jernej Posted March 10, 2019 Posted March 10, 2019 @martinayotte Please check my edit above. But it may help somehow... 0 Quote
greg798 Posted March 10, 2019 Posted March 10, 2019 20 minutes ago, krachlatte said: i just build the image, so you could give it a try Hi. This img with emmc? I can write etcher? 0 Quote
reciu Posted March 10, 2019 Posted March 10, 2019 30 minutes ago, krachlatte said: hi guys, i just build the image, so you could give it a try... https://github.com/krachlatte/armbian-orangepi3/releases/tag/v0.12 i still did not receive the hardware many thanks so far starting kernel and nothing happend, lcd turn off 0 Quote
FrancescoT Posted March 10, 2019 Posted March 10, 2019 39 minutes ago, krachlatte said: hi guys, i just build the image, so you could give it a try... https://github.com/krachlatte/armbian-orangepi3/releases/tag/v0.12 i still did not receive the hardware many thanks so far This is the serial output from my Opi3 (it has a eMMC). No light turn on. v0.12_Armbian_5.76_Orangepi3_Ubuntu_bionic_dev_4.20.12.log 0 Quote
greg798 Posted March 10, 2019 Posted March 10, 2019 16 minutes ago, FrancescoT said: No light turn on.  after update 0.11 also had no boot 0 Quote
@lex Posted March 12, 2019 Posted March 12, 2019 On 3/6/2019 at 11:10 AM, @lex said: I have tried to add i2c and spi but it did not work as i expected. Just an update to i2c and spi. The pin node definition i2c0 and i2c1 are reversed. It works. (5.0.1) So i think it is safe to assume i2c and spi are working, just need someone with better experience with the spi LCD to find the right DT configuration for the mainline 5.0.y . Hope this help. i2cdetect -l i2c-3 i2c DesignWare HDMI I2C adapter i2c-1 i2c mv64xxx_i2c adapter I2C adapter i2c-2 i2c mv64xxx_i2c adapter I2C adapter i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- 3d -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- 0 Quote
Frank Kettenbeil Posted March 12, 2019 Posted March 12, 2019 Update: I checked out from the original repo now. Works like a charm. - Was using Krachlatte's fork before and this was not maintained any more... Now on bionic desktop. -- Hi all, I've been watching this thread for some time now and tried myself to work with armbian build tools. Got u-boot and the message "booting kernel" - afterwards the screen (HDMI) went blank. Only some LEDs still flickered (also Ethernet), but no DHCP address was assigned by my router - so I could not see, if anything is up or reach the Opi3. Can anyone point me to a link, where I see, if and how to apply any userpatches or anything else for this device? Or is already everything updated regulary when I call "compile.sh"? Thanks for your support! Best regards 0 Quote
megi Posted March 12, 2019 Posted March 12, 2019 I have a working Orange Pi 3 branch here: https://github.com/megous/linux I haven't tried HDMI yet, but most of the other stuff works, incl. ethernet. 0 Quote
lanefu Posted March 12, 2019 Posted March 12, 2019 48 minutes ago, megi said: I have a working Orange Pi 3 branch here: https://github.com/megous/linux I haven't tried HDMI yet, but most of the other stuff works, incl. ethernet. LOL yeah uhmm your branch is kind of the goto for the orangepi buildshttps://github.com/armbian/build/blob/master/config/sources/sun50iw6.conf#L54 0 Quote
martinayotte Posted March 12, 2019 Posted March 12, 2019 1 minute ago, lanefu said: your branch is kind of the goto for the orangepi builds Right ! ... and it will soon be on 5.0.y ... 1 Quote
megi Posted March 12, 2019 Posted March 12, 2019 15 minutes ago, martinayotte said: Right ! ... and it will soon be on 5.0.y ... It needs modifications to the H6 OPP table, becase Icenowy told me, that the current table is for the best/fastest H6 SoC bins only. 0 Quote
martinayotte Posted March 12, 2019 Posted March 12, 2019 1 minute ago, megi said: So, no hurry. Of course ... But most of my Allwinnner boards from my park/garden are now running 5.0.y from your branch. The only left, and for only couple of hours, are the H6 ... 0 Quote
jernej Posted March 12, 2019 Posted March 12, 2019 2 hours ago, megi said: I haven't tried HDMI yet, but most of the other stuff works, incl. ethernet. It's present in 5.0, but just for PineH64. Just add DT bits for OrangePi 3 and it should work. BTW, if you'll create patches, please send them upstream. 0 Quote
megi Posted March 12, 2019 Posted March 12, 2019 2 hours ago, jernej said: It's present in 5.0, but just for PineH64. Just add DT bits for OrangePi 3 and it should work. BTW, if you'll create patches, please send them upstream. Yes, HDMI works. Enabling it in DTS + the a64-de2 bus in config is enough. 1 Quote
martinayotte Posted March 12, 2019 Posted March 12, 2019 1 hour ago, megi said: Yes, HDMI works. Enabling it in DTS + the a64-de2 bus in config is enough. Thanks ! Good to know ! Since I'm preparing Armbian-DEV to switch to 5.0.y, I've simply added it to OPiLite2 and OPiOne+, and it works (at least in plain text console) ! 3 Quote
NicoD Posted March 16, 2019 Posted March 16, 2019 On 3/12/2019 at 10:31 PM, martinayotte said: Since I'm preparing Armbian-DEV to switch to 5.0.y, I've simply added it to OPiLite2 and OPiOne+, and it works (at least in plain text console) ! Great job. I've built Armbian_5.77_Orangepi3_Ubuntu_bionic_dev_5.0.1_desktop, and I finally can see the potential of this SoC. It now outperforms all my other quad-core SBC's. Thermals are ok, even without a fan it's very workable. It does seem that the heat can't dissipate well into the heatsink, I think this SoC is a bit too small. With a short 7z benchmark is quickly goes up to 75°C. But the heatsink doesn't warm up. When done it immediatly goes back to 45°C. So it can't deliver the heat into the heatsink. Maximum display resolution is 1024x768. On-board wifi doesn't work, but my dongles worked immediatly. Also no hdmi sound. Just for fun I tried Youtube. And it plays great in 1080p with Firefox. Don't know if this would be the same with a true 1080p display resolution. I'm very happy seeing a better performing image for it. What a difference with the images from Orange Pi. The SoC could use a metal casing to better dissipate the heat, otherwise it looks good. Thank you. 3 Quote
lanefu Posted March 16, 2019 Posted March 16, 2019 1 hour ago, NicoD said: Maximum display resolution is 1024x768. On-board wifi doesn't work, but my dongles worked immediatly. Also no hdmi sound. Just for fun I tried Youtube. And it plays great in 1080p with Firefox. Don't know if this would be the same with a true 1080p display resolution. yah i was shocked myself.... see if this helps https://docs.armbian.com/Hardware_Allwinner/#how-to-reconfigure-video-output 0 Quote
jernej Posted March 16, 2019 Posted March 16, 2019 It seems that OrangePi 3 has DDC_CEC_EN signal (pin PH2), which has to be enabled in order to read out EDID. Can someone try to enable it by hand and then re-plug hdmi to see if it helps? Correct solution would be to extend HDMI driver with additional DDC power supply or gpio property, like it's done here: https://github.com/Icenowy/linux/commits/h6-hdmi (IMO power supply is more appropriate solution). 3 Quote
lanefu Posted March 16, 2019 Posted March 16, 2019 2 hours ago, jernej said: It seems that OrangePi 3 has DDC_CEC_EN signal (pin PH2), which has to be enabled in order to read out EDID. Can someone try to enable it by hand and then re-plug hdmi to see if it helps Interesting. I bet its the same case with my oneplus 0 Quote
Frank Kettenbeil Posted March 17, 2019 Posted March 17, 2019 (edited) So running my Opi3 on Armbian_5.77_Orangepi3_Ubuntu_bionic_dev_5.0.1_desktop.img works stable with HDMI@1024/768, . @martinayotte: Thank you very much for your work! I saw now, that - eth0 connection is still on 10 Mbps (is there anything we could do about this?) - wlan interface is not available - but there seems to be an implementation for H6 already - could we use this in any way? - Bluetooth is not available - Sound is not available Furthermore I was not able to install docker up to now on top of this image - is there any restriction doing so, or can you provide any pointer to a working docker solution? Update 21.3.19: found out now, that docker can easily be installed in armbian-config. BTW if you have any needs, please feel free to download the bionic image file from (new build from 20.3.19:) https://cloud.multivalenzen.de/s/2k36y6QeHrnZHbx build outdated - no longer available! Edited March 27, 2019 by Frank Kettenbeil File no longer available 0 Quote
martinayotte Posted March 17, 2019 Posted March 17, 2019 2 hours ago, Frank Kettenbeil said: - wlan interface is not available - but there seems to be an implementation for H6 already - could we use this in any way? WiFi is working on OPi3, but you need to manually tweak the firmware and reboot : mv /lib/firmware/brcm/brcmfmac43455-sdio.bin /lib/firmware/brcm/brcmfmac43455-sdio.bin-ORIG mv /lib/firmware/brcm/brcmfmac43455-sdio.txt /lib/firmware/brcm/brcmfmac43455-sdio.txt-ORIG cp /lib/firmware/rkwifi/fw_bcm43456c5_ag.bin /lib/firmware/brcm/brcmfmac43455-sdio.bin cp /lib/firmware/rkwifi/nvram_ap6256.txt /lib/firmware/brcm/brcmfmac43455-sdio.txt 1 Quote
062621AM Posted March 17, 2019 Posted March 17, 2019 On 3/16/2019 at 11:32 AM, lanefu said: yah i was shocked myself.... see if this helps https://docs.armbian.com/Hardware_Allwinner/#how-to-reconfigure-video-output i did the following but the screen resolution remain at 1024 x 768: sudo nano /boot/boot.cmd - add -+- setenv video-mode sunxi:1920x1080,monitor=hdmi,hpd=0,edid=1 -+- saveenv Then sudo mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr sudo reboot If reboot, all the LEDs turn off and it won't boot up. Need to unplug and plug the power adapter. 4 hours ago, martinayotte said: WiFi is working on OPi3, but you need to manually tweak the firmware and reboot : mv /lib/firmware/brcm/brcmfmac43455-sdio.bin /lib/firmware/brcm/brcmfmac43455-sdio.bin-ORIG mv /lib/firmware/brcm/brcmfmac43455-sdio.txt /lib/firmware/brcm/brcmfmac43455-sdio.txt-ORIG cp /lib/firmware/rkwifi/fw_bcm43456c5_ag.bin /lib/firmware/brcm/brcmfmac43455-sdio.bin cp /lib/firmware/rkwifi/nvram_ap6256.txt /lib/firmware/brcm/brcmfmac43455-sdio.txt First time built an image. Did the commands above but I can't detect any WiFi network. If reboot, all the LEDs turn off and it won't boot up. Need to unplug and plug the power adapter. 0 Quote
lanefu Posted March 17, 2019 Posted March 17, 2019 2 hours ago, 062621AM said: i did the following but the screen resolution remain at 1024 x 768: sudo nano /boot/boot.cmd - add -+- setenv video-mode sunxi:1920x1080,monitor=hdmi,hpd=0,edid=1 -+- saveenv Then sudo mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr sudo reboot If reboot, all the LEDs turn off and it won't boot up. Need to unplug and plug the power adapter. yeah apparently the u-boot params don't work and needs like a hardcoded change in u-boot for the hardset to work according to the sunxi wiki. See https://forum.armbian.com/topic/9368-orangepi-3-h6-allwiner-chip/?do=findComment&comment=74731 also re: reboot... known issue 0 Quote
martinayotte Posted March 17, 2019 Posted March 17, 2019 2 hours ago, 062621AM said: Need to unplug and plug the power adapter. Almost all H6 boards have problem with "reboot" command, we din't find solution yet, we need to re-cycle power to reboot. 1 Quote
lanefu Posted March 17, 2019 Posted March 17, 2019 13 minutes ago, martinayotte said: Almost all H6 boards have problem with "reboot" command, we din't find solution yet, we need to re-cycle power to reboot. I'm almost tempted to power it through a NC relay... I wonder if i could get the gpio to trip late enough in shutdown process to reboot 0 Quote
martinayotte Posted March 17, 2019 Posted March 17, 2019 30 minutes ago, lanefu said: I wonder if i could get the gpio to trip late enough in shutdown process to reboot Yes, it can be done ... Look at <kerneldir>/kernel/reboot.c But we need to actually find the real issue in U-boot ... 1 Quote
062621AM Posted March 18, 2019 Posted March 18, 2019 To get the latest update, do I need to build a new image or sudo apt upgrade is enough? 0 Quote
ImmortanJoe Posted March 18, 2019 Posted March 18, 2019 I don't know the usual method for rebooting the Allwinner chipsets in Linux. I know the H3 had a register for it, but could also be reset by configuring the mode of the watchdog timer to reset, setting the WDT and letting it trip. Could that work in H6? 0 Quote
Frank Kettenbeil Posted March 18, 2019 Posted March 18, 2019 On 3/17/2019 at 2:12 PM, martinayotte said: WiFi is working on OPi3, but you need to manually tweak the firmware and reboot : mv /lib/firmware/brcm/brcmfmac43455-sdio.bin /lib/firmware/brcm/brcmfmac43455-sdio.bin-ORIG mv /lib/firmware/brcm/brcmfmac43455-sdio.txt /lib/firmware/brcm/brcmfmac43455-sdio.txt-ORIG cp /lib/firmware/rkwifi/fw_bcm43456c5_ag.bin /lib/firmware/brcm/brcmfmac43455-sdio.bin cp /lib/firmware/rkwifi/nvram_ap6256.txt /lib/firmware/brcm/brcmfmac43455-sdio.txt Sorry, there is no change visible to me after doing this. - Are there any further steps needed to have the wifi device available? Where are these firmware files activated or used? 0 Quote
