  2. Hello! I have a follow-up question about installing Armbian on a Raspberry Pi 5, and hopefully this is a good place for it. Perhaps this belongs here instead: I just installed the Armbian/Gnome version for Raspberry Pi "4b", as mentioned above, for my Raspberry Pi 5. The OS booted fine and is running. However, I'm trying to install some additional software (specifically this: https://github.com/sunfounder/pipower5/tree/main) and I'm getting errors related to installing the right version of `linux-headers`, the output of `uname`, and possibly the `bcm2711` vs. `bcm2712` CPU. The original error was: ``` Error: E: Unable to locate package linux-headers-6.18.9-current-bcm2711 E: Couldn't find any package by glob 'linux-headers-6.18.9-current-bcm2711' E: Couldn't find any package by regex 'linux-headers-6.18.9-current-bcm2711' ``` When I searched for the available packages, I found the following "closest" options: ``` linux-headers-current-bcm2711/noble 26.2.1 arm64 [upgradable from: 26.2.1] Armbian Linux current headers 6.18.10-current-bcm2711 linux-headers-current-bcm2712/noble 24.11.1 arm64 Armbian Linux current headers 6.6.63-current-bcm2712 ``` At this point, I realized that the installation scripts were pulling the kernel version from the output of `uname`: ``` denbro@rpi5b:~$ uname -r 6.18.9-current-bcm2711 denbro@rpi5b:~$ uname -a Linux rpi5b 6.18.9-current-bcm2711 #1 SMP PREEMPT Mon Feb 9 10:54:02 UTC 2026 aarch64 aarch64 aarch64 GNU/Linux ``` My two main questions are: 1. Why is the proper linux header not available? My understanding is that, in principle, `linux-headers-$(uname -r)` should always be available. 2. Should I be concerned that my linux kernel thinks it is using the bcm2711 CPU? That's the Pi 4 CPU, but my raspberry pi 5 has a bcm2712. Should I install the version of armbian for the Pi 500? Two additional notes - 1. The Sunfounder software I mentioned above installed without issue on the same device running Raspberry Pi OS Trixie. 2. I originally tried to flash an SD card with Armbian using Raspberry Pi Imager, and it wouldn't boot; the device turned on, and printed a bunch of startup output, and then shut off. After confirming that the SD card worked, I switched to using Armbian Imager to flash the SD card and that led to my current state. ``` denbro@rpi5b:~$ neofetch ##### denbro@rpi5b ####### ------------ ##O#O## OS: Armbian 26.2.1 noble aarch64 ####### Host: Raspberry Pi 5 Model B Rev 1.1 ########### Kernel: 6.18.9-current-bcm2711 ############# Uptime: 1 hour, 25 mins ############### Packages: 1200 (dpkg) ################ Shell: bash 5.2.21 ################# Resolution: 1280x800 ##################### Terminal: /dev/pts/1 ##################### CPU: (4) @ 2.400GHz ################# Memory: 691MiB / 3983MiB ``` Let me know if there's any other information I can provide, and thanks in advance for any guidance!
  3. guess it kernel/driver issue The driver does not request the stmmaceth (emac1-25M) clock during probe. Without this clock the MDIO bus does not function on cold boot - PHY ID reads as 0x00000000 and kernel falls back to Generic PHY instead of YT8531. Ethernet does not work until warm reboot.
  4. I've just installed Ubuntu KDE vendor image and now the proper refresh rates are detected. Thank you However, now it seems video players are not working properly. No HW decoding and no audio. It works if I play youtube videos through via Chrome though Strange thing is that after the clean installation, lots of basic KDE packages were missing (dolphin, Konsole, mpv, etc), which I had to install via apt. After that I also performed a apt full-upgrade, but it didnt solve the problem Tried to play h264 and 265 with no success I add some logs, but feel free to request more if they may help
  5. I have a Orange Pi Zero 3 4GB Board. It uses a Micron LPDDR4X RAM and H618 Processor. I have tried a plethora of distros and tried to change Uboot and DTB but unable to make it work. Spent days on Gemini and Claude but no luck. Below is the output from UART debuggger: The Highlight being Unhandled Exception EL3. U-Boot SPL 2025.04-armbian-2025.04-S3482-Pf089-H8869-V3d5b-Bb703-R448a-dirty (May 25 2025 - 14:46:18 +0000) DRAM base address is defined as 0x40000000 DRAM has 16 b/raw, 10 b/col, 4 B/width, 2 #rank and 8 #bank DRAM top address must be less than 0x100000000 DRAM: 4096 MiB Trying to boot from MMC1 Unhandled Exception in EL3. uart_opizero3.txt
  6. how to enable KVM on Armbian ?
  7. I think most important is that people make sure they can fix their own issues if a HW/computer fails. I found high-availability interesting, but for just my house (or even 2 places/countries at the same time) I found it too much to make it all work. The thing I could maybe use is DRDB, however I see v9 is under development since 2011 and it still is not in mainline kernel. Compared to that I have some script to transfer latest differential Btrfs snapshot from 1 computer to the other on-the-fly, I doubt I can really benefit from DRDB, but maybe I set up a test and see what it does. I use only ARM64 for 24/7 servers, so no x86_64 <=> ARM64 incompatibility. So same as for ZFS for example, it is external to Linux distro and my experience is that complicated issues/failures always happen at the wrong moment, e.g. also no internet and/or mains power failure etc. So I try to minimize the amount of 'external' HW/SW modules, certainly if the backing company is commercial and in whatever country far away from where I am. Proxmox is nice, but also 'external'. Same for even Docker, so I have actually no such containers. But it all depends on how much you are involved in various HW and SW. As you can see in my earlier message, I already forgot HA was available as generic aarch64 image, so that says enough. I use several custom (own) HW (like 'changed' solar inverter) and HomeAssistent does not support it, so I actually do not really use it. It is mostly C-code and Node-RED in conjunction with various micro-controllers. A good test is to disconnect internet (power-off fiber-RJ45 box in my case) and/or also do an ad-hoc power cut (no cheating with UPS). And then see if you can get it all running again within a certain time frame (what you think is acceptable, like before temperature in freezer gets > -10 or so).
  8. @humanus You are a very nice guy!
  9. Hi team, I am on the latest vendor release of gnome installed via armbian installer. Kernel is linux-image-6.1.115-*-rk2410. When I look for audio drivers I do not see card 3: rockchiphdmiin [rockchip,hdmiin], device 0: fddf8000.i2s-dummy_codec hdmiin-dc-0 [fddf8000.i2s-dummy_codec hdmiin-dc-0] Subdevices: 1/1 Subdevice #0: subdevice #0 I got the board very recently and the forum is a little mesay about the hdmi rx functionality. It would be a great help if anyone can help me out on this, let me know if i am missing anything.
  10. Yesterday
  11. Hi @Tavares R You should definetly check the "Media framework installer v0.1" by Jock, on this link -> https://forum.armbian.com/topic/34923-csc-armbian-for-rk322x-tv-box-boards/page/10/#comment-102655 Also, this other link contains a repo to install some patched libs to at least use decoded video -> https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/ Hope it helps, but reality check is the rk3229 is just too weak to properly handle a full DE running a modern browser... Something also worth trying is to enable the "cpu-hs" overlay. it will "overclock" the rk3229 from 1200Mhz to 1400Mhz, giving some extra performance, but keep low expectations... PS: Are you brazillian by any means? Tavares is a very common last name in Brazil.
  12. @Morales Morales when I have more free time.. busy with work the next couple of months.
  13. @Droll, something worth to check out is the SMB version your server is running... They have slightly different authentication, so the mount command differs a bit: SMBV1: sudo mount -t cifs -o vers=1.0,username=your_username,password=your_password //server_ip/share_name /mnt/myshare SMBV2: sudo mount -t cifs -o vers=2.0,username=your_username,password=your_password //server_ip/share_name /mnt/myshare
  14. Suggestions will be very appreciated.
  15. @Arthur Gu Thank you for the effort and congratulations for your success. I will try it in the next days.
  16. yet still giving enough to write a answer. flaming over LPEs (or any vulnerability) does not solve any issues. I suggest to read the license again to get a clue who's responsible about fixing things in general: https://github.com/armbian/build/blob/5e60c0183d035bfd5179373e1eac284790e08904/LICENSE#L265-L268 Both parties also shall read the terms of use again, the very first bullet point in particular. I will not give this hint a second time. fixes will land upstream, stable builds will adapt four times a year. For everyone wants things faster, options were provided.
  17. @Levy Barbosa I was able to boot and install! Instructions Download Armbian from: https://www.armbian.com/boards/aml-s9xx-box Use: - Debian 13 (Trixie) Minimal - Current kernel (6.18.26) Create bootable USB with Rufus/Balena Etcher. S805X-P241 Specific Changes After writing the image, before booting: 1. Set correct DTB - Open armbi_boot partition - Edit extlinux/extlinux.conf - On line 4, change DTB to: meson-gxl-s805x-p241.dtb 2. Set correct u-boot - In armbi_boot, copy u-boot-s905x-s912 - Rename copy to u-boot.ext 3. Boot - Insert USB into USB2 port (closest to power input) - Hold reset button (between USB ports) while applying power - Release after 15 seconds First Login Username: root Password: 1234 Change password when prompted. Notes - Wi-Fi works - Ethernet is 100 Mbps
  18. TV Box Name: Intelbras IzyPlay Board name: DV8038 CPU: Amlogic S805X (GXL Meson, Rev D) Armbian build file name: Armbian_community_26.2.0-trunk.821_Aml-s9xx-box_trixie_current_6.18.26_minimal.img.xz DTB file used: meson-gxl-s805x-p241.dtb Kernel Version: 6.18.26-current-meson64 Distribution Installed: Debian 13 (Trixie) Working Ethernet: Yes Max Ethernet Speed that works: 100 Mbps Does wifi work: Yes Does bluetooth work: No Does HDMI audio work: Not tested (headless setup) Additional Comments: - Board has 1GB RAM (908MB available) and 7.3GB eMMC - HDMI output works (tested on a DELL P2219H) - Reset button is between USB1 and USB2 ports - USB2 port is required for booting (closest to power input) - To boot from USB: hold reset button while applying power, release after 15 seconds
  19. https://github.com/hillac/jetson-nano-armbian-build/blob/main/jetson-armbian-26.md I got a 26 trixie image with the 6.18.29 kernel booting headless. No hdmi. Boot logs over uart were showing 'tegra-pmc 7000e400.pmc: failed to get resets for venc: -517' so I just removed the problem reset from venc in the dtb. This reset was in the dtb for the working 23.8.1 image, so it's not the root cause, but at least it boots properly.
  20. Last week
  21. You shouldn't be getting into android recovery. How did you burn the image to the SD card? On what platform? The fact that I'm seeing things like "System Volume Information" and "box-config" which aren't directories that should exist on an Armbian image, it looks like something strange has happened to your SD card image.
  22. See how Tyr moves beyond MCU firmware boot to build the group, queue, VM, submission, and completion paths needed to run real Vulkan workloads on Mali CSF GPUs. View the full article
  23. @Joao Cordeiro Thanks for your reply. You are right, Amlogic S905X3 seems to be a good hardware without much issue for running Linux servers.
  24. Glad that you got it fixed and figured out a way to set this up. 🙌. I went with similar method, used USB Male to Male cable, Factory Flash Tool and maskrom pins to load the image that I have mentioned in above post, However I am still stuck with no HDMI and LED Display is not showing the clock, but a script which shows the IP address. This was part of the image created by the one who complied it. If you could share steps to get the one that is working (HDMI, Clock, Etc.,) for you would be helpful.
  25. You have the lspci verbose output so you can work back to get the non-verbose output as well. Should I have anything connected to the PCI lane or not? I know my USB devices work, at least with the internal controller, the question was about what exactly is the output/situation you need me to test.
  26. I see it is this board, quite new: http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/details/Orange-Pi-4A.html You can see at https://github.com/armbian/build/commits/main/config/boards/orangepi-4a.csc that no manintainer is defined, so up to yourself to figure out what is wrong. You need to start with attaching a serial debug cable (see 3 pins next to power key) Also I see this board has SPI-flash, there might be an old U-Boot variant in there that does not work together with mainline based 7.0.x kernel.
  27. To my knowledge, there are two versions of this device: the "old" version and the new version, which has a 6031 Wi-Fi chip. Here are the two DTS files extracted from the original android tv firrmware for each hardware version. Hope it helps. Tanix_TX1_6031_DTS.txt Tanix_TX1_DTS.txt
