FrancescoT Posted March 3, 2019 Posted March 3, 2019 46 minutes ago, Werner said: Check top for load. With 3.10.65 image it stabilizes at 3 which means three of four cores are permanently under full load which also explains the temperature issues. Did not test on OPi3 though as I do not have one but on OPi1+ which comes with H6 as well. 4.17 with initial support for H6 fixed this for me. Oh my, I didn't notice. It's even worse than you describe! I left for half an hour the OPi3 idling and its load average is around 7, with cfinteractive taking 100% of the CPU... I managed to compile the kernel from https://github.com/orangepi-xunlong/OrangePiH6_Linux4.9 but now I have to figure out how to convert the image to u-boot format (this u-boot thing is new to me). @krachlatte did you receive your board? I'd like to help with testing but the instruction here: https://github.com/krachlatte/armbian-orangepi3/blob/master/README.md are not clear to me. I'll try with the latest image from https://github.com/krachlatte/armbian-orangepi3/releases/ 1 Quote
Werner Posted March 3, 2019 Posted March 3, 2019 20 minutes ago, FrancescoT said: @krachlatte did you receive your board? I'd like to help with testing but the instruction here: https://github.com/krachlatte/armbian-orangepi3/blob/master/README.md are not clear to me. A bit unclear, yes. There is a folder userpatches after first run of compile.sh with subfolders for kernel and u-boot. Put the patches there. 0 Quote
obenturk Posted March 3, 2019 Posted March 3, 2019 I just received OPI 3 2G + 8G EMMC and trying your image. I flashed following image https://github.com/krachlatte/armbian-orangepi3/releases/download/v0.11/v0.11_Armbian_5.76_Orangepi3_Ubuntu_bionic_dev_4.20.12.img.bz2 HDMI was on until Loading Kernel written on screen then red power light illuminated. I waited nearly 1 hour but nothing happened. What is the meaning of ages as objective? I will try to help by attaching logs but can someone basicly provide info about how to do it? Note : Image file Armbian_5.59.180824_Orangepioneplus_Ubuntu_bionic_dev_4.18.0-rc7 successfully booted with HDMI & w/o network 0 Quote
Werner Posted March 3, 2019 Posted March 3, 2019 An USB TTL adapter is always handy when handling with SBCs. Like this one: https://www.amazon.de/USB-TTL-Konverter-Modul-mit-eingebautem-CP2102/dp/B00AFRXKFU They are even cheaper from China. This way you can access a serial console without the need of having working ethernet/WiFi or HDMI/any other video output. 0 Quote
hojnikb Posted March 3, 2019 Posted March 3, 2019 a second working sbc can also double as a serial adapter. 0 Quote
obenturk Posted March 3, 2019 Posted March 3, 2019 (edited) Here is the outputs U-Boot says Err: vidconsole Net: No ethernet found. Can someone put HDMI related lines of Armbian_5.59.180824_Orangepioneplus_Ubuntu_bionic_dev_4.18.0-rc7 to OPI3 image? Isn't that much easy? Spoiler U-Boot SPL 2018.09-rc1-armbian (Feb 28 2019 - 21:27:18 +0100) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.0(debug):64503b2 NOTICE: BL31: Built : 21:26:49, Feb 28 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc070f88, model: OrangePi 3 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2018.09-rc1-armbian (Feb 28 2019 - 21:27:18 +0100) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi 3 DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... *** Warning - bad CRC, using default environment Failed (-5) Using device 'sun50i_dw_hdmi', disp_uc_priv=00000000b9f33320 fb=be000000, size=1920 1080 In: serial Out: vidconsole Err: vidconsole Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 13 ms (228.5 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 10 ms (15.6 KiB/s) 19138 bytes read in 35 ms (533.2 KiB/s) 4155 bytes read in 44 ms (91.8 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8821549 bytes read in 908 ms (9.3 MiB/s) 14422024 bytes read in 1471 ms (9.3 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8821485 Bytes = 8.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49796000, end 49fffaed ... OK reserving fdt memory region: addr=4fa00000 size=6b000 Loading Device Tree to 0000000049728000, end 0000000049795fff ... OK Setting up simplefb Cannot setup simplefb: node not found Starting kernel ... Ubuntu 18.04.2 LTS orangepi3 ttyS0 orangepi3 login: root@orangepi3:~# tail -n 100 /var/log/syslog Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.7472] policy: auto-activating connection 'Wired connection 1' Feb 28 20:46:37 localhost kernel: [ 17.700395] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.7508] device (eth0): Activation: starting connection 'Wired connection 1' (564d0e86-3f22-3ab9-855f-bb171bb11410) Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.7516] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.7522] manager: NetworkManager state is now CONNECTING Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.7536] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.7548] device (eth0): state change: config -> failed (reason 'config-failed', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.7556] manager: NetworkManager state is now DISCONNECTED Feb 28 20:46:37 localhost NetworkManager[760]: <warn> [1551386797.7566] device (eth0): Activation: failed for connection 'Wired connection 1' Feb 28 20:46:37 localhost kernel: [ 17.708840] platform 5020000.ethernet eth0: Could not attach to PHY Feb 28 20:46:37 localhost kernel: [ 17.708854] platform 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8391] device (eth0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost kernel: [ 17.794194] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8447] policy: auto-activating connection 'Wired connection 1' Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8484] device (eth0): Activation: starting connection 'Wired connection 1' (564d0e86-3f22-3ab9-855f-bb171bb11410) Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8492] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8498] manager: NetworkManager state is now CONNECTING Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8511] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8520] device (eth0): state change: config -> failed (reason 'config-failed', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8527] manager: NetworkManager state is now DISCONNECTED Feb 28 20:46:37 localhost kernel: [ 17.806182] platform 5020000.ethernet eth0: Could not attach to PHY Feb 28 20:46:37 localhost kernel: [ 17.806196] platform 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) Feb 28 20:46:37 localhost NetworkManager[760]: <warn> [1551386797.8537] device (eth0): Activation: failed for connection 'Wired connection 1' Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8554] device (eth0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost kernel: [ 17.810496] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8616] policy: auto-activating connection 'Wired connection 1' Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8648] device (eth0): Activation: starting connection 'Wired connection 1' (564d0e86-3f22-3ab9-855f-bb171bb11410) Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8656] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8663] manager: NetworkManager state is now CONNECTING Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8676] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8686] device (eth0): state change: config -> failed (reason 'config-failed', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8693] manager: NetworkManager state is now DISCONNECTED Feb 28 20:46:37 localhost kernel: [ 17.822695] platform 5020000.ethernet eth0: Could not attach to PHY Feb 28 20:46:37 localhost kernel: [ 17.822708] platform 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) Feb 28 20:46:37 localhost NetworkManager[760]: <warn> [1551386797.8705] device (eth0): Activation: failed for connection 'Wired connection 1' Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8724] device (eth0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost kernel: [ 17.827538] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8779] policy: auto-activating connection 'Wired connection 1' Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8811] device (eth0): Activation: starting connection 'Wired connection 1' (564d0e86-3f22-3ab9-855f-bb171bb11410) Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8819] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8825] manager: NetworkManager state is now CONNECTING Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8839] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8849] device (eth0): state change: config -> failed (reason 'config-failed', sys-iface-state: 'managed') Feb 28 20:46:37 localhost kernel: [ 17.839025] platform 5020000.ethernet eth0: Could not attach to PHY Feb 28 20:46:37 localhost kernel: [ 17.839037] platform 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8855] manager: NetworkManager state is now DISCONNECTED Feb 28 20:46:37 localhost NetworkManager[760]: <warn> [1551386797.8866] device (eth0): Activation: failed for connection 'Wired connection 1' Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8882] device (eth0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed') Feb 28 20:46:37 localhost kernel: [ 17.843231] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Feb 28 20:46:37 localhost NetworkManager[760]: <info> [1551386797.8942] manager: startup complete Feb 28 20:46:37 localhost systemd[1]: Started Network Manager Wait Online. Feb 28 20:46:37 localhost systemd[1]: Reached target Network is Online. Feb 28 20:46:37 localhost systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemon... Feb 28 20:46:37 localhost systemd[1]: Starting /etc/rc.local Compatibility... Feb 28 20:46:37 localhost systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon. Feb 28 20:46:37 localhost systemd[1]: Started /etc/rc.local Compatibility. Feb 28 20:46:37 localhost systemd[1]: Started Getty on tty1. Feb 28 20:46:37 localhost systemd[1]: Started Serial Getty on ttyS0. Feb 28 20:46:37 localhost systemd[1]: Reached target Login Prompts. Feb 28 20:46:37 localhost systemd[1]: Reached target Multi-User System. Feb 28 20:46:37 localhost systemd[1]: Reached target Graphical Interface. Feb 28 20:46:37 localhost systemd[1]: Starting Update UTMP about System Runlevel Changes... Feb 28 20:46:37 localhost systemd[1]: Started Update UTMP about System Runlevel Changes. Feb 28 20:46:38 localhost polkitd[1369]: started daemon version 0.105 using authority implementation `local' version `0.105' Feb 28 20:46:38 localhost dbus-daemon[694]: [system] Successfully activated service 'org.freedesktop.PolicyKit1' Feb 28 20:46:38 localhost systemd[1]: Started Authorization Manager. Feb 28 20:46:38 localhost systemd[1]: Startup finished in 6.782s (kernel) + 11.409s (userspace) = 18.192s. Feb 28 20:46:44 localhost systemd[1]: Reloading. Feb 28 20:46:45 localhost systemd[1]: Starting resolvconf-pull-resolved.service... Feb 28 20:46:45 localhost systemd[1]: Started resolvconf-pull-resolved.service. Feb 28 20:46:45 localhost systemd[1]: Reloading. Feb 28 20:46:45 localhost systemd[1]: Starting resolvconf-pull-resolved.service... Feb 28 20:46:45 localhost systemd[1]: Started resolvconf-pull-resolved.service. Feb 28 20:46:45 localhost systemd[1]: Stopping OpenBSD Secure Shell server... Feb 28 20:46:45 localhost systemd[1]: Stopped OpenBSD Secure Shell server. Feb 28 20:46:45 localhost systemd[1]: Starting OpenBSD Secure Shell server... Feb 28 20:46:45 localhost systemd[1]: Started OpenBSD Secure Shell server. Feb 28 20:46:46 localhost systemd[1]: Stopping OpenBSD Secure Shell server... Feb 28 20:46:46 localhost systemd[1]: Stopped OpenBSD Secure Shell server. Feb 28 20:46:46 localhost systemd[1]: Starting OpenBSD Secure Shell server... Feb 28 20:46:46 localhost systemd[1]: Started OpenBSD Secure Shell server. Feb 28 20:46:46 localhost armbian-firstrun[764]: Removed /etc/systemd/system/multi-user.target.wants/armbian-firstrun.service. Feb 28 20:46:46 localhost systemd[1]: Reloading. Feb 28 20:46:46 localhost systemd[1]: Starting resolvconf-pull-resolved.service... Feb 28 20:46:46 localhost systemd[1]: Started resolvconf-pull-resolved.service. Feb 28 20:48:19 localhost systemd[1]: Created slice User Slice of root. Feb 28 20:48:19 localhost systemd[1]: Starting User Manager for UID 0... Feb 28 20:48:19 localhost systemd[1]: Started Session 1 of user root. Feb 28 20:48:20 localhost systemd[1868]: Reached target Paths. Feb 28 20:48:20 localhost systemd[1868]: Listening on GnuPG cryptographic agent (ssh-agent emulation). Feb 28 20:48:20 localhost systemd[1868]: Reached target Timers. Feb 28 20:48:20 localhost systemd[1868]: Listening on GnuPG cryptographic agent and passphrase cache (restricted). Feb 28 20:48:20 localhost systemd[1868]: Listening on GnuPG network certificate management daemon. Feb 28 20:48:20 localhost systemd[1868]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers). Feb 28 20:48:20 localhost systemd[1868]: Listening on GnuPG cryptographic agent and passphrase cache. Feb 28 20:48:20 localhost systemd[1868]: Reached target Sockets. Feb 28 20:48:20 localhost systemd[1868]: Reached target Basic System. Feb 28 20:48:20 localhost systemd[1868]: Reached target Default. Feb 28 20:48:20 localhost systemd[1868]: Startup finished in 206ms. Feb 28 20:48:20 localhost systemd[1]: Started User Manager for UID 0. root@orangepi3:~# ifconfig -a lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 root@orangepi3:~# ethtool eth0 Settings for eth0: Cannot get device settings: Device or resource busy Cannot get wake-on-lan settings: Device or resource busy Cannot get message level: Device or resource busy Cannot get link status: Device or resource busy No data available root@orangepi3:~# lsmod Module Size Used by zstd 16384 4 cpufreq_dt 16384 0 sun50i_h6_ths 16384 0 thermal_sys 65536 2 cpufreq_dt,sun50i_h6_ths zram 24576 5 hid_logitech_hidpp 28672 0 hid_logitech_dj 20480 0 dwc3_of_simple 16384 0 Edited March 8, 2019 by Tido added spoiler - for better reading, please do that yourself next time. thx 0 Quote
obenturk Posted March 3, 2019 Posted March 3, 2019 (edited) If I add /etc/network/interfaces.d/eth0 auto lo eth0 allow-hotplug eth0 iface eth0 inet dhcp hwaddress ether ************** It stucks at Starting kernel ... after 6 min it successfully booted still without network Edited March 3, 2019 by obenturk Update 0 Quote
FrancescoT Posted March 3, 2019 Posted March 3, 2019 3 hours ago, hojnikb said: a second working sbc can also double as a serial adapter. Brilliant idea!! I attached an arduino to the OPi3 serial port with an old cdrom audio connector (where I moved a pin in order to have three adjacent pins connected) and three male-male pin cables, now I can see the output 1 Quote
FrancescoT Posted March 3, 2019 Posted March 3, 2019 On 2/28/2019 at 9:35 PM, krachlatte said: v0.11 released and available for download This is the serial port output when booting v0.11: Spoiler U-Boot SPL 2018.09-rc1-armbian (Feb 28 2019 - 21:27:18 +0100) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.0(debug):64503b2 NOTICE: BL31: Built : 21:26:49, Feb 28 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc070f88, model: OrangePi 3 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2018.09-rc1-armbian (Feb 28 2019 - 21:27:18 +0100) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi 3 DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... Failed (-5) Using device 'sun50i_dw_hdmi', disp_uc_priv=00000000b9f33320 sunxi_de3_init: device 'sunxi_de3' display won't probe (ret=-1) Using device 'sun50i_dw_hdmi', disp_uc_priv=00000000b9f33320 sunxi_de3_init: device 'sunxi_de3' display won't probe (ret=-1) In: serial Out: serial Err: serial Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 1 0 => MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Unknown command 'MMC:' - try 'help' => Unknown command 'MMC:' - try 'help' => Loading Environment from FAT... Unable to use mmc 1:1... Failed (-5) Unknown command 'Loading' - try 'help' => Unknown command 'Loading' - try 'help' => Using device 'sun50i_dw_hdmi', disp_uc_priv=00000000b9f33320 Unknown command 'Using' - try 'help' => Unknown command 'Using' - try 'help' => sunxi_de3_init: device 'sunxi_de3' display won't probe (ret=-1) > > Using device 'sun5 Unknown command 'sunxi_de3_init:' - try 'help' => => MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => Loading Environment from FAT... Unable to use mmc 1:1... Failed ( Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => Using device 'sun50i_dw_hdmi', disp_uc_priv=00000000b9f33 Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => sunxi_de3_init: device 'sunxi_de3' display won't probe (ret= > > > > Using device 'su Unknown command '=>' - try 'help' => => => MMC: SUNXI SD/MMC: 0, SUNXI SD/ Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => Loading Environment from FAT... Unable to use mmc 1:1... Faile Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => Using device 'sun50i_dw_hdmi', disp_uc_priv=00000000b9 Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => sunxi_de3_init: device 'sunxi_de3' display won't probe (r > > > > > > Using device > => => => MMC: SUNXI SD/MMC: 0, SUNXI > > => => => Loading Environment from FAT... Unable to use mmc 1:1... Fa > > => => => Using device 'sun50i_dw_hdmi', disp_uc_priv=0000000 > > => => => sunxi_de3_init: device 'sunxi_de3' display won't probe Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => > > > Using devi Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => > => => => MMC: SUNXI SD/MMC: 0, SUN Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => > => => => Loading Environment from FAT... Unable to use mmc 1:1... Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => > => => => Using device 'sun50i_dw_hdmi', disp_uc_priv=0000 Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => > => => => sunxi_de3_init: device 'sunxi_de3' display won't pr > > > > > => > > > Using d > > => > => => => MMC: SUNXI SD/MMC: 0, > > > => > => => => Loading Environment from FAT... Unable to use mmc 1:1 > > > => > => => => Using device 'sun50i_dw_hdmi', disp_uc_priv=0 > > > => > => => => sunxi_de3_init: device 'sunxi_de3' display won't Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => > => > > > Usin Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => > => > => => => MMC: SUNXI SD/MMC: Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => > => > => => => Loading Environment from FAT... Unable to use mmc Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => > => > => => => Using device 'sun50i_dw_hdmi', disp_uc_pri Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help'mand '=>' - try 'help' => => => => > => > => => => MMC: SUNXI Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => > => > => => => Loading Environment from FAT... Unable to Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => > => > => => => Using device 'sun50i_dw_hdmi', di Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => > => > => => => sunxi_de3_init: device 'sunxi_de3' d Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => => > = Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => => > => > => => => MMC: SU Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => => > => > => => => Loading Environment from FAT... Unable Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => => > => > => => => Using device 'sun50i_dw_hdmi', Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => => > => > => => => sunxi_de3_init: device 'sunxi_de3 > > > > > > => => => => => > > > => => => => => > => > => => => MMC: > > > > => => => => => > => > => => => Loading Environment from FAT... Una > > > > => => => => => > => > => => => Using device 'sun50i_dw_hdm Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => => => > => > => => => sunxi_de3_init: device 'sunxi_ > > > > > > > > => => => => > > > > > => => => => => > => > => => => MMC > > > > > > => => => => => > => > => => => Loading Environment from FAT... > > > > > > => => => => => > => > => => => Using device 'sun50i_dw_ Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => => => => > => > => => => sunxi_de3_init: device 'sun > > > > > > > > > > => => => > > > > > > > => => => => => > => > => => => > > > > > > > > => => => => => > => > => => => Loading Environment from FAT. > > > > > > > > => => => => => > => > => => => Using device 'sun50i_ Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => => => => => > => > => => => sunxi_de3_init: device ' > > > > > > > > > > > > => => > > > > > > > > > => => => => => > => > => => > > > > > > > > > > => => => => => > => > => => => Loading Environment from F > > > > > > > > > > => => => => => > => > => => => Using device 'sun5 Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => => => => => => => => => > => > => => => sunxi_de3_init: devic Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => Unknown command '=>' - try 'help' => > > > > => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => Unknown command '>' - try 'help' => > > > > => > > > > > > > > > And then goes on like this 0 Quote
datsuns Posted March 3, 2019 Posted March 3, 2019 I see in the download notes that there is a MAC address issue and I have also experienced it with my testing. Is this a hardware issue or is it on the OS side of things? I also had something similar with the aml-s905x-cc and I seem to remember I partially fixed it by hard-defining a MAC address. If it's on the Armbian side of things I will just wait for the stable build to release but otherwise I would like to fix it if I can. Also, does anybody have a recommended heatsink size or even a specific amazon listing they can point to? 0 Quote
qcasey1 Posted March 3, 2019 Posted March 3, 2019 1 hour ago, datsuns said: Also, does anybody have a recommended heatsink size or even a specific amazon listing they can point to? Heatsinks for the Raspberry Pi will work, although ~1mm small. Copper > aluminum in my experience. Check out AliExpress or eBay 0 Quote
krachlatte Posted March 4, 2019 Posted March 4, 2019 (edited) On 3/3/2019 at 4:49 PM, obenturk said: Here is the outputs U-Boot says Err: vidconsole Net: No ethernet found. Can someone put HDMI related lines of Armbian_5.59.180824_Orangepioneplus_Ubuntu_bionic_dev_4.18.0-rc7 to OPI3 image? Isn't that much easy? U-Boot SPL 2018.09-rc1-armbian (Feb 28 2019 - 21:27:18 +0100) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.0(debug):64503b2 NOTICE: BL31: Built : 21:26:49, Feb 28 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc070f88, model: OrangePi 3 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2018.09-rc1-armbian (Feb 28 2019 - 21:27:18 +0100) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi 3 DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... *** Warning - bad CRC, using default environment Failed (-5) Using device 'sun50i_dw_hdmi', disp_uc_priv=00000000b9f33320 fb=be000000, size=1920 1080 In: serial Out: vidconsole Err: vidconsole Net: No ethernet found. starting USB... did you try to do an insmod realtek, because here it is missing still did not receive the ornagepi 3 to do tests. Edited March 8, 2019 by Tido shorted quote - for better reading 0 Quote
qcasey1 Posted March 4, 2019 Posted March 4, 2019 45 minutes ago, krachlatte said: did you try to do an insmod realtek, because here it is missing still did not receive the ornagepi 3 to do tests. Curious, did you get a shipping update yet? I'll try your image as well if I can figure out my serial drivers 0 Quote
obenturk Posted March 4, 2019 Posted March 4, 2019 (edited) I tried modprobe realtek then /etc/init.d/networking restart root@orangepi3:~# ifup eth0 ifup: waiting for lock on /run/network/ifstate.eth0 Nothing happens I need to stop it ctrl+z root@orangepi3:~# ifconfig -a eth0: flags=4098<BROADCAST,MULTICAST> mtu 1500 ether 72:d6:05:4f:b9:3b txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 17 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 Edited March 4, 2019 by obenturk I forget to add with Armbian_5.59.180824_Orangepioneplus_Ubuntu_bionic_dev_4.18.0-rc7 network lights are illuminating even w/o networking but with your image no lights 0 Quote
max-cldx Posted March 4, 2019 Posted March 4, 2019 @Krachlatte v0.11 ubuntu work USB and works with a usb-ethernet I have compiled the image of debian with your patches but usb does not work. What changes are necessary for the USB? 0 Quote
krachlatte Posted March 5, 2019 Posted March 5, 2019 18 hours ago, max-cldx said: @Krachlatte v0.11 ubuntu work USB and works with a usb-ethernet I have compiled the image of debian with your patches but usb does not work. What changes are necessary for the USB? does that mean usb not working in v0.11 ? still waiting for the package to arive 0 Quote
@lex Posted March 6, 2019 Posted March 6, 2019 (edited) I have watched this thread and decided to check the status of the mainline kernel 5.0 for the H6 with the @Icenowy 's work on top of it. I can say it works really nice (tested on Orange Pi 3 H6): * HDMI * DVFS * Gbps / ethernet I have prepared a blindly DT that should work on Opi 3 H6: https://github.com/avafinger/orangepi-h6-ubuntu-base-minimal/tree/master/dts @Igor , Basically fetch the mainline kernel 5, apply your patch set on top and add/modify my DT. I have tried to add i2c and spi but it did not work as i expected. I had something like this: For the i2c i2c0: i2c@5002000 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x05002000 0x400>; interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C0>; resets = <&ccu RST_BUS_I2C0>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; }; i2c1: i2c@5002400 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x05002400 0x400>; interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C1>; resets = <&ccu RST_BUS_I2C1>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; }; i2c0_pins: i2c0_pins { pins = "PH5", "PH6"; function = "i2c0"; }; i2c1_pins: i2c1_pins { pins = "PD25", "PD26"; function = "i2c1"; }; Default i2c in use (PMIC and possibly HDMI): ls /dev/i2c-* /dev/i2c-0 /dev/i2c-1 i2cdetect -y 0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- UU -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: 30 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: 50 51 52 53 54 55 56 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- For the SPI0: spi0: spi@5010000 { compatible = "allwinner,sun8i-h3-spi"; reg = <0x05010000 0x1000>; interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>; clock-names = "ahb", "mod"; dmas = <&dma 23>, <&dma 23>; dma-names = "rx", "tx"; pinctrl-names = "default"; pinctrl-0 = <&spi0_pins>; resets = <&ccu RST_BUS_SPI0>; status = "disabled"; num-cs = <1>; #address-cells = <1>; #size-cells = <0>; }; spi0_pins: spi0 { pins = "PC0", "PC2", "PC3", "PC5"; function = "spi0"; }; One thing i noticed was some instability on SD card but resorting to 4.19-rc6 clk values fixed it. Regarding the reboot command, i applied the latest ATF power fix (as suggested by @jernej but reboot works exactly as shutdown -h now Edited March 6, 2019 by @lex reboot issue 3 Quote
martinayotte Posted March 6, 2019 Posted March 6, 2019 42 minutes ago, @lex said: I have tried to add i2c and spi but it did not work as i expected. In which way ? your i2c tests seems to work, right ? 42 minutes ago, @lex said: Regarding the reboot command, i applied the latest ATF power fix (as suggested by @jernej but reboot works exactly as shutdown -h now We still have to figure out where is the issue ... In another thread, I've mentioned that PineH64, with the same Armbian scripts, does reboot properly, while OrangePiOnePlus doesn't ... 0 Quote
jernej Posted March 6, 2019 Posted March 6, 2019 I suspect there might be some issue with PMIC, like improper voltage set to some regulator... I noticed also some clock issues, which I'll investigate. 0 Quote
@lex Posted March 6, 2019 Posted March 6, 2019 51 minutes ago, martinayotte said: In which way ? your i2c tests seems to work, right ? The printed info above (i2cdetect -y 0/1) is from the stock kernel, as soon as i added the i2c entries i2c gets lazy and do not detect the device i attach on PH6 and PH5 (Orange Pi One Plus). I added: &i2c0_pins { bias-pull-up; }; just in case. No success. SPI seems to be in the right direction, i tried to drive ili9341 display but kernel complains PC5 is already in use, so i gave up for now. 0 Quote
@lex Posted March 6, 2019 Posted March 6, 2019 (edited) 40 minutes ago, jernej said: issue with PMIC, like improper voltage set to some regulator Possible, do you mean u-boot? I am using old u-boot with old values, will re-check and see if it changes something. Thanks for the tip. Edited March 6, 2019 by @lex no regulators on u-boot 0 Quote
@lex Posted March 6, 2019 Posted March 6, 2019 Forgot to print the dma used: dma: dma-controller@3002000 { compatible = "allwinner,sun50i-a64-dma"; reg = <0x03002000 0x1000>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_DMA>; dma-channels = <8>; dma-requests = <27>; resets = <&ccu RST_BUS_DMA>; #dma-cells = <1>; }; 0 Quote
jernej Posted March 6, 2019 Posted March 6, 2019 8 minutes ago, @lex said: Forgot to print the dma used:  dma: dma-controller@3002000 { compatible = "allwinner,sun50i-a64-dma"; reg = <0x03002000 0x1000>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_DMA>; dma-channels = <8>; dma-requests = <27>; resets = <&ccu RST_BUS_DMA>; #dma-cells = <1>; }; That won't fly. DMA is not the same as in A64. But fear not, I have patches which I plan to send soon (just before I2S stuff): https://github.com/jernejsk/linux-1/commits/h6_i2s 0 Quote
@lex Posted March 6, 2019 Posted March 6, 2019 47 minutes ago, jernej said: improper voltage set to some regulator. These are the changes from H64 and OpiOne+ @@ -161,6 +155,7 @@ regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc-ac200"; + regulator-enable-ramp-delay = <100000>; }; reg_aldo3: aldo3 { @@ -219,7 +214,7 @@ reg_dcdca: dcdca { regulator-always-on; regulator-min-microvolt = <810000>; - regulator-max-microvolt = <1160000>; + regulator-max-microvolt = <1080000>; regulator-name = "vdd-cpu"; }; 0 Quote
@lex Posted March 6, 2019 Posted March 6, 2019 3 minutes ago, jernej said: That won't fly. DMA is not the same as in A64. But fear not, I have patches which I plan to send soon (just before I2S stuff): https://github.com/jernejsk/linux-1/commits/h6_i2s Nice. BTW Do you have mali working on your kernel? 0 Quote
jernej Posted March 6, 2019 Posted March 6, 2019 Just now, @lex said: BTW Do you have mali working on your kernel? Yes, with proprietary userspace blobs. Yesterday I posted initial LibreELEC PineH64 image, so most important things from my perspective already work, although not stable yet. 0 Quote
jernej Posted March 6, 2019 Posted March 6, 2019 BTW, newest U-Boot (2019.01) is the most optimal choice for H6. It correctly detects and sets boards with 3 GiB of RAM. It also has some DRAM stability fixes. The only thing you would lose is simplefb HDMI driver, but Linux 5.0 has initial H6 DRM driver anyway. OrangePi DTs don't have HDMI/DE/TCON nodes, but it should be easy to add them (copy over from PineH64). I didn't do it just because I don't have any OrangePi with H6 for testing. 0 Quote
@lex Posted March 6, 2019 Posted March 6, 2019 48 minutes ago, jernej said: OrangePi DTs don't have HDMI/DE/TCON node The opi3-h6.dts i pointed to already have all the nodes. HDMI works like a charm. Those who will try need to compile the kernel with Wifi and BT enabled. I synced the regulators with H64 but that does not fix the reboot issue. I just noticed the power ON/OFF button works, maybe the H64 does not have this button? Do you have any suggestion about i2c? I will use your dma code and see if i get SPI0 to work. 0 Quote
jernej Posted March 6, 2019 Posted March 6, 2019 3 minutes ago, @lex said: The opi3-h6.dts i pointed to already have all the nodes. HDMI works like a charm. Can you please send that patch upstream? There is no reason to hold it up and you would lower patch count when using newer versions of kernel. 5 minutes ago, @lex said: I just noticed the power ON/OFF button works, maybe the H64 does not have this button? I didn't pay attention to that functionality. 6 minutes ago, @lex said: Do you have any suggestion about i2c? I will use your dma code and see if i get SPI0 to work. No suggestions about I2C or SPI. Maybe just compare registers if they are the same and on same addresses, if you plan to use some non-H6 compatible string. 0 Quote
@lex Posted March 6, 2019 Posted March 6, 2019 2 hours ago, jernej said: Can you please send that patch upstream? Err... Just don't know how to do that... In a proper way I mean. 0 Quote
