vm.oom_dump_tasks = 1
  2164    vm.oom_kill_allocating_task = 0
  2165    vm.overcommit_kbytes = 0
  2166    vm.overcommit_memory = 0
  2167    vm.overcommit_ratio = 50
  2168    vm.page-cluster = 0
  2169    vm.panic_on_oom = 0
  2170    vm.percpu_pagelist_fraction = 0
  2171    vm.stat_interval = 1
  2172    vm.swappiness = 100
  2173    vm.user_reserve_kbytes = 30552
  2174    vm.vfs_cache_pressure = 100
  2175    vm.watermark_boost_factor = 15000
  2176    vm.watermark_scale_factor = 10
  2177
  2178    ### ip addr:
  2179
  2180    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2181        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2182        inet XXX.XXX.0.1/8 scope host lo
  2183           valid_lft forever preferred_lft forever
  2184        inet6 ::1/128 scope host
  2185           valid_lft forever preferred_lft forever
  2186    2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2187        link/ether d2:f2:17:2c:67:13 brd ff:ff:ff:ff:ff:ff
  2188    3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2189        link/ether 02:81:bd:8e:20:3d brd ff:ff:ff:ff:ff:ff
  2190    4: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2191        link/ether cc:79:cf:54:c5:4a brd ff:ff:ff:ff:ff:ff
  2192
  2193    ### partitions:
  2194
  2195    major minor  #blocks  name
  2196
  2197     179        0   31260672 mmcblk0
  2198     179        1   30943968 mmcblk0p1
  2199     179        8    7570432 mmcblk1
  2200     179        9    7490624 mmcblk1p1
  2201     254        0      51200 zram0
  2202     254        1     494976 zram1
  2203
  2204    ### df:
  2205
  2206    udev             416M      0  416M   0% /dev
  2207    tmpfs             97M   2,9M   94M   3% /run
  2208    /dev/mmcblk0p1    30G   924M   28G   4% /
  2209    tmpfs            484M      0  484M   0% /dev/shm
  2210    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  2211    tmpfs            484M      0  484M   0% /sys/fs/cgroup
  2212    tmpfs            484M   4,0K  484M   1% /tmp
  2213    /dev/zram0        49M   1,6M   44M   4% /var/log
  2214
  2215    ### lsblk:
  2216
  2217    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  2218    mmcblk0              29,8G
  2219    └─mmcblk0p1  ext4    29,5G /          f972992c-598b-42c9-a9a0-e82ba21ecd3f
  2220    mmcblk1               7,2G
  2221    └─mmcblk1p1  ext4     7,1G            07520a06-bc92-4f9f-be19-d47f09d82abd
  2222    mmcblk1boot0            4M
  2223    mmcblk1boot1            4M
  2224    zram0                  50M /var/log
  2225
  2226    ### zramctl:
  2227
  2228    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  2229    /dev/zram1 lzo         483,4M    4K    76B    4K       4 [SWAP]
  2230    /dev/zram0 zstd           50M  1,5M 250,2K  612K       4 /var/log
  2231
  2232    ### mtab:
  2233
  2234    /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2235    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2236    /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
  2237
  2238    ### mmc1:0001 info:
  2239
  2240                  manfid: 0x000088
  2241                     cid: 8801034e436172642026e16382562375
  2242                   fwrev: 0x0000000000000000
  2243                     rca: 0x0001
  2244                     csd: d0ffff320f5903ffffffffe7964000eb
  2245               life_time: 0x01 0x01
  2246                     ocr: 0x00200000
  2247                    type: MMC
  2248    enhanced_area_offset: 18446744073709551594
  2249                    date: 02/2016
  2250                   hwrev: 0x0
  2251                     prv: 0x26
  2252                     dsr: 0x404
  2253             ffu_capable: 1
  2254                  serial: 0xe1638256
  2255      raw_rpmb_size_mult: 0x20
  2256              erase_size: 524288
  2257            pre_eol_info: 0x01
  2258             rel_sectors: 0x1
  2259                 cmdq_en: 0
  2260                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=NCard  MODALIAS=mmc:block
  2261      enhanced_area_size: 4294967274
  2262                   oemid: 0x0103
  2263                     rev: 0x7
  2264    preferred_erase_size: 4194304
  2265                    name: NCard
  2266
  2267    ### mmc0:0001 info:
  2268
  2269                  manfid: 0x00001b
  2270                     cid: 1b534d303030303010d24155a7010c67
  2271                   fwrev: 0x0
  2272                     rca: 0x0001
  2273                     csd: 400e00325b590000ee7f7f800a404055
  2274                     ocr: 0x00200000
  2275                    type: SD
  2276                    date: 12/2016
  2277                   hwrev: 0x1
  2278                     dsr: 0x404
  2279                  serial: 0xd24155a7
  2280              erase_size: 512
  2281                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=00000 MODALIAS=mmc:block
  2282                     ssr: 0000000005000000040090000f051d00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2283                     scr: 02b5800200000000
  2284                   oemid: 0x534d
  2285    preferred_erase_size: 4194304
  2286                    name: 00000
  2287
  2288    ### Boot system health:
  2289
  2290    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  2291    20:14:21:   ---      1.58  62%  30%  31%   0%   0%   0% 53.8°C
  2292    20:14:22:   ---      1.58  16%  13%   0%   2%   0%   0% 53.3°C
  2293    20:14:22:   ---      1.58  42%  26%  14%   2%   0%   0% 53.2°C
  2294    20:14:23:   ---      1.58  57%  25%  28%   2%   0%   0% 53.9°C
  2295    20:14:23:   ---      1.58  75%  47%  24%   2%   0%   0% 54.4°C
  2296
  2297    ### Activated 1 lzo zram swap devices with 483 MB each
  2298
  2299    ### Activated Armbian ramlog partition with zstd compression
  2300
  2301    vie may 15 20:17:18 CEST 2020 | Orange Pi+ 2E | 20.02.1 | armhf | armv7l | 5.4.20-sunxi
  2302
  2303    ### dmesg:
  2304
  2305    [    0.000000] Booting Linux on physical CPU 0x0
  2306    [    0.000000] Linux version 5.4.20-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.02.1 SMP Mon Feb 17 02:09:41 CET 2020
  2307    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
  2308    [    0.000000] CPU: div instructions available: patching division code
  2309    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  2310    [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi Plus 2E
  2311    [    0.000000] Memory policy: Data cache writealloc
  2312    [    0.000000] cma: Reserved 128 MiB at 0x75c00000
  2313    [    0.000000] On node 0 totalpages: 253952
  2314    [    0.000000]   Normal zone: 1728 pages used for memmap
  2315    [    0.000000]   Normal zone: 0 pages reserved
  2316    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
  2317    [    0.000000]   HighMem zone: 57344 pages, LIFO batch:15
  2318    [    0.000000] psci: probing for conduit method from DT.
  2319    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
  2320    [    0.000000] percpu: Embedded 20 pages/cpu s49868 r8192 d23860 u81920
  2321    [    0.000000] pcpu-alloc: s49868 r8192 d23860 u81920 alloc=20*4096
  2322    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  2323    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 252224
  2324    [    0.000000] Kernel command line: root=UUID=e4eb8394-3faa-4045-8f17-40b557e3885c rootwait rootfstype=f2fs console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart= ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
  2325    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
  2326    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
  2327    [    0.000000] allocated 1015808 bytes of page_ext
  2328    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  2329    [    0.000000] Memory: 850684K/1015808K available (9216K kernel code, 1048K rwdata, 2852K rodata, 1024K init, 316K bss, 34052K reserved, 131072K cma-reserved, 98292K highmem)
  2330    [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x3ac with crng_init=0
  2331    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  2332    [    0.000000] ftrace: allocating 40584 entries in 80 pages
  2333    [    0.000000] rcu: Hierarchical RCU implementation.
  2334    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  2335    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  2336    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  2337    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
  2338    [    0.000000] GIC: Using split EOI/Deactivate mode
  2339    [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  2340    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  2341    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2342    [    0.000012] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2343    [    0.000032] Switching to timer-based delay loop, resolution 41ns
  2344    [    0.000445] Console: colour dummy device 80x30
  2345    [    0.000469] printk: console [tty1] enabled
  2346    [    0.000554] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  2347    [    0.000574] pid_max: default: 32768 minimum: 301
  2348    [    0.001135] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  2349    [    0.001161] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  2350    [    0.001318] *** VALIDATE tmpfs ***
  2351    [    0.002579] *** VALIDATE proc ***
  2352    [    0.003149] *** VALIDATE cgroup1 ***
  2353    [    0.003163] *** VALIDATE cgroup2 ***
  2354    [    0.003278] CPU: Testing write buffer coherency: ok
  2355    [    0.004050] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
  2356    [    0.005109] Setting up static identity map for 0x40100000 - 0x40100054
  2357    [    0.005351] rcu: Hierarchical SRCU implementation.
  2358    [    0.006428] smp: Bringing up secondary CPUs ...
  2359    [    0.017726] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
  2360    [    0.029293] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
  2361    [    0.040712] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
  2362    [    0.040939] smp: Brought up 1 node, 4 CPUs
  2363    [    0.040956] SMP: Total of 4 processors activated (192.00 BogoMIPS).
  2364    [    0.040964] CPU: All CPU(s) started in HYP mode.
  2365    [    0.040969] CPU: Virtualization extensions available.
  2366    [    0.042444] devtmpfs: initialized
  2367    [    0.056984] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
  2368    [    0.057484] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  2369    [    0.057517] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  2370    [    0.067517] xor: measuring software checksum speed
  2371    [    0.104833]    arm4regs  :   508.000 MB/sec
  2372    [    0.144971]    8regs     :   354.000 MB/sec
  2373    [    0.185112]    32regs    :   334.000 MB/sec
  2374    [    0.225262]    neon      :   515.000 MB/sec
  2375    [    0.225272] xor: using function: neon (515.000 MB/sec)
  2376    [    0.225413] pinctrl core: initialized pinctrl subsystem
  2377    [    0.227372] NET: Registered protocol family 16
  2378    [    0.230958] DMA: preallocated 256 KiB pool for atomic coherent allocations
  2379    [    0.232121] audit: initializing netlink subsys (disabled)
  2380    [    0.232465] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
  2381    [    0.233654] cpuidle: using governor ladder
  2382    [    0.233772] cpuidle: using governor menu
  2383    [    0.235007] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
  2384    [    0.235017] hw-breakpoint: maximum watchpoint size is 8 bytes.
  2385    [    0.362146] raid6: neonx8   gen()   286 MB/s
  2386    [    0.430513] raid6: neonx8   xor()   235 MB/s
  2387    [    0.498820] raid6: neonx4   gen()   294 MB/s
  2388    [    0.567059] raid6: neonx4   xor()   245 MB/s
  2389    [    0.635475] raid6: neonx2   gen()   266 MB/s
  2390    [    0.703655] raid6: neonx2   xor()   237 MB/s
  2391    [    0.772048] raid6: neonx1   gen()   195 MB/s
  2392    [    0.840167] raid6: neonx1   xor()   178 MB/s
  2393    [    0.908749] raid6: int32x8  gen()   108 MB/s
  2394    [    0.976800] raid6: int32x8  xor()    70 MB/s
  2395    [    1.045407] raid6: int32x4  gen()   114 MB/s
  2396    [    1.113395] raid6: int32x4  xor()    77 MB/s
  2397    [    1.181854] raid6: int32x2  gen()    99 MB/s
  2398    [    1.250179] raid6: int32x2  xor()    75 MB/s
  2399    [    1.318405] raid6: int32x1  gen()    75 MB/s
  2400    [    1.386935] raid6: int32x1  xor()    59 MB/s
  2401    [    1.386945] raid6: using algorithm neonx4 gen() 294 MB/s
  2402    [    1.386953] raid6: .... xor() 245 MB/s, rmw enabled
  2403    [    1.386961] raid6: using neon recovery algorithm
  2404    [    1.389766] iommu: Default domain type: Translated
  2405    [    1.390452] SCSI subsystem initialized
  2406    [    1.390950] libata version 3.00 loaded.
  2407    [    1.391396] usbcore: registered new interface driver usbfs
  2408    [    1.391488] usbcore: registered new interface driver hub
  2409    [    1.391663] usbcore: registered new device driver usb
  2410    [    1.392061] mc: Linux media interface: v0.10
  2411    [    1.392126] videodev: Linux video capture interface: v2.00
  2412    [    1.392367] pps_core: LinuxPPS API ver. 1 registered
  2413    [    1.392377] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  2414    [    1.392431] PTP clock support registered
  2415    [    1.395641] clocksource: Switched to clocksource arch_sys_counter
  2416    [    3.393090] *** VALIDATE bpf ***
  2417    [    3.393539] VFS: Disk quotas dquot_6.6.0
  2418    [    3.393730] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  2419    [    3.393907] *** VALIDATE ramfs ***
  2420    [    3.411133] thermal_sys: Registered thermal governor 'fair_share'
  2421    [    3.411145] thermal_sys: Registered thermal governor 'bang_bang'
  2422    [    3.411159] thermal_sys: Registered thermal governor 'step_wise'
  2423    [    3.411167] thermal_sys: Registered thermal governor 'power_allocator'
  2424    [    3.412204] NET: Registered protocol family 2
  2425    [    3.413669] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
  2426    [    3.413734] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
  2427    [    3.413900] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
  2428    [    3.414173] TCP: Hash tables configured (established 8192 bind 8192)
  2429    [    3.414388] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
  2430    [    3.414477] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
  2431    [    3.414913] NET: Registered protocol family 1
  2432    [    3.415983] RPC: Registered named UNIX socket transport module.
  2433    [    3.415993] RPC: Registered udp transport module.
  2434    [    3.416000] RPC: Registered tcp transport module.
  2435    [    3.416007] RPC: Registered tcp NFSv4.1 backchannel transport module.
  2436    [    3.416453] Trying to unpack rootfs image as initramfs...
  2437    [    4.464863] Freeing initrd memory: 7172K
  2438    [    4.468952] Initialise system trusted keyrings
  2439    [    4.469359] workingset: timestamp_bits=14 max_order=18 bucket_order=4
  2440    [    4.484238] zbud: loaded
  2441    [    4.489207] NFS: Registering the id_resolver key type
  2442    [    4.489254] Key type id_resolver registered
  2443    [    4.489262] Key type id_legacy registered
  2444    [    4.489289] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  2445    [    4.489297] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  2446    [    4.492285] JFS: nTxBlock = 7726, nTxLock = 61808
  2447    [    4.505859] SGI XFS with ACLs, security attributes, realtime, no debug enabled
  2448    [    4.631427] Key type asymmetric registered
  2449    [    4.631444] Asymmetric key parser 'x509' registered
  2450    [    4.631653] bounce: pool size: 64 pages
  2451    [    4.631777] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  2452    [    4.632168] io scheduler mq-deadline registered
  2453    [    4.632179] io scheduler kyber registered
  2454    [    4.632303] io scheduler bfq registered
  2455    [    4.644492] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  2456    [    4.647918] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  2457    [    4.662270] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  2458    [    4.665901] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
  2459    [    4.666719] printk: console [ttyS0] disabled
  2460    [    4.687034] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 43, base_baud = 1500000) is a U6_16550A
  2461    [    4.687133] printk: console [ttyS0] enabled
  2462    [    4.700855] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a8da18)
  2463    [    4.701392] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a8a600)
  2464    [    4.701568] sun8i-dw-hdmi 1ee0000.hdmi: 1ee0000.hdmi supply hvcc not found, using dummy regulator
  2465    [    4.702977] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
  2466    [    4.703800] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
  2467    [    4.704300] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a8d004)
  2468    [    4.704313] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  2469    [    4.704321] [drm] No driver support for vblank timestamp query.
  2470    [    4.705082] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
  2471    [    5.050818] Console: switching to colour frame buffer device 128x48
  2472    [    5.100661] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
  2473    [    5.107982] brd: module loaded
  2474    [    5.121004] loop: module loaded
  2475    [    5.125789] libphy: Fixed MDIO Bus: probed
  2476    [    5.127323] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  2477    [    5.127753] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  2478    [    5.127771] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  2479    [    5.127965] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  2480    [    5.130395] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  2481    [    5.130408] ehci-platform: EHCI generic platform driver
  2482    [    5.130737] ehci-platform 1c1a000.usb: EHCI Host Controller
  2483    [    5.130790] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  2484    [    5.131540] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  2485    [    5.143667] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  2486    [    5.144247] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  2487    [    5.144266] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2488    [    5.144282] usb usb1: Product: EHCI Host Controller
  2489    [    5.144297] usb usb1: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  2490    [    5.144311] usb usb1: SerialNumber: 1c1a000.usb
  2491    [    5.145447] hub 1-0:1.0: USB hub found
  2492    [    5.145567] hub 1-0:1.0: 1 port detected
  2493    [    5.147375] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  2494    [    5.147415] ohci-platform: OHCI generic platform driver
  2495    [    5.147838] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  2496    [    5.147939] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
  2497    [    5.148319] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  2498    [    5.212193] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  2499    [    5.212213] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2500    [    5.212230] usb usb2: Product: Generic Platform OHCI controller
  2501    [    5.212244] usb usb2: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  2502    [    5.212259] usb usb2: SerialNumber: 1c1a400.usb
  2503    [    5.213301] hub 2-0:1.0: USB hub found
  2504    [    5.213404] hub 2-0:1.0: 1 port detected
  2505    [    5.216297] usbcore: registered new interface driver usb-storage
  2506    [    5.219007] sun6i-rtc 1f00000.rtc: registered as rtc0
  2507    [    5.219023] sun6i-rtc 1f00000.rtc: RTC enabled
  2508    [    5.219770] i2c /dev entries driver
  2509    [    5.220538] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
  2510    [    5.224775] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  2511    [    5.226154] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
  2512    [    5.227528] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  2513    [    5.253148] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
  2514    [    5.253640] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  2515    [    5.255756] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
  2516    [    5.279686] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
  2517    [    5.282161] ledtrig-cpu: registered to indicate activity on CPUs
  2518    [    5.282322] hidraw: raw HID events driver (C) Jiri Kosina
  2519    [    5.282566] usbcore: registered new interface driver usbhid
  2520    [    5.282573] usbhid: USB HID core driver
  2521    [    5.286300] Initializing XFRM netlink socket
  2522    [    5.287835] NET: Registered protocol family 10
  2523    [    5.424422] Segment Routing with IPv6
  2524    [    5.424640] NET: Registered protocol family 17
  2525    [    5.424698] NET: Registered protocol family 15
  2526    [    5.424825] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  2527    [    5.425230] 8021q: 802.1Q VLAN Support v1.8
  2528    [    5.425329] Key type dns_resolver registered
  2529    [    5.426378] Registering SWP/SWPB emulation handler
  2530    [    5.426912] registered taskstats version 1
  2531    [    5.426922] Loading compiled-in X.509 certificates
  2532    [    5.427099] zswap: loaded using pool lzo/zbud
  2533    [    5.427775] Key type ._fscrypt registered
  2534    [    5.427787] Key type .fscrypt registered
  2535    [    5.433706] Btrfs loaded, crc32c=crc32c-generic
  2536    [    5.435883] mmc1: new DDR MMC card at address 0001
  2537    [    5.437707] mmcblk1: mmc1:0001 NCard  7.22 GiB
  2538    [    5.438773] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
  2539    [    5.439946] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
  2540    [    5.443508]  mmcblk1: p1 p2
  2541    [    5.502742] Key type encrypted registered
  2542    [    5.525596] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  2543    [    5.526438] simple-framebuffer 7e000000.framebuffer: framebuffer at 0x7e000000, 0x300000 bytes, mapped to 0x(ptrval)
  2544    [    5.526461] simple-framebuffer 7e000000.framebuffer: format=x8r8g8b8, mode=1024x768x32, linelength=4096
  2545    [    5.526907] simple-framebuffer 7e000000.framebuffer: fb1: simplefb registered!
  2546    [    5.527341] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  2547    [    5.530460] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  2548    [    5.530481] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  2549    [    5.530654] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  2550    [    5.530856] dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
  2551    [    5.636066] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000)
  2552    [    5.636106] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  2553    [    5.636119] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  2554    [    5.636133] dwmac-sun8i 1c30000.ethernet: COE Type 2
  2555    [    5.636147] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  2556    [    5.636161] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  2557    [    5.636174] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  2558    [    5.636541] libphy: stmmac: probed
  2559    [    5.637998] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
  2560    [    5.638243] libphy: mdio_mux: probed
  2561    [    5.638286] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
  2562    [    5.638305] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
  2563    [    5.660066] ac200: Unknown symbol ac200_reg_mod (err -2)
  2564    [    5.660117] ac200: Unknown symbol ac200_reg_write (err -2)
  2565    [    5.662929] libphy: mdio_mux: probed
  2566    [    5.662981] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
  2567    [    5.763068] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
  2568    [    5.763256] dwmac-sun8i 1c30000.ethernet: Error: Failed to register MDIO bus for child /soc/ethernet@1c30000/mdio-mux/mdio@2
  2569    [    5.764487] ehci-platform 1c1b000.usb: EHCI Host Controller
  2570    [    5.764572] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
  2571    [    5.765460] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  2572    [    5.779710] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  2573    [    5.780156] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  2574    [    5.780176] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2575    [    5.780192] usb usb3: Product: EHCI Host Controller
  2576    [    5.780206] usb usb3: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  2577    [    5.780221] usb usb3: SerialNumber: 1c1b000.usb
  2578    [    5.781358] hub 3-0:1.0: USB hub found
  2579    [    5.781440] hub 3-0:1.0: 1 port detected
  2580    [    5.783146] ehci-platform 1c1c000.usb: EHCI Host Controller
  2581    [    5.783197] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
  2582    [    5.783753] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
  2583    [    5.799683] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
  2584    [    5.800084] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  2585    [    5.800103] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2586    [    5.800118] usb usb4: Product: EHCI Host Controller
  2587    [    5.800133] usb usb4: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  2588    [    5.800147] usb usb4: SerialNumber: 1c1c000.usb
  2589    [    5.801148] hub 4-0:1.0: USB hub found
  2590    [    5.801226] hub 4-0:1.0: 1 port detected
  2591    [    5.802873] ehci-platform 1c1d000.usb: EHCI Host Controller
  2592    [    5.802921] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
  2593    [    5.803392] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
  2594    [    5.815692] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
  2595    [    5.816107] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  2596    [    5.816126] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2597    [    5.816141] usb usb5: Product: EHCI Host Controller
  2598    [    5.816157] usb usb5: Manufacturer: Linux 5.4.20-sunxi ehci_hcd
  2599    [    5.816171] usb usb5: SerialNumber: 1c1d000.usb
  2600    [    5.817143] hub 5-0:1.0: USB hub found
  2601    [    5.817219] hub 5-0:1.0: 1 port detected
  2602    [    5.818849] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  2603    [    5.818896] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
  2604    [    5.819276] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  2605    [    5.880068] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  2606    [    5.880088] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2607    [    5.880103] usb usb6: Product: Generic Platform OHCI controller
  2608    [    5.880118] usb usb6: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  2609    [    5.880132] usb usb6: SerialNumber: 1c1b400.usb
  2610    [    5.881120] hub 6-0:1.0: USB hub found
  2611    [    5.881198] hub 6-0:1.0: 1 port detected
  2612    [    5.882822] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
  2613    [    5.882870] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
  2614    [    5.883228] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
  2615    [    5.944038] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  2616    [    5.944059] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2617    [    5.944075] usb usb7: Product: Generic Platform OHCI controller
  2618    [    5.944090] usb usb7: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  2619    [    5.944104] usb usb7: SerialNumber: 1c1c400.usb
  2620    [    5.945087] hub 7-0:1.0: USB hub found
  2621    [    5.945162] hub 7-0:1.0: 1 port detected
  2622    [    5.946782] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
  2623    [    5.946830] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
  2624    [    5.947173] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
  2625    [    6.008077] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  2626    [    6.008097] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2627    [    6.008112] usb usb8: Product: Generic Platform OHCI controller
  2628    [    6.008127] usb usb8: Manufacturer: Linux 5.4.20-sunxi ohci_hcd
  2629    [    6.008141] usb usb8: SerialNumber: 1c1d400.usb
  2630    [    6.009134] hub 8-0:1.0: USB hub found
  2631    [    6.009211] hub 8-0:1.0: 1 port detected
  2632    [    6.010930] usb_phy_generic usb_phy_generic.2.auto: usb_phy_generic.2.auto supply vcc not found, using dummy regulator
  2633    [    6.011896] musb-hdrc musb-hdrc.3.auto: MUSB HDRC host driver
  2634    [    6.011942] musb-hdrc musb-hdrc.3.auto: new USB bus registered, assigned bus number 9
  2635    [    6.012372] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  2636    [    6.012391] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2637    [    6.012406] usb usb9: Product: MUSB HDRC host driver
  2638    [    6.012421] usb usb9: Manufacturer: Linux 5.4.20-sunxi musb-hcd
  2639    [    6.012435] usb usb9: SerialNumber: musb-hdrc.3.auto
  2640    [    6.013402] hub 9-0:1.0: USB hub found
  2641    [    6.013484] hub 9-0:1.0: 1 port detected
  2642    [    6.021091] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:22 UTC (22)
  2643    [    6.021469] of_cfs_init
  2644    [    6.021678] of_cfs_init: OK
  2645    [    6.032633] Freeing unused kernel memory: 1024K
  2646    [    6.044205] Run /init as init process
  2647    [    6.219956] random: fast init done
  2648    [    6.769139] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
  2649    [    6.787770] usb 2-1: new full-speed USB device number 2 using ohci-platform
  2650    [    7.020841] usb 2-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
  2651    [    7.020868] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  2652    [    7.020884] usb 2-1: Product: USB Receiver
  2653    [    7.020898] usb 2-1: Manufacturer: Logitech
  2654    [    7.023043] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  2655    [    7.038498] input: Logitech USB Receiver as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.0/0003:046D:C52B.0001/input/input1
  2656    [    7.047809] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
  2657    [    7.067538] mmc2: new high speed SDIO card at address 0001
  2658    [    7.096183] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-1c1a400.usb-1/input0
  2659    [    7.108199] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input2
  2660    [    7.108762] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input3
  2661    [    7.168122] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input4
  2662    [    7.168886] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1a400.usb-1/input1
  2663    [    7.178213] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
  2664    [    7.299931] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
  2665    [    7.429981] input: Logitech Unifying Device. Wireless PID:4024 Keyboard as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input6
  2666    [    7.430422] input: Logitech Unifying Device. Wireless PID:4024 Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input7
  2667    [    7.431002] input: Logitech Unifying Device. Wireless PID:4024 Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input8
  2668    [    7.431451] hid-generic 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4024] on usb-1c1a400.usb-1/input2:1
  2669    [    7.542373] input: Logitech K400 as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input12
  2670    [    7.542775] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-1c1a400.usb-1/input2:1
  2671    [    8.002932] F2FS-fs (mmcblk1p2): Found nat_bits in checkpoint
  2672    [    8.290986] F2FS-fs (mmcblk1p2): recover fsync data on readonly fs
  2673    [    8.307676] F2FS-fs (mmcblk1p2): Mounted with checkpoint version = 240c28d1
  2674    [    8.858165] systemd[1]: System time before build time, advancing clock.
  2675    [    8.899535] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  2676    [    8.901104] systemd[1]: Detected architecture arm.
  2677    [    8.957745] systemd[1]: Set hostname to <beelinkx2>.
  2678    [    8.962411] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
  2679    [   10.119822] random: systemd: uninitialized urandom read (16 bytes read)
  2680    [   10.145294] random: systemd: uninitialized urandom read (16 bytes read)
  2681    [   10.154537] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  2682    [   10.156194] random: systemd: uninitialized urandom read (16 bytes read)
  2683    [   10.157778] systemd[1]: Listening on udev Kernel Socket.
  2684    [   10.161862] systemd[1]: Created slice system-serial\x2dgetty.slice.
  2685    [   10.164623] systemd[1]: Listening on fsck to fsckd communication Socket.
  2686    [   10.167877] systemd[1]: Listening on Journal Audit Socket.
  2687    [   10.170940] systemd[1]: Listening on Syslog Socket.
  2688    [   11.809309] systemd-journald[303]: Received request to flush runtime journal from PID 1
  2689    [   11.993482] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
  2690    [   12.010678] cedrus 1c0e000.video-codec: Device registered as /dev/video0
  2691    [   12.367324] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  2692    [   12.573705] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  2693    [   12.578983] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  2694    [   12.579036] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
  2695    [   12.663865] Registered IR keymap rc-empty
  2696    [   12.664193] rc rc1: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1
  2697    [   12.664841] rc rc1: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
  2698    [   12.665257] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1/input14
  2699    [   12.666504] sunxi-ir 1f02000.ir: initialized sunXi IR driver
  2700    [   12.668137] sun4i-codec 1c22c00.codec: Failed to register our card
  2701    [   12.698433] sun4i-codec 1c22c00.codec: Failed to register our card
  2702    [   12.699721] Registered IR keymap rc-cec
  2703    [   12.700118] rc rc0: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0
  2704    [   12.700605] input: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0/input13
  2705    [   12.703821] sun4i-codec 1c22c00.codec: Failed to register our card
  2706    [   12.741626] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
  2707    [   12.768431] lima 1c40000.gpu: IRQ ppmmu2 not found
  2708    [   12.768460] lima 1c40000.gpu: IRQ ppmmu3 not found
  2709    [   12.768515] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
  2710    [   12.768644] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
  2711    [   12.768785] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
  2712    [   12.768878] lima 1c40000.gpu: IRQ pp2 not found
  2713    [   12.768897] lima 1c40000.gpu: IRQ pp3 not found
  2714    [   12.768920] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
  2715    [   12.780020] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
  2716    [   12.784133] lima 1c40000.gpu: bus rate = 200000000
  2717    [   12.784159] lima 1c40000.gpu: mod rate = 384000000
  2718    [   12.786337] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 1
  2719    [   12.888658] bFWReady == _FALSE call reset 8051...
  2720    [   13.337199] cfg80211: failed to load regulatory.db
  2721    [   13.389486] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok
  2722    [   14.180702] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: commit=600,errors=remount-ro
  2723    [   14.180777] ext4 filesystem being mounted at /media/mmcboot supports timestamps until 2038 (0x7fffffff)
  2724    [   14.903762] zram: Added device: zram0
  2725    [   14.905464] zram: Added device: zram1
  2726    [   14.906827] zram: Added device: zram2
  2727    [   15.019524] zram1: detected capacity change from 0 to 506855424
  2728    [   16.123741] Adding 494972k swap on /dev/zram1.  Priority:5 extents:1 across:494972k SSFS
  2729    [   16.435317] zram0: detected capacity change from 0 to 52428800
  2730    [   18.020600] random: crng init done
  2731    [   18.020624] random: 7 urandom warning(s) missed due to ratelimiting
  2732    [   18.377245] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
  2733    [   18.377322] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  2734    [   19.606956] logitech-hidpp-device 0003:046D:4024.0004: HID++ 2.0 device connected.
  2735
  2736    ### armbian-release:
  2737
  2738    # PLEASE DO NOT EDIT THIS FILE
  2739    BOARD=orangepiplus2e
  2740    BOARD_NAME="Orange Pi+ 2E"
  2741    BOARDFAMILY=sun8i
  2742    BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin
  2743    BUILD_REPOSITORY_COMMIT=3e533c9
  2744    DISTRIBUTION_CODENAME=buster
  2745    DISTRIBUTION_STATUS=supported
  2746    VERSION=20.02.1
  2747    LINUXFAMILY=sunxi
  2748    BRANCH=current
  2749    ARCH=arm
  2750    IMAGE_TYPE=stable
  2751    BOARD_TYPE=conf
  2752    INITRD_ARCH=arm
  2753    KERNEL_IMAGE_TYPE=Image
  2754
  2755    ### boot environment:
  2756
  2757    verbosity=1
  2758    logo=disabled
  2759    console=both
  2760    disp_mode=1920x1080p60
  2761    overlay_prefix=sun8i-h3
  2762    rootdev=UUID=e4eb8394-3faa-4045-8f17-40b557e3885c
  2763    rootfstype=f2fs
  2764    usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  2765
  2766    ### lsusb:
  2767
  2768    Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2769    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2770    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2771    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2772    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2773    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2774    Bus 002 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
  2775    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2776    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2777    Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2778
  2779    ### lscpu:
  2780
  2781    Architecture:        armv7l
  2782    Byte Order:          Little Endian
  2783    CPU(s):              4
  2784    On-line CPU(s) list: 0-3
  2785    Thread(s) per core:  1
  2786    Core(s) per socket:  4
  2787    Socket(s):           1
  2788    Vendor ID:           ARM
  2789    Model:               5
  2790    Model name:          Cortex-A7
  2791    Stepping:            r0p5
  2792    BogoMIPS:            48.00
  2793    Flags:               half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  2794
  2795    ### cpuinfo:
  2796
  2797    processor    : 0
  2798    model name    : ARMv7 Processor rev 5 (v7l)
  2799    BogoMIPS    : 48.00
  2800    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  2801    CPU implementer    : 0x41
  2802    CPU architecture: 7
  2803    CPU variant    : 0x0
  2804    CPU part    : 0xc07
  2805    CPU revision    : 5
  2806
  2807    processor    : 1
  2808    model name    : ARMv7 Processor rev 5 (v7l)
  2809    BogoMIPS    : 48.00
  2810    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  2811    CPU implementer    : 0x41
  2812    CPU architecture: 7
  2813    CPU variant    : 0x0
  2814    CPU part    : 0xc07
  2815    CPU revision    : 5
  2816
  2817    processor    : 2
  2818    model name    : ARMv7 Processor rev 5 (v7l)
  2819    BogoMIPS    : 48.00
  2820    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  2821    CPU implementer    : 0x41
  2822    CPU architecture: 7
  2823    CPU variant    : 0x0
  2824    CPU part    : 0xc07
  2825    CPU revision    : 5
  2826
  2827    processor    : 3
  2828    model name    : ARMv7 Processor rev 5 (v7l)
  2829    BogoMIPS    : 48.00
  2830    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  2831    CPU implementer    : 0x41
  2832    CPU architecture: 7
  2833    CPU variant    : 0x0
  2834    CPU part    : 0xc07
  2835    CPU revision    : 5
  2836
  2837    Hardware    : Allwinner sun8i Family
  2838    Revision    : 0000
  2839    Serial        : 02c00081bd8e203d
  2840
  2841    ### meminfo:
  2842
  2843    MemTotal:         989952 kB
  2844    MemFree:          858584 kB
  2845    MemAvailable:     900620 kB
  2846    Buffers:            2212 kB
  2847    Cached:            45036 kB
  2848    SwapCached:            0 kB
  2849    Active:            34160 kB
  2850    Inactive:          26644 kB
  2851    Active(anon):      13820 kB
  2852    Inactive(anon):     1520 kB
  2853    Active(file):      20340 kB
  2854    Inactive(file):    25124 kB
  2855    Unevictable:          16 kB
  2856    Mlocked:              16 kB
  2857    HighTotal:        229364 kB
  2858    HighFree:         154620 kB
  2859    LowTotal:         760588 kB
  2860    LowFree:          703964 kB
  2861    SwapTotal:        494972 kB
  2862    SwapFree:         494972 kB
  2863    Dirty:               332 kB
  2864    Writeback:           300 kB
  2865    AnonPages:         13716 kB
  2866    Mapped:            15192 kB
  2867    Shmem:              1732 kB
  2868    KReclaimable:      14588 kB
  2869    Slab:              40304 kB
  2870    SReclaimable:      14588 kB
  2871    SUnreclaim:        25716 kB
  2872    KernelStack:        1192 kB
  2873    PageTables:          968 kB
  2874    NFS_Unstable:          0 kB
  2875    Bounce:                0 kB
  2876    WritebackTmp:          0 kB
  2877    CommitLimit:      989948 kB
  2878    Committed_AS:      70348 kB
  2879    VmallocTotal:     245760 kB
  2880    VmallocUsed:       15900 kB
  2881    VmallocChunk:          0 kB
  2882    Percpu:              704 kB
  2883    CmaTotal:         131072 kB
  2884    CmaFree:          124428 kB
  2885
  2886    ### virtual memory:
  2887
  2888    vm.admin_reserve_kbytes = 8192
  2889    vm.block_dump = 0
  2890    vm.compact_unevictable_allowed = 1
  2891    vm.dirty_background_bytes = 0
  2892    vm.dirty_background_ratio = 10
  2893    vm.dirty_bytes = 0
  2894    vm.dirty_expire_centisecs = 3000
  2895    vm.dirty_ratio = 20
  2896    vm.dirtytime_expire_seconds = 43200
  2897    vm.dirty_writeback_centisecs = 500
  2898    vm.extfrag_threshold = 500
  2899    vm.highmem_is_dirtyable = 0
  2900    vm.laptop_mode = 0
  2901    vm.legacy_va_layout = 0
  2902    vm.lowmem_reserve_ratio = 32    0    0
  2903    vm.max_map_count = 65530
  2904    vm.min_free_kbytes = 3469
  2905    vm.mmap_min_addr = 4096
  2906    vm.mmap_rnd_bits = 8
  2907    vm.oom_dump_tasks = 1
  2908    vm.oom_kill_allocating_task = 0
  2909    vm.overcommit_kbytes = 0
  2910    vm.overcommit_memory = 0
  2911    vm.overcommit_ratio = 50
  2912    vm.page-cluster = 0
  2913    vm.panic_on_oom = 0
  2914    vm.percpu_pagelist_fraction = 0
  2915    vm.stat_interval = 1
  2916    vm.swappiness = 100
  2917    vm.user_reserve_kbytes = 30552
  2918    vm.vfs_cache_pressure = 100
  2919    vm.watermark_boost_factor = 15000
  2920    vm.watermark_scale_factor = 10
  2921
  2922    ### ip addr:
  2923
  2924    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2925        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2926        inet XXX.XXX.0.1/8 scope host lo
  2927           valid_lft forever preferred_lft forever
  2928        inet6 ::1/128 scope host
  2929           valid_lft forever preferred_lft forever
  2930    2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2931        link/ether 26:03:3a:42:f9:17 brd ff:ff:ff:ff:ff:ff
  2932    3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2933        link/ether 02:81:bd:8e:20:3d brd ff:ff:ff:ff:ff:ff
  2934    4: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  2935        link/ether cc:79:cf:54:c5:4a brd ff:ff:ff:ff:ff:ff
  2936
  2937    ### partitions:
  2938
  2939    major minor  #blocks  name
  2940
  2941     179        0    7570432 mmcblk1
  2942     179        1      98304 mmcblk1p1
  2943     179        2    7392320 mmcblk1p2
  2944     254        0      51200 zram0
  2945     254        1     494976 zram1
  2946
  2947    ### df:
  2948
  2949    udev             416M      0  416M   0% /dev
  2950    tmpfs             97M   3,0M   94M   4% /run
  2951    /dev/mmcblk1p2   7,1G   1,4G  5,7G  20% /
  2952    tmpfs            484M      0  484M   0% /dev/shm
  2953    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  2954    tmpfs            484M      0  484M   0% /sys/fs/cgroup
  2955    tmpfs            484M   4,0K  484M   1% /tmp
  2956    /dev/mmcblk1p1    89M    32M   52M  38% /media/mmcboot
  2957    /dev/zram0        49M   2,0M   43M   5% /var/log
  2958
  2959    ### lsblk:
  2960
  2961    NAME         FSTYPE   SIZE MOUNTPOINT     UUID
  2962    mmcblk1               7,2G
  2963    ├─mmcblk1p1  ext4      96M /media/mmcboot 1903597c-c143-4430-bbb1-077aebbaf563
  2964    └─mmcblk1p2  f2fs     7,1G /              e4eb8394-3faa-4045-8f17-40b557e3885c
  2965    mmcblk1boot0            4M
  2966    mmcblk1boot1            4M
  2967    zram0                  50M /var/log
  2968
  2969    ### zramctl:
  2970
  2971    NAME       ALGORITHM DISKSIZE DATA  COMPR TOTAL STREAMS MOUNTPOINT
  2972    /dev/zram1 lzo         483,4M   4K    76B    4K       4 [SWAP]
  2973    /dev/zram0 zstd           50M   2M 389,6K  744K       4 /var/log
  2974
  2975    ### mtab:
  2976
  2977    /dev/mmcblk1p1 /boot ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2978    /dev/mmcblk1p1 /media/mmcboot ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2979    /dev/mmcblk1p2 / f2fs rw,lazytime,noatime,nodiratime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=default,fsync_mode=posix 0 0
  2980    /dev/mmcblk1p2 /var/log.hdd f2fs rw,lazytime,noatime,nodiratime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=default,fsync_mode=posix 0 0
  2981    /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
  2982
  2983    ### mmc1:0001 info:
  2984
  2985                  manfid: 0x000088
  2986                     cid: 8801034e436172642026e16382562375
  2987                   fwrev: 0x0000000000000000
  2988                     rca: 0x0001
  2989                     csd: d0ffff320f5903ffffffffe7964000eb
  2990               life_time: 0x01 0x01
  2991                     ocr: 0x00200000
  2992                    type: MMC
  2993    enhanced_area_offset: 18446744073709551594
  2994                    date: 02/2016
  2995                   hwrev: 0x0
  2996                     prv: 0x26
  2997                     dsr: 0x404
  2998             ffu_capable: 1
  2999                  serial: 0xe1638256
  3000      raw_rpmb_size_mult: 0x20
  3001              erase_size: 524288
  3002            pre_eol_info: 0x01
  3003             rel_sectors: 0x1
  3004                 cmdq_en: 0
  3005                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=NCard  MODALIAS=mmc:block
  3006      enhanced_area_size: 4294967274
  3007                   oemid: 0x0103
  3008                     rev: 0x7
  3009    preferred_erase_size: 4194304
  3010                    name: NCard
  3011
  3012    ### Boot system health:
  3013
  3014    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  3015    20:17:26:   ---      1.30  51%  28%  22%   0%   0%   0% 53.2°C
  3016    20:17:26:   ---      1.30  15%  12%   0%   2%   0%   0% 51.9°C
  3017    20:17:27:   ---      1.30  44%  21%  19%   2%   0%   0% 52.3°C
  3018    20:17:27:   ---      1.30  69%  33%  31%   2%   0%   1% 52.5°C
  3019    20:17:28:   ---      1.30  61%  34%  22%   3%   0%   0% 52.8°C
  3020
  3021    ### Activated 1 lzo zram swap devices with 483 MB each
  3022
  3023    ### Activated Armbian ramlog partition with zstd compression
  3024
  3025    vie may 15 23:07:18 CEST 2020 | Orange Pi+ 2E | 20.02.1 | armhf | armv7l | 5.4.35-sunxi
  3026
  3027    ### dmesg:
  3028
  3029    [    0.000000] Booting Linux on physical CPU 0x0
  3030    [    0.000000] Linux version 5.4.35-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #trunk SMP Thu Apr 23 18:06:21 CEST 2020
  3031    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
  3032    [    0.000000] CPU: div instructions available: patching division code
  3033    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  3034    [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi Plus 2E
  3035    [    0.000000] Memory policy: Data cache writealloc
  3036    [    0.000000] cma: Reserved 128 MiB at 0x75c00000
  3037    [    0.000000] On node 0 totalpages: 253952
  3038    [    0.000000]   Normal zone: 1728 pages used for memmap
  3039    [    0.000000]   Normal zone: 0 pages reserved
  3040    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
  3041    [    0.000000]   HighMem zone: 57344 pages, LIFO batch:15
  3042    [    0.000000] psci: probing for conduit method from DT.
  3043    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
  3044    [    0.000000] percpu: Embedded 20 pages/cpu s49868 r8192 d23860 u81920
  3045    [    0.000000] pcpu-alloc: s49868 r8192 d23860 u81920 alloc=20*4096
  3046    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  3047    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 252224
  3048    [    0.000000] Kernel command line: root=UUID=e4eb8394-3faa-4045-8f17-40b557e3885c rootwait rootfstype=f2fs console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart= ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
  3049    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
  3050    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
  3051    [    0.000000] allocated 1015808 bytes of page_ext
  3052    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  3053    [    0.000000] Memory: 850880K/1015808K available (9216K kernel code, 1053K rwdata, 2880K rodata, 1024K init, 316K bss, 33856K reserved, 131072K cma-reserved, 98292K highmem)
  3054    [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x3ac with crng_init=0
  3055    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  3056    [    0.000000] ftrace: allocating 41314 entries in 81 pages
  3057    [    0.000000] rcu: Hierarchical RCU implementation.
  3058    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  3059    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  3060    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  3061    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
  3062    [    0.000000] GIC: Using split EOI/Deactivate mode
  3063    [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  3064    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  3065    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  3066    [    0.000013] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  3067    [    0.000033] Switching to timer-based delay loop, resolution 41ns
  3068    [    0.000443] Console: colour dummy device 80x30
  3069    [    0.000467] printk: console [tty1] enabled
  3070    [    0.000557] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  3071    [    0.000578] pid_max: default: 32768 minimum: 301
  3072    [    0.001030] LSM: Security Framework initializing
  3073    [    0.001213] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  3074    [    0.001237] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  3075    [    0.001393] *** VALIDATE tmpfs ***
  3076    [    0.002674] *** VALIDATE proc ***
  3077    [    0.003230] *** VALIDATE cgroup1 ***
  3078    [    0.003246] *** VALIDATE cgroup2 ***
  3079    [    0.003364] CPU: Testing write buffer coherency: ok
  3080    [    0.004167] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
  3081    [    0.005214] Setting up static identity map for 0x40100000 - 0x40100054
  3082    [    0.005466] rcu: Hierarchical SRCU implementation.
  3083    [    0.006547] smp: Bringing up secondary CPUs ...
  3084    [    0.017849] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
  3085    [    0.029413] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
  3086    [    0.040849] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
  3087    [    0.041078] smp: Brought up 1 node, 4 CPUs
  3088    [    0.041095] SMP: Total of 4 processors activated (192.00 BogoMIPS).
  3089    [    0.041102] CPU: All CPU(s) started in HYP mode.
  3090    [    0.041108] CPU: Virtualization extensions available.
  3091    [    0.042621] devtmpfs: initialized
  3092    [    0.057309] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
  3093    [    0.057813] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  3094    [    0.057847] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  3095    [    0.068025] xor: measuring software checksum speed
  3096    [    0.104993]    arm4regs  :   508.000 MB/sec
  3097    [    0.145133]    8regs     :   354.000 MB/sec
  3098    [    0.185273]    32regs    :   334.000 MB/sec
  3099    [    0.225426]    neon      :   515.000 MB/sec
  3100    [    0.225437] xor: using function: neon (515.000 MB/sec)
  3101    [    0.225557] pinctrl core: initialized pinctrl subsystem
  3102    [    0.227490] NET: Registered protocol family 16
  3103    [    0.231018] DMA: preallocated 256 KiB pool for atomic coherent allocations
  3104    [    0.232205] audit: initializing netlink subsys (disabled)
  3105    [    0.232556] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
  3106    [    0.233821] cpuidle: using governor ladder
  3107    [    0.233896] cpuidle: using governor menu
  3108    [    0.235151] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
  3109    [    0.235162] hw-breakpoint: maximum watchpoint size is 8 bytes.
  3110    [    0.366293] raid6: neonx8   gen()   287 MB/s
  3111    [    0.434519] raid6: neonx8   xor()   238 MB/s
  3112    [    0.502777] raid6: neonx4   gen()   294 MB/s
  3113    [    0.571026] raid6: neonx4   xor()   249 MB/s
  3114    [    0.639234] raid6: neonx2   gen()   268 MB/s
  3115    [    0.707441] raid6: neonx2   xor()   236 MB/s
  3116    [    0.775652] raid6: neonx1   gen()   200 MB/s
  3117    [    0.843956] raid6: neonx1   xor()   189 MB/s
  3118    [    0.912183] raid6: int32x8  gen()   108 MB/s
  3119    [    0.980353] raid6: int32x8  xor()    70 MB/s
  3120    [    1.049042] raid6: int32x4  gen()   116 MB/s
  3121    [    1.117152] raid6: int32x4  xor()    79 MB/s
  3122    [    1.185209] raid6: int32x2  gen()   103 MB/s
  3123    [    1.253492] raid6: int32x2  xor()    83 MB/s
  3124    [    1.321720] raid6: int32x1  gen()    81 MB/s
  3125    [    1.390099] raid6: int32x1  xor()    71 MB/s
  3126    [    1.390109] raid6: using algorithm neonx4 gen() 294 MB/s
  3127    [    1.390116] raid6: .... xor() 249 MB/s, rmw enabled
  3128    [    1.390124] raid6: using neon recovery algorithm
  3129    [    1.393006] iommu: Default domain type: Translated
  3130    [    1.393727] SCSI subsystem initialized
  3131    [    1.394119] libata version 3.00 loaded.
  3132    [    1.394587] usbcore: registered new interface driver usbfs
  3133    [    1.394684] usbcore: registered new interface driver hub
  3134    [    1.394844] usbcore: registered new device driver usb
  3135    [    1.395284] mc: Linux media interface: v0.10
  3136    [    1.395364] videodev: Linux video capture interface: v2.00
  3137    [    1.395612] pps_core: LinuxPPS API ver. 1 registered
  3138    [    1.395622] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3139    [    1.395657] PTP clock support registered
  3140    [    1.398882] clocksource: Switched to clocksource arch_sys_counter
  3141    [    3.447118] *** VALIDATE bpf ***
  3142    [    3.447582] VFS: Disk quotas dquot_6.6.0
  3143    [    3.447726] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  3144    [    3.447905] *** VALIDATE ramfs ***
  3145    [    3.466073] thermal_sys: Registered thermal governor 'fair_share'
  3146    [    3.466084] thermal_sys: Registered thermal governor 'bang_bang'
  3147    [    3.466098] thermal_sys: Registered thermal governor 'step_wise'
  3148    [    3.466107] thermal_sys: Registered thermal governor 'power_allocator'
  3149    [    3.467107] NET: Registered protocol family 2
  3150    [    3.468520] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
  3151    [    3.468585] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
  3152    [    3.468758] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
  3153    [    3.469031] TCP: Hash tables configured (established 8192 bind 8192)
  3154    [    3.469249] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
  3155    [    3.469337] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
  3156    [    3.469771] NET: Registered protocol family 1
  3157    [    3.470742] RPC: Registered named UNIX socket transport module.
  3158    [    3.470752] RPC: Registered udp transport module.
  3159    [    3.470759] RPC: Registered tcp transport module.
  3160    [    3.470766] RPC: Registered tcp NFSv4.1 backchannel transport module.
  3161    [    3.471300] Trying to unpack rootfs image as initramfs...
  3162    [    4.499056] Freeing initrd memory: 6972K
  3163    [    4.501826] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
  3164    [    4.504403] Initialise system trusted keyrings
  3165    [    4.504838] workingset: timestamp_bits=14 max_order=18 bucket_order=4
  3166    [    4.520191] zbud: loaded
  3167    [    4.525250] NFS: Registering the id_resolver key type
  3168    [    4.525300] Key type id_resolver registered
  3169    [    4.525308] Key type id_legacy registered
  3170    [    4.525335] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  3171    [    4.525344] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  3172    [    4.528369] JFS: nTxBlock = 7725, nTxLock = 61807
  3173    [    4.542084] SGI XFS with ACLs, security attributes, realtime, no debug enabled
  3174    [    4.666939] Key type asymmetric registered
  3175    [    4.666957] Asymmetric key parser 'x509' registered
  3176    [    4.667087] bounce: pool size: 64 pages
  3177    [    4.667214] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  3178    [    4.667619] io scheduler mq-deadline registered
  3179    [    4.667631] io scheduler kyber registered
  3180    [    4.667761] io scheduler bfq registered
  3181    [    4.680168] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  3182    [    4.683682] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  3183    [    4.698250] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  3184    [    4.703369] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
  3185    [    4.704179] printk: console [ttyS0] disabled
  3186    [    4.724507] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 43, base_baud = 1500000) is a U6_16550A
  3187    [    4.724604] printk: console [ttyS0] enabled
  3188    [    4.738702] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a8f2b8)
  3189    [    4.739292] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a8bea4)
  3190    [    4.739424] sun8i-dw-hdmi 1ee0000.hdmi: 1ee0000.hdmi supply hvcc not found, using dummy regulator
  3191    [    4.740781] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
  3192    [    4.741559] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
  3193    [    4.742060] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a8e8a4)
  3194    [    4.742074] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  3195    [    4.742082] [drm] No driver support for vblank timestamp query.
  3196    [    4.742955] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
  3197    [    5.088533] Console: switching to colour frame buffer device 128x48
  3198    [    5.138104] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
  3199    [    5.145756] brd: module loaded
  3200    [    5.159252] loop: module loaded
  3201    [    5.163077] libphy: Fixed MDIO Bus: probed
  3202    [    5.164618] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  3203    [    5.164967] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  3204    [    5.164983] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  3205    [    5.165189] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  3206    [    5.167718] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3207    [    5.167729] ehci-platform: EHCI generic platform driver
  3208    [    5.168066] ehci-platform 1c1a000.usb: EHCI Host Controller
  3209    [    5.168119] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  3210    [    5.168876] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  3211    [    5.182938] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  3212    [    5.183514] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  3213    [    5.183533] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3214    [    5.183549] usb usb1: Product: EHCI Host Controller
  3215    [    5.183563] usb usb1: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  3216    [    5.183578] usb usb1: SerialNumber: 1c1a000.usb
  3217    [    5.184717] hub 1-0:1.0: USB hub found
  3218    [    5.184821] hub 1-0:1.0: 1 port detected
  3219    [    5.186675] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3220    [    5.186716] ohci-platform: OHCI generic platform driver
  3221    [    5.187133] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  3222    [    5.187179] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
  3223    [    5.187523] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  3224    [    5.251431] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  3225    [    5.251451] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3226    [    5.251466] usb usb2: Product: Generic Platform OHCI controller
  3227    [    5.251481] usb usb2: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  3228    [    5.251495] usb usb2: SerialNumber: 1c1a400.usb
  3229    [    5.252520] hub 2-0:1.0: USB hub found
  3230    [    5.252630] hub 2-0:1.0: 1 port detected
  3231    [    5.255556] usbcore: registered new interface driver usb-storage
  3232    [    5.258546] sun6i-rtc 1f00000.rtc: registered as rtc0
  3233    [    5.258563] sun6i-rtc 1f00000.rtc: RTC enabled
  3234    [    5.259344] i2c /dev entries driver
  3235    [    5.260133] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
  3236    [    5.264522] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  3237    [    5.265848] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
  3238    [    5.267274] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  3239    [    5.291551] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
  3240    [    5.292033] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  3241    [    5.294133] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
  3242    [    5.318926] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
  3243    [    5.321455] ledtrig-cpu: registered to indicate activity on CPUs
  3244    [    5.321601] hidraw: raw HID events driver (C) Jiri Kosina
  3245    [    5.321903] usbcore: registered new interface driver usbhid
  3246    [    5.321910] usbhid: USB HID core driver
  3247    [    5.325810] Initializing XFRM netlink socket
  3248    [    5.327132] NET: Registered protocol family 10
  3249    [    5.465336] Segment Routing with IPv6
  3250    [    5.465529] NET: Registered protocol family 17
  3251    [    5.465579] NET: Registered protocol family 15
  3252    [    5.465697] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  3253    [    5.466041] 8021q: 802.1Q VLAN Support v1.8
  3254    [    5.466143] Key type dns_resolver registered
  3255    [    5.467308] Registering SWP/SWPB emulation handler
  3256    [    5.467854] registered taskstats version 1
  3257    [    5.467863] Loading compiled-in X.509 certificates
  3258    [    5.468046] zswap: loaded using pool lzo/zbud
  3259    [    5.468659] Key type ._fscrypt registered
  3260    [    5.468669] Key type .fscrypt registered
  3261    [    5.474585] Btrfs loaded, crc32c=crc32c-generic
  3262    [    5.479123] mmc1: new DDR MMC card at address 0001
  3263    [    5.481001] mmcblk1: mmc1:0001 NCard  7.22 GiB
  3264    [    5.482054] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
  3265    [    5.483132] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
  3266    [    5.486528]  mmcblk1: p1 p2
  3267    [    5.543716] Key type encrypted registered
  3268    [    5.567856] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  3269    [    5.568674] simple-framebuffer 7e000000.framebuffer: framebuffer at 0x7e000000, 0x300000 bytes, mapped to 0x(ptrval)
  3270    [    5.568696] simple-framebuffer 7e000000.framebuffer: format=x8r8g8b8, mode=1024x768x32, linelength=4096
  3271    [    5.569153] simple-framebuffer 7e000000.framebuffer: fb1: simplefb registered!
  3272    [    5.569589] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  3273    [    5.572700] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  3274    [    5.572718] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  3275    [    5.572879] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  3276    [    5.573091] dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
  3277    [    5.679378] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000)
  3278    [    5.679417] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  3279    [    5.679430] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  3280    [    5.679444] dwmac-sun8i 1c30000.ethernet: COE Type 2
  3281    [    5.679457] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  3282    [    5.679472] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  3283    [    5.679485] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  3284    [    5.679840] libphy: stmmac: probed
  3285    [    5.681349] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
  3286    [    5.681570] libphy: mdio_mux: probed
  3287    [    5.681613] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
  3288    [    5.681632] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
  3289    [    5.703639] ac200: Unknown symbol ac200_reg_mod (err -2)
  3290    [    5.703690] ac200: Unknown symbol ac200_reg_write (err -2)
  3291    [    5.706434] libphy: mdio_mux: probed
  3292    [    5.706485] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
  3293    [    5.806608] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
  3294    [    5.806802] dwmac-sun8i 1c30000.ethernet: Error: Failed to register MDIO bus for child /soc/ethernet@1c30000/mdio-mux/mdio@2
  3295    [    5.808036] ehci-platform 1c1b000.usb: EHCI Host Controller
  3296    [    5.808094] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
  3297    [    5.808994] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  3298    [    5.822948] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  3299    [    5.823387] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  3300    [    5.823406] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3301    [    5.823422] usb usb3: Product: EHCI Host Controller
  3302    [    5.823437] usb usb3: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  3303    [    5.823451] usb usb3: SerialNumber: 1c1b000.usb
  3304    [    5.824575] hub 3-0:1.0: USB hub found
  3305    [    5.824659] hub 3-0:1.0: 1 port detected
  3306    [    5.826445] ehci-platform 1c1c000.usb: EHCI Host Controller
  3307    [    5.826497] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
  3308    [    5.827031] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
  3309    [    5.842928] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
  3310    [    5.843331] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  3311    [    5.843349] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3312    [    5.843365] usb usb4: Product: EHCI Host Controller
  3313    [    5.843380] usb usb4: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  3314    [    5.843394] usb usb4: SerialNumber: 1c1c000.usb
  3315    [    5.844419] hub 4-0:1.0: USB hub found
  3316    [    5.844512] hub 4-0:1.0: 1 port detected
  3317    [    5.846149] ehci-platform 1c1d000.usb: EHCI Host Controller
  3318    [    5.846202] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
  3319    [    5.846702] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
  3320    [    5.858932] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
  3321    [    5.859323] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  3322    [    5.859342] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3323    [    5.859357] usb usb5: Product: EHCI Host Controller
  3324    [    5.859372] usb usb5: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  3325    [    5.859386] usb usb5: SerialNumber: 1c1d000.usb
  3326    [    5.860381] hub 5-0:1.0: USB hub found
  3327    [    5.860462] hub 5-0:1.0: 1 port detected
  3328    [    5.862074] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  3329    [    5.862124] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
  3330    [    5.862461] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  3331    [    5.923314] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  3332    [    5.923333] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3333    [    5.923349] usb usb6: Product: Generic Platform OHCI controller
  3334    [    5.923363] usb usb6: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  3335    [    5.923377] usb usb6: SerialNumber: 1c1b400.usb
  3336    [    5.924376] hub 6-0:1.0: USB hub found
  3337    [    5.924474] hub 6-0:1.0: 1 port detected
  3338    [    5.926156] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
  3339    [    5.926206] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
  3340    [    5.926583] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
  3341    [    5.987287] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  3342    [    5.987307] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3343    [    5.987323] usb usb7: Product: Generic Platform OHCI controller
  3344    [    5.987337] usb usb7: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  3345    [    5.987351] usb usb7: SerialNumber: 1c1c400.usb
  3346    [    5.988352] hub 7-0:1.0: USB hub found
  3347    [    5.988431] hub 7-0:1.0: 1 port detected
  3348    [    5.990061] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
  3349    [    5.990111] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
  3350    [    5.990491] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
  3351    [    6.051290] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  3352    [    6.051310] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3353    [    6.051325] usb usb8: Product: Generic Platform OHCI controller
  3354    [    6.051340] usb usb8: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  3355    [    6.051354] usb usb8: SerialNumber: 1c1d400.usb
  3356    [    6.052395] hub 8-0:1.0: USB hub found
  3357    [    6.052481] hub 8-0:1.0: 1 port detected
  3358    [    6.054210] usb_phy_generic usb_phy_generic.3.auto: usb_phy_generic.3.auto supply vcc not found, using dummy regulator
  3359    [    6.055178] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
  3360    [    6.055226] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9
  3361    [    6.055697] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  3362    [    6.055716] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3363    [    6.055731] usb usb9: Product: MUSB HDRC host driver
  3364    [    6.055745] usb usb9: Manufacturer: Linux 5.4.35-sunxi musb-hcd
  3365    [    6.055759] usb usb9: SerialNumber: musb-hdrc.4.auto
  3366    [    6.056750] hub 9-0:1.0: USB hub found
  3367    [    6.056837] hub 9-0:1.0: 1 port detected
  3368    [    6.064502] sun6i-rtc 1f00000.rtc: setting system clock to 2020-05-15T21:06:43 UTC (1589576803)
  3369    [    6.064877] of_cfs_init
  3370    [    6.065094] of_cfs_init: OK
  3371    [    6.073908] Freeing unused kernel memory: 1024K
  3372    [    6.091543] Run /init as init process
  3373    [    6.263204] random: fast init done
  3374    [    6.827763] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
  3375    [    6.830987] usb 2-1: new full-speed USB device number 2 using ohci-platform
  3376    [    7.064088] usb 2-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
  3377    [    7.064115] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  3378    [    7.064131] usb 2-1: Product: USB Receiver
  3379    [    7.064145] usb 2-1: Manufacturer: Logitech
  3380    [    7.081079] input: Logitech USB Receiver as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.0/0003:046D:C52B.0001/input/input1
  3381    [    7.102231] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  3382    [    7.126991] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
  3383    [    7.139443] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-1c1a400.usb-1/input0
  3384    [    7.147320] mmc2: new high speed SDIO card at address 0001
  3385    [    7.152433] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input2
  3386    [    7.153030] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input3
  3387    [    7.215398] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input4
  3388    [    7.216273] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1a400.usb-1/input1
  3389    [    7.225564] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
  3390    [    7.343494] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
  3391    [    7.473221] input: Logitech Unifying Device. Wireless PID:4024 Keyboard as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input6
  3392    [    7.473674] input: Logitech Unifying Device. Wireless PID:4024 Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input7
  3393    [    7.474212] input: Logitech Unifying Device. Wireless PID:4024 Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input8
  3394    [    7.474689] hid-generic 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4024] on usb-1c1a400.usb-1/input2:1
  3395    [    7.577604] input: Logitech K400 as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input12
  3396    [    7.578021] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-1c1a400.usb-1/input2:1
  3397    [   19.006168] random: crng init done
  3398    [   23.092898] F2FS-fs (mmcblk1p2): Found nat_bits in checkpoint
  3399    [   23.382976] F2FS-fs (mmcblk1p2): recover fsync data on readonly fs
  3400    [   23.402961] F2FS-fs (mmcblk1p2): Mounted with checkpoint version = 240c2c2c
  3401    [   24.024697] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  3402    [   24.026247] systemd[1]: Detected architecture arm.
  3403    [   24.110064] systemd[1]: Set hostname to <beelinkx2>.
  3404    [   25.317870] systemd[1]: Reached target System Time Synchronized.
  3405    [   25.336150] systemd[1]: Listening on Journal Audit Socket.
  3406    [   25.351649] systemd[1]: Listening on initctl Compatibility Named Pipe.
  3407    [   25.368423] systemd[1]: Listening on Syslog Socket.
  3408    [   25.383948] systemd[1]: Listening on Journal Socket.
  3409    [   25.415256] systemd[1]: Starting Restore / save the current clock...
  3410    [   25.442626] systemd[1]: Starting Set the console keyboard layout...
  3411    [   27.087845] systemd-journald[309]: Received request to flush runtime journal from PID 1
  3412    [   27.416868] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
  3413    [   27.436211] cedrus 1c0e000.video-codec: Device registered as /dev/video0
  3414    [   27.680271] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  3415    [   27.908147] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  3416    [   27.911286] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  3417    [   27.911311] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
  3418    [   27.957412] sun4i-codec 1c22c00.codec: Failed to register our card
  3419    [   27.963357] lima 1c40000.gpu: IRQ ppmmu2 not found
  3420    [   27.963385] lima 1c40000.gpu: IRQ ppmmu3 not found
  3421    [   27.963438] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
  3422    [   27.963568] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
  3423    [   27.963716] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
  3424    [   27.963827] lima 1c40000.gpu: IRQ pp2 not found
  3425    [   27.963846] lima 1c40000.gpu: IRQ pp3 not found
  3426    [   27.963868] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
  3427    [   27.968336] lima 1c40000.gpu: bus rate = 200000000
  3428    [   27.968361] lima 1c40000.gpu: mod rate = 384000000
  3429    [   27.989935] sun4i-codec 1c22c00.codec: Failed to register our card
  3430    [   28.041295] Registered IR keymap rc-empty
  3431    [   28.041569] rc rc1: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1
  3432    [   28.041987] rc rc1: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
  3433    [   28.042398] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1/input14
  3434    [   28.048476] sunxi-ir 1f02000.ir: initialized sunXi IR driver
  3435    [   28.052048] sun4i-codec 1c22c00.codec: Failed to register our card
  3436    [   28.060621] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
  3437    [   28.065692] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
  3438    [   28.085569] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 1
  3439    [   28.111115] Registered IR keymap rc-cec
  3440    [   28.111546] rc rc0: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0
  3441    [   28.112095] input: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0/input13
  3442    [   28.216411] bFWReady == _FALSE call reset 8051...
  3443    [   28.589145] cfg80211: failed to load regulatory.db
  3444    [   28.657085] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok
  3445    [   29.897960] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: commit=600,errors=remount-ro
  3446    [   29.898033] ext4 filesystem being mounted at /media/mmcboot supports timestamps until 2038 (0x7fffffff)
  3447    [   30.599634] zram: Added device: zram0
  3448    [   30.601760] zram: Added device: zram1
  3449    [   30.603458] zram: Added device: zram2
  3450    [   30.709348] zram1: detected capacity change from 0 to 506855424
  3451    [   30.847078] Adding 494972k swap on /dev/zram1.  Priority:5 extents:1 across:494972k SSFS
  3452    [   31.187249] zram0: detected capacity change from 0 to 52428800
  3453    [   31.517509] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
  3454    [   31.517588] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  3455    [   37.883039] vcc3v0: disabling
  3456    [   37.883063] vcc5v0: disabling
  3457    [   37.883073] usb0-vbus: disabling
  3458
  3459    ### armbian-release:
  3460
  3461    # PLEASE DO NOT EDIT THIS FILE
  3462    BOARD=orangepiplus2e
  3463    BOARD_NAME="Orange Pi+ 2E"
  3464    BOARDFAMILY=sun8i
  3465    BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin
  3466    BUILD_REPOSITORY_COMMIT=3e533c9
  3467    DISTRIBUTION_CODENAME=buster
  3468    DISTRIBUTION_STATUS=supported
  3469    VERSION=20.02.1
  3470    LINUXFAMILY=sunxi
  3471    BRANCH=current
  3472    ARCH=arm
  3473    IMAGE_TYPE=stable
  3474    BOARD_TYPE=conf
  3475    INITRD_ARCH=arm
  3476    KERNEL_IMAGE_TYPE=Image
  3477
  3478    ### boot environment:
  3479
  3480    verbosity=1
  3481    logo=disabled
  3482    console=both
  3483    disp_mode=1920x1080p60
  3484    overlay_prefix=sun8i-h3
  3485    rootdev=UUID=e4eb8394-3faa-4045-8f17-40b557e3885c
  3486    rootfstype=f2fs
  3487    usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  3488
  3489    ### lsusb:
  3490
  3491    Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  3492    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3493    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  3494    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3495    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  3496    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3497    Bus 002 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
  3498    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  3499    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3500    Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3501
  3502    ### lscpu:
  3503
  3504    Architecture:        armv7l
  3505    Byte Order:          Little Endian
  3506    CPU(s):              4
  3507    On-line CPU(s) list: 0-3
  3508    Thread(s) per core:  1
  3509    Core(s) per socket:  4
  3510    Socket(s):           1
  3511    Vendor ID:           ARM
  3512    Model:               5
  3513    Model name:          Cortex-A7
  3514    Stepping:            r0p5
  3515    BogoMIPS:            48.00
  3516    Flags:               half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  3517
  3518    ### cpuinfo:
  3519
  3520    processor    : 0
  3521    model name    : ARMv7 Processor rev 5 (v7l)
  3522    BogoMIPS    : 48.00
  3523    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  3524    CPU implementer    : 0x41
  3525    CPU architecture: 7
  3526    CPU variant    : 0x0
  3527    CPU part    : 0xc07
  3528    CPU revision    : 5
  3529
  3530    processor    : 1
  3531    model name    : ARMv7 Processor rev 5 (v7l)
  3532    BogoMIPS    : 48.00
  3533    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  3534    CPU implementer    : 0x41
  3535    CPU architecture: 7
  3536    CPU variant    : 0x0
  3537    CPU part    : 0xc07
  3538    CPU revision    : 5
  3539
  3540    processor    : 2
  3541    model name    : ARMv7 Processor rev 5 (v7l)
  3542    BogoMIPS    : 48.00
  3543    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  3544    CPU implementer    : 0x41
  3545    CPU architecture: 7
  3546    CPU variant    : 0x0
  3547    CPU part    : 0xc07
  3548    CPU revision    : 5
  3549
  3550    processor    : 3
  3551    model name    : ARMv7 Processor rev 5 (v7l)
  3552    BogoMIPS    : 48.00
  3553    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  3554    CPU implementer    : 0x41
  3555    CPU architecture: 7
  3556    CPU variant    : 0x0
  3557    CPU part    : 0xc07
  3558    CPU revision    : 5
  3559
  3560    Hardware    : Allwinner sun8i Family
  3561    Revision    : 0000
  3562    Serial        : 02c00081bd8e203d
  3563
  3564    ### meminfo:
  3565
  3566    MemTotal:         989948 kB
  3567    MemFree:          858084 kB
  3568    MemAvailable:     902888 kB
  3569    Buffers:            2216 kB
  3570    Cached:            47920 kB
  3571    SwapCached:            0 kB
  3572    Active:            33384 kB
  3573    Inactive:          28320 kB
  3574    Active(anon):      11908 kB
  3575    Inactive(anon):     1532 kB
  3576    Active(file):      21476 kB
  3577    Inactive(file):    26788 kB
  3578    Unevictable:          16 kB
  3579    Mlocked:              16 kB
  3580    HighTotal:        229364 kB
  3581    HighFree:         154076 kB
  3582    LowTotal:         760584 kB
  3583    LowFree:          704008 kB
  3584    SwapTotal:        494972 kB
  3585    SwapFree:         494972 kB
  3586    Dirty:                80 kB
  3587    Writeback:             0 kB
  3588    AnonPages:         11760 kB
  3589    Mapped:            14996 kB
  3590    Shmem:              1732 kB
  3591    KReclaimable:      14556 kB
  3592    Slab:              40544 kB
  3593    SReclaimable:      14556 kB
  3594    SUnreclaim:        25988 kB
  3595    KernelStack:        1088 kB
  3596    PageTables:          780 kB
  3597    NFS_Unstable:          0 kB
  3598    Bounce:                0 kB
  3599    WritebackTmp:          0 kB
  3600    CommitLimit:      989944 kB
  3601    Committed_AS:      64616 kB
  3602    VmallocTotal:     245760 kB
  3603    VmallocUsed:       15912 kB
  3604    VmallocChunk:          0 kB
  3605    Percpu:              704 kB
  3606    CmaTotal:         131072 kB
  3607    CmaFree:          123688 kB
  3608
  3609    ### virtual memory:
  3610
  3611    vm.admin_reserve_kbytes = 8192
  3612    vm.block_dump = 0
  3613    vm.compact_unevictable_allowed = 1
  3614    vm.dirty_background_bytes = 0
  3615    vm.dirty_background_ratio = 10
  3616    vm.dirty_bytes = 0
  3617    vm.dirty_expire_centisecs = 3000
  3618    vm.dirty_ratio = 20
  3619    vm.dirtytime_expire_seconds = 43200
  3620    vm.dirty_writeback_centisecs = 500
  3621    vm.extfrag_threshold = 500
  3622    vm.highmem_is_dirtyable = 0
  3623    vm.laptop_mode = 0
  3624    vm.legacy_va_layout = 0
  3625    vm.lowmem_reserve_ratio = 32    0    0
  3626    vm.max_map_count = 65530
  3627    vm.min_free_kbytes = 3470
  3628    vm.mmap_min_addr = 4096
  3629    vm.mmap_rnd_bits = 8
  3630    vm.oom_dump_tasks = 1
  3631    vm.oom_kill_allocating_task = 0
  3632    vm.overcommit_kbytes = 0
  3633    vm.overcommit_memory = 0
  3634    vm.overcommit_ratio = 50
  3635    vm.page-cluster = 0
  3636    vm.panic_on_oom = 0
  3637    vm.percpu_pagelist_fraction = 0
  3638    vm.stat_interval = 1
  3639    vm.swappiness = 100
  3640    vm.user_reserve_kbytes = 30558
  3641    vm.vfs_cache_pressure = 100
  3642    vm.watermark_boost_factor = 15000
  3643    vm.watermark_scale_factor = 10
  3644
  3645    ### ip addr:
  3646
  3647    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  3648        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  3649        inet XXX.XXX.0.1/8 scope host lo
  3650           valid_lft forever preferred_lft forever
  3651        inet6 ::1/128 scope host
  3652           valid_lft forever preferred_lft forever
  3653    2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3654        link/ether 02:81:bd:8e:20:3d brd ff:ff:ff:ff:ff:ff
  3655    3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  3656        link/ether cc:79:cf:54:c5:4a brd ff:ff:ff:ff:ff:ff
  3657
  3658    ### partitions:
  3659
  3660    major minor  #blocks  name
  3661
  3662     179        0    7570432 mmcblk1
  3663     179        1      98304 mmcblk1p1
  3664     179        2    7392320 mmcblk1p2
  3665     254        0      51200 zram0
  3666     254        1     494976 zram1
  3667
  3668    ### df:
  3669
  3670    udev             416M      0  416M   0% /dev
  3671    tmpfs             97M   3,0M   94M   4% /run
  3672    /dev/mmcblk1p2   7,1G   1,5G  5,7G  20% /
  3673    tmpfs            484M      0  484M   0% /dev/shm
  3674    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  3675    tmpfs            484M      0  484M   0% /sys/fs/cgroup
  3676    tmpfs            484M   4,0K  484M   1% /tmp
  3677    /dev/mmcblk1p1    89M    31M   52M  38% /media/mmcboot
  3678    /dev/zram0        49M   2,7M   43M   6% /var/log
  3679
  3680    ### lsblk:
  3681
  3682    NAME         FSTYPE   SIZE MOUNTPOINT     UUID
  3683    mmcblk1               7,2G
  3684    ├─mmcblk1p1  ext4      96M /media/mmcboot 1903597c-c143-4430-bbb1-077aebbaf563
  3685    └─mmcblk1p2  f2fs     7,1G /              e4eb8394-3faa-4045-8f17-40b557e3885c
  3686    mmcblk1boot0            4M
  3687    mmcblk1boot1            4M
  3688    zram0                  50M /var/log
  3689
  3690    ### zramctl:
  3691
  3692    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  3693    /dev/zram1 lzo         483,4M    4K    76B    4K       4 [SWAP]
  3694    /dev/zram0 zstd           50M  2,5M 501,2K  832K       4 /var/log
  3695
  3696    ### mtab:
  3697
  3698    /dev/mmcblk1p1 /boot ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  3699    /dev/mmcblk1p1 /media/mmcboot ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  3700    /dev/mmcblk1p2 / f2fs rw,lazytime,noatime,nodiratime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=default,fsync_mode=posix 0 0
  3701    /dev/mmcblk1p2 /var/log.hdd f2fs rw,lazytime,noatime,nodiratime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=default,fsync_mode=posix 0 0
  3702    /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
  3703
  3704    ### mmc1:0001 info:
  3705
  3706                  manfid: 0x000088
  3707                     cid: 8801034e436172642026e16382562375
  3708                   fwrev: 0x0000000000000000
  3709                     rca: 0x0001
  3710                     csd: d0ffff320f5903ffffffffe7964000eb
  3711               life_time: 0x01 0x01
  3712                     ocr: 0x00200000
  3713                    type: MMC
  3714    enhanced_area_offset: 18446744073709551594
  3715                    date: 02/2016
  3716                   hwrev: 0x0
  3717                     prv: 0x26
  3718                     dsr: 0x404
  3719             ffu_capable: 1
  3720                  serial: 0xe1638256
  3721      raw_rpmb_size_mult: 0x20
  3722              erase_size: 524288
  3723            pre_eol_info: 0x01
  3724             rel_sectors: 0x1
  3725                 cmdq_en: 0
  3726                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=NCard  MODALIAS=mmc:block
  3727      enhanced_area_size: 4294967274
  3728                   oemid: 0x0103
  3729                     rev: 0x7
  3730    preferred_erase_size: 4194304
  3731                    name: NCard
  3732
  3733    ### Boot system health:
  3734
  3735    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  3736    23:07:26:   ---      1.28  46%  25%  19%   0%   0%   0% 56.5°C
  3737    23:07:26:   ---      1.28  18%  16%   0%   2%   0%   0% 56.4°C
  3738    23:07:27:   ---      1.28  44%  25%  17%   2%   0%   0% 55.8°C
  3739    23:07:27:   ---      1.28  74%  37%  34%   2%   0%   0% 57.0°C
  3740    23:07:28:   ---      1.66  59%  34%  21%   1%   1%   0% 56.3°C
  3741
  3742    ### Activated 1 lzo zram swap devices with 483 MB each
  3743
  3744    ### Activated Armbian ramlog partition with zstd compression
  3745
  3746    vie may 15 23:57:35 CEST 2020 | Orange Pi+ 2E | 20.02.1 | armhf | armv7l | 5.4.35-sunxi
  3747
  3748    ### dmesg:
  3749
  3750    [    0.000000] Booting Linux on physical CPU 0x0
  3751    [    0.000000] Linux version 5.4.35-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #trunk SMP Thu Apr 23 18:06:21 CEST 2020
  3752    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
  3753    [    0.000000] CPU: div instructions available: patching division code
  3754    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  3755    [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi Plus 2E
  3756    [    0.000000] Memory policy: Data cache writealloc
  3757    [    0.000000] cma: Reserved 128 MiB at 0x75c00000
  3758    [    0.000000] On node 0 totalpages: 253952
  3759    [    0.000000]   Normal zone: 1728 pages used for memmap
  3760    [    0.000000]   Normal zone: 0 pages reserved
  3761    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
  3762    [    0.000000]   HighMem zone: 57344 pages, LIFO batch:15
  3763    [    0.000000] psci: probing for conduit method from DT.
  3764    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
  3765    [    0.000000] percpu: Embedded 20 pages/cpu s49868 r8192 d23860 u81920
  3766    [    0.000000] pcpu-alloc: s49868 r8192 d23860 u81920 alloc=20*4096
  3767    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  3768    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 252224
  3769    [    0.000000] Kernel command line: root=UUID=e4eb8394-3faa-4045-8f17-40b557e3885c rootwait rootfstype=f2fs console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart= ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
  3770    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
  3771    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
  3772    [    0.000000] allocated 1015808 bytes of page_ext
  3773    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  3774    [    0.000000] Memory: 846468K/1015808K available (9216K kernel code, 1053K rwdata, 2880K rodata, 1024K init, 316K bss, 38268K reserved, 131072K cma-reserved, 98292K highmem)
  3775    [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x3ac with crng_init=0
  3776    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  3777    [    0.000000] ftrace: allocating 41314 entries in 81 pages
  3778    [    0.000000] rcu: Hierarchical RCU implementation.
  3779    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  3780    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  3781    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  3782    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
  3783    [    0.000000] GIC: Using split EOI/Deactivate mode
  3784    [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  3785    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  3786    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  3787    [    0.000012] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  3788    [    0.000031] Switching to timer-based delay loop, resolution 41ns
  3789    [    0.000443] Console: colour dummy device 80x30
  3790    [    0.000468] printk: console [tty1] enabled
  3791    [    0.000557] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  3792    [    0.000578] pid_max: default: 32768 minimum: 301
  3793    [    0.001026] LSM: Security Framework initializing
  3794    [    0.001210] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  3795    [    0.001236] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  3796    [    0.001395] *** VALIDATE tmpfs ***
  3797    [    0.002681] *** VALIDATE proc ***
  3798    [    0.003232] *** VALIDATE cgroup1 ***
  3799    [    0.003247] *** VALIDATE cgroup2 ***
  3800    [    0.003365] CPU: Testing write buffer coherency: ok
  3801    [    0.004158] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
  3802    [    0.005212] Setting up static identity map for 0x40100000 - 0x40100054
  3803    [    0.005465] rcu: Hierarchical SRCU implementation.
  3804    [    0.006537] smp: Bringing up secondary CPUs ...
  3805    [    0.017852] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
  3806    [    0.029416] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
  3807    [    0.040826] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
  3808    [    0.041039] smp: Brought up 1 node, 4 CPUs
  3809    [    0.041057] SMP: Total of 4 processors activated (192.00 BogoMIPS).
  3810    [    0.041064] CPU: All CPU(s) started in HYP mode.
  3811    [    0.041070] CPU: Virtualization extensions available.
  3812    [    0.042588] devtmpfs: initialized
  3813    [    0.057257] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
  3814    [    0.057747] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  3815    [    0.057779] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  3816    [    0.067917] xor: measuring software checksum speed
  3817    [    0.104959]    arm4regs  :   508.000 MB/sec
  3818    [    0.145097]    8regs     :   354.000 MB/sec
  3819    [    0.185240]    32regs    :   334.000 MB/sec
  3820    [    0.225391]    neon      :   515.000 MB/sec
  3821    [    0.225401] xor: using function: neon (515.000 MB/sec)
  3822    [    0.225519] pinctrl core: initialized pinctrl subsystem
  3823    [    0.227389] NET: Registered protocol family 16
  3824    [    0.230915] DMA: preallocated 256 KiB pool for atomic coherent allocations
  3825    [    0.232064] audit: initializing netlink subsys (disabled)
  3826    [    0.232424] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
  3827    [    0.233695] cpuidle: using governor ladder
  3828    [    0.233970] cpuidle: using governor menu
  3829    [    0.235275] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
  3830    [    0.235286] hw-breakpoint: maximum watchpoint size is 8 bytes.
  3831    [    0.366251] raid6: neonx8   gen()   287 MB/s
  3832    [    0.434442] raid6: neonx8   xor()   238 MB/s
  3833    [    0.502798] raid6: neonx4   gen()   294 MB/s
  3834    [    0.571005] raid6: neonx4   xor()   249 MB/s
  3835    [    0.639387] raid6: neonx2   gen()   268 MB/s
  3836    [    0.707631] raid6: neonx2   xor()   236 MB/s
  3837    [    0.775918] raid6: neonx1   gen()   200 MB/s
  3838    [    0.844153] raid6: neonx1   xor()   189 MB/s
  3839    [    0.912546] raid6: int32x8  gen()   108 MB/s
  3840    [    0.980800] raid6: int32x8  xor()    70 MB/s
  3841    [    1.048974] raid6: int32x4  gen()   115 MB/s
  3842    [    1.117278] raid6: int32x4  xor()    79 MB/s
  3843    [    1.185760] raid6: int32x2  gen()   103 MB/s
  3844    [    1.254121] raid6: int32x2  xor()    83 MB/s
  3845    [    1.322424] raid6: int32x1  gen()    81 MB/s
  3846    [    1.390859] raid6: int32x1  xor()    71 MB/s
  3847    [    1.390869] raid6: using algorithm neonx4 gen() 294 MB/s
  3848    [    1.390876] raid6: .... xor() 249 MB/s, rmw enabled
  3849    [    1.390884] raid6: using neon recovery algorithm
  3850    [    1.393758] iommu: Default domain type: Translated
  3851    [    1.394555] SCSI subsystem initialized
  3852    [    1.394966] libata version 3.00 loaded.
  3853    [    1.395403] usbcore: registered new interface driver usbfs
  3854    [    1.395531] usbcore: registered new interface driver hub
  3855    [    1.395681] usbcore: registered new device driver usb
  3856    [    1.396094] mc: Linux media interface: v0.10
  3857    [    1.396160] videodev: Linux video capture interface: v2.00
  3858    [    1.396425] pps_core: LinuxPPS API ver. 1 registered
  3859    [    1.396435] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3860    [    1.396472] PTP clock support registered
  3861    [    1.399692] clocksource: Switched to clocksource arch_sys_counter
  3862    [    3.451356] *** VALIDATE bpf ***
  3863    [    3.451913] VFS: Disk quotas dquot_6.6.0
  3864    [    3.452057] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  3865    [    3.452236] *** VALIDATE ramfs ***
  3866    [    3.469817] thermal_sys: Registered thermal governor 'fair_share'
  3867    [    3.469829] thermal_sys: Registered thermal governor 'bang_bang'
  3868    [    3.469842] thermal_sys: Registered thermal governor 'step_wise'
  3869    [    3.469851] thermal_sys: Registered thermal governor 'power_allocator'
  3870    [    3.470795] NET: Registered protocol family 2
  3871    [    3.472249] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
  3872    [    3.472315] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
  3873    [    3.472496] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
  3874    [    3.472769] TCP: Hash tables configured (established 8192 bind 8192)
  3875    [    3.472987] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
  3876    [    3.473077] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
  3877    [    3.473528] NET: Registered protocol family 1
  3878    [    3.474463] RPC: Registered named UNIX socket transport module.
  3879    [    3.474474] RPC: Registered udp transport module.
  3880    [    3.474482] RPC: Registered tcp transport module.
  3881    [    3.474489] RPC: Registered tcp NFSv4.1 backchannel transport module.
  3882    [    3.474944] Trying to unpack rootfs image as initramfs...
  3883    [    5.102901] Freeing initrd memory: 11384K
  3884    [    5.105823] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
  3885    [    5.108439] Initialise system trusted keyrings
  3886    [    5.108870] workingset: timestamp_bits=14 max_order=18 bucket_order=4
  3887    [    5.124149] zbud: loaded
  3888    [    5.129226] NFS: Registering the id_resolver key type
  3889    [    5.129272] Key type id_resolver registered
  3890    [    5.129281] Key type id_legacy registered
  3891    [    5.129308] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  3892    [    5.129317] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  3893    [    5.132375] JFS: nTxBlock = 7725, nTxLock = 61807
  3894    [    5.145988] SGI XFS with ACLs, security attributes, realtime, no debug enabled
  3895    [    5.266834] Key type asymmetric registered
  3896    [    5.266851] Asymmetric key parser 'x509' registered
  3897    [    5.266983] bounce: pool size: 64 pages
  3898    [    5.267112] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  3899    [    5.267505] io scheduler mq-deadline registered
  3900    [    5.267516] io scheduler kyber registered
  3901    [    5.267745] io scheduler bfq registered
  3902    [    5.280107] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  3903    [    5.283542] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  3904    [    5.298022] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  3905    [    5.303081] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
  3906    [    5.303942] printk: console [ttyS0] disabled
  3907    [    5.324253] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 43, base_baud = 1500000) is a U6_16550A
  3908    [    5.324348] printk: console [ttyS0] enabled
  3909    [    5.338415] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a8f2b8)
  3910    [    5.338934] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a8bea4)
  3911    [    5.339070] sun8i-dw-hdmi 1ee0000.hdmi: 1ee0000.hdmi supply hvcc not found, using dummy regulator
  3912    [    5.340499] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
  3913    [    5.341253] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
  3914    [    5.341768] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a8e8a4)
  3915    [    5.341782] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  3916    [    5.341789] [drm] No driver support for vblank timestamp query.
  3917    [    5.342592] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
  3918    [    5.688461] Console: switching to colour frame buffer device 128x48
  3919    [    5.738013] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
  3920    [    5.745509] brd: module loaded
  3921    [    5.758759] loop: module loaded
  3922    [    5.762628] libphy: Fixed MDIO Bus: probed
  3923    [    5.764213] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  3924    [    5.764612] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  3925    [    5.764628] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  3926    [    5.764820] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  3927    [    5.767298] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3928    [    5.767309] ehci-platform: EHCI generic platform driver
  3929    [    5.767636] ehci-platform 1c1a000.usb: EHCI Host Controller
  3930    [    5.767778] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  3931    [    5.768565] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  3932    [    5.783746] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  3933    [    5.784329] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  3934    [    5.784350] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3935    [    5.784365] usb usb1: Product: EHCI Host Controller
  3936    [    5.784379] usb usb1: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  3937    [    5.784394] usb usb1: SerialNumber: 1c1a000.usb
  3938    [    5.785506] hub 1-0:1.0: USB hub found
  3939    [    5.785623] hub 1-0:1.0: 1 port detected
  3940    [    5.787430] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3941    [    5.787471] ohci-platform: OHCI generic platform driver
  3942    [    5.787884] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  3943    [    5.787932] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
  3944    [    5.788274] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  3945    [    5.852327] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  3946    [    5.852347] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3947    [    5.852363] usb usb2: Product: Generic Platform OHCI controller
  3948    [    5.852377] usb usb2: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  3949    [    5.852391] usb usb2: SerialNumber: 1c1a400.usb
  3950    [    5.853424] hub 2-0:1.0: USB hub found
  3951    [    5.853524] hub 2-0:1.0: 1 port detected
  3952    [    5.856456] usbcore: registered new interface driver usb-storage
  3953    [    5.859429] sun6i-rtc 1f00000.rtc: registered as rtc0
  3954    [    5.859445] sun6i-rtc 1f00000.rtc: RTC enabled
  3955    [    5.860199] i2c /dev entries driver
  3956    [    5.860972] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
  3957    [    5.865189] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  3958    [    5.866552] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
  3959    [    5.867962] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  3960    [    5.892376] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
  3961    [    5.892868] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  3962    [    5.894953] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
  3963    [    5.919773] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
  3964    [    5.922239] ledtrig-cpu: registered to indicate activity on CPUs
  3965    [    5.922408] hidraw: raw HID events driver (C) Jiri Kosina
  3966    [    5.922673] usbcore: registered new interface driver usbhid
  3967    [    5.922680] usbhid: USB HID core driver
  3968    [    5.926459] Initializing XFRM netlink socket
  3969    [    5.927813] NET: Registered protocol family 10
  3970    [    6.065126] Segment Routing with IPv6
  3971    [    6.065328] NET: Registered protocol family 17
  3972    [    6.065387] NET: Registered protocol family 15
  3973    [    6.065512] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  3974    [    6.065936] 8021q: 802.1Q VLAN Support v1.8
  3975    [    6.066054] Key type dns_resolver registered
  3976    [    6.067124] Registering SWP/SWPB emulation handler
  3977    [    6.067781] registered taskstats version 1
  3978    [    6.067790] Loading compiled-in X.509 certificates
  3979    [    6.067978] zswap: loaded using pool lzo/zbud
  3980    [    6.068536] Key type ._fscrypt registered
  3981    [    6.068548] Key type .fscrypt registered
  3982    [    6.074607] Btrfs loaded, crc32c=crc32c-generic
  3983    [    6.079954] mmc1: new DDR MMC card at address 0001
  3984    [    6.081746] mmcblk1: mmc1:0001 NCard  7.22 GiB
  3985    [    6.082631] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
  3986    [    6.083480] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
  3987    [    6.087502]  mmcblk1: p1 p2
  3988    [    6.146813] Key type encrypted registered
  3989    [    6.170917] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  3990    [    6.171800] simple-framebuffer 7e000000.framebuffer: framebuffer at 0x7e000000, 0x300000 bytes, mapped to 0x(ptrval)
  3991    [    6.171825] simple-framebuffer 7e000000.framebuffer: format=x8r8g8b8, mode=1024x768x32, linelength=4096
  3992    [    6.172282] simple-framebuffer 7e000000.framebuffer: fb1: simplefb registered!
  3993    [    6.172721] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  3994    [    6.175848] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  3995    [    6.175867] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  3996    [    6.176028] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  3997    [    6.176242] dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
  3998    [    6.284142] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000)
  3999    [    6.284181] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  4000    [    6.284194] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  4001    [    6.284208] dwmac-sun8i 1c30000.ethernet: COE Type 2
  4002    [    6.284222] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  4003    [    6.284236] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  4004    [    6.284249] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  4005    [    6.284603] libphy: stmmac: probed
  4006    [    6.286096] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
  4007    [    6.286321] libphy: mdio_mux: probed
  4008    [    6.286363] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
  4009    [    6.286381] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
  4010    [    6.308549] ac200: Unknown symbol ac200_reg_mod (err -2)
  4011    [    6.308601] ac200: Unknown symbol ac200_reg_write (err -2)
  4012    [    6.311386] libphy: mdio_mux: probed
  4013    [    6.311439] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
  4014    [    6.411513] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
  4015    [    6.411754] dwmac-sun8i 1c30000.ethernet: Error: Failed to register MDIO bus for child /soc/ethernet@1c30000/mdio-mux/mdio@2
  4016    [    6.412962] ehci-platform 1c1b000.usb: EHCI Host Controller
  4017    [    6.413022] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
  4018    [    6.413907] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  4019    [    6.427758] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  4020    [    6.428212] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  4021    [    6.428232] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4022    [    6.428247] usb usb3: Product: EHCI Host Controller
  4023    [    6.428262] usb usb3: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  4024    [    6.428277] usb usb3: SerialNumber: 1c1b000.usb
  4025    [    6.429410] hub 3-0:1.0: USB hub found
  4026    [    6.429491] hub 3-0:1.0: 1 port detected
  4027    [    6.431233] ehci-platform 1c1c000.usb: EHCI Host Controller
  4028    [    6.431286] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
  4029    [    6.431852] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
  4030    [    6.447737] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
  4031    [    6.448148] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  4032    [    6.448167] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4033    [    6.448183] usb usb4: Product: EHCI Host Controller
  4034    [    6.448197] usb usb4: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  4035    [    6.448212] usb usb4: SerialNumber: 1c1c000.usb
  4036    [    6.449236] hub 4-0:1.0: USB hub found
  4037    [    6.449314] hub 4-0:1.0: 1 port detected
  4038    [    6.450951] ehci-platform 1c1d000.usb: EHCI Host Controller
  4039    [    6.450999] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
  4040    [    6.451487] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
  4041    [    6.463743] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
  4042    [    6.464171] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  4043    [    6.464190] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4044    [    6.464205] usb usb5: Product: EHCI Host Controller
  4045    [    6.464219] usb usb5: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  4046    [    6.464233] usb usb5: SerialNumber: 1c1d000.usb
  4047    [    6.465239] hub 5-0:1.0: USB hub found
  4048    [    6.465319] hub 5-0:1.0: 1 port detected
  4049    [    6.466971] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  4050    [    6.467020] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
  4051    [    6.467365] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  4052    [    6.528123] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  4053    [    6.528142] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4054    [    6.528158] usb usb6: Product: Generic Platform OHCI controller
  4055    [    6.528173] usb usb6: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  4056    [    6.528187] usb usb6: SerialNumber: 1c1b400.usb
  4057    [    6.529181] hub 6-0:1.0: USB hub found
  4058    [    6.529261] hub 6-0:1.0: 1 port detected
  4059    [    6.530893] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
  4060    [    6.530943] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
  4061    [    6.531311] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
  4062    [    6.592089] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  4063    [    6.592109] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4064    [    6.592124] usb usb7: Product: Generic Platform OHCI controller
  4065    [    6.592138] usb usb7: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  4066    [    6.592152] usb usb7: SerialNumber: 1c1c400.usb
  4067    [    6.593176] hub 7-0:1.0: USB hub found
  4068    [    6.593257] hub 7-0:1.0: 1 port detected
  4069    [    6.594876] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
  4070    [    6.594926] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
  4071    [    6.595257] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
  4072    [    6.656118] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  4073    [    6.656137] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4074    [    6.656152] usb usb8: Product: Generic Platform OHCI controller
  4075    [    6.656167] usb usb8: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  4076    [    6.656181] usb usb8: SerialNumber: 1c1d400.usb
  4077    [    6.657219] hub 8-0:1.0: USB hub found
  4078    [    6.657317] hub 8-0:1.0: 1 port detected
  4079    [    6.659088] usb_phy_generic usb_phy_generic.3.auto: usb_phy_generic.3.auto supply vcc not found, using dummy regulator
  4080    [    6.660084] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
  4081    [    6.660132] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9
  4082    [    6.660564] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  4083    [    6.660583] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4084    [    6.660597] usb usb9: Product: MUSB HDRC host driver
  4085    [    6.660612] usb usb9: Manufacturer: Linux 5.4.35-sunxi musb-hcd
  4086    [    6.660627] usb usb9: SerialNumber: musb-hdrc.4.auto
  4087    [    6.661599] hub 9-0:1.0: USB hub found
  4088    [    6.661684] hub 9-0:1.0: 1 port detected
  4089    [    6.669407] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:23 UTC (23)
  4090    [    6.669781] of_cfs_init
  4091    [    6.669998] of_cfs_init: OK
  4092    [    6.678807] Freeing unused kernel memory: 1024K
  4093    [    6.692234] Run /init as init process
  4094    [    6.868001] random: fast init done
  4095    [    7.435772] usb 2-1: new full-speed USB device number 2 using ohci-platform
  4096    [    7.444597] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
  4097    [    7.661632] lima 1c40000.gpu: IRQ ppmmu2 not found
  4098    [    7.661693] lima 1c40000.gpu: IRQ ppmmu3 not found
  4099    [    7.661807] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
  4100    [    7.662121] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
  4101    [    7.662428] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
  4102    [    7.662679] lima 1c40000.gpu: IRQ pp2 not found
  4103    [    7.662734] lima 1c40000.gpu: IRQ pp3 not found
  4104    [    7.662774] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
  4105    [    7.665500] lima 1c40000.gpu: bus rate = 200000000
  4106    [    7.665519] lima 1c40000.gpu: mod rate = 384000000
  4107    [    7.666564] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 1
  4108    [    7.680922] usb 2-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
  4109    [    7.680949] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  4110    [    7.680974] usb 2-1: Product: USB Receiver
  4111    [    7.680991] usb 2-1: Manufacturer: Logitech
  4112    [    7.694892] input: Logitech USB Receiver as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.0/0003:046D:C52B.0001/input/input2
  4113    [    7.747784] rc_core: IR keymap rc-cec not found
  4114    [    7.747800] Registered IR keymap rc-empty
  4115    [    7.748111] rc rc0: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0
  4116    [    7.748450] input: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0/input1
  4117    [    7.752404] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-1c1a400.usb-1/input0
  4118    [    7.765646] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input3
  4119    [    7.769061] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input4
  4120    [    7.769913] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  4121    [    7.797185] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
  4122    [    7.819278] mmc2: new high speed SDIO card at address 0001
  4123    [    7.828750] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.1/0003:046D:C52B.0002/input/input5
  4124    [    7.829583] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1a400.usb-1/input1
  4125    [    7.840022] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
  4126    [    8.000250] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1a400.usb-1/input2
  4127    [    8.129825] input: Logitech Unifying Device. Wireless PID:4024 Keyboard as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input7
  4128    [    8.130264] input: Logitech Unifying Device. Wireless PID:4024 Mouse as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input8
  4129    [    8.130805] input: Logitech Unifying Device. Wireless PID:4024 Consumer Control as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input9
  4130    [    8.136355] hid-generic 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4024] on usb-1c1a400.usb-1/input2:1
  4131    [    8.246449] input: Logitech K400 as /devices/platform/soc/1c1a400.usb/usb2/2-1/2-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input13
  4132    [    8.246835] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-1c1a400.usb-1/input2:1
  4133    [    8.795095] F2FS-fs (mmcblk1p2): Found nat_bits in checkpoint
  4134    [    9.071268] F2FS-fs (mmcblk1p2): recover fsync data on readonly fs
  4135    [    9.091760] F2FS-fs (mmcblk1p2): Mounted with checkpoint version = 240c4d4c
  4136    [    9.730561] systemd[1]: System time before build time, advancing clock.
  4137    [    9.787336] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  4138    [    9.788956] systemd[1]: Detected architecture arm.
  4139    [    9.833232] systemd[1]: Set hostname to <beelinkx2>.
  4140    [   11.248428] random: systemd: uninitialized urandom read (16 bytes read)
  4141    [   11.276601] random: systemd: uninitialized urandom read (16 bytes read)
  4142    [   11.276755] systemd[1]: Reached target Swap.
  4143    [   11.278023] random: systemd: uninitialized urandom read (16 bytes read)
  4144    [   11.278155] systemd[1]: Reached target System Time Synchronized.
  4145    [   11.280554] systemd[1]: Listening on fsck to fsckd communication Socket.
  4146    [   11.282439] systemd[1]: Listening on Journal Socket (/dev/log).
  4147    [   11.289705] systemd[1]: Created slice User and Session Slice.
  4148    [   11.291631] systemd[1]: Listening on udev Kernel Socket.
  4149    [   11.297601] systemd[1]: Created slice system-serial\x2dgetty.slice.
  4150    [   13.046061] systemd-journald[327]: Received request to flush runtime journal from PID 1
  4151    [   13.704041] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
  4152    [   13.729871] cedrus 1c0e000.video-codec: Device registered as /dev/video0
  4153    [   13.941377] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  4154    [   14.267759] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  4155    [   14.276185] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  4156    [   14.276210] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
  4157    [   14.339599] sun4i-codec 1c22c00.codec: Failed to register our card
  4158    [   14.409855] sun4i-codec 1c22c00.codec: Failed to register our card
  4159    [   14.441353] sun4i-codec 1c22c00.codec: Failed to register our card
  4160    [   14.469991] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
  4161    [   14.478030] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
  4162    [   14.495353] Registered IR keymap rc-empty
  4163    [   14.495612] rc rc1: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1
  4164    [   14.504538] bFWReady == _FALSE call reset 8051...
  4165    [   14.539990] rc rc1: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
  4166    [   14.540917] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1/input14
  4167    [   14.574043] sunxi-ir 1f02000.ir: initialized sunXi IR driver
  4168    [   14.680816] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok
  4169    [   15.149765] cfg80211: failed to load regulatory.db
  4170    [   16.677450] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: commit=600,errors=remount-ro
  4171    [   16.677526] ext4 filesystem being mounted at /media/mmcboot supports timestamps until 2038 (0x7fffffff)
  4172    [   17.594940] zram: Added device: zram0
  4173    [   17.597456] zram: Added device: zram1
  4174    [   17.601357] zram: Added device: zram2
  4175    [   17.702863] zram1: detected capacity change from 0 to 506855424
  4176    [   18.815781] Adding 494972k swap on /dev/zram1.  Priority:5 extents:1 across:494972k SSFS
  4177    [   19.128618] zram0: detected capacity change from 0 to 52428800
  4178    [   20.563002] random: crng init done
  4179    [   20.563021] random: 7 urandom warning(s) missed due to ratelimiting
  4180    [   20.950318] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
  4181    [   20.950443] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  4182
  4183    ### armbian-release:
  4184
  4185    # PLEASE DO NOT EDIT THIS FILE
  4186    BOARD=orangepiplus2e
  4187    BOARD_NAME="Orange Pi+ 2E"
  4188    BOARDFAMILY=sun8i
  4189    BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin
  4190    BUILD_REPOSITORY_COMMIT=3e533c9
  4191    DISTRIBUTION_CODENAME=buster
  4192    DISTRIBUTION_STATUS=supported
  4193    VERSION=20.02.1
  4194    LINUXFAMILY=sunxi
  4195    BRANCH=current
  4196    ARCH=arm
  4197    IMAGE_TYPE=stable
  4198    BOARD_TYPE=conf
  4199    INITRD_ARCH=arm
  4200    KERNEL_IMAGE_TYPE=Image
  4201
  4202    ### boot environment:
  4203
  4204    verbosity=1
  4205    logo=disabled
  4206    console=both
  4207    disp_mode=1920x1080p60
  4208    overlay_prefix=sun8i-h3
  4209    rootdev=UUID=e4eb8394-3faa-4045-8f17-40b557e3885c
  4210    rootfstype=f2fs
  4211    usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  4212
  4213    ### lsusb:
  4214
  4215    Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4216    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4217    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4218    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4219    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4220    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4221    Bus 002 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
  4222    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4223    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4224    Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4225
  4226    ### lscpu:
  4227
  4228    Architecture:        armv7l
  4229    Byte Order:          Little Endian
  4230    CPU(s):              4
  4231    On-line CPU(s) list: 0-3
  4232    Thread(s) per core:  1
  4233    Core(s) per socket:  4
  4234    Socket(s):           1
  4235    Vendor ID:           ARM
  4236    Model:               5
  4237    Model name:          Cortex-A7
  4238    Stepping:            r0p5
  4239    BogoMIPS:            48.00
  4240    Flags:               half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  4241
  4242    ### cpuinfo:
  4243
  4244    processor    : 0
  4245    model name    : ARMv7 Processor rev 5 (v7l)
  4246    BogoMIPS    : 48.00
  4247    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  4248    CPU implementer    : 0x41
  4249    CPU architecture: 7
  4250    CPU variant    : 0x0
  4251    CPU part    : 0xc07
  4252    CPU revision    : 5
  4253
  4254    processor    : 1
  4255    model name    : ARMv7 Processor rev 5 (v7l)
  4256    BogoMIPS    : 48.00
  4257    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  4258    CPU implementer    : 0x41
  4259    CPU architecture: 7
  4260    CPU variant    : 0x0
  4261    CPU part    : 0xc07
  4262    CPU revision    : 5
  4263
  4264    processor    : 2
  4265    model name    : ARMv7 Processor rev 5 (v7l)
  4266    BogoMIPS    : 48.00
  4267    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  4268    CPU implementer    : 0x41
  4269    CPU architecture: 7
  4270    CPU variant    : 0x0
  4271    CPU part    : 0xc07
  4272    CPU revision    : 5
  4273
  4274    processor    : 3
  4275    model name    : ARMv7 Processor rev 5 (v7l)
  4276    BogoMIPS    : 48.00
  4277    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  4278    CPU implementer    : 0x41
  4279    CPU architecture: 7
  4280    CPU variant    : 0x0
  4281    CPU part    : 0xc07
  4282    CPU revision    : 5
  4283
  4284    Hardware    : Allwinner sun8i Family
  4285    Revision    : 0000
  4286    Serial        : 02c00081bd8e203d
  4287
  4288    ### meminfo:
  4289
  4290    MemTotal:         989948 kB
  4291    MemFree:          828672 kB
  4292    MemAvailable:     890088 kB
  4293    Buffers:            2228 kB
  4294    Cached:            66708 kB
  4295    SwapCached:            0 kB
  4296    Active:            45212 kB
  4297    Inactive:          39620 kB
  4298    Active(anon):      18152 kB
  4299    Inactive(anon):     2980 kB
  4300    Active(file):      27060 kB
  4301    Inactive(file):    36640 kB
  4302    Unevictable:        1936 kB
  4303    Mlocked:               0 kB
  4304    HighTotal:        229364 kB
  4305    HighFree:         130600 kB
  4306    LowTotal:         760584 kB
  4307    LowFree:          698072 kB
  4308    SwapTotal:        494972 kB
  4309    SwapFree:         494972 kB
  4310    Dirty:                40 kB
  4311    Writeback:             0 kB
  4312    AnonPages:         17916 kB
  4313    Mapped:            22340 kB
  4314    Shmem:              3188 kB
  4315    KReclaimable:      15696 kB
  4316    Slab:              43420 kB
  4317    SReclaimable:      15696 kB
  4318    SUnreclaim:        27724 kB
  4319    KernelStack:        1288 kB
  4320    PageTables:         1176 kB
  4321    NFS_Unstable:          0 kB
  4322    Bounce:                0 kB
  4323    WritebackTmp:          0 kB
  4324    CommitLimit:      989944 kB
  4325    Committed_AS:     125096 kB
  4326    VmallocTotal:     245760 kB
  4327    VmallocUsed:       15920 kB
  4328    VmallocChunk:          0 kB
  4329    Percpu:              752 kB
  4330    CmaTotal:         131072 kB
  4331    CmaFree:          117364 kB
  4332
  4333    ### virtual memory:
  4334
  4335    vm.admin_reserve_kbytes = 8192
  4336    vm.block_dump = 0
  4337    vm.compact_unevictable_allowed = 1
  4338    vm.dirty_background_bytes = 0
  4339    vm.dirty_background_ratio = 10
  4340    vm.dirty_bytes = 0
  4341    vm.dirty_expire_centisecs = 3000
  4342    vm.dirty_ratio = 20
  4343    vm.dirtytime_expire_seconds = 43200
  4344    vm.dirty_writeback_centisecs = 500
  4345    vm.extfrag_threshold = 500
  4346    vm.highmem_is_dirtyable = 0
  4347    vm.laptop_mode = 0
  4348    vm.legacy_va_layout = 0
  4349    vm.lowmem_reserve_ratio = 32    0    0
  4350    vm.max_map_count = 65530
  4351    vm.min_free_kbytes = 3459
  4352    vm.mmap_min_addr = 4096
  4353    vm.mmap_rnd_bits = 8
  4354    vm.oom_dump_tasks = 1
  4355    vm.oom_kill_allocating_task = 0
  4356    vm.overcommit_kbytes = 0
  4357    vm.overcommit_memory = 0
  4358    vm.overcommit_ratio = 50
  4359    vm.page-cluster = 0
  4360    vm.panic_on_oom = 0
  4361    vm.percpu_pagelist_fraction = 0
  4362    vm.stat_interval = 1
  4363    vm.swappiness = 100
  4364    vm.user_reserve_kbytes = 30417
  4365    vm.vfs_cache_pressure = 100
  4366    vm.watermark_boost_factor = 15000
  4367    vm.watermark_scale_factor = 10
  4368
  4369    ### ip addr:
  4370
  4371    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  4372        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4373        inet XXX.XXX.0.1/8 scope host lo
  4374           valid_lft forever preferred_lft forever
  4375        inet6 ::1/128 scope host
  4376           valid_lft forever preferred_lft forever
  4377    2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4378        link/ether 02:81:bd:8e:20:3d brd ff:ff:ff:ff:ff:ff
  4379    3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  4380        link/ether cc:79:cf:54:c5:4a brd ff:ff:ff:ff:ff:ff
  4381
  4382    ### partitions:
  4383
  4384    major minor  #blocks  name
  4385
  4386     179        0    7570432 mmcblk1
  4387     179        1      98304 mmcblk1p1
  4388     179        2    7392320 mmcblk1p2
  4389     254        0      51200 zram0
  4390     254        1     494976 zram1
  4391
  4392    ### df:
  4393
  4394    udev             414M      0  414M   0% /dev
  4395    tmpfs             97M   3,3M   94M   4% /run
  4396    /dev/mmcblk1p2   7,1G   2,9G  4,3G  40% /
  4397    tmpfs            484M      0  484M   0% /dev/shm
  4398    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  4399    tmpfs            484M      0  484M   0% /sys/fs/cgroup
  4400    tmpfs            484M   8,0K  484M   1% /tmp
  4401    /dev/mmcblk1p1    89M    40M   43M  48% /media/mmcboot
  4402    /dev/zram0        49M   3,9M   42M   9% /var/log
  4403
  4404    ### lsblk:
  4405
  4406    NAME         FSTYPE   SIZE MOUNTPOINT     UUID
  4407    mmcblk1               7,2G
  4408    ├─mmcblk1p1  ext4      96M /media/mmcboot 1903597c-c143-4430-bbb1-077aebbaf563
  4409    └─mmcblk1p2  f2fs     7,1G /              e4eb8394-3faa-4045-8f17-40b557e3885c
  4410    mmcblk1boot0            4M
  4411    mmcblk1boot1            4M
  4412    zram0                  50M /var/log
  4413
  4414    ### zramctl:
  4415
  4416    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  4417    /dev/zram1 lzo         483,4M    4K    76B    4K       4 [SWAP]
  4418    /dev/zram0 zstd           50M  3,9M 792,9K  1,2M       4 /var/log
  4419
  4420    ### mtab:
  4421
  4422    /dev/mmcblk1p1 /boot ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  4423    /dev/mmcblk1p1 /media/mmcboot ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  4424    /dev/mmcblk1p2 / f2fs rw,lazytime,noatime,nodiratime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=default,fsync_mode=posix 0 0
  4425    /dev/mmcblk1p2 /var/log.hdd f2fs rw,lazytime,noatime,nodiratime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=default,fsync_mode=posix 0 0
  4426    /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
  4427
  4428    ### mmc1:0001 info:
  4429
  4430                  manfid: 0x000088
  4431                     cid: 8801034e436172642026e16382562375
  4432                   fwrev: 0x0000000000000000
  4433                     rca: 0x0001
  4434                     csd: d0ffff320f5903ffffffffe7964000eb
  4435               life_time: 0x01 0x01
  4436                     ocr: 0x00200000
  4437                    type: MMC
  4438    enhanced_area_offset: 18446744073709551594
  4439                    date: 02/2016
  4440                   hwrev: 0x0
  4441                     prv: 0x26
  4442                     dsr: 0x404
  4443             ffu_capable: 1
  4444                  serial: 0xe1638256
  4445      raw_rpmb_size_mult: 0x20
  4446              erase_size: 524288
  4447            pre_eol_info: 0x01
  4448             rel_sectors: 0x1
  4449                 cmdq_en: 0
  4450                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=NCard  MODALIAS=mmc:block
  4451      enhanced_area_size: 4294967274
  4452                   oemid: 0x0103
  4453                     rev: 0x7
  4454    preferred_erase_size: 4194304
  4455                    name: NCard
  4456
  4457    ### Boot system health:
  4458
  4459    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  4460    23:57:44:   ---      2.47  56%  30%  26%   0%   0%   0% 40.7°C
  4461    23:57:44:   ---      2.47  56%  30%  23%   3%   0%   0% 40.3°C
  4462    23:57:45:   ---      2.47  75%  37%  34%   2%   0%   0% 39.7°C
  4463    23:57:46:   ---      2.47  86%  32%  51%   1%   0%   0% 41.0°C
  4464    23:57:46:   ---      2.47  76%  35%  36%   3%   1%   0% 39.3°C
  4465
  4466    ### Activated 1 lzo zram swap devices with 483 MB each
  4467
  4468    ### Activated Armbian ramlog partition with zstd compression
  4469
  4470    sáb may 16 21:23:51 CEST 2020 | Orange Pi+ 2E | 20.02.1 | armhf | armv7l | 5.4.35-sunxi
  4471
  4472    ### dmesg:
  4473
  4474    [    0.000000] Booting Linux on physical CPU 0x0
  4475    [    0.000000] Linux version 5.4.35-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #trunk SMP Thu Apr 23 18:06:21 CEST 2020
  4476    [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
  4477    [    0.000000] CPU: div instructions available: patching division code
  4478    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  4479    [    0.000000] OF: fdt: Machine model: Xunlong Orange Pi Plus 2E
  4480    [    0.000000] Memory policy: Data cache writealloc
  4481    [    0.000000] cma: Reserved 128 MiB at 0x75c00000
  4482    [    0.000000] On node 0 totalpages: 253952
  4483    [    0.000000]   Normal zone: 1728 pages used for memmap
  4484    [    0.000000]   Normal zone: 0 pages reserved
  4485    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
  4486    [    0.000000]   HighMem zone: 57344 pages, LIFO batch:15
  4487    [    0.000000] psci: probing for conduit method from DT.
  4488    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
  4489    [    0.000000] percpu: Embedded 20 pages/cpu s49868 r8192 d23860 u81920
  4490    [    0.000000] pcpu-alloc: s49868 r8192 d23860 u81920 alloc=20*4096
  4491    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  4492    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 252224
  4493    [    0.000000] Kernel command line: root=UUID=e4eb8394-3faa-4045-8f17-40b557e3885c rootwait rootfstype=f2fs console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart= ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
  4494    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
  4495    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
  4496    [    0.000000] allocated 1015808 bytes of page_ext
  4497    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  4498    [    0.000000] Memory: 846468K/1015808K available (9216K kernel code, 1053K rwdata, 2880K rodata, 1024K init, 316K bss, 38268K reserved, 131072K cma-reserved, 98292K highmem)
  4499    [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x2b/0x3ac with crng_init=0
  4500    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  4501    [    0.000000] ftrace: allocating 41314 entries in 81 pages
  4502    [    0.000000] rcu: Hierarchical RCU implementation.
  4503    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  4504    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  4505    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  4506    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
  4507    [    0.000000] GIC: Using split EOI/Deactivate mode
  4508    [    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  4509    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  4510    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  4511    [    0.000012] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  4512    [    0.000032] Switching to timer-based delay loop, resolution 41ns
  4513    [    0.000440] Console: colour dummy device 80x30
  4514    [    0.000464] printk: console [tty1] enabled
  4515    [    0.000553] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  4516    [    0.000574] pid_max: default: 32768 minimum: 301
  4517    [    0.001021] LSM: Security Framework initializing
  4518    [    0.001205] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  4519    [    0.001231] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
  4520    [    0.001385] *** VALIDATE tmpfs ***
  4521    [    0.002664] *** VALIDATE proc ***
  4522    [    0.003221] *** VALIDATE cgroup1 ***
  4523    [    0.003237] *** VALIDATE cgroup2 ***
  4524    [    0.003356] CPU: Testing write buffer coherency: ok
  4525    [    0.004154] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
  4526    [    0.005204] Setting up static identity map for 0x40100000 - 0x40100054
  4527    [    0.005454] rcu: Hierarchical SRCU implementation.
  4528    [    0.006519] smp: Bringing up secondary CPUs ...
  4529    [    0.017825] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
  4530    [    0.029387] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
  4531    [    0.040828] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
  4532    [    0.041059] smp: Brought up 1 node, 4 CPUs
  4533    [    0.041076] SMP: Total of 4 processors activated (192.00 BogoMIPS).
  4534    [    0.041083] CPU: All CPU(s) started in HYP mode.
  4535    [    0.041089] CPU: Virtualization extensions available.
  4536    [    0.042600] devtmpfs: initialized
  4537    [    0.057268] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
  4538    [    0.057772] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  4539    [    0.057805] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  4540    [    0.067977] xor: measuring software checksum speed
  4541    [    0.104966]    arm4regs  :   508.000 MB/sec
  4542    [    0.145104]    8regs     :   354.000 MB/sec
  4543    [    0.185247]    32regs    :   334.000 MB/sec
  4544    [    0.225398]    neon      :   515.000 MB/sec
  4545    [    0.225409] xor: using function: neon (515.000 MB/sec)
  4546    [    0.225527] pinctrl core: initialized pinctrl subsystem
  4547    [    0.227448] NET: Registered protocol family 16
  4548    [    0.230982] DMA: preallocated 256 KiB pool for atomic coherent allocations
  4549    [    0.232176] audit: initializing netlink subsys (disabled)
  4550    [    0.232532] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1
  4551    [    0.233800] cpuidle: using governor ladder
  4552    [    0.233872] cpuidle: using governor menu
  4553    [    0.235126] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
  4554    [    0.235136] hw-breakpoint: maximum watchpoint size is 8 bytes.
  4555    [    0.366299] raid6: neonx8   gen()   286 MB/s
  4556    [    0.434475] raid6: neonx8   xor()   238 MB/s
  4557    [    0.502753] raid6: neonx4   gen()   294 MB/s
  4558    [    0.570879] raid6: neonx4   xor()   249 MB/s
  4559    [    0.639201] raid6: neonx2   gen()   268 MB/s
  4560    [    0.707374] raid6: neonx2   xor()   236 MB/s
  4561    [    0.775604] raid6: neonx1   gen()   200 MB/s
  4562    [    0.843905] raid6: neonx1   xor()   189 MB/s
  4563    [    0.912112] raid6: int32x8  gen()   108 MB/s
  4564    [    0.980284] raid6: int32x8  xor()    70 MB/s
  4565    [    1.049004] raid6: int32x4  gen()   116 MB/s
  4566    [    1.117063] raid6: int32x4  xor()    79 MB/s
  4567    [    1.185149] raid6: int32x2  gen()   103 MB/s
  4568    [    1.253465] raid6: int32x2  xor()    83 MB/s
  4569    [    1.321672] raid6: int32x1  gen()    81 MB/s
  4570    [    1.390050] raid6: int32x1  xor()    71 MB/s
  4571    [    1.390059] raid6: using algorithm neonx4 gen() 294 MB/s
  4572    [    1.390067] raid6: .... xor() 249 MB/s, rmw enabled
  4573    [    1.390075] raid6: using neon recovery algorithm
  4574    [    1.392996] iommu: Default domain type: Translated
  4575    [    1.393720] SCSI subsystem initialized
  4576    [    1.394212] libata version 3.00 loaded.
  4577    [    1.394639] usbcore: registered new interface driver usbfs
  4578    [    1.394733] usbcore: registered new interface driver hub
  4579    [    1.394901] usbcore: registered new device driver usb
  4580    [    1.395303] mc: Linux media interface: v0.10
  4581    [    1.395385] videodev: Linux video capture interface: v2.00
  4582    [    1.395631] pps_core: LinuxPPS API ver. 1 registered
  4583    [    1.395640] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  4584    [    1.395676] PTP clock support registered
  4585    [    1.398952] clocksource: Switched to clocksource arch_sys_counter
  4586    [    3.447875] *** VALIDATE bpf ***
  4587    [    3.448407] VFS: Disk quotas dquot_6.6.0
  4588    [    3.448562] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  4589    [    3.448741] *** VALIDATE ramfs ***
  4590    [    3.466257] thermal_sys: Registered thermal governor 'fair_share'
  4591    [    3.466269] thermal_sys: Registered thermal governor 'bang_bang'
  4592    [    3.466282] thermal_sys: Registered thermal governor 'step_wise'
  4593    [    3.466291] thermal_sys: Registered thermal governor 'power_allocator'
  4594    [    3.467322] NET: Registered protocol family 2
  4595    [    3.468738] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
  4596    [    3.468801] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
  4597    [    3.468964] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
  4598    [    3.469238] TCP: Hash tables configured (established 8192 bind 8192)
  4599    [    3.469455] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
  4600    [    3.469544] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
  4601    [    3.469968] NET: Registered protocol family 1
  4602    [    3.471027] RPC: Registered named UNIX socket transport module.
  4603    [    3.471036] RPC: Registered udp transport module.
  4604    [    3.471044] RPC: Registered tcp transport module.
  4605    [    3.471051] RPC: Registered tcp NFSv4.1 backchannel transport module.
  4606    [    3.471508] Trying to unpack rootfs image as initramfs...
  4607    [    5.100117] Freeing initrd memory: 11384K
  4608    [    5.102892] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
  4609    [    5.105443] Initialise system trusted keyrings
  4610    [    5.105858] workingset: timestamp_bits=14 max_order=18 bucket_order=4
  4611    [    5.121098] zbud: loaded
  4612    [    5.126245] NFS: Registering the id_resolver key type
  4613    [    5.126303] Key type id_resolver registered
  4614    [    5.126312] Key type id_legacy registered
  4615    [    5.126338] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  4616    [    5.126348] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  4617    [    5.129385] JFS: nTxBlock = 7725, nTxLock = 61807
  4618    [    5.143077] SGI XFS with ACLs, security attributes, realtime, no debug enabled
  4619    [    5.266614] Key type asymmetric registered
  4620    [    5.266631] Asymmetric key parser 'x509' registered
  4621    [    5.266772] bounce: pool size: 64 pages
  4622    [    5.266891] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  4623    [    5.267346] io scheduler mq-deadline registered
  4624    [    5.267359] io scheduler kyber registered
  4625    [    5.267488] io scheduler bfq registered
  4626    [    5.279913] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  4627    [    5.283392] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  4628    [    5.297850] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
  4629    [    5.302837] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
  4630    [    5.303706] printk: console [ttyS0] disabled
  4631    [    5.324040] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 43, base_baud = 1500000) is a U6_16550A
  4632    [    5.324138] printk: console [ttyS0] enabled
  4633    [    5.338198] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0a8f2b8)
  4634    [    5.338767] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a8bea4)
  4635    [    5.338901] sun8i-dw-hdmi 1ee0000.hdmi: 1ee0000.hdmi supply hvcc not found, using dummy regulator
  4636    [    5.340310] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
  4637    [    5.341078] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
  4638    [    5.341608] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc0a8e8a4)
  4639    [    5.341621] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  4640    [    5.341628] [drm] No driver support for vblank timestamp query.
  4641    [    5.342457] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
  4642    [    5.688425] Console: switching to colour frame buffer device 128x48
  4643    [    5.738010] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
  4644    [    5.745423] brd: module loaded
  4645    [    5.758782] loop: module loaded
  4646    [    5.762567] libphy: Fixed MDIO Bus: probed
  4647    [    5.764227] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  4648    [    5.764622] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  4649    [    5.764638] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  4650    [    5.764828] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  4651    [    5.767356] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  4652    [    5.767367] ehci-platform: EHCI generic platform driver
  4653    [    5.767697] ehci-platform 1c1a000.usb: EHCI Host Controller
  4654    [    5.767753] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  4655    [    5.768540] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  4656    [    5.783005] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  4657    [    5.783552] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  4658    [    5.783572] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4659    [    5.783587] usb usb1: Product: EHCI Host Controller
  4660    [    5.783602] usb usb1: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  4661    [    5.783616] usb usb1: SerialNumber: 1c1a000.usb
  4662    [    5.784744] hub 1-0:1.0: USB hub found
  4663    [    5.784855] hub 1-0:1.0: 1 port detected
  4664    [    5.786677] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  4665    [    5.786719] ohci-platform: OHCI generic platform driver
  4666    [    5.787137] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  4667    [    5.787185] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
  4668    [    5.787545] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  4669    [    5.851518] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  4670    [    5.851537] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4671    [    5.851553] usb usb2: Product: Generic Platform OHCI controller
  4672    [    5.851567] usb usb2: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  4673    [    5.851581] usb usb2: SerialNumber: 1c1a400.usb
  4674    [    5.852624] hub 2-0:1.0: USB hub found
  4675    [    5.852720] hub 2-0:1.0: 1 port detected
  4676    [    5.855612] usbcore: registered new interface driver usb-storage
  4677    [    5.858584] sun6i-rtc 1f00000.rtc: registered as rtc0
  4678    [    5.858600] sun6i-rtc 1f00000.rtc: RTC enabled
  4679    [    5.859362] i2c /dev entries driver
  4680    [    5.860133] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
  4681    [    5.864375] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  4682    [    5.865694] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
  4683    [    5.867107] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  4684    [    5.891637] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
  4685    [    5.892133] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  4686    [    5.894208] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
  4687    [    5.919018] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
  4688    [    5.921567] ledtrig-cpu: registered to indicate activity on CPUs
  4689    [    5.921755] hidraw: raw HID events driver (C) Jiri Kosina
  4690    [    5.922001] usbcore: registered new interface driver usbhid
  4691    [    5.922008] usbhid: USB HID core driver
  4692    [    5.925826] Initializing XFRM netlink socket
  4693    [    5.927200] NET: Registered protocol family 10
  4694    [    6.063888] Segment Routing with IPv6
  4695    [    6.064098] NET: Registered protocol family 17
  4696    [    6.064150] NET: Registered protocol family 15
  4697    [    6.064269] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  4698    [    6.064618] 8021q: 802.1Q VLAN Support v1.8
  4699    [    6.064724] Key type dns_resolver registered
  4700    [    6.065796] Registering SWP/SWPB emulation handler
  4701    [    6.066337] registered taskstats version 1
  4702    [    6.066346] Loading compiled-in X.509 certificates
  4703    [    6.066516] zswap: loaded using pool lzo/zbud
  4704    [    6.067166] Key type ._fscrypt registered
  4705    [    6.067175] Key type .fscrypt registered
  4706    [    6.073129] Btrfs loaded, crc32c=crc32c-generic
  4707    [    6.079132] mmc1: new DDR MMC card at address 0001
  4708    [    6.081068] mmcblk1: mmc1:0001 NCard  7.22 GiB
  4709    [    6.081986] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
  4710    [    6.082850] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
  4711    [    6.086304]  mmcblk1: p1 p2
  4712    [    6.142211] Key type encrypted registered
  4713    [    6.166302] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  4714    [    6.167290] simple-framebuffer 7e000000.framebuffer: framebuffer at 0x7e000000, 0x300000 bytes, mapped to 0x(ptrval)
  4715    [    6.167314] simple-framebuffer 7e000000.framebuffer: format=x8r8g8b8, mode=1024x768x32, linelength=4096
  4716    [    6.167764] simple-framebuffer 7e000000.framebuffer: fb1: simplefb registered!
  4717    [    6.168197] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  4718    [    6.171268] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  4719    [    6.171288] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  4720    [    6.171447] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  4721    [    6.171682] dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
  4722    [    6.279422] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000)
  4723    [    6.279459] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  4724    [    6.279473] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  4725    [    6.279487] dwmac-sun8i 1c30000.ethernet: COE Type 2
  4726    [    6.279500] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  4727    [    6.279515] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  4728    [    6.279528] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  4729    [    6.279874] libphy: stmmac: probed
  4730    [    6.281397] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
  4731    [    6.281616] libphy: mdio_mux: probed
  4732    [    6.281659] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
  4733    [    6.281679] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
  4734    [    6.303863] ac200: Unknown symbol ac200_reg_mod (err -2)
  4735    [    6.303916] ac200: Unknown symbol ac200_reg_write (err -2)
  4736    [    6.306634] libphy: mdio_mux: probed
  4737    [    6.306687] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
  4738    [    6.406818] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
  4739    [    6.407064] dwmac-sun8i 1c30000.ethernet: Error: Failed to register MDIO bus for child /soc/ethernet@1c30000/mdio-mux/mdio@2
  4740    [    6.408250] ehci-platform 1c1b000.usb: EHCI Host Controller
  4741    [    6.408308] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
  4742    [    6.409240] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  4743    [    6.423021] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  4744    [    6.423458] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  4745    [    6.423477] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4746    [    6.423492] usb usb3: Product: EHCI Host Controller
  4747    [    6.423507] usb usb3: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  4748    [    6.423522] usb usb3: SerialNumber: 1c1b000.usb
  4749    [    6.424633] hub 3-0:1.0: USB hub found
  4750    [    6.424721] hub 3-0:1.0: 1 port detected
  4751    [    6.426485] ehci-platform 1c1c000.usb: EHCI Host Controller
  4752    [    6.426540] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
  4753    [    6.427078] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
  4754    [    6.443002] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
  4755    [    6.443403] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  4756    [    6.443422] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4757    [    6.443438] usb usb4: Product: EHCI Host Controller
  4758    [    6.443452] usb usb4: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  4759    [    6.443466] usb usb4: SerialNumber: 1c1c000.usb
  4760    [    6.444487] hub 4-0:1.0: USB hub found
  4761    [    6.444570] hub 4-0:1.0: 1 port detected
  4762    [    6.446217] ehci-platform 1c1d000.usb: EHCI Host Controller
  4763    [    6.446267] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
  4764    [    6.446759] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
  4765    [    6.459004] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
  4766    [    6.459407] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  4767    [    6.459426] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4768    [    6.459441] usb usb5: Product: EHCI Host Controller
  4769    [    6.459455] usb usb5: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  4770    [    6.459469] usb usb5: SerialNumber: 1c1d000.usb
  4771    [    6.460459] hub 5-0:1.0: USB hub found
  4772    [    6.460541] hub 5-0:1.0: 1 port detected
  4773    [    6.462182] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  4774    [    6.462231] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
  4775    [    6.462566] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  4776    [    6.523389] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  4777    [    6.523409] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4778    [    6.523424] usb usb6: Product: Generic Platform OHCI controller
  4779    [    6.523439] usb usb6: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  4780    [    6.523452] usb usb6: SerialNumber: 1c1b400.usb
  4781    [    6.524488] hub 6-0:1.0: USB hub found
  4782    [    6.524572] hub 6-0:1.0: 1 port detected
  4783    [    6.526227] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
  4784    [    6.526278] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
  4785    [    6.526661] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
  4786    [    6.587354] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  4787    [    6.587373] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4788    [    6.587388] usb usb7: Product: Generic Platform OHCI controller
  4789    [    6.587403] usb usb7: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  4790    [    6.587417] usb usb7: SerialNumber: 1c1c400.usb
  4791    [    6.588489] hub 7-0:1.0: USB hub found
  4792    [    6.588566] hub 7-0:1.0: 1 port detected
  4793    [    6.590201] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
  4794    [    6.590252] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
  4795    [    6.590595] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
  4796    [    6.651359] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  4797    [    6.651378] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4798    [    6.651393] usb usb8: Product: Generic Platform OHCI controller
  4799    [    6.651408] usb usb8: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  4800    [    6.651422] usb usb8: SerialNumber: 1c1d400.usb
  4801    [    6.652426] hub 8-0:1.0: USB hub found
  4802    [    6.652516] hub 8-0:1.0: 1 port detected
  4803    [    6.654281] usb_phy_generic usb_phy_generic.3.auto: usb_phy_generic.3.auto supply vcc not found, using dummy regulator
  4804    [    6.655318] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
  4805    [    6.655365] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9
  4806    [    6.655803] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  4807    [    6.655822] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4808    [    6.655837] usb usb9: Product: MUSB HDRC host driver
  4809    [    6.655852] usb usb9: Manufacturer: Linux 5.4.35-sunxi musb-hcd
  4810    [    6.655866] usb usb9: SerialNumber: musb-hdrc.4.auto
  4811    [    6.656818] hub 9-0:1.0: USB hub found
  4812    [    6.656912] hub 9-0:1.0: 1 port detected
  4813    [    6.664494] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:23 UTC (23)
  4814    [    6.664873] of_cfs_init
  4815    [    6.665087] of_cfs_init: OK
  4816    [    6.673955] Freeing unused kernel memory: 1024K
  4817    [    6.679536] Run /init as init process
  4818    [    6.871640] random: fast init done
  4819    [    7.423505] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
  4820    [    7.641582] lima 1c40000.gpu: IRQ ppmmu2 not found
  4821    [    7.641607] lima 1c40000.gpu: IRQ ppmmu3 not found
  4822    [    7.641660] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
  4823    [    7.641786] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
  4824    [    7.641930] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
  4825    [    7.642035] lima 1c40000.gpu: IRQ pp2 not found
  4826    [    7.642054] lima 1c40000.gpu: IRQ pp3 not found
  4827    [    7.642075] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
  4828    [    7.643907] lima 1c40000.gpu: bus rate = 200000000
  4829    [    7.643929] lima 1c40000.gpu: mod rate = 384000000
  4830    [    7.644887] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 1
  4831    [    7.726045] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  4832    [    7.751002] rc_core: IR keymap rc-cec not found
  4833    [    7.751018] Registered IR keymap rc-empty
  4834    [    7.751075] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
  4835    [    7.751277] rc rc0: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0
  4836    [    7.751956] input: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0/input1
  4837    [    7.783431] mmc2: new high speed SDIO card at address 0001
  4838    [    8.387816] F2FS-fs (mmcblk1p2): Found nat_bits in checkpoint
  4839    [    8.655971] F2FS-fs (mmcblk1p2): recover fsync data on readonly fs
  4840    [    8.671002] F2FS-fs (mmcblk1p2): Mounted with checkpoint version = 240c53cf
  4841    [    9.316061] systemd[1]: System time before build time, advancing clock.
  4842    [    9.360244] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  4843    [    9.361767] systemd[1]: Detected architecture arm.
  4844    [    9.414580] systemd[1]: Set hostname to <beelinkx2>.
  4845    [   10.799116] random: systemd: uninitialized urandom read (16 bytes read)
  4846    [   10.827241] random: systemd: uninitialized urandom read (16 bytes read)
  4847    [   10.828876] systemd[1]: Listening on udev Kernel Socket.
  4848    [   10.830158] random: systemd: uninitialized urandom read (16 bytes read)
  4849    [   10.839562] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  4850    [   10.842080] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  4851    [   10.845821] systemd[1]: Created slice system-serial\x2dgetty.slice.
  4852    [   10.846376] systemd[1]: Reached target Swap.
  4853    [   10.848802] systemd[1]: Listening on Journal Socket (/dev/log).
  4854    [   10.850675] systemd[1]: Listening on Journal Audit Socket.
  4855    [   12.515739] systemd-journald[317]: Received request to flush runtime journal from PID 1
  4856    [   13.210744] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
  4857    [   13.249493] cedrus 1c0e000.video-codec: Device registered as /dev/video0
  4858    [   13.612341] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  4859    [   13.838769] sun4i-codec 1c22c00.codec: Failed to register our card
  4860    [   13.852785] sun4i-codec 1c22c00.codec: Failed to register our card
  4861    [   13.872732] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  4862    [   13.874803] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  4863    [   13.874832] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
  4864    [   13.999995] Registered IR keymap rc-empty
  4865    [   14.000258] rc rc1: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1
  4866    [   14.000680] rc rc1: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
  4867    [   14.001038] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1/input2
  4868    [   14.019416] sunxi-ir 1f02000.ir: initialized sunXi IR driver
  4869    [   14.048273] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok
  4870    [   14.090442] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
  4871    [   14.096713] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
  4872    [   14.107252] bFWReady == _FALSE call reset 8051...
  4873    [   14.724723] cfg80211: failed to load regulatory.db
  4874    [   15.935825] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: commit=600,errors=remount-ro
  4875    [   15.935898] ext4 filesystem being mounted at /media/mmcboot supports timestamps until 2038 (0x7fffffff)
  4876    [   16.929621] zram: Added device: zram0
  4877    [   16.936501] zram: Added device: zram1
  4878    [   16.937858] zram: Added device: zram2
  4879    [   17.043849] zram1: detected capacity change from 0 to 506855424
  4880    [   18.155012] Adding 494972k swap on /dev/zram1.  Priority:5 extents:1 across:494972k SSFS
  4881    [   18.475192] zram0: detected capacity change from 0 to 52428800
  4882    [   19.111057] usb 6-1: new full-speed USB device number 2 using ohci-platform
  4883    [   19.348144] usb 6-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
  4884    [   19.348168] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  4885    [   19.348184] usb 6-1: Product: USB Receiver
  4886    [   19.348199] usb 6-1: Manufacturer: Logitech
  4887    [   19.364673] input: Logitech USB Receiver as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.0/0003:046D:C52B.0001/input/input3
  4888    [   19.423794] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-1c1b400.usb-1/input0
  4889    [   19.435683] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C52B.0002/input/input4
  4890    [   19.440364] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C52B.0002/input/input5
  4891    [   19.499740] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C52B.0002/input/input6
  4892    [   19.500724] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1b400.usb-1/input1
  4893    [   19.513620] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1b400.usb-1/input2
  4894    [   19.811753] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1b400.usb-1/input2
  4895    [   19.842222] random: crng init done
  4896    [   19.842241] random: 7 urandom warning(s) missed due to ratelimiting
  4897    [   19.963607] input: Logitech Unifying Device. Wireless PID:4024 Keyboard as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input8
  4898    [   19.964519] input: Logitech Unifying Device. Wireless PID:4024 Mouse as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input9
  4899    [   19.965422] input: Logitech Unifying Device. Wireless PID:4024 Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input10
  4900    [   19.966248] hid-generic 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4024] on usb-1c1b400.usb-1/input2:1
  4901    [   20.265066] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
  4902    [   20.265153] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  4903    [   20.542082] input: Logitech K400 as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input14
  4904    [   20.544668] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-1c1b400.usb-1/input2:1
  4905
  4906    ### armbian-release:
  4907
  4908    # PLEASE DO NOT EDIT THIS FILE
  4909    BOARD=orangepiplus2e
  4910    BOARD_NAME="Orange Pi+ 2E"
  4911    BOARDFAMILY=sun8i
  4912    BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin
  4913    BUILD_REPOSITORY_COMMIT=3e533c9
  4914    DISTRIBUTION_CODENAME=buster
  4915    DISTRIBUTION_STATUS=supported
  4916    VERSION=20.02.1
  4917    LINUXFAMILY=sunxi
  4918    BRANCH=current
  4919    ARCH=arm
  4920    IMAGE_TYPE=stable
  4921    BOARD_TYPE=conf
  4922    INITRD_ARCH=arm
  4923    KERNEL_IMAGE_TYPE=Image
  4924
  4925    ### boot environment:
  4926
  4927    verbosity=1
  4928    logo=disabled
  4929    console=both
  4930    disp_mode=1920x1080p60
  4931    overlay_prefix=sun8i-h3
  4932    rootdev=UUID=e4eb8394-3faa-4045-8f17-40b557e3885c
  4933    rootfstype=f2fs
  4934    usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  4935
  4936    ### lsusb:
  4937
  4938    Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4939    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4940    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4941    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4942    Bus 006 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
  4943    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4944    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4945    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4946    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4947    Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4948
  4949    ### lscpu:
  4950
  4951    Architecture:        armv7l
  4952    Byte Order:          Little Endian
  4953    CPU(s):              4
  4954    On-line CPU(s) list: 0-3
  4955    Thread(s) per core:  1
  4956    Core(s) per socket:  4
  4957    Socket(s):           1
  4958    Vendor ID:           ARM
  4959    Model:               5
  4960    Model name:          Cortex-A7
  4961    Stepping:            r0p5
  4962    BogoMIPS:            48.00
  4963    Flags:               half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  4964
  4965    ### cpuinfo:
  4966
  4967    processor    : 0
  4968    model name    : ARMv7 Processor rev 5 (v7l)
  4969    BogoMIPS    : 48.00
  4970    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  4971    CPU implementer    : 0x41
  4972    CPU architecture: 7
  4973    CPU variant    : 0x0
  4974    CPU part    : 0xc07
  4975    CPU revision    : 5
  4976
  4977    processor    : 1
  4978    model name    : ARMv7 Processor rev 5 (v7l)
  4979    BogoMIPS    : 48.00
  4980    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  4981    CPU implementer    : 0x41
  4982    CPU architecture: 7
  4983    CPU variant    : 0x0
  4984    CPU part    : 0xc07
  4985    CPU revision    : 5
  4986
  4987    processor    : 2
  4988    model name    : ARMv7 Processor rev 5 (v7l)
  4989    BogoMIPS    : 48.00
  4990    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  4991    CPU implementer    : 0x41
  4992    CPU architecture: 7
  4993    CPU variant    : 0x0
  4994    CPU part    : 0xc07
  4995    CPU revision    : 5
  4996
  4997    processor    : 3
  4998    model name    : ARMv7 Processor rev 5 (v7l)
  4999    BogoMIPS    : 48.00
  5000    Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
  5001    CPU implementer    : 0x41
  5002    CPU architecture: 7
  5003    CPU variant    : 0x0
  5004    CPU part    : 0xc07
  5005    CPU revision    : 5
  5006
  5007    Hardware    : Allwinner sun8i Family
  5008    Revision    : 0000
  5009    Serial        : 02c00081bd8e203d
  5010
  5011    ### meminfo:
  5012
  5013    MemTotal:         989948 kB
  5014    MemFree:          841544 kB
  5015    MemAvailable:     898360 kB
  5016    Buffers:            2228 kB
  5017    Cached:            61484 kB
  5018    SwapCached:            0 kB
  5019    Active:            41404 kB
  5020    Inactive:          34340 kB
  5021    Active(anon):      14188 kB
  5022    Inactive(anon):     1796 kB
  5023    Active(file):      27216 kB
  5024    Inactive(file):    32544 kB
  5025    Unevictable:        1936 kB
  5026    Mlocked:               0 kB
  5027    HighTotal:        229364 kB
  5028    HighFree:         140768 kB
  5029    LowTotal:         760584 kB
  5030    LowFree:          700776 kB
  5031    SwapTotal:        494972 kB
  5032    SwapFree:         494972 kB
  5033    Dirty:              2692 kB
  5034    Writeback:           676 kB
  5035    AnonPages:         13964 kB
  5036    Mapped:            19868 kB
  5037    Shmem:              2004 kB
  5038    KReclaimable:      15036 kB
  5039    Slab:              40580 kB
  5040    SReclaimable:      15036 kB
  5041    SUnreclaim:        25544 kB
  5042    KernelStack:        1112 kB
  5043    PageTables:          872 kB
  5044    NFS_Unstable:          0 kB
  5045    Bounce:                0 kB
  5046    WritebackTmp:          0 kB
  5047    CommitLimit:      989944 kB
  5048    Committed_AS:      55184 kB
  5049    VmallocTotal:     245760 kB
  5050    VmallocUsed:       15924 kB
  5051    VmallocChunk:          0 kB
  5052    Percpu:              752 kB
  5053    CmaTotal:         131072 kB
  5054    CmaFree:          122124 kB
  5055
  5056    ### virtual memory:
  5057
  5058    vm.admin_reserve_kbytes = 8192
  5059    vm.block_dump = 0
  5060    vm.compact_unevictable_allowed = 1
  5061    vm.dirty_background_bytes = 0
  5062    vm.dirty_background_ratio = 10
  5063    vm.dirty_bytes = 0
  5064    vm.dirty_expire_centisecs = 3000
  5065    vm.dirty_ratio = 20
  5066    vm.dirtytime_expire_seconds = 43200
  5067    vm.dirty_writeback_centisecs = 500
  5068    vm.extfrag_threshold = 500
  5069    vm.highmem_is_dirtyable = 0
  5070    vm.laptop_mode = 0
  5071    vm.legacy_va_layout = 0
  5072    vm.lowmem_reserve_ratio = 32    0    0
  5073    vm.max_map_count = 65530
  5074    vm.min_free_kbytes = 3459
  5075    vm.mmap_min_addr = 4096
  5076    vm.mmap_rnd_bits = 8
  5077    vm.oom_dump_tasks = 1
  5078    vm.oom_kill_allocating_task = 0
  5079    vm.overcommit_kbytes = 0
  5080    vm.overcommit_memory = 0
  5081    vm.overcommit_ratio = 50
  5082    vm.page-cluster = 0
  5083    vm.panic_on_oom = 0
  5084    vm.percpu_pagelist_fraction = 0
  5085    vm.stat_interval = 1
  5086    vm.swappiness = 100
  5087    vm.user_reserve_kbytes = 30420
  5088    vm.vfs_cache_pressure = 100
  5089    vm.watermark_boost_factor = 15000
  5090    vm.watermark_scale_factor = 10
  5091
  5092    ### ip addr:
  5093
  5094    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  5095        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  5096        inet XXX.XXX.0.1/8 scope host lo
  5097           valid_lft forever preferred_lft forever
  5098        inet6 ::1/128 scope host
  5099           valid_lft forever preferred_lft forever
  5100    2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  5101        link/ether 02:81:bd:8e:20:3d brd ff:ff:ff:ff:ff:ff
  5102    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  5103        link/ether cc:79:cf:54:c5:4a brd ff:ff:ff:ff:ff:ff
  5104
  5105    ### partitions:
  5106
  5107    major minor  #blocks  name
  5108
  5109     179        0    7570432 mmcblk1
  5110     179        1      98304 mmcblk1p1
  5111     179        2    7392320 mmcblk1p2
  5112     254        0      51200 zram0
  5113     254        1     494976 zram1
  5114
  5115    ### df:
  5116
  5117    udev             414M      0  414M   0% /dev
  5118    tmpfs             97M   3,3M   94M   4% /run
  5119    /dev/mmcblk1p2   7,1G   4,2G  2,9G  60% /
  5120    tmpfs            484M      0  484M   0% /dev/shm
  5121    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  5122    tmpfs            484M      0  484M   0% /sys/fs/cgroup
  5123    tmpfs            484M   8,0K  484M   1% /tmp
  5124    /dev/mmcblk1p1    89M    40M   43M  48% /media/mmcboot
  5125    /dev/zram0        49M   4,0M   41M   9% /var/log
  5126
  5127    ### lsblk:
  5128
  5129    NAME         FSTYPE   SIZE MOUNTPOINT     UUID
  5130    mmcblk1               7,2G
  5131    ├─mmcblk1p1  ext4      96M /media/mmcboot 1903597c-c143-4430-bbb1-077aebbaf563
  5132    └─mmcblk1p2  f2fs     7,1G /              e4eb8394-3faa-4045-8f17-40b557e3885c
  5133    mmcblk1boot0            4M
  5134    mmcblk1boot1            4M
  5135    zram0                  50M /var/log
  5136
  5137    ### zramctl:
  5138
  5139    NAME       ALGORITHM DISKSIZE DATA  COMPR TOTAL STREAMS MOUNTPOINT
  5140    /dev/zram1 lzo         483,4M   4K    76B    4K       4 [SWAP]
  5141    /dev/zram0 zstd           50M   4M 780,8K  1,1M       4 /var/log
  5142
  5143    ### mtab:
  5144
  5145    /dev/mmcblk1p1 /boot ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5146    /dev/mmcblk1p1 /media/mmcboot ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5147    /dev/mmcblk1p2 / f2fs rw,lazytime,noatime,nodiratime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=default,fsync_mode=posix 0 0
  5148    /dev/mmcblk1p2 /var/log.hdd f2fs rw,lazytime,noatime,nodiratime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=default,fsync_mode=posix 0 0
  5149    /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
  5150
  5151    ### mmc1:0001 info:
  5152
  5153                  manfid: 0x000088
  5154                     cid: 8801034e436172642026e16382562375
  5155                   fwrev: 0x0000000000000000
  5156                     rca: 0x0001
  5157                     csd: d0ffff320f5903ffffffffe7964000eb
  5158               life_time: 0x01 0x01
  5159                     ocr: 0x00200000
  5160                    type: MMC
  5161    enhanced_area_offset: 18446744073709551594
  5162                    date: 02/2016
  5163                   hwrev: 0x0
  5164                     prv: 0x26
  5165                     dsr: 0x404
  5166             ffu_capable: 1
  5167                  serial: 0xe1638256
  5168      raw_rpmb_size_mult: 0x20
  5169              erase_size: 524288
  5170            pre_eol_info: 0x01
  5171             rel_sectors: 0x1
  5172                 cmdq_en: 0
  5173                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=NCard  MODALIAS=mmc:block
  5174      enhanced_area_size: 4294967274
  5175                   oemid: 0x0103
  5176                     rev: 0x7
  5177    preferred_erase_size: 4194304
  5178                    name: NCard
  5179
  5180    ### Boot system health:
  5181
  5182    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  5183    21:24:00:   ---      2.01  58%  31%  26%   0%   0%   0% 41.2°C
  5184    21:24:01:   ---      2.17  54%  17%  34%   2%   0%   0% 40.6°C
  5185    21:24:01:   ---      2.17  58%  24%  31%   1%   0%   0% 41.3°C
  5186    21:24:02:   ---      2.17  64%  36%  25%   3%   0%   0% 41.9°C
  5187    21:24:03:   ---      2.17  88%  34%  50%   2%   0%   0% 41.9°C
  5188
  5189    ### lsusb:
  5190
  5191    Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  5192    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5193    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  5194    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5195    Bus 006 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
  5196    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  5197    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5198    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  5199    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5200    Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5201
  5202    /:  Bus 09.Port 1: Dev 1, Class=root_hub, Driver=musb-hdrc/1p, 480M
  5203    /:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  5204    /:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  5205    /:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  5206        |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
  5207        |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
  5208        |__ Port 1: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M
  5209    /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  5210    /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  5211    /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  5212    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  5213    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  5214
  5215    ### Installed packages:
  5216
  5217    ii  armbian-buster-desktop                   20.05.0-trunk                            all          Armbian desktop for Debian buster
  5218    ii  armbian-config                           20.02.16                                 all          Armbian configuration utility
  5219    ii  armbian-firmware                         20.05.0-trunk                            all          Linux firmware
  5220    ii  hostapd                                  3:2.9-101~armbian20.05.1+1               armhf        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
  5221    ii  htop                                     2.2.0-3~armbian5.92+1                    armhf        interactive processes viewer
  5222    ii  linux-base                               4.6                                      all          Linux image base package
  5223    ii  linux-buster-root-current-orangepiplus2e 20.02.1                                  armhf        Armbian tweaks for buster on orangepiplus2e (current branch)
  5224    ii  linux-dtb-current-sunxi                  20.05.0-trunk                            armhf        Linux DTB, version 5.4.35-sunxi
  5225    ii  linux-image-current-sunxi                20.05.0-trunk                            armhf        Linux kernel, version 5.4.35-sunxi
  5226    ii  linux-libc-dev:armhf                     4.19.118-2                               armhf        Linux support headers for userspace development
  5227    ii  linux-u-boot-orangepiplus2e-current      20.02.1                                  armhf        Uboot loader 2019.10
  5228
  5229    ### Loaded modules:
  5230
  5231    Module                  Size  Used by
  5232    fuse                   81920  3
  5233    hid_logitech_hidpp     32768  0
  5234    input_leds             16384  0
  5235    hid_logitech_dj        20480  0
  5236    zram                   24576  2
  5237    8189es                868352  0
  5238    sunxi_cir              16384  0
  5239    sun8i_codec_analog     24576  1
  5240    sun8i_adda_pr_regmap    16384  1 sun8i_codec_analog
  5241    snd_soc_simple_card    16384  2
  5242    snd_soc_simple_card_utils    16384  1 snd_soc_simple_card
  5243    sun4i_i2s              24576  2
  5244    sun4i_gpadc_iio        16384  0
  5245    sun4i_codec            40960  3
  5246    snd_soc_hdmi_codec     16384  1
  5247    industrialio           49152  1 sun4i_gpadc_iio
  5248    snd_soc_core          118784  6 sun4i_codec,sun4i_i2s,sun8i_codec_analog,snd_soc_hdmi_codec,snd_soc_simple_card_utils,snd_soc_simple_card
  5249    snd_pcm_dmaengine      16384  1 snd_soc_core
  5250    snd_pcm                65536  5 sun4i_codec,sun4i_i2s,snd_pcm_dmaengine,snd_soc_hdmi_codec,snd_soc_core
  5251    sun8i_thermal          16384  0
  5252    snd_timer              24576  1 snd_pcm
  5253    snd                    45056  14 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm
  5254    soundcore              16384  1 snd
  5255    cfg80211              425984  1 8189es
  5256    rfkill                 20480  3 cfg80211
  5257    sunxi_cedrus           32768  0
  5258    v4l2_mem2mem           20480  1 sunxi_cedrus
  5259    evdev                  20480  6
  5260    uio_pdrv_genirq        16384  0
  5261    uio                    16384  1 uio_pdrv_genirq
  5262    cpufreq_dt             16384  0
  5263    ip_tables              24576  0
  5264    x_tables               20480  1 ip_tables
  5265    pwrseq_simple          16384  1
  5266    sy8106a_regulator      16384  0
  5267    lima                   36864  0
  5268    dw_hdmi_i2s_audio      16384  0
  5269    dw_hdmi_cec            16384  0
  5270    gpu_sched              24576  1 lima
  5271    gpio_keys              20480  0
  5272
  5273    ### nand-sata-install.log:
  5274
  5275    vie may 15 20:31:24 CEST 2020: Start nand-sata-install.
  5276
  5277
  5278        F2FS-tools: mkfs.f2fs Ver: 1.11.0 (2018-07-10)
  5279
  5280    Info: Disable heap-based policy
  5281    Info: Debug level = 0
  5282    Info: Label =
  5283    Info: Trim is enabled
  5284    Info: Segments per section = 1
  5285    Info: Sections per zone = 1
  5286    Info: sector size = 512
  5287    Info: total sectors = 14784640 (7219 MB)
  5288    Info: zone aligned segment0 blkaddr: 512
  5289    Info: format version with
  5290      "Linux version 5.4.20-sunxi (root@builder) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #20.02.1 SMP Mon Feb 17 02:09:41 CET 2020"
  5291    Info: [/dev/mmcblk1p2] Discarding device
  5292    Info: Secure Discarded 0 MB
  5293    Info: Overprovision ratio = 2.370%
  5294    Info: Overprovision segments = 174 (GC reserved = 92)
  5295    Info: format successful
  5296
  5297    Old UUID:  UUID=f972992c-598b-42c9-a9a0-e82ba21ecd3f
  5298    SD UUID:   UUID=f972992c-598b-42c9-a9a0-e82ba21ecd3f
  5299    UUID=1903597c-c143-4430-bbb1-077aebbaf563
  5300    SATA UUID: UUID=e4eb8394-3faa-4045-8f17-40b557e3885c
  5301    eMMC UUID: UUID=e4eb8394-3faa-4045-8f17-40b557e3885c f2fs
  5302    Boot: $1 /dev/mmcblk1p1 f2fs
  5303    Root: $2 /dev/mmcblk1p2
  5304    Usage: 980
  5305    Dest: 6812
  5306
  5307    /etc/fstab:
  5308    UUID=f972992c-598b-42c9-a9a0-e82ba21ecd3f / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
  5309    tmpfs /tmp tmpfs defaults,nosuid 0 0
  5310
  5311    /etc/mtab:
  5312    /dev/mmcblk0p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5313    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5314    /dev/mmcblk1p1 /mnt/nand-sata-install.JMe8tK/bootfs ext4 rw,relatime 0 0
  5315    /dev/mmcblk1p2 /mnt/nand-sata-install.JMe8tK/rootfs f2fs rw,lazytime,relatime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=reuse,fsync_mode=posix 0 0
  5316    /dev/zram0 /var/log ext4 rw,relatime,discard 0 0
  5317
  5318    Files currently open for writing:
  5319    dhclient  1345       root    4w   REG  179,1     1093  37205 /var/lib/NetworkManager/dhclient-c6657daf-b5be-4bec-aeda-3ce3287ea699-wlan0.lease
  5320    dhclient  1470       root    4w   REG  179,1     1294  37207 /var/lib/NetworkManager/dhclient6-c6657daf-b5be-4bec-aeda-3ce3287ea699-wlan0.lease
  5321
  5322    Trying to stop running services to minimize open files:
  5323    Stopping cron.service
  5324
  5325    Checking again for open files:
  5326
  5327    Copying 37292 files to /dev/mmcblk1p2. Finishing full install to eMMC.
  5328
  5329    Checking again for open files:
  5330
  5331    vie may 15 20:34:51 CEST 2020: Finished
  5332
  5333    ### Current system health:
  5334
  5335    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  5336    23:45:39:   ---      1.57  47%  11%  33%   0%   0%   0% 46.5°C
  5337    23:45:40:   ---      1.57   9%   6%   0%   2%   0%   0% 46.0°C
  5338    23:45:40:   ---      1.57   9%   6%   0%   3%   0%   0% 46.0°C
  5339    23:45:41:   ---      1.57  49%   6%  36%   6%   0%   0% 47.5°C
  5340    23:45:41:   ---      1.57  64%   9%  51%   3%   0%   0% 47.5°C
  5341    23:45:45:   ---      1.85  47%  11%  34%   0%   0%   0% 48.4°C
  5342    23:45:45:   ---      1.85   9%   7%   0%   2%   0%   0% 46.9°C
  5343    23:45:46:   ---      1.85  45%   7%  34%   3%   0%   0% 47.3°C
  5344    23:45:46:   ---      1.85  59%   9%  47%   3%   0%   0% 47.6°C
  5345    23:45:47:   ---      1.85  31%   9%  17%   4%   0%   0% 47.3°C
  5346
  5347    ### resolv.conf
  5348
  5349    -rw-r--r-- 1 root root 93 may 16 21:24 /etc/resolv.conf
  5350    # Generated by NetworkManager
  5351    search lan
  5352    nameserver XXX.XXX.1.1
  5353    nameserver fdb5:bca2:cc37::1
  5354
  5355    ### Current sysinfo:
  5356
  5357    Linux 5.4.35-sunxi (beelinkx2)     18/05/20     _armv7l_    (4 CPU)
  5358
  5359    avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  5360              34,42    0,96   11,92    0,19    0,00   52,51
  5361
  5362    Device             tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
  5363    ram0              0,00         0,00         0,00          0          0
  5364    ram1              0,00         0,00         0,00          0          0
  5365    ram2              0,00         0,00         0,00          0          0
  5366    ram3              0,00         0,00         0,00          0          0
  5367    mmcblk1          56,93      1411,52       101,86     380333      27447
  5368    mmcblk1p1         0,56        15,77         0,13       4249         35
  5369    mmcblk1p2        55,83      1384,11       101,73     372948      27412
  5370    mmcblk1boot1      0,22         0,86         0,00        232          0
  5371    mmcblk1boot0      0,22         0,86         0,00        232          0
  5372    zram0            11,03        11,07        33,06       2984       8908
  5373    zram1             1,11         4,44         0,01       1196          4
  5374    zram2             0,00         0,00         0,00          0          0
  5375
  5376    procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
  5377     r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
  5378     0  0            0        72224         2228       476536    0    0   358    34  359  457  35  12  53   0   0
  5379
  5380                  total        used        free      shared  buff/cache   available
  5381    Mem:          966Mi       428Mi        70Mi        88Mi       467Mi       427Mi
  5382    Swap:         483Mi          0B       483Mi
  5383
  5384    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  5385    /dev/zram1 lzo         483,4M    4K    76B    4K       4 [SWAP]
  5386    /dev/zram0 zstd           50M  3,9M 759,1K  1,1M       4 /var/log
  5387
  5388     23:45:47 up 4 min,  1 user,  load average: 1,85, 1,62, 0,75
  5389
  5390    [    5.852624] hub 2-0:1.0: USB hub found
  5391    [    5.852720] hub 2-0:1.0: 1 port detected
  5392    [    5.855612] usbcore: registered new interface driver usb-storage
  5393    [    5.858584] sun6i-rtc 1f00000.rtc: registered as rtc0
  5394    [    5.858600] sun6i-rtc 1f00000.rtc: RTC enabled
  5395    [    5.859362] i2c /dev entries driver
  5396    [    5.860133] sun8i-h3-r-pinctrl 1f02c00.pinctrl: 1f02c00.pinctrl supply vcc-pl not found, using dummy regulator
  5397    [    5.864375] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  5398    [    5.865694] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
  5399    [    5.867107] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  5400    [    5.891637] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
  5401    [    5.892133] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  5402    [    5.894208] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
  5403    [    5.919018] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
  5404    [    5.921567] ledtrig-cpu: registered to indicate activity on CPUs
  5405    [    5.921755] hidraw: raw HID events driver (C) Jiri Kosina
  5406    [    5.922001] usbcore: registered new interface driver usbhid
  5407    [    5.922008] usbhid: USB HID core driver
  5408    [    5.925826] Initializing XFRM netlink socket
  5409    [    5.927200] NET: Registered protocol family 10
  5410    [    6.063888] Segment Routing with IPv6
  5411    [    6.064098] NET: Registered protocol family 17
  5412    [    6.064150] NET: Registered protocol family 15
  5413    [    6.064269] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  5414    [    6.064618] 8021q: 802.1Q VLAN Support v1.8
  5415    [    6.064724] Key type dns_resolver registered
  5416    [    6.065796] Registering SWP/SWPB emulation handler
  5417    [    6.066337] registered taskstats version 1
  5418    [    6.066346] Loading compiled-in X.509 certificates
  5419    [    6.066516] zswap: loaded using pool lzo/zbud
  5420    [    6.067166] Key type ._fscrypt registered
  5421    [    6.067175] Key type .fscrypt registered
  5422    [    6.073129] Btrfs loaded, crc32c=crc32c-generic
  5423    [    6.079132] mmc1: new DDR MMC card at address 0001
  5424    [    6.081068] mmcblk1: mmc1:0001 NCard  7.22 GiB
  5425    [    6.081986] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
  5426    [    6.082850] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
  5427    [    6.086304]  mmcblk1: p1 p2
  5428    [    6.142211] Key type encrypted registered
  5429    [    6.166302] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
  5430    [    6.167290] simple-framebuffer 7e000000.framebuffer: framebuffer at 0x7e000000, 0x300000 bytes, mapped to 0x(ptrval)
  5431    [    6.167314] simple-framebuffer 7e000000.framebuffer: format=x8r8g8b8, mode=1024x768x32, linelength=4096
  5432    [    6.167764] simple-framebuffer 7e000000.framebuffer: fb1: simplefb registered!
  5433    [    6.168197] sun8i-h3-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
  5434    [    6.171268] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  5435    [    6.171288] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  5436    [    6.171447] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  5437    [    6.171682] dwmac-sun8i 1c30000.ethernet: 1c30000.ethernet supply phy-io not found, using dummy regulator
  5438    [    6.279422] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 50006 (expect 58000)
  5439    [    6.279459] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  5440    [    6.279473] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  5441    [    6.279487] dwmac-sun8i 1c30000.ethernet: COE Type 2
  5442    [    6.279500] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  5443    [    6.279515] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  5444    [    6.279528] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  5445    [    6.279874] libphy: stmmac: probed
  5446    [    6.281397] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
  5447    [    6.281616] libphy: mdio_mux: probed
  5448    [    6.281659] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
  5449    [    6.281679] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
  5450    [    6.303863] ac200: Unknown symbol ac200_reg_mod (err -2)
  5451    [    6.303916] ac200: Unknown symbol ac200_reg_write (err -2)
  5452    [    6.306634] libphy: mdio_mux: probed
  5453    [    6.306687] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
  5454    [    6.406818] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
  5455    [    6.407064] dwmac-sun8i 1c30000.ethernet: Error: Failed to register MDIO bus for child /soc/ethernet@1c30000/mdio-mux/mdio@2
  5456    [    6.408250] ehci-platform 1c1b000.usb: EHCI Host Controller
  5457    [    6.408308] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
  5458    [    6.409240] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  5459    [    6.423021] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  5460    [    6.423458] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  5461    [    6.423477] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5462    [    6.423492] usb usb3: Product: EHCI Host Controller
  5463    [    6.423507] usb usb3: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  5464    [    6.423522] usb usb3: SerialNumber: 1c1b000.usb
  5465    [    6.424633] hub 3-0:1.0: USB hub found
  5466    [    6.424721] hub 3-0:1.0: 1 port detected
  5467    [    6.426485] ehci-platform 1c1c000.usb: EHCI Host Controller
  5468    [    6.426540] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
  5469    [    6.427078] ehci-platform 1c1c000.usb: irq 32, io mem 0x01c1c000
  5470    [    6.443002] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
  5471    [    6.443403] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  5472    [    6.443422] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5473    [    6.443438] usb usb4: Product: EHCI Host Controller
  5474    [    6.443452] usb usb4: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  5475    [    6.443466] usb usb4: SerialNumber: 1c1c000.usb
  5476    [    6.444487] hub 4-0:1.0: USB hub found
  5477    [    6.444570] hub 4-0:1.0: 1 port detected
  5478    [    6.446217] ehci-platform 1c1d000.usb: EHCI Host Controller
  5479    [    6.446267] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
  5480    [    6.446759] ehci-platform 1c1d000.usb: irq 34, io mem 0x01c1d000
  5481    [    6.459004] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
  5482    [    6.459407] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  5483    [    6.459426] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5484    [    6.459441] usb usb5: Product: EHCI Host Controller
  5485    [    6.459455] usb usb5: Manufacturer: Linux 5.4.35-sunxi ehci_hcd
  5486    [    6.459469] usb usb5: SerialNumber: 1c1d000.usb
  5487    [    6.460459] hub 5-0:1.0: USB hub found
  5488    [    6.460541] hub 5-0:1.0: 1 port detected
  5489    [    6.462182] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  5490    [    6.462231] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
  5491    [    6.462566] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  5492    [    6.523389] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  5493    [    6.523409] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5494    [    6.523424] usb usb6: Product: Generic Platform OHCI controller
  5495    [    6.523439] usb usb6: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  5496    [    6.523452] usb usb6: SerialNumber: 1c1b400.usb
  5497    [    6.524488] hub 6-0:1.0: USB hub found
  5498    [    6.524572] hub 6-0:1.0: 1 port detected
  5499    [    6.526227] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
  5500    [    6.526278] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
  5501    [    6.526661] ohci-platform 1c1c400.usb: irq 33, io mem 0x01c1c400
  5502    [    6.587354] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  5503    [    6.587373] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5504    [    6.587388] usb usb7: Product: Generic Platform OHCI controller
  5505    [    6.587403] usb usb7: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  5506    [    6.587417] usb usb7: SerialNumber: 1c1c400.usb
  5507    [    6.588489] hub 7-0:1.0: USB hub found
  5508    [    6.588566] hub 7-0:1.0: 1 port detected
  5509    [    6.590201] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
  5510    [    6.590252] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
  5511    [    6.590595] ohci-platform 1c1d400.usb: irq 35, io mem 0x01c1d400
  5512    [    6.651359] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.04
  5513    [    6.651378] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5514    [    6.651393] usb usb8: Product: Generic Platform OHCI controller
  5515    [    6.651408] usb usb8: Manufacturer: Linux 5.4.35-sunxi ohci_hcd
  5516    [    6.651422] usb usb8: SerialNumber: 1c1d400.usb
  5517    [    6.652426] hub 8-0:1.0: USB hub found
  5518    [    6.652516] hub 8-0:1.0: 1 port detected
  5519    [    6.654281] usb_phy_generic usb_phy_generic.3.auto: usb_phy_generic.3.auto supply vcc not found, using dummy regulator
  5520    [    6.655318] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
  5521    [    6.655365] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9
  5522    [    6.655803] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
  5523    [    6.655822] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5524    [    6.655837] usb usb9: Product: MUSB HDRC host driver
  5525    [    6.655852] usb usb9: Manufacturer: Linux 5.4.35-sunxi musb-hcd
  5526    [    6.655866] usb usb9: SerialNumber: musb-hdrc.4.auto
  5527    [    6.656818] hub 9-0:1.0: USB hub found
  5528    [    6.656912] hub 9-0:1.0: 1 port detected
  5529    [    6.664494] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T00:00:23 UTC (23)
  5530    [    6.664873] of_cfs_init
  5531    [    6.665087] of_cfs_init: OK
  5532    [    6.673955] Freeing unused kernel memory: 1024K
  5533    [    6.679536] Run /init as init process
  5534    [    6.871640] random: fast init done
  5535    [    7.423505] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
  5536    [    7.641582] lima 1c40000.gpu: IRQ ppmmu2 not found
  5537    [    7.641607] lima 1c40000.gpu: IRQ ppmmu3 not found
  5538    [    7.641660] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
  5539    [    7.641786] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
  5540    [    7.641930] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
  5541    [    7.642035] lima 1c40000.gpu: IRQ pp2 not found
  5542    [    7.642054] lima 1c40000.gpu: IRQ pp3 not found
  5543    [    7.642075] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
  5544    [    7.643907] lima 1c40000.gpu: bus rate = 200000000
  5545    [    7.643929] lima 1c40000.gpu: mod rate = 384000000
  5546    [    7.644887] [drm] Initialized lima 1.0.0 20190217 for 1c40000.gpu on minor 1
  5547    [    7.726045] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  5548    [    7.751002] rc_core: IR keymap rc-cec not found
  5549    [    7.751018] Registered IR keymap rc-empty
  5550    [    7.751075] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
  5551    [    7.751277] rc rc0: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0
  5552    [    7.751956] input: dw_hdmi as /devices/platform/soc/1ee0000.hdmi/rc/rc0/input1
  5553    [    7.783431] mmc2: new high speed SDIO card at address 0001
  5554    [    8.387816] F2FS-fs (mmcblk1p2): Found nat_bits in checkpoint
  5555    [    8.655971] F2FS-fs (mmcblk1p2): recover fsync data on readonly fs
  5556    [    8.671002] F2FS-fs (mmcblk1p2): Mounted with checkpoint version = 240c53cf
  5557    [    9.316061] systemd[1]: System time before build time, advancing clock.
  5558    [    9.360244] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  5559    [    9.361767] systemd[1]: Detected architecture arm.
  5560    [    9.414580] systemd[1]: Set hostname to <beelinkx2>.
  5561    [   10.799116] random: systemd: uninitialized urandom read (16 bytes read)
  5562    [   10.827241] random: systemd: uninitialized urandom read (16 bytes read)
  5563    [   10.828876] systemd[1]: Listening on udev Kernel Socket.
  5564    [   10.830158] random: systemd: uninitialized urandom read (16 bytes read)
  5565    [   10.839562] systemd[1]: Created slice system-systemd-fsck.slice.
  5566    [   10.842080] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  5567    [   10.845821] systemd[1]: Created slice system-serial-getty.slice.
  5568    [   10.846376] systemd[1]: Reached target Swap.
  5569    [   10.848802] systemd[1]: Listening on Journal Socket (/dev/log).
  5570    [   10.850675] systemd[1]: Listening on Journal Audit Socket.
  5571    [   12.515739] systemd-journald[317]: Received request to flush runtime journal from PID 1
  5572    [   13.210744] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
  5573    [   13.249493] cedrus 1c0e000.video-codec: Device registered as /dev/video0
  5574    [   13.612341] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  5575    [   13.838769] sun4i-codec 1c22c00.codec: Failed to register our card
  5576    [   13.852785] sun4i-codec 1c22c00.codec: Failed to register our card
  5577    [   13.872732] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  5578    [   13.874803] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  5579    [   13.874832] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
  5580    [   13.999995] Registered IR keymap rc-empty
  5581    [   14.000258] rc rc1: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1
  5582    [   14.000680] rc rc1: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
  5583    [   14.001038] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc1/input2
  5584    [   14.019416] sunxi-ir 1f02000.ir: initialized sunXi IR driver
  5585    [   14.048273] asoc-simple-card sound: i2s-hifi <-> 1c22800.i2s mapping ok
  5586    [   14.090442] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
  5587    [   14.096713] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
  5588    [   14.107252] bFWReady == _FALSE call reset 8051...
  5589    [   14.724723] cfg80211: failed to load regulatory.db
  5590    [   15.935825] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: commit=600,errors=remount-ro
  5591    [   15.935898] ext4 filesystem being mounted at /media/mmcboot supports timestamps until 2038 (0x7fffffff)
  5592    [   16.929621] zram: Added device: zram0
  5593    [   16.936501] zram: Added device: zram1
  5594    [   16.937858] zram: Added device: zram2
  5595    [   17.043849] zram1: detected capacity change from 0 to 506855424
  5596    [   18.155012] Adding 494972k swap on /dev/zram1.  Priority:5 extents:1 across:494972k SSFS
  5597    [   18.475192] zram0: detected capacity change from 0 to 52428800
  5598    [   19.111057] usb 6-1: new full-speed USB device number 2 using ohci-platform
  5599    [   19.348144] usb 6-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.03
  5600    [   19.348168] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  5601    [   19.348184] usb 6-1: Product: USB Receiver
  5602    [   19.348199] usb 6-1: Manufacturer: Logitech
  5603    [   19.364673] input: Logitech USB Receiver as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.0/0003:046D:C52B.0001/input/input3
  5604    [   19.423794] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-1c1b400.usb-1/input0
  5605    [   19.435683] input: Logitech USB Receiver Mouse as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C52B.0002/input/input4
  5606    [   19.440364] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C52B.0002/input/input5
  5607    [   19.499740] input: Logitech USB Receiver System Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:046D:C52B.0002/input/input6
  5608    [   19.500724] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-1c1b400.usb-1/input1
  5609    [   19.513620] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1b400.usb-1/input2
  5610    [   19.811753] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-1c1b400.usb-1/input2
  5611    [   19.842222] random: crng init done
  5612    [   19.842241] random: 7 urandom warning(s) missed due to ratelimiting
  5613    [   19.963607] input: Logitech Unifying Device. Wireless PID:4024 Keyboard as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input8
  5614    [   19.964519] input: Logitech Unifying Device. Wireless PID:4024 Mouse as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input9
  5615    [   19.965422] input: Logitech Unifying Device. Wireless PID:4024 Consumer Control as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input10
  5616    [   19.966248] hid-generic 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4024] on usb-1c1b400.usb-1/input2:1
  5617    [   20.265066] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
  5618    [   20.265153] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  5619    [   20.542082] input: Logitech K400 as /devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input14
  5620    [   20.544668] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-1c1b400.usb-1/input2:1
  5621    [   36.730493] dwmac-sun8i 1c30000.ethernet eth0: no phy at addr -1
  5622    [   36.730525] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
  5623    [   37.799002] dwmac-sun8i 1c30000.ethernet eth0: no phy at addr -1
  5624    [   37.799127] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
  5625    [   37.883226] vcc3v0: disabling
  5626    [   37.883263] vcc5v0: disabling
  5627    [   37.883284] usb0-vbus: disabling
  5628    [   38.103175] dwmac-sun8i 1c30000.ethernet eth0: no phy at addr -1
  5629    [   38.103206] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
  5630    [   38.191733] dwmac-sun8i 1c30000.ethernet eth0: no phy at addr -1
  5631    [   38.191763] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
  5632    [   38.268114] dwmac-sun8i 1c30000.ethernet eth0: no phy at addr -1
  5633    [   38.268147] dwmac-sun8i 1c30000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
  5634    [   38.405541] broken atomic modeset userspace detected, disabling atomic
  5635    [   41.369226] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
  5636    [   47.569056] fuse: init (API version 7.31)
  5637    [   47.569458] *** VALIDATE fuse ***
  5638    [   47.569507] *** VALIDATE fuse ***
  5639    [   54.286339] logitech-hidpp-device 0003:046D:4024.0004: HID++ 2.0 device connected.
  5640
  5641
  5642    vm.admin_reserve_kbytes = 8192
  5643    vm.block_dump = 0
  5644    vm.compact_unevictable_allowed = 1
  5645    vm.dirty_background_bytes = 0
  5646    vm.dirty_background_ratio = 10
  5647    vm.dirty_bytes = 0
  5648    vm.dirty_expire_centisecs = 3000
  5649    vm.dirty_ratio = 20
  5650    vm.dirtytime_expire_seconds = 43200
  5651    vm.dirty_writeback_centisecs = 500
  5652    vm.extfrag_threshold = 500
  5653    vm.highmem_is_dirtyable = 0
  5654    vm.laptop_mode = 0
  5655    vm.legacy_va_layout = 0
  5656    vm.lowmem_reserve_ratio = 32    0    0
  5657    vm.max_map_count = 65530
  5658    vm.min_free_kbytes = 3459
  5659    vm.mmap_min_addr = 4096
  5660    vm.oom_dump_tasks = 1
  5661    vm.oom_kill_allocating_task = 0
  5662    vm.overcommit_kbytes = 0
  5663    vm.overcommit_memory = 0
  5664    vm.overcommit_ratio = 50
  5665    vm.page-cluster = 0
  5666    vm.panic_on_oom = 0
  5667    vm.percpu_pagelist_fraction = 0
  5668    vm.stat_interval = 1
  5669    vm.swappiness = 100
  5670    vm.user_reserve_kbytes = 30420
  5671    vm.vfs_cache_pressure = 100
  5672    vm.watermark_boost_factor = 15000
  5673    vm.watermark_scale_factor = 10
  5674
  5675    ### interrupts:
  5676               CPU0       CPU1       CPU2       CPU3
  5677     17:          0          0          0          0     GICv2  50 Level     timer@1c20c00
  5678     18:          0          0          0          0     GICv2  29 Level     arch_timer
  5679     19:      41081      38938      39893      42308     GICv2  30 Level     arch_timer
  5680     22:         30          0          0          0     GICv2  82 Level     1c02000.dma-controller
  5681     23:       1254          0          0          0     GICv2 118 Level     1c0c000.lcd-controller
  5682     24:          0          0          0          0     GICv2  92 Level     sunxi-mmc
  5683     25:      45993          0          0          0     GICv2  93 Level     sunxi-mmc
  5684     26:      35189          0          0          0     GICv2  94 Level     sunxi-mmc
  5685     27:          0          0          0          0     GICv2 103 Level     musb-hdrc.4.auto
  5686     28:          0          0          0          0     GICv2 104 Level     ehci_hcd:usb1
  5687     29:          0          0          0          0     GICv2 105 Level     ohci_hcd:usb2
  5688     30:          2          0          0          0     GICv2 106 Level     ehci_hcd:usb3
  5689     31:       1494          0          0          0     GICv2 107 Level     ohci_hcd:usb6
  5690     32:          0          0          0          0     GICv2 108 Level     ehci_hcd:usb4
  5691     33:          0          0          0          0     GICv2 109 Level     ohci_hcd:usb7
  5692     34:          0          0          0          0     GICv2 110 Level     ehci_hcd:usb5
  5693     35:          0          0          0          0     GICv2 111 Level     ohci_hcd:usb8
  5694     43:        308          0          0          0     GICv2  32 Level     ttyS0
  5695     44:        646          0          0          0     GICv2 120 Level     1ee0000.hdmi, dw-hdmi-cec
  5696     45:          0          0          0          0     GICv2  72 Level     1f00000.rtc
  5697     47:          0          0          0          0     GICv2  69 Level     sunxi-ir
  5698     48:          2          0          0          0     GICv2  76 Level     mv64xxx_i2c
  5699     50:          0          0          0          0     GICv2  90 Level     1c0e000.video-codec
  5700     51:          0          0          0          0     GICv2 129 Level     gp
  5701     52:          0          0          0          0     GICv2 130 Level     gpmmu
  5702     53:          0          0          0          0     GICv2 131 Level     pp0
  5703     54:          0          0          0          0     GICv2 132 Level     ppmmu0
  5704     55:          0          0          0          0     GICv2 134 Level     pp1
  5705     56:          0          0          0          0     GICv2 135 Level     ppmmu1
  5706     58:       1031          0          0          0     GICv2  63 Level     ths
  5707     59:          0          0          0          0     GICv2 152 Level     arm-pmu
  5708     60:          0          0          0          0     GICv2 153 Level     arm-pmu
  5709     61:          0          0          0          0     GICv2 154 Level     arm-pmu
  5710     62:          0          0          0          0     GICv2 155 Level     arm-pmu
  5711    107:          0          0          0          0  sunxi_pio_edge  44 Edge      usb0-id-det
  5712    130:          1          0          0          0  sunxi_pio_edge   3 Edge      sw4
  5713    IPI0:          0          0          0          0  CPU wakeup interrupts
  5714    IPI1:          0          0          0          0  Timer broadcast interrupts
  5715    IPI2:      19503      38018      48195      30977  Rescheduling interrupts
  5716    IPI3:        455        568        387        349  Function call interrupts
  5717    IPI4:          0          0          0          0  CPU stop interrupts
  5718    IPI5:          0          0          0          0  IRQ work interrupts
  5719    IPI6:          0          0          0          0  completion interrupts
  5720    Err:          0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
Firewall issues, so no -u only -U.
Think about is a Beelink X2 running a Orange Pi+ 2e  image.
Link to comment
Share on other sites
@Tido edited.  Sorry for flooding the thread.
@Igor Yesss! I know is incorrect to switch images in this crazy way but:  the last image for Beelink X2 is too old (normal because is EOS) and also the internal Wi-Fi din't work so I decide to the most similar, under my opinion, OPi+2e : Internal Wi-Fi and eMMC.
So the board starts and run pretty decent. The temperature don't go high (supposing is measure correctly).
If there and easy way to change the hardware configuration I'll do; if not, don't worry.
Thanks for trying to help me.
Link to comment
