Werner Posted July 6, 2020 Posted July 6, 2020 Just now, Flole said: I assume there is no way to just disable the GPU completely? I don't need it at all, so if there is a way to disable it I would give that a try. Try to blacklist panfrost module. 1
Francisco Posted July 6, 2020 Posted July 6, 2020 On 6/24/2020 at 9:02 AM, Francisco said: Thank you all for your answers and tips! The wi-fi works as expected, there is no external network restriction, I plug several devices to the same ethernet port (one at a time, of course). I'll try the serial console messages next. Regarding the "armbianmonitor -U", here's the result: https://pastebin.com/3kBFfhUZ I'll try the serial console next. Thanks again, Francisco I've connected to a 10/100M switch, and now it works. Connected to a 1G switch, it doesn't. Could that be something related to the regulators, also? Thanks, Francisco
Flole Posted July 6, 2020 Posted July 6, 2020 6 minutes ago, Werner said: Try to blacklist panfrost module. That indeed disabled those messages. I have a few more, are those normal and necessary aswell or can I disable something to get rid of them: Quote [ 34.811404] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PD regulator [ 34.811412] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 96 [ 34.811419] sun50i-h6-pinctrl 300b000.pinctrl: pin-96 (5020000.ethernet) status -517 [ 34.811427] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 96 (PD0) from group PD0 on device 300b000.pinctrl [ 34.811433] dwmac-sun8i 5020000.ethernet: Error applying setting, reverse things back [ 34.812121] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PC regulator [ 34.812130] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 65 [ 34.812137] sun50i-h6-pinctrl 300b000.pinctrl: pin-65 (4022000.mmc) status -517 [ 34.812145] sun50i-h6-pinctrl 300b000.pinctrl: could not request pin 65 (PC1) from group PC1 on device 300b000.pinctrl [ 34.812150] sunxi-mmc 4022000.mmc: Error applying setting, reverse things back [ 34.812417] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PC regulator [ 34.812423] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 79 [ 34.812429] sun50i-h6-pinctrl 300b000.pinctrl: pin-79 (300b000.pinctrl:79) status -517 [ 34.814736] sun50i-h6-pinctrl 300b000.pinctrl: Couldn't get bank PD regulator [ 34.814745] sun50i-h6-pinctrl 300b000.pinctrl: request() failed for pin 102 [ 34.814753] sun50i-h6-pinctrl 300b000.pinctrl: pin-102 (300b000.pinctrl:102) status -517 [ 34.815255] sun50i-h6-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pf not found, using dummy regulator
Flole Posted July 16, 2020 Posted July 16, 2020 I think I found the reason for my crashes: I used the ondemand power governor and apparently that caused the issues. Maybe the voltage regulator was set to an invalid level or something. Anyways, since I disabled it and used performance I now have had no crashes, that's an uptime of 8 days now. My absolute record was 14 days so I guess the next weeks will show if that was really the issue or not.
Werner Posted July 16, 2020 Posted July 16, 2020 6 hours ago, Flole said: I think I found the reason for my crashes: I used the ondemand power governor and apparently that caused the issues. Maybe the voltage regulator was set to an invalid level or something. Anyways, since I disabled it and used performance I now have had no crashes, that's an uptime of 8 days now. My absolute record was 14 days so I guess the next weeks will show if that was really the issue or not. Hm @dolphs@martinayotte did you experience these issues too? Should th Orangepi 3 be tweaked to a fixed clock by default?
martinayotte Posted July 16, 2020 Posted July 16, 2020 6 hours ago, Werner said: @martinayotte did you experience these issues too? My OPi3 doesn't suffer such issue, but it is running almost idle every time.
dolphs Posted July 16, 2020 Posted July 16, 2020 same here ( idle most time ) but must admit I always use "conservative" even on the H5 boards. BTW still did not have time to spin up a new build ( rc5 ) , come to that later ( weekend perhaps )
Flole Posted July 16, 2020 Posted July 16, 2020 This is what happened right before a crash, looks like it was adjusting the frequency quite often at that time. I would assume that many frequency adjustments are the cause of it and also that is the only thing I changed and since then it's running super stable. Not even my selfmade power supply that provides 5.25V 3A through the dc jack made a change, I still had the same crashes while the voltage that comes out of the USB ports is super stable (checked with an oscilloscope). Only after switching to the performance governor it started to run stable (at least until now, but's thats already longer than usual).
062621AM Posted July 19, 2020 Posted July 19, 2020 Anyone updated their OrangePi 3 to the latest kernel released? Now my unit won't boot up unless I plug in an SD card with an earlier kernel The details of previous working image:- armbian@orangepi3:~$ lsb_release -a ; uname -a Distributor ID: Ubuntu Description: Ubuntu 20.04 LTS Release: 20.04 Codename: focal Linux orangepi3 5.7.8-sunxi64 #trunk.40 SMP Fri Jul 17 19:09:21 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux I think I need help on how to start troubleshooting this
lanefu Posted July 19, 2020 Posted July 19, 2020 FYI you're running a nightly which is un supported. Try a different kernel via armbian-config
062621AM Posted July 20, 2020 Posted July 20, 2020 45 minutes ago, lanefu said: FYI you're running a nightly which is un supported. Try a different kernel via armbian-config Sorry for asking a newbie question. How do I run armbian-config if I cannot boot up? should I try chroot?
lanefu Posted July 20, 2020 Posted July 20, 2020 20 minutes ago, 062621AM said: Sorry for asking a newbie question. How do I run armbian-config if I cannot boot up? should I try chroot? yep try chroot.
Aquino Posted July 22, 2020 Posted July 22, 2020 On 7/6/2020 at 9:43 AM, Francisco said: I've connected to a 10/100M switch, and now it works. Connected to a 1G switch, it doesn't. Could that be something related to the regulators, also? Thanks, Francisco The problem is on autonegotiation, until solveded in some distro you can use something like : ethtool -s eth0 speed 100 duplex full autoneg off.
bojarin Posted July 23, 2020 Posted July 23, 2020 (edited) Current update to current stable focal server image is broken. Pic after reboot. Edited July 23, 2020 by bojarin
062621AM Posted July 25, 2020 Posted July 25, 2020 On 7/20/2020 at 8:50 AM, lanefu said: yep try chroot. managed to recover after chroot. could you comment if this error is normal? Spoiler armbian@orangepi3:~$ sudo apt-get dist-upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: linux-dtb-current-sunxi64 linux-image-current-sunxi64 2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/31.3 MB of archives. After this operation, 14.9 MB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 70290 files and directories currently installed.) Preparing to unpack .../linux-dtb-current-sunxi64_20.08.0-trunk.43_arm64.deb ... Unpacking linux-dtb-current-sunxi64 (20.08.0-trunk.43) over (20.08.0-trunk.40) ... dpkg: error processing archive /var/cache/apt/archives/linux-dtb-current-sunxi64_20.08.0-trunk.43_arm64.deb (--unpack): trying to overwrite '/boot/dtb-5.7.8-sunxi64/allwinner/overlay/README.sun50i-a64-overlays', which is also in package linux-dtb-dev-sunxi64 20.08.0-trunk.43 Preparing to unpack .../linux-image-current-sunxi64_20.08.0-trunk.43_arm64.deb ... Unpacking linux-image-current-sunxi64 (20.08.0-trunk.43) over (20.08.0-trunk.40) ... dpkg: error processing archive /var/cache/apt/archives/linux-image-current-sunxi64_20.08.0-trunk.43_arm64.deb (--unpack): trying to overwrite '/boot/System.map-5.7.8-sunxi64', which is also in package linux-image-dev-sunxi64 20.08.0-trunk.43 dpkg-deb: error: paste subprocess was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/linux-dtb-current-sunxi64_20.08.0-trunk.43_arm64.deb /var/cache/apt/archives/linux-image-current-sunxi64_20.08.0-trunk.43_arm64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
Werner Posted July 25, 2020 Posted July 25, 2020 Well nightlies can be broken at any time...tried to switch back to stable?
062621AM Posted July 25, 2020 Posted July 25, 2020 1 minute ago, Werner said: Well nightlies can be broken at any time...tried to switch back to stable? Ok. But I think i will stay at trunk.40. No issue with dev trunk.40 so far.
VaclavN Posted August 16, 2020 Posted August 16, 2020 (edited) Sorry for the noob question. I tried to find a toolchain for Orange Pi 3 and couldn't. The sources would also help me, I'm going to work with GPIO from C++. Sunxi tools are not suitable for this board and Armbian. The program cannot be run on Armbian and gdbserver reports that it does not know how to run it. How to write programs for Armbian and orange Pi 3 in C/C++? Edited August 16, 2020 by VaclavN
lanefu Posted August 17, 2020 Posted August 17, 2020 4 hours ago, VaclavN said: Sorry for the noob question. I tried to find a toolchain for Orange Pi 3 and couldn't. The sources would also help me, I'm going to work with GPIO from C++. Sunxi tools are not suitable for this board and Armbian. The program cannot be run on Armbian and gdbserver reports that it does not know how to run it. How to write programs for Armbian and orange Pi 3 in C/C++? First install the kernel headers via armbian config. then you'll want to use libgpiod for interacting with the GPIO
czosnekltd Posted September 30, 2020 Posted September 30, 2020 Do I have to add some modules / patches to the kernel to run HDMI touch display on OPi3? It is a no-name 1024x600 from china display and the image is normal but the touch is not working. Interestingly, this display connected to MeCOOL M8S PRO W (AML 905X chip) with Armbian 20.09 Focal with Linux 5.8.10-arm-64 works fine and that system recognizes the touch panel as: sudo evtest No device specified, trying to scan all of / dev / input / event * (...) / dev / input / event19: wch.cn USB2IIC_CTP_CONTROL Select the device event number [0-19]: 19 Input driver version is 1.0.1 Input device ID: bus 0x3 vendor 0x1a86 product 0xe5e3 version 0x100 Input device name: "wch.cn USB2IIC_CTP_CONTROL" (...) and lsusb root @ arm-64: ~ # lsusb (...) Bus 001 Device 003: ID 1a86: e5e3 QinHeng Electronics USB2IIC_CTP_CONTROL On OP3, the touch panel does not work on any of the Armbian editions.
greg798 Posted November 5, 2020 Posted November 5, 2020 Hi Back problem Im build armbian Armbian_20.11.0-trunk_Orangepi3_bionic_current_5.9.5 and eth0 down, no ip address, no link, how fix this? thanks
Werner Posted November 6, 2020 Posted November 6, 2020 6 hours ago, greg798 said: -trunk Use stable build for now Side note: Ethernet on OPi1+ running 5.9.0-rc5-sunxi64 is just fine.
lanefu Posted November 7, 2020 Posted November 7, 2020 On 11/5/2020 at 6:19 PM, greg798 said: Im build armbian Armbian_20.11.0-trunk_Orangepi3_bionic_current_5.9.5 and eth0 down, no ip address, no link, how fix this? Yep I'm experiencing same thing with 5.9.5 as well as 5.10.0-rc2 on my opi3
lanefu Posted November 7, 2020 Posted November 7, 2020 Issue created https://github.com/armbian/build/issues/2315
anITiot Posted December 7, 2020 Posted December 7, 2020 Hi I had some issues with one-wire and gpio on my OP3 overlays=w1-gpio param_w1_pin=PL10 and on boot it says can't find bank "L" (or simular), PD16 works fine, have not tested with PHxx yet. .
martinayotte Posted December 7, 2020 Posted December 7, 2020 1 hour ago, anITiot said: I had some issues with one-wire and gpio on my OP3 That is because "sun50i-h6-fixup.scr" doesn't handle "L" bank (and "H" bank as well) as you can see here : setenv decompose_pin 'setexpr tmp_bank sub "P(A|C|D|G)\\d+" "\\1"; setexpr tmp_pin sub "P\\S(\\d+)" "\\1"; test "${tmp_bank}" = "A" && setenv tmp_bank 0; test "${tmp_bank}" = "C" && setenv tmp_bank 2; test "${tmp_bank}" = "D" && setenv tmp_bank 3; test "${tmp_bank}" = "G" && setenv tmp_bank 6' Feel free to tweak that script and submit the fix in a PR... EDIT : adding "H" bank should be pretty easy, but for "L" bank, it would be a bit harder since it need to change also the "pinctrl" with some "if" statements : ("L" bank is using "pinctrl@7022000" instead of "pinctrl@300b000" ...) if test -n "${param_w1_pin}"; then setenv tmp_bank "${param_w1_pin}" setenv tmp_pin "${param_w1_pin}" run decompose_pin fdt set /soc/pinctrl@300b000/w1_pins pins "${param_w1_pin}" fdt get value tmp_phandle /soc/pinctrl@300b000 phandle fdt set /onewire@0 gpios "<${tmp_phandle} ${tmp_bank} ${tmp_pin} 0>" env delete tmp_pin tmp_bank tmp_phandle fi if test "${param_w1_pin_int_pullup}" = "1"; then fdt set /soc/pinctrl@300b000/w1_pins bias-pull-up fi
anITiot Posted December 7, 2020 Posted December 7, 2020 35 minutes ago, martinayotte said: That is because "sun50i-h6-fixup.scr" doesn't handle "L" bank (and "H" bank as well) as you can see here : setenv decompose_pin 'setexpr tmp_bank sub "P(A|C|D|G)\\d+" "\\1"; setexpr tmp_pin sub "P\\S(\\d+)" "\\1"; test "${tmp_bank}" = "A" && setenv tmp_bank 0; test "${tmp_bank}" = "C" && setenv tmp_bank 2; test "${tmp_bank}" = "D" && setenv tmp_bank 3; test "${tmp_bank}" = "G" && setenv tmp_bank 6' Feel free to tweak that script and submit the fix in a PR... EDIT : adding "H" bank should be pretty easy, but for "L" bank, it would be a bit harder since it need to change also the "pinctrl" with some "if" statements : ("L" bank is using "pinctrl@7022000" instead of "pinctrl@300b000" ...) if test -n "${param_w1_pin}"; then setenv tmp_bank "${param_w1_pin}" setenv tmp_pin "${param_w1_pin}" run decompose_pin fdt set /soc/pinctrl@300b000/w1_pins pins "${param_w1_pin}" fdt get value tmp_phandle /soc/pinctrl@300b000 phandle fdt set /onewire@0 gpios "<${tmp_phandle} ${tmp_bank} ${tmp_pin} 0>" env delete tmp_pin tmp_bank tmp_phandle fi if test "${param_w1_pin_int_pullup}" = "1"; then fdt set /soc/pinctrl@300b000/w1_pins bias-pull-up fi Thanks for the info, unfort I'm not skilled enough to code, I'm better to find faults/errors/mods and sometimes suggest a solution.
icehot Posted December 14, 2020 Posted December 14, 2020 Hi All!. I have installed Armbian 20.11.3 Buster with Linux 5.9.14-sunxi64 from apt update && apt upgrade. I have problem with ethernet that isn't working, so now I use Wifi but I need ethernet so :). When I do ifconfig eth0 it show eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet6 fe80::2cc3:f331:7442:2701 prefixlen 64 scopeid 0x20<link> ether 02:07:d6:da:1c:89 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 147 bytes 36018 (35.1 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 27 Note device interrupt 27 is new and I think is the problem but I haven't more linux expirience. What can I do? Do you need more info?. Thanks for all!
Werner Posted December 14, 2020 Posted December 14, 2020 1 minute ago, icehot said: ethernet that isn't working, Known issue. I put a few ideas to github but they need testing and I do not own this particular board. 1
icehot Posted December 14, 2020 Posted December 14, 2020 14 minutes ago, Werner said: Known issue. I put a few ideas to github but they need testing and I do not own this particular board. Thanks for the info!. For a newbie... is posibble to downgrade to previos version?. Thnaks again for your time.
